Microsoft (R) Windows Debugger Version 10.0.17763.132 AMD64
Loading Dump File [C:\Users\PalmDesert\_jcgriff2_\dbug\__Kernel__\090519-9515-01\090519-9515-01.dmp]
************* Path validation summary **************
Response Time (ms) Location
Deferred SRV*c:\symbols*http://msdl.microsoft.com/download/symbols
Symbol search path is: SRV*c:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 10 Kernel Version 18362 MP (12 procs) Free x64
Built by: 18362.1.amd64fre.19h1_release.190318-1202
Machine Name:
Kernel base = 0xfffff806`71c00000 PsLoadedModuleList = 0xfffff806`720432f0
Debug session time: Thu Sep 5 16:25:14.887 2019 (UTC - 4:00)
System Uptime: 21 days 22:26:47.740
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
BugCheck 50, {ffffb54176e5a5b1, 2, fffff80671dcf980, 2}
Could not read faulting driver name
*** ERROR: Module load completed but symbols could not be loaded for win32k.sys
Probably caused by : memory_corruption ( nt!MiSystemFault+1d2ee4 )
Followup: MachineOwner
Processing initial command '!analyze -v;r;kv;lmtn;lmtsmn;.bugcheck'
3: kd> !analyze -v;r;kv;lmtn;lmtsmn;.bugcheck
PAGE_FAULT_IN_NONPAGED_AREA (50)
Invalid system memory was referenced. This cannot be protected by try-except.
Typically the address is just plain bad or it is pointing at freed memory.
Arguments:
Arg1: ffffb54176e5a5b1, memory referenced.
Arg2: 0000000000000002, value 0 = read operation, 1 = write operation.
Arg3: fffff80671dcf980, If non-zero, the instruction address which referenced the bad memory
address.
Arg4: 0000000000000002, (reserved)
Debugging Details:
KEY_VALUES_STRING: 1
STACKHASH_ANALYSIS: 1
TIMELINE_ANALYSIS: 1
DUMP_CLASS: 1
DUMP_QUALIFIER: 400
BUILD_VERSION_STRING: 18362.1.amd64fre.19h1_release.190318-1202
DUMP_TYPE: 2
BUGCHECK_P1: ffffb54176e5a5b1
BUGCHECK_P2: 2
BUGCHECK_P3: fffff80671dcf980
BUGCHECK_P4: 2
READ_ADDRESS: fffff8067216e3b0: Unable to get MiVisibleState
Unable to get NonPagedPoolStart
Unable to get NonPagedPoolEnd
Unable to get PagedPoolStart
Unable to get PagedPoolEnd
ffffb54176e5a5b1
FAULTING_IP:
nt!memset+0
fffff806`71dcf980 488bc1 mov rax,rcx
MM_INTERNAL_CODE: 2
CPU_COUNT: c
CPU_MHZ: fa8
CPU_VENDOR: GenuineIntel
CPU_FAMILY: 6
CPU_MODEL: 9e
CPU_STEPPING: a
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: WIN8_DRIVER_FAULT
BUGCHECK_STR: AV
PROCESS_NAME: System
CURRENT_IRQL: 0
ANALYSIS_SESSION_HOST: SYSNATIVEFORUMS
ANALYSIS_SESSION_TIME: 09-05-2019 23:42:35.0263
ANALYSIS_VERSION: 10.0.17763.132 amd64fre
TRAP_FRAME: fffff50d0b64f540 -- (.trap 0xfffff50d0b64f540)
rax=fffff8068d7015a0 rbx=0000000000000000 rcx=fffff50d0b64f868
rdx=0000000000000000 rsi=0000000000000000 rdi=0000000000000000
rip=fffff80671dcf980 rsp=fffff50d0b64f6d8 rbp=ffff810cfbf2b010
r8=00000000000000a0 r9=0000000000000000 r10=fffff8068d7015a0
r11=0000000000000000 r12=0000000000000000 r13=0000000000000000
iopl=0 nv up ei pl zr na po nc
nt!memset:
Resetting default scope
LAST_CONTROL_TRANSFER: from fffff80671ddfed4 to fffff80671dbc900
STACK_TEXT:
fffff50d`0b64f298 fffff806`71ddfed4 : 00000000`00000050 ffffb541`76e5a5b1 00000000`00000002 fffff50d`0b64f540 : nt!KeBugCheckEx
fffff50d`0b64f2a0 fffff806`71c7aaef : ffff810d`12d7c92b 00000000`00000002 00000000`00000000 ffffb541`76e5a5b1 : nt!MiSystemFault+0x1d2ee4
fffff50d`0b64f3a0 fffff806`71dca920 : 00000000`00000000 00000000`00000000 00000000`00000003 00000000`00000000 : nt!MmAccessFault+0x34f
fffff50d`0b64f540 fffff806`71dcf980 : fffff806`71c21f66 ffffbe80`b8ac4180 00000000`00989680 ffffbe80`b8b79180 : nt!KiPageFault+0x360
fffff50d`0b64f6d8 fffff806`71c21f66 : ffffbe80`b8ac4180 00000000`00989680 ffffbe80`b8b79180 00000000`00000004 : nt!memset
fffff50d`0b64f6e0 fffff806`71c2142e : 00000000`00000000 fffff50d`0b64fbc0 00000000`00000001 00000000`00000000 : nt!PpmIdleExecuteTransition+0x996
fffff50d`0b64fa00 fffff806`71dc0388 : ffffffff`00000000 ffffbe80`b8b79180 ffff810d`10ede080 00000000`000006ef : nt!PoIdle+0x36e
fffff50d`0b64fb60 00000000`00000000 : fffff50d`0b650000 fffff50d`0b649000 00000000`00000000 00000000`00000000 : nt!KiIdleLoop+0x48
THREAD_SHA1_HASH_MOD_FUNC: f03ab26a6e072007dacfd9c1ebdd8044ceb6985d
THREAD_SHA1_HASH_MOD_FUNC_OFFSET: 22770157572661e5c82ce2bb298e18721592618d
THREAD_SHA1_HASH_MOD: cb5f414824c2521bcc505eaa03e92fa10922dad8
FOLLOWUP_IP:
fffff806`71ddfed4 cc int 3
FAULT_INSTR_CODE: 4d8d48cc
SYMBOL_STACK_INDEX: 1
SYMBOL_NAME: nt!MiSystemFault+1d2ee4
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: nt
DEBUG_FLR_IMAGE_TIMESTAMP: 3ed0f42
IMAGE_VERSION: 10.0.18362.239
STACK_COMMAND: .thread ; .cxr ; kb
IMAGE_NAME: memory_corruption
BUCKET_ID_FUNC_OFFSET: 1d2ee4
FAILURE_BUCKET_ID: AV_INVALID_nt!MiSystemFault
PRIMARY_PROBLEM_CLASS: AV_INVALID_nt!MiSystemFault
TARGET_TIME: 2019-09-05T20:25:14.000Z
OSBUILD: 18362
OSSERVICEPACK: 239
SERVICEPACK_NUMBER: 0
OS_REVISION: 0
SUITE_MASK: 272
PRODUCT_TYPE: 1
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
OSEDITION: Windows 10 WinNt TerminalServer SingleUserTS
OS_LOCALE:
USER_LCID: 0
OSBUILD_TIMESTAMP: 1972-02-02 03:33:06
BUILDDATESTAMP_STR: 190318-1202
BUILDLAB_STR: 19h1_release
BUILDOSVER_STR: 10.0.18362.1.amd64fre.19h1_release.190318-1202
ANALYSIS_SESSION_ELAPSED_TIME: f23
ANALYSIS_SOURCE: KM
FAILURE_ID_HASH_STRING: km:av_invalid_nt!misystemfault
FAILURE_ID_HASH: {8a33c6b1-a9f1-4efe-025b-a861cc33d6e2}
rax=0000000000000000 rbx=ffffb54176e5a5b1 rcx=0000000000000050
rdx=ffffb54176e5a5b1 rsi=0000000000000000 rdi=fffff50d0b64f460
rip=fffff80671dbc900 rsp=fffff50d0b64f298 rbp=fffff50d0b64f339
r8=0000000000000002 r9=fffff50d0b64f540 r10=fffff80672063a40
r11=fffff50d0b64f1f0 r12=fffff80672063a40 r13=ffffeb75badd6000
r14=fffff50d0b64f540 r15=0000000000000000
cs=0010 ss=0018 ds=002b es=002b fs=0053 gs=002b efl=00040246
nt!KeBugCheckEx:
fffff806`71dbc900 48894c2408 mov qword ptr [rsp+8],rcx ss:0018:fffff50d`0b64f2a0=0000000000000050
# Child-SP RetAddr : Args to Child : Call Site
00 fffff50d`0b64f298 fffff806`71ddfed4 : 00000000`00000050 ffffb541`76e5a5b1 00000000`00000002 fffff50d`0b64f540 : nt!KeBugCheckEx
01 fffff50d`0b64f2a0 fffff806`71c7aaef : ffff810d`12d7c92b 00000000`00000002 00000000`00000000 ffffb541`76e5a5b1 : nt!MiSystemFault+0x1d2ee4
02 fffff50d`0b64f3a0 fffff806`71dca920 : 00000000`00000000 00000000`00000000 00000000`00000003 00000000`00000000 : nt!MmAccessFault+0x34f
03 fffff50d`0b64f540 fffff806`71dcf980 : fffff806`71c21f66 ffffbe80`b8ac4180 00000000`00989680 ffffbe80`b8b79180 : nt!KiPageFault+0x360 (TrapFrame @ fffff50d`0b64f540)
04 fffff50d`0b64f6d8 fffff806`71c21f66 : ffffbe80`b8ac4180 00000000`00989680 ffffbe80`b8b79180 00000000`00000004 : nt!memset
05 fffff50d`0b64f6e0 fffff806`71c2142e : 00000000`00000000 fffff50d`0b64fbc0 00000000`00000001 00000000`00000000 : nt!PpmIdleExecuteTransition+0x996
06 fffff50d`0b64fa00 fffff806`71dc0388 : ffffffff`00000000 ffffbe80`b8b79180 ffff810d`10ede080 00000000`000006ef : nt!PoIdle+0x36e
07 fffff50d`0b64fb60 00000000`00000000 : fffff50d`0b650000 fffff50d`0b649000 00000000`00000000 00000000`00000000 : nt!KiIdleLoop+0x48
start end module name
ffffe920`1e200000 ffffe920`1e5a1000 win32kfull win32kfull.sys unavailable (00000000)
ffffe920`1e5b0000 ffffe920`1e858000 win32kbase win32kbase.sys unavailable (00000000)
ffffe920`1e860000 ffffe920`1e8a8000 cdd cdd.dll unavailable (00000000)
ffffe920`1f000000 ffffe920`1f08c000 win32k win32k.sys unavailable (00000000)
fffff806`71b5d000 fffff806`71c00000 hal hal.dll 63975E9E (This is a reproducible build file hash, not a timestamp)
fffff806`71c00000 fffff806`726b2000 nt ntkrnlmp.exe 03ED0F42 (This is a reproducible build file hash, not a timestamp)
fffff806`76600000 fffff806`7660b000 kd kd.dll 5A75D524 (This is a reproducible build file hash, not a timestamp)
fffff806`76610000 fffff806`76811000 mcupdate_GenuineIntel mcupdate_GenuineIntel.dll 258CAB1A (This is a reproducible build file hash, not a timestamp)
fffff806`76820000 fffff806`76831000 werkernel werkernel.sys 958E14B2 (This is a reproducible build file hash, not a timestamp)
fffff806`76840000 fffff806`7686a000 ksecdd ksecdd.sys A35F28F6 (This is a reproducible build file hash, not a timestamp)
fffff806`76870000 fffff806`768d0000 msrpc msrpc.sys 8E1A4F15 (This is a reproducible build file hash, not a timestamp)
fffff806`768e0000 fffff806`76907000 tm tm.sys 2ADB549A (This is a reproducible build file hash, not a timestamp)
fffff806`76910000 fffff806`76978000 CLFS CLFS.SYS 296CBB1A (This is a reproducible build file hash, not a timestamp)
fffff806`76980000 fffff806`7699a000 PSHED PSHED.dll B21F9DDA (This is a reproducible build file hash, not a timestamp)
fffff806`769a0000 fffff806`769ab000 BOOTVID BOOTVID.dll 0F301604 (This is a reproducible build file hash, not a timestamp)
fffff806`769b0000 fffff806`769be000 cmimcext cmimcext.sys C7F022B4 (This is a reproducible build file hash, not a timestamp)
fffff806`769c0000 fffff806`769cc000 ntosext ntosext.sys BAC877D8 (This is a reproducible build file hash, not a timestamp)
fffff806`769d0000 fffff806`769e3000 WDFLDR WDFLDR.SYS 3B396780 (This is a reproducible build file hash, not a timestamp)
fffff806`769f0000 fffff806`769ff000 SleepStudyHelper SleepStudyHelper.sys BA6E2346 (This is a reproducible build file hash, not a timestamp)
fffff806`76a00000 fffff806`76b05000 clipsp clipsp.sys Mon Mar 18 15:11:27 2019 (5C90178F)
fffff806`76b10000 fffff806`76b81000 FLTMGR FLTMGR.SYS 2FCE7C68 (This is a reproducible build file hash, not a timestamp)
fffff806`76b90000 fffff806`76c6c000 CI CI.dll 8581DC0D (This is a reproducible build file hash, not a timestamp)
fffff806`76c70000 fffff806`76d2c000 cng cng.sys 268793E7 (This is a reproducible build file hash, not a timestamp)
fffff806`76d30000 fffff806`76e05000 Wdf01000 Wdf01000.sys 116A658A (This is a reproducible build file hash, not a timestamp)
fffff806`76e10000 fffff806`76e20000 WppRecorder WppRecorder.sys 34A54231 (This is a reproducible build file hash, not a timestamp)
fffff806`76e30000 fffff806`76e55000 acpiex acpiex.sys 2B91EDB2 (This is a reproducible build file hash, not a timestamp)
fffff806`76e60000 fffff806`76ea9000 mssecflt mssecflt.sys 96F3388F (This is a reproducible build file hash, not a timestamp)
fffff806`76eb0000 fffff806`76eca000 SgrmAgent SgrmAgent.sys F851A195 (This is a reproducible build file hash, not a timestamp)
fffff806`76ed0000 fffff806`76f9c000 ACPI ACPI.sys 637B6DAD (This is a reproducible build file hash, not a timestamp)
fffff806`76fa0000 fffff806`76fac000 WMILIB WMILIB.SYS 59021E3D (This is a reproducible build file hash, not a timestamp)
fffff806`76fd0000 fffff806`77019000 intelpep intelpep.sys 8A1B7970 (This is a reproducible build file hash, not a timestamp)
fffff806`77020000 fffff806`77037000 WindowsTrustedRT WindowsTrustedRT.sys CB95CE3D (This is a reproducible build file hash, not a timestamp)
fffff806`77040000 fffff806`7704b000 WindowsTrustedRTProxy WindowsTrustedRTProxy.sys 514E3023 (This is a reproducible build file hash, not a timestamp)
fffff806`77050000 fffff806`77065000 pcw pcw.sys 6B731527 (This is a reproducible build file hash, not a timestamp)
fffff806`77070000 fffff806`7707b000 msisadrv msisadrv.sys 5E470A0E (This is a reproducible build file hash, not a timestamp)
fffff806`77080000 fffff806`770ef000 pci pci.sys 79450D16 (This is a reproducible build file hash, not a timestamp)
fffff806`770f0000 fffff806`77103000 vdrvroot vdrvroot.sys 0101BCC6 (This is a reproducible build file hash, not a timestamp)
fffff806`77110000 fffff806`77143000 pdc pdc.sys 9AEEDDCB (This is a reproducible build file hash, not a timestamp)
fffff806`77150000 fffff806`77169000 CEA CEA.sys F3811107 (This is a reproducible build file hash, not a timestamp)
fffff806`77170000 fffff806`771a0000 partmgr partmgr.sys 89C96AD1 (This is a reproducible build file hash, not a timestamp)
fffff806`771b0000 fffff806`77255000 spaceport spaceport.sys DC82B965 (This is a reproducible build file hash, not a timestamp)
fffff806`77260000 fffff806`7727a000 volmgr volmgr.sys 211CEF76 (This is a reproducible build file hash, not a timestamp)
fffff806`77280000 fffff806`772e3000 volmgrx volmgrx.sys D6F366B7 (This is a reproducible build file hash, not a timestamp)
fffff806`772f0000 fffff806`7730f000 mountmgr mountmgr.sys 242DB05F (This is a reproducible build file hash, not a timestamp)
fffff806`77310000 fffff806`77337000 stornvme stornvme.sys 65EFCFF4 (This is a reproducible build file hash, not a timestamp)
fffff806`77340000 fffff806`773e2000 storport storport.sys A692CE5B (This is a reproducible build file hash, not a timestamp)
fffff806`773f0000 fffff806`77f84000 iaStorAC iaStorAC.sys Tue Mar 19 08:53:42 2019 (5C911086)
fffff806`77f90000 fffff806`77fb1000 EhStorTcgDrv EhStorTcgDrv.sys 80316E4C (This is a reproducible build file hash, not a timestamp)
fffff806`77fc0000 fffff806`77fdb000 EhStorClass EhStorClass.sys 526CC202 (This is a reproducible build file hash, not a timestamp)
fffff806`77fe0000 fffff806`77ffa000 fileinfo fileinfo.sys 24BBED20 (This is a reproducible build file hash, not a timestamp)
fffff806`78000000 fffff806`7803d000 Wof Wof.sys 3CB75347 (This is a reproducible build file hash, not a timestamp)
fffff806`78040000 fffff806`78099000 WdFilter WdFilter.sys ***** Invalid (E9CC4EB5)
fffff806`780a0000 fffff806`780ad000 Fs_Rec Fs_Rec.sys 49E932BA (This is a reproducible build file hash, not a timestamp)
fffff806`780b0000 fffff806`78144000 NETIO NETIO.SYS E3375155 (This is a reproducible build file hash, not a timestamp)
fffff806`78150000 fffff806`78182000 ksecpkg ksecpkg.sys E1E129D5 (This is a reproducible build file hash, not a timestamp)
fffff806`781a0000 fffff806`7843e000 Ntfs Ntfs.sys D9A3CE82 (This is a reproducible build file hash, not a timestamp)
fffff806`78440000 fffff806`785b2000 ndis ndis.sys A6D0FB1E (This is a reproducible build file hash, not a timestamp)
fffff806`785c0000 fffff806`788aa000 tcpip tcpip.sys 83DCBC58 (This is a reproducible build file hash, not a timestamp)
fffff806`788b0000 fffff806`7892a000 fwpkclnt fwpkclnt.sys 58C1E6ED (This is a reproducible build file hash, not a timestamp)
fffff806`78930000 fffff806`78960000 wfplwfs wfplwfs.sys 60902CBB (This is a reproducible build file hash, not a timestamp)
fffff806`78970000 fffff806`78a39000 fvevol fvevol.sys 55DC2AFE (This is a reproducible build file hash, not a timestamp)
fffff806`78a40000 fffff806`78a4b000 volume volume.sys A4E9FDFA (This is a reproducible build file hash, not a timestamp)
fffff806`78a50000 fffff806`78abd000 volsnap volsnap.sys 1876F533 (This is a reproducible build file hash, not a timestamp)
fffff806`78ac0000 fffff806`78b0e000 rdyboost rdyboost.sys F450CEB3 (This is a reproducible build file hash, not a timestamp)
fffff806`78b10000 fffff806`78b35000 mup mup.sys 565E0311 (This is a reproducible build file hash, not a timestamp)
fffff806`78b40000 fffff806`78b52000 iorate iorate.sys 18D52DDA (This is a reproducible build file hash, not a timestamp)
fffff806`78b70000 fffff806`78b8c000 disk disk.sys 384FEFED (This is a reproducible build file hash, not a timestamp)
fffff806`78b90000 fffff806`78bfb000 CLASSPNP CLASSPNP.SYS 09ED6E49 (This is a reproducible build file hash, not a timestamp)
fffff806`8ae00000 fffff806`8ae0e000 tbs tbs.sys 965BAC31 (This is a reproducible build file hash, not a timestamp)
fffff806`8ae10000 fffff806`8ae1a000 Null Null.SYS unavailable (00000000)
fffff806`8ae20000 fffff806`8ae2a000 Beep Beep.SYS 528EC21A (This is a reproducible build file hash, not a timestamp)
fffff806`8ae30000 fffff806`8b1a3000 dxgkrnl dxgkrnl.sys 7A92A2DE (This is a reproducible build file hash, not a timestamp)
fffff806`8b1b0000 fffff806`8b1c6000 watchdog watchdog.sys 21474799 (This is a reproducible build file hash, not a timestamp)
fffff806`8b1d0000 fffff806`8b1e6000 BasicDisplay BasicDisplay.sys 4E6E05E1 (This is a reproducible build file hash, not a timestamp)
fffff806`8b1f0000 fffff806`8b201000 BasicRender BasicRender.sys 82A93228 (This is a reproducible build file hash, not a timestamp)
fffff806`8b210000 fffff806`8b22c000 Npfs Npfs.SYS B03ECFD3 (This is a reproducible build file hash, not a timestamp)
fffff806`8b230000 fffff806`8b241000 Msfs Msfs.SYS 91FE0FF4 (This is a reproducible build file hash, not a timestamp)
fffff806`8b250000 fffff806`8b276000 tdx tdx.sys 0A1F3DC4 (This is a reproducible build file hash, not a timestamp)
fffff806`8b280000 fffff806`8b290000 TDI TDI.SYS 894065A0 (This is a reproducible build file hash, not a timestamp)
fffff806`8b2a0000 fffff806`8b2f9000 netbt netbt.sys 113D2A22 (This is a reproducible build file hash, not a timestamp)
fffff806`8b300000 fffff806`8b313000 afunix afunix.sys 9D6C12C4 (This is a reproducible build file hash, not a timestamp)
fffff806`8b320000 fffff806`8b3c7000 afd afd.sys B88DD13E (This is a reproducible build file hash, not a timestamp)
fffff806`8b3d0000 fffff806`8b3ea000 vwififlt vwififlt.sys 39396289 (This is a reproducible build file hash, not a timestamp)
fffff806`8b3f0000 fffff806`8b41b000 pacer pacer.sys E7276BDE (This is a reproducible build file hash, not a timestamp)
fffff806`8b420000 fffff806`8b434000 netbios netbios.sys B37FD2E9 (This is a reproducible build file hash, not a timestamp)
fffff806`8b440000 fffff806`8b4bb000 rdbss rdbss.sys BCE0ED0A (This is a reproducible build file hash, not a timestamp)
fffff806`8b4c0000 fffff806`8b554000 csc csc.sys B2D84C51 (This is a reproducible build file hash, not a timestamp)
fffff806`8b560000 fffff806`8b5ba000 YSDrv YSDrv.sys Wed Oct 11 00:00:25 2017 (59DDC189)
fffff806`8b5c0000 fffff806`8b5d2000 nsiproxy nsiproxy.sys 528DA18A (This is a reproducible build file hash, not a timestamp)
fffff806`8b5e0000 fffff806`8b5ed000 npsvctrig npsvctrig.sys 0E7AC006 (This is a reproducible build file hash, not a timestamp)
fffff806`8b5f0000 fffff806`8b600000 mssmbios mssmbios.sys E6DC521D (This is a reproducible build file hash, not a timestamp)
fffff806`8b610000 fffff806`8b61a000 gpuenergydrv gpuenergydrv.sys 0CC24294 (This is a reproducible build file hash, not a timestamp)
fffff806`8b620000 fffff806`8b628000 GLCKIO2 GLCKIO2.sys Mon Apr 22 06:44:46 2019 (5CBDC54E)
fffff806`8b630000 fffff806`8b637000 ene ene.sys Wed May 15 08:36:46 2019 (5CDC320E)
fffff806`8b640000 fffff806`8b66c000 dfsc dfsc.sys FABE3F7D (This is a reproducible build file hash, not a timestamp)
fffff806`8b690000 fffff806`8b6fb000 fastfat fastfat.SYS 5D09ADAA (This is a reproducible build file hash, not a timestamp)
fffff806`8b700000 fffff806`8b716000 bam bam.sys 22198778 (This is a reproducible build file hash, not a timestamp)
fffff806`8b720000 fffff806`8b729000 AsIO2 AsIO2.sys Tue Apr 9 02:59:16 2019 (5CAC6CF4)
fffff806`8b730000 fffff806`8b77f000 ahcache ahcache.sys A8473BE2 (This is a reproducible build file hash, not a timestamp)
fffff806`8b780000 fffff806`8b80c000 Vid Vid.sys B7391632 (This is a reproducible build file hash, not a timestamp)
fffff806`8b810000 fffff806`8b82f000 winhvr winhvr.sys 5EB9FF62 (This is a reproducible build file hash, not a timestamp)
fffff806`8b830000 fffff806`8b841000 CompositeBus CompositeBus.sys F050D616 (This is a reproducible build file hash, not a timestamp)
fffff806`8b850000 fffff806`8b85d000 kdnic kdnic.sys 1FF5F7F5 (This is a reproducible build file hash, not a timestamp)
fffff806`8b860000 fffff806`8b875000 umbus umbus.sys 3104A4AD (This is a reproducible build file hash, not a timestamp)
fffff806`8b880000 fffff806`8b88c000 wmiacpi wmiacpi.sys AF7EFCE5 (This is a reproducible build file hash, not a timestamp)
fffff806`8b890000 fffff806`8b8ecf80 RDWM1203 RDWM1203.SYS Tue May 1 21:16:16 2018 (5AE93B90)
fffff806`8b8f0000 fffff806`8b92b000 HIDCLASS HIDCLASS.SYS D4D0DEE6 (This is a reproducible build file hash, not a timestamp)
fffff806`8b930000 fffff806`8b943000 HIDPARSE HIDPARSE.SYS 0D56F932 (This is a reproducible build file hash, not a timestamp)
fffff806`8b950000 fffff806`8b96b000 wachidrouter wachidrouter.sys Mon Nov 11 16:15:44 2013 (52817330)
fffff806`8b970000 fffff806`8b978000 hidkmdf hidkmdf.sys Wed Aug 24 12:48:10 2011 (4E55557A)
fffff806`8b980000 fffff806`8b9b3000 usbccgp usbccgp.sys 5D2AF1D1 (This is a reproducible build file hash, not a timestamp)
fffff806`8b9c0000 fffff806`8b9d0000 mouhid mouhid.sys A140C187 (This is a reproducible build file hash, not a timestamp)
fffff806`8b9e0000 fffff806`8b9ea000 wacomrouterfilter wacomrouterfilter.sys Mon Nov 11 16:15:51 2013 (52817337)
fffff806`8b9f0000 fffff806`8ba03000 mouclass mouclass.sys 4A22FFB8 (This is a reproducible build file hash, not a timestamp)
fffff806`8ba10000 fffff806`8ba21000 kbdhid kbdhid.sys 4CF68CA7 (This is a reproducible build file hash, not a timestamp)
fffff806`8ba30000 fffff806`8ba44000 kbdclass kbdclass.sys 0B474226 (This is a reproducible build file hash, not a timestamp)
fffff806`8ba60000 fffff806`8ba6e000 dump_dumpstorport dump_dumpstorport.sys 518A16BD (This is a reproducible build file hash, not a timestamp)
fffff806`8baa0000 fffff806`8bac7000 dump_stornvme dump_stornvme.sys 65EFCFF4 (This is a reproducible build file hash, not a timestamp)
fffff806`8baf0000 fffff806`8bb0d000 dump_dumpfve dump_dumpfve.sys 59B1C57D (This is a reproducible build file hash, not a timestamp)
fffff806`8bb10000 fffff806`8bbeb000 dxgmms2 dxgmms2.sys E443C889 (This is a reproducible build file hash, not a timestamp)
fffff806`8bc10000 fffff806`8bc3a000 luafv luafv.sys 08A8E82A (This is a reproducible build file hash, not a timestamp)
fffff806`8bc40000 fffff806`8bc76000 wcifs wcifs.sys 616EC3AA (This is a reproducible build file hash, not a timestamp)
fffff806`8bcc0000 fffff806`8bcdd000 crashdmp crashdmp.sys 2985CB13 (This is a reproducible build file hash, not a timestamp)
fffff806`8bce0000 fffff806`8bd30000 WUDFRd WUDFRd.sys 2A40F545 (This is a reproducible build file hash, not a timestamp)
fffff806`8bd40000 fffff806`8bd4e000 WpdUpFltr WpdUpFltr.sys 9F7376EA (This is a reproducible build file hash, not a timestamp)
fffff806`8bda0000 fffff806`8bdd0000 cdrom cdrom.sys 9F6B0B7B (This is a reproducible build file hash, not a timestamp)
fffff806`8bde0000 fffff806`8bdf5000 filecrypt filecrypt.sys 4EAD73C1 (This is a reproducible build file hash, not a timestamp)
fffff806`8d400000 fffff806`8d489000 USBXHCI USBXHCI.SYS 951B0A79 (This is a reproducible build file hash, not a timestamp)
fffff806`8d490000 fffff806`8d4d1000 ucx01000 ucx01000.sys 04268533 (This is a reproducible build file hash, not a timestamp)
fffff806`8d4e0000 fffff806`8d54f000 UcmCxUcsiNvppc UcmCxUcsiNvppc.sys Sun Dec 9 12:39:33 2018 (5C0D7D85)
fffff806`8d550000 fffff806`8d57c000 UcmCx UcmCx.sys E8A9CD85 (This is a reproducible build file hash, not a timestamp)
fffff806`8d580000 fffff806`8d5bb000 TeeDriverW8x64 TeeDriverW8x64.sys Wed Apr 11 07:46:32 2018 (5ACE1FC8)
fffff806`8d5c0000 fffff806`8d5dc000 serial serial.sys B6549B39 (This is a reproducible build file hash, not a timestamp)
fffff806`8d5e0000 fffff806`8d5ef000 serenum serenum.sys 0B8B1DB3 (This is a reproducible build file hash, not a timestamp)
fffff806`8d5f0000 fffff806`8d685000 e1d68x64 e1d68x64.sys Tue May 7 05:11:29 2019 (5CD175F1)
fffff806`8d690000 fffff806`8d6b1000 iaLPSS2i_GPIO2_CNL iaLPSS2i_GPIO2_CNL.sys Tue Apr 17 00:07:03 2018 (5AD59D17)
fffff806`8d6c0000 fffff806`8d6f0000 msgpioclx msgpioclx.sys 764CDE46 (This is a reproducible build file hash, not a timestamp)
fffff806`8d700000 fffff806`8d73e000 intelppm intelppm.sys DF02127E (This is a reproducible build file hash, not a timestamp)
fffff806`8d740000 fffff806`8d74b000 acpipagr acpipagr.sys 80AB510E (This is a reproducible build file hash, not a timestamp)
fffff806`8d750000 fffff806`8d75c000 acpitime acpitime.sys DE5D8591 (This is a reproducible build file hash, not a timestamp)
fffff806`8d760000 fffff806`8d76e000 UEFI UEFI.sys 60BAE916 (This is a reproducible build file hash, not a timestamp)
fffff806`8d770000 fffff806`8d781000 nvvad64v nvvad64v.sys Thu Mar 14 01:58:48 2019 (5C8A17C8)
fffff806`8d790000 fffff806`8d79f000 ksthunk ksthunk.sys 15502221 (This is a reproducible build file hash, not a timestamp)
fffff806`8d7a0000 fffff806`8d7b0000 nvvhci nvvhci.sys Thu Aug 16 13:01:22 2018 (5B75D812)
fffff806`8d7c0000 fffff806`8d7cd000 NdisVirtualBus NdisVirtualBus.sys D217410A (This is a reproducible build file hash, not a timestamp)
fffff806`8d7d0000 fffff806`8d7dc000 swenum swenum.sys C4D73525 (This is a reproducible build file hash, not a timestamp)
fffff806`8d7e0000 fffff806`8d7ee000 rdpbus rdpbus.sys 4E9899F8 (This is a reproducible build file hash, not a timestamp)
fffff806`8d7f0000 fffff806`8d827000 nvhda64v nvhda64v.sys Mon Mar 18 21:47:57 2019 (5C90747D)
fffff806`8d830000 fffff806`8d8cc000 UsbHub3 UsbHub3.sys D4267D67 (This is a reproducible build file hash, not a timestamp)
fffff806`8d8d0000 fffff806`8d8de000 USBD USBD.SYS CD63CE9D (This is a reproducible build file hash, not a timestamp)
fffff806`8d8e0000 fffff806`8df1e000 RTKVHD64 RTKVHD64.sys Thu Aug 2 01:52:59 2018 (5B62C66B)
fffff806`8df20000 fffff806`8f45b000 nvlddmkm nvlddmkm.sys Wed Jul 17 14:04:33 2019 (5D2F8D61)
fffff806`8f460000 fffff806`8f482000 HDAudBus HDAudBus.sys AECD2958 (This is a reproducible build file hash, not a timestamp)
fffff806`8f490000 fffff806`8f4f7000 portcls portcls.sys D4F15BF0 (This is a reproducible build file hash, not a timestamp)
fffff806`8f500000 fffff806`8f521000 drmk drmk.sys ***** Invalid (A3E06FB0)
fffff806`8f530000 fffff806`8f5a8000 ks ks.sys 1F5FE6FB (This is a reproducible build file hash, not a timestamp)
fffff806`8f5b0000 fffff806`8f5d5000 USBSTOR USBSTOR.SYS 9CFA0789 (This is a reproducible build file hash, not a timestamp)
fffff806`8f5e0000 fffff806`8f5f2000 hidusb hidusb.sys 7B9189FE (This is a reproducible build file hash, not a timestamp)
fffff806`ce800000 fffff806`ce944000 HTTP HTTP.sys F709630D (This is a reproducible build file hash, not a timestamp)
fffff806`ce950000 fffff806`ce975000 bowser bowser.sys D37F2E35 (This is a reproducible build file hash, not a timestamp)
fffff806`ce980000 fffff806`ce99a000 mpsdrv mpsdrv.sys 7D5AF2F0 (This is a reproducible build file hash, not a timestamp)
fffff806`ce9a0000 fffff806`cea2f000 mrxsmb mrxsmb.sys BACC3E1C (This is a reproducible build file hash, not a timestamp)
fffff806`cea30000 fffff806`cea75000 mrxsmb20 mrxsmb20.sys 274D454A (This is a reproducible build file hash, not a timestamp)
fffff806`cea80000 fffff806`cead3000 srvnet srvnet.sys 220AB43D (This is a reproducible build file hash, not a timestamp)
fffff806`ceae0000 fffff806`ceaf4000 mmcss mmcss.sys 3EE4136D (This is a reproducible build file hash, not a timestamp)
fffff806`ceb00000 fffff806`ceb27000 Ndu Ndu.sys 23725908 (This is a reproducible build file hash, not a timestamp)
fffff806`ceb30000 fffff806`cec06000 peauth peauth.sys ***** Invalid (8335FA6C)
fffff806`cec10000 fffff806`cec24000 tcpipreg tcpipreg.sys 3451B629 (This is a reproducible build file hash, not a timestamp)
fffff806`cec30000 fffff806`cecf5000 srv2 srv2.sys 8351FE4E (This is a reproducible build file hash, not a timestamp)
fffff806`ced00000 fffff806`ced1d000 rassstp rassstp.sys 6EC6A1E5 (This is a reproducible build file hash, not a timestamp)
fffff806`ced20000 fffff806`ced60000 NDProxy NDProxy.sys 1E12D3FF (This is a reproducible build file hash, not a timestamp)
fffff806`ced70000 fffff806`ced97000 AgileVpn AgileVpn.sys A96AFF6D (This is a reproducible build file hash, not a timestamp)
fffff806`ceda0000 fffff806`cedc2000 rasl2tp rasl2tp.sys A7AA404E (This is a reproducible build file hash, not a timestamp)
fffff806`cedd0000 fffff806`cedf0000 raspptp raspptp.sys 54893590 (This is a reproducible build file hash, not a timestamp)
fffff806`cee00000 fffff806`cee1c000 raspppoe raspppoe.sys 053A7D72 (This is a reproducible build file hash, not a timestamp)
fffff806`cee20000 fffff806`cee2f000 ndistapi ndistapi.sys 690D0D05 (This is a reproducible build file hash, not a timestamp)
fffff806`cee30000 fffff806`cee6a000 ndiswan ndiswan.sys FB43C10D (This is a reproducible build file hash, not a timestamp)
fffff806`cee70000 fffff806`cee88000 monitor monitor.sys 93F54FB5 (This is a reproducible build file hash, not a timestamp)
fffff806`cee90000 fffff806`ceea2000 WdNisDrv WdNisDrv.sys ***** Invalid (DB1D2C05)
fffff806`ceeb0000 fffff806`ceec3000 condrv condrv.sys AEE79CBA (This is a reproducible build file hash, not a timestamp)
fffff806`ceed0000 fffff806`ceed6000 msio64 msio64.sys Sun Feb 11 23:57:50 2018 (5A8148FE)
fffff806`ceee0000 fffff806`ceee6000 RTCore64 RTCore64.sys Fri Sep 30 05:03:17 2016 (57EE5485)
fffff806`ceef0000 fffff806`cef11000 bindflt bindflt.sys 24A0F39E (This is a reproducible build file hash, not a timestamp)
fffff806`cefc0000 fffff806`cefd8000 ndisuio ndisuio.sys 38FD20EE (This is a reproducible build file hash, not a timestamp)
fffff806`cf000000 fffff806`cf00d000 WSDScan WSDScan.sys ED66A961 (This is a reproducible build file hash, not a timestamp)
fffff806`cf010000 fffff806`cf087000 cldflt cldflt.sys 0CF2C7CF (This is a reproducible build file hash, not a timestamp)
fffff806`cf090000 fffff806`cf0aa000 storqosflt storqosflt.sys D77C69C8 (This is a reproducible build file hash, not a timestamp)
fffff806`cf0b0000 fffff806`cf0c9000 mslldp mslldp.sys 15C3108A (This is a reproducible build file hash, not a timestamp)
fffff806`cf0d0000 fffff806`cf0e8000 lltdio lltdio.sys 707E9308 (This is a reproducible build file hash, not a timestamp)
fffff806`cf0f0000 fffff806`cf10d000 wanarp wanarp.sys 1BD57CFB (This is a reproducible build file hash, not a timestamp)
fffff806`cf110000 fffff806`cf12b000 rspndr rspndr.sys ED98D1EE (This is a reproducible build file hash, not a timestamp)
fffff806`cf130000 fffff806`cf168000 winquic winquic.sys D60F7863 (This is a reproducible build file hash, not a timestamp)
fffff806`cf170000 fffff806`cf17d000 WSDPrint WSDPrint.sys FCE23E82 (This is a reproducible build file hash, not a timestamp)
fffff806`cf1c0000 fffff806`cf1cc000 ALSysIO64 ALSysIO64.sys Fri Feb 1 09:48:41 2019 (5C548679)
fffff806`cf1d0000 fffff806`cf1e4000 qwavedrv qwavedrv.sys 5AC1A01C (This is a reproducible build file hash, not a timestamp)
Unloaded modules:
fffff806`d1580000 fffff806`d1693000 YSR0.sys
Checksum: 00000000
ImageSize: 00113000
fffff806`d16a0000 fffff806`d16c7000 YSDDR0.sys
Checksum: 00000000
ImageSize: 00027000
fffff806`cefa0000 fffff806`cefaf000 hiber_storpo
Checksum: 00000000
ImageSize: 0000F000
fffff806`cf180000 fffff806`cf1a8000 hiber_stornv
Checksum: 00000000
ImageSize: 00028000
fffff806`cef20000 fffff806`cef3e000 hiber_dumpfv
Checksum: 00000000
ImageSize: 0001E000
fffff806`d8990000 fffff806`d8aa3000 YSR0.sys
Checksum: 00000000
ImageSize: 00113000
fffff806`d8ab0000 fffff806`d8ad7000 YSDDR0.sys
Checksum: 00000000
ImageSize: 00027000
fffff806`d1670000 fffff806`d1783000 YSR0.sys
Checksum: 00000000
ImageSize: 00113000
fffff806`d1790000 fffff806`d17b7000 YSDDR0.sys
Checksum: 00000000
ImageSize: 00027000
fffff806`cef40000 fffff806`cef4f000 hiber_storpo
Checksum: 00000000
ImageSize: 0000F000
fffff806`cef50000 fffff806`cef78000 hiber_stornv
Checksum: 00000000
ImageSize: 00028000
fffff806`cef80000 fffff806`cef9e000 hiber_dumpfv
Checksum: 00000000
ImageSize: 0001E000
fffff806`73fb0000 fffff806`740c3000 YSR0.sys
Checksum: 00000000
ImageSize: 00113000
fffff806`740d0000 fffff806`740f7000 YSDDR0.sys
Checksum: 00000000
ImageSize: 00027000
fffff806`cf180000 fffff806`cf18f000 hiber_storpo
Checksum: 00000000
ImageSize: 0000F000
fffff806`cf190000 fffff806`cf1b8000 hiber_stornv
Checksum: 00000000
ImageSize: 00028000
Checksum: 00000000
ImageSize: 0001E000
fffff806`d13d0000 fffff806`d13de000 WSDPrint.sys
Checksum: 00000000
ImageSize: 0000E000
fffff806`d13c0000 fffff806`d13ce000 WSDScan.sys
Checksum: 00000000
ImageSize: 0000E000
fffff806`d13e0000 fffff806`d13ef000 hiber_storpo
Checksum: 00000000
ImageSize: 0000F000
fffff806`d0e00000 fffff806`d0e28000 hiber_stornv
Checksum: 00000000
ImageSize: 00028000
fffff806`d0e30000 fffff806`d0e4e000 hiber_dumpfv
Checksum: 00000000
ImageSize: 0001E000
fffff806`d1270000 fffff806`d1383000 YSR0.sys
Checksum: 00000000
ImageSize: 00113000
fffff806`d1390000 fffff806`d13b7000 YSDDR0.sys
Checksum: 00000000
ImageSize: 00027000
fffff806`cef70000 fffff806`cef7f000 hiber_storpo
Checksum: 00000000
ImageSize: 0000F000
fffff806`cef80000 fffff806`cefa8000 hiber_stornv
Checksum: 00000000
ImageSize: 00028000
fffff806`cefe0000 fffff806`ceffe000 hiber_dumpfv
Checksum: 00000000
ImageSize: 0001E000
fffff806`d11c0000 fffff806`d12d3000 YSR0.sys
Checksum: 00000000
ImageSize: 00113000
fffff806`d12e0000 fffff806`d1307000 YSDDR0.sys
Checksum: 00000000
ImageSize: 00027000
fffff806`cf190000 fffff806`cf19f000 hiber_storpo
Checksum: 00000000
ImageSize: 0000F000
fffff806`cef20000 fffff806`cef48000 hiber_stornv
Checksum: 00000000
ImageSize: 00028000
fffff806`cef50000 fffff806`cef6e000 hiber_dumpfv
Checksum: 00000000
ImageSize: 0001E000
fffff806`cef90000 fffff806`cef9f000 hiber_storpo
Checksum: 00000000
ImageSize: 0000F000
fffff806`cefe0000 fffff806`cf008000 hiber_stornv
Checksum: 00000000
ImageSize: 00028000
fffff806`cf170000 fffff806`cf18e000 hiber_dumpfv
Checksum: 00000000
ImageSize: 0001E000
fffff806`cef30000 fffff806`cef3f000 hiber_storpo
Checksum: 00000000
ImageSize: 0000F000
fffff806`cef40000 fffff806`cef68000 hiber_stornv
Checksum: 00000000
ImageSize: 00028000
fffff806`cef70000 fffff806`cef8e000 hiber_dumpfv
Checksum: 00000000
ImageSize: 0001E000
fffff806`cef20000 fffff806`cef2e000 WSDPrint.sys
Checksum: 00000000
ImageSize: 0000E000
fffff806`cf1f0000 fffff806`cf1fe000 WSDScan.sys
Checksum: 00000000
ImageSize: 0000E000
fffff806`73ed0000 fffff806`73fe3000 YSR0.sys
Checksum: 00000000
ImageSize: 00113000
fffff806`73c00000 fffff806`73c27000 YSDDR0.sys
Checksum: 00000000
ImageSize: 00027000
fffff806`cf000000 fffff806`cf00f000 hiber_storpo
Checksum: 00000000
ImageSize: 0000F000
fffff806`cf170000 fffff806`cf198000 hiber_stornv
Checksum: 00000000
ImageSize: 00028000
fffff806`cf1a0000 fffff806`cf1be000 hiber_dumpfv
Checksum: 00000000
ImageSize: 0001E000
fffff806`cef80000 fffff806`cef8f000 hiber_storpo
Checksum: 00000000
ImageSize: 0000F000
fffff806`cef90000 fffff806`cefb8000 hiber_stornv
Checksum: 00000000
ImageSize: 00028000
Checksum: 00000000
ImageSize: 0001E000
fffff806`70600000 fffff806`70713000 YSR0.sys
Checksum: 00000000
ImageSize: 00113000
fffff806`70720000 fffff806`70747000 YSDDR0.sys
Checksum: 00000000
ImageSize: 00027000
Unloaded modules:
Checksum: 00000000
ImageSize: 00113000
Checksum: 00000000
ImageSize: 00027000
Checksum: 00000000
ImageSize: 0000F000
Checksum: 00000000
ImageSize: 00028000
Checksum: 00000000
ImageSize: 0001E000
Checksum: 00000000
ImageSize: 00113000
Checksum: 00000000
ImageSize: 00027000
Checksum: 00000000
ImageSize: 00113000
Checksum: 00000000
ImageSize: 00027000
Checksum: 00000000
ImageSize: 0000F000
Checksum: 00000000
ImageSize: 00028000
Checksum: 00000000
ImageSize: 0001E000
Checksum: 00000000
ImageSize: 00113000
Checksum: 00000000
ImageSize: 00027000
Checksum: 00000000
ImageSize: 0000F000
Checksum: 00000000
ImageSize: 00028000
Checksum: 00000000
ImageSize: 0001E000
Checksum: 00000000
ImageSize: 0000E000
Checksum: 00000000
ImageSize: 0000E000
Checksum: 00000000
ImageSize: 0000F000
Checksum: 00000000
ImageSize: 00028000
Checksum: 00000000
ImageSize: 0001E000
Checksum: 00000000
ImageSize: 00113000
Checksum: 00000000
ImageSize: 00027000
Checksum: 00000000
ImageSize: 0000F000
Checksum: 00000000
ImageSize: 00028000
Checksum: 00000000
ImageSize: 0001E000
Checksum: 00000000
ImageSize: 00113000
Checksum: 00000000
ImageSize: 00027000
Checksum: 00000000
ImageSize: 0000F000
Checksum: 00000000
ImageSize: 00028000
Checksum: 00000000
ImageSize: 0001E000
Checksum: 00000000
ImageSize: 0000F000
Checksum: 00000000
ImageSize: 00028000
Checksum: 00000000
ImageSize: 0001E000
Checksum: 00000000
ImageSize: 0000F000
Checksum: 00000000
ImageSize: 00028000
Checksum: 00000000
ImageSize: 0001E000
Checksum: 00000000
ImageSize: 0000E000
Checksum: 00000000
ImageSize: 0000E000
Checksum: 00000000
ImageSize: 00113000
Checksum: 00000000
ImageSize: 00027000
Checksum: 00000000
ImageSize: 0000F000
Checksum: 00000000
ImageSize: 00028000
Checksum: 00000000
ImageSize: 0001E000
Checksum: 00000000
ImageSize: 0000F000
Checksum: 00000000
ImageSize: 00028000
Checksum: 00000000
ImageSize: 0001E000
Checksum: 00000000
ImageSize: 00113000
Checksum: 00000000
ImageSize: 00027000
Bugcheck code 00000050
Arguments ffffb541`76e5a5b1 00000000`00000002 fffff806`71dcf980 00000000`00000002
3: kd> lmvm storport
Browse full module list
fffff806`77340000 fffff806`773e2000 storport (deferred)
Mapped memory image file: c:\symbols\storport.sys\A692CE5Ba2000\storport.sys
Image path: \SystemRoot\System32\drivers\storport.sys
Image name: storport.sys
Browse all global symbols functions data
Image was built with /Brepro flag.
Timestamp: A692CE5B (This is a reproducible build file hash, not a timestamp)
CheckSum: 000A8237
ImageSize: 000A2000
File version: 10.0.18362.1093
Product version: 10.0.18362.1093
File flags: 0 (Mask 3F)
File OS: 40004 NT Win32
File type: 3.7 Driver
File date: 00000000.00000000
Translations: 0000.04b0
CompanyName: Microsoft Corporation
ProductName: Microsoft® Windows® Operating System
InternalName: storport.sys
OriginalFilename: storport.sys
ProductVersion: 10.0.18362.1093
FileVersion: 10.0.18362.1093 (WinBuild.160101.0800)
FileDescription: Microsoft Storage Port Driver
LegalCopyright: © Microsoft Corporation. All rights reserved.
3: kd> k
# Child-SP RetAddr Call Site
00 fffff50d`0b64f298 fffff806`71ddfed4 nt!KeBugCheckEx
01 fffff50d`0b64f2a0 fffff806`71c7aaef nt!MiSystemFault+0x1d2ee4
02 fffff50d`0b64f3a0 fffff806`71dca920 nt!MmAccessFault+0x34f
03 fffff50d`0b64f540 fffff806`71dcf980 nt!KiPageFault+0x360
04 fffff50d`0b64f6d8 fffff806`71c21f66 nt!memset
05 fffff50d`0b64f6e0 fffff806`71c2142e nt!PpmIdleExecuteTransition+0x996
06 fffff50d`0b64fa00 fffff806`71dc0388 nt!PoIdle+0x36e
07 fffff50d`0b64fb60 00000000`00000000 nt!KiIdleLoop+0x48
