[SOLVED] Dual Partitions Disk 0 will not boot
I restarted but there were no repairs in drive D and I follow your instructions again and I get the same thing in the command prompt.UGH!
When I boot into 8.1 ..I always get Repairing PC and then it goes to Advanced repair options. I was only trying to use the Command Prompt in Advanced Setting..I am not sure what you mean..Sorry...Every time I run Command Prompt within Windows 10 and run the SFC I get that message about restarting PC.
I have done all those repair options before all this. I will try all of them again..Should I run Command Prompt while I'm in 8.1 safemode?
No I cannot boot up in safemode in 8.1. Sorry about the confusion. I cannot get any where when rebooting the PC. I have 2 options. Windows 10 or 8.1 and 8.1 always keeps sending me to Repair. With the advanced options.
Hello Softwaremaniac!
Great news! I made another disk of 8.1 ISO. Then I started the disk in Windows 10 and 8.1 asked me for a keycode to activate and I entered that . I got an error of course because you cannot downgrade. But I was just seeing if this disk was bootable. I restarted my system and went into 8.1 partition and got the Preparing Auto Repair and I went to Advanced options and clicked Reset this PC. Then it told me to insert Media. Which asked to reset all drives and I said no just this one. So it looks like 8.1N Pro is now my default and I can now boot from both partitions. I am good to go. Thank you so much for all your patience and help & support This is now solved. :dance:
Of course you are most welcome and besides I learned some more about Windows with your helping me in all of this!:hysterical:
Write your reply...
