BrianDrab
Emeritus
OK, please close your registry editor. We can't use that hive anymore. Luckily I had you send me a copy so I have it. Please do the following. If you have any questions, please stop and ask.
Step#1 - Replace Manually
1. Download COMPONENTS2.ZIP and save to your desktop.
2. Right-click on it and select Extract all.... Make sure the "Show extracted files when complete" is checked and click Extract.
3. Now we have the COMPONENTS file that we will be using to replace your current one.
4. Navigate to C:\Windows\System32\config
5. Right-click on the current COMPONENTS file and select rename. Rename it to COMPONENTS.bad2.
6. Take the file from the Components2 folder on your desktop and paste it into C:\Windows\System32\config
