1. Please download Farbar Recovery Scan Tool and save it to your Desktop. Note: You need to run the 64-bit Version so please ensure you download that one.
4. Press Scan button.
6. Please attach the log back here.
7. Another log (Addition.txt - also located in the same directory as FRST64.exe) will be generated Please also attach that along with the FRST.txt in your reply.
After checking for updates, installation and failure.
Note that this is a server without SQL, the only service remaining on it is SQL Server VSS Writer.
Attached is CBS, FRST and Addition
