Step#1 - FRST Fix NOTICE: This script was written specifically for this user, for use on that particular machine. Running this on another machine may cause damage to your operating system
1. Please download Farbar Recovery Scan Tool and save it to your Desktop. Note: You need to run the 64-bit Version so please ensure you download that one.
2. Download attached file and save it to the Desktop. Note. It's important that both files, FRST64 and fixlist.txt are in the same location or the fix will not work (in this case...the desktop).
