[SOLVED] DNSAP.dll Problem!
2015-10-17 22:23:17, Info                  CSI    00001320 Hashes for file member \SystemRoot\WinSxS\amd64_microsoft-windows-dns-client-minwin_31bf3856ad364e35_10.0.10240.16384_none_9d8c256ebdd2e48a\dnsapi.dll do not match actual file [l:20{10}]"dnsapi.dll" :
  Found: {l:32 b:87ErPm6x7e2xW0UFxm1Fnme9IyidOo41DLhGIdh9sko=} Expected: {l:32 b:89EkYV4PbX7gh9gX2RWg3TlqSrM0cl1isOBDJ8+XdcQ=}
2015-10-17 22:23:17, Error                 CSI    00001321@2015/10/18:02:23:17.622 (F) base\wcp\componentstore\deltastore.cpp(2475): Error STATUS_INVALID_PARAMETER originated in function ComponentStore::CRawStoreLayout::DecompressFile expression: false
[gle=0x80004005]
We'll need to replace the dnsapi.dll file in your store with a clean copy. You can download the SFCFix.exe and SFCFix.zip files on your phone and move them on your computer.
SFCFix - Fix Time
SFCFix.zip
.I got it and it says Failed to check for updates. This may be due to an internet connection problem or a temporary availability failure of the update servers
What does the command prompt says? Sorry I just woke up.
And it won't go on in processing the script?
If you press on Enter while being in the command prompt when that message is displayed, does it move on or not?
It says en error occurred while processing the command. Ensure that the command line arguments are valid.
I don't need the DISM log for now, it looks like I'll need to create a batch script for the replacement. Your Internet connection is broken because of that DNSAPI.dll file, and it's also possible that it's due to an infection currently present on your system.
