[SOLVED] Cant run SFCfix cause of side by side configuration is incorrect
I really hope this is correct
Yes.
  3. Press the Fix button.
Attach the file C:\SFCFix\CrashDumps\SFCFixCrashReport\SFCFixCrashReport.zip also to your next reply.
It seems the red marked folder in C:\Users\happy\Desktop\FRSTfix is not there as you mentioned in message #14.
Please check and make sure the 2 files in the attachment of message #11 are placed in the red marked folder.
Sorry, I cannot give any predation when the issues are solved. Please be patient.
And you are correct the files are auto deleted after there are used so it isn't there and if that's not what you meant than please correct me
Please make sure the folder and its 2 files are there again, then report back.
Is this what you meant
Lets see.
Ok. 1 of them is fixed.
Can you run the tool SFCFix successful now?
After restarting the PC and trying it didn't run
The same side by side error popped up
Did the side-by-side error started to popup after you installed KB5018474 or already earlier ?
I don't remember downloading that but if i did, the errors probably started before i downloaded it
KB5018474 is a Monthly Rollup update,released October 11, 2022
