[SOLVED] Finally forced to move to 10. Errors involved
Didn't know it would make a difference
A shortcut to a file on a local computer or local network only works on that local computer or network. On a public network like the internet the file the shortcut is pointing to cannot be found.
The file cbs.log rolled-over so it isn't useful.
Please attach the most recent file called "C:\Windows\Logs\CBS\CbsPersist_<date><time>.cab"
Great. All clear now.
Install Update with DISM
  1. Download the update MSU here: https://catalog.s.download.windowsu..._b5614c6cea5cb4e198717789633dca16308ef79c.msu
    cd C:\temp
    expand windows6.1-kb4474419-v3-x64_b5614c6cea5cb4e198717789633dca16308ef79c.msu -f:* C:\temp
    DISM.exe /Online /Add-Package /PackagePath:C:\temp\windows6.1-kb4474419-v3-x64.cab
You made a typo, forgot the red marked text below.
Please redo the previous instructions.
Check for Windows Updates again.
Please report the result before you install any update.
Try to install the Windows Update "2019-09 Security Monthly..." again and report the result.
Copy the file C:\Windows\Logs\CBS\cbs.log to your desktop.
FRST Scan:
  2. Download the attachment fixlist.txt and save it to your desktop.
  3. Right-click on FRST64.exe and select "Run as administrator".
  4. Press the Fix button.
  5. The tool will now process fixlist.txt.
  6. If for some reason the tool needs a restart, please make sure you let the system restart normally. After that let the tool complete its run.
  7. When finished, a log called Fixlog.txt will appear in the same directory the tool is run from.
  8. Attach the logfile Fixlog.txt to your next reply.
  1. Download the update MSU here: http://download.windowsupdate.com/c..._d3de52d6987f7c8bdc2c015dca69eac96047c76e.msu
    cd C:\temp
    expand windows6.1-kb4490628-x64_d3de52d6987f7c8bdc2c015dca69eac96047c76e.msu -f:* C:\temp
    DISM.exe /Online /Add-Package /PackagePath:C:\temp\windows6.1-kb4490628-x64.cab
I have no idea what's going on with it this time. I don't know if that previous file in temp is messing something up or not
  • CBS.zip
    CBS.zip
It looks like file windows6.1-kb4490628-x64_d3de52d6987f7c8bdc2c015dca69eac96047c76e.msu isn't downloaded correctly or isn't copied successful. The size should be 9.321kb, not zero.
Remove the previously downloaded file, then download it again.
Next, try to install it again as mentioned in message #35.
It took this time. For some reason it marked that as a suspicious file and not the one you suspected and I didn't notice at first.
No restart prompted.
Restart the machine.
Somehow that specific one is missing. I also do not see it in the update history. This is after the restart of course
