P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 14,709 Jun 17, 2024 #41 Ok. Try to install the Windows Update "2020-01 Security Monthly..." again and report the result.
C CTMFSparky13 Member Joined Jun 10, 2024 Posts 24 Jun 17, 2024 #42 Update successful. Needs to restart though. Go ahead with that or should I try to install anything else first?
P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 14,709 Jun 17, 2024 #43 Perform the restart. Backup all your important data, then try the upgrade again and report the result.
C CTMFSparky13 Member Joined Jun 10, 2024 Posts 24 Jun 17, 2024 #44 Upgrade Successful so far it seems. Are there any important steps I should take now that I'm on 10 to ensure it runs safely/smoothly?
P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 14,709 Jun 17, 2024 #45 Great. No special steps are needed. Just keep your Windows and antivirus up-to-date.
C CTMFSparky13 Member Joined Jun 10, 2024 Posts 24 Jun 17, 2024 #46 Wonderful. Thanks for all your help
P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 14,709 Jun 17, 2024 #47 Your welcome. I will mark this thread as solved. Take care.
