[SOLVED] Another issue with upgrading to SP1 (0x80073712)
Excellent. There are still many more to replace but we should get an updated list of them. Please follow the instructions below.
We were able to source some more but many of them we can't. Please run the following scan on your system and post the results.
Step#1 - SFCFix Script
Hi szega -
Unfortunately there are simply too many missing payload files to fix. Your best option would be to do a repair install. Do you have your Windows 7 (without service pack) install media?
Hi szega -
Maybe I have it somewhere... do you belive that would work? If you don't have time to compose those fix packs I understand that, but it was fine with me doing step by step...
Yes I do believe that should work. It's really the only option at this point.
It has nothing to do with the time that it would take to acquire the missing files. We've identified some files that we simply can't source. They were updates that came out and may have been pulled or revised so the update is no longer available to pull down and get the files. It's unfortunately but sometimes happens. I've even asked other helpers here at Sysnative and the they concur.
I see.
Then I will have a look if I still have that Win7 somewhere, and if I will find it will give a try.
Anyways, I appreciate your help, thank you very much.
So if I understood correctly, the pre SP1 Win7 installer I should just use for a reapair, follow the instructions what you linked and then I should be able to upgrade to SP1?
OK, let me know how it goes.
So, I made some free space on C:\, started to launch the WIN installer and an error message comes up that I can't downgrade from a 64bit sys to a 32bit and I can't upgrade from a 32 to 64 bit system.
Well, it's funny, 'cause I have 64bit installed, up and running for years, and now shows me this. And why does it show me both ways? Upgrade and downgrade too? I don't get it....
So to confirm the DVD that you have is a Windows 7 x64 DVD with No Service Pack correct? Do you know if it is Home, Premium, Professional?
It's Win 7 Ultimate without SP1, you can pick which version you want, I choose x64 always.
Can you provide the exact message that comes up when you try to run the installer?
A Firefox HTML Document is created with following text: (it's in hungarian, try google translater)
%5CUsers%5Cszega%5CAppData%5CRoaming%5CMicrosoft%5Cwindows%5Cupgrade%5Cimages%5Calert.gif
A következő problémák akadályozzák a Windows frissítését. Szakítsa meg a telepítést, fejezze be az egyes feladatokat, majd indítsa újra a frissítést.
  • [*] A Windows 64 bites verzióját nem frissítheti 32 bites verzióra. A frissítéshez szerezze be a Windows 64 bites verziójának telepítőlemezét, vagy csatlakozzon az internethez, és megtudhatja, hogyan telepítheti a Windows 7 operációs rendszert fájljai és beállításai megtartásával.
    [*] A Windows 32 bites verziója nem frissíthető 64 bites verzióra. Szerezze be a Windows-telepítőlemez 32 bites verzióját.
%5CUsers%5Cszega%5CAppData%5CRoaming%5CMicrosoft%5Cwindows%5Cupgrade%5Cimages%5Cwarning.gif
A Windows frissítése a következő eszközökre és/vagy programokra lesz hatással:
  • Lehet, hogy ezek az eszközök a frissítést követően nem fognak megfelelően működni. Javasoljuk, hogy előbb frissítse az eszközök illesztőprogramjait. Szakítsa meg a telepítést, nyissa meg a Vezérlőpultot, és keresse az "eszközillesztők frissítése" kifejezést, vagy az eszköz gyártójának webhelyén keresse meg a frissített illesztőprogramokat.
    • [*] Tárolóvezérlők: AXJDCPLA IDE Controller
      [*] Hálózati kártyák: Microsoft Virtual WiFi Miniport Adapter #2
