[SOLVED] Cant run SFCfix cause of side by side configuration is incorrect
Instead of the command
expand windows8.1-kb5018474-x64_04d5097ac019afc70c130f027942a7f0ee9bf890.msu -f:* D:\FIXUP
use the command
expand windows8.1-kb5018474-x64.msu -f:* D:\FIXUP
If that works resume with the next steps.
If not report the failure.
it still didnt work
Microsoft Windows [Version 6.3.9600]
(c) 2013 Microsoft Corporation. All rights reserved.
C:\WINDOWS\system32>expand windows8.1-kb5018474-x64.msu -f:* D:\FIXUP
Microsoft (R) File Expansion Utility Version 6.3.9600.17415
Can't open input file: windows8.1-kb5018474-x64.msu.
Now I see. You used another drive as a temporary folder.
In message #60 you used the command C:\WINDOWS\system32>cd D:\FIXUP
That only changes on drive D: the active folder to FIXUP. It does not change the active folder on the system drive C:. The command expand can therefor not find the input file.
Please do following.
  • Move the folder FIXUP from drive D: to drive C:
    Now you should have C:\FIXUP instead of D:\FIXUP
  • Click on the Start button and in the search box, type Command Prompt
  • When you see Command Prompt on the list, right-click on it and select Run as administrator
  • When command prompt opens, copy and paste the following commands into it, press enter after each
    cd C:\FIXUP
    expand windows8.1-kb5018474-x64_04d5097ac019afc70c130f027942a7f0ee9bf890.msu -f:* C:\FIXUP
    DISM.exe /Online /Add-Package /PackagePath:C:\FIXUP\windows8.1-kb5018474-x64.cab
  • You should receive the message:
  • If you receive any other message:
Sooooo mmmmmmhhhhh i just realized the file name for the
file has an "(1)" at the end, and after deleting it the command works
the third command failed though
C:\WINDOWS\system32>cd C:\FIXUP
C:\FIXUP>expand windows8.1-kb5018474-x64_04d5097ac019afc70c130f027942a7f0ee9bf89
0.msu -f:* C:\FIXUP
Can't open input file: windows8.1-kb5018474-x64_04d5097ac019afc70c130f027942a7f0
ee9bf890.msu.
0.msu -f:* C:\FIXUP
Adding C:\FIXUP\WSUSSCAN.cab to Extraction Queue
Adding C:\FIXUP\Windows8.1-KB5018474-x64-pkgProperties.txt to Extraction Queue
Adding C:\FIXUP\Windows8.1-KB5018474-x64.xml to Extraction Queue
Adding C:\FIXUP\Windows8.1-KB5018474-x64.cab to Extraction Queue
Expanding Files ....
Progress: 3 out of 4 files
Expanding Files Complete ...
4 files total.
C:\FIXUP>DISM.exe /Online /Add-Package /PackagePath:C:\FIXUP\windows8.1-kb501847
4-x64.cab
Version: 6.3.9600.19408
Image Version: 6.3.9600.19397
Processing 1 of 1 - Adding package Package_for_RollupFix~31bf3856ad364e35~amd64~
~9600.20625.1.18
[=================== 32.8% ]
An error occurred - Package_for_RollupFix Error: 0x80073712
Error: 14098
The component store has been corrupted.
C:\FIXUP>
Attach the file C:\Windows\Logs\CBS\cbs.log also.
The files dism.log and cbs.log do not line up in time.
Open an elevated commandprompt again.
Enter the command cd C:\FIXUP again and press enter.
Next, enter the command DISM.exe /Online /Add-Package /PackagePath:C:\FIXUP\windows8.1-kb5018474-x64.cab again and press enter.
Wait for this to finish.
When it fails, attach the files C:\Windows\Logs\DISM\dism.log and C:\Windows\Logs\CBS\cbs.log to your next reply.
its the same
4-x64.cab
~9600.20625.1.18
Error: 14098
C:\FIXUP>
Download the attachment Manifests.zip and save it on your desktop.
Right-click the file Manifests.zip on your desktop and select Extract all. Keep the default folder and click the button Extract.
When completed there should be a folder Manifests on your desktop which we need in the next step.
  3. Press the Fix button.
if i remember correctly these files need to be in the same place as the FRST64.exe, right?
No, that was only valid for a previous fix.
Please perform the instructions as given in message #70.
it is on the desktop when i did it so that fixlog should still be be valid
No. You started the tool FRST64.exe from the folder C:\Users\happy\Desktop\FRSTfix, not C:\Users\happy\Desktop which is your desktop.
