[SOLVED] CBS MUM Missing
Step#1 - FRST Fix
Résultats de correction de Farbar Recovery Scan Tool (x64) Version: 21.11.2018
Exécuté par admin-jp (14-12-2018 21:53:43) Run:28
Exécuté depuis C:\Users\jp\Desktop
Profils chargés: admin-jp & jp (Profils disponibles: admin-jp & jp & Coralie & Isalyne)
Mode d'amorçage: Normal
fixlist contenu:
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinPE-WMI-Package~31bf3856ad364e35~amd64~~0.0.0.0|Package_for_KB4284842_RTM~31bf3856ad364e35~amd64~~6.1.1.5
"HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinPE-WMI-Package~31bf3856ad364e35~amd64~~0.0.0.0\\Package_for_KB4284842_RTM~31bf3856ad364e35~amd64~~6.1.1.5" => supprimé(es) avec succès
==== Fin de Fixlog 21:53:43 ====
But
Binary Version 6.1.7601.23471
2018-12-14 21:53
Checking Package Watchlist
Checking Component Watchlist
Checking Packages
Checking Component Store
(f) CSI Missing Winning Component Key 0x00000000 amd64_microsoft-windows-s..-downlevel.binaries_31bf3856ad364e35_6.3.9600.17691_none_5f5cc410ff7c8bf5
Summary:
Seconds executed: 219
Found 1 errors
CSI Missing Winning Component Key Total count: 1
FRST Registry Search
3. Select the Programs group.
4. Click the Turn Windows features on or off link. This will bring up the Windows Features dialog. Wait until this dialog populates with information. If this does not happen for some reason, please continue with the steps anyway.
Note: This loads your components hive which is what we want. Please keep this dialog open while you perform the remaining steps.
5. Please download Farbar Recovery Scan Tool and save it to your Desktop.
7. Copy and paste
6.3.9600.17691 into the Search box and click the Search Registry button.
8. When the scan is complete a notepad window will open with the results. Please attach this to your next reply. It is saved on your desktop named SearchReg.txt.
Exécuté par admin-jp (14-12-2018 22:06:03)
================== Chercher Registre: "6.3.9600.17691" ===========
[HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_microsoft-windows-s..-downlevel.binaries_31bf3856ad364e35_6.3.9600.17691_none_5f5cc410ff7c8bf5]
[HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\VersionedIndex\6.1.7601.23505 (win7sp1_ldr.160722-0600)\ComponentFamilies\amd64_microsoft-windows-s..-downlevel.binaries_31bf3856ad364e35_none_4c333166e6d3e019\v!6.3.9600.17691]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide\Winners\amd64_microsoft-windows-s..-downlevel.binaries_31bf3856ad364e35_none_4c333166e6d3e019\6.3]
"6.3.9600.17691"="0x01"
====== Fin de Chercher ======
Step#1 - FRST Fix
All seems to be ok now thanks to your great job but do you know how my Windows got all theses issues ?
2018-12-14 22:31
Checking Packages
Summary:
Seconds executed: 209
No errors detected
All in all you can be proud of the tedious and time-consuming work you do helping people, BIG THANKS.
