CSI Missing Winning Component Key - Lot of Missing Assembly errors when add features
Hi, I'm still getting errors about missing assembly while trying to add features to windows.
Does that also prevent you from running the SURT tool again ?
The SURT tool is missing a header part but we move on using another tool.
SFC Scan
Restart the computer.
Open an elevated command prompt.
Copy and paste the following commands into it, press enter after each.
copy %windir%\Logs\CBS\cbs.log "%userprofile%\Desktop\cbs.txt"
This will create a file, cbs.txt on your Desktop. Zip this file and attach the zipped cbs.txt to your next post.
I read in order so I run SFC before and after restart, sorry!
By the way, every time I restart I get the legend: Install updates and shutdown. It happened to me many times but it seems to me that it never finishes installing them. This time I selected only restart.
Go to Control Panel - Windows Update - Change settings.
Select Download updates but let me choose whether to install them.
Click OK.
Attach the file C:\Windows\Logs\CBS\CbsPersist_20230209115145.cab to your next reply.
Install Update with DISM
  1. Download the update MSU here: https://catalog.s.download.windowsu..._8a9779c594fec5a8ec70e49de467de3c67cf5829.msu
    cd C:\temp
    expand windows6.1-kb4088875-x64_8a9779c594fec5a8ec70e49de467de3c67cf5829.msu -f:* C:\temp
    DISM.exe /Online /Add-Package /PackagePath:C:\temp\windows6.1-kb4088875-x64.cab
    cd C:\temp
ERROR 14098: The component store was damaged.
Microsoft Windows [Versión 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. Reservados todos los derechos.
C:\Users\Administrador>DISM.exe /Online /Add-Package /PackagePath:C:\Temp\Win2008r2\windows6.1-kb4088875-x64.cab
Herramienta Administración y mantenimiento de imágenes de implementación
Versión: 6.1.7600.16385
Versión de imagen: 6.1.7601.18489
Procesando 1 de 1: Agregando paquete Package_for_RollupFix~31bf3856ad364e35~amd6
4~~7601.24076.1.2
[===== 10.0% ]
Error: Package_for_RollupFix Error: 0x80073712
Error: 14098
Se daño el almacén del componente.
El archivo de registro de DISM se encuentra en C:\Windows\Logs\DISM\dism.log
Please forgive me. I'm so sorry to bother you, but I'm starting to think this is one of your most difficult and tedious cases.
Don't worry about my time.
Remove Update Manually
    wusa /uninstall /KB:4056894
FRST Registry Search
  3. Select the Programs group.
  6. Copy and paste KB4056894 into the Search box and click the Search Registry button.
  3. Press the Fix button.
Run the command sfc /scannow in an elevated commandprompt and report the result.
If it fails attach the file cbs.log to your next reply.
When I try to reboot I see "Power off and install updates" option, but I selected only "Reboot". After that I run SFC /scannow and no error found.
C:\Users\Administrador.FUCHSAR>cd \
C:\>sfc /scannow
Iniciando examen en el sistema. Este proceso tardará algún tiempo.
Iniciando la fase de comprobación del examen del sistema.
Se completó la comprobación de 100%.
Protección de recursos de Windows no encontró ninguna infracción
de integridad.
Check Windows Update but do not install any updates yet.
Provide a screenshot of the available important updates first.
