CSI Missing Winning Component Key - Lot of Missing Assembly errors when add features
Try to install KB890830 only and report the result.
Try to install KB4343205 only and report the result.
If it fails attach a copy of the file cbs.log to your next reply.
Install Update with DISM
  1. Download the update MSU here: https://catalog.s.download.windowsu..._8a9779c594fec5a8ec70e49de467de3c67cf5829.msu
    cd C:\temp
    expand windows6.1-kb4088875-x64_8a9779c594fec5a8ec70e49de467de3c67cf5829.msu -f:* C:\temp
    DISM.exe /Online /Add-Package /PackagePath:C:\temp\windows6.1-kb4088875-x64.cab
    cd C:\temp
Remove Update Manually
    wusa /uninstall /KB:4088875
KB4088875 is not installed!
FRST Registry Search
  3. Select the Programs group.
  6. Copy and paste KB4088875 into the Search box and click the Search Registry button.
Found Nothing!
Farbar Recovery Scan Tool (x64) Versión: 09-01-2023
Ejecutado por Administrador (03-03-2023 19:22:31)
Ejecutado desde C:\Temp\Win2008r2
Modo de Inicio: Normal
================== Buscar en Registro: "KB4088875" ===========
====== Final de Buscar ======
  3. Press the Fix button.
Perform the instructions in message #46 again and report the result.
Step 2 falied!
Resultados de la corrección de Farbar Recovery Scan Tool (x64) Versión: 09-01-2023
Ejecutado por Administrador (07-03-2023 08:40:32) Run:5
Perfiles cargados: JSegovia & gselva & Administrador & KPrieto & maria.saponare & JDalessandro & RBallesillos & german.lopez
fixlist contenido:
CMD: REG LOAD HKLM\COMPONENTS C:\Windows\System32\config\COMPONENTS
StartRegedit:
[HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_input.inf_31bf3856ad364e35_6.1.7601.24024_none_7f141c594fe353d0]
"c!input.inf_31bf3856ad364e35_6.1.7601.24024_7f141c594fe353d0"=hex:
EndRegedit:
========= REG LOAD HKLM\COMPONENTS C:\Windows\System32\config\COMPONENTS =========
La operaci¢n se complet¢ correctamente.
========= Final de CMD: =========
Registro ====> La operaci�n se complet� correctamente.
==== Final de Fixlog 08:40:33 ====
    wusa /uninstall /KB:4534310
