Hi
@xilolee, sorry for not getting back to you. I've been busy lately, and haven't really had the time to check in. The C-states have always been off.
Now then, over the course of the month, I've been experiencing
a lot of BSODs.
Half of them were irregular (different error codes each time; you name it and I've probably experienced it), and the other half were consistently KMODE_EXCEPTION_NOT_HANDLED.
Every time I got the KMODE error, WhoCrashed would quote that something was wrong with the Processor Device Driver (intelppm.sys).
Before August, I've never had BSODs happen
this frequently. Now it's happening pretty much once every other day or more.
I haven't changed anything in the system, apart from whatever Windows Update provides me. I genuinely feel that my system has gotten a lot more unstable after upgrading to Build 2004.
Before, I almost never get a BSOD outside of gaming, and I always attributed it to the possibility that gaming might've heated up my CPU and caused it to throw an error.
But now, I don't even have to be gaming for it to suddenly happen out of the blue.
One "pattern" that I have noticed is that the the BSODs tend to occur once my committed memory starts to build up. That is, when it starts to reach over high amounts like 25-30 GB.
That typically happens after about 1-2 days of cumulative uptime, since I always sleep my PC in order to maintain my workspace. (It's inconvenient to keep setting it up after a restart.)
Some rudimentary research on Google gave me an interesting finding to consider: There is a possibility that my CPU or RAM might be "bad."
See here.
I already put my RAM under rigorous tests with Memtest86+ and the Windows Memory Diagnostic, but they didn't return any negative results. This was the same when I checked it several times in the past.
I can also put my PC under various stress tests for several hours (including Prime95), and they would always pass without any issue.
My PC has thrown a BSOD every so often (once a month at least) ever since I bought and installed the CPU, but I've always shrugged it off as being too infrequent to matter.
But after reading that post that I linked, I am now under the impression that I might have a faulty CPU that may have degraded or something.
I'm truly at a loss and I'm not sure what's going on. I don't know if my CPU/RAM is faulty or if it is genuinely a Windows 10 problem (Build 2004) that I should patiently wait to get fixed.
What do you suggest I should do? Should I replace my CPU/RAM? In the meanwhile, I'll try reseating my RAM again in hopes that it stabilizes the PC. Thank you, again
