[SOLVED] Dual Partitions Disk 0 will not boot
Hi!
First and foremost, backup everything you need. As far as I have understood you can boot to Windows 10 HDD? If so, back up everything you need from there and while you are there, please get me a fully expanded screenshot of Disk Management. After all of that has been done, we'll proceed. Sounds good?
Yes I can boot to Windows 10 HDD. I have backed up my what I wanted on an external drive. Here is the Disk Management:
Okay, now that everything is backed up, let's first check smart status of the problematic Windows 8 HDD.
GSmartControl
  • Execute gsmartcontrol.exe; Let the install complete and launch the programme.
Hi Softwaremaniac!
Looks to be 2 1/2 hours approx.
Softwaremaniac,
Is this test stuck at 90%? It has been like this for 20-30 minutes or so. These HDD's are always writing to the disks. Which this is annoying listening to noisy drives. Have to say the disks have been like that for 10 years. LOL Nevermind. Test are done.
Sorry for rattling..
Number of entries in self-test log: 1
"Test #","Type","Status","% Completed","Lifetime hours","LBA of the first error"
1,"Extended offline","Completed without error","100%","1927","-"
I have set Command Prompt to chk dsk. When I did this the other day. It said it had errors and it took hours to chkdsk /F. So it'll be awhile before I get back to you again. I had to leave the other day and I never did see the completion of that Disk being checked/finished/ or fixed.
Disk check went really fast this time which was odd on a 500GB HD. I ran the Dropbox- ListChkdsk and it opened in Notepad. I am sorry how do I share the results?
------< Log generate on 9/1/2018 7:27:07 PM >------
Category: 0
Computer Name: Seal-PC
Event Code: 1001
Record Number: 5760
Time Written: 09-01-2018 @ 23:21:22
Event Type: Information
User:
Message:
Checking file system on D:
Stage 1: Examining basic file system structure ...
283392 file records processed.
File verification completed.
6878 large file records processed.
0 bad file records processed.
Stage 2: Examining file name linkage ...
2423 reparse records processed.
339942 index entries processed.
Index verification completed.
0 unindexed files scanned.
0 unindexed files recovered to lost and found.
Stage 3: Examining security descriptors ...
Cleaning up 2 unused index entries from index $SII of file 0x9.
Cleaning up 2 unused index entries from index $SDH of file 0x9.
Cleaning up 2 unused security descriptors.
28276 data files processed.
35800712 USN bytes processed.
Windows has scanned the file system and found no problems.
No further action is required.
488384511 KB total disk space.
66028448 KB in 142644 files.
93160 KB in 28277 indexes.
0 KB in bad sectors.
404215 KB in use by the system.
421858688 KB available on disk.
122096127 total allocation units on disk.
105464672 allocation units available on disk.
Internal Info:
00 53 04 00 99 9b 02 00 12 1d 05 00 00 00 00 00 .S..............
15 01 00 00 62 08 00 00 00 00 00 00 00 00 00 00 ....b...........
Category: 0
Event Code: 1001
Record Number: 5350
Time Written: 08-30-2018 @ 01:14:36
User:
Message:
2421 reparse records processed.
Cleaning up 476 unused index entries from index $SII of file 0x9.
Cleaning up 476 unused index entries from index $SDH of file 0x9.
Cleaning up 476 unused security descriptors.
35779864 USN bytes processed.
Stage 4: Looking for bad clusters in user file data ...
283376 files processed.
File data verification completed.
Stage 5: Looking for bad, free clusters ...
106080553 free clusters processed.
Free space verification is complete.
CHKDSK discovered free space marked as allocated in the volume bitmap.
63565440 KB in 142647 files.
93156 KB in 28277 indexes.
403703 KB in use by the system.
424322212 KB available on disk.
106080553 allocation units available on disk.
Internal Info:
00 53 04 00 9c 9b 02 00 19 1d 05 00 00 00 00 00 .S..............
13 01 00 00 62 08 00 00 00 00 00 00 00 00 00 00 ....b...........
Category: 0
Event Code: 26226
Record Number: 5328
Source Name: Chkdsk
Time Written: 08-29-2018 @ 22:21:08
User:
Message: Chkdsk was executed in scan mode on a volume snapshot.
6907 large file records processed.
2566 reparse records processed.
342612 index entries processed.
29611 data files processed.
41072312 USN bytes processed.
102502844 KB in 150751 files.
96756 KB in 29612 indexes.
409335 KB in use by the system.
385375576 KB available on disk.
96343894 allocation units available on disk.
Category: 0
Event Code: 1001
Record Number: 4293
Time Written: 08-12-2018 @ 23:00:19
User:
Message:
Checking file system on C:
Volume label is New Volume.
The volume is dirty.
469760 file records processed.
11358 large file records processed.
30339 reparse records processed.
608360 index entries processed.
Cleaning up 402 unused index entries from index $SII of file 0x9.
Cleaning up 402 unused index entries from index $SDH of file 0x9.
Cleaning up 402 unused security descriptors.
69301 data files processed.
40145360 USN bytes processed.
487923711 KB total disk space.
383981880 KB in 350275 files.
214068 KB in 69302 indexes.
596947 KB in use by the system.
103130816 KB available on disk.
121980927 total allocation units on disk.
25782704 allocation units available on disk.
Internal Info:
00 2b 07 00 18 66 06 00 0a de 0b 00 00 00 00 00 .+...f..........
11 0d 00 00 72 69 00 00 00 00 00 00 00 00 00 00 ....ri..........
Category: 0
Event Code: 26226
Record Number: 3984
Source Name: Chkdsk
Time Written: 08-12-2018 @ 15:10:27
User:
6905 large file records processed.
2563 reparse records processed.
342600 index entries processed.
29605 data files processed.
35347872 USN bytes processed.
100245264 KB in 150712 files.
96708 KB in 29606 indexes.
403583 KB in use by the system.
387638956 KB available on disk.
96909739 allocation units available on disk.
Category: 0
Event Code: 1001
Record Number: 2502
Time Written: 05-30-2018 @ 20:30:45
User:
Message:
that you continue.
6879 large file records processed.
12128 reparse records processed.
552084 index entries processed.
Cleaning up 6864 unused index entries from index $SII of file 0x9.
Cleaning up 6864 unused index entries from index $SDH of file 0x9.
Cleaning up 6864 unused security descriptors.
CHKDSK is compacting the security descriptor stream
41163 data files processed.
38695576 USN bytes processed.
Correcting errors in the Volume Bitmap.
371525968 KB in 264153 files.
142604 KB in 41166 indexes.
593135 KB in use by the system.
115662004 KB available on disk.
28915501 allocation units available on disk.
Internal Info:
00 2b 07 00 c3 a7 04 00 62 28 08 00 00 00 00 00 .+......b(......
21 0d 00 00 3f 22 00 00 00 00 00 00 00 00 00 00 !...?"..........
Okay, let Startup Repair fail, then go into CMD and enter the following:
[B]
notepad[/B]
Hit enter.
When Notepad opens, click File... Open...
Go to This PC and check the drive letter of your Windows 8.1 HDD.
Close notepad and enter the following command into the CMD window:
DISM /image:C:\ /cleanup-image /revertpendingactions
Note: Replace C: with the drive letter identified in This PC.
Write your reply...
