[SOLVED] Having issues with my pc
FRST.txt
Scan result of Farbar Recovery Scan Tool (FRST) (x64) Version: 02-11-2021
Ran by Carlos Luna (administrator) on 1989AH (ASUS All Series) (03-11-2021 20:11:42)
Running from C:\Users\Carlos Luna\Desktop
Loaded Profiles: Carlos Luna
: Microsoft Windows 7 Ultimate Service Pack 1 (X64) Language: English (United States)
Default browser: Opera
Boot Mode: Normal
(Adobe Systems, Incorporated -> Adobe Systems Incorporated) C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\armsvc.exe
(Arvato Digital Services Canada Inc -> arvato digital services llc) C:\Program Files (x86)\Common Files\Protexis\License Service\PsiService_2.exe
(Borislav Surbat -> MyCity) C:\Program Files (x86)\MCShield\MCShieldRTM.exe
(Intel Corporation - Intel® Management Engine Firmware -> Intel Corporation) C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL\jhi_service.exe
(Intel Corporation - Software and Firmware Products -> Intel Corporation) C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\LMS\LMS.exe
(Intel(R) Corporation) [File not signed] C:\Program Files\Intel\iCLS Client\HeciServer.exe
(Logitech -> Logitech Inc.) C:\Program Files\Logitech Gaming Software\LCore.exe
(Microsoft Windows Hardware Compatibility Publisher -> ) C:\Program Files (x86)\ASUS\AXSP\1.01.01\atkexComSvc.exe
(NVIDIA Corporation -> NVIDIA Corporation) C:\Program Files\NVIDIA Corporation\Display.NvContainer\NVDisplay.Container.exe <2>
(Opera Software AS -> Opera Software) C:\Users\Carlos Luna\AppData\Local\Programs\Opera GX\80.0.4170.61\opera_crashreporter.exe
(Opera Software AS -> Opera Software) C:\Users\Carlos Luna\AppData\Local\Programs\Opera GX\opera.exe <12>
(Realtek Semiconductor Corp. -> Realtek Semiconductor) C:\Program Files\Realtek\Audio\HDA\RtkNGUI64.exe
==================== Registry (Whitelisted) ===================
HKLM\...\Run: [RTHDVCPL] => C:\Program Files\Realtek\Audio\HDA\RtkNGUI64.exe [9068040 2016-11-09] (Realtek Semiconductor Corp. -> Realtek Semiconductor)
HKLM\...\Run: [ProxyCap] => C:\Program Files\Proxy Labs\ProxyCap\pcapui.exe
HKLM\...\Run: [Launch LCore] => C:\Program Files\Logitech Gaming Software\LCore.exe [8294680 2014-02-27] (Logitech -> Logitech Inc.)
HKLM\...\Run: [AdobeAAMUpdater-1.0] => C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\UWA\UpdaterStartupUtility.exe [446392 2012-04-04] (Adobe Systems Incorporated -> Adobe Systems Incorporated)
HKLM-x32\...\Run: [Genshin Impact_Launcher] => [X]
HKLM-x32\...\Run: [USB3MON] => C:\Program Files (x86)\Intel\Intel(R) USB 3.0 eXtensible Host Controller Driver\Application\iusb3mon.exe [292848 2013-04-26] (Intel Corporation - Software and Firmware Products -> Intel Corporation)
HKLM-x32\...\Run: [SwitchBoard] => C:\Program Files (x86)\Common Files\Adobe\SwitchBoard\SwitchBoard.exe [517096 2010-02-19] (Test Signing Certificate -> Adobe Systems Incorporated) [File not signed]
HKLM-x32\...\Run: [BCSSync] => C:\Program Files (x86)\Microsoft Office\Office14\BCSSync.exe [91520 2010-03-13] (Microsoft Corporation -> Microsoft Corporation)
HKLM-x32\...\Run: [ADSKAppManager] => "C:\Program Files (x86)\Common Files\Autodesk Shared\AppManager\R1\AdAppMgr.exe" -showminimized -checkautorun
HKLM-x32\...\Run: [ADSK DLMSession] => C:\Program Files (x86)\Common Files\Autodesk Shared\Autodesk Download Manager\DLMSession.exe
HKLM-x32\...\Run: [AdobeCS6ServiceManager] => C:\Program Files (x86)\Common Files\Adobe\CS6ServiceManager\CS6ServiceManager.exe [1073312 2012-03-09] (Adobe Systems Incorporated -> Adobe Systems Incorporated)
HKU\S-1-5-21-2305226654-651215044-733858041-1000\...\Run: [Opera GX Browser Assistant] => C:\Users\Carlos Luna\AppData\Local\Programs\Opera GX\assistant\browser_assistant.exe [3291288 2021-02-01] (Opera Software AS -> Opera Software)
HKU\S-1-5-21-2305226654-651215044-733858041-1000\...\Run: [MCShield Monitor] => C:\Program Files (x86)\MCShield\mcshieldrtm.exe [650816 2014-04-11] (Borislav Surbat -> MyCity)
HKU\S-1-5-21-2305226654-651215044-733858041-1000\...\Run: [Google Update] => "C:\Users\Carlos Luna\AppData\Local\Google\Update\GoogleUpdate.exe" /c
HKU\S-1-5-21-2305226654-651215044-733858041-1000\...\MountPoints2: E - E:\setup.exe
HKU\S-1-5-21-2305226654-651215044-733858041-1000\...\MountPoints2: {7776be3f-f783-11e4-b3bf-ab6770d31304} - E:\Startme.exe
HKU\S-1-5-21-2305226654-651215044-733858041-1000\...\MountPoints2: {c02e2f6e-805e-11e6-9b0c-d850e63c46b2} - E:\setup\rsrc\Autorun.exe
HKU\S-1-5-21-2305226654-651215044-733858041-1000\...\MountPoints2: {c2d0008f-546d-11e8-b0dd-0014d1237121} - F:\startme.exe
HKU\S-1-5-18\...\RunOnce: [SPReview] => C:\Windows\System32\SPReview\SPReview.exe [301568 2014-03-12] (Microsoft Windows -> Microsoft Corporation)
HKLM\Software\Microsoft\Active Setup\Installed Components: [{2D46B6DC-2207-486B-B523-A557E6D54B47}] -> C:\Windows\system32\cmd.exe /D /C start C:\Windows\system32\ie4uinit.exe -ClearIconCache
HKLM\Software\Wow6432Node\Microsoft\Active Setup\Installed Components: [{2D46B6DC-2207-486B-B523-A557E6D54B47}] -> C:\Windows\system32\cmd.exe /D /C start C:\Windows\system32\ie4uinit.exe -ClearIconCache
HKLM\Software\Wow6432Node\Microsoft\Active Setup\Installed Components: [{8A69D345-D564-463c-AFF1-A69D9E530F96}] -> "C:\Program Files (x86)\Google\Chrome\Application\58.0.3029.81\Installer\chrmstp.exe" --configure-user-settings --verbose-logging --system-level
Startup: C:\Users\Carlos Luna\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\GameVox.lnk [2016-03-17]
ShortcutTarget: GameVox.lnk -> C:\Program Files (x86)\GameVox\GameVox.exe (No File)
GroupPolicy: Restriction ? <==== ATTENTION
Policies: C:\ProgramData\NTUSER.pol: Restriction <==== ATTENTION
HKLM\SOFTWARE\Policies\Mozilla\Firefox: Restriction <==== ATTENTION
HKLM\SOFTWARE\Policies\Google: Restriction <==== ATTENTION
==================== Scheduled Tasks (Whitelisted) ============
Task: {0C9A5565-C85D-4309-810F-9B2EF6D93455} - System32\Tasks\EOSv3 Scheduler onLogOn => C:\Users\Carlos Luna\Downloads\esetonlinescanner_esn.exe
Task: {1156D15A-AAE6-4EE4-A768-C21AF23191D3} - System32\Tasks\{9F4A8BFD-E17F-4A42-B4EE-55FD2C147405} => C:\Windows\system32\pcalua.exe -a "C:\Users\Carlos Luna\AppData\Roaming\Nox\bin\Nox_unload.exe"
Task: {1ADD0762-CC79-45E7-B15D-17E123E1BE18} - System32\Tasks\Microsoft_Hardware_Launch_ipoint_exe => C:\Program Files\Microsoft Mouse and Keyboard Center\ipoint.exe [2206488 2016-08-15] (Microsoft Corporation -> Microsoft Corporation)
Task: {427624A0-6125-446F-84D9-BC6C71027E47} - System32\Tasks\Microsoft_Hardware_Launch_mousekeyboardcenter_exe => C:\Program Files\Microsoft Mouse and Keyboard Center\mousekeyboardcenter.exe [2225952 2016-08-15] (Microsoft Corporation -> Microsoft)
Task: {4580E52B-91EE-42B5-9363-56BABDA2AFFC} - System32\Tasks\CorelUpdateHelperTask-F299A6B575097899476390FCD7D79BE3 => C:\Program Files (x86)\Corel\CUH\v2\CUH.exe
Task: {45A4D6E9-3EB8-4039-87C0-8EDD5A1CDC23} - System32\Tasks\Opera GX scheduled assistant Autoupdate 1634663272 => C:\Users\Carlos Luna\AppData\Local\Programs\Opera GX\launcher.exe [3963600 2021-10-19] (Opera Software AS -> Opera Software) -> --scheduledautoupdate --component-name=assistant --component-path="C:\Users\Carlos Luna\AppData\Local\Programs\Opera GX\assistant" $(Arg0)
Task: {4D109734-C672-4DAB-8E1C-0848709181B8} - System32\Tasks\Games\UpdateCheck_S-1-5-21-2305226654-651215044-733858041-1000 => {CA22F5B1-E06F-4A2B-94FC-21E87FE53781} C:\Windows\System32\gameux.dll [2746368 2012-12-07] (Microsoft Windows -> Microsoft Corporation)
Task: {52482CF5-BDD9-49A4-94A9-43C7A412C125} - System32\Tasks\{CB3E5831-270F-443A-894C-A54F005941DE} => C:\Windows\system32\pcalua.exe -a "C:\Users\Carlos Luna\Downloads\setup-gtarcade-601b27db75125.exe" -d "C:\Users\Carlos Luna\Downloads"
Task: {5918D14A-68E3-4CFE-B21E-E1748D153440} - System32\Tasks\AdobeAAMUpdater-1.0-CarlosLuna-PC-Carlos Luna => C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\UWA\UpdaterStartupUtility.exe [446392 2012-04-04] (Adobe Systems Incorporated -> Adobe Systems Incorporated)
Task: {61AA0E70-25B1-4153-A33F-B19B7AC78098} - System32\Tasks\{0C2E49FB-E0FA-4939-849F-2F5A476D0F82} => C:\Windows\system32\pcalua.exe -a "C:\Users\Carlos Luna\Downloads\coreaacSetup.exe" -d "C:\Users\Carlos Luna\Downloads"
Task: {62A6C492-DB90-48A0-8729-0E9EE4C6AA60} - System32\Tasks\Adobe Acrobat Update Task => C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\AdobeARM.exe [998104 2015-07-07] (Adobe Systems, Incorporated -> Adobe Systems Incorporated)
Task: {671E9D4A-C29E-4F2E-B2B6-E844B48D0215} - System32\Tasks\AVAST Software\Avast settings backup => C:\Program Files\Common Files\AV\avast! Antivirus\backup.exe
Task: {6D10DDD6-E35A-4909-8989-1D5F095840CE} - System32\Tasks\CCleanerSkipUAC => C:\Program Files\CCleaner\CCleaner.exe [4624152 2014-06-24] (Piriform Ltd -> Piriform Ltd)
Task: {6FC4D6E7-AEFA-40A9-9BB7-93CA381DA6F7} - System32\Tasks\BlueStacksHelper_nxt => C:\Program Files\BlueStacks_nxt\BlueStacksHelper.exe [275136 2021-09-21] (Bluestack Systems, Inc -> BlueStack Systems, Inc.)
Task: {8F95A2D6-F062-4745-A5AF-962DB9825FAA} - System32\Tasks\Opera GX scheduled Autoupdate 1634241479 => C:\Users\Carlos Luna\AppData\Local\Programs\Opera GX\launcher.exe [3963600 2021-10-19] (Opera Software AS -> Opera Software)
Task: {93D89636-DEDB-4163-B18A-E7AA18E71A78} - System32\Tasks\CorelUpdateHelperTaskCore => c:\Program Files (x86)\Corel\CUH\v2\CUH.exe
Task: {A3B005D3-E9D2-481C-8F83-C314EFE5F8A2} - System32\Tasks\Microsoft_MKC_Logon_Task_itype.exe => C:\Program Files\Microsoft Mouse and Keyboard Center\itype.exe [1665312 2016-08-15] (Microsoft Corporation -> Microsoft Corporation)
Task: {B07B46E1-E12B-40BE-98B3-19CE5A3F4679} - System32\Tasks\MEGA\MEGAsync Update Task S-1-5-21-2305226654-651215044-733858041-1000 => C:\Users\Carlos Luna\AppData\Local\MEGAsync\MEGAupdater.exe
Task: {BD5159BA-C4CA-4CEC-A03A-8757F4788891} - System32\Tasks\{9AC3D973-ABA9-417C-BFEC-58F9A2E0316A} => C:\Windows\system32\pcalua.exe -a "C:\Program Files (x86)\InstallShield Installation Information\{7F7E4FA7-6F32-4DE2-917E-361E034AED7A}\setup.exe" -c -runfromtemp -l0x0409
Task: {CFE7C1EB-6D01-4C36-9CBB-4299E628064A} - System32\Tasks\{FB630E37-2B8D-498A-AF0C-D1E8035CCC9A} => C:\Windows\system32\pcalua.exe -a "C:\Users\Carlos Luna\Downloads\remix-os-player-1-0-108.exe" -d "C:\Users\Carlos Luna\Downloads"
Task: {D0087371-BA7B-40D8-B082-1AA679E01EE7} - System32\Tasks\Microsoft_MKC_Logon_Task_ipoint.exe => C:\Program Files\Microsoft Mouse and Keyboard Center\ipoint.exe [2206488 2016-08-15] (Microsoft Corporation -> Microsoft Corporation)
Task: {D0C532E0-D1C5-4939-9A5D-20C1E65CEBAA} - System32\Tasks\Microsoft_Hardware_Launch_itype_exe => C:\Program Files\Microsoft Mouse and Keyboard Center\itype.exe [1665312 2016-08-15] (Microsoft Corporation -> Microsoft Corporation)
Task: {D685ED40-7570-4DD0-8D05-E36B8F49EF67} - System32\Tasks\BlueStacksHelper => C:\ProgramData\BlueStacks\Client\Helper\BlueStacksHelper.exe [754472 2021-04-05] (BlueStack Systems, Inc. -> BlueStack Systems, Inc.)
Task: {DD67DAB7-77D5-429A-A54E-4723DD7E316D} - System32\Tasks\{8BA74D91-FA29-419D-858B-36DC14E276AD} => C:\Windows\system32\pcalua.exe -a "F:\AutoPlay\Docs\Extras\Game Tools\DOSBox 0.63\DOSBox0.63-win32-installer.exe" -d "F:\AutoPlay\Docs\Extras\Game Tools\DOSBox 0.63"
Task: {E7C96D1D-73AE-4ED4-ACCB-72AAE2A699BB} - System32\Tasks\EOSv3 Scheduler onTime => C:\Users\Carlos Luna\Downloads\esetonlinescanner_esn.exe
IPSecPolicy: [ActivePolicy] SOFTWARE\Policies\Microsoft\Windows\IPSEC\Policy\Local\ipsecPolicy{54a8fc58-9b91-49c0-9f77-0893a0c1aae3} <==== ATTENTION (Restriction - IP)
Tcpip\Parameters: [DhcpNameServer] 200.48.225.146 200.48.225.130
Tcpip\..\Interfaces\{4F611090-1E2A-4C0B-B218-CB68014871BD}: [DhcpNameServer] 192.168.42.129
Tcpip\..\Interfaces\{577DA66F-E0C5-4726-8D88-1A73332085A9}: [DhcpNameServer] 200.48.225.146 200.48.225.130
Tcpip\..\Interfaces\{8D58557D-1DB6-4DD8-B77E-9A6F9972990A}: [DhcpNameServer] 192.168.42.129
Tcpip\..\Interfaces\{A27F8B15-26C0-4909-9700-9719E16C3A24}: [DhcpNameServer] 200.48.225.130 200.48.225.146
Tcpip\..\Interfaces\{B67BBEAF-70C7-4ED9-ADCE-DAC65DF532A9}: [DhcpNameServer] 200.48.225.146 200.48.225.130
HKLM\System\...\Parameters\PersistentRoutes: [0.0.0.0,0.0.0.0,26.0.0.1,9256]
FireFox:
FF Plugin: @microsoft.com/GENUINE -> disabled [No File]
FF Plugin: @microsoft.com/OfficeAuthz,version=14.0 -> C:\PROGRA~1\MICROS~3\Office14\NPAUTHZ.DLL [2010-01-09] (Microsoft Corporation -> Microsoft Corporation)
FF Plugin: @wacom.com/wtPlugin,version=2.1.0.2 -> C:\Program Files\TabletPlugins\npWacomTabletPlugin.dll [No File]
FF Plugin: wacom.com/WacomTabletPlugin -> C:\Program Files\TabletPlugins\npWacomTabletPlugin.dll [No File]
FF Plugin-x32: @intel-webapi.intel.com/Intel WebAPI ipt;version=4.0.5 -> C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT\npIntelWebAPIIPT.dll [2013-09-16] (Intel® Identity Protection Technology Software -> Intel Corporation)
FF Plugin-x32: @intel-webapi.intel.com/Intel WebAPI updater -> C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT\npIntelWebAPIUpdater.dll [2013-09-16] (Intel® Identity Protection Technology Software -> Intel Corporation)
FF Plugin-x32: @microsoft.com/GENUINE -> disabled [No File]
FF Plugin-x32: @microsoft.com/OfficeAuthz,version=14.0 -> C:\PROGRA~2\MICROS~2\Office14\NPAUTHZ.DLL [2010-01-09] (Microsoft Corporation -> Microsoft Corporation)
FF Plugin-x32: @microsoft.com/SharePoint,version=14.0 -> C:\PROGRA~2\MICROS~2\Office14\NPSPWRAP.DLL [2010-03-24] (Microsoft Corporation -> Microsoft Corporation)
FF Plugin-x32: @videolan.org/vlc,version=2.1.3 -> C:\Program Files (x86)\VideoLAN\VLC\npvlc.dll [No File]
FF Plugin-x32: @videolan.org/vlc,version=2.2.1 -> C:\Program Files (x86)\VideoLAN\VLC\npvlc.dll [No File]
FF Plugin-x32: @videolan.org/vlc,version=2.2.6 -> C:\Program Files (x86)\VideoLAN\VLC\npvlc.dll [No File]
FF Plugin-x32: @wacom.com/wtPlugin,version=2.1.0.2 -> C:\Program Files (x86)\TabletPlugins\npWacomTabletPlugin.dll [No File]
FF Plugin-x32: wacom.com/WacomTabletPlugin -> C:\Program Files (x86)\TabletPlugins\npWacomTabletPlugin.dll [No File]
FF Plugin HKU\S-1-5-21-2305226654-651215044-733858041-1000: @unity3d.com/UnityPlayer,version=1.0 -> C:\Users\Carlos Luna\AppData\LocalLow\Unity\WebPlayer\loader\npUnity3D32.dll [2015-07-05] (Unity Technologies SF -> Unity Technologies ApS)
FF Plugin HKU\S-1-5-21-2305226654-651215044-733858041-1000: wacom.com/WacomTabletPlugin -> C:\Program Files\TabletPlugins\npWacomTabletPlugin.dll [No File]
Chrome:
CHR HKLM-x32\...\Chrome\Extension: [bnbbhgcfmdnamgfgjfgjdkcjbofkjihb]
CHR HKLM-x32\...\Chrome\Extension: [eofcbnmajmjmplflapaojjnihcjkigck]
CHR HKLM-x32\...\Chrome\Extension: [gomekmidlodglbbmalcneegieacbdmki] - C:\Program Files\AVAST Software\Avast\WebRep\Chrome\aswWebRepChrome.crx <not found>
CHR HKLM-x32\...\Chrome\Extension: [kpdmjodecdegfglgaapafjleomjjlpnh]
CHR HKLM-x32\...\Chrome\Extension: [lifbcibllhkdhoafpjfnlhfpfgnpldfl]
CHR HKLM-x32\...\Chrome\Extension: [looohgelibjoplmkhecmalapkgadkfcc]
CHR HKLM-x32\...\Chrome\Extension: [mcegpkkjabjeiddmpmgbmjlmiebfiofd]
CHR HKLM-x32\...\Chrome\Extension: [npdicihegicnhaangkdmcgbjceoemeoo]
Opera:
OPR Profile: C:\Users\Carlos Luna\AppData\Roaming\Opera Software\Opera Stable [2021-10-14]
OPR DefaultSuggestURL: Opera Stable -> hxxps://www.google.com/complete/search?client=opera&q={searchTerms}&ie={inputEncoding}&oe={outputEncoding}
OPR Extension: (Rich Hints Agent) - C:\Users\Carlos Luna\AppData\Roaming\Opera Software\Opera Stable\Extensions\enegjkbbakeegngfapepobipndnebkdk [2021-09-29]
OPR Extension: (Amazon Assistant Promotion) - C:\Users\Carlos Luna\AppData\Roaming\Opera Software\Opera Stable\Extensions\kbmoiomgmchbpihhdpabemajcbjpcijk [2021-09-28]
StartMenuInternet: (HKU\S-1-5-21-2305226654-651215044-733858041-1000) Opera GXStable - "C:\Users\Carlos Luna\AppData\Local\Programs\Opera GX\Launcher.exe"
==================== Services (Whitelisted) ===================
R2 AdobeARMservice; C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\armsvc.exe [82128 2015-07-07] (Adobe Systems, Incorporated -> Adobe Systems Incorporated)
R2 asComSvc; C:\Program Files (x86)\ASUS\AXSP\1.01.01\atkexComSvc.exe [927232 2012-10-29] (Microsoft Windows Hardware Compatibility Publisher -> )
S3 EasyAntiCheat; C:\Program Files (x86)\EasyAntiCheat\EasyAntiCheat.exe [781440 2019-03-11] (EasyAntiCheat Oy -> EasyAntiCheat Ltd)
S3 EpicOnlineServices; C:\Program Files (x86)\Epic Games\Epic Online Services\service\EpicOnlineServicesHost.exe [16029472 2021-10-23] (Epic Games Inc. -> Epic Games, Inc.)
S3 IDriverT; C:\Program Files (x86)\Common Files\InstallShield\Driver\11\Intel 32\IDriverT.exe [69632 2005-04-04] (Macrovision Corporation) [File not signed]
R2 Intel(R) Capability Licensing Service Interface; C:\Program Files\Intel\iCLS Client\HeciServer.exe [747520 2013-08-27] (Intel(R) Corporation) [File not signed]
S3 npggsvc; C:\Windows\SysWOW64\GameMon.des [9473408 2021-01-18] (INCA Internet Co.,Ltd. -> INCA Internet Co., Ltd.)
R2 PSI_SVC_2; c:\Program Files (x86)\Common Files\Protexis\License Service\PsiService_2.exe [277360 2014-04-30] (Arvato Digital Services Canada Inc -> arvato digital services llc)
S3 SwitchBoard; C:\Program Files (x86)\Common Files\Adobe\SwitchBoard\SwitchBoard.exe [517096 2010-02-19] (Test Signing Certificate -> Adobe Systems Incorporated) [File not signed]
R2 WinDefend; C:\Program Files\Windows Defender\mpsvc.dll [1011712 2013-05-27] (Microsoft Windows -> Microsoft Corporation)
S4 MozillaMaintenance; "C:\Program Files (x86)\Mozilla Maintenance Service\maintenanceservice.exe" [X]
===================== Drivers (Whitelisted) ===================
R1 AsIO; C:\Windows\SysWow64\drivers\AsIO.sys [15232 2012-08-21] (ASUSTeK Computer Inc. -> )
R2 BlueStacksDrv_nxt; C:\Program Files\BlueStacks_nxt\BstkDrv_nxt.sys [320728 2021-09-20] (Bluestack Systems, Inc -> Bluestack System Inc.)
S3 dtlitescsibus; C:\Windows\System32\DRIVERS\dtlitescsibus.sys [30264 2016-09-22] (Disc Soft Ltd -> Disc Soft Ltd)
S3 dtliteusbbus; C:\Windows\System32\DRIVERS\dtliteusbbus.sys [47672 2016-09-22] (Disc Soft Ltd -> Disc Soft Ltd)
R0 klupd_klif_arkmon; C:\Windows\System32\Drivers\klupd_klif_arkmon.sys [246952 2021-10-19] (Microsoft Windows Hardware Compatibility Publisher -> AO Kaspersky Lab)
S3 klupd_klif_klark; C:\Windows\System32\Drivers\klupd_klif_klark.sys [284408 2021-10-19] (Microsoft Windows Hardware Compatibility Publisher -> AO Kaspersky Lab)
R3 LGSHidFilt; C:\Windows\System32\DRIVERS\LGSHidFilt.Sys [64280 2013-05-30] (Logitech -> Logitech Inc.)
R3 LGSUsbFilt; C:\Windows\System32\DRIVERS\LGSUsbFilt.Sys [41752 2013-05-30] (Logitech -> Logitech Inc.)
R3 rtl819xpn64; C:\Windows\System32\DRIVERS\rtl819xp.sys [622624 2010-02-01] (Realtek Semiconductor Corp -> Realtek Semiconductor Corporation)
S3 RTTEAMPT; C:\Windows\System32\DRIVERS\RtTeam620.sys [58512 2012-07-03] (Realtek Semiconductor Corp -> Realtek Corporation)
S3 RvNetMP60; C:\Windows\System32\DRIVERS\RvNetMP60.sys [69048 2018-12-25] (Famatech Corp. -> Famatech Corp.)
S3 tap0901; C:\Windows\System32\DRIVERS\tap0901.sys [27136 2017-08-30] (OpenVPN Technologies, Inc. -> The OpenVPN Project)
R1 VBoxUSBMon; C:\Windows\System32\DRIVERS\VBoxUSBMon.sys [127432 2016-12-03] (Duodian Online Technology Co. Ltd. -> BigNox Corporation)
R3 wovad_micarray; C:\Windows\System32\drivers\womic.sys [35696 2017-11-25] (Beijing Wolicheng Technology Co., Ltd. -> Windows (R) Win 7 DDK provider)
S1 amsdk; \??\C:\Windows\system32\drivers\amsdk.sys [X]
S2 BlueStacksDrv; \??\C:\Program Files\BlueStacks\BstkDrv_bgp.sys [X]
S3 Synth3dVsc; System32\drivers\synth3dvsc.sys [X]
S3 tsusbhub; system32\drivers\tsusbhub.sys [X]
S3 VGPU; System32\drivers\rdvgkmd.sys [X]
S3 WacHidRouter; system32\DRIVERS\wachidrouter.sys [X]
S3 wacomrouterfilter; system32\DRIVERS\wacomrouterfilter.sys [X]
S3 WinRing0_1_2_0; \??\C:\Users\Carlos Luna\AppData\Local\Temp\tmpE675.tmp [X] <==== ATTENTION
S3 xhunter1; \??\C:\Windows\xhunter1.sys [X]
S1 YSDrv; \??\C:\Program Files (x86)\Bignox\BigNoxVM\RT\YSDrv.sys [X]
==================== Three months (created) (Whitelisted) =========
2021-11-03 20:11 - 2021-11-03 20:13 - 000021478 _____ C:\Users\Carlos Luna\Desktop\FRST.txt
2021-11-03 20:02 - 2021-11-03 20:03 - 000001970 _____ C:\Users\Carlos Luna\Desktop\netcfg_2021-11-03_20-02-55.dat
2021-11-03 10:11 - 2021-11-03 10:11 - 000000000 ____D C:\Users\Carlos Luna\AppData\Local\CrashDumps
2021-11-03 01:03 - 2021-11-03 01:03 - 000000031 _____ C:\Users\Carlos Luna\Documents\recover network settings.txt
2021-11-02 19:01 - 2021-11-02 19:01 - 000005478 _____ C:\NetworkSettings.txt
2021-11-02 18:59 - 2021-11-02 19:00 - 000005478 _____ C:\Windows\system32\NetworkSettings.txt
2021-11-02 18:58 - 2021-11-02 18:58 - 001053600 _____ (ESET) C:\Users\Carlos Luna\Desktop\esetuninstaller.exe
2021-11-01 15:33 - 2021-11-03 20:11 - 000000000 ____D C:\Users\Carlos Luna\Desktop\FRST-OlderVersion
2021-10-31 20:20 - 2021-10-31 20:20 - 000000186 _____ C:\Users\Carlos Luna\Documents\fixlist.txt
2021-10-30 19:13 - 2021-10-30 19:10 - 000038441 _____ C:\Users\Carlos Luna\Documents\FRST.txt
2021-10-28 17:52 - 2021-11-03 20:04 - 000000000 ____D C:\ProgramData\MCShield
2021-10-28 17:52 - 2021-10-28 17:52 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\MCShield
2021-10-28 17:52 - 2021-10-28 17:52 - 000000000 ____D C:\Program Files (x86)\MCShield
2021-10-28 17:44 - 2021-10-28 17:45 - 002856736 _____ (MyCity) C:\Users\Carlos Luna\Desktop\MCShield-Setup.exe
2021-10-26 22:53 - 2021-10-26 22:53 - 001802704 _____ (Bleeping Computer, LLC) C:\Users\Carlos Luna\Downloads\iExplore.exe
2021-10-25 20:29 - 2021-11-03 20:12 - 000000000 ____D C:\FRST
2021-10-25 19:16 - 2021-11-03 20:11 - 002311168 _____ (Farbar) C:\Users\Carlos Luna\Desktop\FRST64.exe
2021-10-24 19:45 - 2021-10-24 19:48 - 000000000 ____D C:\Users\Carlos Luna\AppData\Local\niemiro
2021-10-24 01:54 - 2021-10-24 01:54 - 002316112 _____ (niemiro) C:\Users\Carlos Luna\Desktop\SFCFix.exe
2021-10-24 01:20 - 2021-10-24 01:20 - 010228313 _____ (Macrovision Corporation) C:\Users\Carlos Luna\Downloads\asmwsoftpcoptimizersetup.exe
2021-10-24 01:04 - 2021-10-24 01:05 - 000000000 ____D C:\Users\Carlos Luna\Downloads\Windupdate
2021-10-24 00:28 - 2021-10-28 22:08 - 000000000 ____D C:\Users\Carlos Luna\AppData\Local\ElevatedDiagnostics
2021-10-24 00:11 - 2021-10-24 00:11 - 003298367 _____ C:\Users\Carlos Luna\Downloads\Windows6.1-KB3050265-x64.msu
2021-10-23 23:01 - 2021-10-23 23:02 - 000000000 ____D C:\Program Files\TEST
2021-10-23 21:43 - 2021-10-23 21:43 - 000000000 ____D C:\Users\Carlos Luna\AppData\Local\EOSUserHelper
2021-10-23 21:42 - 2021-10-23 21:42 - 000000000 ____D C:\Users\Carlos Luna\AppData\Local\Epic Games
2021-10-23 21:30 - 2021-10-23 21:30 - 000000000 ____D C:\Users\Default\AppData\Local\Epic Games
2021-10-21 20:11 - 2021-10-21 20:19 - 000000000 ____D C:\Users\Carlos Luna\Downloads\backups
2021-10-21 18:01 - 2021-10-21 18:01 - 000000000 ____D C:\Users\Carlos Luna\AppData\Local\CEF
2021-10-20 22:52 - 2021-10-20 22:53 - 000388608 _____ (Trend Micro Inc.) C:\Users\Carlos Luna\Downloads\HijackThis.exe
2021-10-19 12:08 - 2021-10-19 12:08 - 000004352 _____ C:\Windows\system32\Tasks\Opera GX scheduled assistant Autoupdate 1634663272
2021-10-19 05:27 - 2021-10-19 05:27 - 000284408 _____ (AO Kaspersky Lab) C:\Windows\system32\Drivers\klupd_klif_klark.sys
2021-10-19 05:25 - 2021-10-19 05:25 - 000246952 _____ (AO Kaspersky Lab) C:\Windows\system32\Drivers\klupd_klif_arkmon.sys
2021-10-19 02:18 - 2021-10-19 02:18 - 000057449 _____ C:\Windows\system32\NOTICE_mod
2021-10-18 22:48 - 2021-10-18 22:48 - 000909824 _____ (Farbar) C:\Users\Carlos Luna\Downloads\FSS.exe
2021-10-18 22:47 - 2021-10-18 22:48 - 201686784 _____ (SUPERAntiSpyware) C:\Users\Carlos Luna\Downloads\SUPERAntiSpyware.exe
2021-10-17 02:19 - 2021-10-17 02:19 - 000000000 ____D C:\ProgramData\Emsisoft
2021-10-17 00:57 - 2021-10-17 00:57 - 001802704 _____ (Bleeping Computer, LLC) C:\Users\Carlos Luna\Downloads\rkill.exe
2021-10-14 14:58 - 2021-10-26 12:39 - 000004100 _____ C:\Windows\system32\Tasks\Opera GX scheduled Autoupdate 1634241479
2021-10-14 14:58 - 2021-10-14 14:58 - 000001437 _____ C:\Users\Carlos Luna\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Opera GX Browser.lnk
2021-10-13 21:05 - 2021-10-13 21:06 - 000000083 _____ C:\Users\Carlos Luna\Documents\lista cosas.txt
2021-10-12 02:37 - 2021-10-12 02:37 - 000001085 _____ C:\Users\Carlos Luna\Desktop\Windows Media Player.lnk
2021-10-11 02:36 - 2021-10-11 02:36 - 000001345 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Media Center.lnk
2021-10-11 02:35 - 2021-10-11 02:35 - 000000000 ____D C:\Users\Default\AppData\Roaming\Media Center Programs
2021-10-08 16:24 - 2021-10-08 16:24 - 000000000 ____D C:\.android
2021-10-08 04:10 - 2021-10-08 04:10 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Project64 2.3
2021-10-08 04:10 - 2021-10-08 04:10 - 000000000 ____D C:\Program Files (x86)\Project64 3.0
2021-09-27 15:15 - 2021-09-27 20:37 - 000000000 ____D C:\Users\Carlos Luna\AppData\Local\GUI
2021-09-26 13:30 - 2021-11-03 10:12 - 000000000 ____D C:\ProgramData\BlueStacks_nxt
2021-09-26 13:30 - 2021-09-27 18:10 - 000000000 ____D C:\Program Files\BlueStacks_nxt
2021-09-26 13:26 - 2021-09-26 13:26 - 001168608 _____ (BlueStack Systems Inc.) C:\Users\Carlos Luna\Downloads\BlueStacksMicroInstaller_5.3.70.1004_native.exe
2021-08-30 00:49 - 2021-10-10 23:03 - 000000995 _____ C:\Users\Carlos Luna\Desktop\Genshin Impact.lnk
2021-08-06 18:53 - 2021-09-26 13:32 - 000001987 _____ C:\Users\Public\Desktop\BlueStacks 5.lnk
==================== Three months (modified) ==================
2021-11-03 20:11 - 2009-07-13 23:45 - 000023936 ____H C:\Windows\system32\7B296FB0-376B-497e-B012-9C450E1B7327-5P-1.C7483456-A289-439d-8115-601632D005A0
2021-11-03 20:11 - 2009-07-13 23:45 - 000023936 ____H C:\Windows\system32\7B296FB0-376B-497e-B012-9C450E1B7327-5P-0.C7483456-A289-439d-8115-601632D005A0
2021-11-03 20:05 - 2020-07-17 23:22 - 000000000 ____D C:\ProgramData\NVIDIA
2021-11-03 20:04 - 2009-07-14 00:08 - 000000006 ____H C:\Windows\Tasks\SA.DAT
2021-11-03 20:03 - 2009-07-13 22:20 - 000000000 ____D C:\Windows\inf
2021-11-03 19:59 - 2016-04-14 00:33 - 000000000 ____D C:\Windows\pss
2021-11-03 17:31 - 2020-10-21 01:14 - 000000000 ____D C:\Program Files\Genshin Impact
2021-11-03 10:11 - 2015-04-19 18:58 - 000007630 _____ C:\Users\Carlos Luna\AppData\Local\Resmon.ResmonCfg
2021-11-03 08:57 - 2014-07-04 16:56 - 000000000 ____D C:\Users\Carlos Luna\AppData\Local\Adobe
2021-11-03 01:02 - 2014-06-22 19:37 - 000000000 ____D C:\Program Files (x86)\Steam
2021-11-02 21:38 - 2017-05-05 20:31 - 000000000 ____D C:\Users\Carlos Luna\AppData\Roaming\discord
2021-11-02 21:10 - 2017-05-05 20:30 - 000000000 ____D C:\Users\Carlos Luna\AppData\Local\Discord
2021-11-02 18:52 - 2020-03-13 03:31 - 000000000 ____D C:\Users\Carlos Luna\AppData\Roaming\Sun
2021-11-02 18:52 - 2014-05-10 22:18 - 000000000 ____D C:\Program Files\Java
2021-11-02 18:47 - 2014-03-12 19:31 - 000000000 ____D C:\Windows\system32\Macromed
2021-11-02 18:47 - 2014-03-12 19:26 - 000000000 ____D C:\Windows\SysWOW64\Macromed
2021-11-01 20:53 - 2016-06-08 15:05 - 000000000 ____D C:\Users\Carlos Luna\AppData\Roaming\.minecraft
2021-10-30 17:55 - 2014-08-07 03:52 - 000000132 _____ C:\Users\Carlos Luna\AppData\Roaming\Prefs. de formato PNG de Adobe CS6
2021-10-28 18:29 - 2020-03-22 18:03 - 000689126 _____ C:\Windows\system32\perfh007.dat
2021-10-28 18:29 - 2020-03-22 18:03 - 000149098 _____ C:\Windows\system32\perfc007.dat
2021-10-28 18:29 - 2014-03-12 20:39 - 000745504 _____ C:\Windows\system32\perfh00A.dat
2021-10-28 18:29 - 2014-03-12 20:39 - 000158582 _____ C:\Windows\system32\perfc00A.dat
2021-10-28 18:29 - 2009-07-14 00:13 - 002514704 _____ C:\Windows\system32\PerfStringBackup.INI
2021-10-28 18:28 - 2018-08-09 13:46 - 000000000 ____D C:\Users\Carlos Luna\Documents\Hermanos
2021-10-25 20:23 - 2018-08-09 13:33 - 000000000 ____D C:\Users\Carlos Luna\Documents\Carlos
2021-10-25 19:58 - 2014-04-11 01:54 - 000000000 ____D C:\Users\Carlos Luna\Documents\My Games
2021-10-24 00:28 - 2009-07-13 22:20 - 000000000 ____D C:\Windows\system32\NDF
2021-10-23 02:22 - 2021-08-02 01:56 - 000000000 ____D C:\Users\Carlos Luna\AppData\Roaming\vlc
2021-10-21 02:15 - 2014-03-12 19:32 - 000000000 ____D C:\Users\Carlos Luna\AppData\Roaming\Adobe
2021-10-21 02:04 - 2021-03-11 21:40 - 000000000 ____D C:\Users\Carlos Luna\AppData\Local\Opera Software
2021-10-21 01:46 - 2015-10-24 19:03 - 000000000 ____D C:\Users\Carlos Luna\Downloads\Series
2021-10-20 23:09 - 2014-04-19 03:42 - 000000000 ____D C:\Program Files (x86)\Adobe
2021-10-20 16:10 - 2009-01-01 01:05 - 000000000 ___RD C:\Program Files (x86)\ASUS
2021-10-19 05:17 - 2009-01-01 00:26 - 000154328 _____ C:\Users\Carlos Luna\AppData\Local\GDIPFONTCACHEV1.DAT
2021-10-19 02:57 - 2009-07-13 23:45 - 005165616 _____ C:\Windows\system32\FNTCACHE.DAT
2021-10-19 02:07 - 2016-06-08 15:04 - 000000000 ____D C:\Program Files (x86)\Minecraft
2021-10-19 02:06 - 2014-04-19 03:17 - 000000000 ____D C:\ProgramData\Adobe
2021-10-19 02:03 - 2015-02-16 14:11 - 000000000 ____D C:\Program Files (x86)\Java
2021-10-18 22:24 - 2019-02-06 20:46 - 000000000 ____D C:\Windows\system32\DAX2
2021-10-18 22:23 - 2021-05-01 02:22 - 000000000 ____D C:\Windows\SysWOW64\RTCOM
2021-10-18 22:05 - 2015-10-24 19:03 - 000000000 ____D C:\Users\Carlos Luna\Downloads\Archives
2021-10-18 22:02 - 2014-03-12 20:50 - 000000000 ____D C:\Windows\system32\Tasks\Games
2021-10-18 14:41 - 2009-07-13 22:20 - 000000000 ____D C:\Windows\rescache
2021-10-14 14:56 - 2016-01-14 23:46 - 000000000 ____D C:\Users\Carlos Luna\AppData\Roaming\Opera Software
2021-10-12 00:06 - 2009-01-01 03:16 - 000000000 ____D C:\Windows\Panther
2021-10-11 02:35 - 2009-07-14 02:45 - 000000000 ___RD C:\Users\Public\Recorded TV
2021-10-11 02:14 - 2009-07-13 22:20 - 000000000 ____D C:\Windows\PolicyDefinitions
2021-10-10 23:03 - 2020-10-21 01:14 - 000000000 ____D C:\Users\Carlos Luna\AppData\Local\miHoYo
2021-10-10 23:03 - 2020-10-21 01:14 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Genshin Impact
2021-10-10 13:31 - 2014-03-12 20:50 - 000018960 _____ (Logitech, Inc.) C:\Windows\system32\Drivers\LNonPnP.sys
2021-10-10 01:13 - 2009-07-14 00:08 - 000032640 _____ C:\Windows\Tasks\SCHEDLGU.TXT
2021-10-08 16:24 - 2014-07-08 15:40 - 000000000 ____D C:\ProgramData\Apple
2021-10-08 03:55 - 2015-01-14 14:34 - 000000000 ____D C:\Users\Carlos Luna\Downloads\Zips
==================== Files in the root of some directories ========
2014-10-07 03:30 - 2016-03-28 23:20 - 000000132 _____ () C:\Users\Carlos Luna\AppData\Roaming\Prefs. de formato OpenEXR de Adobe CS6
2014-08-07 03:52 - 2021-10-30 17:55 - 000000132 _____ () C:\Users\Carlos Luna\AppData\Roaming\Prefs. de formato PNG de Adobe CS6
2016-02-15 18:17 - 2017-09-18 11:15 - 002447075 _____ () C:\Users\Carlos Luna\AppData\Roaming\PS13_panel.log
2020-06-26 00:10 - 2020-06-26 00:10 - 000000045 _____ () C:\Users\Carlos Luna\AppData\Roaming\WB.CFG
2016-08-03 21:50 - 2017-09-17 09:56 - 000001456 _____ () C:\Users\Carlos Luna\AppData\Local\Adobe Guardar para Web 13.0 Prefs
2021-01-10 12:03 - 2021-01-10 12:04 - 000000774 _____ () C:\Users\Carlos Luna\AppData\Local\install_info.txt
2015-08-07 11:17 - 2015-08-07 11:17 - 013545694 _____ () C:\Users\Carlos Luna\AppData\Local\package.nw.new
2018-08-31 01:09 - 2018-12-29 02:20 - 000000600 _____ () C:\Users\Carlos Luna\AppData\Local\PUTTY.RND
2015-04-19 18:58 - 2021-11-03 10:11 - 000007630 _____ () C:\Users\Carlos Luna\AppData\Local\Resmon.ResmonCfg
2019-10-18 02:55 - 2020-07-25 01:51 - 000000077 _____ () C:\Users\Carlos Luna\AppData\Local\update_progress.txt
2019-12-06 23:13 - 2019-12-06 23:13 - 000017408 _____ () C:\Users\Carlos Luna\AppData\Local\WebpageIcons.db
2018-06-21 16:19 - 2018-06-21 16:19 - 000000000 _____ () C:\Users\Carlos Luna\AppData\Local\{A194310A-E09D-4DA5-9E3E-1171E9EEAB3E}
==================== SigCheck ============================
==================== End of FRST.txt ========================
I noticing that a emoticon ( :p ) is appearing in the addition log, there is a way to stop the use of emotes in a reply?
Addition.txt
Additional scan result of Farbar Recovery Scan Tool (x64) Version: 02-11-2021
Ran by Carlos Luna (03-11-2021 20:14:23)
Microsoft Windows 7 Ultimate Service Pack 1 (X64) (2009-01-01 05:23:52)
Boot Mode: Normal
Administrator (S-1-5-21-2305226654-651215044-733858041-500 - Administrator - Disabled)
Carlos Luna (S-1-5-21-2305226654-651215044-733858041-1000 - Administrator - Enabled) => C:\Users\Carlos Luna
Guest (S-1-5-21-2305226654-651215044-733858041-501 - Limited - Enabled)
HomeGroupUser$ (S-1-5-21-2305226654-651215044-733858041-1005 - Limited - Enabled)
AS: Windows Defender (Enabled - Up to date) {D68DDC3A-831F-4fae-9E44-DA132C1ACF46}
7-Zip 19.00 (x64 edition) (HKLM\...\{23170F69-40C1-2702-1900-000001000000}) (Version: 19.00.00.0 - Igor Pavlov)
Action! (HKLM-x32\...\Mirillis Action!) (Version: 3.9.6 - Mirillis)
Autodesk Maya 2015 SP2 (HKLM\...\Autodesk Maya 2015 SP2) (Version: 15.2.1633.0 - Autodesk)
Autodesk Maya 2016 SP1 (HKLM\...\Autodesk Maya 2016 SP1) (Version: 16.6.2775.0 - Autodesk) Hidden
Autodesk Maya 2016 SP2 (HKLM\...\Autodesk Maya 2016 SP2) (Version: 16.6.2775.0 - Autodesk) Hidden
Autodesk Maya 2016 SP3 (HKLM\...\Autodesk Maya 2016 SP3) (Version: 16.6.2775.0 - Autodesk) Hidden
Autodesk Maya 2016 SP3P02 (HKLM\...\Autodesk Maya 2016 SP3P02) (Version: 16.6.2775.0 - Autodesk) Hidden
Autodesk Maya 2016 SP4 (HKLM\...\Autodesk Maya 2016 SP4) (Version: 16.6.2775.0 - Autodesk) Hidden
Autodesk Maya 2016 SP4P04 (HKLM\...\Autodesk Maya 2016 SP4P04) (Version: 16.6.2775.0 - Autodesk) Hidden
Autodesk Maya 2016 SP4P05 (HKLM\...\Autodesk Maya 2016 SP4P05) (Version: 16.6.2775.0 - Autodesk) Hidden
Autodesk Maya 2016 SP5 (HKLM\...\Autodesk Maya 2016 SP5) (Version: 16.6.2775.0 - Autodesk) Hidden
Autodesk Maya 2016 SP5P06 (HKLM\...\Autodesk Maya 2016 SP5P06) (Version: 16.6.2775.0 - Autodesk) Hidden
Autodesk Maya 2016 SP5P07 (HKLM\...\Autodesk Maya 2016 SP5P07) (Version: 16.6.2775.0 - Autodesk) Hidden
Autodesk Maya 2016 SP5P08 (HKLM\...\Autodesk Maya 2016 SP5P08) (Version: 16.6.2775.0 - Autodesk) Hidden
Autodesk Maya 2016 SP6 (HKLM\...\Autodesk Maya 2016 SP6) (Version: 16.6.2775.0 - Autodesk)
BlueStacks 5 (HKLM\...\BlueStacks_nxt) (Version: 5.3.70.1004 - BlueStack Systems, Inc.)
CCleaner (HKLM\...\CCleaner) (Version: 4.15 - Piriform)
Corel Update Manager (HKLM\...\{9E1EE683-0C7B-46E7-83EC-1F5A1D8F2296}) (Version: 2.9.389 - Corel corporation) Hidden
CorelDRAW Graphics Suite 2017 - IPM (x64) (HKLM\...\{904B10A6-0D9C-4645-9C61-504FA92B9220}) (Version: 19.1 - Corel Corporation) Hidden
CorelDRAW Graphics Suite 2017 - IPM Content (x64) (HKLM\...\{54F024CB-16AF-4CC0-9BC2-D2507E7C6C01}) (Version: 19.0 - Corel Corporation) Hidden
CorelDRAW Graphics Suite 2017 - Writing Tools (x64) (HKLM\...\{E38357D4-1B80-400F-A6D7-B4D5DD83D979}) (Version: 19.1 - Corel Corporation) Hidden
CrystalDiskInfo 7.6.1 (HKLM-x32\...\CrystalDiskInfo_is1) (Version: 7.6.1 - Crystal Dew World)
Discord (HKU\S-1-5-21-2305226654-651215044-733858041-1000\...\Discord) (Version: 0.0.309 - Discord Inc.)
Epic Games Launcher (HKLM-x32\...\{8CAF0391-512D-485C-B141-39D89E7EDCA8}) (Version: 1.2.17.0 - Epic Games, Inc.)
Epic Games Launcher Prerequisites (x64) (HKLM\...\{F9C5C994-F6B9-4D75-B3E7-AD01B84073E9}) (Version: 1.0.0.0 - Epic Games, Inc.) Hidden
Epic Online Services (HKLM-x32\...\{32C68D93-D32F-4B01-8250-61642BFC22F8}) (Version: 2.0.28.0 - Epic Games, Inc.)
Genshin Impact (HKLM\...\Genshin Impact) (Version: 2.12.1.0 - miHoYo Co.,Ltd)
Intel(R) C++ Redistributables for Windows* on Intel(R) 64 (HKLM-x32\...\{D2437C5C-2D8C-40D2-8059-689AD7239FA3}) (Version: 11.1.048 - Intel Corporation)
Intel(R) Management Engine Components (HKLM-x32\...\{65153EA5-8B6E-43B6-857B-C6E4FC25798A}) (Version: 9.5.15.1730 - Intel Corporation)
Intel(R) USB 3.0 eXtensible Host Controller Driver (HKLM-x32\...\{240C3DDD-C5E9-4029-9DF7-95650D040CF2}) (Version: 2.5.0.19 - Intel Corporation)
Intel® Hardware Accelerated Execution Manager (HKLM\...\{557D160E-2085-4D38-BDA3-1D5D3F74A3A4}) (Version: 6.0.4 - Intel Corporation)
Launcher Prerequisites (x64) (HKLM-x32\...\{43a03b9c-4770-409c-a999-587b60700b63}) (Version: 1.0.0.0 - Epic Games, Inc.) Hidden
Launcher Prerequisites (x64) (HKLM-x32\...\{c6c5a357-c7ca-4a5f-9789-3bb1af579253}) (Version: 1.0.0.0 - Epic Games, Inc.) Hidden
MCShield ::Anti-Malware Tool:: (HKLM-x32\...\MCShield) (Version: 3.0.5.28 - MyCity)
Microsoft .NET Framework 4.8 (Deutsch) (HKLM\...\{92FB6C44-E685-45AD-9B20-CADF4CABA132} - 1031) (Version: 4.8.03761 - Microsoft Corporation)
Microsoft .NET Framework 4.8 (español) (HKLM\...\{92FB6C44-E685-45AD-9B20-CADF4CABA132} - 3082) (Version: 4.8.03761 - Microsoft Corporation)
Microsoft .NET Framework 4.8 (HKLM\...\{92FB6C44-E685-45AD-9B20-CADF4CABA132} - 1033) (Version: 4.8.03761 - Microsoft Corporation)
Microsoft Mouse and Keyboard Center (HKLM\...\Microsoft Mouse and Keyboard Center) (Version: 2.8.106.0 - Microsoft Corporation)
Microsoft Office 2010 Service Pack 1 (SP1) (HKLM-x32\...\{90140000-0011-0000-0000-0000000FF1CE}_Office14.PROPLUS_{047B0968-E622-4FAA-9B4B-121FA109EDDE}) (Version: - Microsoft)
Microsoft Office Professional Plus 2010 (HKLM-x32\...\Office14.PROPLUS) (Version: 14.0.6029.1000 - Microsoft Corporation)
Microsoft Research Mesh Virtual WIFI (HKLM-x32\...\{034A32D5-699E-4AED-A2EB-2CCB6E7F37F1}) (Version: 1.0.000 - Microsoft Research)
Microsoft Visual C++ 2005 Redistributable (HKLM-x32\...\{710f4c1c-cc18-4c49-8cbf-51240c89a1a2}) (Version: 8.0.61001 - Microsoft Corporation)
Microsoft Visual C++ 2005 Redistributable (HKLM-x32\...\{7299052b-02a4-4627-81f2-1818da5d550d}) (Version: 8.0.56336 - Microsoft Corporation)
Microsoft Visual C++ 2005 Redistributable (HKLM-x32\...\{837b34e3-7c30-493c-8f6a-2b0f04e2912c}) (Version: 8.0.59193 - Microsoft Corporation)
Microsoft Visual C++ 2005 Redistributable (x64) (HKLM\...\{6ce5bae9-d3ca-4b99-891a-1dc6c118a5fc}) (Version: 8.0.59192 - Microsoft Corporation)
Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.17 (HKLM\...\{8220EEFE-38CD-377E-8595-13398D740ACE}) (Version: 9.0.30729 - Microsoft Corporation)
Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.4148 (HKLM\...\{4B6C7001-C7D6-3710-913E-5BC23FCE91E6}) (Version: 9.0.30729.4148 - Microsoft Corporation)
Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.6161 (HKLM\...\{5FCE6D76-F5DC-37AB-B2B8-22AB8CEDB1D4}) (Version: 9.0.30729.6161 - Microsoft Corporation)
Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.4148 (HKLM-x32\...\{1F1C2DFC-2D24-3E06-BCB8-725134ADF989}) (Version: 9.0.30729.4148 - Microsoft Corporation)
Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.6161 (HKLM-x32\...\{9BE518E6-ECC6-35A9-88E4-87755C07200F}) (Version: 9.0.30729.6161 - Microsoft Corporation)
Microsoft Visual C++ 2012 Redistributable (x64) - 11.0.61030 (HKLM-x32\...\{ca67548a-5ebe-413a-b50c-4b9ceb6d66c6}) (Version: 11.0.61030.0 - Microsoft Corporation)
Microsoft Visual C++ 2013 Redistributable (x64) - 12.0.30501 (HKLM-x32\...\{050d4fc8-5d48-4b8f-8972-47c82c46020f}) (Version: 12.0.30501.0 - Microsoft Corporation)
Microsoft Visual C++ 2013 Redistributable (x64) - 12.0.30501 (HKLM-x32\...\{1b103cea-f037-4504-81de-956057b442c3}) (Version: 12.0.30501.0 - Microsoft Corporation)
Microsoft Visual C++ 2013 Redistributable (x86) - 12.0.30501 (HKLM-x32\...\{f65db027-aff3-4070-886a-0d87064aabb1}) (Version: 12.0.30501.0 - Microsoft Corporation)
Microsoft Visual C++ 2015-2019 Redistributable (x64) - 14.28.29334 (HKLM-x32\...\{a9cfe9c7-e54f-46cd-9c5c-542ff8e3e8c4}) (Version: 14.28.29334.0 - Microsoft Corporation)
Microsoft Visual C++ 2015-2019 Redistributable (x86) - 14.28.29334 (HKLM-x32\...\{b2d0f752-adc5-496e-8f70-8669de01f746}) (Version: 14.28.29334.0 - Microsoft Corporation)
Microsoft Visual Studio Tools for Applications 2012 (HKLM-x32\...\{89ca2a32-2b52-4595-8dfd-6fe4757958d0}) (Version: 11.0.51108 - Microsoft Corporation)
Microsoft Visual Studio Tools for Applications 2015 (HKLM-x32\...\{dd8b09df-3ef8-49f1-bd1a-65278435860b}) (Version: 14.0.23217 - Microsoft Corporation)
Minecraft Launcher (HKLM-x32\...\{810F1419-7760-402E-8772-B4054FAA2B72}) (Version: 1.0.0.0 - Mojang)
MSI Afterburner 4.6.2 (HKLM-x32\...\Afterburner) (Version: 4.6.2 - MSI Co., LTD)
NVIDIA Graphics Driver 451.67 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.Driver) (Version: 451.67 - NVIDIA Corporation)
NVIDIA HD Audio Driver 1.3.38.34 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_HDAudio.Driver) (Version: 1.3.38.34 - NVIDIA Corporation)
NVIDIA PhysX System Software 9.19.0218 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.PhysX) (Version: 9.19.0218 - NVIDIA Corporation)
Opera GX Stable 80.0.4170.61 (HKU\S-1-5-21-2305226654-651215044-733858041-1000\...\Opera GX 80.0.4170.61) (Version: 80.0.4170.61 - Opera Software)
Pacote de Idiomas do Microsoft Visual Studio Tools for Applications 2012 x64 Hosting Support - PTB (HKLM\...\{E237254B-36A1-3D27-815E-B37C13BE0796}) (Version: 11.0.51108 - Microsoft Corporation) Hidden
Pacote de Idiomas do Microsoft Visual Studio Tools for Applications 2012 x86 Hosting Support - PTB (HKLM-x32\...\{03077B58-6ACF-32CA-B42A-EAA458C295A1}) (Version: 11.0.51108 - Microsoft Corporation) Hidden
Project64 version 3.0.1.5664 (HKLM-x32\...\{BEB5FB69-4080-466F-96C4-F15DF271718B}_is1) (Version: 3.0.1.5664 - )
Realtek Ethernet Controller Driver (HKLM-x32\...\{8833FFB6-5B0C-4764-81AA-06DFEED9A476}) (Version: 7.67.1226.2012 - Realtek)
Realtek Ethernet Diagnostic Utility (HKLM-x32\...\{DADC7AB0-E554-4705-9F6A-83EA82ED708E}) (Version: 2.0.2.7 - Realtek)
Realtek High Definition Audio Driver (HKLM-x32\...\{F132AF7F-7BCA-4EDE-8A7C-958108FE7DBC}) (Version: 6.0.1.7982 - Realtek Semiconductor Corp.)
UE4 Prerequisites (x86) (HKLM-x32\...\{6EAAE1C0-6000-45FA-B46D-D206144925BF}) (Version: 1.0.11.0 - Epic Games, Inc.) Hidden
UE4 Prerequisites (x86) (HKLM-x32\...\{f1203e43-4ddb-4280-974e-73f14d793dbd}) (Version: 1.0.13.0 - Epic Games, Inc.) Hidden
WO Mic Client (HKLM-x32\...\WOMic) (Version: - )
Языковой пакет для поддержки размещения набора средств Microsoft Visual Studio Tools для работы с приложениями 2012 (x64) - RUS (HKLM\...\{25FB53C5-BE4C-3B6C-A0C9-D49A39227E1E}) (Version: 11.0.51108 - Microsoft Corporation) Hidden
Языковой пакет для поддержки размещения набора средств Microsoft Visual Studio Tools для работы с приложениями 2012 (x86) - RUS (HKLM-x32\...\{68DC347D-C1C0-3DE2-A53E-CCC71DA53E57}) (Version: 11.0.51108 - Microsoft Corporation) Hidden
==================== Custom CLSID (Whitelisted): ==============
CustomCLSID: HKU\S-1-5-21-2305226654-651215044-733858041-1000_Classes\CLSID\{00020420-0000-0000-C000-000000000046}\InprocServer32 -> C:\Windows\system32\oleaut32.dll (Microsoft Windows -> Microsoft Corporation)
CustomCLSID: HKU\S-1-5-21-2305226654-651215044-733858041-1000_Classes\CLSID\{00020421-0000-0000-C000-000000000046}\InprocServer32 -> C:\Windows\system32\oleaut32.dll (Microsoft Windows -> Microsoft Corporation)
CustomCLSID: HKU\S-1-5-21-2305226654-651215044-733858041-1000_Classes\CLSID\{00020422-0000-0000-C000-000000000046}\InprocServer32 -> C:\Windows\system32\oleaut32.dll (Microsoft Windows -> Microsoft Corporation)
CustomCLSID: HKU\S-1-5-21-2305226654-651215044-733858041-1000_Classes\CLSID\{00020423-0000-0000-C000-000000000046}\InprocServer32 -> C:\Windows\system32\oleaut32.dll (Microsoft Windows -> Microsoft Corporation)
CustomCLSID: HKU\S-1-5-21-2305226654-651215044-733858041-1000_Classes\CLSID\{00020424-0000-0000-C000-000000000046}\InprocServer32 -> C:\Windows\system32\oleaut32.dll (Microsoft Windows -> Microsoft Corporation)
CustomCLSID: HKU\S-1-5-21-2305226654-651215044-733858041-1000_Classes\CLSID\{00020425-0000-0000-C000-000000000046}\InprocServer32 -> C:\Windows\system32\oleaut32.dll (Microsoft Windows -> Microsoft Corporation)
ShellExecuteHooks: Groove GFS Stub Execution Hook - {B5A7F190-DDA6-4420-B3BA-52453494E6CD} - C:\Program Files\Microsoft Office\Office14\GROOVEEX.DLL [6718864 2011-02-12] (Microsoft Corporation -> Microsoft Corporation)
ShellExecuteHooks-x32: Groove GFS Stub Execution Hook - {B5A7F190-DDA6-4420-B3BA-52453494E6CD} - C:\Program Files (x86)\Microsoft Office\Office14\GROOVEEX.DLL [4220304 2011-02-12] (Microsoft Corporation -> Microsoft Corporation)
ShellIconOverlayIdentifiers: [ MEGA (Pending)] -> {056D528D-CE28-4194-9BA3-BA2E9197FF8C} => -> No File
ShellIconOverlayIdentifiers: [ MEGA (Synced)] -> {05B38830-F4E9-4329-978B-1DD28605D202} => -> No File
ShellIconOverlayIdentifiers: [ MEGA (Syncing)] -> {0596C850-7BDD-4C9D-AFDF-873BE6890637} => -> No File
ShellIconOverlayIdentifiers-x32: [ MEGA (Pending)] -> {056D528D-CE28-4194-9BA3-BA2E9197FF8C} => -> No File
ShellIconOverlayIdentifiers-x32: [ MEGA (Synced)] -> {05B38830-F4E9-4329-978B-1DD28605D202} => -> No File
ShellIconOverlayIdentifiers-x32: [ MEGA (Syncing)] -> {0596C850-7BDD-4C9D-AFDF-873BE6890637} => -> No File
ContextMenuHandlers1: [7-Zip] -> {23170F69-40C1-278A-1000-000100020000} => C:\Program Files\7-Zip\7-zip.dll [2019-02-21] (Igor Pavlov) [File not signed]
ContextMenuHandlers1: [MEGA (Context menu)] -> {0229E5E7-09E9-45CF-9228-0228EC7D5F17} => -> No File
ContextMenuHandlers1-x32: [WinRAR] -> {B41DB860-8EE4-11D2-9906-E49FADC173CA} => C:\Program Files (x86)\WinRAR\rarext.dll [2004-12-26] () [File not signed]
ContextMenuHandlers2: [MEGA (Context menu)] -> {0229E5E7-09E9-45CF-9228-0228EC7D5F17} => -> No File
ContextMenuHandlers3: [MEGA (Context menu)] -> {0229E5E7-09E9-45CF-9228-0228EC7D5F17} => -> No File
ContextMenuHandlers4: [7-Zip] -> {23170F69-40C1-278A-1000-000100020000} => C:\Program Files\7-Zip\7-zip.dll [2019-02-21] (Igor Pavlov) [File not signed]
ContextMenuHandlers4: [AutopanoShell.ShellContextMenu] -> {4B4F4C4F-5220-4798-ABF3-EC03F7C8A498} => -> No File
ContextMenuHandlers4: [MEGA (Context menu)] -> {0229E5E7-09E9-45CF-9228-0228EC7D5F17} => -> No File
ContextMenuHandlers4-x32: [WinRAR] -> {B41DB860-8EE4-11D2-9906-E49FADC173CA} => C:\Program Files (x86)\WinRAR\rarext.dll [2004-12-26] () [File not signed]
ContextMenuHandlers5: [NvCplDesktopContext] -> {3D1975AF-48C6-4f8e-A182-BE0E08FA86A9} => C:\Windows\system32\nvshext.dll [2020-07-05] (NVIDIA Corporation -> NVIDIA Corporation)
ContextMenuHandlers6: [7-Zip] -> {23170F69-40C1-278A-1000-000100020000} => C:\Program Files\7-Zip\7-zip.dll [2019-02-21] (Igor Pavlov) [File not signed]
ContextMenuHandlers6-x32: [WinRAR] -> {B41DB860-8EE4-11D2-9906-E49FADC173CA} => C:\Program Files (x86)\WinRAR\rarext.dll [2004-12-26] () [File not signed]
==================== Codecs (Whitelisted) ====================
HKLM\...\Drivers32: [VIDC.FICV] => C:\Windows\system32\ficvdec_x64.dll [652288 2013-05-28] () [File not signed]
HKLM\...\Drivers32: [VIDC.FICV] => C:\Windows\SysWOW64\ficvdec_x86.dll [641024 2013-05-28] () [File not signed]
==================== Shortcuts & WMI ========================
==================== Loaded Modules (Whitelisted) =============
2009-01-01 01:06 - 2021-11-03 20:04 - 000034448 _____ (ASUSTeK Computer Inc. -> ) [File not signed] C:\Program Files (x86)\ASUS\AXSP\1.01.01\PEbiosinterface32.dll
2019-02-21 21:00 - 2019-02-21 21:00 - 000078336 _____ (Igor Pavlov) [File not signed] C:\Program Files\7-Zip\7-zip.dll
2014-02-27 17:43 - 2014-02-27 17:43 - 000173568 _____ (Nokia Corporation and/or its subsidiary(-ies)) [File not signed] C:\Program Files\Logitech Gaming Software\imageformats\qjpeg4.dll
2014-02-27 17:43 - 2014-02-27 17:43 - 001807360 _____ (Nokia Corporation and/or its subsidiary(-ies)) [File not signed] C:\Program Files\Logitech Gaming Software\QtCLucene4.dll
2014-02-27 17:43 - 2014-02-27 17:43 - 003276288 _____ (Nokia Corporation and/or its subsidiary(-ies)) [File not signed] C:\Program Files\Logitech Gaming Software\QtCore4.dll
2014-02-27 17:43 - 2014-02-27 17:43 - 012168192 _____ (Nokia Corporation and/or its subsidiary(-ies)) [File not signed] C:\Program Files\Logitech Gaming Software\QtGui4.dll
2014-02-27 17:43 - 2014-02-27 17:43 - 000750080 _____ (Nokia Corporation and/or its subsidiary(-ies)) [File not signed] C:\Program Files\Logitech Gaming Software\QtHelp4.dll
2014-02-27 17:43 - 2014-02-27 17:43 - 001085952 _____ (Nokia Corporation and/or its subsidiary(-ies)) [File not signed] C:\Program Files\Logitech Gaming Software\QtNetwork4.dll
2014-02-27 17:43 - 2014-02-27 17:43 - 000841728 _____ (Nokia Corporation and/or its subsidiary(-ies)) [File not signed] C:\Program Files\Logitech Gaming Software\QtOpenGL4.dll
2014-02-27 17:43 - 2014-02-27 17:43 - 001990144 _____ (Nokia Corporation and/or its subsidiary(-ies)) [File not signed] C:\Program Files\Logitech Gaming Software\QtScript4.dll
2014-02-27 17:43 - 2014-02-27 17:43 - 000897024 _____ (Nokia Corporation and/or its subsidiary(-ies)) [File not signed] C:\Program Files\Logitech Gaming Software\QtSql4.dll
2014-02-27 17:43 - 2014-02-27 17:43 - 000539136 _____ (Nokia Corporation and/or its subsidiary(-ies)) [File not signed] C:\Program Files\Logitech Gaming Software\QtXml4.dll
==================== Alternate Data Streams (Whitelisted) ========
(If an entry is included in the fixlist, only the ADS will be removed.)
AlternateDataStreams: C:\Users\Carlos Luna\Cookies:9uiptag9KhjXpJROea9BnnRVF [1826]
==================== Safe Mode (Whitelisted) ==================
(If an entry is included in the fixlist, it will be removed from the registry. The "AlternateShell" will be restored.)
HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\amsdk.sys => ""="Driver"
HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\dump_3D569C04.sys => ""="Driver"
HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\Ms3D569C04App => ""="Service"
HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\amsdk.sys => ""="Driver"
HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\dump_3D569C04.sys => ""="Driver"
HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\Ms3D569C04App => ""="Service"
==================== Association (Whitelisted) =================
==================== Internet Explorer (Version 11) (Whitelisted) ==========
HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = [URL='http://www.google.com']www.google.com[/URL]
HKLM\Software\Microsoft\Internet Explorer\Main,Search Page =
HKLM\Software\Wow6432Node\Microsoft\Internet Explorer\Main,Search Page =
HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL =
HKLM\Software\Wow6432Node\Microsoft\Internet Explorer\Main,Default_Page_URL =
HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL =
HKLM\Software\Wow6432Node\Microsoft\Internet Explorer\Main,Default_Search_URL =
HKLM\Software\Microsoft\Internet Explorer\Main,Local Page =
HKU\S-1-5-21-2305226654-651215044-733858041-1000\Software\Microsoft\Internet Explorer\Main,Start Page Redirect Cache = hxxp://latam.msn.com/?ocid=iehp
SearchScopes: HKLM -> DefaultScope {0633EE93-D776-472f-A0FF-E1416B8B2E3A} URL =
SearchScopes: HKLM -> {0633EE93-D776-472f-A0FF-E1416B8B2E3A} URL =
SearchScopes: HKLM-x32 -> DefaultScope {632F07F3-19A1-4d16-A23F-E6CE9486BAB5} URL =
SearchScopes: HKLM-x32 -> {0633EE93-D776-472f-A0FF-E1416B8B2E3A} URL =
BHO: Groove GFS Browser Helper -> {72853161-30C5-4D22-B7F9-0BBC1D38A37E} -> C:\Program Files\Microsoft Office\Office14\GROOVEEX.DLL [2011-02-12] (Microsoft Corporation -> Microsoft Corporation)
BHO: Office Document Cache Handler -> {B4F3A835-0E21-4959-BA22-42B3008E02FF} -> C:\Program Files\Microsoft Office\Office14\URLREDIR.DLL [2010-12-21] (Microsoft Corporation -> Microsoft Corporation)
BHO-x32: Office Document Cache Handler -> {B4F3A835-0E21-4959-BA22-42B3008E02FF} -> C:\Program Files (x86)\Microsoft Office\Office14\URLREDIR.DLL [2010-12-21] (Microsoft Corporation -> Microsoft Corporation)
Toolbar: HKLM - No Name - {CC1A175A-E45B-41ED-A30C-C9B1D7A0C02F} - No File
Toolbar: HKU\S-1-5-21-2305226654-651215044-733858041-1000 -> No Name - {47833539-D0C5-4125-9FA8-0819E2EAAC93} - No File
(If an entry is included in the fixlist, it will be removed from the registry.)
IE restricted site: HKU\.DEFAULT\...\007guard.com -> install.007guard.com
IE restricted site: HKU\.DEFAULT\...\008i.com -> 008i.com
IE restricted site: HKU\.DEFAULT\...\008k.com -> [URL='http://www.008k.com']www.008k.com[/URL]
IE restricted site: HKU\.DEFAULT\...\00hq.com -> [URL='http://www.00hq.com']www.00hq.com[/URL]
IE restricted site: HKU\.DEFAULT\...\010402.com -> 010402.com
IE restricted site: HKU\.DEFAULT\...\032439.com -> 80gw6ry3i3x3qbrkwhxhw.032439.com
IE restricted site: HKU\.DEFAULT\...\0scan.com -> [URL='http://www.0scan.com']www.0scan.com[/URL]
IE restricted site: HKU\.DEFAULT\...\1-2005-search.com -> [URL='http://www.1-2005-search.com']www.1-2005-search.com[/URL]
IE restricted site: HKU\.DEFAULT\...\1-domains-registrations.com -> [URL='http://www.1-domains-registrations.com']www.1-domains-registrations.com[/URL]
IE restricted site: HKU\.DEFAULT\...\1000gratisproben.com -> [URL='http://www.1000gratisproben.com']www.1000gratisproben.com[/URL]
IE restricted site: HKU\.DEFAULT\...\1001namen.com -> [URL='http://www.1001namen.com']www.1001namen.com[/URL]
IE restricted site: HKU\.DEFAULT\...\100888290cs.com -> mir.100888290cs.com
IE restricted site: HKU\.DEFAULT\...\100sexlinks.com -> [URL='http://www.100sexlinks.com']www.100sexlinks.com[/URL]
IE restricted site: HKU\.DEFAULT\...\10sek.com -> [URL='http://www.10sek.com']www.10sek.com[/URL]
IE restricted site: HKU\.DEFAULT\...\12-26.net -> user1.12-26.net
IE restricted site: HKU\.DEFAULT\...\12-27.net -> user1.12-27.net
IE restricted site: HKU\.DEFAULT\...\123fporn.info -> [URL='http://www.123fporn.info']www.123fporn.info[/URL]
IE restricted site: HKU\.DEFAULT\...\123haustiereundmehr.com -> [URL='http://www.123haustiereundmehr.com']www.123haustiereundmehr.com[/URL]
IE restricted site: HKU\.DEFAULT\...\123moviedownload.com -> [URL='http://www.123moviedownload.com']www.123moviedownload.com[/URL]
IE restricted site: HKU\.DEFAULT\...\123simsen.com -> [URL='http://www.123simsen.com']www.123simsen.com[/URL]
There are 7945 more sites.
IE restricted site: HKU\S-1-5-21-2305226654-651215044-733858041-1000\...\007guard.com -> install.007guard.com
IE restricted site: HKU\S-1-5-21-2305226654-651215044-733858041-1000\...\008i.com -> 008i.com
IE restricted site: HKU\S-1-5-21-2305226654-651215044-733858041-1000\...\008k.com -> [URL='http://www.008k.com']www.008k.com[/URL]
IE restricted site: HKU\S-1-5-21-2305226654-651215044-733858041-1000\...\00hq.com -> [URL='http://www.00hq.com']www.00hq.com[/URL]
IE restricted site: HKU\S-1-5-21-2305226654-651215044-733858041-1000\...\010402.com -> 010402.com
IE restricted site: HKU\S-1-5-21-2305226654-651215044-733858041-1000\...\032439.com -> 80gw6ry3i3x3qbrkwhxhw.032439.com
IE restricted site: HKU\S-1-5-21-2305226654-651215044-733858041-1000\...\0scan.com -> [URL='http://www.0scan.com']www.0scan.com[/URL]
IE restricted site: HKU\S-1-5-21-2305226654-651215044-733858041-1000\...\1-2005-search.com -> [URL='http://www.1-2005-search.com']www.1-2005-search.com[/URL]
IE restricted site: HKU\S-1-5-21-2305226654-651215044-733858041-1000\...\1-domains-registrations.com -> [URL='http://www.1-domains-registrations.com']www.1-domains-registrations.com[/URL]
IE restricted site: HKU\S-1-5-21-2305226654-651215044-733858041-1000\...\1000gratisproben.com -> [URL='http://www.1000gratisproben.com']www.1000gratisproben.com[/URL]
IE restricted site: HKU\S-1-5-21-2305226654-651215044-733858041-1000\...\1001namen.com -> [URL='http://www.1001namen.com']www.1001namen.com[/URL]
IE restricted site: HKU\S-1-5-21-2305226654-651215044-733858041-1000\...\100888290cs.com -> mir.100888290cs.com
IE restricted site: HKU\S-1-5-21-2305226654-651215044-733858041-1000\...\100sexlinks.com -> [URL='http://www.100sexlinks.com']www.100sexlinks.com[/URL]
IE restricted site: HKU\S-1-5-21-2305226654-651215044-733858041-1000\...\10sek.com -> [URL='http://www.10sek.com']www.10sek.com[/URL]
IE restricted site: HKU\S-1-5-21-2305226654-651215044-733858041-1000\...\12-26.net -> user1.12-26.net
IE restricted site: HKU\S-1-5-21-2305226654-651215044-733858041-1000\...\12-27.net -> user1.12-27.net
IE restricted site: HKU\S-1-5-21-2305226654-651215044-733858041-1000\...\123fporn.info -> [URL='http://www.123fporn.info']www.123fporn.info[/URL]
IE restricted site: HKU\S-1-5-21-2305226654-651215044-733858041-1000\...\123haustiereundmehr.com -> [URL='http://www.123haustiereundmehr.com']www.123haustiereundmehr.com[/URL]
IE restricted site: HKU\S-1-5-21-2305226654-651215044-733858041-1000\...\123moviedownload.com -> [URL='http://www.123moviedownload.com']www.123moviedownload.com[/URL]
IE restricted site: HKU\S-1-5-21-2305226654-651215044-733858041-1000\...\123simsen.com -> [URL='http://www.123simsen.com']www.123simsen.com[/URL]
==================== Hosts content: =========================
2021-10-18 22:12 - 2021-10-18 22:12 - 000000833 ____R C:\Windows\system32\drivers\etc\hosts
==================== Other Areas ===========================
HKLM\System\CurrentControlSet\Control\Session Manager\Environment\\Path -> C:\Program Files (x86)\Intel\iCLS Client\;C:\Program Files\Intel\iCLS Client\;C:\Program Files (x86)\Common Files\Intel\Shared Files\cpp\bin\Intel64;C:\ProgramData\Oracle\Java\javapath;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\Autodesk\Backburner\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR;C:\Program Files\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT
HKU\S-1-5-21-2305226654-651215044-733858041-1000\Control Panel\Desktop\\Wallpaper -> C:\Users\Carlos Luna\AppData\Roaming\Microsoft\Windows\Themes\TranscodedWallpaper.jpg
DNS Servers: 200.48.225.146 - 200.48.225.130
Windows Firewall is enabled.
MSCONFIG\Services: ACTION_SVC => 3
MSCONFIG\Services: AdAppMgrSvc => 2
MSCONFIG\Services: Foundry License Server => 2
MSCONFIG\Services: GfExperienceService => 2
MSCONFIG\Services: gupdate => 2
MSCONFIG\Services: gupdatem => 3
MSCONFIG\Services: McComponentHostService => 3
MSCONFIG\Services: MozillaMaintenance => 3
MSCONFIG\Services: NvNetworkService => 2
MSCONFIG\Services: NvStreamNetworkSvc => 3
MSCONFIG\Services: NvStreamSvc => 2
MSCONFIG\Services: nvsvc => 2
MSCONFIG\Services: RLM => 2
MSCONFIG\Services: Rockstar Service => 3
MSCONFIG\Services: SkypeUpdate => 2
MSCONFIG\Services: Stereo Service => 2
MSCONFIG\Services: vgc => 3
MSCONFIG\Services: WTabletServiceCon => 2
==================== FirewallRules (Whitelisted) ================
FirewallRules: [{26BF10EE-1D79-4107-B72C-C9B0B6530348}] => (Allow) C:\Users\Carlos Luna\AppData\Local\Programs\Opera GX\80.0.4170.48\opera.exe (Opera Software AS -> Opera Software)
FirewallRules: [TCP Query User{5CB41C60-5184-4DE4-97E7-47A8CE3C61C2}C:\program files (x86)\womic\womicclient.exe] => (Allow) C:\program files (x86)\womic\womicclient.exe () [File not signed]
FirewallRules: [UDP Query User{C4B58CE0-9B62-4529-B69B-189EF82CB167}C:\program files (x86)\womic\womicclient.exe] => (Allow) C:\program files (x86)\womic\womicclient.exe () [File not signed]
FirewallRules: [TCP Query User{53066240-262C-4D89-AD40-374FC9C37118}C:\users\carlos luna\appdata\local\programs\opera gx\opera.exe] => (Allow) C:\users\carlos luna\appdata\local\programs\opera gx\opera.exe (Opera Software AS -> Opera Software)
FirewallRules: [UDP Query User{4FE1146C-6B94-4A3F-B3B9-03B3D4234638}C:\users\carlos luna\appdata\local\programs\opera gx\opera.exe] => (Allow) C:\users\carlos luna\appdata\local\programs\opera gx\opera.exe (Opera Software AS -> Opera Software)
FirewallRules: [TCP Query User{DFCFD19C-91C2-40C7-946E-3EE01B712C2E}C:\program files (x86)\steam\steam.exe] => (Allow) C:\program files (x86)\steam\steam.exe (Valve -> Valve Corporation)
FirewallRules: [UDP Query User{6A80C201-3B27-4588-98EE-E01BBA7533C3}C:\program files (x86)\steam\steam.exe] => (Allow) C:\program files (x86)\steam\steam.exe (Valve -> Valve Corporation)
FirewallRules: [{36077DE1-8476-401E-8EA6-52CBF9065A7D}] => (Allow) C:\Program Files (x86)\Steam\bin\cef\cef.win7x64\steamwebhelper.exe (Valve -> Valve Corporation)
FirewallRules: [{D025ADD2-4276-4691-B046-73FA0D984488}] => (Allow) C:\Program Files (x86)\Steam\bin\cef\cef.win7x64\steamwebhelper.exe (Valve -> Valve Corporation)
FirewallRules: [TCP Query User{586D1D22-7153-4987-97D8-B77472B9AF71}C:\program files\epic games\amongus\among us.exe] => (Allow) C:\program files\epic games\amongus\among us.exe () [File not signed]
FirewallRules: [UDP Query User{CC6FE1C3-7381-4122-8B0F-95493109FF5E}C:\program files\epic games\amongus\among us.exe] => (Allow) C:\program files\epic games\amongus\among us.exe () [File not signed]
FirewallRules: [{3BDD0093-9E93-4FDA-938C-6F8CC931654F}] => (Allow) C:\Users\Carlos Luna\AppData\Local\Programs\Opera GX\80.0.4170.61\opera.exe (Opera Software AS -> Opera Software)
FirewallRules: [TCP Query User{5CBDF2E0-CB20-4AE0-9BA2-CE78F6BDF0AE}C:\program files\genshin impact\genshin impact game\genshinimpact.exe] => (Allow) C:\program files\genshin impact\genshin impact game\genshinimpact.exe (miHoYo Co.,Ltd. -> )
FirewallRules: [UDP Query User{985CB71C-5064-4898-8B6F-1A4B83F251E0}C:\program files\genshin impact\genshin impact game\genshinimpact.exe] => (Allow) C:\program files\genshin impact\genshin impact game\genshinimpact.exe (miHoYo Co.,Ltd. -> )
FirewallRules: [{9BCB1DAC-4A40-44C1-BA83-D5E1CF1DD096}] => (Allow) C:\Program Files (x86)\Steam\SteamApps\common\RISK Global Domination\RISK.exe () [File not signed]
FirewallRules: [{2D9C3240-87F7-414B-A498-1A6238A99B0D}] => (Allow) C:\Program Files (x86)\Steam\SteamApps\common\RISK Global Domination\RISK.exe () [File not signed]
FirewallRules: [TCP Query User{01F7E6D7-6831-4E02-AC98-14FC7C0AC9C8}C:\program files (x86)\steam\steamapps\common\left 4 dead 2\left4dead2.exe] => (Allow) C:\program files (x86)\steam\steamapps\common\left 4 dead 2\left4dead2.exe () [File not signed]
FirewallRules: [UDP Query User{53A32A65-3F71-4320-9C6C-D832023AA22C}C:\program files (x86)\steam\steamapps\common\left 4 dead 2\left4dead2.exe] => (Allow) C:\program files (x86)\steam\steamapps\common\left 4 dead 2\left4dead2.exe () [File not signed]
FirewallRules: [{0E255199-C3C4-4F02-88FD-FC94100871C9}] => (Allow) C:\Program Files (x86)\Steam\SteamApps\common\Action Taimanin\ActionTaimanin.exe () [File not signed]
FirewallRules: [{FD9C28AB-F010-407B-B017-0D6B689E01CC}] => (Allow) C:\Program Files (x86)\Steam\SteamApps\common\Action Taimanin\ActionTaimanin.exe () [File not signed]
FirewallRules: [TCP Query User{33001C23-34A2-484A-B476-E23DFAD5ABE6}C:\program files (x86)\minecraft launcher\runtime\java-runtime-alpha\windows-x64\java-runtime-alpha\bin\javaw.exe] => (Allow) C:\program files (x86)\minecraft launcher\runtime\java-runtime-alpha\windows-x64\java-runtime-alpha\bin\javaw.exe
FirewallRules: [UDP Query User{F4584F73-C6BE-4460-AAA4-1C76B08DEB29}C:\program files (x86)\minecraft launcher\runtime\java-runtime-alpha\windows-x64\java-runtime-alpha\bin\javaw.exe] => (Allow) C:\program files (x86)\minecraft launcher\runtime\java-runtime-alpha\windows-x64\java-runtime-alpha\bin\javaw.exe
02-11-2021 18:51:37 Removed Java 8 Update 311 (64-bit)
==================== Faulty Device Manager Devices ============
Description: BigNox Service
Class Guid: {8ECC055D-047F-11D1-A537-0000F8753ED1}
Manufacturer:
Service: YSDrv
Problem: : This device is not present, is not working properly, or does not have all its drivers installed. (Code 24)
Resolution: The device is installed incorrectly. The problem could be a hardware failure, or a new driver might be needed.
Devices stay in this state if they have been prepared for removal.
After you remove the device, this error disappears.Remove the device, and this error should be resolved.
Name: BlueStacks Hypervisor
Description: BlueStacks Hypervisor
Manufacturer:
Service: BlueStacksDrv
Description: AMSDK Driver
Manufacturer:
Service: amsdk
Name: SM Bus Controller
Description: SM Bus Controller
Class Guid:
Manufacturer:
Service:
Problem: : The drivers for this device are not installed. (Code 28)
Resolution: To install the drivers for this device, click "Update Driver", which starts the Hardware Update wizard.
==================== Event log errors: ========================
Application errors:
Error: (11/03/2021 10:11:44 AM) (Source: Application Error) (EventID: 1000) (User: )
Description: Faulting application name: HD-Player.exe, version: 5.3.70.1004, time stamp: 0x614976f6
Faulting module name: ucrtbase.DLL, version: 10.0.14393.2990, time stamp: 0x5caeb96f
Exception code: 0x40000015
Fault offset: 0x000000000006e01f
Faulting process id: 0x1284
Faulting application start time: 0x01d7d0c4bc230e70
Faulting application path: C:\Program Files\BlueStacks_nxt\HD-Player.exe
Faulting module path: C:\Windows\system32\ucrtbase.DLL
Report Id: 5a8e2fac-3cb8-11ec-b387-d850e63c46b2
Error: (10/31/2021 04:40:59 PM) (Source: Application Error) (EventID: 1000) (User: )
Faulting module name: Qt5Core.dll, version: 5.15.4.0, time stamp: 0x608bce4d
Exception code: 0xc0000005
Fault offset: 0x00000000001d606b
Faulting process id: 0xa60
Faulting application start time: 0x01d7ce8c1125a165
Faulting module path: C:\Program Files\BlueStacks_nxt\Qt5Core.dll
Report Id: 3c2b7ce1-3a93-11ec-83d3-d850e63c46b2
Error: (10/23/2021 09:29:35 PM) (Source: Microsoft-Windows-RestartManager) (EventID: 10006) (User: NT AUTHORITY)
Description: Application or service 'Epic Online Services local application.' could not be shut down.
Error: (10/23/2021 08:11:21 PM) (Source: Application Error) (EventID: 1000) (User: )
Faulting module name: HD-Player.exe, version: 5.3.70.1004, time stamp: 0x614976f6
Fault offset: 0x0000000000031409
Faulting process id: 0x874
Faulting application start time: 0x01d7c86b27659c15
Faulting module path: C:\Program Files\BlueStacks_nxt\HD-Player.exe
Report Id: 4be535b1-3467-11ec-b7f3-d850e63c46b2
Error: (10/19/2021 06:16:02 AM) (Source: Application Error) (EventID: 1000) (User: )
Description: Faulting application name: AntiMalware.exe, version: 3.2.28.0, time stamp: 0x60633416
Faulting module name: KERNELBASE.dll, version: 6.1.7601.24545, time stamp: 0x5e0eb7f5
Exception code: 0xe0434352
Fault offset: 0x0000c5af
Faulting process id: 0x1260
Faulting application start time: 0x01d7c4dab20fd0e2
Faulting application path: C:\Program Files (x86)\Zemana\AntiMalware\AntiMalware.exe
Faulting module path: C:\Windows\syswow64\KERNELBASE.dll
Report Id: f139c231-30cd-11ec-ac98-d850e63c46b2
Error: (10/19/2021 06:16:01 AM) (Source: .NET Runtime) (EventID: 1026) (User: )
Description: Application: AntiMalware.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.IO.FileLoadException
at Zemana.AntiMalware.UI.Program.Main(System.String[])
Error: (10/19/2021 06:01:08 AM) (Source: AntiMalware) (EventID: 0) (User: )
Description: Application has encountered a problem and needs to be closed. Please contact the adminstrator with the following information:
System.ComponentModel.Win32Exception (0x80004005): Error creating window handle.
at System.Windows.Forms.NativeWindow.CreateHandle(CreateParams cp)
at System.Windows.Forms.Control.CreateHandle()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.ControlCollection.Add(Control value)
at Zemana.AntiMalware.UI.Services.ScanPanelController.<>c__DisplayClass12_0.<AddScanFailedPanel>b__0(Panel pnl) in Z:\Projects\Zemana AntiMalware Staging\Zemana.AntiMalware.UI\Services\ScanPanelController.cs:line 73Error creating window handle.
Stack Trace:
Error: (10/19/2021 05:17:10 AM) (Source: MsiInstaller) (EventID: 1013) (User: 1989AH)
Description: Product: SuspendedBypass -- <<29017>>
System errors:
Error: (11/03/2021 08:19:18 PM) (Source: DCOM) (EventID: 10010) (User: )
Description: The server {BB6DF56B-CACE-11DC-9992-0019B93A3A84} did not register with DCOM within the required timeout.
Error: (11/03/2021 08:04:40 PM) (Source: Service Control Manager) (EventID: 7026) (User: )
Description: The following boot-start or system-start driver(s) failed to load:
YSDrv
Error: (11/03/2021 08:04:36 PM) (Source: Service Control Manager) (EventID: 7000) (User: )
Description: The BlueStacks Hypervisor service failed to start due to the following error:
The system cannot find the path specified.
Error: (11/03/2021 08:02:30 PM) (Source: Service Control Manager) (EventID: 7001) (User: )
Description: The PnP-X IP Bus Enumerator service depends on the Function Discovery Provider Host service which failed to start because of the following error:
The dependency service or group failed to start.
Error: (11/03/2021 08:02:25 PM) (Source: Service Control Manager) (EventID: 7030) (User: )
Description: The EsetUninstaller service is marked as an interactive service. However, the system is configured to not allow interactive services. This service may not function properly.
Error: (11/03/2021 08:01:06 PM) (Source: Service Control Manager) (EventID: 7030) (User: )
Error: (11/03/2021 08:00:46 PM) (Source: Service Control Manager) (EventID: 7001) (User: )
Description: The Network List Service service depends on the Network Location Awareness service which failed to start because of the following error:
Windows Defender:
Date: 2016-05-08 05:04:37.251
Description:
Windows Defender scan has been stopped before completion.
Scan Type:AntiSpyware
Scan Parameters:Quick Scan
Date: 2016-02-03 02:42:01.148
Description:
Windows Defender has detected spyware or other potentially unwanted software.
For more information please see the following:
[URL='http://go.microsoft.com/fwlink/?linkid=37020&name=BrowserModifier:Win32/SupTab&threatid=214126']BrowserModifier:Win32/SupTab threat description - Microsoft Security Intelligence[/URL]
Severity:High
Category:Browser Modifier
Path Found:file:C:\Program Files (x86)\TData\DuiLib.dll;file:C:\Program Files (x86)\TData\MCfig.ini;file:C:\Program Files (x86)\TData\msvcp110.dll;file:C:\Program Files (x86)\TData\msvcr110.dll;file:C:\Program Files (x86)\TData\Raydld.exe;file:C:\Program Files (x86)\TData\skin\About.xml;file:C:\Program Files (x86)\TData\skin\about_banner.png;file:C:\Program Files (x86)\TData\skin\animate_history.png;file:C:\Program Files (x86)\TData\skin\animate_portal.png;file:C:\Program Files (x86)\TData\skin\animate_recent.png;file:C:\Program Files (x86)\TData\skin\big_button_down.png;file:C:\Program Files (x86)\TData\skin\bk_shadow.png;file:C:\Program Files (x86)\TData\skin\bottom_toolbar_bk.png;file:C:\Program Files (x86)\TData\skin\brower_back.png;file:C:\Program Files (x86)\TData\skin\brower_refresh.png;file:C:\Program Files (x86)\TData\skin\btn.png;file:C:\Program Files (x86)\TData\skin\btn_browser_dir.png;file:C:\Program Files (x86)\TData\skin\ck_box.png;file:C:\Program Files (x86)\TData\skin\ck_check.png;file:C:\Program Files
Detection Type:Concrete
Detection Source:System
Status:Unknown
Process Name:
Date: 2016-02-03 02:11:35.241
Description:
Severity:High
Status:Unknown
Process Name:C:\Windows\System32\svchost.exe
Date: 2016-02-03 02:10:32.255
Description:
Severity:High
Path Found:file:C:\Program Files (x86)\TData\TData.exe;process:pid:3380,ProcessStart:130989568244561237
Status:Unknown
Date: 2016-02-03 00:26:57.463
Description:
Severity:High
Status:Unknown
Date: 2015-09-16 13:10:27.854
Description:
Windows Defender has encountered an error trying to load signatures and will attempt reverting back to a known-good set of signatures.
Signatures Attempted:Current
Error Code:0x80070002
Error description:The system cannot find the file specified.
Signature version:0.0.0.0
Engine version:0.0.0.0
BIOS: American Megatrends Inc. 2003 10/15/2014
Motherboard: ASUSTeK COMPUTER INC. H87-PLUS
Processor: Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz
Percentage of memory in use: 47%
Total physical RAM: 8130.46 MB
Available physical RAM: 4296.32 MB
Total Virtual: 16259.06 MB
Available Virtual: 10327.92 MB
Drive c: () (Fixed) (Total:931.41 GB) (Free:454.17 GB) NTFS
Drive h: (CarlosLuna) (Fixed) (Total:465.76 GB) (Free:253.9 GB) NTFS
\\?\Volume{6f327824-d7c3-11dd-893f-806e6f6e6963}\ (System Reserved) (Fixed) (Total:0.1 GB) (Free:0.06 GB) NTFS
==================== MBR & Partition Table ====================
Disk: 0 (MBR Code: Windows 7/8/10) (Size: 931.5 GB) (Disk ID: 319F4949)
Partition 1: (Active) - (Size=100 MB) - (Type=07 NTFS)
Partition 2: (Not Active) - (Size=931.4 GB) - (Type=07 NTFS)
Disk: 1 (Size: 465.8 GB) (Disk ID: 844382C4)
Partition 1: (Active) - (Size=465.8 GB) - (Type=07 NTFS)
==================== End of Addition.txt =======================
Mod edit: added noparse bbcode.
Hello, Carlosh.
1. FRST fix
Please do the following to run a FRST fix.
NOTICE: This script was written specifically for this user. Running it on another machine may cause damage to your operating system
  • Please select the entire contents of the code box below, from the "Start::" line to "End::", including both lines. Right-click and select "Copy ". No need to paste anything to anywhere.
Start::
CreateRestorePoint:
CloseProcesses:
HKLM\System\...\Parameters\PersistentRoutes: [0.0.0.0,0.0.0.0,26.0.0.1,9256]
IPSecPolicy: [ActivePolicy] SOFTWARE\Policies\Microsoft\Windows\IPSEC\Policy\Local\ipsecPolicy{54a8fc58-9b91-49c0-9f77-0893a0c1aae3} <==== ATTENTION (Restriction - IP)
GroupPolicy: Restriction ? <==== ATTENTION
Policies: C:\ProgramData\NTUSER.pol: Restriction <==== ATTENTION
HKLM\SOFTWARE\Policies\Mozilla\Firefox: Restriction <==== ATTENTION
HKLM\SOFTWARE\Policies\Google: Restriction <==== ATTENTION
HKLM\...\Run: [ProxyCap] => C:\Program Files\Proxy Labs\ProxyCap\pcapui.exe
HKLM-x32\...\Run: [Genshin Impact_Launcher] => [X]
HKLM-x32\...\Run: [ADSKAppManager] => "C:\Program Files (x86)\Common Files\Autodesk Shared\AppManager\R1\AdAppMgr.exe" -showminimized -checkautorun
HKLM-x32\...\Run: [ADSK DLMSession] => C:\Program Files (x86)\Common Files\Autodesk Shared\Autodesk Download Manager\DLMSession.exe
HKU\S-1-5-21-2305226654-651215044-733858041-1000\...\Run: [Google Update] => "C:\Users\Carlos Luna\AppData\Local\Google\Update\GoogleUpdate.exe" /c
HKLM\Software\Wow6432Node\Microsoft\Active Setup\Installed Components: [{8A69D345-D564-463c-AFF1-A69D9E530F96}] -> "C:\Program Files (x86)\Google\Chrome\Application\58.0.3029.81\Installer\chrmstp.exe" --configure-user-settings --verbose-logging --system-level
Startup: C:\Users\Carlos Luna\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\GameVox.lnk [2016-03-17]
Task: {0C9A5565-C85D-4309-810F-9B2EF6D93455} - System32\Tasks\EOSv3 Scheduler onLogOn => C:\Users\Carlos Luna\Downloads\esetonlinescanner_esn.exe
Task: {1156D15A-AAE6-4EE4-A768-C21AF23191D3} - System32\Tasks\{9F4A8BFD-E17F-4A42-B4EE-55FD2C147405} => C:\Windows\system32\pcalua.exe -a "C:\Users\Carlos Luna\AppData\Roaming\Nox\bin\Nox_unload.exe"
Task: {4580E52B-91EE-42B5-9363-56BABDA2AFFC} - System32\Tasks\CorelUpdateHelperTask-F299A6B575097899476390FCD7D79BE3 => C:\Program Files (x86)\Corel\CUH\v2\CUH.exe
Task: {52482CF5-BDD9-49A4-94A9-43C7A412C125} - System32\Tasks\{CB3E5831-270F-443A-894C-A54F005941DE} => C:\Windows\system32\pcalua.exe -a "C:\Users\Carlos Luna\Downloads\setup-gtarcade-601b27db75125.exe" -d "C:\Users\Carlos Luna\Downloads"
Task: {61AA0E70-25B1-4153-A33F-B19B7AC78098} - System32\Tasks\{0C2E49FB-E0FA-4939-849F-2F5A476D0F82} => C:\Windows\system32\pcalua.exe -a "C:\Users\Carlos Luna\Downloads\coreaacSetup.exe" -d "C:\Users\Carlos Luna\Downloads"
Task: {671E9D4A-C29E-4F2E-B2B6-E844B48D0215} - System32\Tasks\AVAST Software\Avast settings backup => C:\Program Files\Common Files\AV\avast! Antivirus\backup.exe
Task: {93D89636-DEDB-4163-B18A-E7AA18E71A78} - System32\Tasks\CorelUpdateHelperTaskCore => c:\Program Files (x86)\Corel\CUH\v2\CUH.exe
Task: {B07B46E1-E12B-40BE-98B3-19CE5A3F4679} - System32\Tasks\MEGA\MEGAsync Update Task S-1-5-21-2305226654-651215044-733858041-1000 => C:\Users\Carlos Luna\AppData\Local\MEGAsync\MEGAupdater.exe
Task: {BD5159BA-C4CA-4CEC-A03A-8757F4788891} - System32\Tasks\{9AC3D973-ABA9-417C-BFEC-58F9A2E0316A} => C:\Windows\system32\pcalua.exe -a "C:\Program Files (x86)\InstallShield Installation Information\{7F7E4FA7-6F32-4DE2-917E-361E034AED7A}\setup.exe" -c -runfromtemp -l0x0409
Task: {CFE7C1EB-6D01-4C36-9CBB-4299E628064A} - System32\Tasks\{FB630E37-2B8D-498A-AF0C-D1E8035CCC9A} => C:\Windows\system32\pcalua.exe -a "C:\Users\Carlos Luna\Downloads\remix-os-player-1-0-108.exe" -d "C:\Users\Carlos Luna\Downloads"
Task: {DD67DAB7-77D5-429A-A54E-4723DD7E316D} - System32\Tasks\{8BA74D91-FA29-419D-858B-36DC14E276AD} => C:\Windows\system32\pcalua.exe -a "F:\AutoPlay\Docs\Extras\Game Tools\DOSBox 0.63\DOSBox0.63-win32-installer.exe" -d "F:\AutoPlay\Docs\Extras\Game Tools\DOSBox 0.63"
Task: {E7C96D1D-73AE-4ED4-ACCB-72AAE2A699BB} - System32\Tasks\EOSv3 Scheduler onTime => C:\Users\Carlos Luna\Downloads\esetonlinescanner_esn.exe
R0 klupd_klif_arkmon; C:\Windows\System32\Drivers\klupd_klif_arkmon.sys [246952 2021-10-19] (Microsoft Windows Hardware Compatibility Publisher -> AO Kaspersky Lab)
S3 klupd_klif_klark; C:\Windows\System32\Drivers\klupd_klif_klark.sys [284408 2021-10-19] (Microsoft Windows Hardware Compatibility Publisher -> AO Kaspersky Lab)
S4 MozillaMaintenance; "C:\Program Files (x86)\Mozilla Maintenance Service\maintenanceservice.exe" [X]
Reg: reg add "HKLM\SOFTWARE\Microsoft\Internet Explorer\SearchScopes\{0633EE93-D776-472f-A0FF-E1416B8B2E3A}" /f
Reg: reg add "HKLM\SOFTWARE\Microsoft\Internet Explorer\SearchScopes\{0633EE93-D776-472f-A0FF-E1416B8B2E3A}" /ve /t REG_SZ /d Bing /f
Reg: reg add "HKLM\SOFTWARE\Microsoft\Internet Explorer\SearchScopes\{0633EE93-D776-472f-A0FF-E1416B8B2E3A}" /v URL /t REG_SZ /d "https://www.bing.com/search?q={searchTerms}&FORM=IE8SRC"/f
Reg: reg add "HKLM\SOFTWARE\Microsoft\Internet Explorer\SearchScopes\{0633EE93-D776-472f-A0FF-E1416B8B2E3A}" /v DisplayName /t REG_SZ /d "@ieframe.dll,-12512" /f
Reg: reg add "HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\SearchScopes\{0633EE93-D776-472f-A0FF-E1416B8B2E3A}" /f
Reg: reg add "HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\SearchScopes\{0633EE93-D776-472f-A0FF-E1416B8B2E3A}" /ve /t REG_SZ /d Bing /f
Reg: reg add "HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\SearchScopes\{0633EE93-D776-472f-A0FF-E1416B8B2E3A}" /v URL /t REG_SZ /d "https://www.bing.com/search?q={searchTerms}&FORM=IE8SRC"/f
Reg: reg add "HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\SearchScopes\{0633EE93-D776-472f-A0FF-E1416B8B2E3A}" /v DisplayName /t REG_SZ /d "@ieframe.dll,-12512" /f
DeleteKey: HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\AVAST Software
DeleteKey: HKCU\Software\Google
DeleteKey: HKLM\SOFTWARE\Google
DeleteKey: HKLM\SOFTWARE\Wow6432Node\Google
DeleteKey: HKCU\Software\MozillaPlugins
DeleteKey: HKLM\SOFTWARE\MozillaPlugins
DeleteKey: HKLM\SOFTWARE\Wow6432Node\MozillaPlugins
DeleteKey: HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\mountpoints2
DeleteKey: HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings\ZoneMap\Domains
DeleteKey: HKU\S-1-5-18\Software\Microsoft\Windows\CurrentVersion\Internet Settings\ZoneMap\Domains
C:\Windows\System32\Drivers\VBoxUSBMon.sys
C:\Windows\System32\Tasks\AVAST Software
File: C:\Windows\System32\User32.dll
File: C:\Windows\SysWOW64\User32.dll
Folder: C:\RECYCLER
Folder: C:\Windows\AppPatch
ExportKey: HKLM\SOFTWARE\SoundResearch
ExportKey: HKLM\SOFTWARE\Microsoft\DirectPlay8\Direct3D
ExportValue: HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
ExportValue: HKLM\SYSTEM\CurrentControlSet\Control\Session Manager
Powershell: wevtutil el | Foreach-Object {wevtutil cl "$_"}
cmd: more < "C:\Users\Carlos Luna\Cookies:9uiptag9KhjXpJROea9BnnRVF"
EmptyTemp:
End::
  • Please right-click on FRST64 on your Desktop, to run it as administrator. When the tool opens, click "yes" to the disclaimer.
  • Press the Fix button once and wait.
  • FRST will process fixlist.txt
  • When finished, it will produce a log fixlog.txt on your Desktop.
  • Please post the log in your next reply.
I forgot to check the 90 days option, I could do the fix again? or something bad could happen?
Fix result of Farbar Recovery Scan Tool (x64) Version: 02-11-2021
Ran by Carlos Luna (04-11-2021 15:04:52) Run:2
Running from C:\Users\Carlos Luna\Desktop
Loaded Profiles: Carlos Luna
Boot Mode: Normal
fixlist content:
CreateRestorePoint:
CloseProcesses:
R1 VBoxUSBMon; C:\Windows\System32\DRIVERS\VBoxUSBMon.sys [127432 2016-12-03] (Duodian Online Technology Co. Ltd. -> BigNox Corporation)
S1 amsdk; \??\C:\Windows\system32\drivers\amsdk.sys [X]
S2 BlueStacksDrv; \??\C:\Program Files\BlueStacks\BstkDrv_bgp.sys [X]
S3 Synth3dVsc; System32\drivers\synth3dvsc.sys [X]
S3 tsusbhub; system32\drivers\tsusbhub.sys [X]
S3 VGPU; System32\drivers\rdvgkmd.sys [X]
S3 WacHidRouter; system32\DRIVERS\wachidrouter.sys [X]
S3 wacomrouterfilter; system32\DRIVERS\wacomrouterfilter.sys [X]
S3 WinRing0_1_2_0; \??\C:\Users\Carlos Luna\AppData\Local\Temp\tmpE675.tmp [X] <==== ATTENTION
S3 xhunter1; \??\C:\Windows\xhunter1.sys [X]
S1 YSDrv; \??\C:\Program Files (x86)\Bignox\BigNoxVM\RT\YSDrv.sys [X]
Reg: reg add "HKLM\SOFTWARE\Microsoft\Internet Explorer\SearchScopes\{0633EE93-D776-472f-A0FF-E1416B8B2E3A}" /v URL /t REG_SZ /d "All aglow for Diwali{searchTerms}&FORM=IE8SRC"/f
Reg: reg add "HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\SearchScopes\{0633EE93-D776-472f-A0FF-E1416B8B2E3A}" /v URL /t REG_SZ /d "All aglow for Diwali{searchTerms}&FORM=IE8SRC"/f
Folder: C:\RECYCLER
EmptyTemp:
"HKLM\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\PersistentRoutes\\0.0.0.0,0.0.0.0,26.0.0.1,9256" => removed successfully
"HKLM\SOFTWARE\Policies\Microsoft\Windows\IPSec\Policy\Local\\ActivePolicy" => removed successfully
C:\Windows\system32\GroupPolicy\Machine => moved successfully
C:\Windows\system32\GroupPolicy\GPT.ini => moved successfully
C:\Windows\SysWOW64\GroupPolicy\GPT.ini => moved successfully
C:\ProgramData\NTUSER.pol => moved successfully
HKLM\SOFTWARE\Policies\Mozilla => removed successfully
HKLM\SOFTWARE\Policies\Google => removed successfully
"HKLM\Software\Microsoft\Windows\CurrentVersion\Run\\ProxyCap" => removed successfully
"HKLM\Software\WOW6432Node\Microsoft\Windows\CurrentVersion\Run\\Genshin Impact_Launcher" => removed successfully
"HKLM\Software\WOW6432Node\Microsoft\Windows\CurrentVersion\Run\\ADSKAppManager" => removed successfully
"HKLM\Software\WOW6432Node\Microsoft\Windows\CurrentVersion\Run\\ADSK DLMSession" => removed successfully
"HKU\S-1-5-21-2305226654-651215044-733858041-1000\Software\Microsoft\Windows\CurrentVersion\Run\\Google Update" => removed successfully
HKLM\Software\Wow6432Node\Microsoft\Active Setup\Installed Components\{8A69D345-D564-463c-AFF1-A69D9E530F96} => removed successfully
C:\Users\Carlos Luna\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\GameVox.lnk => moved successfully
"HKLM\Software\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Logon\{0C9A5565-C85D-4309-810F-9B2EF6D93455}" => removed successfully
"HKLM\Software\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{0C9A5565-C85D-4309-810F-9B2EF6D93455}" => removed successfully
C:\Windows\System32\Tasks\EOSv3 Scheduler onLogOn => moved successfully
"HKLM\Software\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\EOSv3 Scheduler onLogOn" => removed successfully
"HKLM\Software\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain\{1156D15A-AAE6-4EE4-A768-C21AF23191D3}" => removed successfully
"HKLM\Software\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{1156D15A-AAE6-4EE4-A768-C21AF23191D3}" => removed successfully
C:\Windows\System32\Tasks\{9F4A8BFD-E17F-4A42-B4EE-55FD2C147405} => moved successfully
"HKLM\Software\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\{9F4A8BFD-E17F-4A42-B4EE-55FD2C147405}" => removed successfully
"HKLM\Software\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain\{4580E52B-91EE-42B5-9363-56BABDA2AFFC}" => removed successfully
"HKLM\Software\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{4580E52B-91EE-42B5-9363-56BABDA2AFFC}" => removed successfully
C:\Windows\System32\Tasks\CorelUpdateHelperTask-F299A6B575097899476390FCD7D79BE3 => moved successfully
"HKLM\Software\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\CorelUpdateHelperTask-F299A6B575097899476390FCD7D79BE3" => removed successfully
"HKLM\Software\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain\{52482CF5-BDD9-49A4-94A9-43C7A412C125}" => removed successfully
"HKLM\Software\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{52482CF5-BDD9-49A4-94A9-43C7A412C125}" => removed successfully
C:\Windows\System32\Tasks\{CB3E5831-270F-443A-894C-A54F005941DE} => moved successfully
"HKLM\Software\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\{CB3E5831-270F-443A-894C-A54F005941DE}" => removed successfully
"HKLM\Software\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain\{61AA0E70-25B1-4153-A33F-B19B7AC78098}" => removed successfully
"HKLM\Software\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{61AA0E70-25B1-4153-A33F-B19B7AC78098}" => removed successfully
C:\Windows\System32\Tasks\{0C2E49FB-E0FA-4939-849F-2F5A476D0F82} => moved successfully
"HKLM\Software\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\{0C2E49FB-E0FA-4939-849F-2F5A476D0F82}" => removed successfully
"HKLM\Software\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Boot\{671E9D4A-C29E-4F2E-B2B6-E844B48D0215}" => removed successfully
"HKLM\Software\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{671E9D4A-C29E-4F2E-B2B6-E844B48D0215}" => removed successfully
C:\Windows\System32\Tasks\AVAST Software\Avast settings backup => moved successfully
"HKLM\Software\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\AVAST Software\Avast settings backup" => removed successfully
"HKLM\Software\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain\{93D89636-DEDB-4163-B18A-E7AA18E71A78}" => removed successfully
"HKLM\Software\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{93D89636-DEDB-4163-B18A-E7AA18E71A78}" => removed successfully
C:\Windows\System32\Tasks\CorelUpdateHelperTaskCore => moved successfully
"HKLM\Software\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\CorelUpdateHelperTaskCore" => removed successfully
"HKLM\Software\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain\{B07B46E1-E12B-40BE-98B3-19CE5A3F4679}" => removed successfully
"HKLM\Software\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{B07B46E1-E12B-40BE-98B3-19CE5A3F4679}" => removed successfully
C:\Windows\System32\Tasks\MEGA\MEGAsync Update Task S-1-5-21-2305226654-651215044-733858041-1000 => moved successfully
"HKLM\Software\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\MEGA\MEGAsync Update Task S-1-5-21-2305226654-651215044-733858041-1000" => removed successfully
"HKLM\Software\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain\{BD5159BA-C4CA-4CEC-A03A-8757F4788891}" => removed successfully
"HKLM\Software\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{BD5159BA-C4CA-4CEC-A03A-8757F4788891}" => removed successfully
C:\Windows\System32\Tasks\{9AC3D973-ABA9-417C-BFEC-58F9A2E0316A} => moved successfully
"HKLM\Software\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\{9AC3D973-ABA9-417C-BFEC-58F9A2E0316A}" => removed successfully
"HKLM\Software\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain\{CFE7C1EB-6D01-4C36-9CBB-4299E628064A}" => removed successfully
"HKLM\Software\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{CFE7C1EB-6D01-4C36-9CBB-4299E628064A}" => removed successfully
C:\Windows\System32\Tasks\{FB630E37-2B8D-498A-AF0C-D1E8035CCC9A} => moved successfully
"HKLM\Software\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\{FB630E37-2B8D-498A-AF0C-D1E8035CCC9A}" => removed successfully
"HKLM\Software\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain\{DD67DAB7-77D5-429A-A54E-4723DD7E316D}" => removed successfully
"HKLM\Software\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{DD67DAB7-77D5-429A-A54E-4723DD7E316D}" => removed successfully
C:\Windows\System32\Tasks\{8BA74D91-FA29-419D-858B-36DC14E276AD} => moved successfully
"HKLM\Software\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\{8BA74D91-FA29-419D-858B-36DC14E276AD}" => removed successfully
"HKLM\Software\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain\{E7C96D1D-73AE-4ED4-ACCB-72AAE2A699BB}" => removed successfully
"HKLM\Software\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{E7C96D1D-73AE-4ED4-ACCB-72AAE2A699BB}" => removed successfully
C:\Windows\System32\Tasks\EOSv3 Scheduler onTime => moved successfully
"HKLM\Software\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\EOSv3 Scheduler onTime" => removed successfully
klupd_klif_arkmon => Unable to stop service.
HKLM\System\CurrentControlSet\Services\klupd_klif_arkmon => removed successfully
klupd_klif_arkmon => service removed successfully
HKLM\System\CurrentControlSet\Services\klupd_klif_klark => removed successfully
klupd_klif_klark => service removed successfully
VBoxUSBMon => Service stopped successfully.
HKLM\System\CurrentControlSet\Services\VBoxUSBMon => removed successfully
VBoxUSBMon => service removed successfully
HKLM\System\CurrentControlSet\Services\MozillaMaintenance => removed successfully
MozillaMaintenance => service removed successfully
HKLM\System\CurrentControlSet\Services\amsdk => removed successfully
amsdk => service removed successfully
HKLM\System\CurrentControlSet\Services\BlueStacksDrv => removed successfully
BlueStacksDrv => service removed successfully
HKLM\System\CurrentControlSet\Services\Synth3dVsc => removed successfully
Synth3dVsc => service removed successfully
HKLM\System\CurrentControlSet\Services\tsusbhub => removed successfully
tsusbhub => service removed successfully
HKLM\System\CurrentControlSet\Services\VGPU => removed successfully
VGPU => service removed successfully
HKLM\System\CurrentControlSet\Services\WacHidRouter => removed successfully
WacHidRouter => service removed successfully
HKLM\System\CurrentControlSet\Services\wacomrouterfilter => removed successfully
wacomrouterfilter => service removed successfully
HKLM\System\CurrentControlSet\Services\WinRing0_1_2_0 => removed successfully
WinRing0_1_2_0 => service removed successfully
HKLM\System\CurrentControlSet\Services\xhunter1 => removed successfully
xhunter1 => service removed successfully
HKLM\System\CurrentControlSet\Services\YSDrv => removed successfully
YSDrv => service removed successfully
HKLM\System\CurrentControlSet\Control\SafeBoot\Minimal\amsdk.sys => removed successfully
HKLM\System\CurrentControlSet\Control\SafeBoot\Minimal\dump_3D569C04.sys => removed successfully
HKLM\System\CurrentControlSet\Control\SafeBoot\Minimal\Ms3D569C04App => removed successfully
HKLM\System\CurrentControlSet\Control\SafeBoot\Network\amsdk.sys => removed successfully
HKLM\System\CurrentControlSet\Control\SafeBoot\Network\dump_3D569C04.sys => removed successfully
HKLM\System\CurrentControlSet\Control\SafeBoot\Network\Ms3D569C04App => removed successfully
HKLM\SOFTWARE\Microsoft\Shared Tools\MSConfig\Services\Foundry License Server => removed successfully
HKLM\System\CurrentControlSet\Services\Foundry License Server => not found
HKLM\SOFTWARE\Microsoft\Shared Tools\MSConfig\Services\gupdate => removed successfully
HKLM\System\CurrentControlSet\Services\gupdate => not found
HKLM\SOFTWARE\Microsoft\Shared Tools\MSConfig\Services\gupdatem => removed successfully
HKLM\System\CurrentControlSet\Services\gupdatem => not found
HKLM\SOFTWARE\Microsoft\Shared Tools\MSConfig\Services\McComponentHostService => removed successfully
HKLM\System\CurrentControlSet\Services\McComponentHostService => not found
HKLM\SOFTWARE\Microsoft\Shared Tools\MSConfig\Services\MozillaMaintenance => removed successfully
HKLM\System\CurrentControlSet\Services\MozillaMaintenance => not found
HKLM\SOFTWARE\Microsoft\Shared Tools\MSConfig\Services\RLM => removed successfully
HKLM\System\CurrentControlSet\Services\RLM => not found
HKLM\SOFTWARE\Microsoft\Shared Tools\MSConfig\Services\Rockstar Service => removed successfully
HKLM\System\CurrentControlSet\Services\Rockstar Service => not found
HKLM\SOFTWARE\Microsoft\Shared Tools\MSConfig\Services\SkypeUpdate => removed successfully
HKLM\System\CurrentControlSet\Services\SkypeUpdate => not found
HKLM\SOFTWARE\Microsoft\Shared Tools\MSConfig\Services\vgc => removed successfully
HKLM\System\CurrentControlSet\Services\vgc => not found
HKLM\SOFTWARE\Microsoft\Shared Tools\MSConfig\Services\WTabletServiceCon => removed successfully
HKLM\System\CurrentControlSet\Services\WTabletServiceCon => not found
HKLM\Software\Microsoft\Windows\CurrentVersion\Explorer\ShellIconOverlayIdentifiers\ MEGA (Pending) => subkey with invalid name -> removed successfully
HKLM\Software\Microsoft\Windows\CurrentVersion\Explorer\ShellIconOverlayIdentifiers\ MEGA (Synced) => subkey with invalid name -> removed successfully
HKLM\Software\Microsoft\Windows\CurrentVersion\Explorer\ShellIconOverlayIdentifiers\ MEGA (Syncing) => subkey with invalid name -> removed successfully
HKLM\Software\Wow6432Node\Microsoft\Windows\CurrentVersion\Explorer\ShellIconOverlayIdentifiers\ MEGA (Pending) => subkey with invalid name -> removed successfully
HKLM\Software\Wow6432Node\Microsoft\Windows\CurrentVersion\Explorer\ShellIconOverlayIdentifiers\ MEGA (Synced) => subkey with invalid name -> removed successfully
HKLM\Software\Wow6432Node\Microsoft\Windows\CurrentVersion\Explorer\ShellIconOverlayIdentifiers\ MEGA (Syncing) => subkey with invalid name -> removed successfully
HKLM\Software\Classes\*\ShellEx\ContextMenuHandlers\MEGA (Context menu) => removed successfully
HKLM\Software\Classes\Drive\ShellEx\ContextMenuHandlers\MEGA (Context menu) => removed successfully
HKLM\Software\Classes\AllFileSystemObjects\ShellEx\ContextMenuHandlers\MEGA (Context menu) => removed successfully
HKLM\Software\Classes\Directory\ShellEx\ContextMenuHandlers\AutopanoShell.ShellContextMenu => removed successfully
HKLM\Software\Classes\Directory\ShellEx\ContextMenuHandlers\MEGA (Context menu) => removed successfully
"HKLM\SOFTWARE\Microsoft\Internet Explorer\Toolbar\\{CC1A175A-E45B-41ED-A30C-C9B1D7A0C02F}" => removed successfully
"HKU\S-1-5-21-2305226654-651215044-733858041-1000\Software\Microsoft\Internet Explorer\Toolbar\WebBrowser\\{47833539-D0C5-4125-9FA8-0819E2EAAC93}" => removed successfully
HKLM\Software\\Microsoft\Internet Explorer\Main\\"Search Page"="All aglow for Diwali" => value restored successfully
HKLM\Software\Wow6432Node\Microsoft\Internet Explorer\Main\\"Search Page"="All aglow for Diwali" => value restored successfully
HKLM\Software\\Microsoft\Internet Explorer\Main\\"Default_Page_URL"="MSN | Outlook, Office, Skype, Bing, Breaking News, and Latest Videos" => value restored successfully
HKLM\Software\Wow6432Node\Microsoft\Internet Explorer\Main\\"Default_Page_URL"="MSN | Outlook, Office, Skype, Bing, Breaking News, and Latest Videos" => value restored successfully
HKLM\Software\\Microsoft\Internet Explorer\Main\\"Default_Search_URL"="All aglow for Diwali" => value restored successfully
HKLM\Software\Wow6432Node\Microsoft\Internet Explorer\Main\\"Default_Search_URL"="All aglow for Diwali" => value restored successfully
HKLM\Software\\Microsoft\Internet Explorer\Main\\"Local Page"="C:\Windows\System32\blank.htm" => value restored successfully
========= reg add "HKLM\SOFTWARE\Microsoft\Internet Explorer\SearchScopes\{0633EE93-D776-472f-A0FF-E1416B8B2E3A}" /f =========
========= End of Reg: =========
========= reg add "HKLM\SOFTWARE\Microsoft\Internet Explorer\SearchScopes\{0633EE93-D776-472f-A0FF-E1416B8B2E3A}" /ve /t REG_SZ /d Bing /f =========
========= reg add "HKLM\SOFTWARE\Microsoft\Internet Explorer\SearchScopes\{0633EE93-D776-472f-A0FF-E1416B8B2E3A}" /v URL /t REG_SZ /d "All aglow for Diwali{searchTerms}&FORM=IE8SRC"/f =========
========= reg add "HKLM\SOFTWARE\Microsoft\Internet Explorer\SearchScopes\{0633EE93-D776-472f-A0FF-E1416B8B2E3A}" /v DisplayName /t REG_SZ /d "@ieframe.dll,-12512" /f =========
========= reg add "HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\SearchScopes\{0633EE93-D776-472f-A0FF-E1416B8B2E3A}" /f =========
========= reg add "HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\SearchScopes\{0633EE93-D776-472f-A0FF-E1416B8B2E3A}" /ve /t REG_SZ /d Bing /f =========
========= reg add "HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\SearchScopes\{0633EE93-D776-472f-A0FF-E1416B8B2E3A}" /v URL /t REG_SZ /d "All aglow for Diwali{searchTerms}&FORM=IE8SRC"/f =========
========= reg add "HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\SearchScopes\{0633EE93-D776-472f-A0FF-E1416B8B2E3A}" /v DisplayName /t REG_SZ /d "@ieframe.dll,-12512" /f =========
"HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\AVAST Software" => removed successfully
HKCU\Software\Google => removed successfully
HKLM\SOFTWARE\Google => removed successfully
HKLM\SOFTWARE\Wow6432Node\Google => removed successfully
HKCU\Software\MozillaPlugins => removed successfully
HKLM\SOFTWARE\MozillaPlugins => removed successfully
HKLM\SOFTWARE\Wow6432Node\MozillaPlugins => removed successfully
HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\mountpoints2 => removed successfully
HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings\ZoneMap\Domains => removed successfully
HKU\S-1-5-18\Software\Microsoft\Windows\CurrentVersion\Internet Settings\ZoneMap\Domains => removed successfully
C:\ProgramData\Apple => moved successfully
C:\ProgramData\Emsisoft => moved successfully
C:\Users\Carlos Luna\AppData\Local\{A194310A-E09D-4DA5-9E3E-1171E9EEAB3E} => moved successfully
C:\Windows\system32\NOTICE_mod => moved successfully
C:\Windows\system32\Drivers\klupd_klif_arkmon.sys => moved successfully
C:\Windows\system32\Drivers\klupd_klif_klark.sys => moved successfully
C:\Windows\System32\Drivers\VBoxUSBMon.sys => moved successfully
C:\Windows\System32\Tasks\AVAST Software => moved successfully
"C:\Program Files (x86)\TData" => not found
========================= File: C:\Windows\System32\User32.dll ========================
Catalog: C:\Windows\system32\CatRoot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_822_for_KB4539601~31bf3856ad364e35~amd64~~6.1.1.2.cat
File is digitally signed
MD5: 8638404CAC7EAC3F44824EAFBF91A715
Creation and modification date: 2021-04-29 14:41 - 2020-01-29 21:23
Attributes: ----A
Company Name: Microsoft Windows -> Microsoft Corporation
Internal Name: user32
Original Name: user32
Product: Microsoft® Windows® Operating System
Description: Multi-User Windows USER API Client DLL
File Version: 6.1.7601.24546 (win7sp1_ldr_escrow.200129-1600)
Product Version: 6.1.7601.24546
Copyright: © Microsoft Corporation. All rights reserved.
VirusTotal: VirusTotal
====== End of File: ======
========================= File: C:\Windows\SysWOW64\User32.dll ========================
Catalog: C:\Windows\system32\CatRoot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_757_for_KB4539601~31bf3856ad364e35~amd64~~6.1.1.2.cat
MD5: 8A4B88FFFCC661A3824860467CEB1D78
Creation and modification date: 2021-04-29 14:41 - 2020-01-29 21:30
Attributes: ----A
========================= Folder: C:\RECYCLER ========================
not found.
====== End of Folder: ======
========================= Folder: C:\Windows\AppPatch ========================
2018-09-12 20:17 - 2018-07-07 10:46 - 002182656 ____A [446ECE1E1F8AC2D3CAC848E360C57F3C] (Microsoft Corporation) C:\Windows\AppPatch\AcGenral.dll
2015-11-11 03:31 - 2015-10-29 12:49 - 000562176 ____A [8704A754CE5AF0C28CBB87A5FE77995A] (Microsoft Corporation) C:\Windows\AppPatch\AcLayers.dll
2019-03-12 19:25 - 2019-01-04 10:56 - 000002560 ____A [B03BA0E3A0C442F5B6B0E8885F881FA7] (Microsoft Corporation) C:\Windows\AppPatch\AcRes.dll
2015-11-11 03:31 - 2015-10-29 12:49 - 000470528 ____A [D22445D5DC0B475D4FCC9E99B25598AD] (Microsoft Corporation) C:\Windows\AppPatch\AcSpecfc.dll
2020-01-16 18:12 - 2020-01-02 22:37 - 000044544 ____A [8A1048AF855E51FD351E93AF52748D78] (Microsoft Corporation) C:\Windows\AppPatch\acwow64.dll
2015-11-11 03:31 - 2015-10-29 12:49 - 000211968 ____A [B48008CC06F17D14E8E741AB1C263DED] (Microsoft Corporation) C:\Windows\AppPatch\AcXtrnal.dll
2009-07-13 18:20 - 2009-07-13 20:14 - 000041984 ____A [59C7DD2EAFDBE86B2E23BCDABB575448] (Microsoft Corporation) C:\Windows\AppPatch\apihex86.dll
2021-09-26 01:50 - 2021-11-01 02:43 - 000966423 ____A [C32A49C90D831B2221C16FFAB4019013] () C:\Windows\AppPatch\DB3D569C04MK.sdb
2015-11-11 03:31 - 2015-10-29 08:50 - 000151806 ____A [B7861AAE75A529046D165FE9E4C7D504] () C:\Windows\AppPatch\drvmain.sdb
2017-11-19 22:28 - 2017-09-17 10:04 - 000004154 ____A [31CC816ECE45AD2A3966079296C08547] () C:\Windows\AppPatch\frxmain.sdb
2014-03-12 21:24 - 2010-11-19 22:59 - 001764066 ____A [EFF238D014B8357147503FB4209652C5] () C:\Windows\AppPatch\msimain.sdb
2014-03-12 21:24 - 2010-11-19 22:53 - 000044930 ____A [8C6D2DDBD98DAAF8789F0D84E4C9F4B1] () C:\Windows\AppPatch\pcamain.sdb
2021-09-26 01:50 - 2021-11-01 02:43 - 002821758 ____A [BCAD8F679EB502D052134E7D61B8554F] () C:\Windows\AppPatch\RC3D569C04MS.sdb
2019-03-12 19:25 - 2019-01-04 09:22 - 004082518 ____A [9BCE21CFB0CC6EDE026E1354064E897C] () C:\Windows\AppPatch\sysmain.sdb
2021-09-26 01:50 - 2021-11-01 02:20 - 000510352 ____A [F12332ACF2B94BDA02EABB5A5D24D179] () C:\Windows\AppPatch\TK3D569C04MS.sdb
2009-07-13 22:20 - 2019-03-12 20:49 - 000000000 ____D [00000000000000000000000000000000] () C:\Windows\AppPatch\AppPatch64
2018-09-12 20:17 - 2018-07-07 11:01 - 000316928 ____A [59C041E46987E4A47275A63670DA6F12] (Microsoft Corporation) C:\Windows\AppPatch\AppPatch64\AcGenral.dll
2015-11-11 03:31 - 2015-10-29 12:50 - 000350208 ____A [537C166E044FD90E0BBD768053C75654] (Microsoft Corporation) C:\Windows\AppPatch\AppPatch64\AcLayers.dll
2015-11-11 03:31 - 2015-10-29 12:50 - 000103424 ____A [1B31908AAEC9A580212CB27D24FBEB25] (Microsoft Corporation) C:\Windows\AppPatch\AppPatch64\acspecfc.dll
2015-11-11 03:31 - 2015-10-29 12:50 - 000135168 ____A [34003C8554568F9F35D122D87CF385AB] (Microsoft Corporation) C:\Windows\AppPatch\AppPatch64\AcXtrnal.dll
2009-07-13 18:32 - 2009-07-13 20:40 - 000052736 ____A [87F88B9C8882E84344729DDBEA731BD8] (Microsoft Corporation) C:\Windows\AppPatch\AppPatch64\apihex64.dll
2019-03-12 19:25 - 2019-01-04 09:22 - 000127986 ____A [6712E83EA2BF4FB46A316EEEF51E8101] () C:\Windows\AppPatch\AppPatch64\sysmain.sdb
2009-07-13 22:20 - 2009-07-13 22:20 - 000000000 ____D [00000000000000000000000000000000] () C:\Windows\AppPatch\Custom
2009-07-13 22:20 - 2009-07-13 21:34 - 000000000 ____D [00000000000000000000000000000000] () C:\Windows\AppPatch\Custom\Custom64
2020-03-22 18:02 - 2020-03-22 18:02 - 000000000 ____D [00000000000000000000000000000000] () C:\Windows\AppPatch\de-DE
2020-03-22 16:41 - 2010-11-20 04:03 - 000343040 ____A [C1BFE11701831B2D93B4AA681AD3408F] (Microsoft Corporation) C:\Windows\AppPatch\de-DE\AcRes.dll.mui
2009-07-14 00:37 - 2014-03-12 23:03 - 000000000 ____D [00000000000000000000000000000000] () C:\Windows\AppPatch\en-US
2014-03-12 19:28 - 2010-11-20 07:02 - 000292352 ____A [FEED731D80E4CCCC5BE0A5308552D178] (Microsoft Corporation) C:\Windows\AppPatch\en-US\AcRes.dll.mui
2014-03-12 20:36 - 2014-03-12 23:03 - 000000000 ____D [00000000000000000000000000000000] () C:\Windows\AppPatch\es-ES
2014-03-12 21:23 - 2010-11-20 07:05 - 000338432 ____A [DB765D658B6CD83E3D913B6822BA34BD] (Microsoft Corporation) C:\Windows\AppPatch\es-ES\AcRes.dll.mui
================== ExportKey: ===================
[HKLM\SOFTWARE\SoundResearch]
=== End of ExportKey ===
[HKLM\SOFTWARE\Microsoft\DirectPlay8\Direct3D]
"GrctZy5SKtqs1Mw8gR6NBV58WP3KYQ=="="WbtOjIMyq0ZjeKiA23AzswTfNVl9caG86p6W6OuyMhO/eZqhvUU23Dr1OxN7KWaBI3DfS/vrfM+c5+g+cIaEVPI+nOffisbpXynwcGjg2nEMdkPoHJxY65F026jq6OLBQjs6dt+x2jGiz9pSVUsaWCMuou9uDcbEfKeN62Kd5IGAfNxkfSNMAdjwckvZy6yWHKUwNFKu (the data entry has 1276 more characters)."
"FW8gc8ZxDaiTPJAzHyEKgHg="="KMtmalFB13vytHZdd8M="
"200000006D5F074C214C0F564280CAA13BEF038B22E6809F205A9E1B0F341E99E8C3208E"="150000004E1A54183009BE006C67E52FA2FBE35DA59833480F"
"1F000000B3188D70A8DB9B1DF3727D70D574C02E9EE67EE840E8BA8F2F34417AF069FC"="BE5E0000C878EBC2A8A94B3A9086121EA1CDB7A0D31A9D61F5DDED4E9CDCB120D90C2C9D869FD81A7839615F1C9CAE2FAF9709498ED21A0DB0E533D7EB001C6793BE88DA42BA61426EF6FD3F3B82A08BF0840B7C94F7CE5CA4A7CA07036CF653908E1DFC (the data entry has 48316 more characters)."
================== ExportValue: ===================
[HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon]
"ReportBootOk"="1"
"Shell"="explorer.exe"
"PreCreateKnownFolders"="{A520A1A4-1780-4FF6-BD18-167343C5AF16}"
"Userinit"="C:\Windows\system32\userinit.exe,"
"VMApplet"="SystemPropertiesPerformance.exe /pagefile"
"AutoRestartShell"="1"
"Background"="0 0 0"
"CachedLogonsCount"="10"
"DebugServerCommand"="no"
"ForceUnlockLogon"="0"
"LegalNoticeCaption"=""
"LegalNoticeText"=""
"PasswordExpiryWarning"="5"
"PowerdownAfterShutdown"="0"
"ShutdownWithoutLogon"="0"
"WinStationsDisabled"="0"
"DisableCAD"="1"
"scremoveoption"="0"
"ShutdownFlags"="43"
=== End of ExportValue ===
[HKLM\SYSTEM\CurrentControlSet\Control\Session Manager]
"CriticalSectionTimeout"="2592000"
"GlobalFlag"="0"
"HeapDeCommitFreeBlockThreshold"="0"
"HeapDeCommitTotalFreeThreshold"="0"
"HeapSegmentCommit"="0"
"HeapSegmentReserve"="0"
"ProcessorControl"="2"
"ResourceTimeoutCount"="648000"
"BootExecute"="autocheck autochk *"
"ExcludeFromKnownDlls"="*"
"ObjectDirectories"="\Windows*\RPC Control"
"ProtectionMode"="1"
"NumberOfInitialSessions"="2"
"SetupExecute"="*"
========= wevtutil el | Foreach-Object {wevtutil cl "$_"} =========
wevtutil.exe : Failed to clear log DebugChannel. The requested operation cannot
be performed over an enabled direct channel. The channel must first be disable
d before performing the requested operation.
At C:\FRST\tmp.ps1:1 char:39
+ wevtutil el | Foreach-Object {wevtutil <<<< cl "$_"}
+ CategoryInfo : NotSpecified: (Failed to clear...sted operation.
:String) [], RemoteException
+ FullyQualifiedErrorId : NativeCommandError
========= End of Powershell: =========
========= more < "C:\Users\Carlos Luna\Cookies:9uiptag9KhjXpJROea9BnnRVF" =========
yABTŽ
blBT‚
DGW^"ÍeTà³Sª~ù!`‰íϧ!pÑO´)?ÿEv»•YÜ
%»ŸT- N3&Òn‹{að”¯ùœMö¦%Éï5™ô‡ÃaS[ðLùžq¤=üËñ’n$'–žCʉ(¢6>DÈÐt‘¼ó`PD«Å”zßU„‹K´ÔÎr!ËøjZ¸ƒ „Î>ìÆ%OöL½]cë”þ &âH×T}ùH©X³£—D>µãù¢ôˆ|6¶NõOÈ?u‹Ü!–ŠqÛr¼|ˆùCQè•zsg:¬ãçºfäý÷#ù GŒrøY
ó´NÙìIMõ>tß|êNj€©m(Ç©—aÚÏÄ
¨–wŸØý¿q¯Vóy¡6Z2¿Úk¼yãhYÌq½Ç†oÿ;ûq‡ÃßDãpÖ{×iì(BïpsMÊj\ßô¹¶?ýŸ›Ùÿí»S—¨¤šúAñºÓVqŸ½[a[™3¬;rŽã±3]^^Ô2iɾ¸m{Ž@Rê‘°€g¸ùòFµ~ ¥®ˆß+Zj(X?³ "¶#¢7TK…¦1ñKiÙ$¼ÌŒY-0fLéÕ-õ»Bž”‰è®#W‰2–©ÿfrp$Ç\Z6Äö/ð°é]^Ü–d„‡‰QMc¡*¡¿Š½…ŒxIXÁ³Ý
DW™ø)®¸œì½¿JîûLÃÿ…²ÿ@H5}Y«ßÙD¯³ÉÁ”‡b†ì¸[®8ázŽæÊq0ê´Ú†ÉÎ]c{ûÜŸPɼ†
Û›ŸÌ]rÑžO[C¶›²•£ù–%«ïÿÏuÃîSæS=u
ŸtÅõQ×HÚ•1c:ßêIãslÍÎ_ ¤±0™4„àÿ'<2l›Ÿï‰¯OX>#›G4Q‚ª°@·ˆû@S¿ñ›Ø./Öd'‰›ÓìÁî¨rÿJ(žË5Ï.ØG‘7,à£ljn~‹UšŸLby‹)K8e^^Åò@Onóe]NDaͬ³£xúRRïÙÄ•fÁ]Lhú>`U;÷°µmÃv&÷Žkã<¹-Lvlbz½ ÖÕ¦îžSÞŠ‹"…ùW G^ß÷qQ¤e~߸,û…]-Ó]X¤’4j
0Šî„x:`Øzí´â•Uö¶3±Á»)\Ü0Vle
=========== EmptyTemp: ==========
BITS transfer queue => 0 B
DOMStore, IE Recovery, AppCache, Feeds Cache, Thumbcache, IconCache => 196634389 B
Java, Flash, Steam htmlcache => 1029130796 B
Windows/system/drivers => 15929965 B
Edge => 0 B
Firefox => 0 B
Opera => 18197037 B
Temp, IE cache, history, cookies, recent:
Default => 0 B
Public => 0 B
ProgramData => 0 B
systemprofile => 33186 B
systemprofile32 => 9976005 B
LocalService => 10009063 B
NetworkService => 10042121 B
Carlos Luna => 1203264907 B
RecycleBin => 8718875 B
EmptyTemp: => 2.3 GB temporary data Removed.
The system needed a reboot.
==== End of Fixlog 15:07:45 ====
Hi, Carlosh.
Thanks for the fix. No need to run it again. The 90 days option is for the Scan, not for the Fix action. So we are OK.
Let's move on.
1. FRST log
Start::
CreateRestorePoint:
CloseProcesses:
DeleteKey: HKLM\SOFTWARE\SoundResearch
DeleteKey: HKLM\SOFTWARE\Microsoft\DirectPlay8\Direct3D
EmptyTemp:
End::
2. Run AdwCleaner (Scan mode)
Download AdwCleaner and save it to your desktop.
  • Double click AdwCleaner.exe to run it.
  • Click Scan Now.
    • When the scan has finished, a Scan Results window will open.
    • Click Cancel (at this point do not attempt to Quarantine anything that is found)
  • Now click the Log Filestab.
    • Double click on the latest scan log (Scan logs have a [S0*] suffix, where * is replaced by a number. The latest scan will have the largest number)
    • A Notepad file will open containing the results of the scan.
    • Please post the contents of the file in your next reply.
3. Run Malwarebytes (Scan mode)
  • Download Malwarebytes and save it to your Desktop.
  • Once downloaded, close all programs and Windows on your computer.
  • Double-click on the icon on your desktop named MBSetup.exe. This will start the installation of MBAM onto your computer.
  • Follow the instructions to install the program.
  • When finished, double click the program's icon created on your Desktop.
  • Click the little gear on the top right (Settings) and when it opens, click the Security tab and make sure about the following:
    Under the title Scan Options, all the options are checked.
    Under the title Windows Security Center (Premium only) the option is NOT checked.
    Under the title Potentially unwanted items all options are set to Always.
  • Click on the little gear to return to the main menu and select Scan. The program will start scanning your computer. This may take about 10 minutes, but in some cases it may be take longer.
  • When finished, you will see the Threat Scan Summary window open.
If threats are not found, click View Report and proceed to the two last steps below.
If threats are found, make sure that all threats are not selected, close the program and proceed to the next steps below.
  • Open Malwarebytes again, click on the Scanner, and then on the Reports tab.
  • Find the report with the most recent date and double click on it.
  • Click on Export and then Copy to Clipboard.
  • Paste its content here, in your next reply.
In your next reply, please post:
  1. The fixlog.txt
  2. The AdwCleaner[S0*].txt
  3. The Malwarebytes report
Fixlog:
Ran by Carlos Luna (05-11-2021 19:49:05) Run:3
Boot Mode: Normal
fixlist content:
CreateRestorePoint:
CloseProcesses:
AlternateDataStreams: C:\Users\Carlos Luna\Cookies:9uiptag9KhjXpJROea9BnnRVF [1826]
EmptyTemp:
HKLM\SOFTWARE\SoundResearch => removed successfully
HKLM\SOFTWARE\Microsoft\DirectPlay8\Direct3D => removed successfully
C:\Windows\AppPatch\DB3D569C04MK.sdb => moved successfully
C:\Windows\AppPatch\RC3D569C04MS.sdb => moved successfully
C:\Windows\AppPatch\TK3D569C04MS.sdb => moved successfully
C:\Users\Carlos Luna\Cookies => ":9uiptag9KhjXpJROea9BnnRVF" ADS removed successfully
DOMStore, IE Recovery, AppCache, Feeds Cache, Thumbcache, IconCache => 6752916 B
Java, Flash, Steam htmlcache => 16630468 B
Windows/system/drivers => 23704 B
Edge => 0 B
Firefox => 0 B
Opera => 0 B
Default => 0 B
Public => 0 B
ProgramData => 0 B
systemprofile => 0 B
systemprofile32 => 0 B
LocalService => 0 B
NetworkService => 0 B
Carlos Luna => 5163399 B
RecycleBin => 0 B
EmptyTemp: => 27.2 MB temporary data Removed.
==== End of Fixlog 19:49:34 ====
AdwCleaner log:
# Malwarebytes AdwCleaner 8.3.0.0
# Build: 06-29-2021
# Database: 2021-10-26.1 (Cloud)
# Support: https://www.malwarebytes.com/support
# Mode: Scan
# Start: 11-05-2021
# Duration: 00:00:09
# OS: Windows 7 Ultimate
# Scanned: 31997
# Detected: 13
***** [ Services ] *****
No malicious services found.
***** [ Folders ] *****
PUP.Optional.PCProtect C:\Windows\SysWOW64\config\systemprofile\AppData\Roaming\PCProtect
***** [ Files ] *****
No malicious files found.
***** [ DLL ] *****
No malicious DLLs found.
***** [ WMI ] *****
No malicious WMI found.
***** [ Shortcuts ] *****
No malicious shortcuts found.
***** [ Tasks ] *****
No malicious tasks found.
***** [ Registry ] *****
PUP.Optional.CrossRider HKCU\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{189B4C7D-CB31-4D84-96CE-6BCA38AD365}
PUP.Optional.CrossRider HKCU\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{6FBDC96C-2B2B-4680-ACA7-22BE27BB4B}
PUP.Optional.CrossRider HKCU\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{EB0D9100-DA11-466F-A2F4-1F978AC76CE}
PUP.Optional.DriverUpdatePlus HKLM\Software\Wow6432Node\BSD
PUP.Optional.PCProtect HKCU\Software\SSProtect
PUP.Optional.PCProtect HKLM\SOFTWARE\Mozilla\NativeMessagingHosts\com.pcprotect.passwordvaultassistant
PUP.Optional.PCProtect HKLM\System\CurrentControlSet\Services\EventLog\Application\SecurityService
PUP.Optional.SafePCKit HKCU\Software\Sunisoft
PUP.Optional.TotalAV HKLM\SOFTWARE\Microsoft\Edge\NativeMessagingHosts\com.totalav.passwordvaultassistant
PUP.Optional.TotalAV HKLM\SOFTWARE\Mozilla\NativeMessagingHosts\com.totalav.passwordvaultassistant
PUP.Optional.TotalAV HKLM\Software\Classes\totalav
PUP.Optional.TotalAV HKLM\System\CurrentControlSet\Services\EventLog\Application\SecurityServiceMonitor
***** [ Chromium (and derivatives) ] *****
No malicious Chromium entries found.
***** [ Chromium URLs ] *****
No malicious Chromium URLs found.
***** [ Firefox (and derivatives) ] *****
No malicious Firefox entries found.
***** [ Firefox URLs ] *****
No malicious Firefox URLs found.
***** [ Hosts File Entries ] *****
No malicious hosts file entries found.
***** [ Preinstalled Software ] *****
No Preinstalled Software found.
AdwCleaner[S00].txt - [10727 octets] - [19/02/2019 20:50:32]
AdwCleaner[C00].txt - [9264 octets] - [19/02/2019 20:51:26]
########## EOF - C:\AdwCleaner\Logs\AdwCleaner[S01].txt ##########
Malwarebytes:
Malwarebytes
-Log Details-
Scan Date: 11/5/21
Scan Time: 8:08 PM
Log File: 00d8e864-3e9e-11ec-a296-d850e63c46b2.json
-Software Information-
Version: 4.4.10.144
Components Version: 1.0.1499
Update Package Version: 1.0.46844
License: Free
-System Information-
OS: Windows 7 Service Pack 1
CPU: x64
File System: NTFS
User: 1989AH\Carlos Luna
-Scan Summary-
Scan Type: Threat Scan
Scan Initiated By: Manual
Result: Completed
Objects Scanned: 328130
Threats Detected: 0
Threats Quarantined: 0
Time Elapsed: 17 min, 38 sec
-Scan Options-
Memory: Enabled
Startup: Enabled
Filesystem: Enabled
Archives: Enabled
Rootkits: Enabled
Heuristics: Enabled
PUP: Detect
PUM: Detect
-Scan Details-
Process: 0
(No malicious items detected)
Module: 0
Registry Key: 0
Registry Value: 0
Registry Data: 0
Data Stream: 0
Folder: 0
File: 0
Physical Sector: 0
WMI: 0
(end)
Hi, Carlosh.
AdwCleaner found many PUPs, meaning potentially unwanted programs. Let's clean.
To proceed, please do the following:
  • Double click AdwCleaner.exe on your Desktop, to run it as you did before.
  • Click Scan Now.
  • When the scan has finished a Scan Results window will open.
  • Please check all the boxes and then click Quarantine.
  • Click Next.
    • If any pre-installed software was found on your machine, a prompt window will open. Click OK to close it.
    • Check any pre-installed software items you want to remove.
    • Click Quarantine.
  • A prompt to save your work will appear.
    • Click Continue when you're ready to proceed.
  • A prompt to restart your computer will appear.
    • Click Restart Now.
  • Once your computer has restarted:
    • If it doesn't open automatically, please start AdwCleaner.
    • Click the Log Files tab.
    • Double click on the latest Clean log (Clean logs have a [C0*] suffix, where * is replaced by a number, the latest scan will have the largest number)
    • A Notepad file will open containing the results of the removal.
After the above, I would like to see fresh FRST logs, Addition and FRST.
In your next reply please post:
  1. The AdwCleaner[C0*].txt
  2. The two FRST logs, Addition.txt and FRST.txt
AdwCleaner log:
# Build: 06-29-2021
# Mode: Clean
# Start: 11-06-2021
# Duration: 00:00:01
# Cleaned: 13
# Failed: 0
No malicious services cleaned.
Deleted C:\Windows\SysWOW64\config\systemprofile\AppData\Roaming\PCProtect
No malicious files cleaned.
***** [ DLL ] *****
No malicious DLLs cleaned.
***** [ WMI ] *****
No malicious WMI cleaned.
No malicious shortcuts cleaned.
No malicious tasks cleaned.
Deleted HKCU\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{189B4C7D-CB31-4D84-96CE-6BCA38AD365}
Deleted HKCU\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{6FBDC96C-2B2B-4680-ACA7-22BE27BB4B}
Deleted HKCU\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{EB0D9100-DA11-466F-A2F4-1F978AC76CE}
Deleted HKCU\Software\SSProtect
Deleted HKCU\Software\Sunisoft
Deleted HKLM\SOFTWARE\Microsoft\Edge\NativeMessagingHosts\com.totalav.passwordvaultassistant
Deleted HKLM\SOFTWARE\Mozilla\NativeMessagingHosts\com.pcprotect.passwordvaultassistant
Deleted HKLM\SOFTWARE\Mozilla\NativeMessagingHosts\com.totalav.passwordvaultassistant
Deleted HKLM\Software\Classes\totalav
Deleted HKLM\Software\Wow6432Node\BSD
Deleted HKLM\System\CurrentControlSet\Services\EventLog\Application\SecurityService
Deleted HKLM\System\CurrentControlSet\Services\EventLog\Application\SecurityServiceMonitor
No malicious Chromium entries cleaned.
No malicious Chromium URLs cleaned.
No malicious Firefox entries cleaned.
No malicious Firefox URLs cleaned.
No malicious hosts file entries cleaned.
No Preinstalled Software cleaned.
[+] Delete Tracing Keys
[+] Reset Winsock
AdwCleaner[S01].txt - [2791 octets] - [05/11/2021 19:58:39]
AdwCleaner[S02].txt - [2852 octets] - [06/11/2021 17:26:13]
########## EOF - C:\AdwCleaner\Logs\AdwCleaner[C02].txt ##########
FRST log:
Scan result of Farbar Recovery Scan Tool (FRST) (x64) Version: 06-11-2021
Ran by Carlos Luna (administrator) on 1989AH (ASUS All Series) (06-11-2021 17:36:33)
: Microsoft Windows 7 Ultimate Service Pack 1 (X64) Language: English (United States)
Default browser: Opera
Boot Mode: Normal
(Adobe Systems, Incorporated -> Adobe Systems Incorporated) C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\armsvc.exe
(Arvato Digital Services Canada Inc -> arvato digital services llc) C:\Program Files (x86)\Common Files\Protexis\License Service\PsiService_2.exe
(Borislav Surbat -> MyCity) C:\Program Files (x86)\MCShield\MCShieldRTM.exe
(Intel Corporation - Intel® Management Engine Firmware -> Intel Corporation) C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL\jhi_service.exe
(Intel Corporation - Software and Firmware Products -> Intel Corporation) C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\LMS\LMS.exe
(Intel Corporation - Software and Firmware Products -> Intel Corporation) C:\Program Files (x86)\Intel\Intel(R) USB 3.0 eXtensible Host Controller Driver\Application\iusb3mon.exe
(Intel(R) Corporation) [File not signed] C:\Program Files\Intel\iCLS Client\HeciServer.exe
(Logitech -> Logitech Inc.) C:\Program Files\Logitech Gaming Software\LCore.exe
(Microsoft Windows -> Microsoft Corporation) C:\Windows\System32\rundll32.exe
(Microsoft Windows Hardware Compatibility Publisher -> ) C:\Program Files (x86)\ASUS\AXSP\1.01.01\atkexComSvc.exe
(NVIDIA Corporation -> NVIDIA Corporation) C:\Program Files\NVIDIA Corporation\Display.NvContainer\NVDisplay.Container.exe <2>
(Opera Software AS -> Opera Software) C:\Users\Carlos Luna\AppData\Local\Programs\Opera GX\80.0.4170.91\opera_crashreporter.exe
(Opera Software AS -> Opera Software) C:\Users\Carlos Luna\AppData\Local\Programs\Opera GX\opera.exe <12>
(Realtek Semiconductor Corp. -> Realtek Semiconductor) C:\Program Files\Realtek\Audio\HDA\RtkNGUI64.exe
==================== Registry (Whitelisted) ===================
HKLM\...\Run: [RTHDVCPL] => C:\Program Files\Realtek\Audio\HDA\RtkNGUI64.exe [9068040 2016-11-09] (Realtek Semiconductor Corp. -> Realtek Semiconductor)
HKLM\...\Run: [Launch LCore] => C:\Program Files\Logitech Gaming Software\LCore.exe [8294680 2014-02-27] (Logitech -> Logitech Inc.)
HKLM\...\Run: [AdobeAAMUpdater-1.0] => C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\UWA\UpdaterStartupUtility.exe [446392 2012-04-04] (Adobe Systems Incorporated -> Adobe Systems Incorporated)
HKLM-x32\...\Run: [USB3MON] => C:\Program Files (x86)\Intel\Intel(R) USB 3.0 eXtensible Host Controller Driver\Application\iusb3mon.exe [292848 2013-04-26] (Intel Corporation - Software and Firmware Products -> Intel Corporation)
HKLM-x32\...\Run: [SwitchBoard] => C:\Program Files (x86)\Common Files\Adobe\SwitchBoard\SwitchBoard.exe [517096 2010-02-19] (Test Signing Certificate -> Adobe Systems Incorporated) [File not signed]
HKLM-x32\...\Run: [BCSSync] => C:\Program Files (x86)\Microsoft Office\Office14\BCSSync.exe [91520 2010-03-13] (Microsoft Corporation -> Microsoft Corporation)
HKLM-x32\...\Run: [AdobeCS6ServiceManager] => C:\Program Files (x86)\Common Files\Adobe\CS6ServiceManager\CS6ServiceManager.exe [1073312 2012-03-09] (Adobe Systems Incorporated -> Adobe Systems Incorporated)
HKU\S-1-5-21-2305226654-651215044-733858041-1000\...\Run: [Opera GX Browser Assistant] => C:\Users\Carlos Luna\AppData\Local\Programs\Opera GX\assistant\browser_assistant.exe [3291288 2021-02-01] (Opera Software AS -> Opera Software)
HKU\S-1-5-21-2305226654-651215044-733858041-1000\...\Run: [MCShield Monitor] => C:\Program Files (x86)\MCShield\mcshieldrtm.exe [650816 2014-04-11] (Borislav Surbat -> MyCity)
HKU\S-1-5-18\...\RunOnce: [SPReview] => C:\Windows\System32\SPReview\SPReview.exe [301568 2014-03-12] (Microsoft Windows -> Microsoft Corporation)
HKLM\Software\Microsoft\Active Setup\Installed Components: [{2D46B6DC-2207-486B-B523-A557E6D54B47}] -> C:\Windows\system32\cmd.exe /D /C start C:\Windows\system32\ie4uinit.exe -ClearIconCache
HKLM\Software\Wow6432Node\Microsoft\Active Setup\Installed Components: [{2D46B6DC-2207-486B-B523-A557E6D54B47}] -> C:\Windows\system32\cmd.exe /D /C start C:\Windows\system32\ie4uinit.exe -ClearIconCache
==================== Scheduled Tasks (Whitelisted) ============
Task: {1ADD0762-CC79-45E7-B15D-17E123E1BE18} - System32\Tasks\Microsoft_Hardware_Launch_ipoint_exe => C:\Program Files\Microsoft Mouse and Keyboard Center\ipoint.exe [2206488 2016-08-15] (Microsoft Corporation -> Microsoft Corporation)
Task: {293D7E12-004D-4520-8CE0-C06D21EFB4D1} - System32\Tasks\Opera GX scheduled Autoupdate 1634241479 => C:\Users\Carlos Luna\AppData\Local\Programs\Opera GX\launcher.exe [46162128 2021-11-04] (Opera Software AS -> Opera Software)
Task: {427624A0-6125-446F-84D9-BC6C71027E47} - System32\Tasks\Microsoft_Hardware_Launch_mousekeyboardcenter_exe => C:\Program Files\Microsoft Mouse and Keyboard Center\mousekeyboardcenter.exe [2225952 2016-08-15] (Microsoft Corporation -> Microsoft)
Task: {45A4D6E9-3EB8-4039-87C0-8EDD5A1CDC23} - System32\Tasks\Opera GX scheduled assistant Autoupdate 1634663272 => C:\Users\Carlos Luna\AppData\Local\Programs\Opera GX\launcher.exe [46162128 2021-11-04] (Opera Software AS -> Opera Software) -> --scheduledautoupdate --component-name=assistant --component-path="C:\Users\Carlos Luna\AppData\Local\Programs\Opera GX\assistant" $(Arg0)
Task: {4D109734-C672-4DAB-8E1C-0848709181B8} - System32\Tasks\Games\UpdateCheck_S-1-5-21-2305226654-651215044-733858041-1000 => {CA22F5B1-E06F-4A2B-94FC-21E87FE53781} C:\Windows\System32\gameux.dll [2746368 2012-12-07] (Microsoft Windows -> Microsoft Corporation)
Task: {5918D14A-68E3-4CFE-B21E-E1748D153440} - System32\Tasks\AdobeAAMUpdater-1.0-CarlosLuna-PC-Carlos Luna => C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\UWA\UpdaterStartupUtility.exe [446392 2012-04-04] (Adobe Systems Incorporated -> Adobe Systems Incorporated)
Task: {62A6C492-DB90-48A0-8729-0E9EE4C6AA60} - System32\Tasks\Adobe Acrobat Update Task => C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\AdobeARM.exe [998104 2015-07-07] (Adobe Systems, Incorporated -> Adobe Systems Incorporated)
Task: {6D10DDD6-E35A-4909-8989-1D5F095840CE} - System32\Tasks\CCleanerSkipUAC => C:\Program Files\CCleaner\CCleaner.exe [4624152 2014-06-24] (Piriform Ltd -> Piriform Ltd)
Task: {6FC4D6E7-AEFA-40A9-9BB7-93CA381DA6F7} - System32\Tasks\BlueStacksHelper_nxt => C:\Program Files\BlueStacks_nxt\BlueStacksHelper.exe [275136 2021-09-21] (Bluestack Systems, Inc -> BlueStack Systems, Inc.)
Task: {A3B005D3-E9D2-481C-8F83-C314EFE5F8A2} - System32\Tasks\Microsoft_MKC_Logon_Task_itype.exe => C:\Program Files\Microsoft Mouse and Keyboard Center\itype.exe [1665312 2016-08-15] (Microsoft Corporation -> Microsoft Corporation)
Task: {D0087371-BA7B-40D8-B082-1AA679E01EE7} - System32\Tasks\Microsoft_MKC_Logon_Task_ipoint.exe => C:\Program Files\Microsoft Mouse and Keyboard Center\ipoint.exe [2206488 2016-08-15] (Microsoft Corporation -> Microsoft Corporation)
Task: {D0C532E0-D1C5-4939-9A5D-20C1E65CEBAA} - System32\Tasks\Microsoft_Hardware_Launch_itype_exe => C:\Program Files\Microsoft Mouse and Keyboard Center\itype.exe [1665312 2016-08-15] (Microsoft Corporation -> Microsoft Corporation)
Task: {D685ED40-7570-4DD0-8D05-E36B8F49EF67} - System32\Tasks\BlueStacksHelper => C:\ProgramData\BlueStacks\Client\Helper\BlueStacksHelper.exe [754472 2021-04-05] (BlueStack Systems, Inc. -> BlueStack Systems, Inc.)
Tcpip\Parameters: [DhcpNameServer] 200.48.225.146 200.48.225.130
Tcpip\..\Interfaces\{4F611090-1E2A-4C0B-B218-CB68014871BD}: [DhcpNameServer] 192.168.42.129
Tcpip\..\Interfaces\{577DA66F-E0C5-4726-8D88-1A73332085A9}: [DhcpNameServer] 200.48.225.146 200.48.225.130
Tcpip\..\Interfaces\{8D58557D-1DB6-4DD8-B77E-9A6F9972990A}: [DhcpNameServer] 192.168.42.129
Tcpip\..\Interfaces\{A27F8B15-26C0-4909-9700-9719E16C3A24}: [DhcpNameServer] 200.48.225.130 200.48.225.146
Tcpip\..\Interfaces\{B67BBEAF-70C7-4ED9-ADCE-DAC65DF532A9}: [DhcpNameServer] 200.48.225.146 200.48.225.130
Opera:
OPR Profile: C:\Users\Carlos Luna\AppData\Roaming\Opera Software\Opera Stable [2021-11-04]
OPR DefaultSuggestURL: Opera Stable -> hxxps://www.google.com/complete/search?client=opera&q={searchTerms}&ie={inputEncoding}&oe={outputEncoding}
OPR Extension: (Rich Hints Agent) - C:\Users\Carlos Luna\AppData\Roaming\Opera Software\Opera Stable\Extensions\enegjkbbakeegngfapepobipndnebkdk [2021-09-29]
OPR Extension: (Amazon Assistant Promotion) - C:\Users\Carlos Luna\AppData\Roaming\Opera Software\Opera Stable\Extensions\kbmoiomgmchbpihhdpabemajcbjpcijk [2021-09-28]
StartMenuInternet: (HKU\S-1-5-21-2305226654-651215044-733858041-1000) Opera GXStable - "C:\Users\Carlos Luna\AppData\Local\Programs\Opera GX\Launcher.exe"
==================== Services (Whitelisted) ===================
"MBAMChameleon" => service could not be unlocked. <==== ATTENTION
HKLM\SYSTEM\ControlSet001\Services\MBAMChameleon => \SystemRoot\System32\Drivers\MbamChameleon.sys <==== ATTENTION (Rootkit!/Locked Service)
R2 AdobeARMservice; C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\armsvc.exe [82128 2015-07-07] (Adobe Systems, Incorporated -> Adobe Systems Incorporated)
R2 asComSvc; C:\Program Files (x86)\ASUS\AXSP\1.01.01\atkexComSvc.exe [927232 2012-10-29] (Microsoft Windows Hardware Compatibility Publisher -> )
S3 EasyAntiCheat; C:\Program Files (x86)\EasyAntiCheat\EasyAntiCheat.exe [781440 2019-03-11] (EasyAntiCheat Oy -> EasyAntiCheat Ltd)
S3 EpicOnlineServices; C:\Program Files (x86)\Epic Games\Epic Online Services\service\EpicOnlineServicesHost.exe [16029472 2021-10-23] (Epic Games Inc. -> Epic Games, Inc.)
S3 IDriverT; C:\Program Files (x86)\Common Files\InstallShield\Driver\11\Intel 32\IDriverT.exe [69632 2005-04-04] (Macrovision Corporation) [File not signed]
R2 Intel(R) Capability Licensing Service Interface; C:\Program Files\Intel\iCLS Client\HeciServer.exe [747520 2013-08-27] (Intel(R) Corporation) [File not signed]
S2 MBAMService; C:\Program Files\Malwarebytes\Anti-Malware\MBAMService.exe [7848632 2021-11-05] (Malwarebytes Inc -> Malwarebytes)
S3 npggsvc; C:\Windows\SysWOW64\GameMon.des [9473408 2021-01-18] (INCA Internet Co.,Ltd. -> INCA Internet Co., Ltd.)
R2 PSI_SVC_2; c:\Program Files (x86)\Common Files\Protexis\License Service\PsiService_2.exe [277360 2014-04-30] (Arvato Digital Services Canada Inc -> arvato digital services llc)
S3 SwitchBoard; C:\Program Files (x86)\Common Files\Adobe\SwitchBoard\SwitchBoard.exe [517096 2010-02-19] (Test Signing Certificate -> Adobe Systems Incorporated) [File not signed]
R2 WinDefend; C:\Program Files\Windows Defender\mpsvc.dll [1011712 2013-05-27] (Microsoft Windows -> Microsoft Corporation)
===================== Drivers (Whitelisted) ===================
R1 AsIO; C:\Windows\SysWow64\drivers\AsIO.sys [15232 2012-08-21] (ASUSTeK Computer Inc. -> )
R2 BlueStacksDrv_nxt; C:\Program Files\BlueStacks_nxt\BstkDrv_nxt.sys [320728 2021-09-20] (Bluestack Systems, Inc -> Bluestack System Inc.)
S3 dtlitescsibus; C:\Windows\System32\DRIVERS\dtlitescsibus.sys [30264 2016-09-22] (Disc Soft Ltd -> Disc Soft Ltd)
S3 dtliteusbbus; C:\Windows\System32\DRIVERS\dtliteusbbus.sys [47672 2016-09-22] (Disc Soft Ltd -> Disc Soft Ltd)
R3 LGSHidFilt; C:\Windows\System32\DRIVERS\LGSHidFilt.Sys [64280 2013-05-30] (Logitech -> Logitech Inc.)
R3 LGSUsbFilt; C:\Windows\System32\DRIVERS\LGSUsbFilt.Sys [41752 2013-05-30] (Logitech -> Logitech Inc.)
S3 MBAMSwissArmy; C:\Windows\System32\Drivers\mbamswissarmy.sys [248992 2021-11-05] (Malwarebytes Inc -> Malwarebytes)
R3 rtl819xpn64; C:\Windows\System32\DRIVERS\rtl819xp.sys [622624 2010-02-01] (Realtek Semiconductor Corp -> Realtek Semiconductor Corporation)
S3 RTTEAMPT; C:\Windows\System32\DRIVERS\RtTeam620.sys [58512 2012-07-03] (Realtek Semiconductor Corp -> Realtek Corporation)
S3 RvNetMP60; C:\Windows\System32\DRIVERS\RvNetMP60.sys [69048 2018-12-25] (Famatech Corp. -> Famatech Corp.)
S3 tap0901; C:\Windows\System32\DRIVERS\tap0901.sys [27136 2017-08-30] (OpenVPN Technologies, Inc. -> The OpenVPN Project)
R3 wovad_micarray; C:\Windows\System32\drivers\womic.sys [35696 2017-11-25] (Beijing Wolicheng Technology Co., Ltd. -> Windows (R) Win 7 DDK provider)
==================== Three months (created) (Whitelisted) =========
2021-11-06 17:36 - 2021-11-06 17:37 - 000013725 _____ C:\Users\Carlos Luna\Desktop\FRST.txt
2021-11-05 20:05 - 2021-11-05 20:05 - 000248992 _____ (Malwarebytes) C:\Windows\system32\Drivers\mbamswissarmy.sys
2021-11-05 20:05 - 2021-11-05 20:05 - 000001960 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Malwarebytes.lnk
2021-11-05 20:05 - 2021-11-05 20:05 - 000001948 _____ C:\Users\Public\Desktop\Malwarebytes.lnk
2021-11-05 20:05 - 2021-11-05 20:05 - 000000000 ____D C:\Users\Carlos Luna\AppData\Local\mbam
2021-11-05 20:04 - 2021-11-05 20:04 - 000160176 _____ (Malwarebytes) C:\Windows\system32\Drivers\mbae64.sys
2021-11-05 20:04 - 2021-11-05 20:04 - 000000000 ____D C:\ProgramData\Malwarebytes
2021-11-05 20:04 - 2021-11-05 20:04 - 000000000 ____D C:\Program Files\Malwarebytes
2021-11-05 20:03 - 2021-11-05 20:03 - 000001415 _____ C:\Users\Carlos Luna\Desktop\steps mwbites.txt
2021-11-05 19:43 - 2021-11-05 19:43 - 008553680 _____ (Malwarebytes) C:\Users\Carlos Luna\Desktop\AdwCleaner.exe
2021-11-05 19:42 - 2021-11-05 19:42 - 002101944 _____ (Malwarebytes) C:\Users\Carlos Luna\Desktop\MBSetup-119967.119967-consumer.exe
2021-11-04 15:43 - 2021-11-04 15:43 - 000000008 __RSH C:\ProgramData\ntuser.pol
2021-11-03 20:02 - 2021-11-03 20:03 - 000001970 _____ C:\Users\Carlos Luna\Desktop\netcfg_2021-11-03_20-02-55.dat
2021-11-03 10:11 - 2021-11-05 20:06 - 000000000 ____D C:\Users\Carlos Luna\AppData\Local\CrashDumps
2021-11-03 01:03 - 2021-11-03 01:03 - 000000031 _____ C:\Users\Carlos Luna\Documents\recover network settings.txt
2021-11-02 19:01 - 2021-11-02 19:01 - 000005478 _____ C:\NetworkSettings.txt
2021-11-02 18:59 - 2021-11-02 19:00 - 000005478 _____ C:\Windows\system32\NetworkSettings.txt
2021-11-02 18:58 - 2021-11-02 18:58 - 001053600 _____ (ESET) C:\Users\Carlos Luna\Desktop\esetuninstaller.exe
2021-11-01 15:33 - 2021-11-06 17:36 - 000000000 ____D C:\Users\Carlos Luna\Desktop\FRST-OlderVersion
2021-10-28 17:52 - 2021-11-06 17:31 - 000000000 ____D C:\ProgramData\MCShield
2021-10-28 17:52 - 2021-10-28 17:52 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\MCShield
2021-10-28 17:52 - 2021-10-28 17:52 - 000000000 ____D C:\Program Files (x86)\MCShield
2021-10-28 17:44 - 2021-10-28 17:45 - 002856736 _____ (MyCity) C:\Users\Carlos Luna\Desktop\MCShield-Setup.exe
2021-10-25 20:29 - 2021-11-06 17:37 - 000000000 ____D C:\FRST
2021-10-25 19:16 - 2021-11-06 17:36 - 002312192 _____ (Farbar) C:\Users\Carlos Luna\Desktop\FRST64.exe
2021-10-24 19:45 - 2021-10-24 19:48 - 000000000 ____D C:\Users\Carlos Luna\AppData\Local\niemiro
2021-10-24 01:54 - 2021-10-24 01:54 - 002316112 _____ (niemiro) C:\Users\Carlos Luna\Desktop\SFCFix.exe
2021-10-24 01:04 - 2021-10-24 01:05 - 000000000 ____D C:\Users\Carlos Luna\Downloads\Windupdate
2021-10-24 00:28 - 2021-10-28 22:08 - 000000000 ____D C:\Users\Carlos Luna\AppData\Local\ElevatedDiagnostics
2021-10-23 23:01 - 2021-10-23 23:02 - 000000000 ____D C:\Program Files\TEST
2021-10-23 21:43 - 2021-10-23 21:43 - 000000000 ____D C:\Users\Carlos Luna\AppData\Local\EOSUserHelper
2021-10-23 21:42 - 2021-10-23 21:42 - 000000000 ____D C:\Users\Carlos Luna\AppData\Local\Epic Games
2021-10-23 21:30 - 2021-10-23 21:30 - 000000000 ____D C:\Users\Default\AppData\Local\Epic Games
2021-10-21 20:11 - 2021-10-21 20:19 - 000000000 ____D C:\Users\Carlos Luna\Downloads\backups
2021-10-21 18:01 - 2021-10-21 18:01 - 000000000 ____D C:\Users\Carlos Luna\AppData\Local\CEF
2021-10-19 12:08 - 2021-10-19 12:08 - 000004352 _____ C:\Windows\system32\Tasks\Opera GX scheduled assistant Autoupdate 1634663272
2021-10-14 14:58 - 2021-11-04 15:49 - 000004100 _____ C:\Windows\system32\Tasks\Opera GX scheduled Autoupdate 1634241479
2021-10-14 14:58 - 2021-10-14 14:58 - 000001437 _____ C:\Users\Carlos Luna\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Opera GX Browser.lnk
2021-10-12 02:37 - 2021-10-12 02:37 - 000001085 _____ C:\Users\Carlos Luna\Desktop\Windows Media Player.lnk
2021-10-11 02:36 - 2021-10-11 02:36 - 000001345 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Media Center.lnk
2021-10-11 02:35 - 2021-10-11 02:35 - 000000000 ____D C:\Users\Default\AppData\Roaming\Media Center Programs
2021-10-08 16:24 - 2021-10-08 16:24 - 000000000 ____D C:\.android
2021-10-08 04:10 - 2021-10-08 04:10 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Project64 2.3
2021-10-08 04:10 - 2021-10-08 04:10 - 000000000 ____D C:\Program Files (x86)\Project64 3.0
2021-09-27 15:15 - 2021-09-27 20:37 - 000000000 ____D C:\Users\Carlos Luna\AppData\Local\GUI
2021-09-26 13:30 - 2021-11-05 21:17 - 000000000 ____D C:\ProgramData\BlueStacks_nxt
2021-09-26 13:30 - 2021-09-27 18:10 - 000000000 ____D C:\Program Files\BlueStacks_nxt
2021-09-26 13:26 - 2021-09-26 13:26 - 001168608 _____ (BlueStack Systems Inc.) C:\Users\Carlos Luna\Downloads\BlueStacksMicroInstaller_5.3.70.1004_native.exe
2021-08-30 00:49 - 2021-10-10 23:03 - 000000995 _____ C:\Users\Carlos Luna\Desktop\Genshin Impact.lnk
==================== Three months (modified) ==================
2021-11-06 17:32 - 2020-07-17 23:22 - 000000000 ____D C:\ProgramData\NVIDIA
2021-11-06 17:31 - 2009-07-14 00:08 - 000000006 ____H C:\Windows\Tasks\SA.DAT
2021-11-06 17:30 - 2009-07-13 23:45 - 000023936 ____H C:\Windows\system32\7B296FB0-376B-497e-B012-9C450E1B7327-5P-1.C7483456-A289-439d-8115-601632D005A0
2021-11-06 17:30 - 2009-07-13 23:45 - 000023936 ____H C:\Windows\system32\7B296FB0-376B-497e-B012-9C450E1B7327-5P-0.C7483456-A289-439d-8115-601632D005A0
2021-11-06 17:22 - 2014-07-04 16:56 - 000000000 ____D C:\Users\Carlos Luna\AppData\Local\Adobe
2021-11-06 01:09 - 2014-06-22 19:37 - 000000000 ____D C:\Program Files (x86)\Steam
2021-11-05 23:07 - 2020-10-21 01:14 - 000000000 ____D C:\Program Files\Genshin Impact
2021-11-05 22:16 - 2017-05-05 20:31 - 000000000 ____D C:\Users\Carlos Luna\AppData\Roaming\discord
2021-11-05 22:16 - 2017-05-05 20:30 - 000000000 ____D C:\Users\Carlos Luna\AppData\Local\Discord
2021-11-05 19:40 - 2018-08-09 13:33 - 000000000 ____D C:\Users\Carlos Luna\Documents\Carlos
2021-11-04 15:05 - 2020-01-20 18:10 - 000000000 ____D C:\Windows\system32\Tasks\MEGA
2021-11-04 15:05 - 2009-07-13 22:20 - 000000000 ___HD C:\Windows\system32\GroupPolicy
2021-11-04 15:05 - 2009-07-13 22:20 - 000000000 ____D C:\Windows\SysWOW64\GroupPolicy
2021-11-03 20:03 - 2009-07-13 22:20 - 000000000 ____D C:\Windows\inf
2021-11-03 19:59 - 2016-04-14 00:33 - 000000000 ____D C:\Windows\pss
2021-11-03 10:11 - 2015-04-19 18:58 - 000007630 _____ C:\Users\Carlos Luna\AppData\Local\Resmon.ResmonCfg
2021-11-02 18:52 - 2020-03-13 03:31 - 000000000 ____D C:\Users\Carlos Luna\AppData\Roaming\Sun
2021-11-02 18:52 - 2014-05-10 22:18 - 000000000 ____D C:\Program Files\Java
2021-11-02 18:47 - 2014-03-12 19:31 - 000000000 ____D C:\Windows\system32\Macromed
2021-11-02 18:47 - 2014-03-12 19:26 - 000000000 ____D C:\Windows\SysWOW64\Macromed
2021-11-01 20:53 - 2016-06-08 15:05 - 000000000 ____D C:\Users\Carlos Luna\AppData\Roaming\.minecraft
2021-10-30 17:55 - 2014-08-07 03:52 - 000000132 _____ C:\Users\Carlos Luna\AppData\Roaming\Prefs. de formato PNG de Adobe CS6
2021-10-28 18:29 - 2020-03-22 18:03 - 000689126 _____ C:\Windows\system32\perfh007.dat
2021-10-28 18:29 - 2020-03-22 18:03 - 000149098 _____ C:\Windows\system32\perfc007.dat
2021-10-28 18:29 - 2014-03-12 20:39 - 000745504 _____ C:\Windows\system32\perfh00A.dat
2021-10-28 18:29 - 2014-03-12 20:39 - 000158582 _____ C:\Windows\system32\perfc00A.dat
2021-10-28 18:29 - 2009-07-14 00:13 - 002514704 _____ C:\Windows\system32\PerfStringBackup.INI
2021-10-28 18:28 - 2018-08-09 13:46 - 000000000 ____D C:\Users\Carlos Luna\Documents\Hermanos
2021-10-25 19:58 - 2014-04-11 01:54 - 000000000 ____D C:\Users\Carlos Luna\Documents\My Games
2021-10-24 00:28 - 2009-07-13 22:20 - 000000000 ____D C:\Windows\system32\NDF
2021-10-23 02:22 - 2021-08-02 01:56 - 000000000 ____D C:\Users\Carlos Luna\AppData\Roaming\vlc
2021-10-21 02:15 - 2014-03-12 19:32 - 000000000 ____D C:\Users\Carlos Luna\AppData\Roaming\Adobe
2021-10-21 02:04 - 2021-03-11 21:40 - 000000000 ____D C:\Users\Carlos Luna\AppData\Local\Opera Software
2021-10-21 01:46 - 2015-10-24 19:03 - 000000000 ____D C:\Users\Carlos Luna\Downloads\Series
2021-10-20 23:09 - 2014-04-19 03:42 - 000000000 ____D C:\Program Files (x86)\Adobe
2021-10-20 16:10 - 2009-01-01 01:05 - 000000000 ___RD C:\Program Files (x86)\ASUS
2021-10-19 05:17 - 2009-01-01 00:26 - 000154328 _____ C:\Users\Carlos Luna\AppData\Local\GDIPFONTCACHEV1.DAT
2021-10-19 02:57 - 2009-07-13 23:45 - 005165616 _____ C:\Windows\system32\FNTCACHE.DAT
2021-10-19 02:07 - 2016-06-08 15:04 - 000000000 ____D C:\Program Files (x86)\Minecraft
2021-10-19 02:06 - 2014-04-19 03:17 - 000000000 ____D C:\ProgramData\Adobe
2021-10-19 02:03 - 2015-02-16 14:11 - 000000000 ____D C:\Program Files (x86)\Java
2021-10-18 22:24 - 2019-02-06 20:46 - 000000000 ____D C:\Windows\system32\DAX2
2021-10-18 22:23 - 2021-05-01 02:22 - 000000000 ____D C:\Windows\SysWOW64\RTCOM
2021-10-18 22:05 - 2015-10-24 19:03 - 000000000 ____D C:\Users\Carlos Luna\Downloads\Archives
2021-10-18 22:02 - 2014-03-12 20:50 - 000000000 ____D C:\Windows\system32\Tasks\Games
2021-10-18 14:41 - 2009-07-13 22:20 - 000000000 ____D C:\Windows\rescache
2021-10-14 14:56 - 2016-01-14 23:46 - 000000000 ____D C:\Users\Carlos Luna\AppData\Roaming\Opera Software
2021-10-12 00:06 - 2009-01-01 03:16 - 000000000 ____D C:\Windows\Panther
2021-10-11 02:35 - 2009-07-14 02:45 - 000000000 ___RD C:\Users\Public\Recorded TV
2021-10-11 02:14 - 2009-07-13 22:20 - 000000000 ____D C:\Windows\PolicyDefinitions
2021-10-10 23:03 - 2020-10-21 01:14 - 000000000 ____D C:\Users\Carlos Luna\AppData\Local\miHoYo
2021-10-10 23:03 - 2020-10-21 01:14 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Genshin Impact
2021-10-10 13:31 - 2014-03-12 20:50 - 000018960 _____ (Logitech, Inc.) C:\Windows\system32\Drivers\LNonPnP.sys
2021-10-10 01:13 - 2009-07-14 00:08 - 000032640 _____ C:\Windows\Tasks\SCHEDLGU.TXT
2021-10-08 03:55 - 2015-01-14 14:34 - 000000000 ____D C:\Users\Carlos Luna\Downloads\Zips
==================== Files in the root of some directories ========
2014-10-07 03:30 - 2016-03-28 23:20 - 000000132 _____ () C:\Users\Carlos Luna\AppData\Roaming\Prefs. de formato OpenEXR de Adobe CS6
2014-08-07 03:52 - 2021-10-30 17:55 - 000000132 _____ () C:\Users\Carlos Luna\AppData\Roaming\Prefs. de formato PNG de Adobe CS6
2016-02-15 18:17 - 2017-09-18 11:15 - 002447075 _____ () C:\Users\Carlos Luna\AppData\Roaming\PS13_panel.log
2020-06-26 00:10 - 2020-06-26 00:10 - 000000045 _____ () C:\Users\Carlos Luna\AppData\Roaming\WB.CFG
2016-08-03 21:50 - 2017-09-17 09:56 - 000001456 _____ () C:\Users\Carlos Luna\AppData\Local\Adobe Guardar para Web 13.0 Prefs
2021-01-10 12:03 - 2021-01-10 12:04 - 000000774 _____ () C:\Users\Carlos Luna\AppData\Local\install_info.txt
2015-08-07 11:17 - 2015-08-07 11:17 - 013545694 _____ () C:\Users\Carlos Luna\AppData\Local\package.nw.new
2018-08-31 01:09 - 2018-12-29 02:20 - 000000600 _____ () C:\Users\Carlos Luna\AppData\Local\PUTTY.RND
2015-04-19 18:58 - 2021-11-03 10:11 - 000007630 _____ () C:\Users\Carlos Luna\AppData\Local\Resmon.ResmonCfg
2019-10-18 02:55 - 2020-07-25 01:51 - 000000077 _____ () C:\Users\Carlos Luna\AppData\Local\update_progress.txt
2019-12-06 23:13 - 2019-12-06 23:13 - 000017408 _____ () C:\Users\Carlos Luna\AppData\Local\WebpageIcons.db
==================== SigCheck ============================
==================== End of FRST.txt ========================
Addition log:
Additional scan result of Farbar Recovery Scan Tool (x64) Version: 06-11-2021
Ran by Carlos Luna (06-11-2021 17:37:54)
Running from C:\Users\Carlos Luna\Desktop
Microsoft Windows 7 Ultimate Service Pack 1 (X64) (2009-01-01 05:23:52)
Boot Mode: Normal
Administrator (S-1-5-21-2305226654-651215044-733858041-500 - Administrator - Disabled)
Carlos Luna (S-1-5-21-2305226654-651215044-733858041-1000 - Administrator - Enabled) => C:\Users\Carlos Luna
Guest (S-1-5-21-2305226654-651215044-733858041-501 - Limited - Enabled)
HomeGroupUser$ (S-1-5-21-2305226654-651215044-733858041-1005 - Limited - Enabled)
AS: Windows Defender (Enabled - Out of date) {D68DDC3A-831F-4fae-9E44-DA132C1ACF46}
7-Zip 19.00 (x64 edition) (HKLM\...\{23170F69-40C1-2702-1900-000001000000}) (Version: 19.00.00.0 - Igor Pavlov)
Action! (HKLM-x32\...\Mirillis Action!) (Version: 3.9.6 - Mirillis)
Autodesk Maya 2015 SP2 (HKLM\...\Autodesk Maya 2015 SP2) (Version: 15.2.1633.0 - Autodesk)
Autodesk Maya 2016 SP1 (HKLM\...\Autodesk Maya 2016 SP1) (Version: 16.6.2775.0 - Autodesk) Hidden
Autodesk Maya 2016 SP2 (HKLM\...\Autodesk Maya 2016 SP2) (Version: 16.6.2775.0 - Autodesk) Hidden
Autodesk Maya 2016 SP3 (HKLM\...\Autodesk Maya 2016 SP3) (Version: 16.6.2775.0 - Autodesk) Hidden
Autodesk Maya 2016 SP3P02 (HKLM\...\Autodesk Maya 2016 SP3P02) (Version: 16.6.2775.0 - Autodesk) Hidden
Autodesk Maya 2016 SP4 (HKLM\...\Autodesk Maya 2016 SP4) (Version: 16.6.2775.0 - Autodesk) Hidden
Autodesk Maya 2016 SP4P04 (HKLM\...\Autodesk Maya 2016 SP4P04) (Version: 16.6.2775.0 - Autodesk) Hidden
Autodesk Maya 2016 SP4P05 (HKLM\...\Autodesk Maya 2016 SP4P05) (Version: 16.6.2775.0 - Autodesk) Hidden
Autodesk Maya 2016 SP5 (HKLM\...\Autodesk Maya 2016 SP5) (Version: 16.6.2775.0 - Autodesk) Hidden
Autodesk Maya 2016 SP5P06 (HKLM\...\Autodesk Maya 2016 SP5P06) (Version: 16.6.2775.0 - Autodesk) Hidden
Autodesk Maya 2016 SP5P07 (HKLM\...\Autodesk Maya 2016 SP5P07) (Version: 16.6.2775.0 - Autodesk) Hidden
Autodesk Maya 2016 SP5P08 (HKLM\...\Autodesk Maya 2016 SP5P08) (Version: 16.6.2775.0 - Autodesk) Hidden
Autodesk Maya 2016 SP6 (HKLM\...\Autodesk Maya 2016 SP6) (Version: 16.6.2775.0 - Autodesk)
BlueStacks 5 (HKLM\...\BlueStacks_nxt) (Version: 5.3.70.1004 - BlueStack Systems, Inc.)
CCleaner (HKLM\...\CCleaner) (Version: 4.15 - Piriform)
Corel Update Manager (HKLM\...\{9E1EE683-0C7B-46E7-83EC-1F5A1D8F2296}) (Version: 2.9.389 - Corel corporation) Hidden
CorelDRAW Graphics Suite 2017 - IPM (x64) (HKLM\...\{904B10A6-0D9C-4645-9C61-504FA92B9220}) (Version: 19.1 - Corel Corporation) Hidden
CorelDRAW Graphics Suite 2017 - IPM Content (x64) (HKLM\...\{54F024CB-16AF-4CC0-9BC2-D2507E7C6C01}) (Version: 19.0 - Corel Corporation) Hidden
CorelDRAW Graphics Suite 2017 - Writing Tools (x64) (HKLM\...\{E38357D4-1B80-400F-A6D7-B4D5DD83D979}) (Version: 19.1 - Corel Corporation) Hidden
CrystalDiskInfo 7.6.1 (HKLM-x32\...\CrystalDiskInfo_is1) (Version: 7.6.1 - Crystal Dew World)
Discord (HKU\S-1-5-21-2305226654-651215044-733858041-1000\...\Discord) (Version: 0.0.309 - Discord Inc.)
Epic Games Launcher (HKLM-x32\...\{8CAF0391-512D-485C-B141-39D89E7EDCA8}) (Version: 1.2.17.0 - Epic Games, Inc.)
Epic Games Launcher Prerequisites (x64) (HKLM\...\{F9C5C994-F6B9-4D75-B3E7-AD01B84073E9}) (Version: 1.0.0.0 - Epic Games, Inc.) Hidden
Epic Online Services (HKLM-x32\...\{32C68D93-D32F-4B01-8250-61642BFC22F8}) (Version: 2.0.28.0 - Epic Games, Inc.)
Genshin Impact (HKLM\...\Genshin Impact) (Version: 2.12.1.0 - miHoYo Co.,Ltd)
Intel(R) C++ Redistributables for Windows* on Intel(R) 64 (HKLM-x32\...\{D2437C5C-2D8C-40D2-8059-689AD7239FA3}) (Version: 11.1.048 - Intel Corporation)
Intel(R) Management Engine Components (HKLM-x32\...\{65153EA5-8B6E-43B6-857B-C6E4FC25798A}) (Version: 9.5.15.1730 - Intel Corporation)
Intel(R) USB 3.0 eXtensible Host Controller Driver (HKLM-x32\...\{240C3DDD-C5E9-4029-9DF7-95650D040CF2}) (Version: 2.5.0.19 - Intel Corporation)
Intel® Hardware Accelerated Execution Manager (HKLM\...\{557D160E-2085-4D38-BDA3-1D5D3F74A3A4}) (Version: 6.0.4 - Intel Corporation)
Launcher Prerequisites (x64) (HKLM-x32\...\{43a03b9c-4770-409c-a999-587b60700b63}) (Version: 1.0.0.0 - Epic Games, Inc.) Hidden
Launcher Prerequisites (x64) (HKLM-x32\...\{c6c5a357-c7ca-4a5f-9789-3bb1af579253}) (Version: 1.0.0.0 - Epic Games, Inc.) Hidden
Malwarebytes version 4.4.10.144 (HKLM\...\{35065F43-4BB2-439A-BFF7-0F1014F2E0CD}_is1) (Version: 4.4.10.144 - Malwarebytes)
MCShield ::Anti-Malware Tool:: (HKLM-x32\...\MCShield) (Version: 3.0.5.28 - MyCity)
Microsoft .NET Framework 4.8 (Deutsch) (HKLM\...\{92FB6C44-E685-45AD-9B20-CADF4CABA132} - 1031) (Version: 4.8.03761 - Microsoft Corporation)
Microsoft .NET Framework 4.8 (español) (HKLM\...\{92FB6C44-E685-45AD-9B20-CADF4CABA132} - 3082) (Version: 4.8.03761 - Microsoft Corporation)
Microsoft .NET Framework 4.8 (HKLM\...\{92FB6C44-E685-45AD-9B20-CADF4CABA132} - 1033) (Version: 4.8.03761 - Microsoft Corporation)
Microsoft Mouse and Keyboard Center (HKLM\...\Microsoft Mouse and Keyboard Center) (Version: 2.8.106.0 - Microsoft Corporation)
Microsoft Office 2010 Service Pack 1 (SP1) (HKLM-x32\...\{90140000-0011-0000-0000-0000000FF1CE}_Office14.PROPLUS_{047B0968-E622-4FAA-9B4B-121FA109EDDE}) (Version: - Microsoft)
Microsoft Office Professional Plus 2010 (HKLM-x32\...\Office14.PROPLUS) (Version: 14.0.6029.1000 - Microsoft Corporation)
Microsoft Research Mesh Virtual WIFI (HKLM-x32\...\{034A32D5-699E-4AED-A2EB-2CCB6E7F37F1}) (Version: 1.0.000 - Microsoft Research)
Microsoft Visual C++ 2005 Redistributable (HKLM-x32\...\{710f4c1c-cc18-4c49-8cbf-51240c89a1a2}) (Version: 8.0.61001 - Microsoft Corporation)
Microsoft Visual C++ 2005 Redistributable (HKLM-x32\...\{7299052b-02a4-4627-81f2-1818da5d550d}) (Version: 8.0.56336 - Microsoft Corporation)
Microsoft Visual C++ 2005 Redistributable (HKLM-x32\...\{837b34e3-7c30-493c-8f6a-2b0f04e2912c}) (Version: 8.0.59193 - Microsoft Corporation)
Microsoft Visual C++ 2005 Redistributable (x64) (HKLM\...\{6ce5bae9-d3ca-4b99-891a-1dc6c118a5fc}) (Version: 8.0.59192 - Microsoft Corporation)
Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.17 (HKLM\...\{8220EEFE-38CD-377E-8595-13398D740ACE}) (Version: 9.0.30729 - Microsoft Corporation)
Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.4148 (HKLM\...\{4B6C7001-C7D6-3710-913E-5BC23FCE91E6}) (Version: 9.0.30729.4148 - Microsoft Corporation)
Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.6161 (HKLM\...\{5FCE6D76-F5DC-37AB-B2B8-22AB8CEDB1D4}) (Version: 9.0.30729.6161 - Microsoft Corporation)
Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.4148 (HKLM-x32\...\{1F1C2DFC-2D24-3E06-BCB8-725134ADF989}) (Version: 9.0.30729.4148 - Microsoft Corporation)
Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.6161 (HKLM-x32\...\{9BE518E6-ECC6-35A9-88E4-87755C07200F}) (Version: 9.0.30729.6161 - Microsoft Corporation)
Microsoft Visual C++ 2012 Redistributable (x64) - 11.0.61030 (HKLM-x32\...\{ca67548a-5ebe-413a-b50c-4b9ceb6d66c6}) (Version: 11.0.61030.0 - Microsoft Corporation)
Microsoft Visual C++ 2013 Redistributable (x64) - 12.0.30501 (HKLM-x32\...\{050d4fc8-5d48-4b8f-8972-47c82c46020f}) (Version: 12.0.30501.0 - Microsoft Corporation)
Microsoft Visual C++ 2013 Redistributable (x64) - 12.0.30501 (HKLM-x32\...\{1b103cea-f037-4504-81de-956057b442c3}) (Version: 12.0.30501.0 - Microsoft Corporation)
Microsoft Visual C++ 2013 Redistributable (x86) - 12.0.30501 (HKLM-x32\...\{f65db027-aff3-4070-886a-0d87064aabb1}) (Version: 12.0.30501.0 - Microsoft Corporation)
Microsoft Visual C++ 2015-2019 Redistributable (x64) - 14.28.29334 (HKLM-x32\...\{a9cfe9c7-e54f-46cd-9c5c-542ff8e3e8c4}) (Version: 14.28.29334.0 - Microsoft Corporation)
Microsoft Visual C++ 2015-2019 Redistributable (x86) - 14.28.29334 (HKLM-x32\...\{b2d0f752-adc5-496e-8f70-8669de01f746}) (Version: 14.28.29334.0 - Microsoft Corporation)
Microsoft Visual Studio Tools for Applications 2012 (HKLM-x32\...\{89ca2a32-2b52-4595-8dfd-6fe4757958d0}) (Version: 11.0.51108 - Microsoft Corporation)
Microsoft Visual Studio Tools for Applications 2015 (HKLM-x32\...\{dd8b09df-3ef8-49f1-bd1a-65278435860b}) (Version: 14.0.23217 - Microsoft Corporation)
Minecraft Launcher (HKLM-x32\...\{810F1419-7760-402E-8772-B4054FAA2B72}) (Version: 1.0.0.0 - Mojang)
MSI Afterburner 4.6.2 (HKLM-x32\...\Afterburner) (Version: 4.6.2 - MSI Co., LTD)
NVIDIA Graphics Driver 451.67 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.Driver) (Version: 451.67 - NVIDIA Corporation)
NVIDIA HD Audio Driver 1.3.38.34 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_HDAudio.Driver) (Version: 1.3.38.34 - NVIDIA Corporation)
NVIDIA PhysX System Software 9.19.0218 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.PhysX) (Version: 9.19.0218 - NVIDIA Corporation)
Opera GX Stable 80.0.4170.91 (HKU\S-1-5-21-2305226654-651215044-733858041-1000\...\Opera GX 80.0.4170.91) (Version: 80.0.4170.91 - Opera Software)
Pacote de Idiomas do Microsoft Visual Studio Tools for Applications 2012 x64 Hosting Support - PTB (HKLM\...\{E237254B-36A1-3D27-815E-B37C13BE0796}) (Version: 11.0.51108 - Microsoft Corporation) Hidden
Pacote de Idiomas do Microsoft Visual Studio Tools for Applications 2012 x86 Hosting Support - PTB (HKLM-x32\...\{03077B58-6ACF-32CA-B42A-EAA458C295A1}) (Version: 11.0.51108 - Microsoft Corporation) Hidden
Project64 version 3.0.1.5664 (HKLM-x32\...\{BEB5FB69-4080-466F-96C4-F15DF271718B}_is1) (Version: 3.0.1.5664 - )
Realtek Ethernet Controller Driver (HKLM-x32\...\{8833FFB6-5B0C-4764-81AA-06DFEED9A476}) (Version: 7.67.1226.2012 - Realtek)
Realtek Ethernet Diagnostic Utility (HKLM-x32\...\{DADC7AB0-E554-4705-9F6A-83EA82ED708E}) (Version: 2.0.2.7 - Realtek)
Realtek High Definition Audio Driver (HKLM-x32\...\{F132AF7F-7BCA-4EDE-8A7C-958108FE7DBC}) (Version: 6.0.1.7982 - Realtek Semiconductor Corp.)
UE4 Prerequisites (x86) (HKLM-x32\...\{6EAAE1C0-6000-45FA-B46D-D206144925BF}) (Version: 1.0.11.0 - Epic Games, Inc.) Hidden
UE4 Prerequisites (x86) (HKLM-x32\...\{f1203e43-4ddb-4280-974e-73f14d793dbd}) (Version: 1.0.13.0 - Epic Games, Inc.) Hidden
WO Mic Client (HKLM-x32\...\WOMic) (Version: - )
Языковой пакет для поддержки размещения набора средств Microsoft Visual Studio Tools для работы с приложениями 2012 (x64) - RUS (HKLM\...\{25FB53C5-BE4C-3B6C-A0C9-D49A39227E1E}) (Version: 11.0.51108 - Microsoft Corporation) Hidden
Языковой пакет для поддержки размещения набора средств Microsoft Visual Studio Tools для работы с приложениями 2012 (x86) - RUS (HKLM-x32\...\{68DC347D-C1C0-3DE2-A53E-CCC71DA53E57}) (Version: 11.0.51108 - Microsoft Corporation) Hidden
==================== Custom CLSID (Whitelisted): ==============
CustomCLSID: HKU\S-1-5-21-2305226654-651215044-733858041-1000_Classes\CLSID\{00020420-0000-0000-C000-000000000046}\InprocServer32 -> C:\Windows\system32\oleaut32.dll (Microsoft Windows -> Microsoft Corporation)
CustomCLSID: HKU\S-1-5-21-2305226654-651215044-733858041-1000_Classes\CLSID\{00020421-0000-0000-C000-000000000046}\InprocServer32 -> C:\Windows\system32\oleaut32.dll (Microsoft Windows -> Microsoft Corporation)
CustomCLSID: HKU\S-1-5-21-2305226654-651215044-733858041-1000_Classes\CLSID\{00020422-0000-0000-C000-000000000046}\InprocServer32 -> C:\Windows\system32\oleaut32.dll (Microsoft Windows -> Microsoft Corporation)
CustomCLSID: HKU\S-1-5-21-2305226654-651215044-733858041-1000_Classes\CLSID\{00020423-0000-0000-C000-000000000046}\InprocServer32 -> C:\Windows\system32\oleaut32.dll (Microsoft Windows -> Microsoft Corporation)
CustomCLSID: HKU\S-1-5-21-2305226654-651215044-733858041-1000_Classes\CLSID\{00020424-0000-0000-C000-000000000046}\InprocServer32 -> C:\Windows\system32\oleaut32.dll (Microsoft Windows -> Microsoft Corporation)
CustomCLSID: HKU\S-1-5-21-2305226654-651215044-733858041-1000_Classes\CLSID\{00020425-0000-0000-C000-000000000046}\InprocServer32 -> C:\Windows\system32\oleaut32.dll (Microsoft Windows -> Microsoft Corporation)
ShellExecuteHooks: Groove GFS Stub Execution Hook - {B5A7F190-DDA6-4420-B3BA-52453494E6CD} - C:\Program Files\Microsoft Office\Office14\GROOVEEX.DLL [6718864 2011-02-12] (Microsoft Corporation -> Microsoft Corporation)
ShellExecuteHooks-x32: Groove GFS Stub Execution Hook - {B5A7F190-DDA6-4420-B3BA-52453494E6CD} - C:\Program Files (x86)\Microsoft Office\Office14\GROOVEEX.DLL [4220304 2011-02-12] (Microsoft Corporation -> Microsoft Corporation)
ContextMenuHandlers1: [7-Zip] -> {23170F69-40C1-278A-1000-000100020000} => C:\Program Files\7-Zip\7-zip.dll [2019-02-21] (Igor Pavlov) [File not signed]
ContextMenuHandlers1-x32: [WinRAR] -> {B41DB860-8EE4-11D2-9906-E49FADC173CA} => C:\Program Files (x86)\WinRAR\rarext.dll [2004-12-26] () [File not signed]
ContextMenuHandlers3: [MBAMShlExt] -> {57CE581A-0CB6-4266-9CA0-19364C90A0B3} => C:\Program Files\Malwarebytes\Anti-Malware\mbshlext.dll [2021-11-05] (Malwarebytes Corporation -> Malwarebytes)
ContextMenuHandlers4: [7-Zip] -> {23170F69-40C1-278A-1000-000100020000} => C:\Program Files\7-Zip\7-zip.dll [2019-02-21] (Igor Pavlov) [File not signed]
ContextMenuHandlers4-x32: [WinRAR] -> {B41DB860-8EE4-11D2-9906-E49FADC173CA} => C:\Program Files (x86)\WinRAR\rarext.dll [2004-12-26] () [File not signed]
ContextMenuHandlers5: [NvCplDesktopContext] -> {3D1975AF-48C6-4f8e-A182-BE0E08FA86A9} => C:\Windows\system32\nvshext.dll [2020-07-05] (NVIDIA Corporation -> NVIDIA Corporation)
ContextMenuHandlers6: [7-Zip] -> {23170F69-40C1-278A-1000-000100020000} => C:\Program Files\7-Zip\7-zip.dll [2019-02-21] (Igor Pavlov) [File not signed]
ContextMenuHandlers6: [MBAMShlExt] -> {57CE581A-0CB6-4266-9CA0-19364C90A0B3} => C:\Program Files\Malwarebytes\Anti-Malware\mbshlext.dll [2021-11-05] (Malwarebytes Corporation -> Malwarebytes)
ContextMenuHandlers6-x32: [WinRAR] -> {B41DB860-8EE4-11D2-9906-E49FADC173CA} => C:\Program Files (x86)\WinRAR\rarext.dll [2004-12-26] () [File not signed]
==================== Codecs (Whitelisted) ====================
HKLM\...\Drivers32: [VIDC.FICV] => C:\Windows\system32\ficvdec_x64.dll [652288 2013-05-28] () [File not signed]
HKLM\...\Drivers32: [VIDC.FICV] => C:\Windows\SysWOW64\ficvdec_x86.dll [641024 2013-05-28] () [File not signed]
==================== Shortcuts & WMI ========================
==================== Loaded Modules (Whitelisted) =============
2009-01-01 01:06 - 2021-11-06 17:31 - 000034448 _____ (ASUSTeK Computer Inc. -> ) [File not signed] C:\Program Files (x86)\ASUS\AXSP\1.01.01\PEbiosinterface32.dll
2019-02-21 21:00 - 2019-02-21 21:00 - 000078336 _____ (Igor Pavlov) [File not signed] C:\Program Files\7-Zip\7-zip.dll
2021-05-01 02:09 - 2013-04-26 10:24 - 000073728 _____ (Intel Corporation) [File not signed] C:\Program Files (x86)\Intel\Intel(R) USB 3.0 eXtensible Host Controller Driver\Application\iusb3mon.dll
2014-02-27 17:43 - 2014-02-27 17:43 - 000173568 _____ (Nokia Corporation and/or its subsidiary(-ies)) [File not signed] C:\Program Files\Logitech Gaming Software\imageformats\qjpeg4.dll
2014-02-27 17:43 - 2014-02-27 17:43 - 001807360 _____ (Nokia Corporation and/or its subsidiary(-ies)) [File not signed] C:\Program Files\Logitech Gaming Software\QtCLucene4.dll
2014-02-27 17:43 - 2014-02-27 17:43 - 003276288 _____ (Nokia Corporation and/or its subsidiary(-ies)) [File not signed] C:\Program Files\Logitech Gaming Software\QtCore4.dll
2014-02-27 17:43 - 2014-02-27 17:43 - 012168192 _____ (Nokia Corporation and/or its subsidiary(-ies)) [File not signed] C:\Program Files\Logitech Gaming Software\QtGui4.dll
2014-02-27 17:43 - 2014-02-27 17:43 - 000750080 _____ (Nokia Corporation and/or its subsidiary(-ies)) [File not signed] C:\Program Files\Logitech Gaming Software\QtHelp4.dll
2014-02-27 17:43 - 2014-02-27 17:43 - 001085952 _____ (Nokia Corporation and/or its subsidiary(-ies)) [File not signed] C:\Program Files\Logitech Gaming Software\QtNetwork4.dll
2014-02-27 17:43 - 2014-02-27 17:43 - 000841728 _____ (Nokia Corporation and/or its subsidiary(-ies)) [File not signed] C:\Program Files\Logitech Gaming Software\QtOpenGL4.dll
2014-02-27 17:43 - 2014-02-27 17:43 - 001990144 _____ (Nokia Corporation and/or its subsidiary(-ies)) [File not signed] C:\Program Files\Logitech Gaming Software\QtScript4.dll
2014-02-27 17:43 - 2014-02-27 17:43 - 000897024 _____ (Nokia Corporation and/or its subsidiary(-ies)) [File not signed] C:\Program Files\Logitech Gaming Software\QtSql4.dll
2014-02-27 17:43 - 2014-02-27 17:43 - 000539136 _____ (Nokia Corporation and/or its subsidiary(-ies)) [File not signed] C:\Program Files\Logitech Gaming Software\QtXml4.dll
==================== Alternate Data Streams (Whitelisted) ========
==================== Safe Mode (Whitelisted) ==================
(If an entry is included in the fixlist, it will be removed from the registry. The "AlternateShell" will be restored.)
HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\MBAMService => ""="Service"
HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\MBAMService => ""="Service"
==================== Association (Whitelisted) =================
==================== Internet Explorer (Version 11) (Whitelisted) ==========
HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = www.google.com
HKU\S-1-5-21-2305226654-651215044-733858041-1000\Software\Microsoft\Internet Explorer\Main,Start Page Redirect Cache = hxxp://latam.msn.com/?ocid=iehp
SearchScopes: HKLM -> DefaultScope {0633EE93-D776-472f-A0FF-E1416B8B2E3A} URL = hxxps://www.bing.com/search?q={searchTerms}&FORM=IE8SRC/f
SearchScopes: HKLM -> {0633EE93-D776-472f-A0FF-E1416B8B2E3A} URL = hxxps://www.bing.com/search?q={searchTerms}&FORM=IE8SRC/f
SearchScopes: HKLM-x32 -> DefaultScope {632F07F3-19A1-4d16-A23F-E6CE9486BAB5} URL =
SearchScopes: HKLM-x32 -> {0633EE93-D776-472f-A0FF-E1416B8B2E3A} URL = hxxps://www.bing.com/search?q={searchTerms}&FORM=IE8SRC/f
BHO: Groove GFS Browser Helper -> {72853161-30C5-4D22-B7F9-0BBC1D38A37E} -> C:\Program Files\Microsoft Office\Office14\GROOVEEX.DLL [2011-02-12] (Microsoft Corporation -> Microsoft Corporation)
BHO: Office Document Cache Handler -> {B4F3A835-0E21-4959-BA22-42B3008E02FF} -> C:\Program Files\Microsoft Office\Office14\URLREDIR.DLL [2010-12-21] (Microsoft Corporation -> Microsoft Corporation)
BHO-x32: Office Document Cache Handler -> {B4F3A835-0E21-4959-BA22-42B3008E02FF} -> C:\Program Files (x86)\Microsoft Office\Office14\URLREDIR.DLL [2010-12-21] (Microsoft Corporation -> Microsoft Corporation)
==================== Hosts content: =========================
2021-10-18 22:12 - 2021-10-18 22:12 - 000000833 ____R C:\Windows\system32\drivers\etc\hosts
==================== Other Areas ===========================
HKLM\System\CurrentControlSet\Control\Session Manager\Environment\\Path -> C:\Program Files (x86)\Intel\iCLS Client\;C:\Program Files\Intel\iCLS Client\;C:\Program Files (x86)\Common Files\Intel\Shared Files\cpp\bin\Intel64;C:\ProgramData\Oracle\Java\javapath;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\Autodesk\Backburner\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR;C:\Program Files\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT
HKU\S-1-5-21-2305226654-651215044-733858041-1000\Control Panel\Desktop\\Wallpaper -> C:\Users\Carlos Luna\AppData\Roaming\Microsoft\Windows\Themes\TranscodedWallpaper.jpg
DNS Servers: 200.48.225.146 - 200.48.225.130
Windows Firewall is enabled.
MSCONFIG\Services: ACTION_SVC => 3
MSCONFIG\Services: AdAppMgrSvc => 2
MSCONFIG\Services: GfExperienceService => 2
MSCONFIG\Services: NvNetworkService => 2
MSCONFIG\Services: NvStreamNetworkSvc => 3
MSCONFIG\Services: NvStreamSvc => 2
MSCONFIG\Services: nvsvc => 2
MSCONFIG\Services: Stereo Service => 2
==================== FirewallRules (Whitelisted) ================
FirewallRules: [TCP Query User{5CB41C60-5184-4DE4-97E7-47A8CE3C61C2}C:\program files (x86)\womic\womicclient.exe] => (Allow) C:\program files (x86)\womic\womicclient.exe () [File not signed]
FirewallRules: [UDP Query User{C4B58CE0-9B62-4529-B69B-189EF82CB167}C:\program files (x86)\womic\womicclient.exe] => (Allow) C:\program files (x86)\womic\womicclient.exe () [File not signed]
FirewallRules: [TCP Query User{53066240-262C-4D89-AD40-374FC9C37118}C:\users\carlos luna\appdata\local\programs\opera gx\opera.exe] => (Allow) C:\users\carlos luna\appdata\local\programs\opera gx\opera.exe (Opera Software AS -> Opera Software)
FirewallRules: [UDP Query User{4FE1146C-6B94-4A3F-B3B9-03B3D4234638}C:\users\carlos luna\appdata\local\programs\opera gx\opera.exe] => (Allow) C:\users\carlos luna\appdata\local\programs\opera gx\opera.exe (Opera Software AS -> Opera Software)
FirewallRules: [TCP Query User{DFCFD19C-91C2-40C7-946E-3EE01B712C2E}C:\program files (x86)\steam\steam.exe] => (Allow) C:\program files (x86)\steam\steam.exe (Valve -> Valve Corporation)
FirewallRules: [UDP Query User{6A80C201-3B27-4588-98EE-E01BBA7533C3}C:\program files (x86)\steam\steam.exe] => (Allow) C:\program files (x86)\steam\steam.exe (Valve -> Valve Corporation)
FirewallRules: [{36077DE1-8476-401E-8EA6-52CBF9065A7D}] => (Allow) C:\Program Files (x86)\Steam\bin\cef\cef.win7x64\steamwebhelper.exe (Valve -> Valve Corporation)
FirewallRules: [{D025ADD2-4276-4691-B046-73FA0D984488}] => (Allow) C:\Program Files (x86)\Steam\bin\cef\cef.win7x64\steamwebhelper.exe (Valve -> Valve Corporation)
FirewallRules: [TCP Query User{586D1D22-7153-4987-97D8-B77472B9AF71}C:\program files\epic games\amongus\among us.exe] => (Allow) C:\program files\epic games\amongus\among us.exe () [File not signed]
FirewallRules: [UDP Query User{CC6FE1C3-7381-4122-8B0F-95493109FF5E}C:\program files\epic games\amongus\among us.exe] => (Allow) C:\program files\epic games\amongus\among us.exe () [File not signed]
FirewallRules: [TCP Query User{5CBDF2E0-CB20-4AE0-9BA2-CE78F6BDF0AE}C:\program files\genshin impact\genshin impact game\genshinimpact.exe] => (Allow) C:\program files\genshin impact\genshin impact game\genshinimpact.exe (miHoYo Co.,Ltd. -> )
FirewallRules: [UDP Query User{985CB71C-5064-4898-8B6F-1A4B83F251E0}C:\program files\genshin impact\genshin impact game\genshinimpact.exe] => (Allow) C:\program files\genshin impact\genshin impact game\genshinimpact.exe (miHoYo Co.,Ltd. -> )
FirewallRules: [{9BCB1DAC-4A40-44C1-BA83-D5E1CF1DD096}] => (Allow) C:\Program Files (x86)\Steam\SteamApps\common\RISK Global Domination\RISK.exe () [File not signed]
FirewallRules: [{2D9C3240-87F7-414B-A498-1A6238A99B0D}] => (Allow) C:\Program Files (x86)\Steam\SteamApps\common\RISK Global Domination\RISK.exe () [File not signed]
FirewallRules: [TCP Query User{01F7E6D7-6831-4E02-AC98-14FC7C0AC9C8}C:\program files (x86)\steam\steamapps\common\left 4 dead 2\left4dead2.exe] => (Allow) C:\program files (x86)\steam\steamapps\common\left 4 dead 2\left4dead2.exe () [File not signed]
FirewallRules: [UDP Query User{53A32A65-3F71-4320-9C6C-D832023AA22C}C:\program files (x86)\steam\steamapps\common\left 4 dead 2\left4dead2.exe] => (Allow) C:\program files (x86)\steam\steamapps\common\left 4 dead 2\left4dead2.exe () [File not signed]
FirewallRules: [{0E255199-C3C4-4F02-88FD-FC94100871C9}] => (Allow) C:\Program Files (x86)\Steam\SteamApps\common\Action Taimanin\ActionTaimanin.exe () [File not signed]
FirewallRules: [{FD9C28AB-F010-407B-B017-0D6B689E01CC}] => (Allow) C:\Program Files (x86)\Steam\SteamApps\common\Action Taimanin\ActionTaimanin.exe () [File not signed]
FirewallRules: [TCP Query User{33001C23-34A2-484A-B476-E23DFAD5ABE6}C:\program files (x86)\minecraft launcher\runtime\java-runtime-alpha\windows-x64\java-runtime-alpha\bin\javaw.exe] => (Allow) C:\program files (x86)\minecraft launcher\runtime\java-runtime-alpha\windows-x64\java-runtime-alpha\bin\javaw.exe
FirewallRules: [UDP Query User{F4584F73-C6BE-4460-AAA4-1C76B08DEB29}C:\program files (x86)\minecraft launcher\runtime\java-runtime-alpha\windows-x64\java-runtime-alpha\bin\javaw.exe] => (Allow) C:\program files (x86)\minecraft launcher\runtime\java-runtime-alpha\windows-x64\java-runtime-alpha\bin\javaw.exe
FirewallRules: [{6765061F-677B-4DBE-A273-09BAC861F1ED}] => (Allow) C:\Users\Carlos Luna\AppData\Local\Programs\Opera GX\80.0.4170.86\opera.exe (Opera Software AS -> Opera Software)
FirewallRules: [{324AD36E-790D-4E4C-853C-D1E1DB37E1EE}] => (Allow) C:\Users\Carlos Luna\AppData\Local\Programs\Opera GX\80.0.4170.91\opera.exe (Opera Software AS -> Opera Software)
==================== Faulty Device Manager Devices ============
Name: SM Bus Controller
Description: SM Bus Controller
Class Guid:
Manufacturer:
Service:
Problem: : The drivers for this device are not installed. (Code 28)
Resolution: To install the drivers for this device, click "Update Driver", which starts the Hardware Update wizard.
==================== Event log errors: ========================
Application errors:
Error: (11/05/2021 08:06:29 PM) (Source: Application Error) (EventID: 1000) (User: )
Description: Faulting application name: mbamtray.exe, version: 4.0.0.1162, time stamp: 0x61783b28
Faulting module name: Qt5Core.dll, version: 5.14.1.0, time stamp: 0x603971ce
Exception code: 0xc0000005
Fault offset: 0x0000000000219dc5
Faulting process id: 0xccc
Faulting application start time: 0x01d7d2aa86888b35
Faulting application path: C:\Program Files\Malwarebytes\Anti-Malware\mbamtray.exe
Faulting module path: C:\Program Files\Malwarebytes\Anti-Malware\Qt5Core.dll
Report Id: c5321d78-3e9d-11ec-85a1-d850e63c46b2
Error: (11/05/2021 07:49:08 PM) (Source: VSS) (EventID: 8194) (User: )
Description: Volume Shadow Copy Service error: Unexpected error querying for the IVssWriterCallback interface. hr = 0x80070005, Access is denied.
This is often caused by incorrect security settings in either the writer or requestor process.
Operation:
Gathering Writer Data
Context:
Writer Class Id: {e8132975-6f93-4464-a53e-1050253ae220}
Writer Name: System Writer
Writer Instance ID: {f9c2217e-9e3d-4114-b3dc-2f49d95edd69}
System errors:
Error: (11/06/2021 05:40:59 PM) (Source: DCOM) (EventID: 10010) (User: )
Description: The server {BB6DF56B-CACE-11DC-9992-0019B93A3A84} did not register with DCOM within the required timeout.
Error: (11/06/2021 05:26:53 PM) (Source: Service Control Manager) (EventID: 7031) (User: )
Description: The Software Protection service terminated unexpectedly. It has done this 1 time(s). The following corrective action will be taken in 120000 milliseconds: Restart the service.
Description: The Windows Media Player Network Sharing Service service terminated unexpectedly. It has done this 1 time(s). The following corrective action will be taken in 30000 milliseconds: Restart the service.
Description: The Windows Modules Installer service terminated unexpectedly. It has done this 1 time(s). The following corrective action will be taken in 120000 milliseconds: Restart the service.
Error: (11/06/2021 05:26:53 PM) (Source: Service Control Manager) (EventID: 7034) (User: )
Description: The Intel(R) Dynamic Application Loader Host Interface Service service terminated unexpectedly. It has done this 1 time(s).
Description: The Intel(R) Capability Licensing Service Interface service terminated unexpectedly. It has done this 1 time(s). The following corrective action will be taken in 0 milliseconds: Restart the service.
Description: The NVIDIA Display Container LS service terminated unexpectedly. It has done this 1 time(s). The following corrective action will be taken in 6000 milliseconds: Restart the service.
Description: The ASUS Com Service service terminated unexpectedly. It has done this 1 time(s).
BIOS: American Megatrends Inc. 2003 10/15/2014
Motherboard: ASUSTeK COMPUTER INC. H87-PLUS
Processor: Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz
Percentage of memory in use: 46%
Total physical RAM: 8130.46 MB
Available physical RAM: 4350.41 MB
Total Virtual: 16259.06 MB
Available Virtual: 10378.11 MB
Drive c: () (Fixed) (Total:931.41 GB) (Free:463.61 GB) NTFS
Drive h: (CarlosLuna) (Fixed) (Total:465.76 GB) (Free:253.9 GB) NTFS
\\?\Volume{6f327824-d7c3-11dd-893f-806e6f6e6963}\ (System Reserved) (Fixed) (Total:0.1 GB) (Free:0.06 GB) NTFS
==================== MBR & Partition Table ====================
Disk: 0 (MBR Code: Windows 7/8/10) (Size: 931.5 GB) (Disk ID: 319F4949)
Partition 1: (Active) - (Size=100 MB) - (Type=07 NTFS)
Partition 2: (Not Active) - (Size=931.4 GB) - (Type=07 NTFS)
Disk: 1 (Size: 465.8 GB) (Disk ID: 844382C4)
Partition 1: (Active) - (Size=465.8 GB) - (Type=07 NTFS)
==================== End of Addition.txt =======================
Hi, Carlosh.
Things look much better now. Go on for the following fix. Hopefully, if everything goes well, we will take care of your computer's security protection.
FRST fix
Please do the following to run a FRST fix.
NOTICE: This script was written specifically for this user. Running it on another machine may cause damage to your operating system
  • Please select the entire contents of the code box below, from the "Start::" line to "End::", including both lines. Right-click and select "Copy ". No need to paste anything to anywhere.
Start::
CreateRestorePoint:
CloseProcesses:
Policies: C:\ProgramData\NTUSER.pol: Restriction <==== ATTENTION
Reg: reg add "HKLM\SOFTWARE\Microsoft\Internet Explorer\SearchScopes\{0633EE93-D776-472f-A0FF-E1416B8B2E3A}" /v URL /t REG_SZ /d "https://www.bing.com/search?q={searchTerms}&FORM=IE8SRC" /f
Reg: reg add "HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\SearchScopes\{0633EE93-D776-472f-A0FF-E1416B8B2E3A}" /v URL /t REG_SZ /d "https://www.bing.com/search?q={searchTerms}&FORM=IE8SRC" /f
Reg: reg add "HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\Environment" /v Path /t REG_EXPAND_SZ /d ^%SystemRoot^%\system32;^%SystemRoot^%;^%SystemRoot^%\System32\Wbem;^%SystemRoot^%\System32\WindowsPowerShell\v1.0\;"C:\Program Files (x86)\Intel\iCLS Client\";"C:\Program Files\Intel\iCLS Client\";"C:\Program Files (x86)\Common Files\Intel\Shared Files\cpp\bin\Intel64";"C:\Program Files (x86)\Autodesk\Backburner\";"C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common";"C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR";"C:\Program Files\Intel\Intel(R) Management Engine Components\DAL";"C:\Program Files\Intel\Intel(R) Management Engine Components\IPT";"C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL";"C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT" /f̩
CMD: DISM /Online /Cleanup-Image /RestoreHealth
CMD: SFC /scannow
EmptyTemp:
End::
  • Please right-click on FRST64 on your Desktop, to run it as administrator. When the tool opens, click "yes" to the disclaimer.
  • Press the Fix button once and wait.
  • FRST will process fixlist.txt
  • When finished, it will produce a log fixlog.txt on your Desktop.
  • Please post the log in your next reply.
Really glad to hear that and thanks for all the help until now, I really appreciate the effort that I surely couldn't do by myself.
Fixlog:
Fix result of Farbar Recovery Scan Tool (x64) Version: 07-11-2021 01
Ran by Carlos Luna (07-11-2021 19:24:44) Run:4
Loaded Profiles: Carlos Luna
Boot Mode: Normal
fixlist content:
CreateRestorePoint:
CloseProcesses:
Reg: reg add "HKLM\SOFTWARE\Microsoft\Internet Explorer\SearchScopes\{0633EE93-D776-472f-A0FF-E1416B8B2E3A}" /v URL /t REG_SZ /d "Stacking up with the best of them{searchTerms}&FORM=IE8SRC" /f
Reg: reg add "HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\SearchScopes\{0633EE93-D776-472f-A0FF-E1416B8B2E3A}" /v URL /t REG_SZ /d "Stacking up with the best of them{searchTerms}&FORM=IE8SRC" /f
CMD: SFC /scannow
EmptyTemp:
C:\ProgramData\NTUSER.pol => moved successfully
HKLM\SOFTWARE\Microsoft\Shared Tools\MSConfig\Services\ACTION_SVC => removed successfully
HKLM\System\CurrentControlSet\Services\ACTION_SVC => not found
HKLM\SOFTWARE\Microsoft\Shared Tools\MSConfig\Services\AdAppMgrSvc => removed successfully
HKLM\System\CurrentControlSet\Services\AdAppMgrSvc => not found
========= reg add "HKLM\SOFTWARE\Microsoft\Internet Explorer\SearchScopes\{0633EE93-D776-472f-A0FF-E1416B8B2E3A}" /v URL /t REG_SZ /d "Stacking up with the best of them{searchTerms}&FORM=IE8SRC" /f =========
========= End of Reg: =========
========= reg add "HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\SearchScopes\{0633EE93-D776-472f-A0FF-E1416B8B2E3A}" /v URL /t REG_SZ /d "Stacking up with the best of them{searchTerms}&FORM=IE8SRC" /f =========
========= reg add "HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\Environment" /v Path /t REG_EXPAND_SZ /d ^%SystemRoot^%\system32;^%SystemRoot^%;^%SystemRoot^%\System32\Wbem;^%SystemRoot^%\System32\WindowsPowerShell\v1.0\;"C:\Program Files (x86)\Intel\iCLS Client\";"C:\Program Files\Intel\iCLS Client\";"C:\Program Files (x86)\Common Files\Intel\Shared Files\cpp\bin\Intel64";"C:\Program Files (x86)\Autodesk\Backburner\";"C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common";"C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR";"C:\Program Files\Intel\Intel(R) Management Engine Components\DAL";"C:\Program Files\Intel\Intel(R) Management Engine Components\IPT";"C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL";"C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT" /f̩ =========
ERROR: Invalid syntax.
Type "REG ADD /?" for usage.
C:\Users\Carlos Luna\AppData\Roaming\Sun => moved successfully
C:\Program Files\Java => moved successfully
C:\Program Files (x86)\Java => moved successfully
========= DISM /Online /Cleanup-Image /RestoreHealth =========
Version: 6.1.7601.24499
Image Version: 6.1.7601.24499
Error: 87
The restorehealth option is not recognized in this context.
For more information, refer to the help.
========= SFC /scannow =========
Verification 0% complete.Verification 0% complete.Verification 1% complete.Verification 1% complete.Verification 1% complete.Verification 2% complete.Verification 2% complete.Verification 3% complete.Verification 3% complete.Verification 3% complete.Verification 4% complete.Verification 4% complete.Verification 5% complete.Verification 5% complete.Verification 5% complete.Verification 6% complete.Verification 6% complete.Verification 7% complete.Verification 7% complete.Verification 7% complete.Verification 8% complete.Verification 8% complete.Verification 8% complete.Verification 9% complete.Verification 9% complete.Verification 10% complete.Verification 10% complete.Verification 10% complete.Verification 11% complete.Verification 11% complete.Verification 12% complete.Verification 12% complete.Verification 12% complete.Verification 13% complete.Verification 13% complete.Verification 14% complete.Verification 14% complete.Verification 14% complete.Verification 15% complete.Verification 15% complete.Verification 15% complete.Verification 16% complete.Verification 16% complete.Verification 17% complete.Verification 17% complete.Verification 17% complete.Verification 18% complete.Verification 18% complete.Verification 19% complete.Verification 19% complete.Verification 19% complete.Verification 20% complete.Verification 20% complete.Verification 21% complete.Verification 21% complete.Verification 21% complete.Verification 22% complete.Verification 22% complete.Verification 22% complete.Verification 23% complete.Verification 23% complete.Verification 24% complete.Verification 24% complete.Verification 24% complete.Verification 25% complete.Verification 25% complete.Verification 26% complete.Verification 26% complete.Verification 26% complete.Verification 27% complete.Verification 27% complete.Verification 28% complete.Verification 28% complete.Verification 28% complete.Verification 29% complete.Verification 29% complete.Verification 29% complete.Verification 30% complete.Verification 30% complete.Verification 31% complete.Verification 31% complete.Verification 31% complete.Verification 32% complete.Verification 32% complete.Verification 33% complete.Verification 33% complete.Verification 33% complete.Verification 34% complete.Verification 34% complete.Verification 35% complete.Verification 35% complete.Verification 35% complete.Verification 36% complete.Verification 36% complete.Verification 36% complete.Verification 37% complete.Verification 37% complete.Verification 38% complete.Verification 38% complete.Verification 38% complete.Verification 39% complete.Verification 39% complete.Verification 40% complete.Verification 40% complete.Verification 40% complete.Verification 41% complete.Verification 41% complete.Verification 42% complete.Verification 42% complete.Verification 42% complete.Verification 43% complete.Verification 43% complete.Verification 43% complete.Verification 44% complete.Verification 44% complete.Verification 45% complete.Verification 45% complete.Verification 45% complete.Verification 46% complete.Verification 46% complete.Verification 47% complete.Verification 47% complete.Verification 47% complete.Verification 48% complete.Verification 48% complete.Verification 49% complete.Verification 49% complete.Verification 49% complete.Verification 50% complete.Verification 50% complete.Verification 51% complete.Verification 51% complete.Verification 51% complete.Verification 52% complete.Verification 52% complete.Verification 52% complete.Verification 53% complete.Verification 53% complete.Verification 54% complete.Verification 54% complete.Verification 54% complete.Verification 55% complete.Verification 55% complete.Verification 56% complete.Verification 56% complete.Verification 56% complete.Verification 57% complete.Verification 57% complete.Verification 58% complete.Verification 58% complete.Verification 58% complete.Verification 59% complete.Verification 59% complete.Verification 59% complete.Verification 60% complete.Verification 60% complete.Verification 61% complete.Verification 61% complete.Verification 61% complete.Verification 62% complete.Verification 62% complete.Verification 63% complete.Verification 63% complete.Verification 63% complete.Verification 64% complete.Verification 64% complete.Verification 65% complete.Verification 65% complete.Verification 65% complete.Verification 66% complete.Verification 66% complete.Verification 66% complete.Verification 67% complete.Verification 67% complete.Verification 68% complete.Verification 68% complete.Verification 68% complete.Verification 69% complete.Verification 69% complete.Verification 70% complete.Verification 70% complete.Verification 70% complete.Verification 71% complete.Verification 71% complete.Verification 72% complete.Verification 72% complete.Verification 72% complete.Verification 73% complete.Verification 73% complete.Verification 73% complete.Verification 74% complete.Verification 74% complete.Verification 75% complete.Verification 75% complete.Verification 75% complete.Verification 76% complete.Verification 76% complete.Verification 77% complete.Verification 77% complete.Verification 77% complete.Verification 78% complete.Verification 78% complete.Verification 79% complete.Verification 79% complete.Verification 79% complete.Verification 80% complete.Verification 80% complete.Verification 80% complete.Verification 81% complete.Verification 81% complete.Verification 82% complete.Verification 82% complete.Verification 82% complete.Verification 83% complete.Verification 83% complete.Verification 84% complete.Verification 84% complete.Verification 84% complete.Verification 85% complete.Verification 85% complete.Verification 86% complete.Verification 86% complete.Verification 86% complete.Verification 87% complete.Verification 87% complete.Verification 87% complete.Verification 88% complete.Verification 88% complete.Verification 89% complete.Verification 89% complete.Verification 89% complete.Verification 90% complete.Verification 90% complete.Verification 91% complete.Verification 91% complete.Verification 91% complete.Verification 92% complete.Verification 92% complete.Verification 93% complete.Verification 93% complete.Verification 93% complete.Verification 94% complete.Verification 94% complete.Verification 95% complete.Verification 95% complete.Verification 95% complete.Verification 96% complete.Verification 96% complete.Verification 96% complete.Verification 97% complete.Verification 97% complete.Verification 98% complete.Verification 98% complete.Verification 98% complete.Verification 99% complete.Verification 99% complete.Verification 100% complete.
Details are included in the CBS.Log windir\Logs\CBS\CBS.log. For example
C:\Windows\Logs\CBS\CBS.log
=========== EmptyTemp: ==========
BITS transfer queue => 0 B
DOMStore, IE Recovery, AppCache, Feeds Cache, Thumbcache, IconCache => 5088676 B
Java, Flash, Steam htmlcache => 31022052 B
Windows/system/drivers => 591526 B
Edge => 0 B
Firefox => 0 B
Opera => 0 B
Temp, IE cache, history, cookies, recent:
Default => 0 B
Public => 0 B
ProgramData => 0 B
systemprofile => 0 B
systemprofile32 => 0 B
LocalService => 0 B
NetworkService => 0 B
Carlos Luna => 13421730 B
RecycleBin => 0 B
EmptyTemp: => 47.8 MB temporary data Removed.
The system needed a reboot.
==== End of Fixlog 19:43:27 ====
Carlosh,
The fix revealed some errors.
The one has to do with the script syntax, and I will provide it corrected to you next. The other one, has to do with ... me, keep forgetting that your computer is running with Windows 7! DISM utility isn't supported for Windows 7 computers. Lastly, and most important, the SFC utility revealed that "Windows Resource Protection found corrupt files but was unable to fix some of them". We are going to check further this.
For now...
1. FRST fix
Start::
CreateRestorePoint:
CloseProcesses:
Reg: reg add "HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\Environment" /v Path /t REG_EXPAND_SZ /d ^%SystemRoot^%\system32;^%SystemRoot^%;^%SystemRoot^%\System32\Wbem;^%SystemRoot^%\System32\WindowsPowerShell\v1.0\;"C:\Program Files (x86)\Intel\iCLS Client";"C:\Program Files\Intel\iCLS Client";"C:\Program Files (x86)\Common Files\Intel\Shared Files\cpp\bin\Intel64";"C:\Program Files (x86)\Autodesk\Backburner";"C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common";"C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR";"C:\Program Files\Intel\Intel(R) Management Engine Components\DAL";"C:\Program Files\Intel\Intel(R) Management Engine Components\IPT";"C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL";"C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT" /f
cmd: findstr /c:"[SR]" %windir%\logs\cbs\cbs.log
EmptyTemp:
End::
Fix result of Farbar Recovery Scan Tool (x64) Version: 08-11-2021 02
Ran by Carlos Luna (08-11-2021 20:09:48) Run:5
Boot Mode: Normal
fixlist content:
CreateRestorePoint:
CloseProcesses:
EmptyTemp:
========= reg add "HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\Environment" /v Path /t REG_EXPAND_SZ /d ^%SystemRoot^%\system32;^%SystemRoot^%;^%SystemRoot^%\System32\Wbem;^%SystemRoot^%\System32\WindowsPowerShell\v1.0\;"C:\Program Files (x86)\Intel\iCLS Client";"C:\Program Files\Intel\iCLS Client";"C:\Program Files (x86)\Common Files\Intel\Shared Files\cpp\bin\Intel64";"C:\Program Files (x86)\Autodesk\Backburner";"C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common";"C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR";"C:\Program Files\Intel\Intel(R) Management Engine Components\DAL";"C:\Program Files\Intel\Intel(R) Management Engine Components\IPT";"C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL";"C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT" /f =========
========= findstr /c:"[SR]" %windir%\logs\cbs\cbs.log =========
2021-10-24 01:14:59, Info CSI 00000009 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:14:59, Info CSI 0000000a [SR] Beginning Verify and Repair transaction
2021-10-24 01:15:01, Info CSI 0000000c [SR] Verify complete
2021-10-24 01:15:02, Info CSI 0000000d [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:15:02, Info CSI 0000000e [SR] Beginning Verify and Repair transaction
2021-10-24 01:15:04, Info CSI 00000010 [SR] Verify complete
2021-10-24 01:15:06, Info CSI 00000011 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:15:06, Info CSI 00000012 [SR] Beginning Verify and Repair transaction
2021-10-24 01:15:07, Info CSI 00000014 [SR] Verify complete
2021-10-24 01:15:09, Info CSI 00000015 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:15:09, Info CSI 00000016 [SR] Beginning Verify and Repair transaction
2021-10-24 01:15:10, Info CSI 00000018 [SR] Verify complete
2021-10-24 01:15:12, Info CSI 00000019 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:15:12, Info CSI 0000001a [SR] Beginning Verify and Repair transaction
2021-10-24 01:15:14, Info CSI 0000001c [SR] Verify complete
2021-10-24 01:15:17, Info CSI 0000001d [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:15:17, Info CSI 0000001e [SR] Beginning Verify and Repair transaction
2021-10-24 01:15:18, Info CSI 00000020 [SR] Verify complete
2021-10-24 01:15:20, Info CSI 00000021 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:15:20, Info CSI 00000022 [SR] Beginning Verify and Repair transaction
2021-10-24 01:15:22, Info CSI 00000024 [SR] Verify complete
2021-10-24 01:15:24, Info CSI 00000025 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:15:24, Info CSI 00000026 [SR] Beginning Verify and Repair transaction
2021-10-24 01:15:25, Info CSI 00000028 [SR] Verify complete
2021-10-24 01:15:26, Info CSI 00000029 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:15:26, Info CSI 0000002a [SR] Beginning Verify and Repair transaction
2021-10-24 01:15:28, Info CSI 0000002c [SR] Verify complete
2021-10-24 01:15:30, Info CSI 0000002d [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:15:30, Info CSI 0000002e [SR] Beginning Verify and Repair transaction
2021-10-24 01:15:32, Info CSI 00000030 [SR] Verify complete
2021-10-24 01:15:33, Info CSI 00000031 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:15:33, Info CSI 00000032 [SR] Beginning Verify and Repair transaction
2021-10-24 01:15:34, Info CSI 00000034 [SR] Verify complete
2021-10-24 01:15:37, Info CSI 00000035 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:15:37, Info CSI 00000036 [SR] Beginning Verify and Repair transaction
2021-10-24 01:15:38, Info CSI 00000038 [SR] Verify complete
2021-10-24 01:15:39, Info CSI 00000039 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:15:39, Info CSI 0000003a [SR] Beginning Verify and Repair transaction
2021-10-24 01:15:41, Info CSI 0000003c [SR] Verify complete
2021-10-24 01:15:43, Info CSI 0000003d [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:15:43, Info CSI 0000003e [SR] Beginning Verify and Repair transaction
2021-10-24 01:15:44, Info CSI 00000040 [SR] Verify complete
2021-10-24 01:15:46, Info CSI 00000041 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:15:46, Info CSI 00000042 [SR] Beginning Verify and Repair transaction
2021-10-24 01:15:47, Info CSI 00000044 [SR] Verify complete
2021-10-24 01:15:48, Info CSI 00000045 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:15:48, Info CSI 00000046 [SR] Beginning Verify and Repair transaction
2021-10-24 01:15:50, Info CSI 00000048 [SR] Verify complete
2021-10-24 01:15:51, Info CSI 00000049 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:15:51, Info CSI 0000004a [SR] Beginning Verify and Repair transaction
2021-10-24 01:15:53, Info CSI 0000004c [SR] Verify complete
2021-10-24 01:15:54, Info CSI 0000004d [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:15:54, Info CSI 0000004e [SR] Beginning Verify and Repair transaction
2021-10-24 01:15:55, Info CSI 00000050 [SR] Verify complete
2021-10-24 01:15:57, Info CSI 00000051 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:15:57, Info CSI 00000052 [SR] Beginning Verify and Repair transaction
2021-10-24 01:15:58, Info CSI 00000054 [SR] Verify complete
2021-10-24 01:16:00, Info CSI 00000055 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:16:00, Info CSI 00000056 [SR] Beginning Verify and Repair transaction
2021-10-24 01:16:01, Info CSI 00000058 [SR] Verify complete
2021-10-24 01:16:03, Info CSI 00000059 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:16:03, Info CSI 0000005a [SR] Beginning Verify and Repair transaction
2021-10-24 01:16:04, Info CSI 0000005c [SR] Verify complete
2021-10-24 01:16:06, Info CSI 0000005d [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:16:06, Info CSI 0000005e [SR] Beginning Verify and Repair transaction
2021-10-24 01:16:07, Info CSI 00000060 [SR] Verify complete
2021-10-24 01:16:09, Info CSI 00000061 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:16:09, Info CSI 00000062 [SR] Beginning Verify and Repair transaction
2021-10-24 01:16:11, Info CSI 00000064 [SR] Verify complete
2021-10-24 01:16:12, Info CSI 00000065 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:16:12, Info CSI 00000066 [SR] Beginning Verify and Repair transaction
2021-10-24 01:16:13, Info CSI 00000068 [SR] Verify complete
2021-10-24 01:16:15, Info CSI 00000069 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:16:15, Info CSI 0000006a [SR] Beginning Verify and Repair transaction
2021-10-24 01:16:16, Info CSI 0000006c [SR] Verify complete
2021-10-24 01:16:19, Info CSI 0000006d [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:16:19, Info CSI 0000006e [SR] Beginning Verify and Repair transaction
2021-10-24 01:16:20, Info CSI 00000070 [SR] Verify complete
2021-10-24 01:16:21, Info CSI 00000071 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:16:21, Info CSI 00000072 [SR] Beginning Verify and Repair transaction
2021-10-24 01:16:23, Info CSI 00000074 [SR] Verify complete
2021-10-24 01:16:24, Info CSI 00000075 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:16:24, Info CSI 00000076 [SR] Beginning Verify and Repair transaction
2021-10-24 01:16:26, Info CSI 00000078 [SR] Verify complete
2021-10-24 01:16:27, Info CSI 00000079 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:16:27, Info CSI 0000007a [SR] Beginning Verify and Repair transaction
2021-10-24 01:16:29, Info CSI 0000007c [SR] Verify complete
2021-10-24 01:16:30, Info CSI 0000007d [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:16:30, Info CSI 0000007e [SR] Beginning Verify and Repair transaction
2021-10-24 01:16:32, Info CSI 00000080 [SR] Verify complete
2021-10-24 01:16:33, Info CSI 00000081 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:16:33, Info CSI 00000082 [SR] Beginning Verify and Repair transaction
2021-10-24 01:16:34, Info CSI 00000084 [SR] Verify complete
2021-10-24 01:16:36, Info CSI 00000085 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:16:36, Info CSI 00000086 [SR] Beginning Verify and Repair transaction
2021-10-24 01:16:37, Info CSI 00000088 [SR] Verify complete
2021-10-24 01:16:38, Info CSI 00000089 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:16:38, Info CSI 0000008a [SR] Beginning Verify and Repair transaction
2021-10-24 01:16:39, Info CSI 0000008c [SR] Verify complete
2021-10-24 01:16:41, Info CSI 0000008d [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:16:41, Info CSI 0000008e [SR] Beginning Verify and Repair transaction
2021-10-24 01:16:42, Info CSI 00000090 [SR] Verify complete
2021-10-24 01:16:43, Info CSI 00000091 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:16:43, Info CSI 00000092 [SR] Beginning Verify and Repair transaction
2021-10-24 01:16:45, Info CSI 00000094 [SR] Verify complete
2021-10-24 01:16:46, Info CSI 00000095 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:16:46, Info CSI 00000096 [SR] Beginning Verify and Repair transaction
2021-10-24 01:16:48, Info CSI 00000098 [SR] Verify complete
2021-10-24 01:16:49, Info CSI 00000099 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:16:49, Info CSI 0000009a [SR] Beginning Verify and Repair transaction
2021-10-24 01:16:50, Info CSI 0000009c [SR] Verify complete
2021-10-24 01:16:51, Info CSI 0000009d [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:16:51, Info CSI 0000009e [SR] Beginning Verify and Repair transaction
2021-10-24 01:16:53, Info CSI 000000a0 [SR] Verify complete
2021-10-24 01:16:54, Info CSI 000000a1 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:16:54, Info CSI 000000a2 [SR] Beginning Verify and Repair transaction
2021-10-24 01:16:55, Info CSI 000000a4 [SR] Verify complete
2021-10-24 01:16:56, Info CSI 000000a5 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:16:56, Info CSI 000000a6 [SR] Beginning Verify and Repair transaction
2021-10-24 01:16:58, Info CSI 000000a8 [SR] Verify complete
2021-10-24 01:16:59, Info CSI 000000a9 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:16:59, Info CSI 000000aa [SR] Beginning Verify and Repair transaction
2021-10-24 01:17:02, Info CSI 000000ac [SR] Verify complete
2021-10-24 01:17:03, Info CSI 000000ad [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:17:03, Info CSI 000000ae [SR] Beginning Verify and Repair transaction
2021-10-24 01:17:04, Info CSI 000000b0 [SR] Verify complete
2021-10-24 01:17:06, Info CSI 000000b1 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:17:06, Info CSI 000000b2 [SR] Beginning Verify and Repair transaction
2021-10-24 01:17:07, Info CSI 000000b4 [SR] Verify complete
2021-10-24 01:17:08, Info CSI 000000b5 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:17:08, Info CSI 000000b6 [SR] Beginning Verify and Repair transaction
2021-10-24 01:17:10, Info CSI 000000b8 [SR] Verify complete
2021-10-24 01:17:11, Info CSI 000000b9 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:17:11, Info CSI 000000ba [SR] Beginning Verify and Repair transaction
2021-10-24 01:17:13, Info CSI 000000bc [SR] Verify complete
2021-10-24 01:17:14, Info CSI 000000bd [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:17:14, Info CSI 000000be [SR] Beginning Verify and Repair transaction
2021-10-24 01:17:17, Info CSI 000000c0 [SR] Verify complete
2021-10-24 01:17:18, Info CSI 000000c1 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:17:18, Info CSI 000000c2 [SR] Beginning Verify and Repair transaction
2021-10-24 01:17:20, Info CSI 000000c4 [SR] Verify complete
2021-10-24 01:17:21, Info CSI 000000c5 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:17:21, Info CSI 000000c6 [SR] Beginning Verify and Repair transaction
2021-10-24 01:17:23, Info CSI 000000c8 [SR] Verify complete
2021-10-24 01:17:24, Info CSI 000000c9 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:17:24, Info CSI 000000ca [SR] Beginning Verify and Repair transaction
2021-10-24 01:17:28, Info CSI 000000cc [SR] Verify complete
2021-10-24 01:17:30, Info CSI 000000cd [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:17:30, Info CSI 000000ce [SR] Beginning Verify and Repair transaction
2021-10-24 01:17:33, Info CSI 000000d0 [SR] Verify complete
2021-10-24 01:17:34, Info CSI 000000d1 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:17:34, Info CSI 000000d2 [SR] Beginning Verify and Repair transaction
2021-10-24 01:17:35, Info CSI 000000d4 [SR] Verify complete
2021-10-24 01:17:37, Info CSI 000000d5 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:17:37, Info CSI 000000d6 [SR] Beginning Verify and Repair transaction
2021-10-24 01:17:38, Info CSI 000000d8 [SR] Verify complete
2021-10-24 01:17:40, Info CSI 000000d9 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:17:40, Info CSI 000000da [SR] Beginning Verify and Repair transaction
2021-10-24 01:17:42, Info CSI 000000dc [SR] Verify complete
2021-10-24 01:17:43, Info CSI 000000dd [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:17:43, Info CSI 000000de [SR] Beginning Verify and Repair transaction
2021-10-24 01:17:46, Info CSI 000000e0 [SR] Verify complete
2021-10-24 01:17:47, Info CSI 000000e1 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:17:47, Info CSI 000000e2 [SR] Beginning Verify and Repair transaction
2021-10-24 01:17:48, Info CSI 000000e4 [SR] Verify complete
2021-10-24 01:17:49, Info CSI 000000e5 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:17:49, Info CSI 000000e6 [SR] Beginning Verify and Repair transaction
2021-10-24 01:17:51, Info CSI 000000e8 [SR] Verify complete
2021-10-24 01:17:52, Info CSI 000000e9 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:17:52, Info CSI 000000ea [SR] Beginning Verify and Repair transaction
2021-10-24 01:17:53, Info CSI 000000ec [SR] Verify complete
2021-10-24 01:17:54, Info CSI 000000ed [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:17:54, Info CSI 000000ee [SR] Beginning Verify and Repair transaction
2021-10-24 01:17:56, Info CSI 000000f0 [SR] Verify complete
2021-10-24 01:17:57, Info CSI 000000f1 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:17:57, Info CSI 000000f2 [SR] Beginning Verify and Repair transaction
2021-10-24 01:17:59, Info CSI 000000f4 [SR] Verify complete
2021-10-24 01:18:00, Info CSI 000000f5 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:18:00, Info CSI 000000f6 [SR] Beginning Verify and Repair transaction
2021-10-24 01:18:01, Info CSI 000000f8 [SR] Verify complete
2021-10-24 01:18:02, Info CSI 000000f9 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:18:02, Info CSI 000000fa [SR] Beginning Verify and Repair transaction
2021-10-24 01:18:05, Info CSI 000000fc [SR] Verify complete
2021-10-24 01:18:06, Info CSI 000000fd [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:18:06, Info CSI 000000fe [SR] Beginning Verify and Repair transaction
2021-10-24 01:18:09, Info CSI 00000100 [SR] Verify complete
2021-10-24 01:18:09, Info CSI 00000101 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:18:09, Info CSI 00000102 [SR] Beginning Verify and Repair transaction
2021-10-24 01:18:13, Info CSI 00000104 [SR] Verify complete
2021-10-24 01:18:13, Info CSI 00000105 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:18:13, Info CSI 00000106 [SR] Beginning Verify and Repair transaction
2021-10-24 01:18:17, Info CSI 00000108 [SR] Verify complete
2021-10-24 01:18:17, Info CSI 00000109 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:18:17, Info CSI 0000010a [SR] Beginning Verify and Repair transaction
2021-10-24 01:18:19, Info CSI 0000010c [SR] Verify complete
2021-10-24 01:18:20, Info CSI 0000010d [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:18:20, Info CSI 0000010e [SR] Beginning Verify and Repair transaction
2021-10-24 01:18:22, Info CSI 00000110 [SR] Verify complete
2021-10-24 01:18:22, Info CSI 00000111 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:18:22, Info CSI 00000112 [SR] Beginning Verify and Repair transaction
2021-10-24 01:18:25, Info CSI 00000114 [SR] Verify complete
2021-10-24 01:18:26, Info CSI 00000115 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:18:26, Info CSI 00000116 [SR] Beginning Verify and Repair transaction
2021-10-24 01:18:31, Info CSI 00000118 [SR] Verify complete
2021-10-24 01:18:32, Info CSI 00000119 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:18:32, Info CSI 0000011a [SR] Beginning Verify and Repair transaction
2021-10-24 01:18:40, Info CSI 0000011d [SR] Verify complete
2021-10-24 01:18:41, Info CSI 0000011e [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:18:41, Info CSI 0000011f [SR] Beginning Verify and Repair transaction
2021-10-24 01:18:46, Info CSI 00000122 [SR] Verify complete
2021-10-24 01:18:46, Info CSI 00000123 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:18:46, Info CSI 00000124 [SR] Beginning Verify and Repair transaction
2021-10-24 01:18:51, Info CSI 00000127 [SR] Verify complete
2021-10-24 01:18:52, Info CSI 00000128 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:18:52, Info CSI 00000129 [SR] Beginning Verify and Repair transaction
2021-10-24 01:18:55, Info CSI 0000012c [SR] Verify complete
2021-10-24 01:18:56, Info CSI 0000012d [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:18:56, Info CSI 0000012e [SR] Beginning Verify and Repair transaction
2021-10-24 01:19:00, Info CSI 00000133 [SR] Verify complete
2021-10-24 01:19:00, Info CSI 00000134 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:19:00, Info CSI 00000135 [SR] Beginning Verify and Repair transaction
2021-10-24 01:19:04, Info CSI 00000137 [SR] Verify complete
2021-10-24 01:19:05, Info CSI 00000138 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:19:05, Info CSI 00000139 [SR] Beginning Verify and Repair transaction
2021-10-24 01:19:11, Info CSI 0000013b [SR] Verify complete
2021-10-24 01:19:11, Info CSI 0000013c [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:19:11, Info CSI 0000013d [SR] Beginning Verify and Repair transaction
2021-10-24 01:19:17, Info CSI 0000015f [SR] Verify complete
2021-10-24 01:19:18, Info CSI 00000160 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:19:18, Info CSI 00000161 [SR] Beginning Verify and Repair transaction
2021-10-24 01:19:26, Info CSI 00000166 [SR] Verify complete
2021-10-24 01:19:26, Info CSI 00000167 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:19:26, Info CSI 00000168 [SR] Beginning Verify and Repair transaction
2021-10-24 01:19:30, Info CSI 0000016a [SR] Verify complete
2021-10-24 01:19:30, Info CSI 0000016b [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:19:30, Info CSI 0000016c [SR] Beginning Verify and Repair transaction
2021-10-24 01:19:36, Info CSI 0000016e [SR] Verify complete
2021-10-24 01:19:36, Info CSI 0000016f [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:19:36, Info CSI 00000170 [SR] Beginning Verify and Repair transaction
2021-10-24 01:19:40, Info CSI 00000172 [SR] Verify complete
2021-10-24 01:19:41, Info CSI 00000173 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:19:41, Info CSI 00000174 [SR] Beginning Verify and Repair transaction
2021-10-24 01:19:44, Info CSI 00000176 [SR] Verify complete
2021-10-24 01:19:44, Info CSI 00000177 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:19:44, Info CSI 00000178 [SR] Beginning Verify and Repair transaction
2021-10-24 01:19:51, Info CSI 0000017a [SR] Verify complete
2021-10-24 01:19:51, Info CSI 0000017b [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:19:51, Info CSI 0000017c [SR] Beginning Verify and Repair transaction
2021-10-24 01:19:55, Info CSI 0000017e [SR] Verify complete
2021-10-24 01:19:55, Info CSI 0000017f [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:19:55, Info CSI 00000180 [SR] Beginning Verify and Repair transaction
2021-10-24 01:20:00, Info CSI 00000182 [SR] Verify complete
2021-10-24 01:20:01, Info CSI 00000183 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:20:01, Info CSI 00000184 [SR] Beginning Verify and Repair transaction
2021-10-24 01:20:04, Info CSI 00000186 [SR] Verify complete
2021-10-24 01:20:05, Info CSI 00000187 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:20:05, Info CSI 00000188 [SR] Beginning Verify and Repair transaction
2021-10-24 01:20:10, Info CSI 0000018a [SR] Verify complete
2021-10-24 01:20:10, Info CSI 0000018b [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:20:10, Info CSI 0000018c [SR] Beginning Verify and Repair transaction
2021-10-24 01:20:19, Info CSI 000001aa [SR] Verify complete
2021-10-24 01:20:19, Info CSI 000001ab [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:20:19, Info CSI 000001ac [SR] Beginning Verify and Repair transaction
2021-10-24 01:20:24, Info CSI 000001cd [SR] Verify complete
2021-10-24 01:20:25, Info CSI 000001ce [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:20:25, Info CSI 000001cf [SR] Beginning Verify and Repair transaction
2021-10-24 01:20:35, Info CSI 000001d1 [SR] Verify complete
2021-10-24 01:20:36, Info CSI 000001d2 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:20:36, Info CSI 000001d3 [SR] Beginning Verify and Repair transaction
2021-10-24 01:20:44, Info CSI 000001d5 [SR] Verify complete
2021-10-24 01:20:44, Info CSI 000001d6 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:20:44, Info CSI 000001d7 [SR] Beginning Verify and Repair transaction
2021-10-24 01:20:53, Info CSI 000001d9 [SR] Verify complete
2021-10-24 01:20:53, Info CSI 000001da [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:20:53, Info CSI 000001db [SR] Beginning Verify and Repair transaction
2021-10-24 01:20:56, Info CSI 000001df [SR] Verify complete
2021-10-24 01:20:57, Info CSI 000001e0 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:20:57, Info CSI 000001e1 [SR] Beginning Verify and Repair transaction
2021-10-24 01:21:00, Info CSI 000001e3 [SR] Verify complete
2021-10-24 01:21:00, Info CSI 000001e4 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:21:00, Info CSI 000001e5 [SR] Beginning Verify and Repair transaction
2021-10-24 01:21:04, Info CSI 000001e7 [SR] Verify complete
2021-10-24 01:21:04, Info CSI 000001e8 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:21:04, Info CSI 000001e9 [SR] Beginning Verify and Repair transaction
2021-10-24 01:21:06, Info CSI 000001eb [SR] Verify complete
2021-10-24 01:21:06, Info CSI 000001ec [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:21:06, Info CSI 000001ed [SR] Beginning Verify and Repair transaction
2021-10-24 01:21:08, Info CSI 000001ef [SR] Verify complete
2021-10-24 01:21:08, Info CSI 000001f0 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:21:08, Info CSI 000001f1 [SR] Beginning Verify and Repair transaction
2021-10-24 01:21:10, Info CSI 000001f3 [SR] Verify complete
2021-10-24 01:21:10, Info CSI 000001f4 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:21:10, Info CSI 000001f5 [SR] Beginning Verify and Repair transaction
2021-10-24 01:21:14, Info CSI 000001f7 [SR] Verify complete
2021-10-24 01:21:14, Info CSI 000001f8 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:21:14, Info CSI 000001f9 [SR] Beginning Verify and Repair transaction
2021-10-24 01:21:23, Info CSI 0000020c [SR] Verify complete
2021-10-24 01:21:23, Info CSI 0000020d [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:21:23, Info CSI 0000020e [SR] Beginning Verify and Repair transaction
2021-10-24 01:21:25, Info CSI 00000210 [SR] Verify complete
2021-10-24 01:21:26, Info CSI 00000211 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:21:26, Info CSI 00000212 [SR] Beginning Verify and Repair transaction
2021-10-24 01:21:29, Info CSI 00000214 [SR] Verify complete
2021-10-24 01:21:30, Info CSI 00000215 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:21:30, Info CSI 00000216 [SR] Beginning Verify and Repair transaction
2021-10-24 01:21:32, Info CSI 00000218 [SR] Verify complete
2021-10-24 01:21:32, Info CSI 00000219 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:21:32, Info CSI 0000021a [SR] Beginning Verify and Repair transaction
2021-10-24 01:21:37, Info CSI 0000021c [SR] Verify complete
2021-10-24 01:21:37, Info CSI 0000021d [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:21:37, Info CSI 0000021e [SR] Beginning Verify and Repair transaction
2021-10-24 01:21:42, Info CSI 00000221 [SR] Verify complete
2021-10-24 01:21:42, Info CSI 00000222 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:21:42, Info CSI 00000223 [SR] Beginning Verify and Repair transaction
2021-10-24 01:21:54, Info CSI 00000224 [SR] Repairing corrupted file [ml:520{260},l:90{45}]"\??\C:\Program Files\Internet Explorer\images"\[l:16{8}]"bing.ico" from store
2021-10-24 01:21:56, Info CSI 00000227 [SR] Verify complete
2021-10-24 01:21:56, Info CSI 00000228 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:21:56, Info CSI 00000229 [SR] Beginning Verify and Repair transaction
2021-10-24 01:22:01, Info CSI 0000022b [SR] Verify complete
2021-10-24 01:22:01, Info CSI 0000022c [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:22:01, Info CSI 0000022d [SR] Beginning Verify and Repair transaction
2021-10-24 01:22:04, Info CSI 0000022f [SR] Verify complete
2021-10-24 01:22:05, Info CSI 00000230 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:22:05, Info CSI 00000231 [SR] Beginning Verify and Repair transaction
2021-10-24 01:22:07, Info CSI 00000233 [SR] Verify complete
2021-10-24 01:22:07, Info CSI 00000234 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:22:07, Info CSI 00000235 [SR] Beginning Verify and Repair transaction
2021-10-24 01:22:10, Info CSI 00000237 [SR] Verify complete
2021-10-24 01:22:11, Info CSI 00000238 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:22:11, Info CSI 00000239 [SR] Beginning Verify and Repair transaction
2021-10-24 01:22:14, Info CSI 0000023b [SR] Verify complete
2021-10-24 01:22:15, Info CSI 0000023c [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:22:15, Info CSI 0000023d [SR] Beginning Verify and Repair transaction
2021-10-24 01:22:21, Info CSI 0000023f [SR] Verify complete
2021-10-24 01:22:21, Info CSI 00000240 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:22:21, Info CSI 00000241 [SR] Beginning Verify and Repair transaction
2021-10-24 01:22:25, Info CSI 00000243 [SR] Verify complete
2021-10-24 01:22:26, Info CSI 00000244 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:22:26, Info CSI 00000245 [SR] Beginning Verify and Repair transaction
2021-10-24 01:22:29, Info CSI 00000247 [SR] Verify complete
2021-10-24 01:22:29, Info CSI 00000248 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:22:29, Info CSI 00000249 [SR] Beginning Verify and Repair transaction
2021-10-24 01:22:33, Info CSI 0000024b [SR] Verify complete
2021-10-24 01:22:34, Info CSI 0000024c [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:22:34, Info CSI 0000024d [SR] Beginning Verify and Repair transaction
2021-10-24 01:22:44, Info CSI 00000261 [SR] Verify complete
2021-10-24 01:22:44, Info CSI 00000262 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:22:44, Info CSI 00000263 [SR] Beginning Verify and Repair transaction
2021-10-24 01:22:49, Info CSI 00000269 [SR] Verify complete
2021-10-24 01:22:50, Info CSI 0000026a [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:22:50, Info CSI 0000026b [SR] Beginning Verify and Repair transaction
2021-10-24 01:22:56, Info CSI 0000026d [SR] Verify complete
2021-10-24 01:22:57, Info CSI 0000026e [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:22:57, Info CSI 0000026f [SR] Beginning Verify and Repair transaction
2021-10-24 01:23:00, Info CSI 00000271 [SR] Verify complete
2021-10-24 01:23:00, Info CSI 00000272 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:23:00, Info CSI 00000273 [SR] Beginning Verify and Repair transaction
2021-10-24 01:23:16, Info CSI 00000275 [SR] Verify complete
2021-10-24 01:23:16, Info CSI 00000276 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:23:16, Info CSI 00000277 [SR] Beginning Verify and Repair transaction
2021-10-24 01:23:21, Info CSI 00000279 [SR] Verify complete
2021-10-24 01:23:22, Info CSI 0000027a [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:23:22, Info CSI 0000027b [SR] Beginning Verify and Repair transaction
2021-10-24 01:23:28, Info CSI 0000027e [SR] Verify complete
2021-10-24 01:23:29, Info CSI 0000027f [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:23:29, Info CSI 00000280 [SR] Beginning Verify and Repair transaction
2021-10-24 01:23:35, Info CSI 00000282 [SR] Verify complete
2021-10-24 01:23:35, Info CSI 00000283 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:23:35, Info CSI 00000284 [SR] Beginning Verify and Repair transaction
2021-10-24 01:23:42, Info CSI 00000286 [SR] Verify complete
2021-10-24 01:23:43, Info CSI 00000287 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:23:43, Info CSI 00000288 [SR] Beginning Verify and Repair transaction
2021-10-24 01:23:49, Info CSI 0000028c [SR] Verify complete
2021-10-24 01:23:49, Info CSI 0000028d [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:23:49, Info CSI 0000028e [SR] Beginning Verify and Repair transaction
2021-10-24 01:23:52, Info CSI 00000290 [SR] Verify complete
2021-10-24 01:23:53, Info CSI 00000291 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:23:53, Info CSI 00000292 [SR] Beginning Verify and Repair transaction
2021-10-24 01:23:59, Info CSI 00000294 [SR] Verify complete
2021-10-24 01:24:00, Info CSI 00000295 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:24:00, Info CSI 00000296 [SR] Beginning Verify and Repair transaction
2021-10-24 01:24:04, Info CSI 00000298 [SR] Verify complete
2021-10-24 01:24:04, Info CSI 00000299 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:24:04, Info CSI 0000029a [SR] Beginning Verify and Repair transaction
2021-10-24 01:24:07, Info CSI 0000029c [SR] Verify complete
2021-10-24 01:24:08, Info CSI 0000029d [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:24:08, Info CSI 0000029e [SR] Beginning Verify and Repair transaction
2021-10-24 01:24:12, Info CSI 000002a2 [SR] Verify complete
2021-10-24 01:24:13, Info CSI 000002a3 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:24:13, Info CSI 000002a4 [SR] Beginning Verify and Repair transaction
2021-10-24 01:24:17, Info CSI 000002a6 [SR] Verify complete
2021-10-24 01:24:18, Info CSI 000002a7 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:24:18, Info CSI 000002a8 [SR] Beginning Verify and Repair transaction
2021-10-24 01:24:21, Info CSI 000002aa [SR] Verify complete
2021-10-24 01:24:22, Info CSI 000002ab [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:24:22, Info CSI 000002ac [SR] Beginning Verify and Repair transaction
2021-10-24 01:24:37, Info CSI 000002ae [SR] Verify complete
2021-10-24 01:24:37, Info CSI 000002af [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:24:37, Info CSI 000002b0 [SR] Beginning Verify and Repair transaction
2021-10-24 01:24:41, Info CSI 000002b2 [SR] Verify complete
2021-10-24 01:24:41, Info CSI 000002b3 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:24:41, Info CSI 000002b4 [SR] Beginning Verify and Repair transaction
2021-10-24 01:24:47, Info CSI 000002b7 [SR] Verify complete
2021-10-24 01:24:47, Info CSI 000002b8 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:24:47, Info CSI 000002b9 [SR] Beginning Verify and Repair transaction
2021-10-24 01:24:57, Info CSI 000002bb [SR] Verify complete
2021-10-24 01:24:58, Info CSI 000002bc [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:24:58, Info CSI 000002bd [SR] Beginning Verify and Repair transaction
2021-10-24 01:25:05, Info CSI 000002bf [SR] Verify complete
2021-10-24 01:25:06, Info CSI 000002c0 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:25:06, Info CSI 000002c1 [SR] Beginning Verify and Repair transaction
2021-10-24 01:25:20, Info CSI 000002c4 [SR] Verify complete
2021-10-24 01:25:22, Info CSI 000002c5 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:25:22, Info CSI 000002c6 [SR] Beginning Verify and Repair transaction
2021-10-24 01:25:28, Info CSI 000002c8 [SR] Verify complete
2021-10-24 01:25:28, Info CSI 000002c9 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:25:28, Info CSI 000002ca [SR] Beginning Verify and Repair transaction
2021-10-24 01:26:46, Info CSI 000002cc [SR] Verify complete
2021-10-24 01:26:54, Info CSI 000002cd [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:26:54, Info CSI 000002ce [SR] Beginning Verify and Repair transaction
2021-10-24 01:27:11, Info CSI 000002d1 [SR] Verify complete
2021-10-24 01:27:12, Info CSI 000002d2 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:27:12, Info CSI 000002d3 [SR] Beginning Verify and Repair transaction
2021-10-24 01:27:17, Info CSI 000002d5 [SR] Verify complete
2021-10-24 01:27:17, Info CSI 000002d6 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:27:17, Info CSI 000002d7 [SR] Beginning Verify and Repair transaction
2021-10-24 01:27:20, Info CSI 000002d9 [SR] Verify complete
2021-10-24 01:27:21, Info CSI 000002da [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:27:21, Info CSI 000002db [SR] Beginning Verify and Repair transaction
2021-10-24 01:27:25, Info CSI 000002dd [SR] Verify complete
2021-10-24 01:27:25, Info CSI 000002de [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:27:25, Info CSI 000002df [SR] Beginning Verify and Repair transaction
2021-10-24 01:27:29, Info CSI 000002e1 [SR] Verify complete
2021-10-24 01:27:30, Info CSI 000002e2 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:27:30, Info CSI 000002e3 [SR] Beginning Verify and Repair transaction
2021-10-24 01:27:33, Info CSI 000002e6 [SR] Verify complete
2021-10-24 01:27:34, Info CSI 000002e7 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:27:34, Info CSI 000002e8 [SR] Beginning Verify and Repair transaction
2021-10-24 01:27:38, Info CSI 000002ea [SR] Verify complete
2021-10-24 01:27:38, Info CSI 000002eb [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:27:38, Info CSI 000002ec [SR] Beginning Verify and Repair transaction
2021-10-24 01:27:41, Info CSI 000002ee [SR] Verify complete
2021-10-24 01:27:41, Info CSI 000002ef [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:27:41, Info CSI 000002f0 [SR] Beginning Verify and Repair transaction
2021-10-24 01:27:44, Info CSI 000002f3 [SR] Verify complete
2021-10-24 01:27:44, Info CSI 000002f4 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:27:44, Info CSI 000002f5 [SR] Beginning Verify and Repair transaction
2021-10-24 01:27:47, Info CSI 000002f9 [SR] Verify complete
2021-10-24 01:27:48, Info CSI 000002fa [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:27:48, Info CSI 000002fb [SR] Beginning Verify and Repair transaction
2021-10-24 01:27:52, Info CSI 000002fe [SR] Verify complete
2021-10-24 01:27:52, Info CSI 000002ff [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:27:52, Info CSI 00000300 [SR] Beginning Verify and Repair transaction
2021-10-24 01:27:55, Info CSI 00000304 [SR] Verify complete
2021-10-24 01:27:56, Info CSI 00000305 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:27:56, Info CSI 00000306 [SR] Beginning Verify and Repair transaction
2021-10-24 01:28:00, Info CSI 0000030a [SR] Verify complete
2021-10-24 01:28:01, Info CSI 0000030b [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:28:01, Info CSI 0000030c [SR] Beginning Verify and Repair transaction
2021-10-24 01:28:04, Info CSI 0000030f [SR] Verify complete
2021-10-24 01:28:04, Info CSI 00000310 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:28:04, Info CSI 00000311 [SR] Beginning Verify and Repair transaction
2021-10-24 01:28:09, Info CSI 00000314 [SR] Verify complete
2021-10-24 01:28:09, Info CSI 00000315 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:28:09, Info CSI 00000316 [SR] Beginning Verify and Repair transaction
2021-10-24 01:28:12, Info CSI 00000318 [SR] Verify complete
2021-10-24 01:28:12, Info CSI 00000319 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:28:12, Info CSI 0000031a [SR] Beginning Verify and Repair transaction
2021-10-24 01:28:17, Info CSI 0000031c [SR] Verify complete
2021-10-24 01:28:17, Info CSI 0000031d [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:28:17, Info CSI 0000031e [SR] Beginning Verify and Repair transaction
2021-10-24 01:28:23, Info CSI 00000321 [SR] Verify complete
2021-10-24 01:28:23, Info CSI 00000322 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:28:23, Info CSI 00000323 [SR] Beginning Verify and Repair transaction
2021-10-24 01:28:26, Info CSI 00000325 [SR] Verify complete
2021-10-24 01:28:26, Info CSI 00000326 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:28:26, Info CSI 00000327 [SR] Beginning Verify and Repair transaction
2021-10-24 01:28:29, Info CSI 00000329 [SR] Verify complete
2021-10-24 01:28:30, Info CSI 0000032a [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:28:30, Info CSI 0000032b [SR] Beginning Verify and Repair transaction
2021-10-24 01:28:31, Info CSI 0000032d [SR] Verify complete
2021-10-24 01:28:32, Info CSI 0000032e [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:28:32, Info CSI 0000032f [SR] Beginning Verify and Repair transaction
2021-10-24 01:28:35, Info CSI 00000331 [SR] Verify complete
2021-10-24 01:28:36, Info CSI 00000332 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:28:36, Info CSI 00000333 [SR] Beginning Verify and Repair transaction
2021-10-24 01:28:37, Info CSI 00000335 [SR] Verify complete
2021-10-24 01:28:37, Info CSI 00000336 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:28:37, Info CSI 00000337 [SR] Beginning Verify and Repair transaction
2021-10-24 01:28:41, Info CSI 00000339 [SR] Verify complete
2021-10-24 01:28:42, Info CSI 0000033a [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:28:42, Info CSI 0000033b [SR] Beginning Verify and Repair transaction
2021-10-24 01:28:48, Info CSI 0000033d [SR] Verify complete
2021-10-24 01:28:48, Info CSI 0000033e [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:28:48, Info CSI 0000033f [SR] Beginning Verify and Repair transaction
2021-10-24 01:28:51, Info CSI 00000341 [SR] Verify complete
2021-10-24 01:28:51, Info CSI 00000342 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:28:51, Info CSI 00000343 [SR] Beginning Verify and Repair transaction
2021-10-24 01:28:53, Info CSI 00000345 [SR] Verify complete
2021-10-24 01:28:53, Info CSI 00000346 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:28:53, Info CSI 00000347 [SR] Beginning Verify and Repair transaction
2021-10-24 01:28:56, Info CSI 00000349 [SR] Verify complete
2021-10-24 01:28:56, Info CSI 0000034a [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:28:56, Info CSI 0000034b [SR] Beginning Verify and Repair transaction
2021-10-24 01:29:00, Info CSI 0000034d [SR] Verify complete
2021-10-24 01:29:00, Info CSI 0000034e [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:29:00, Info CSI 0000034f [SR] Beginning Verify and Repair transaction
2021-10-24 01:29:07, Info CSI 00000351 [SR] Verify complete
2021-10-24 01:29:07, Info CSI 00000352 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:29:07, Info CSI 00000353 [SR] Beginning Verify and Repair transaction
2021-10-24 01:29:13, Info CSI 00000355 [SR] Verify complete
2021-10-24 01:29:13, Info CSI 00000356 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:29:13, Info CSI 00000357 [SR] Beginning Verify and Repair transaction
2021-10-24 01:29:26, Info CSI 00000359 [SR] Verify complete
2021-10-24 01:29:26, Info CSI 0000035a [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:29:26, Info CSI 0000035b [SR] Beginning Verify and Repair transaction
2021-10-24 01:29:29, Info CSI 0000035d [SR] Verify complete
2021-10-24 01:29:29, Info CSI 0000035e [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:29:29, Info CSI 0000035f [SR] Beginning Verify and Repair transaction
2021-10-24 01:29:31, Info CSI 00000361 [SR] Verify complete
2021-10-24 01:29:31, Info CSI 00000362 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:29:31, Info CSI 00000363 [SR] Beginning Verify and Repair transaction
2021-10-24 01:29:34, Info CSI 00000365 [SR] Verify complete
2021-10-24 01:29:34, Info CSI 00000366 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:29:34, Info CSI 00000367 [SR] Beginning Verify and Repair transaction
2021-10-24 01:29:37, Info CSI 00000369 [SR] Verify complete
2021-10-24 01:29:38, Info CSI 0000036a [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:29:38, Info CSI 0000036b [SR] Beginning Verify and Repair transaction
2021-10-24 01:29:40, Info CSI 0000036d [SR] Verify complete
2021-10-24 01:29:40, Info CSI 0000036e [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:29:40, Info CSI 0000036f [SR] Beginning Verify and Repair transaction
2021-10-24 01:29:42, Info CSI 00000371 [SR] Verify complete
2021-10-24 01:29:42, Info CSI 00000372 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:29:42, Info CSI 00000373 [SR] Beginning Verify and Repair transaction
2021-10-24 01:29:43, Info CSI 00000375 [SR] Verify complete
2021-10-24 01:29:43, Info CSI 00000376 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:29:43, Info CSI 00000377 [SR] Beginning Verify and Repair transaction
2021-10-24 01:29:47, Info CSI 00000379 [SR] Verify complete
2021-10-24 01:29:47, Info CSI 0000037a [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:29:47, Info CSI 0000037b [SR] Beginning Verify and Repair transaction
2021-10-24 01:29:50, Info CSI 0000037d [SR] Verify complete
2021-10-24 01:29:50, Info CSI 0000037e [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:29:50, Info CSI 0000037f [SR] Beginning Verify and Repair transaction
2021-10-24 01:29:53, Info CSI 00000381 [SR] Verify complete
2021-10-24 01:29:53, Info CSI 00000382 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:29:53, Info CSI 00000383 [SR] Beginning Verify and Repair transaction
2021-10-24 01:29:55, Info CSI 00000385 [SR] Verify complete
2021-10-24 01:29:56, Info CSI 00000386 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:29:56, Info CSI 00000387 [SR] Beginning Verify and Repair transaction
2021-10-24 01:29:58, Info CSI 00000389 [SR] Verify complete
2021-10-24 01:29:58, Info CSI 0000038a [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:29:58, Info CSI 0000038b [SR] Beginning Verify and Repair transaction
2021-10-24 01:29:59, Info CSI 0000038d [SR] Verify complete
2021-10-24 01:30:00, Info CSI 0000038e [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:30:00, Info CSI 0000038f [SR] Beginning Verify and Repair transaction
2021-10-24 01:30:00, Info CSI 00000391 [SR] Verify complete
2021-10-24 01:30:01, Info CSI 00000392 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:30:01, Info CSI 00000393 [SR] Beginning Verify and Repair transaction
2021-10-24 01:30:06, Info CSI 000003a1 [SR] Verify complete
2021-10-24 01:30:06, Info CSI 000003a2 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:30:06, Info CSI 000003a3 [SR] Beginning Verify and Repair transaction
2021-10-24 01:30:10, Info CSI 000003a5 [SR] Verify complete
2021-10-24 01:30:10, Info CSI 000003a6 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:30:10, Info CSI 000003a7 [SR] Beginning Verify and Repair transaction
2021-10-24 01:30:14, Info CSI 000003a9 [SR] Verify complete
2021-10-24 01:30:14, Info CSI 000003aa [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:30:14, Info CSI 000003ab [SR] Beginning Verify and Repair transaction
2021-10-24 01:30:17, Info CSI 000003ad [SR] Verify complete
2021-10-24 01:30:18, Info CSI 000003ae [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:30:18, Info CSI 000003af [SR] Beginning Verify and Repair transaction
2021-10-24 01:30:21, Info CSI 000003b1 [SR] Verify complete
2021-10-24 01:30:22, Info CSI 000003b2 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:30:22, Info CSI 000003b3 [SR] Beginning Verify and Repair transaction
2021-10-24 01:30:26, Info CSI 000003b5 [SR] Verify complete
2021-10-24 01:30:27, Info CSI 000003b6 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:30:27, Info CSI 000003b7 [SR] Beginning Verify and Repair transaction
2021-10-24 01:30:30, Info CSI 000003b9 [SR] Verify complete
2021-10-24 01:30:31, Info CSI 000003ba [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:30:31, Info CSI 000003bb [SR] Beginning Verify and Repair transaction
2021-10-24 01:30:35, Info CSI 000003bd [SR] Verify complete
2021-10-24 01:30:35, Info CSI 000003be [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:30:35, Info CSI 000003bf [SR] Beginning Verify and Repair transaction
2021-10-24 01:30:41, Info CSI 000003c1 [SR] Verify complete
2021-10-24 01:30:41, Info CSI 000003c2 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:30:41, Info CSI 000003c3 [SR] Beginning Verify and Repair transaction
2021-10-24 01:30:47, Info CSI 000003c5 [SR] Verify complete
2021-10-24 01:30:47, Info CSI 000003c6 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:30:47, Info CSI 000003c7 [SR] Beginning Verify and Repair transaction
2021-10-24 01:30:48, Info CSI 000003c9 [SR] Verify complete
2021-10-24 01:30:49, Info CSI 000003ca [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:30:49, Info CSI 000003cb [SR] Beginning Verify and Repair transaction
2021-10-24 01:30:52, Info CSI 000003cd [SR] Verify complete
2021-10-24 01:30:53, Info CSI 000003ce [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:30:53, Info CSI 000003cf [SR] Beginning Verify and Repair transaction
2021-10-24 01:31:03, Info CSI 000003d4 [SR] Verify complete
2021-10-24 01:31:03, Info CSI 000003d5 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:31:03, Info CSI 000003d6 [SR] Beginning Verify and Repair transaction
2021-10-24 01:31:14, Info CSI 000003d8 [SR] Verify complete
2021-10-24 01:31:14, Info CSI 000003d9 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:31:14, Info CSI 000003da [SR] Beginning Verify and Repair transaction
2021-10-24 01:31:18, Info CSI 000003df [SR] Verify complete
2021-10-24 01:31:18, Info CSI 000003e0 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:31:18, Info CSI 000003e1 [SR] Beginning Verify and Repair transaction
2021-10-24 01:31:24, Info CSI 000003e3 [SR] Verify complete
2021-10-24 01:31:24, Info CSI 000003e4 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:31:24, Info CSI 000003e5 [SR] Beginning Verify and Repair transaction
2021-10-24 01:31:29, Info CSI 000003f2 [SR] Verify complete
2021-10-24 01:31:30, Info CSI 000003f3 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:31:30, Info CSI 000003f4 [SR] Beginning Verify and Repair transaction
2021-10-24 01:31:36, Info CSI 000003f8 [SR] Verify complete
2021-10-24 01:31:37, Info CSI 000003f9 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:31:37, Info CSI 000003fa [SR] Beginning Verify and Repair transaction
2021-10-24 01:31:41, Info CSI 000003ff [SR] Verify complete
2021-10-24 01:31:41, Info CSI 00000400 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:31:41, Info CSI 00000401 [SR] Beginning Verify and Repair transaction
2021-10-24 01:31:45, Info CSI 00000403 [SR] Verify complete
2021-10-24 01:31:45, Info CSI 00000404 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:31:45, Info CSI 00000405 [SR] Beginning Verify and Repair transaction
2021-10-24 01:31:48, Info CSI 00000407 [SR] Verify complete
2021-10-24 01:31:48, Info CSI 00000408 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:31:48, Info CSI 00000409 [SR] Beginning Verify and Repair transaction
2021-10-24 01:31:51, Info CSI 0000040d [SR] Verify complete
2021-10-24 01:31:52, Info CSI 0000040e [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:31:52, Info CSI 0000040f [SR] Beginning Verify and Repair transaction
2021-10-24 01:31:54, Info CSI 00000411 [SR] Verify complete
2021-10-24 01:31:54, Info CSI 00000412 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:31:54, Info CSI 00000413 [SR] Beginning Verify and Repair transaction
2021-10-24 01:31:59, Info CSI 00000423 [SR] Verify complete
2021-10-24 01:31:59, Info CSI 00000424 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:31:59, Info CSI 00000425 [SR] Beginning Verify and Repair transaction
2021-10-24 01:32:03, Info CSI 0000043c [SR] Verify complete
2021-10-24 01:32:04, Info CSI 0000043d [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:32:04, Info CSI 0000043e [SR] Beginning Verify and Repair transaction
2021-10-24 01:32:07, Info CSI 00000440 [SR] Verify complete
2021-10-24 01:32:07, Info CSI 00000441 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:32:07, Info CSI 00000442 [SR] Beginning Verify and Repair transaction
2021-10-24 01:32:11, Info CSI 00000444 [SR] Verify complete
2021-10-24 01:32:11, Info CSI 00000445 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:32:11, Info CSI 00000446 [SR] Beginning Verify and Repair transaction
2021-10-24 01:32:14, Info CSI 00000448 [SR] Verify complete
2021-10-24 01:32:14, Info CSI 00000449 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:32:14, Info CSI 0000044a [SR] Beginning Verify and Repair transaction
2021-10-24 01:32:18, Info CSI 0000044c [SR] Verify complete
2021-10-24 01:32:18, Info CSI 0000044d [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:32:18, Info CSI 0000044e [SR] Beginning Verify and Repair transaction
2021-10-24 01:32:20, Info CSI 00000450 [SR] Verify complete
2021-10-24 01:32:20, Info CSI 00000451 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:32:20, Info CSI 00000452 [SR] Beginning Verify and Repair transaction
2021-10-24 01:32:25, Info CSI 00000464 [SR] Verify complete
2021-10-24 01:32:25, Info CSI 00000465 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:32:25, Info CSI 00000466 [SR] Beginning Verify and Repair transaction
2021-10-24 01:32:28, Info CSI 00000468 [SR] Verify complete
2021-10-24 01:32:28, Info CSI 00000469 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:32:28, Info CSI 0000046a [SR] Beginning Verify and Repair transaction
2021-10-24 01:32:34, Info CSI 0000046c [SR] Verify complete
2021-10-24 01:32:34, Info CSI 0000046d [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:32:34, Info CSI 0000046e [SR] Beginning Verify and Repair transaction
2021-10-24 01:32:37, Info CSI 00000470 [SR] Verify complete
2021-10-24 01:32:37, Info CSI 00000471 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:32:37, Info CSI 00000472 [SR] Beginning Verify and Repair transaction
2021-10-24 01:32:43, Info CSI 00000480 [SR] Verify complete
2021-10-24 01:32:43, Info CSI 00000481 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:32:43, Info CSI 00000482 [SR] Beginning Verify and Repair transaction
2021-10-24 01:32:45, Info CSI 00000484 [SR] Verify complete
2021-10-24 01:32:46, Info CSI 00000485 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:32:46, Info CSI 00000486 [SR] Beginning Verify and Repair transaction
2021-10-24 01:32:49, Info CSI 00000488 [SR] Verify complete
2021-10-24 01:32:49, Info CSI 00000489 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:32:49, Info CSI 0000048a [SR] Beginning Verify and Repair transaction
2021-10-24 01:32:55, Info CSI 0000048d [SR] Verify complete
2021-10-24 01:32:56, Info CSI 0000048e [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:32:56, Info CSI 0000048f [SR] Beginning Verify and Repair transaction
2021-10-24 01:32:58, Info CSI 00000491 [SR] Verify complete
2021-10-24 01:32:59, Info CSI 00000492 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:32:59, Info CSI 00000493 [SR] Beginning Verify and Repair transaction
2021-10-24 01:33:00, Info CSI 00000495 [SR] Verify complete
2021-10-24 01:33:01, Info CSI 00000496 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:33:01, Info CSI 00000497 [SR] Beginning Verify and Repair transaction
2021-10-24 01:33:03, Info CSI 00000499 [SR] Verify complete
2021-10-24 01:33:03, Info CSI 0000049a [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:33:03, Info CSI 0000049b [SR] Beginning Verify and Repair transaction
2021-10-24 01:33:07, Info CSI 0000049d [SR] Verify complete
2021-10-24 01:33:07, Info CSI 0000049e [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:33:07, Info CSI 0000049f [SR] Beginning Verify and Repair transaction
2021-10-24 01:33:11, Info CSI 000004a1 [SR] Verify complete
2021-10-24 01:33:11, Info CSI 000004a2 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:33:11, Info CSI 000004a3 [SR] Beginning Verify and Repair transaction
2021-10-24 01:33:14, Info CSI 000004a5 [SR] Verify complete
2021-10-24 01:33:14, Info CSI 000004a6 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:33:14, Info CSI 000004a7 [SR] Beginning Verify and Repair transaction
2021-10-24 01:33:17, Info CSI 000004a9 [SR] Verify complete
2021-10-24 01:33:18, Info CSI 000004aa [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:33:18, Info CSI 000004ab [SR] Beginning Verify and Repair transaction
2021-10-24 01:33:24, Info CSI 000004c5 [SR] Verify complete
2021-10-24 01:33:24, Info CSI 000004c6 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:33:24, Info CSI 000004c7 [SR] Beginning Verify and Repair transaction
2021-10-24 01:33:27, Info CSI 000004c9 [SR] Cannot repair member file [l:28{14}]"iassdo.dll.mui" of Microsoft-Windows-Networking-Internet_Authentication_Service_Iassdo.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"en-US", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2021-10-24 01:33:28, Info CSI 000004cb [SR] Cannot repair member file [l:28{14}]"iassdo.dll.mui" of Microsoft-Windows-Networking-Internet_Authentication_Service_Iassdo.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"en-US", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2021-10-24 01:33:28, Info CSI 000004cc [SR] This component was referenced by [l:266{133}]"Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~en-US~6.1.7601.17514.Windows Foundation Language Pack"
2021-10-24 01:33:28, Info CSI 000004cf [SR] Could not reproject corrupted file [ml:60{30},l:58{29}]"\??\C:\Windows\SysWOW64\en-US"\[l:28{14}]"iassdo.dll.mui"; source file in store is also corrupted
2021-10-24 01:33:28, Info CSI 000004d1 [SR] Verify complete
2021-10-24 01:33:29, Info CSI 000004d2 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:33:29, Info CSI 000004d3 [SR] Beginning Verify and Repair transaction
2021-10-24 01:33:31, Info CSI 000004d5 [SR] Verify complete
2021-10-24 01:33:31, Info CSI 000004d6 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:33:31, Info CSI 000004d7 [SR] Beginning Verify and Repair transaction
2021-10-24 01:33:42, Info CSI 000004d9 [SR] Verify complete
2021-10-24 01:33:42, Info CSI 000004da [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:33:42, Info CSI 000004db [SR] Beginning Verify and Repair transaction
2021-10-24 01:33:45, Info CSI 000004dd [SR] Verify complete
2021-10-24 01:33:45, Info CSI 000004de [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:33:45, Info CSI 000004df [SR] Beginning Verify and Repair transaction
2021-10-24 01:33:48, Info CSI 000004e1 [SR] Verify complete
2021-10-24 01:33:49, Info CSI 000004e2 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:33:49, Info CSI 000004e3 [SR] Beginning Verify and Repair transaction
2021-10-24 01:33:51, Info CSI 000004e5 [SR] Verify complete
2021-10-24 01:33:51, Info CSI 000004e6 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:33:51, Info CSI 000004e7 [SR] Beginning Verify and Repair transaction
2021-10-24 01:33:54, Info CSI 000004eb [SR] Verify complete
2021-10-24 01:33:54, Info CSI 000004ec [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:33:54, Info CSI 000004ed [SR] Beginning Verify and Repair transaction
2021-10-24 01:33:56, Info CSI 000004ef [SR] Verify complete
2021-10-24 01:33:56, Info CSI 000004f0 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:33:56, Info CSI 000004f1 [SR] Beginning Verify and Repair transaction
2021-10-24 01:33:58, Info CSI 000004f3 [SR] Verify complete
2021-10-24 01:33:58, Info CSI 000004f4 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:33:58, Info CSI 000004f5 [SR] Beginning Verify and Repair transaction
2021-10-24 01:34:01, Info CSI 000004f7 [SR] Verify complete
2021-10-24 01:34:01, Info CSI 000004f8 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:34:01, Info CSI 000004f9 [SR] Beginning Verify and Repair transaction
2021-10-24 01:34:05, Info CSI 000004fb [SR] Verify complete
2021-10-24 01:34:05, Info CSI 000004fc [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:34:05, Info CSI 000004fd [SR] Beginning Verify and Repair transaction
2021-10-24 01:34:08, Info CSI 000004ff [SR] Verify complete
2021-10-24 01:34:08, Info CSI 00000500 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:34:08, Info CSI 00000501 [SR] Beginning Verify and Repair transaction
2021-10-24 01:34:11, Info CSI 00000503 [SR] Verify complete
2021-10-24 01:34:11, Info CSI 00000504 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:34:11, Info CSI 00000505 [SR] Beginning Verify and Repair transaction
2021-10-24 01:34:14, Info CSI 00000508 [SR] Verify complete
2021-10-24 01:34:15, Info CSI 00000509 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:34:15, Info CSI 0000050a [SR] Beginning Verify and Repair transaction
2021-10-24 01:34:17, Info CSI 0000050c [SR] Verify complete
2021-10-24 01:34:18, Info CSI 0000050d [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:34:18, Info CSI 0000050e [SR] Beginning Verify and Repair transaction
2021-10-24 01:34:20, Info CSI 00000510 [SR] Verify complete
2021-10-24 01:34:21, Info CSI 00000511 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:34:21, Info CSI 00000512 [SR] Beginning Verify and Repair transaction
2021-10-24 01:34:22, Info CSI 00000514 [SR] Verify complete
2021-10-24 01:34:23, Info CSI 00000515 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:34:23, Info CSI 00000516 [SR] Beginning Verify and Repair transaction
2021-10-24 01:34:26, Info CSI 0000051a [SR] Verify complete
2021-10-24 01:34:26, Info CSI 0000051b [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:34:26, Info CSI 0000051c [SR] Beginning Verify and Repair transaction
2021-10-24 01:34:30, Info CSI 0000051e [SR] Verify complete
2021-10-24 01:34:30, Info CSI 0000051f [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:34:30, Info CSI 00000520 [SR] Beginning Verify and Repair transaction
2021-10-24 01:34:32, Info CSI 00000522 [SR] Verify complete
2021-10-24 01:34:33, Info CSI 00000523 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:34:33, Info CSI 00000524 [SR] Beginning Verify and Repair transaction
2021-10-24 01:34:37, Info CSI 00000526 [SR] Verify complete
2021-10-24 01:34:37, Info CSI 00000527 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:34:37, Info CSI 00000528 [SR] Beginning Verify and Repair transaction
2021-10-24 01:34:40, Info CSI 0000052b [SR] Verify complete
2021-10-24 01:34:41, Info CSI 0000052c [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:34:41, Info CSI 0000052d [SR] Beginning Verify and Repair transaction
2021-10-24 01:34:45, Info CSI 0000052f [SR] Verify complete
2021-10-24 01:34:46, Info CSI 00000530 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:34:46, Info CSI 00000531 [SR] Beginning Verify and Repair transaction
2021-10-24 01:34:50, Info CSI 00000533 [SR] Verify complete
2021-10-24 01:34:51, Info CSI 00000534 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:34:51, Info CSI 00000535 [SR] Beginning Verify and Repair transaction
2021-10-24 01:34:55, Info CSI 00000537 [SR] Verify complete
2021-10-24 01:34:55, Info CSI 00000538 [SR] Verifying 82 (0x0000000000000052) components
2021-10-24 01:34:55, Info CSI 00000539 [SR] Beginning Verify and Repair transaction
2021-10-24 01:34:58, Info CSI 0000053b [SR] Verify complete
2021-10-24 01:34:58, Info CSI 0000053c [SR] Repairing 2 components
2021-10-24 01:34:58, Info CSI 0000053d [SR] Beginning Verify and Repair transaction
2021-10-24 01:34:59, Info CSI 0000053f [SR] Cannot repair member file [l:28{14}]"iassdo.dll.mui" of Microsoft-Windows-Networking-Internet_Authentication_Service_Iassdo.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"en-US", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2021-10-24 01:34:59, Info CSI 00000540 [SR] Repairing corrupted file [ml:520{260},l:90{45}]"\??\C:\Program Files\Internet Explorer\images"\[l:16{8}]"bing.ico" from store
2021-10-24 01:34:59, Info CSI 00000542 [SR] Cannot repair member file [l:28{14}]"iassdo.dll.mui" of Microsoft-Windows-Networking-Internet_Authentication_Service_Iassdo.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"en-US", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2021-10-24 01:34:59, Info CSI 00000543 [SR] This component was referenced by [l:266{133}]"Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~en-US~6.1.7601.17514.Windows Foundation Language Pack"
2021-10-24 01:34:59, Info CSI 00000546 [SR] Could not reproject corrupted file [ml:60{30},l:58{29}]"\??\C:\Windows\SysWOW64\en-US"\[l:28{14}]"iassdo.dll.mui"; source file in store is also corrupted
2021-10-24 01:34:59, Info CSI 00000548 [SR] Repair complete
2021-10-24 01:34:59, Info CSI 00000549 [SR] Committing transaction
2021-10-24 01:34:59, Info CSI 0000054d [SR] Verify and Repair Transaction completed. All files and registry keys listed in this transaction have been successfully repaired
2021-11-07 19:25:25, Info CSI 00000009 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:25:25, Info CSI 0000000a [SR] Beginning Verify and Repair transaction
2021-11-07 19:25:30, Info CSI 0000000c [SR] Verify complete
2021-11-07 19:25:32, Info CSI 0000000d [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:25:32, Info CSI 0000000e [SR] Beginning Verify and Repair transaction
2021-11-07 19:25:37, Info CSI 00000010 [SR] Verify complete
2021-11-07 19:25:41, Info CSI 00000011 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:25:41, Info CSI 00000012 [SR] Beginning Verify and Repair transaction
2021-11-07 19:25:45, Info CSI 00000014 [SR] Verify complete
2021-11-07 19:25:48, Info CSI 00000015 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:25:48, Info CSI 00000016 [SR] Beginning Verify and Repair transaction
2021-11-07 19:25:51, Info CSI 00000018 [SR] Verify complete
2021-11-07 19:25:54, Info CSI 00000019 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:25:54, Info CSI 0000001a [SR] Beginning Verify and Repair transaction
2021-11-07 19:25:59, Info CSI 0000001c [SR] Verify complete
2021-11-07 19:26:00, Info CSI 0000001d [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:26:00, Info CSI 0000001e [SR] Beginning Verify and Repair transaction
2021-11-07 19:26:04, Info CSI 00000020 [SR] Verify complete
2021-11-07 19:26:05, Info CSI 00000021 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:26:05, Info CSI 00000022 [SR] Beginning Verify and Repair transaction
2021-11-07 19:26:08, Info CSI 00000024 [SR] Verify complete
2021-11-07 19:26:09, Info CSI 00000025 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:26:09, Info CSI 00000026 [SR] Beginning Verify and Repair transaction
2021-11-07 19:26:10, Info CSI 00000028 [SR] Verify complete
2021-11-07 19:26:12, Info CSI 00000029 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:26:12, Info CSI 0000002a [SR] Beginning Verify and Repair transaction
2021-11-07 19:26:14, Info CSI 0000002c [SR] Verify complete
2021-11-07 19:26:15, Info CSI 0000002d [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:26:15, Info CSI 0000002e [SR] Beginning Verify and Repair transaction
2021-11-07 19:26:17, Info CSI 00000030 [SR] Verify complete
2021-11-07 19:26:18, Info CSI 00000031 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:26:18, Info CSI 00000032 [SR] Beginning Verify and Repair transaction
2021-11-07 19:26:20, Info CSI 00000034 [SR] Verify complete
2021-11-07 19:26:21, Info CSI 00000035 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:26:21, Info CSI 00000036 [SR] Beginning Verify and Repair transaction
2021-11-07 19:26:23, Info CSI 00000038 [SR] Verify complete
2021-11-07 19:26:24, Info CSI 00000039 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:26:24, Info CSI 0000003a [SR] Beginning Verify and Repair transaction
2021-11-07 19:26:26, Info CSI 0000003c [SR] Verify complete
2021-11-07 19:26:27, Info CSI 0000003d [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:26:27, Info CSI 0000003e [SR] Beginning Verify and Repair transaction
2021-11-07 19:26:29, Info CSI 00000040 [SR] Verify complete
2021-11-07 19:26:30, Info CSI 00000041 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:26:30, Info CSI 00000042 [SR] Beginning Verify and Repair transaction
2021-11-07 19:26:32, Info CSI 00000044 [SR] Verify complete
2021-11-07 19:26:33, Info CSI 00000045 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:26:33, Info CSI 00000046 [SR] Beginning Verify and Repair transaction
2021-11-07 19:26:35, Info CSI 00000048 [SR] Verify complete
2021-11-07 19:26:36, Info CSI 00000049 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:26:36, Info CSI 0000004a [SR] Beginning Verify and Repair transaction
2021-11-07 19:26:38, Info CSI 0000004c [SR] Verify complete
2021-11-07 19:26:39, Info CSI 0000004d [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:26:39, Info CSI 0000004e [SR] Beginning Verify and Repair transaction
2021-11-07 19:26:41, Info CSI 00000050 [SR] Verify complete
2021-11-07 19:26:42, Info CSI 00000051 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:26:42, Info CSI 00000052 [SR] Beginning Verify and Repair transaction
2021-11-07 19:26:43, Info CSI 00000054 [SR] Verify complete
2021-11-07 19:26:45, Info CSI 00000055 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:26:45, Info CSI 00000056 [SR] Beginning Verify and Repair transaction
2021-11-07 19:26:46, Info CSI 00000058 [SR] Verify complete
2021-11-07 19:26:47, Info CSI 00000059 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:26:47, Info CSI 0000005a [SR] Beginning Verify and Repair transaction
2021-11-07 19:26:49, Info CSI 0000005c [SR] Verify complete
2021-11-07 19:26:51, Info CSI 0000005d [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:26:51, Info CSI 0000005e [SR] Beginning Verify and Repair transaction
2021-11-07 19:26:52, Info CSI 00000060 [SR] Verify complete
2021-11-07 19:26:53, Info CSI 00000061 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:26:53, Info CSI 00000062 [SR] Beginning Verify and Repair transaction
2021-11-07 19:26:55, Info CSI 00000064 [SR] Verify complete
2021-11-07 19:26:56, Info CSI 00000065 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:26:56, Info CSI 00000066 [SR] Beginning Verify and Repair transaction
2021-11-07 19:26:58, Info CSI 00000068 [SR] Verify complete
2021-11-07 19:26:59, Info CSI 00000069 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:26:59, Info CSI 0000006a [SR] Beginning Verify and Repair transaction
2021-11-07 19:27:01, Info CSI 0000006c [SR] Verify complete
2021-11-07 19:27:02, Info CSI 0000006d [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:27:02, Info CSI 0000006e [SR] Beginning Verify and Repair transaction
2021-11-07 19:27:04, Info CSI 00000070 [SR] Verify complete
2021-11-07 19:27:04, Info CSI 00000071 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:27:04, Info CSI 00000072 [SR] Beginning Verify and Repair transaction
2021-11-07 19:27:06, Info CSI 00000074 [SR] Verify complete
2021-11-07 19:27:07, Info CSI 00000075 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:27:07, Info CSI 00000076 [SR] Beginning Verify and Repair transaction
2021-11-07 19:27:09, Info CSI 00000078 [SR] Verify complete
2021-11-07 19:27:10, Info CSI 00000079 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:27:10, Info CSI 0000007a [SR] Beginning Verify and Repair transaction
2021-11-07 19:27:12, Info CSI 0000007c [SR] Verify complete
2021-11-07 19:27:13, Info CSI 0000007d [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:27:13, Info CSI 0000007e [SR] Beginning Verify and Repair transaction
2021-11-07 19:27:16, Info CSI 00000080 [SR] Verify complete
2021-11-07 19:27:17, Info CSI 00000081 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:27:17, Info CSI 00000082 [SR] Beginning Verify and Repair transaction
2021-11-07 19:27:18, Info CSI 00000084 [SR] Verify complete
2021-11-07 19:27:19, Info CSI 00000085 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:27:19, Info CSI 00000086 [SR] Beginning Verify and Repair transaction
2021-11-07 19:27:21, Info CSI 00000088 [SR] Verify complete
2021-11-07 19:27:22, Info CSI 00000089 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:27:22, Info CSI 0000008a [SR] Beginning Verify and Repair transaction
2021-11-07 19:27:23, Info CSI 0000008c [SR] Verify complete
2021-11-07 19:27:24, Info CSI 0000008d [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:27:24, Info CSI 0000008e [SR] Beginning Verify and Repair transaction
2021-11-07 19:27:26, Info CSI 00000090 [SR] Verify complete
2021-11-07 19:27:27, Info CSI 00000091 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:27:27, Info CSI 00000092 [SR] Beginning Verify and Repair transaction
2021-11-07 19:27:28, Info CSI 00000094 [SR] Verify complete
2021-11-07 19:27:30, Info CSI 00000095 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:27:30, Info CSI 00000096 [SR] Beginning Verify and Repair transaction
2021-11-07 19:27:31, Info CSI 00000098 [SR] Verify complete
2021-11-07 19:27:31, Info CSI 00000099 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:27:31, Info CSI 0000009a [SR] Beginning Verify and Repair transaction
2021-11-07 19:27:33, Info CSI 0000009c [SR] Verify complete
2021-11-07 19:27:35, Info CSI 0000009d [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:27:35, Info CSI 0000009e [SR] Beginning Verify and Repair transaction
2021-11-07 19:27:36, Info CSI 000000a0 [SR] Verify complete
2021-11-07 19:27:37, Info CSI 000000a1 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:27:37, Info CSI 000000a2 [SR] Beginning Verify and Repair transaction
2021-11-07 19:27:38, Info CSI 000000a4 [SR] Verify complete
2021-11-07 19:27:39, Info CSI 000000a5 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:27:39, Info CSI 000000a6 [SR] Beginning Verify and Repair transaction
2021-11-07 19:27:41, Info CSI 000000a8 [SR] Verify complete
2021-11-07 19:27:42, Info CSI 000000a9 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:27:42, Info CSI 000000aa [SR] Beginning Verify and Repair transaction
2021-11-07 19:27:45, Info CSI 000000ac [SR] Verify complete
2021-11-07 19:27:46, Info CSI 000000ad [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:27:46, Info CSI 000000ae [SR] Beginning Verify and Repair transaction
2021-11-07 19:27:48, Info CSI 000000b0 [SR] Verify complete
2021-11-07 19:27:49, Info CSI 000000b1 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:27:49, Info CSI 000000b2 [SR] Beginning Verify and Repair transaction
2021-11-07 19:27:50, Info CSI 000000b4 [SR] Verify complete
2021-11-07 19:27:51, Info CSI 000000b5 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:27:51, Info CSI 000000b6 [SR] Beginning Verify and Repair transaction
2021-11-07 19:27:53, Info CSI 000000b8 [SR] Verify complete
2021-11-07 19:27:54, Info CSI 000000b9 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:27:54, Info CSI 000000ba [SR] Beginning Verify and Repair transaction
2021-11-07 19:27:57, Info CSI 000000bc [SR] Verify complete
2021-11-07 19:27:58, Info CSI 000000bd [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:27:58, Info CSI 000000be [SR] Beginning Verify and Repair transaction
2021-11-07 19:28:01, Info CSI 000000c0 [SR] Verify complete
2021-11-07 19:28:01, Info CSI 000000c1 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:28:01, Info CSI 000000c2 [SR] Beginning Verify and Repair transaction
2021-11-07 19:28:03, Info CSI 000000c4 [SR] Verify complete
2021-11-07 19:28:04, Info CSI 000000c5 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:28:04, Info CSI 000000c6 [SR] Beginning Verify and Repair transaction
2021-11-07 19:28:05, Info CSI 000000c8 [SR] Verify complete
2021-11-07 19:28:07, Info CSI 000000c9 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:28:07, Info CSI 000000ca [SR] Beginning Verify and Repair transaction
2021-11-07 19:28:08, Info CSI 000000cc [SR] Verify complete
2021-11-07 19:28:09, Info CSI 000000cd [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:28:09, Info CSI 000000ce [SR] Beginning Verify and Repair transaction
2021-11-07 19:28:12, Info CSI 000000d0 [SR] Verify complete
2021-11-07 19:28:13, Info CSI 000000d1 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:28:13, Info CSI 000000d2 [SR] Beginning Verify and Repair transaction
2021-11-07 19:28:14, Info CSI 000000d4 [SR] Verify complete
2021-11-07 19:28:16, Info CSI 000000d5 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:28:16, Info CSI 000000d6 [SR] Beginning Verify and Repair transaction
2021-11-07 19:28:16, Info CSI 000000d8 [SR] Verify complete
2021-11-07 19:28:17, Info CSI 000000d9 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:28:17, Info CSI 000000da [SR] Beginning Verify and Repair transaction
2021-11-07 19:28:20, Info CSI 000000dc [SR] Verify complete
2021-11-07 19:28:20, Info CSI 000000dd [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:28:20, Info CSI 000000de [SR] Beginning Verify and Repair transaction
2021-11-07 19:28:24, Info CSI 000000e0 [SR] Verify complete
2021-11-07 19:28:25, Info CSI 000000e1 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:28:25, Info CSI 000000e2 [SR] Beginning Verify and Repair transaction
2021-11-07 19:28:26, Info CSI 000000e4 [SR] Verify complete
2021-11-07 19:28:27, Info CSI 000000e5 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:28:27, Info CSI 000000e6 [SR] Beginning Verify and Repair transaction
2021-11-07 19:28:29, Info CSI 000000e8 [SR] Verify complete
2021-11-07 19:28:29, Info CSI 000000e9 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:28:29, Info CSI 000000ea [SR] Beginning Verify and Repair transaction
2021-11-07 19:28:31, Info CSI 000000ec [SR] Verify complete
2021-11-07 19:28:32, Info CSI 000000ed [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:28:32, Info CSI 000000ee [SR] Beginning Verify and Repair transaction
2021-11-07 19:28:34, Info CSI 000000f0 [SR] Verify complete
2021-11-07 19:28:35, Info CSI 000000f1 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:28:35, Info CSI 000000f2 [SR] Beginning Verify and Repair transaction
2021-11-07 19:28:36, Info CSI 000000f4 [SR] Verify complete
2021-11-07 19:28:37, Info CSI 000000f5 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:28:37, Info CSI 000000f6 [SR] Beginning Verify and Repair transaction
2021-11-07 19:28:38, Info CSI 000000f8 [SR] Verify complete
2021-11-07 19:28:39, Info CSI 000000f9 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:28:39, Info CSI 000000fa [SR] Beginning Verify and Repair transaction
2021-11-07 19:28:41, Info CSI 000000fc [SR] Verify complete
2021-11-07 19:28:42, Info CSI 000000fd [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:28:42, Info CSI 000000fe [SR] Beginning Verify and Repair transaction
2021-11-07 19:28:45, Info CSI 00000100 [SR] Verify complete
2021-11-07 19:28:46, Info CSI 00000101 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:28:46, Info CSI 00000102 [SR] Beginning Verify and Repair transaction
2021-11-07 19:28:50, Info CSI 00000104 [SR] Verify complete
2021-11-07 19:28:51, Info CSI 00000105 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:28:51, Info CSI 00000106 [SR] Beginning Verify and Repair transaction
2021-11-07 19:28:55, Info CSI 00000108 [SR] Verify complete
2021-11-07 19:28:55, Info CSI 00000109 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:28:55, Info CSI 0000010a [SR] Beginning Verify and Repair transaction
2021-11-07 19:28:58, Info CSI 0000010c [SR] Verify complete
2021-11-07 19:28:58, Info CSI 0000010d [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:28:58, Info CSI 0000010e [SR] Beginning Verify and Repair transaction
2021-11-07 19:29:00, Info CSI 00000110 [SR] Verify complete
2021-11-07 19:29:01, Info CSI 00000111 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:29:01, Info CSI 00000112 [SR] Beginning Verify and Repair transaction
2021-11-07 19:29:04, Info CSI 00000114 [SR] Verify complete
2021-11-07 19:29:04, Info CSI 00000115 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:29:04, Info CSI 00000116 [SR] Beginning Verify and Repair transaction
2021-11-07 19:29:10, Info CSI 00000118 [SR] Verify complete
2021-11-07 19:29:10, Info CSI 00000119 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:29:10, Info CSI 0000011a [SR] Beginning Verify and Repair transaction
2021-11-07 19:29:18, Info CSI 0000011d [SR] Verify complete
2021-11-07 19:29:18, Info CSI 0000011e [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:29:18, Info CSI 0000011f [SR] Beginning Verify and Repair transaction
2021-11-07 19:29:24, Info CSI 00000122 [SR] Verify complete
2021-11-07 19:29:24, Info CSI 00000123 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:29:24, Info CSI 00000124 [SR] Beginning Verify and Repair transaction
2021-11-07 19:29:30, Info CSI 00000127 [SR] Verify complete
2021-11-07 19:29:31, Info CSI 00000128 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:29:31, Info CSI 00000129 [SR] Beginning Verify and Repair transaction
2021-11-07 19:29:35, Info CSI 0000012c [SR] Verify complete
2021-11-07 19:29:36, Info CSI 0000012d [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:29:36, Info CSI 0000012e [SR] Beginning Verify and Repair transaction
2021-11-07 19:29:41, Info CSI 00000133 [SR] Verify complete
2021-11-07 19:29:42, Info CSI 00000134 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:29:42, Info CSI 00000135 [SR] Beginning Verify and Repair transaction
2021-11-07 19:29:46, Info CSI 00000137 [SR] Verify complete
2021-11-07 19:29:47, Info CSI 00000138 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:29:47, Info CSI 00000139 [SR] Beginning Verify and Repair transaction
2021-11-07 19:29:54, Info CSI 0000013b [SR] Verify complete
2021-11-07 19:29:54, Info CSI 0000013c [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:29:54, Info CSI 0000013d [SR] Beginning Verify and Repair transaction
2021-11-07 19:30:00, Info CSI 0000015f [SR] Verify complete
2021-11-07 19:30:00, Info CSI 00000160 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:30:00, Info CSI 00000161 [SR] Beginning Verify and Repair transaction
2021-11-07 19:30:06, Info CSI 00000166 [SR] Verify complete
2021-11-07 19:30:06, Info CSI 00000167 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:30:06, Info CSI 00000168 [SR] Beginning Verify and Repair transaction
2021-11-07 19:30:10, Info CSI 0000016a [SR] Verify complete
2021-11-07 19:30:11, Info CSI 0000016b [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:30:11, Info CSI 0000016c [SR] Beginning Verify and Repair transaction
2021-11-07 19:30:16, Info CSI 0000016e [SR] Verify complete
2021-11-07 19:30:16, Info CSI 0000016f [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:30:16, Info CSI 00000170 [SR] Beginning Verify and Repair transaction
2021-11-07 19:30:20, Info CSI 00000172 [SR] Verify complete
2021-11-07 19:30:20, Info CSI 00000173 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:30:20, Info CSI 00000174 [SR] Beginning Verify and Repair transaction
2021-11-07 19:30:24, Info CSI 00000176 [SR] Verify complete
2021-11-07 19:30:25, Info CSI 00000177 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:30:25, Info CSI 00000178 [SR] Beginning Verify and Repair transaction
2021-11-07 19:30:30, Info CSI 0000017a [SR] Verify complete
2021-11-07 19:30:30, Info CSI 0000017b [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:30:30, Info CSI 0000017c [SR] Beginning Verify and Repair transaction
2021-11-07 19:30:34, Info CSI 0000017e [SR] Verify complete
2021-11-07 19:30:34, Info CSI 0000017f [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:30:34, Info CSI 00000180 [SR] Beginning Verify and Repair transaction
2021-11-07 19:30:38, Info CSI 00000182 [SR] Verify complete
2021-11-07 19:30:38, Info CSI 00000183 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:30:38, Info CSI 00000184 [SR] Beginning Verify and Repair transaction
2021-11-07 19:30:41, Info CSI 00000186 [SR] Verify complete
2021-11-07 19:30:41, Info CSI 00000187 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:30:41, Info CSI 00000188 [SR] Beginning Verify and Repair transaction
2021-11-07 19:30:47, Info CSI 0000018a [SR] Verify complete
2021-11-07 19:30:47, Info CSI 0000018b [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:30:47, Info CSI 0000018c [SR] Beginning Verify and Repair transaction
2021-11-07 19:30:54, Info CSI 000001aa [SR] Verify complete
2021-11-07 19:30:55, Info CSI 000001ab [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:30:55, Info CSI 000001ac [SR] Beginning Verify and Repair transaction
2021-11-07 19:31:00, Info CSI 000001cd [SR] Verify complete
2021-11-07 19:31:00, Info CSI 000001ce [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:31:00, Info CSI 000001cf [SR] Beginning Verify and Repair transaction
2021-11-07 19:31:10, Info CSI 000001d1 [SR] Verify complete
2021-11-07 19:31:11, Info CSI 000001d2 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:31:11, Info CSI 000001d3 [SR] Beginning Verify and Repair transaction
2021-11-07 19:31:18, Info CSI 000001d5 [SR] Verify complete
2021-11-07 19:31:18, Info CSI 000001d6 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:31:18, Info CSI 000001d7 [SR] Beginning Verify and Repair transaction
2021-11-07 19:31:27, Info CSI 000001d9 [SR] Verify complete
2021-11-07 19:31:27, Info CSI 000001da [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:31:27, Info CSI 000001db [SR] Beginning Verify and Repair transaction
2021-11-07 19:31:31, Info CSI 000001df [SR] Verify complete
2021-11-07 19:31:31, Info CSI 000001e0 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:31:31, Info CSI 000001e1 [SR] Beginning Verify and Repair transaction
2021-11-07 19:31:34, Info CSI 000001e3 [SR] Verify complete
2021-11-07 19:31:34, Info CSI 000001e4 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:31:34, Info CSI 000001e5 [SR] Beginning Verify and Repair transaction
2021-11-07 19:31:38, Info CSI 000001e7 [SR] Verify complete
2021-11-07 19:31:38, Info CSI 000001e8 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:31:38, Info CSI 000001e9 [SR] Beginning Verify and Repair transaction
2021-11-07 19:31:40, Info CSI 000001eb [SR] Verify complete
2021-11-07 19:31:40, Info CSI 000001ec [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:31:40, Info CSI 000001ed [SR] Beginning Verify and Repair transaction
2021-11-07 19:31:41, Info CSI 000001ef [SR] Verify complete
2021-11-07 19:31:42, Info CSI 000001f0 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:31:42, Info CSI 000001f1 [SR] Beginning Verify and Repair transaction
2021-11-07 19:31:44, Info CSI 000001f3 [SR] Verify complete
2021-11-07 19:31:45, Info CSI 000001f4 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:31:45, Info CSI 000001f5 [SR] Beginning Verify and Repair transaction
2021-11-07 19:31:48, Info CSI 000001f7 [SR] Verify complete
2021-11-07 19:31:49, Info CSI 000001f8 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:31:49, Info CSI 000001f9 [SR] Beginning Verify and Repair transaction
2021-11-07 19:31:56, Info CSI 0000020c [SR] Verify complete
2021-11-07 19:31:57, Info CSI 0000020d [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:31:57, Info CSI 0000020e [SR] Beginning Verify and Repair transaction
2021-11-07 19:31:58, Info CSI 00000210 [SR] Verify complete
2021-11-07 19:31:59, Info CSI 00000211 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:31:59, Info CSI 00000212 [SR] Beginning Verify and Repair transaction
2021-11-07 19:32:03, Info CSI 00000214 [SR] Verify complete
2021-11-07 19:32:03, Info CSI 00000215 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:32:03, Info CSI 00000216 [SR] Beginning Verify and Repair transaction
2021-11-07 19:32:06, Info CSI 00000218 [SR] Verify complete
2021-11-07 19:32:07, Info CSI 00000219 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:32:07, Info CSI 0000021a [SR] Beginning Verify and Repair transaction
2021-11-07 19:32:12, Info CSI 0000021c [SR] Verify complete
2021-11-07 19:32:12, Info CSI 0000021d [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:32:12, Info CSI 0000021e [SR] Beginning Verify and Repair transaction
2021-11-07 19:32:17, Info CSI 00000221 [SR] Verify complete
2021-11-07 19:32:18, Info CSI 00000222 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:32:18, Info CSI 00000223 [SR] Beginning Verify and Repair transaction
2021-11-07 19:32:32, Info CSI 00000226 [SR] Verify complete
2021-11-07 19:32:32, Info CSI 00000227 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:32:32, Info CSI 00000228 [SR] Beginning Verify and Repair transaction
2021-11-07 19:32:37, Info CSI 0000022a [SR] Verify complete
2021-11-07 19:32:38, Info CSI 0000022b [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:32:38, Info CSI 0000022c [SR] Beginning Verify and Repair transaction
2021-11-07 19:32:42, Info CSI 0000022e [SR] Verify complete
2021-11-07 19:32:42, Info CSI 0000022f [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:32:42, Info CSI 00000230 [SR] Beginning Verify and Repair transaction
2021-11-07 19:32:45, Info CSI 00000232 [SR] Verify complete
2021-11-07 19:32:45, Info CSI 00000233 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:32:45, Info CSI 00000234 [SR] Beginning Verify and Repair transaction
2021-11-07 19:32:48, Info CSI 00000236 [SR] Verify complete
2021-11-07 19:32:48, Info CSI 00000237 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:32:48, Info CSI 00000238 [SR] Beginning Verify and Repair transaction
2021-11-07 19:32:53, Info CSI 0000023a [SR] Verify complete
2021-11-07 19:32:53, Info CSI 0000023b [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:32:53, Info CSI 0000023c [SR] Beginning Verify and Repair transaction
2021-11-07 19:33:00, Info CSI 0000023e [SR] Verify complete
2021-11-07 19:33:00, Info CSI 0000023f [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:33:00, Info CSI 00000240 [SR] Beginning Verify and Repair transaction
2021-11-07 19:33:04, Info CSI 00000242 [SR] Verify complete
2021-11-07 19:33:05, Info CSI 00000243 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:33:05, Info CSI 00000244 [SR] Beginning Verify and Repair transaction
2021-11-07 19:33:09, Info CSI 00000246 [SR] Verify complete
2021-11-07 19:33:09, Info CSI 00000247 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:33:09, Info CSI 00000248 [SR] Beginning Verify and Repair transaction
2021-11-07 19:33:14, Info CSI 0000024a [SR] Verify complete
2021-11-07 19:33:15, Info CSI 0000024b [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:33:15, Info CSI 0000024c [SR] Beginning Verify and Repair transaction
2021-11-07 19:33:24, Info CSI 00000260 [SR] Verify complete
2021-11-07 19:33:25, Info CSI 00000261 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:33:25, Info CSI 00000262 [SR] Beginning Verify and Repair transaction
2021-11-07 19:33:29, Info CSI 00000268 [SR] Verify complete
2021-11-07 19:33:30, Info CSI 00000269 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:33:30, Info CSI 0000026a [SR] Beginning Verify and Repair transaction
2021-11-07 19:33:36, Info CSI 0000026c [SR] Verify complete
2021-11-07 19:33:36, Info CSI 0000026d [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:33:36, Info CSI 0000026e [SR] Beginning Verify and Repair transaction
2021-11-07 19:33:40, Info CSI 00000270 [SR] Verify complete
2021-11-07 19:33:41, Info CSI 00000271 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:33:41, Info CSI 00000272 [SR] Beginning Verify and Repair transaction
2021-11-07 19:33:57, Info CSI 00000274 [SR] Verify complete
2021-11-07 19:33:58, Info CSI 00000275 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:33:58, Info CSI 00000276 [SR] Beginning Verify and Repair transaction
2021-11-07 19:34:03, Info CSI 00000278 [SR] Verify complete
2021-11-07 19:34:04, Info CSI 00000279 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:34:04, Info CSI 0000027a [SR] Beginning Verify and Repair transaction
2021-11-07 19:34:11, Info CSI 0000027d [SR] Verify complete
2021-11-07 19:34:12, Info CSI 0000027e [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:34:12, Info CSI 0000027f [SR] Beginning Verify and Repair transaction
2021-11-07 19:34:18, Info CSI 00000281 [SR] Verify complete
2021-11-07 19:34:19, Info CSI 00000282 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:34:19, Info CSI 00000283 [SR] Beginning Verify and Repair transaction
2021-11-07 19:34:26, Info CSI 00000285 [SR] Verify complete
2021-11-07 19:34:26, Info CSI 00000286 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:34:26, Info CSI 00000287 [SR] Beginning Verify and Repair transaction
2021-11-07 19:34:32, Info CSI 0000028b [SR] Verify complete
2021-11-07 19:34:33, Info CSI 0000028c [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:34:33, Info CSI 0000028d [SR] Beginning Verify and Repair transaction
2021-11-07 19:34:37, Info CSI 0000028f [SR] Verify complete
2021-11-07 19:34:37, Info CSI 00000290 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:34:37, Info CSI 00000291 [SR] Beginning Verify and Repair transaction
2021-11-07 19:34:42, Info CSI 00000293 [SR] Verify complete
2021-11-07 19:34:42, Info CSI 00000294 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:34:42, Info CSI 00000295 [SR] Beginning Verify and Repair transaction
2021-11-07 19:34:47, Info CSI 00000297 [SR] Verify complete
2021-11-07 19:34:48, Info CSI 00000298 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:34:48, Info CSI 00000299 [SR] Beginning Verify and Repair transaction
2021-11-07 19:34:50, Info CSI 0000029b [SR] Verify complete
2021-11-07 19:34:51, Info CSI 0000029c [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:34:51, Info CSI 0000029d [SR] Beginning Verify and Repair transaction
2021-11-07 19:34:55, Info CSI 000002a1 [SR] Verify complete
2021-11-07 19:34:56, Info CSI 000002a2 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:34:56, Info CSI 000002a3 [SR] Beginning Verify and Repair transaction
2021-11-07 19:35:00, Info CSI 000002a5 [SR] Verify complete
2021-11-07 19:35:01, Info CSI 000002a6 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:35:01, Info CSI 000002a7 [SR] Beginning Verify and Repair transaction
2021-11-07 19:35:05, Info CSI 000002a9 [SR] Verify complete
2021-11-07 19:35:06, Info CSI 000002aa [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:35:06, Info CSI 000002ab [SR] Beginning Verify and Repair transaction
2021-11-07 19:35:20, Info CSI 000002ad [SR] Verify complete
2021-11-07 19:35:20, Info CSI 000002ae [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:35:20, Info CSI 000002af [SR] Beginning Verify and Repair transaction
2021-11-07 19:35:25, Info CSI 000002b1 [SR] Verify complete
2021-11-07 19:35:26, Info CSI 000002b2 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:35:26, Info CSI 000002b3 [SR] Beginning Verify and Repair transaction
2021-11-07 19:35:32, Info CSI 000002b6 [SR] Verify complete
2021-11-07 19:35:33, Info CSI 000002b7 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:35:33, Info CSI 000002b8 [SR] Beginning Verify and Repair transaction
2021-11-07 19:35:38, Info CSI 000002ba [SR] Verify complete
2021-11-07 19:35:38, Info CSI 000002bb [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:35:38, Info CSI 000002bc [SR] Beginning Verify and Repair transaction
2021-11-07 19:35:42, Info CSI 000002be [SR] Verify complete
2021-11-07 19:35:43, Info CSI 000002bf [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:35:43, Info CSI 000002c0 [SR] Beginning Verify and Repair transaction
2021-11-07 19:35:47, Info CSI 000002c3 [SR] Verify complete
2021-11-07 19:35:48, Info CSI 000002c4 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:35:48, Info CSI 000002c5 [SR] Beginning Verify and Repair transaction
2021-11-07 19:35:54, Info CSI 000002c7 [SR] Verify complete
2021-11-07 19:35:54, Info CSI 000002c8 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:35:54, Info CSI 000002c9 [SR] Beginning Verify and Repair transaction
2021-11-07 19:36:02, Info CSI 000002cb [SR] Verify complete
2021-11-07 19:36:02, Info CSI 000002cc [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:36:02, Info CSI 000002cd [SR] Beginning Verify and Repair transaction
2021-11-07 19:36:10, Info CSI 000002d0 [SR] Verify complete
2021-11-07 19:36:10, Info CSI 000002d1 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:36:10, Info CSI 000002d2 [SR] Beginning Verify and Repair transaction
2021-11-07 19:36:15, Info CSI 000002d4 [SR] Verify complete
2021-11-07 19:36:16, Info CSI 000002d5 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:36:16, Info CSI 000002d6 [SR] Beginning Verify and Repair transaction
2021-11-07 19:36:20, Info CSI 000002d8 [SR] Verify complete
2021-11-07 19:36:21, Info CSI 000002d9 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:36:21, Info CSI 000002da [SR] Beginning Verify and Repair transaction
2021-11-07 19:36:26, Info CSI 000002dc [SR] Verify complete
2021-11-07 19:36:27, Info CSI 000002dd [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:36:27, Info CSI 000002de [SR] Beginning Verify and Repair transaction
2021-11-07 19:36:32, Info CSI 000002e0 [SR] Verify complete
2021-11-07 19:36:33, Info CSI 000002e1 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:36:33, Info CSI 000002e2 [SR] Beginning Verify and Repair transaction
2021-11-07 19:36:36, Info CSI 000002e5 [SR] Verify complete
2021-11-07 19:36:37, Info CSI 000002e6 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:36:37, Info CSI 000002e7 [SR] Beginning Verify and Repair transaction
2021-11-07 19:36:42, Info CSI 000002e9 [SR] Verify complete
2021-11-07 19:36:43, Info CSI 000002ea [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:36:43, Info CSI 000002eb [SR] Beginning Verify and Repair transaction
2021-11-07 19:36:47, Info CSI 000002ed [SR] Verify complete
2021-11-07 19:36:48, Info CSI 000002ee [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:36:48, Info CSI 000002ef [SR] Beginning Verify and Repair transaction
2021-11-07 19:36:50, Info CSI 000002f2 [SR] Verify complete
2021-11-07 19:36:51, Info CSI 000002f3 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:36:51, Info CSI 000002f4 [SR] Beginning Verify and Repair transaction
2021-11-07 19:36:55, Info CSI 000002f8 [SR] Verify complete
2021-11-07 19:36:56, Info CSI 000002f9 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:36:56, Info CSI 000002fa [SR] Beginning Verify and Repair transaction
2021-11-07 19:37:02, Info CSI 000002fd [SR] Verify complete
2021-11-07 19:37:02, Info CSI 000002fe [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:37:02, Info CSI 000002ff [SR] Beginning Verify and Repair transaction
2021-11-07 19:37:06, Info CSI 00000303 [SR] Verify complete
2021-11-07 19:37:06, Info CSI 00000304 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:37:06, Info CSI 00000305 [SR] Beginning Verify and Repair transaction
2021-11-07 19:37:13, Info CSI 00000309 [SR] Verify complete
2021-11-07 19:37:14, Info CSI 0000030a [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:37:14, Info CSI 0000030b [SR] Beginning Verify and Repair transaction
2021-11-07 19:37:18, Info CSI 0000030e [SR] Verify complete
2021-11-07 19:37:18, Info CSI 0000030f [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:37:18, Info CSI 00000310 [SR] Beginning Verify and Repair transaction
2021-11-07 19:37:24, Info CSI 00000313 [SR] Verify complete
2021-11-07 19:37:25, Info CSI 00000314 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:37:25, Info CSI 00000315 [SR] Beginning Verify and Repair transaction
2021-11-07 19:37:27, Info CSI 00000317 [SR] Verify complete
2021-11-07 19:37:28, Info CSI 00000318 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:37:28, Info CSI 00000319 [SR] Beginning Verify and Repair transaction
2021-11-07 19:37:34, Info CSI 0000031b [SR] Verify complete
2021-11-07 19:37:35, Info CSI 0000031c [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:37:35, Info CSI 0000031d [SR] Beginning Verify and Repair transaction
2021-11-07 19:37:43, Info CSI 00000320 [SR] Verify complete
2021-11-07 19:37:43, Info CSI 00000321 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:37:43, Info CSI 00000322 [SR] Beginning Verify and Repair transaction
2021-11-07 19:37:47, Info CSI 00000324 [SR] Verify complete
2021-11-07 19:37:48, Info CSI 00000325 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:37:48, Info CSI 00000326 [SR] Beginning Verify and Repair transaction
2021-11-07 19:37:52, Info CSI 00000328 [SR] Verify complete
2021-11-07 19:37:52, Info CSI 00000329 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:37:52, Info CSI 0000032a [SR] Beginning Verify and Repair transaction
2021-11-07 19:37:55, Info CSI 0000032c [SR] Verify complete
2021-11-07 19:37:56, Info CSI 0000032d [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:37:56, Info CSI 0000032e [SR] Beginning Verify and Repair transaction
2021-11-07 19:38:02, Info CSI 00000330 [SR] Verify complete
2021-11-07 19:38:03, Info CSI 00000331 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:38:03, Info CSI 00000332 [SR] Beginning Verify and Repair transaction
2021-11-07 19:38:05, Info CSI 00000334 [SR] Verify complete
2021-11-07 19:38:06, Info CSI 00000335 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:38:06, Info CSI 00000336 [SR] Beginning Verify and Repair transaction
2021-11-07 19:38:12, Info CSI 00000338 [SR] Verify complete
2021-11-07 19:38:14, Info CSI 00000339 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:38:14, Info CSI 0000033a [SR] Beginning Verify and Repair transaction
2021-11-07 19:38:21, Info CSI 0000033c [SR] Verify complete
2021-11-07 19:38:21, Info CSI 0000033d [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:38:21, Info CSI 0000033e [SR] Beginning Verify and Repair transaction
2021-11-07 19:38:25, Info CSI 00000340 [SR] Verify complete
2021-11-07 19:38:25, Info CSI 00000341 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:38:25, Info CSI 00000342 [SR] Beginning Verify and Repair transaction
2021-11-07 19:38:28, Info CSI 00000344 [SR] Verify complete
2021-11-07 19:38:28, Info CSI 00000345 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:38:28, Info CSI 00000346 [SR] Beginning Verify and Repair transaction
2021-11-07 19:38:30, Info CSI 00000348 [SR] Verify complete
2021-11-07 19:38:31, Info CSI 00000349 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:38:31, Info CSI 0000034a [SR] Beginning Verify and Repair transaction
2021-11-07 19:38:40, Info CSI 0000034c [SR] Verify complete
2021-11-07 19:38:40, Info CSI 0000034d [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:38:40, Info CSI 0000034e [SR] Beginning Verify and Repair transaction
2021-11-07 19:38:52, Info CSI 00000350 [SR] Verify complete
2021-11-07 19:38:53, Info CSI 00000351 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:38:53, Info CSI 00000352 [SR] Beginning Verify and Repair transaction
2021-11-07 19:39:01, Info CSI 00000354 [SR] Verify complete
2021-11-07 19:39:02, Info CSI 00000355 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:39:02, Info CSI 00000356 [SR] Beginning Verify and Repair transaction
2021-11-07 19:39:12, Info CSI 00000358 [SR] Verify complete
2021-11-07 19:39:13, Info CSI 00000359 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:39:13, Info CSI 0000035a [SR] Beginning Verify and Repair transaction
2021-11-07 19:39:15, Info CSI 0000035c [SR] Verify complete
2021-11-07 19:39:15, Info CSI 0000035d [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:39:15, Info CSI 0000035e [SR] Beginning Verify and Repair transaction
2021-11-07 19:39:17, Info CSI 00000360 [SR] Verify complete
2021-11-07 19:39:17, Info CSI 00000361 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:39:17, Info CSI 00000362 [SR] Beginning Verify and Repair transaction
2021-11-07 19:39:19, Info CSI 00000364 [SR] Verify complete
2021-11-07 19:39:19, Info CSI 00000365 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:39:19, Info CSI 00000366 [SR] Beginning Verify and Repair transaction
2021-11-07 19:39:22, Info CSI 00000368 [SR] Verify complete
2021-11-07 19:39:22, Info CSI 00000369 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:39:22, Info CSI 0000036a [SR] Beginning Verify and Repair transaction
2021-11-07 19:39:24, Info CSI 0000036c [SR] Verify complete
2021-11-07 19:39:24, Info CSI 0000036d [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:39:24, Info CSI 0000036e [SR] Beginning Verify and Repair transaction
2021-11-07 19:39:25, Info CSI 00000370 [SR] Verify complete
2021-11-07 19:39:26, Info CSI 00000371 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:39:26, Info CSI 00000372 [SR] Beginning Verify and Repair transaction
2021-11-07 19:39:27, Info CSI 00000374 [SR] Verify complete
2021-11-07 19:39:27, Info CSI 00000375 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:39:27, Info CSI 00000376 [SR] Beginning Verify and Repair transaction
2021-11-07 19:39:29, Info CSI 00000378 [SR] Verify complete
2021-11-07 19:39:29, Info CSI 00000379 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:39:29, Info CSI 0000037a [SR] Beginning Verify and Repair transaction
2021-11-07 19:39:32, Info CSI 0000037c [SR] Verify complete
2021-11-07 19:39:32, Info CSI 0000037d [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:39:32, Info CSI 0000037e [SR] Beginning Verify and Repair transaction
2021-11-07 19:39:34, Info CSI 00000380 [SR] Verify complete
2021-11-07 19:39:35, Info CSI 00000381 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:39:35, Info CSI 00000382 [SR] Beginning Verify and Repair transaction
2021-11-07 19:39:36, Info CSI 00000384 [SR] Verify complete
2021-11-07 19:39:36, Info CSI 00000385 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:39:36, Info CSI 00000386 [SR] Beginning Verify and Repair transaction
2021-11-07 19:39:39, Info CSI 00000388 [SR] Verify complete
2021-11-07 19:39:39, Info CSI 00000389 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:39:39, Info CSI 0000038a [SR] Beginning Verify and Repair transaction
2021-11-07 19:39:40, Info CSI 0000038c [SR] Verify complete
2021-11-07 19:39:40, Info CSI 0000038d [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:39:40, Info CSI 0000038e [SR] Beginning Verify and Repair transaction
2021-11-07 19:39:41, Info CSI 00000390 [SR] Verify complete
2021-11-07 19:39:41, Info CSI 00000391 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:39:41, Info CSI 00000392 [SR] Beginning Verify and Repair transaction
2021-11-07 19:39:44, Info CSI 000003a0 [SR] Verify complete
2021-11-07 19:39:45, Info CSI 000003a1 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:39:45, Info CSI 000003a2 [SR] Beginning Verify and Repair transaction
2021-11-07 19:39:48, Info CSI 000003a4 [SR] Verify complete
2021-11-07 19:39:48, Info CSI 000003a5 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:39:48, Info CSI 000003a6 [SR] Beginning Verify and Repair transaction
2021-11-07 19:39:50, Info CSI 000003a8 [SR] Verify complete
2021-11-07 19:39:51, Info CSI 000003a9 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:39:51, Info CSI 000003aa [SR] Beginning Verify and Repair transaction
2021-11-07 19:39:53, Info CSI 000003ac [SR] Verify complete
2021-11-07 19:39:54, Info CSI 000003ad [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:39:54, Info CSI 000003ae [SR] Beginning Verify and Repair transaction
2021-11-07 19:39:56, Info CSI 000003b0 [SR] Verify complete
2021-11-07 19:39:57, Info CSI 000003b1 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:39:57, Info CSI 000003b2 [SR] Beginning Verify and Repair transaction
2021-11-07 19:40:00, Info CSI 000003b4 [SR] Verify complete
2021-11-07 19:40:00, Info CSI 000003b5 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:40:00, Info CSI 000003b6 [SR] Beginning Verify and Repair transaction
2021-11-07 19:40:03, Info CSI 000003b8 [SR] Verify complete
2021-11-07 19:40:03, Info CSI 000003b9 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:40:03, Info CSI 000003ba [SR] Beginning Verify and Repair transaction
2021-11-07 19:40:06, Info CSI 000003bc [SR] Verify complete
2021-11-07 19:40:06, Info CSI 000003bd [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:40:06, Info CSI 000003be [SR] Beginning Verify and Repair transaction
2021-11-07 19:40:10, Info CSI 000003c0 [SR] Verify complete
2021-11-07 19:40:10, Info CSI 000003c1 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:40:10, Info CSI 000003c2 [SR] Beginning Verify and Repair transaction
2021-11-07 19:40:14, Info CSI 000003c4 [SR] Verify complete
2021-11-07 19:40:14, Info CSI 000003c5 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:40:14, Info CSI 000003c6 [SR] Beginning Verify and Repair transaction
2021-11-07 19:40:16, Info CSI 000003c8 [SR] Verify complete
2021-11-07 19:40:16, Info CSI 000003c9 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:40:16, Info CSI 000003ca [SR] Beginning Verify and Repair transaction
2021-11-07 19:40:18, Info CSI 000003cc [SR] Verify complete
2021-11-07 19:40:19, Info CSI 000003cd [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:40:19, Info CSI 000003ce [SR] Beginning Verify and Repair transaction
2021-11-07 19:40:26, Info CSI 000003d3 [SR] Verify complete
2021-11-07 19:40:27, Info CSI 000003d4 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:40:27, Info CSI 000003d5 [SR] Beginning Verify and Repair transaction
2021-11-07 19:40:34, Info CSI 000003d7 [SR] Verify complete
2021-11-07 19:40:34, Info CSI 000003d8 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:40:34, Info CSI 000003d9 [SR] Beginning Verify and Repair transaction
2021-11-07 19:40:37, Info CSI 000003de [SR] Verify complete
2021-11-07 19:40:38, Info CSI 000003df [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:40:38, Info CSI 000003e0 [SR] Beginning Verify and Repair transaction
2021-11-07 19:40:41, Info CSI 000003e2 [SR] Verify complete
2021-11-07 19:40:42, Info CSI 000003e3 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:40:42, Info CSI 000003e4 [SR] Beginning Verify and Repair transaction
2021-11-07 19:40:45, Info CSI 000003f1 [SR] Verify complete
2021-11-07 19:40:45, Info CSI 000003f2 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:40:45, Info CSI 000003f3 [SR] Beginning Verify and Repair transaction
2021-11-07 19:40:50, Info CSI 000003f7 [SR] Verify complete
2021-11-07 19:40:50, Info CSI 000003f8 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:40:50, Info CSI 000003f9 [SR] Beginning Verify and Repair transaction
2021-11-07 19:40:53, Info CSI 000003fe [SR] Verify complete
2021-11-07 19:40:54, Info CSI 000003ff [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:40:54, Info CSI 00000400 [SR] Beginning Verify and Repair transaction
2021-11-07 19:40:56, Info CSI 00000402 [SR] Verify complete
2021-11-07 19:40:56, Info CSI 00000403 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:40:56, Info CSI 00000404 [SR] Beginning Verify and Repair transaction
2021-11-07 19:40:58, Info CSI 00000406 [SR] Verify complete
2021-11-07 19:40:59, Info CSI 00000407 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:40:59, Info CSI 00000408 [SR] Beginning Verify and Repair transaction
2021-11-07 19:41:01, Info CSI 0000040c [SR] Verify complete
2021-11-07 19:41:01, Info CSI 0000040d [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:41:01, Info CSI 0000040e [SR] Beginning Verify and Repair transaction
2021-11-07 19:41:03, Info CSI 00000410 [SR] Verify complete
2021-11-07 19:41:03, Info CSI 00000411 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:41:03, Info CSI 00000412 [SR] Beginning Verify and Repair transaction
2021-11-07 19:41:06, Info CSI 00000422 [SR] Verify complete
2021-11-07 19:41:06, Info CSI 00000423 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:41:06, Info CSI 00000424 [SR] Beginning Verify and Repair transaction
2021-11-07 19:41:09, Info CSI 0000043b [SR] Verify complete
2021-11-07 19:41:10, Info CSI 0000043c [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:41:10, Info CSI 0000043d [SR] Beginning Verify and Repair transaction
2021-11-07 19:41:12, Info CSI 0000043f [SR] Verify complete
2021-11-07 19:41:12, Info CSI 00000440 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:41:12, Info CSI 00000441 [SR] Beginning Verify and Repair transaction
2021-11-07 19:41:14, Info CSI 00000443 [SR] Verify complete
2021-11-07 19:41:14, Info CSI 00000444 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:41:14, Info CSI 00000445 [SR] Beginning Verify and Repair transaction
2021-11-07 19:41:16, Info CSI 00000447 [SR] Verify complete
2021-11-07 19:41:16, Info CSI 00000448 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:41:16, Info CSI 00000449 [SR] Beginning Verify and Repair transaction
2021-11-07 19:41:19, Info CSI 0000044b [SR] Verify complete
2021-11-07 19:41:19, Info CSI 0000044c [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:41:19, Info CSI 0000044d [SR] Beginning Verify and Repair transaction
2021-11-07 19:41:21, Info CSI 0000044f [SR] Verify complete
2021-11-07 19:41:21, Info CSI 00000450 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:41:21, Info CSI 00000451 [SR] Beginning Verify and Repair transaction
2021-11-07 19:41:23, Info CSI 00000463 [SR] Verify complete
2021-11-07 19:41:24, Info CSI 00000464 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:41:24, Info CSI 00000465 [SR] Beginning Verify and Repair transaction
2021-11-07 19:41:25, Info CSI 00000467 [SR] Verify complete
2021-11-07 19:41:26, Info CSI 00000468 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:41:26, Info CSI 00000469 [SR] Beginning Verify and Repair transaction
2021-11-07 19:41:30, Info CSI 0000046b [SR] Verify complete
2021-11-07 19:41:30, Info CSI 0000046c [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:41:30, Info CSI 0000046d [SR] Beginning Verify and Repair transaction
2021-11-07 19:41:32, Info CSI 0000046f [SR] Verify complete
2021-11-07 19:41:32, Info CSI 00000470 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:41:32, Info CSI 00000471 [SR] Beginning Verify and Repair transaction
2021-11-07 19:41:36, Info CSI 0000047f [SR] Verify complete
2021-11-07 19:41:36, Info CSI 00000480 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:41:36, Info CSI 00000481 [SR] Beginning Verify and Repair transaction
2021-11-07 19:41:38, Info CSI 00000483 [SR] Verify complete
2021-11-07 19:41:39, Info CSI 00000484 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:41:39, Info CSI 00000485 [SR] Beginning Verify and Repair transaction
2021-11-07 19:41:41, Info CSI 00000487 [SR] Verify complete
2021-11-07 19:41:42, Info CSI 00000488 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:41:42, Info CSI 00000489 [SR] Beginning Verify and Repair transaction
2021-11-07 19:41:46, Info CSI 0000048c [SR] Verify complete
2021-11-07 19:41:46, Info CSI 0000048d [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:41:46, Info CSI 0000048e [SR] Beginning Verify and Repair transaction
2021-11-07 19:41:49, Info CSI 00000490 [SR] Verify complete
2021-11-07 19:41:49, Info CSI 00000491 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:41:49, Info CSI 00000492 [SR] Beginning Verify and Repair transaction
2021-11-07 19:41:50, Info CSI 00000494 [SR] Verify complete
2021-11-07 19:41:50, Info CSI 00000495 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:41:50, Info CSI 00000496 [SR] Beginning Verify and Repair transaction
2021-11-07 19:41:52, Info CSI 00000498 [SR] Verify complete
2021-11-07 19:41:52, Info CSI 00000499 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:41:52, Info CSI 0000049a [SR] Beginning Verify and Repair transaction
2021-11-07 19:41:55, Info CSI 0000049c [SR] Verify complete
2021-11-07 19:41:56, Info CSI 0000049d [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:41:56, Info CSI 0000049e [SR] Beginning Verify and Repair transaction
2021-11-07 19:41:58, Info CSI 000004a0 [SR] Verify complete
2021-11-07 19:41:59, Info CSI 000004a1 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:41:59, Info CSI 000004a2 [SR] Beginning Verify and Repair transaction
2021-11-07 19:42:01, Info CSI 000004a4 [SR] Verify complete
2021-11-07 19:42:01, Info CSI 000004a5 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:42:01, Info CSI 000004a6 [SR] Beginning Verify and Repair transaction
2021-11-07 19:42:04, Info CSI 000004a8 [SR] Verify complete
2021-11-07 19:42:04, Info CSI 000004a9 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:42:04, Info CSI 000004aa [SR] Beginning Verify and Repair transaction
2021-11-07 19:42:08, Info CSI 000004c4 [SR] Verify complete
2021-11-07 19:42:08, Info CSI 000004c5 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:42:08, Info CSI 000004c6 [SR] Beginning Verify and Repair transaction
2021-11-07 19:42:11, Info CSI 000004c8 [SR] Cannot repair member file [l:28{14}]"iassdo.dll.mui" of Microsoft-Windows-Networking-Internet_Authentication_Service_Iassdo.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"en-US", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2021-11-07 19:42:11, Info CSI 000004ca [SR] Cannot repair member file [l:28{14}]"iassdo.dll.mui" of Microsoft-Windows-Networking-Internet_Authentication_Service_Iassdo.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"en-US", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2021-11-07 19:42:11, Info CSI 000004cb [SR] This component was referenced by [l:266{133}]"Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~en-US~6.1.7601.17514.Windows Foundation Language Pack"
2021-11-07 19:42:11, Info CSI 000004ce [SR] Could not reproject corrupted file [ml:60{30},l:58{29}]"\??\C:\Windows\SysWOW64\en-US"\[l:28{14}]"iassdo.dll.mui"; source file in store is also corrupted
2021-11-07 19:42:11, Info CSI 000004d0 [SR] Verify complete
2021-11-07 19:42:11, Info CSI 000004d1 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:42:11, Info CSI 000004d2 [SR] Beginning Verify and Repair transaction
2021-11-07 19:42:13, Info CSI 000004d4 [SR] Verify complete
2021-11-07 19:42:13, Info CSI 000004d5 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:42:13, Info CSI 000004d6 [SR] Beginning Verify and Repair transaction
2021-11-07 19:42:20, Info CSI 000004d8 [SR] Verify complete
2021-11-07 19:42:20, Info CSI 000004d9 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:42:20, Info CSI 000004da [SR] Beginning Verify and Repair transaction
2021-11-07 19:42:22, Info CSI 000004dc [SR] Verify complete
2021-11-07 19:42:22, Info CSI 000004dd [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:42:22, Info CSI 000004de [SR] Beginning Verify and Repair transaction
2021-11-07 19:42:24, Info CSI 000004e0 [SR] Verify complete
2021-11-07 19:42:25, Info CSI 000004e1 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:42:25, Info CSI 000004e2 [SR] Beginning Verify and Repair transaction
2021-11-07 19:42:26, Info CSI 000004e4 [SR] Verify complete
2021-11-07 19:42:26, Info CSI 000004e5 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:42:26, Info CSI 000004e6 [SR] Beginning Verify and Repair transaction
2021-11-07 19:42:28, Info CSI 000004ea [SR] Verify complete
2021-11-07 19:42:28, Info CSI 000004eb [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:42:28, Info CSI 000004ec [SR] Beginning Verify and Repair transaction
2021-11-07 19:42:30, Info CSI 000004ee [SR] Verify complete
2021-11-07 19:42:30, Info CSI 000004ef [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:42:30, Info CSI 000004f0 [SR] Beginning Verify and Repair transaction
2021-11-07 19:42:32, Info CSI 000004f2 [SR] Verify complete
2021-11-07 19:42:32, Info CSI 000004f3 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:42:32, Info CSI 000004f4 [SR] Beginning Verify and Repair transaction
2021-11-07 19:42:33, Info CSI 000004f6 [SR] Verify complete
2021-11-07 19:42:34, Info CSI 000004f7 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:42:34, Info CSI 000004f8 [SR] Beginning Verify and Repair transaction
2021-11-07 19:42:36, Info CSI 000004fa [SR] Verify complete
2021-11-07 19:42:36, Info CSI 000004fb [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:42:36, Info CSI 000004fc [SR] Beginning Verify and Repair transaction
2021-11-07 19:42:38, Info CSI 000004fe [SR] Verify complete
2021-11-07 19:42:39, Info CSI 000004ff [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:42:39, Info CSI 00000500 [SR] Beginning Verify and Repair transaction
2021-11-07 19:42:40, Info CSI 00000502 [SR] Verify complete
2021-11-07 19:42:40, Info CSI 00000503 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:42:40, Info CSI 00000504 [SR] Beginning Verify and Repair transaction
2021-11-07 19:42:43, Info CSI 00000507 [SR] Verify complete
2021-11-07 19:42:43, Info CSI 00000508 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:42:43, Info CSI 00000509 [SR] Beginning Verify and Repair transaction
2021-11-07 19:42:45, Info CSI 0000050b [SR] Verify complete
2021-11-07 19:42:45, Info CSI 0000050c [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:42:45, Info CSI 0000050d [SR] Beginning Verify and Repair transaction
2021-11-07 19:42:47, Info CSI 0000050f [SR] Verify complete
2021-11-07 19:42:47, Info CSI 00000510 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:42:47, Info CSI 00000511 [SR] Beginning Verify and Repair transaction
2021-11-07 19:42:50, Info CSI 00000513 [SR] Verify complete
2021-11-07 19:42:50, Info CSI 00000514 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:42:50, Info CSI 00000515 [SR] Beginning Verify and Repair transaction
2021-11-07 19:42:52, Info CSI 00000519 [SR] Verify complete
2021-11-07 19:42:52, Info CSI 0000051a [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:42:52, Info CSI 0000051b [SR] Beginning Verify and Repair transaction
2021-11-07 19:42:55, Info CSI 0000051d [SR] Verify complete
2021-11-07 19:42:56, Info CSI 0000051e [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:42:56, Info CSI 0000051f [SR] Beginning Verify and Repair transaction
2021-11-07 19:42:58, Info CSI 00000521 [SR] Verify complete
2021-11-07 19:42:58, Info CSI 00000522 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:42:58, Info CSI 00000523 [SR] Beginning Verify and Repair transaction
2021-11-07 19:43:01, Info CSI 00000525 [SR] Verify complete
2021-11-07 19:43:01, Info CSI 00000526 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:43:01, Info CSI 00000527 [SR] Beginning Verify and Repair transaction
2021-11-07 19:43:04, Info CSI 0000052a [SR] Verify complete
2021-11-07 19:43:04, Info CSI 0000052b [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:43:04, Info CSI 0000052c [SR] Beginning Verify and Repair transaction
2021-11-07 19:43:07, Info CSI 0000052e [SR] Verify complete
2021-11-07 19:43:08, Info CSI 0000052f [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:43:08, Info CSI 00000530 [SR] Beginning Verify and Repair transaction
2021-11-07 19:43:11, Info CSI 00000532 [SR] Verify complete
2021-11-07 19:43:11, Info CSI 00000533 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:43:11, Info CSI 00000534 [SR] Beginning Verify and Repair transaction
2021-11-07 19:43:14, Info CSI 00000536 [SR] Verify complete
2021-11-07 19:43:14, Info CSI 00000537 [SR] Verifying 82 (0x0000000000000052) components
2021-11-07 19:43:14, Info CSI 00000538 [SR] Beginning Verify and Repair transaction
2021-11-07 19:43:17, Info CSI 0000053a [SR] Verify complete
2021-11-07 19:43:17, Info CSI 0000053b [SR] Repairing 1 components
2021-11-07 19:43:17, Info CSI 0000053c [SR] Beginning Verify and Repair transaction
2021-11-07 19:43:17, Info CSI 0000053e [SR] Cannot repair member file [l:28{14}]"iassdo.dll.mui" of Microsoft-Windows-Networking-Internet_Authentication_Service_Iassdo.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"en-US", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2021-11-07 19:43:17, Info CSI 00000540 [SR] Cannot repair member file [l:28{14}]"iassdo.dll.mui" of Microsoft-Windows-Networking-Internet_Authentication_Service_Iassdo.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"en-US", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2021-11-07 19:43:17, Info CSI 00000541 [SR] This component was referenced by [l:266{133}]"Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~en-US~6.1.7601.17514.Windows Foundation Language Pack"
2021-11-07 19:43:17, Info CSI 00000544 [SR] Could not reproject corrupted file [ml:60{30},l:58{29}]"\??\C:\Windows\SysWOW64\en-US"\[l:28{14}]"iassdo.dll.mui"; source file in store is also corrupted
2021-11-07 19:43:17, Info CSI 00000546 [SR] Repair complete
2021-11-07 19:43:17, Info CSI 00000547 [SR] Committing transaction
2021-11-07 19:43:17, Info CSI 0000054b [SR] Verify and Repair Transaction completed. All files and registry keys listed in this transaction have been successfully repaired
=========== EmptyTemp: ==========
BITS transfer queue => 0 B
DOMStore, IE Recovery, AppCache, Feeds Cache, Thumbcache, IconCache => 8243054 B
Java, Flash, Steam htmlcache => 21775262 B
Windows/system/drivers => 29630 B
Edge => 0 B
Firefox => 0 B
Opera => 0 B
Temp, IE cache, history, cookies, recent:
Default => 0 B
Public => 0 B
ProgramData => 0 B
systemprofile => 0 B
systemprofile32 => 0 B
LocalService => 0 B
NetworkService => 0 B
Carlos Luna => 3829038 B
RecycleBin => 0 B
EmptyTemp: => 32.3 MB temporary data Removed.
The system needed a reboot.
==== End of Fixlog 20:10:27 ====
Thank you.
Let's see if we can fix the corrupted file.
!!! WARNING !!!
The following fix is only relevant for this system and no other, applying this fix on another computer will not work and most likely will cause problems.
  • Download SFCFix.exe (by Niemiro) and save it to the Desktop.
  • Download the file SFCFIX.ZIP, attached below, and save this to your Desktop.
  • On your Desktop, make sure you have the two files: SFCFix.exe and SFCFIX.zip.
  • Drag the file SFCFIX.zip onto the file SFCFix.exe and release it.
  • The SFCFix tool will process the script.
  • Upon completion, a log file SFCFix.txt should be created on your Desktop.
  • Open the SFCFix.txt log and copy & paste the contents to your post.
Start time: 2021-11-09 21:11:05.163
Using .zip script file at C:\Users\Carlos Luna\Desktop\SFCFIX.zip [0]
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-n..ce_iassdo.resources_31bf3856ad364e35_6.1.7600.16385_en-us_e86c80b89a3f77b7\iassdo.dll.mui
Successfully copied file C:\Users\Carlos Luna\AppData\Local\niemiro\Archive\x86_microsoft-windows-n..ce_iassdo.resources_31bf3856ad364e35_6.1.7600.16385_en-us_e86c80b89a3f77b7\iassdo.dll.mui to C:\Windows\winsxs\x86_microsoft-windows-n..ce_iassdo.resources_31bf3856ad364e35_6.1.7600.16385_en-us_e86c80b89a3f77b7\iassdo.dll.mui.
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-n..ce_iassdo.resources_31bf3856ad364e35_6.1.7600.16385_en-us_e86c80b89a3f77b7\iassdo.dll.mui
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-n..ce_iassdo.resources_31bf3856ad364e35_6.1.7600.16385_en-us_e86c80b89a3f77b7\iassdo.dll.mui
Finish time: 2021-11-09 21:11:05.397
Script hash: 8/VaaaOLXXxtgFCNWvpNyJYS/MQ6iatcuwVrfcPz8+w=
Hi, Carlosh.
1. FRST fix - SFC
1. FRST fix
Please do the following to run a FRST fix.
NOTICE: This script was written specifically for this user. Running it on another machine may cause damage to your operating system
  • Please select the entire contents of the code box below, from the "Start::" line to "End::", including both lines. Right-click and select "Copy ". No need to paste anything to anywhere.
Start::
CreateRestorePoint:
CloseProcesses:
cmd: SFC /scannow
cmd: findstr /c:"[SR]" %windir%\logs\cbs\cbs.log
EmptyTemp:
End::
  • Please right-click on FRST64 on your Desktop, to run it as administrator. When the tool opens, click "yes" to the disclaimer.
  • Press the Fix button once and wait.
  • FRST will process fixlist.txt
  • When finished, it will produce a log fixlog.txt on your Desktop.
  • Please post the log in your next reply.
2. Update Windows Defender
Windows Defender is out of date.
Check this article and follow the steps under the title How do I manually update WD.
How do I update Windows Defender on Windows 7? (ostoday.org)
3. Antivirus
You have no antivirus installed. This is a security risk.
The following vendors provide free antivirus solutions. You can check them and install one of them, unless you decide to buy a payed version of these or anything else.
Cloud Antivirus Free Download | Kaspersky Security Cloud Free | Kaspersky
Download Security Software for Windows, Mac, Android & iOS | Avira Antivirus
Bitdefender Antivirus Free - Download Free Antivirus Software
In your next reply please post:
  1. The fixlog.txt
  2. If everything went fine with Defender
  3. If you installed an antivirus
  4. Feedback: How is the computer running now? Any remaining issue/question/concern?
Thanks, so far everything is running smoothly, don't having any issues now with the process or CPU, my main issue was that rootkit that was consuming all the memory, still didn't know I have so many other problems that I could never find for myself. So far everything looks good. Also I gonna post 2 replies or more, the log is a bit long.​
  • I update the Windows defender yesterday, so I think is that's check.​
  • I have a doubt about the antiviruses, Kaspersky I know is good, but I know it consumes tons of process too and the pc slows down a bit, Avira I never used before but I just know have some good reviews (still don't know anything about it), but now Bitfender I know is a bit intrusive in certain aspects, for what I search before and really don't like that after all the issues we check so far.
    So any recommendation on which to choose, Avira or Kaspersky?​
  • And lastly, if ok to remove some of the setup installations and programs such Esetuninstaller, Malwarebytes, MCShield and the AdwCleaner? or I gonna still need some of them just in case?​
FRST Fixlog:
Fix result of Farbar Recovery Scan Tool (x64) Version: 09-11-2021
Ran by Carlos Luna (10-11-2021 20:06:52) Run:6
Running from C:\Users\Carlos Luna\Desktop
Loaded Profiles: Carlos Luna
Boot Mode: Normal
fixlist content:
CreateRestorePoint:
CloseProcesses:
cmd: SFC /scannow
EmptyTemp:
========= SFC /scannow =========
Verification 0% complete.Verification 0% complete.Verification 1% complete.Verification 1% complete.Verification 1% complete.Verification 2% complete.Verification 2% complete.Verification 3% complete.Verification 3% complete.Verification 3% complete.Verification 4% complete.Verification 4% complete.Verification 5% complete.Verification 5% complete.Verification 5% complete.Verification 6% complete.Verification 6% complete.Verification 7% complete.Verification 7% complete.Verification 7% complete.Verification 8% complete.Verification 8% complete.Verification 8% complete.Verification 9% complete.Verification 9% complete.Verification 10% complete.Verification 10% complete.Verification 10% complete.Verification 11% complete.Verification 11% complete.Verification 12% complete.Verification 12% complete.Verification 12% complete.Verification 13% complete.Verification 13% complete.Verification 14% complete.Verification 14% complete.Verification 14% complete.Verification 15% complete.Verification 15% complete.Verification 15% complete.Verification 16% complete.Verification 16% complete.Verification 17% complete.Verification 17% complete.Verification 17% complete.Verification 18% complete.Verification 18% complete.Verification 19% complete.Verification 19% complete.Verification 19% complete.Verification 20% complete.Verification 20% complete.Verification 21% complete.Verification 21% complete.Verification 21% complete.Verification 22% complete.Verification 22% complete.Verification 22% complete.Verification 23% complete.Verification 23% complete.Verification 24% complete.Verification 24% complete.Verification 24% complete.Verification 25% complete.Verification 25% complete.Verification 26% complete.Verification 26% complete.Verification 26% complete.Verification 27% complete.Verification 27% complete.Verification 28% complete.Verification 28% complete.Verification 28% complete.Verification 29% complete.Verification 29% complete.Verification 29% complete.Verification 30% complete.Verification 30% complete.Verification 31% complete.Verification 31% complete.Verification 31% complete.Verification 32% complete.Verification 32% complete.Verification 33% complete.Verification 33% complete.Verification 33% complete.Verification 34% complete.Verification 34% complete.Verification 35% complete.Verification 35% complete.Verification 35% complete.Verification 36% complete.Verification 36% complete.Verification 36% complete.Verification 37% complete.Verification 37% complete.Verification 38% complete.Verification 38% complete.Verification 38% complete.Verification 39% complete.Verification 39% complete.Verification 40% complete.Verification 40% complete.Verification 40% complete.Verification 41% complete.Verification 41% complete.Verification 42% complete.Verification 42% complete.Verification 42% complete.Verification 43% complete.Verification 43% complete.Verification 43% complete.Verification 44% complete.Verification 44% complete.Verification 45% complete.Verification 45% complete.Verification 45% complete.Verification 46% complete.Verification 46% complete.Verification 47% complete.Verification 47% complete.Verification 47% complete.Verification 48% complete.Verification 48% complete.Verification 49% complete.Verification 49% complete.Verification 49% complete.Verification 50% complete.Verification 50% complete.Verification 51% complete.Verification 51% complete.Verification 51% complete.Verification 52% complete.Verification 52% complete.Verification 52% complete.Verification 53% complete.Verification 53% complete.Verification 54% complete.Verification 54% complete.Verification 54% complete.Verification 55% complete.Verification 55% complete.Verification 56% complete.Verification 56% complete.Verification 56% complete.Verification 57% complete.Verification 57% complete.Verification 58% complete.Verification 58% complete.Verification 58% complete.Verification 59% complete.Verification 59% complete.Verification 59% complete.Verification 60% complete.Verification 60% complete.Verification 61% complete.Verification 61% complete.Verification 61% complete.Verification 62% complete.Verification 62% complete.Verification 63% complete.Verification 63% complete.Verification 63% complete.Verification 64% complete.Verification 64% complete.Verification 65% complete.Verification 65% complete.Verification 65% complete.Verification 66% complete.Verification 66% complete.Verification 66% complete.Verification 67% complete.Verification 67% complete.Verification 68% complete.Verification 68% complete.Verification 68% complete.Verification 69% complete.Verification 69% complete.Verification 70% complete.Verification 70% complete.Verification 70% complete.Verification 71% complete.Verification 71% complete.Verification 72% complete.Verification 72% complete.Verification 72% complete.Verification 73% complete.Verification 73% complete.Verification 73% complete.Verification 74% complete.Verification 74% complete.Verification 75% complete.Verification 75% complete.Verification 75% complete.Verification 76% complete.Verification 76% complete.Verification 77% complete.Verification 77% complete.Verification 77% complete.Verification 78% complete.Verification 78% complete.Verification 79% complete.Verification 79% complete.Verification 79% complete.Verification 80% complete.Verification 80% complete.Verification 80% complete.Verification 81% complete.Verification 81% complete.Verification 82% complete.Verification 82% complete.Verification 82% complete.Verification 83% complete.Verification 83% complete.Verification 84% complete.Verification 84% complete.Verification 84% complete.Verification 85% complete.Verification 85% complete.Verification 86% complete.Verification 86% complete.Verification 86% complete.Verification 87% complete.Verification 87% complete.Verification 87% complete.Verification 88% complete.Verification 88% complete.Verification 89% complete.Verification 89% complete.Verification 89% complete.Verification 90% complete.Verification 90% complete.Verification 91% complete.Verification 91% complete.Verification 91% complete.Verification 92% complete.Verification 92% complete.Verification 93% complete.Verification 93% complete.Verification 93% complete.Verification 94% complete.Verification 94% complete.Verification 95% complete.Verification 95% complete.Verification 95% complete.Verification 96% complete.Verification 96% complete.Verification 96% complete.Verification 97% complete.Verification 97% complete.Verification 98% complete.Verification 98% complete.Verification 98% complete.Verification 99% complete.Verification 99% complete.Verification 100% complete.
========= findstr /c:"[SR]" %windir%\logs\cbs\cbs.log =========
2021-10-24 01:14:59, Info CSI 00000009 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:14:59, Info CSI 0000000a [SR] Beginning Verify and Repair transaction
2021-10-24 01:15:01, Info CSI 0000000c [SR] Verify complete
2021-10-24 01:15:02, Info CSI 0000000d [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:15:02, Info CSI 0000000e [SR] Beginning Verify and Repair transaction
2021-10-24 01:15:04, Info CSI 00000010 [SR] Verify complete
2021-10-24 01:15:06, Info CSI 00000011 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:15:06, Info CSI 00000012 [SR] Beginning Verify and Repair transaction
2021-10-24 01:15:07, Info CSI 00000014 [SR] Verify complete
2021-10-24 01:15:09, Info CSI 00000015 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:15:09, Info CSI 00000016 [SR] Beginning Verify and Repair transaction
2021-10-24 01:15:10, Info CSI 00000018 [SR] Verify complete
2021-10-24 01:15:12, Info CSI 00000019 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:15:12, Info CSI 0000001a [SR] Beginning Verify and Repair transaction
2021-10-24 01:15:14, Info CSI 0000001c [SR] Verify complete
2021-10-24 01:15:17, Info CSI 0000001d [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:15:17, Info CSI 0000001e [SR] Beginning Verify and Repair transaction
2021-10-24 01:15:18, Info CSI 00000020 [SR] Verify complete
2021-10-24 01:15:20, Info CSI 00000021 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:15:20, Info CSI 00000022 [SR] Beginning Verify and Repair transaction
2021-10-24 01:15:22, Info CSI 00000024 [SR] Verify complete
2021-10-24 01:15:24, Info CSI 00000025 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:15:24, Info CSI 00000026 [SR] Beginning Verify and Repair transaction
2021-10-24 01:15:25, Info CSI 00000028 [SR] Verify complete
2021-10-24 01:15:26, Info CSI 00000029 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:15:26, Info CSI 0000002a [SR] Beginning Verify and Repair transaction
2021-10-24 01:15:28, Info CSI 0000002c [SR] Verify complete
2021-10-24 01:15:30, Info CSI 0000002d [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:15:30, Info CSI 0000002e [SR] Beginning Verify and Repair transaction
2021-10-24 01:15:32, Info CSI 00000030 [SR] Verify complete
2021-10-24 01:15:33, Info CSI 00000031 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:15:33, Info CSI 00000032 [SR] Beginning Verify and Repair transaction
2021-10-24 01:15:34, Info CSI 00000034 [SR] Verify complete
2021-10-24 01:15:37, Info CSI 00000035 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:15:37, Info CSI 00000036 [SR] Beginning Verify and Repair transaction
2021-10-24 01:15:38, Info CSI 00000038 [SR] Verify complete
2021-10-24 01:15:39, Info CSI 00000039 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:15:39, Info CSI 0000003a [SR] Beginning Verify and Repair transaction
2021-10-24 01:15:41, Info CSI 0000003c [SR] Verify complete
2021-10-24 01:15:43, Info CSI 0000003d [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:15:43, Info CSI 0000003e [SR] Beginning Verify and Repair transaction
2021-10-24 01:15:44, Info CSI 00000040 [SR] Verify complete
2021-10-24 01:15:46, Info CSI 00000041 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:15:46, Info CSI 00000042 [SR] Beginning Verify and Repair transaction
2021-10-24 01:15:47, Info CSI 00000044 [SR] Verify complete
2021-10-24 01:15:48, Info CSI 00000045 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:15:48, Info CSI 00000046 [SR] Beginning Verify and Repair transaction
2021-10-24 01:15:50, Info CSI 00000048 [SR] Verify complete
2021-10-24 01:15:51, Info CSI 00000049 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:15:51, Info CSI 0000004a [SR] Beginning Verify and Repair transaction
2021-10-24 01:15:53, Info CSI 0000004c [SR] Verify complete
2021-10-24 01:15:54, Info CSI 0000004d [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:15:54, Info CSI 0000004e [SR] Beginning Verify and Repair transaction
2021-10-24 01:15:55, Info CSI 00000050 [SR] Verify complete
2021-10-24 01:15:57, Info CSI 00000051 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:15:57, Info CSI 00000052 [SR] Beginning Verify and Repair transaction
2021-10-24 01:15:58, Info CSI 00000054 [SR] Verify complete
2021-10-24 01:16:00, Info CSI 00000055 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:16:00, Info CSI 00000056 [SR] Beginning Verify and Repair transaction
2021-10-24 01:16:01, Info CSI 00000058 [SR] Verify complete
2021-10-24 01:16:03, Info CSI 00000059 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:16:03, Info CSI 0000005a [SR] Beginning Verify and Repair transaction
2021-10-24 01:16:04, Info CSI 0000005c [SR] Verify complete
2021-10-24 01:16:06, Info CSI 0000005d [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:16:06, Info CSI 0000005e [SR] Beginning Verify and Repair transaction
2021-10-24 01:16:07, Info CSI 00000060 [SR] Verify complete
2021-10-24 01:16:09, Info CSI 00000061 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:16:09, Info CSI 00000062 [SR] Beginning Verify and Repair transaction
2021-10-24 01:16:11, Info CSI 00000064 [SR] Verify complete
2021-10-24 01:16:12, Info CSI 00000065 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:16:12, Info CSI 00000066 [SR] Beginning Verify and Repair transaction
2021-10-24 01:16:13, Info CSI 00000068 [SR] Verify complete
2021-10-24 01:16:15, Info CSI 00000069 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:16:15, Info CSI 0000006a [SR] Beginning Verify and Repair transaction
2021-10-24 01:16:16, Info CSI 0000006c [SR] Verify complete
2021-10-24 01:16:19, Info CSI 0000006d [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:16:19, Info CSI 0000006e [SR] Beginning Verify and Repair transaction
2021-10-24 01:16:20, Info CSI 00000070 [SR] Verify complete
2021-10-24 01:16:21, Info CSI 00000071 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:16:21, Info CSI 00000072 [SR] Beginning Verify and Repair transaction
2021-10-24 01:16:23, Info CSI 00000074 [SR] Verify complete
2021-10-24 01:16:24, Info CSI 00000075 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:16:24, Info CSI 00000076 [SR] Beginning Verify and Repair transaction
2021-10-24 01:16:26, Info CSI 00000078 [SR] Verify complete
2021-10-24 01:16:27, Info CSI 00000079 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:16:27, Info CSI 0000007a [SR] Beginning Verify and Repair transaction
2021-10-24 01:16:29, Info CSI 0000007c [SR] Verify complete
2021-10-24 01:16:30, Info CSI 0000007d [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:16:30, Info CSI 0000007e [SR] Beginning Verify and Repair transaction
2021-10-24 01:16:32, Info CSI 00000080 [SR] Verify complete
2021-10-24 01:16:33, Info CSI 00000081 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:16:33, Info CSI 00000082 [SR] Beginning Verify and Repair transaction
2021-10-24 01:16:34, Info CSI 00000084 [SR] Verify complete
2021-10-24 01:16:36, Info CSI 00000085 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:16:36, Info CSI 00000086 [SR] Beginning Verify and Repair transaction
2021-10-24 01:16:37, Info CSI 00000088 [SR] Verify complete
2021-10-24 01:16:38, Info CSI 00000089 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:16:38, Info CSI 0000008a [SR] Beginning Verify and Repair transaction
2021-10-24 01:16:39, Info CSI 0000008c [SR] Verify complete
2021-10-24 01:16:41, Info CSI 0000008d [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:16:41, Info CSI 0000008e [SR] Beginning Verify and Repair transaction
2021-10-24 01:16:42, Info CSI 00000090 [SR] Verify complete
2021-10-24 01:16:43, Info CSI 00000091 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:16:43, Info CSI 00000092 [SR] Beginning Verify and Repair transaction
2021-10-24 01:16:45, Info CSI 00000094 [SR] Verify complete
2021-10-24 01:16:46, Info CSI 00000095 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:16:46, Info CSI 00000096 [SR] Beginning Verify and Repair transaction
2021-10-24 01:16:48, Info CSI 00000098 [SR] Verify complete
2021-10-24 01:16:49, Info CSI 00000099 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:16:49, Info CSI 0000009a [SR] Beginning Verify and Repair transaction
2021-10-24 01:16:50, Info CSI 0000009c [SR] Verify complete
2021-10-24 01:16:51, Info CSI 0000009d [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:16:51, Info CSI 0000009e [SR] Beginning Verify and Repair transaction
2021-10-24 01:16:53, Info CSI 000000a0 [SR] Verify complete
2021-10-24 01:16:54, Info CSI 000000a1 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:16:54, Info CSI 000000a2 [SR] Beginning Verify and Repair transaction
2021-10-24 01:16:55, Info CSI 000000a4 [SR] Verify complete
2021-10-24 01:16:56, Info CSI 000000a5 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:16:56, Info CSI 000000a6 [SR] Beginning Verify and Repair transaction
2021-10-24 01:16:58, Info CSI 000000a8 [SR] Verify complete
2021-10-24 01:16:59, Info CSI 000000a9 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:16:59, Info CSI 000000aa [SR] Beginning Verify and Repair transaction
2021-10-24 01:17:02, Info CSI 000000ac [SR] Verify complete
2021-10-24 01:17:03, Info CSI 000000ad [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:17:03, Info CSI 000000ae [SR] Beginning Verify and Repair transaction
2021-10-24 01:17:04, Info CSI 000000b0 [SR] Verify complete
2021-10-24 01:17:06, Info CSI 000000b1 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:17:06, Info CSI 000000b2 [SR] Beginning Verify and Repair transaction
2021-10-24 01:17:07, Info CSI 000000b4 [SR] Verify complete
2021-10-24 01:17:08, Info CSI 000000b5 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:17:08, Info CSI 000000b6 [SR] Beginning Verify and Repair transaction
2021-10-24 01:17:10, Info CSI 000000b8 [SR] Verify complete
2021-10-24 01:17:11, Info CSI 000000b9 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:17:11, Info CSI 000000ba [SR] Beginning Verify and Repair transaction
2021-10-24 01:17:13, Info CSI 000000bc [SR] Verify complete
2021-10-24 01:17:14, Info CSI 000000bd [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:17:14, Info CSI 000000be [SR] Beginning Verify and Repair transaction
2021-10-24 01:17:17, Info CSI 000000c0 [SR] Verify complete
2021-10-24 01:17:18, Info CSI 000000c1 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:17:18, Info CSI 000000c2 [SR] Beginning Verify and Repair transaction
2021-10-24 01:17:20, Info CSI 000000c4 [SR] Verify complete
2021-10-24 01:17:21, Info CSI 000000c5 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:17:21, Info CSI 000000c6 [SR] Beginning Verify and Repair transaction
2021-10-24 01:17:23, Info CSI 000000c8 [SR] Verify complete
2021-10-24 01:17:24, Info CSI 000000c9 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:17:24, Info CSI 000000ca [SR] Beginning Verify and Repair transaction
2021-10-24 01:17:28, Info CSI 000000cc [SR] Verify complete
2021-10-24 01:17:30, Info CSI 000000cd [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:17:30, Info CSI 000000ce [SR] Beginning Verify and Repair transaction
2021-10-24 01:17:33, Info CSI 000000d0 [SR] Verify complete
2021-10-24 01:17:34, Info CSI 000000d1 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:17:34, Info CSI 000000d2 [SR] Beginning Verify and Repair transaction
2021-10-24 01:17:35, Info CSI 000000d4 [SR] Verify complete
2021-10-24 01:17:37, Info CSI 000000d5 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:17:37, Info CSI 000000d6 [SR] Beginning Verify and Repair transaction
2021-10-24 01:17:38, Info CSI 000000d8 [SR] Verify complete
2021-10-24 01:17:40, Info CSI 000000d9 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:17:40, Info CSI 000000da [SR] Beginning Verify and Repair transaction
2021-10-24 01:17:42, Info CSI 000000dc [SR] Verify complete
2021-10-24 01:17:43, Info CSI 000000dd [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:17:43, Info CSI 000000de [SR] Beginning Verify and Repair transaction
2021-10-24 01:17:46, Info CSI 000000e0 [SR] Verify complete
2021-10-24 01:17:47, Info CSI 000000e1 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:17:47, Info CSI 000000e2 [SR] Beginning Verify and Repair transaction
2021-10-24 01:17:48, Info CSI 000000e4 [SR] Verify complete
2021-10-24 01:17:49, Info CSI 000000e5 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:17:49, Info CSI 000000e6 [SR] Beginning Verify and Repair transaction
2021-10-24 01:17:51, Info CSI 000000e8 [SR] Verify complete
2021-10-24 01:17:52, Info CSI 000000e9 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:17:52, Info CSI 000000ea [SR] Beginning Verify and Repair transaction
2021-10-24 01:17:53, Info CSI 000000ec [SR] Verify complete
2021-10-24 01:17:54, Info CSI 000000ed [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:17:54, Info CSI 000000ee [SR] Beginning Verify and Repair transaction
2021-10-24 01:17:56, Info CSI 000000f0 [SR] Verify complete
2021-10-24 01:17:57, Info CSI 000000f1 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:17:57, Info CSI 000000f2 [SR] Beginning Verify and Repair transaction
2021-10-24 01:17:59, Info CSI 000000f4 [SR] Verify complete
2021-10-24 01:18:00, Info CSI 000000f5 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:18:00, Info CSI 000000f6 [SR] Beginning Verify and Repair transaction
2021-10-24 01:18:01, Info CSI 000000f8 [SR] Verify complete
2021-10-24 01:18:02, Info CSI 000000f9 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:18:02, Info CSI 000000fa [SR] Beginning Verify and Repair transaction
2021-10-24 01:18:05, Info CSI 000000fc [SR] Verify complete
2021-10-24 01:18:06, Info CSI 000000fd [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:18:06, Info CSI 000000fe [SR] Beginning Verify and Repair transaction
2021-10-24 01:18:09, Info CSI 00000100 [SR] Verify complete
2021-10-24 01:18:09, Info CSI 00000101 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:18:09, Info CSI 00000102 [SR] Beginning Verify and Repair transaction
2021-10-24 01:18:13, Info CSI 00000104 [SR] Verify complete
2021-10-24 01:18:13, Info CSI 00000105 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:18:13, Info CSI 00000106 [SR] Beginning Verify and Repair transaction
2021-10-24 01:18:17, Info CSI 00000108 [SR] Verify complete
2021-10-24 01:18:17, Info CSI 00000109 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:18:17, Info CSI 0000010a [SR] Beginning Verify and Repair transaction
2021-10-24 01:18:19, Info CSI 0000010c [SR] Verify complete
2021-10-24 01:18:20, Info CSI 0000010d [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:18:20, Info CSI 0000010e [SR] Beginning Verify and Repair transaction
2021-10-24 01:18:22, Info CSI 00000110 [SR] Verify complete
2021-10-24 01:18:22, Info CSI 00000111 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:18:22, Info CSI 00000112 [SR] Beginning Verify and Repair transaction
2021-10-24 01:18:25, Info CSI 00000114 [SR] Verify complete
2021-10-24 01:18:26, Info CSI 00000115 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:18:26, Info CSI 00000116 [SR] Beginning Verify and Repair transaction
2021-10-24 01:18:31, Info CSI 00000118 [SR] Verify complete
2021-10-24 01:18:32, Info CSI 00000119 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:18:32, Info CSI 0000011a [SR] Beginning Verify and Repair transaction
2021-10-24 01:18:40, Info CSI 0000011d [SR] Verify complete
2021-10-24 01:18:41, Info CSI 0000011e [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:18:41, Info CSI 0000011f [SR] Beginning Verify and Repair transaction
2021-10-24 01:18:46, Info CSI 00000122 [SR] Verify complete
2021-10-24 01:18:46, Info CSI 00000123 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:18:46, Info CSI 00000124 [SR] Beginning Verify and Repair transaction
2021-10-24 01:18:51, Info CSI 00000127 [SR] Verify complete
2021-10-24 01:18:52, Info CSI 00000128 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:18:52, Info CSI 00000129 [SR] Beginning Verify and Repair transaction
2021-10-24 01:18:55, Info CSI 0000012c [SR] Verify complete
2021-10-24 01:18:56, Info CSI 0000012d [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:18:56, Info CSI 0000012e [SR] Beginning Verify and Repair transaction
2021-10-24 01:19:00, Info CSI 00000133 [SR] Verify complete
2021-10-24 01:19:00, Info CSI 00000134 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:19:00, Info CSI 00000135 [SR] Beginning Verify and Repair transaction
2021-10-24 01:19:04, Info CSI 00000137 [SR] Verify complete
2021-10-24 01:19:05, Info CSI 00000138 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:19:05, Info CSI 00000139 [SR] Beginning Verify and Repair transaction
2021-10-24 01:19:11, Info CSI 0000013b [SR] Verify complete
2021-10-24 01:19:11, Info CSI 0000013c [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:19:11, Info CSI 0000013d [SR] Beginning Verify and Repair transaction
2021-10-24 01:19:17, Info CSI 0000015f [SR] Verify complete
2021-10-24 01:19:18, Info CSI 00000160 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:19:18, Info CSI 00000161 [SR] Beginning Verify and Repair transaction
2021-10-24 01:19:26, Info CSI 00000166 [SR] Verify complete
2021-10-24 01:19:26, Info CSI 00000167 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:19:26, Info CSI 00000168 [SR] Beginning Verify and Repair transaction
2021-10-24 01:19:30, Info CSI 0000016a [SR] Verify complete
2021-10-24 01:19:30, Info CSI 0000016b [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:19:30, Info CSI 0000016c [SR] Beginning Verify and Repair transaction
2021-10-24 01:19:36, Info CSI 0000016e [SR] Verify complete
2021-10-24 01:19:36, Info CSI 0000016f [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:19:36, Info CSI 00000170 [SR] Beginning Verify and Repair transaction
2021-10-24 01:19:40, Info CSI 00000172 [SR] Verify complete
2021-10-24 01:19:41, Info CSI 00000173 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:19:41, Info CSI 00000174 [SR] Beginning Verify and Repair transaction
2021-10-24 01:19:44, Info CSI 00000176 [SR] Verify complete
2021-10-24 01:19:44, Info CSI 00000177 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:19:44, Info CSI 00000178 [SR] Beginning Verify and Repair transaction
2021-10-24 01:19:51, Info CSI 0000017a [SR] Verify complete
2021-10-24 01:19:51, Info CSI 0000017b [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:19:51, Info CSI 0000017c [SR] Beginning Verify and Repair transaction
2021-10-24 01:19:55, Info CSI 0000017e [SR] Verify complete
2021-10-24 01:19:55, Info CSI 0000017f [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:19:55, Info CSI 00000180 [SR] Beginning Verify and Repair transaction
2021-10-24 01:20:00, Info CSI 00000182 [SR] Verify complete
2021-10-24 01:20:01, Info CSI 00000183 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:20:01, Info CSI 00000184 [SR] Beginning Verify and Repair transaction
2021-10-24 01:20:04, Info CSI 00000186 [SR] Verify complete
2021-10-24 01:20:05, Info CSI 00000187 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:20:05, Info CSI 00000188 [SR] Beginning Verify and Repair transaction
2021-10-24 01:20:10, Info CSI 0000018a [SR] Verify complete
2021-10-24 01:20:10, Info CSI 0000018b [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:20:10, Info CSI 0000018c [SR] Beginning Verify and Repair transaction
2021-10-24 01:20:19, Info CSI 000001aa [SR] Verify complete
2021-10-24 01:20:19, Info CSI 000001ab [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:20:19, Info CSI 000001ac [SR] Beginning Verify and Repair transaction
2021-10-24 01:20:24, Info CSI 000001cd [SR] Verify complete
2021-10-24 01:20:25, Info CSI 000001ce [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:20:25, Info CSI 000001cf [SR] Beginning Verify and Repair transaction
2021-10-24 01:20:35, Info CSI 000001d1 [SR] Verify complete
2021-10-24 01:20:36, Info CSI 000001d2 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:20:36, Info CSI 000001d3 [SR] Beginning Verify and Repair transaction
2021-10-24 01:20:44, Info CSI 000001d5 [SR] Verify complete
2021-10-24 01:20:44, Info CSI 000001d6 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:20:44, Info CSI 000001d7 [SR] Beginning Verify and Repair transaction
2021-10-24 01:20:53, Info CSI 000001d9 [SR] Verify complete
2021-10-24 01:20:53, Info CSI 000001da [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:20:53, Info CSI 000001db [SR] Beginning Verify and Repair transaction
2021-10-24 01:20:56, Info CSI 000001df [SR] Verify complete
2021-10-24 01:20:57, Info CSI 000001e0 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:20:57, Info CSI 000001e1 [SR] Beginning Verify and Repair transaction
2021-10-24 01:21:00, Info CSI 000001e3 [SR] Verify complete
2021-10-24 01:21:00, Info CSI 000001e4 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:21:00, Info CSI 000001e5 [SR] Beginning Verify and Repair transaction
2021-10-24 01:21:04, Info CSI 000001e7 [SR] Verify complete
2021-10-24 01:21:04, Info CSI 000001e8 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:21:04, Info CSI 000001e9 [SR] Beginning Verify and Repair transaction
2021-10-24 01:21:06, Info CSI 000001eb [SR] Verify complete
2021-10-24 01:21:06, Info CSI 000001ec [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:21:06, Info CSI 000001ed [SR] Beginning Verify and Repair transaction
2021-10-24 01:21:08, Info CSI 000001ef [SR] Verify complete
2021-10-24 01:21:08, Info CSI 000001f0 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:21:08, Info CSI 000001f1 [SR] Beginning Verify and Repair transaction
2021-10-24 01:21:10, Info CSI 000001f3 [SR] Verify complete
2021-10-24 01:21:10, Info CSI 000001f4 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:21:10, Info CSI 000001f5 [SR] Beginning Verify and Repair transaction
2021-10-24 01:21:14, Info CSI 000001f7 [SR] Verify complete
2021-10-24 01:21:14, Info CSI 000001f8 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:21:14, Info CSI 000001f9 [SR] Beginning Verify and Repair transaction
2021-10-24 01:21:23, Info CSI 0000020c [SR] Verify complete
2021-10-24 01:21:23, Info CSI 0000020d [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:21:23, Info CSI 0000020e [SR] Beginning Verify and Repair transaction
2021-10-24 01:21:25, Info CSI 00000210 [SR] Verify complete
2021-10-24 01:21:26, Info CSI 00000211 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:21:26, Info CSI 00000212 [SR] Beginning Verify and Repair transaction
2021-10-24 01:21:29, Info CSI 00000214 [SR] Verify complete
2021-10-24 01:21:30, Info CSI 00000215 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:21:30, Info CSI 00000216 [SR] Beginning Verify and Repair transaction
2021-10-24 01:21:32, Info CSI 00000218 [SR] Verify complete
2021-10-24 01:21:32, Info CSI 00000219 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:21:32, Info CSI 0000021a [SR] Beginning Verify and Repair transaction
2021-10-24 01:21:37, Info CSI 0000021c [SR] Verify complete
2021-10-24 01:21:37, Info CSI 0000021d [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:21:37, Info CSI 0000021e [SR] Beginning Verify and Repair transaction
2021-10-24 01:21:42, Info CSI 00000221 [SR] Verify complete
2021-10-24 01:21:42, Info CSI 00000222 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:21:42, Info CSI 00000223 [SR] Beginning Verify and Repair transaction
2021-10-24 01:21:54, Info CSI 00000224 [SR] Repairing corrupted file [ml:520{260},l:90{45}]"\??\C:\Program Files\Internet Explorer\images"\[l:16{8}]"bing.ico" from store
2021-10-24 01:21:56, Info CSI 00000227 [SR] Verify complete
2021-10-24 01:21:56, Info CSI 00000228 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:21:56, Info CSI 00000229 [SR] Beginning Verify and Repair transaction
2021-10-24 01:22:01, Info CSI 0000022b [SR] Verify complete
2021-10-24 01:22:01, Info CSI 0000022c [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:22:01, Info CSI 0000022d [SR] Beginning Verify and Repair transaction
2021-10-24 01:22:04, Info CSI 0000022f [SR] Verify complete
2021-10-24 01:22:05, Info CSI 00000230 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:22:05, Info CSI 00000231 [SR] Beginning Verify and Repair transaction
2021-10-24 01:22:07, Info CSI 00000233 [SR] Verify complete
2021-10-24 01:22:07, Info CSI 00000234 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:22:07, Info CSI 00000235 [SR] Beginning Verify and Repair transaction
2021-10-24 01:22:10, Info CSI 00000237 [SR] Verify complete
2021-10-24 01:22:11, Info CSI 00000238 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:22:11, Info CSI 00000239 [SR] Beginning Verify and Repair transaction
2021-10-24 01:22:14, Info CSI 0000023b [SR] Verify complete
2021-10-24 01:22:15, Info CSI 0000023c [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:22:15, Info CSI 0000023d [SR] Beginning Verify and Repair transaction
2021-10-24 01:22:21, Info CSI 0000023f [SR] Verify complete
2021-10-24 01:22:21, Info CSI 00000240 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:22:21, Info CSI 00000241 [SR] Beginning Verify and Repair transaction
2021-10-24 01:22:25, Info CSI 00000243 [SR] Verify complete
2021-10-24 01:22:26, Info CSI 00000244 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:22:26, Info CSI 00000245 [SR] Beginning Verify and Repair transaction
2021-10-24 01:22:29, Info CSI 00000247 [SR] Verify complete
2021-10-24 01:22:29, Info CSI 00000248 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:22:29, Info CSI 00000249 [SR] Beginning Verify and Repair transaction
2021-10-24 01:22:33, Info CSI 0000024b [SR] Verify complete
2021-10-24 01:22:34, Info CSI 0000024c [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:22:34, Info CSI 0000024d [SR] Beginning Verify and Repair transaction
2021-10-24 01:22:44, Info CSI 00000261 [SR] Verify complete
2021-10-24 01:22:44, Info CSI 00000262 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:22:44, Info CSI 00000263 [SR] Beginning Verify and Repair transaction
2021-10-24 01:22:49, Info CSI 00000269 [SR] Verify complete
2021-10-24 01:22:50, Info CSI 0000026a [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:22:50, Info CSI 0000026b [SR] Beginning Verify and Repair transaction
2021-10-24 01:22:56, Info CSI 0000026d [SR] Verify complete
2021-10-24 01:22:57, Info CSI 0000026e [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:22:57, Info CSI 0000026f [SR] Beginning Verify and Repair transaction
2021-10-24 01:23:00, Info CSI 00000271 [SR] Verify complete
2021-10-24 01:23:00, Info CSI 00000272 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:23:00, Info CSI 00000273 [SR] Beginning Verify and Repair transaction
2021-10-24 01:23:16, Info CSI 00000275 [SR] Verify complete
2021-10-24 01:23:16, Info CSI 00000276 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:23:16, Info CSI 00000277 [SR] Beginning Verify and Repair transaction
2021-10-24 01:23:21, Info CSI 00000279 [SR] Verify complete
2021-10-24 01:23:22, Info CSI 0000027a [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:23:22, Info CSI 0000027b [SR] Beginning Verify and Repair transaction
2021-10-24 01:23:28, Info CSI 0000027e [SR] Verify complete
2021-10-24 01:23:29, Info CSI 0000027f [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:23:29, Info CSI 00000280 [SR] Beginning Verify and Repair transaction
2021-10-24 01:23:35, Info CSI 00000282 [SR] Verify complete
2021-10-24 01:23:35, Info CSI 00000283 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:23:35, Info CSI 00000284 [SR] Beginning Verify and Repair transaction
2021-10-24 01:23:42, Info CSI 00000286 [SR] Verify complete
2021-10-24 01:23:43, Info CSI 00000287 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:23:43, Info CSI 00000288 [SR] Beginning Verify and Repair transaction
2021-10-24 01:23:49, Info CSI 0000028c [SR] Verify complete
2021-10-24 01:23:49, Info CSI 0000028d [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:23:49, Info CSI 0000028e [SR] Beginning Verify and Repair transaction
2021-10-24 01:23:52, Info CSI 00000290 [SR] Verify complete
2021-10-24 01:23:53, Info CSI 00000291 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:23:53, Info CSI 00000292 [SR] Beginning Verify and Repair transaction
2021-10-24 01:23:59, Info CSI 00000294 [SR] Verify complete
2021-10-24 01:24:00, Info CSI 00000295 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:24:00, Info CSI 00000296 [SR] Beginning Verify and Repair transaction
2021-10-24 01:24:04, Info CSI 00000298 [SR] Verify complete
2021-10-24 01:24:04, Info CSI 00000299 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:24:04, Info CSI 0000029a [SR] Beginning Verify and Repair transaction
2021-10-24 01:24:07, Info CSI 0000029c [SR] Verify complete
2021-10-24 01:24:08, Info CSI 0000029d [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:24:08, Info CSI 0000029e [SR] Beginning Verify and Repair transaction
2021-10-24 01:24:12, Info CSI 000002a2 [SR] Verify complete
2021-10-24 01:24:13, Info CSI 000002a3 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:24:13, Info CSI 000002a4 [SR] Beginning Verify and Repair transaction
2021-10-24 01:24:17, Info CSI 000002a6 [SR] Verify complete
2021-10-24 01:24:18, Info CSI 000002a7 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:24:18, Info CSI 000002a8 [SR] Beginning Verify and Repair transaction
2021-10-24 01:24:21, Info CSI 000002aa [SR] Verify complete
2021-10-24 01:24:22, Info CSI 000002ab [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:24:22, Info CSI 000002ac [SR] Beginning Verify and Repair transaction
2021-10-24 01:24:37, Info CSI 000002ae [SR] Verify complete
2021-10-24 01:24:37, Info CSI 000002af [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:24:37, Info CSI 000002b0 [SR] Beginning Verify and Repair transaction
2021-10-24 01:24:41, Info CSI 000002b2 [SR] Verify complete
2021-10-24 01:24:41, Info CSI 000002b3 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:24:41, Info CSI 000002b4 [SR] Beginning Verify and Repair transaction
2021-10-24 01:24:47, Info CSI 000002b7 [SR] Verify complete
2021-10-24 01:24:47, Info CSI 000002b8 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:24:47, Info CSI 000002b9 [SR] Beginning Verify and Repair transaction
2021-10-24 01:24:57, Info CSI 000002bb [SR] Verify complete
2021-10-24 01:24:58, Info CSI 000002bc [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:24:58, Info CSI 000002bd [SR] Beginning Verify and Repair transaction
2021-10-24 01:25:05, Info CSI 000002bf [SR] Verify complete
2021-10-24 01:25:06, Info CSI 000002c0 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:25:06, Info CSI 000002c1 [SR] Beginning Verify and Repair transaction
2021-10-24 01:25:20, Info CSI 000002c4 [SR] Verify complete
2021-10-24 01:25:22, Info CSI 000002c5 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:25:22, Info CSI 000002c6 [SR] Beginning Verify and Repair transaction
2021-10-24 01:25:28, Info CSI 000002c8 [SR] Verify complete
2021-10-24 01:25:28, Info CSI 000002c9 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:25:28, Info CSI 000002ca [SR] Beginning Verify and Repair transaction
2021-10-24 01:26:46, Info CSI 000002cc [SR] Verify complete
2021-10-24 01:26:54, Info CSI 000002cd [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:26:54, Info CSI 000002ce [SR] Beginning Verify and Repair transaction
2021-10-24 01:27:11, Info CSI 000002d1 [SR] Verify complete
2021-10-24 01:27:12, Info CSI 000002d2 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:27:12, Info CSI 000002d3 [SR] Beginning Verify and Repair transaction
2021-10-24 01:27:17, Info CSI 000002d5 [SR] Verify complete
2021-10-24 01:27:17, Info CSI 000002d6 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:27:17, Info CSI 000002d7 [SR] Beginning Verify and Repair transaction
2021-10-24 01:27:20, Info CSI 000002d9 [SR] Verify complete
2021-10-24 01:27:21, Info CSI 000002da [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:27:21, Info CSI 000002db [SR] Beginning Verify and Repair transaction
2021-10-24 01:27:25, Info CSI 000002dd [SR] Verify complete
2021-10-24 01:27:25, Info CSI 000002de [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:27:25, Info CSI 000002df [SR] Beginning Verify and Repair transaction
2021-10-24 01:27:29, Info CSI 000002e1 [SR] Verify complete
2021-10-24 01:27:30, Info CSI 000002e2 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:27:30, Info CSI 000002e3 [SR] Beginning Verify and Repair transaction
2021-10-24 01:27:33, Info CSI 000002e6 [SR] Verify complete
2021-10-24 01:27:34, Info CSI 000002e7 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:27:34, Info CSI 000002e8 [SR] Beginning Verify and Repair transaction
2021-10-24 01:27:38, Info CSI 000002ea [SR] Verify complete
2021-10-24 01:27:38, Info CSI 000002eb [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:27:38, Info CSI 000002ec [SR] Beginning Verify and Repair transaction
2021-10-24 01:27:41, Info CSI 000002ee [SR] Verify complete
2021-10-24 01:27:41, Info CSI 000002ef [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:27:41, Info CSI 000002f0 [SR] Beginning Verify and Repair transaction
2021-10-24 01:27:44, Info CSI 000002f3 [SR] Verify complete
2021-10-24 01:27:44, Info CSI 000002f4 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:27:44, Info CSI 000002f5 [SR] Beginning Verify and Repair transaction
2021-10-24 01:27:47, Info CSI 000002f9 [SR] Verify complete
2021-10-24 01:27:48, Info CSI 000002fa [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:27:48, Info CSI 000002fb [SR] Beginning Verify and Repair transaction
2021-10-24 01:27:52, Info CSI 000002fe [SR] Verify complete
2021-10-24 01:27:52, Info CSI 000002ff [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:27:52, Info CSI 00000300 [SR] Beginning Verify and Repair transaction
2021-10-24 01:27:55, Info CSI 00000304 [SR] Verify complete
2021-10-24 01:27:56, Info CSI 00000305 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:27:56, Info CSI 00000306 [SR] Beginning Verify and Repair transaction
2021-10-24 01:28:00, Info CSI 0000030a [SR] Verify complete
2021-10-24 01:28:01, Info CSI 0000030b [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:28:01, Info CSI 0000030c [SR] Beginning Verify and Repair transaction
2021-10-24 01:28:04, Info CSI 0000030f [SR] Verify complete
2021-10-24 01:28:04, Info CSI 00000310 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:28:04, Info CSI 00000311 [SR] Beginning Verify and Repair transaction
2021-10-24 01:28:09, Info CSI 00000314 [SR] Verify complete
2021-10-24 01:28:09, Info CSI 00000315 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:28:09, Info CSI 00000316 [SR] Beginning Verify and Repair transaction
2021-10-24 01:28:12, Info CSI 00000318 [SR] Verify complete
2021-10-24 01:28:12, Info CSI 00000319 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:28:12, Info CSI 0000031a [SR] Beginning Verify and Repair transaction
2021-10-24 01:28:17, Info CSI 0000031c [SR] Verify complete
2021-10-24 01:28:17, Info CSI 0000031d [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:28:17, Info CSI 0000031e [SR] Beginning Verify and Repair transaction
2021-10-24 01:28:23, Info CSI 00000321 [SR] Verify complete
2021-10-24 01:28:23, Info CSI 00000322 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:28:23, Info CSI 00000323 [SR] Beginning Verify and Repair transaction
2021-10-24 01:28:26, Info CSI 00000325 [SR] Verify complete
2021-10-24 01:28:26, Info CSI 00000326 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:28:26, Info CSI 00000327 [SR] Beginning Verify and Repair transaction
2021-10-24 01:28:29, Info CSI 00000329 [SR] Verify complete
2021-10-24 01:28:30, Info CSI 0000032a [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:28:30, Info CSI 0000032b [SR] Beginning Verify and Repair transaction
2021-10-24 01:28:31, Info CSI 0000032d [SR] Verify complete
2021-10-24 01:28:32, Info CSI 0000032e [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:28:32, Info CSI 0000032f [SR] Beginning Verify and Repair transaction
2021-10-24 01:28:35, Info CSI 00000331 [SR] Verify complete
2021-10-24 01:28:36, Info CSI 00000332 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:28:36, Info CSI 00000333 [SR] Beginning Verify and Repair transaction
2021-10-24 01:28:37, Info CSI 00000335 [SR] Verify complete
2021-10-24 01:28:37, Info CSI 00000336 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:28:37, Info CSI 00000337 [SR] Beginning Verify and Repair transaction
2021-10-24 01:28:41, Info CSI 00000339 [SR] Verify complete
2021-10-24 01:28:42, Info CSI 0000033a [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:28:42, Info CSI 0000033b [SR] Beginning Verify and Repair transaction
2021-10-24 01:28:48, Info CSI 0000033d [SR] Verify complete
2021-10-24 01:28:48, Info CSI 0000033e [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:28:48, Info CSI 0000033f [SR] Beginning Verify and Repair transaction
2021-10-24 01:28:51, Info CSI 00000341 [SR] Verify complete
2021-10-24 01:28:51, Info CSI 00000342 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:28:51, Info CSI 00000343 [SR] Beginning Verify and Repair transaction
2021-10-24 01:28:53, Info CSI 00000345 [SR] Verify complete
2021-10-24 01:28:53, Info CSI 00000346 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:28:53, Info CSI 00000347 [SR] Beginning Verify and Repair transaction
2021-10-24 01:28:56, Info CSI 00000349 [SR] Verify complete
2021-10-24 01:28:56, Info CSI 0000034a [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:28:56, Info CSI 0000034b [SR] Beginning Verify and Repair transaction
2021-10-24 01:29:00, Info CSI 0000034d [SR] Verify complete
2021-10-24 01:29:00, Info CSI 0000034e [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:29:00, Info CSI 0000034f [SR] Beginning Verify and Repair transaction
2021-10-24 01:29:07, Info CSI 00000351 [SR] Verify complete
2021-10-24 01:29:07, Info CSI 00000352 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:29:07, Info CSI 00000353 [SR] Beginning Verify and Repair transaction
2021-10-24 01:29:13, Info CSI 00000355 [SR] Verify complete
2021-10-24 01:29:13, Info CSI 00000356 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:29:13, Info CSI 00000357 [SR] Beginning Verify and Repair transaction
2021-10-24 01:29:26, Info CSI 00000359 [SR] Verify complete
2021-10-24 01:29:26, Info CSI 0000035a [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:29:26, Info CSI 0000035b [SR] Beginning Verify and Repair transaction
2021-10-24 01:29:29, Info CSI 0000035d [SR] Verify complete
2021-10-24 01:29:29, Info CSI 0000035e [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:29:29, Info CSI 0000035f [SR] Beginning Verify and Repair transaction
2021-10-24 01:29:31, Info CSI 00000361 [SR] Verify complete
2021-10-24 01:29:31, Info CSI 00000362 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:29:31, Info CSI 00000363 [SR] Beginning Verify and Repair transaction
2021-10-24 01:29:34, Info CSI 00000365 [SR] Verify complete
2021-10-24 01:29:34, Info CSI 00000366 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:29:34, Info CSI 00000367 [SR] Beginning Verify and Repair transaction
2021-10-24 01:29:37, Info CSI 00000369 [SR] Verify complete
2021-10-24 01:29:38, Info CSI 0000036a [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:29:38, Info CSI 0000036b [SR] Beginning Verify and Repair transaction
2021-10-24 01:29:40, Info CSI 0000036d [SR] Verify complete
2021-10-24 01:29:40, Info CSI 0000036e [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:29:40, Info CSI 0000036f [SR] Beginning Verify and Repair transaction
2021-10-24 01:29:42, Info CSI 00000371 [SR] Verify complete
2021-10-24 01:29:42, Info CSI 00000372 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:29:42, Info CSI 00000373 [SR] Beginning Verify and Repair transaction
2021-10-24 01:29:43, Info CSI 00000375 [SR] Verify complete
2021-10-24 01:29:43, Info CSI 00000376 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:29:43, Info CSI 00000377 [SR] Beginning Verify and Repair transaction
2021-10-24 01:29:47, Info CSI 00000379 [SR] Verify complete
2021-10-24 01:29:47, Info CSI 0000037a [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:29:47, Info CSI 0000037b [SR] Beginning Verify and Repair transaction
2021-10-24 01:29:50, Info CSI 0000037d [SR] Verify complete
2021-10-24 01:29:50, Info CSI 0000037e [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:29:50, Info CSI 0000037f [SR] Beginning Verify and Repair transaction
2021-10-24 01:29:53, Info CSI 00000381 [SR] Verify complete
2021-10-24 01:29:53, Info CSI 00000382 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:29:53, Info CSI 00000383 [SR] Beginning Verify and Repair transaction
2021-10-24 01:29:55, Info CSI 00000385 [SR] Verify complete
2021-10-24 01:29:56, Info CSI 00000386 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:29:56, Info CSI 00000387 [SR] Beginning Verify and Repair transaction
2021-10-24 01:29:58, Info CSI 00000389 [SR] Verify complete
2021-10-24 01:29:58, Info CSI 0000038a [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:29:58, Info CSI 0000038b [SR] Beginning Verify and Repair transaction
2021-10-24 01:29:59, Info CSI 0000038d [SR] Verify complete
2021-10-24 01:30:00, Info CSI 0000038e [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:30:00, Info CSI 0000038f [SR] Beginning Verify and Repair transaction
2021-10-24 01:30:00, Info CSI 00000391 [SR] Verify complete
2021-10-24 01:30:01, Info CSI 00000392 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:30:01, Info CSI 00000393 [SR] Beginning Verify and Repair transaction
2021-10-24 01:30:06, Info CSI 000003a1 [SR] Verify complete
2021-10-24 01:30:06, Info CSI 000003a2 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:30:06, Info CSI 000003a3 [SR] Beginning Verify and Repair transaction
2021-10-24 01:30:10, Info CSI 000003a5 [SR] Verify complete
2021-10-24 01:30:10, Info CSI 000003a6 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:30:10, Info CSI 000003a7 [SR] Beginning Verify and Repair transaction
2021-10-24 01:30:14, Info CSI 000003a9 [SR] Verify complete
2021-10-24 01:30:14, Info CSI 000003aa [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:30:14, Info CSI 000003ab [SR] Beginning Verify and Repair transaction
2021-10-24 01:30:17, Info CSI 000003ad [SR] Verify complete
2021-10-24 01:30:18, Info CSI 000003ae [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:30:18, Info CSI 000003af [SR] Beginning Verify and Repair transaction
2021-10-24 01:30:21, Info CSI 000003b1 [SR] Verify complete
2021-10-24 01:30:22, Info CSI 000003b2 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:30:22, Info CSI 000003b3 [SR] Beginning Verify and Repair transaction
2021-10-24 01:30:26, Info CSI 000003b5 [SR] Verify complete
2021-10-24 01:30:27, Info CSI 000003b6 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:30:27, Info CSI 000003b7 [SR] Beginning Verify and Repair transaction
2021-10-24 01:30:30, Info CSI 000003b9 [SR] Verify complete
2021-10-24 01:30:31, Info CSI 000003ba [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:30:31, Info CSI 000003bb [SR] Beginning Verify and Repair transaction
2021-10-24 01:30:35, Info CSI 000003bd [SR] Verify complete
2021-10-24 01:30:35, Info CSI 000003be [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:30:35, Info CSI 000003bf [SR] Beginning Verify and Repair transaction
2021-10-24 01:30:41, Info CSI 000003c1 [SR] Verify complete
2021-10-24 01:30:41, Info CSI 000003c2 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:30:41, Info CSI 000003c3 [SR] Beginning Verify and Repair transaction
2021-10-24 01:30:47, Info CSI 000003c5 [SR] Verify complete
2021-10-24 01:30:47, Info CSI 000003c6 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:30:47, Info CSI 000003c7 [SR] Beginning Verify and Repair transaction
2021-10-24 01:30:48, Info CSI 000003c9 [SR] Verify complete
2021-10-24 01:30:49, Info CSI 000003ca [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:30:49, Info CSI 000003cb [SR] Beginning Verify and Repair transaction
2021-10-24 01:30:52, Info CSI 000003cd [SR] Verify complete
2021-10-24 01:30:53, Info CSI 000003ce [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:30:53, Info CSI 000003cf [SR] Beginning Verify and Repair transaction
2021-10-24 01:31:03, Info CSI 000003d4 [SR] Verify complete
2021-10-24 01:31:03, Info CSI 000003d5 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:31:03, Info CSI 000003d6 [SR] Beginning Verify and Repair transaction
2021-10-24 01:31:14, Info CSI 000003d8 [SR] Verify complete
2021-10-24 01:31:14, Info CSI 000003d9 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:31:14, Info CSI 000003da [SR] Beginning Verify and Repair transaction
2021-10-24 01:31:18, Info CSI 000003df [SR] Verify complete
2021-10-24 01:31:18, Info CSI 000003e0 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:31:18, Info CSI 000003e1 [SR] Beginning Verify and Repair transaction
2021-10-24 01:31:24, Info CSI 000003e3 [SR] Verify complete
2021-10-24 01:31:24, Info CSI 000003e4 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:31:24, Info CSI 000003e5 [SR] Beginning Verify and Repair transaction
2021-10-24 01:31:29, Info CSI 000003f2 [SR] Verify complete
2021-10-24 01:31:30, Info CSI 000003f3 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:31:30, Info CSI 000003f4 [SR] Beginning Verify and Repair transaction
2021-10-24 01:31:36, Info CSI 000003f8 [SR] Verify complete
2021-10-24 01:31:37, Info CSI 000003f9 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:31:37, Info CSI 000003fa [SR] Beginning Verify and Repair transaction
2021-10-24 01:31:41, Info CSI 000003ff [SR] Verify complete
2021-10-24 01:31:41, Info CSI 00000400 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:31:41, Info CSI 00000401 [SR] Beginning Verify and Repair transaction
2021-10-24 01:31:45, Info CSI 00000403 [SR] Verify complete
2021-10-24 01:31:45, Info CSI 00000404 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:31:45, Info CSI 00000405 [SR] Beginning Verify and Repair transaction
2021-10-24 01:31:48, Info CSI 00000407 [SR] Verify complete
2021-10-24 01:31:48, Info CSI 00000408 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:31:48, Info CSI 00000409 [SR] Beginning Verify and Repair transaction
2021-10-24 01:31:51, Info CSI 0000040d [SR] Verify complete
2021-10-24 01:31:52, Info CSI 0000040e [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:31:52, Info CSI 0000040f [SR] Beginning Verify and Repair transaction
2021-10-24 01:31:54, Info CSI 00000411 [SR] Verify complete
2021-10-24 01:31:54, Info CSI 00000412 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:31:54, Info CSI 00000413 [SR] Beginning Verify and Repair transaction
2021-10-24 01:31:59, Info CSI 00000423 [SR] Verify complete
2021-10-24 01:31:59, Info CSI 00000424 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:31:59, Info CSI 00000425 [SR] Beginning Verify and Repair transaction
2021-10-24 01:32:03, Info CSI 0000043c [SR] Verify complete
2021-10-24 01:32:04, Info CSI 0000043d [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:32:04, Info CSI 0000043e [SR] Beginning Verify and Repair transaction
2021-10-24 01:32:07, Info CSI 00000440 [SR] Verify complete
2021-10-24 01:32:07, Info CSI 00000441 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:32:07, Info CSI 00000442 [SR] Beginning Verify and Repair transaction
2021-10-24 01:32:11, Info CSI 00000444 [SR] Verify complete
2021-10-24 01:32:11, Info CSI 00000445 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:32:11, Info CSI 00000446 [SR] Beginning Verify and Repair transaction
2021-10-24 01:32:14, Info CSI 00000448 [SR] Verify complete
2021-10-24 01:32:14, Info CSI 00000449 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:32:14, Info CSI 0000044a [SR] Beginning Verify and Repair transaction
2021-10-24 01:32:18, Info CSI 0000044c [SR] Verify complete
2021-10-24 01:32:18, Info CSI 0000044d [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:32:18, Info CSI 0000044e [SR] Beginning Verify and Repair transaction
2021-10-24 01:32:20, Info CSI 00000450 [SR] Verify complete
2021-10-24 01:32:20, Info CSI 00000451 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:32:20, Info CSI 00000452 [SR] Beginning Verify and Repair transaction
2021-10-24 01:32:25, Info CSI 00000464 [SR] Verify complete
2021-10-24 01:32:25, Info CSI 00000465 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:32:25, Info CSI 00000466 [SR] Beginning Verify and Repair transaction
2021-10-24 01:32:28, Info CSI 00000468 [SR] Verify complete
2021-10-24 01:32:28, Info CSI 00000469 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:32:28, Info CSI 0000046a [SR] Beginning Verify and Repair transaction
2021-10-24 01:32:34, Info CSI 0000046c [SR] Verify complete
2021-10-24 01:32:34, Info CSI 0000046d [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:32:34, Info CSI 0000046e [SR] Beginning Verify and Repair transaction
2021-10-24 01:32:37, Info CSI 00000470 [SR] Verify complete
2021-10-24 01:32:37, Info CSI 00000471 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:32:37, Info CSI 00000472 [SR] Beginning Verify and Repair transaction
2021-10-24 01:32:43, Info CSI 00000480 [SR] Verify complete
2021-10-24 01:32:43, Info CSI 00000481 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:32:43, Info CSI 00000482 [SR] Beginning Verify and Repair transaction
2021-10-24 01:32:45, Info CSI 00000484 [SR] Verify complete
2021-10-24 01:32:46, Info CSI 00000485 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:32:46, Info CSI 00000486 [SR] Beginning Verify and Repair transaction
2021-10-24 01:32:49, Info CSI 00000488 [SR] Verify complete
2021-10-24 01:32:49, Info CSI 00000489 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:32:49, Info CSI 0000048a [SR] Beginning Verify and Repair transaction
2021-10-24 01:32:55, Info CSI 0000048d [SR] Verify complete
2021-10-24 01:32:56, Info CSI 0000048e [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:32:56, Info CSI 0000048f [SR] Beginning Verify and Repair transaction
2021-10-24 01:32:58, Info CSI 00000491 [SR] Verify complete
2021-10-24 01:32:59, Info CSI 00000492 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:32:59, Info CSI 00000493 [SR] Beginning Verify and Repair transaction
2021-10-24 01:33:00, Info CSI 00000495 [SR] Verify complete
2021-10-24 01:33:01, Info CSI 00000496 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:33:01, Info CSI 00000497 [SR] Beginning Verify and Repair transaction
2021-10-24 01:33:03, Info CSI 00000499 [SR] Verify complete
2021-10-24 01:33:03, Info CSI 0000049a [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:33:03, Info CSI 0000049b [SR] Beginning Verify and Repair transaction
2021-10-24 01:33:07, Info CSI 0000049d [SR] Verify complete
2021-10-24 01:33:07, Info CSI 0000049e [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:33:07, Info CSI 0000049f [SR] Beginning Verify and Repair transaction
2021-10-24 01:33:11, Info CSI 000004a1 [SR] Verify complete
2021-10-24 01:33:11, Info CSI 000004a2 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:33:11, Info CSI 000004a3 [SR] Beginning Verify and Repair transaction
2021-10-24 01:33:14, Info CSI 000004a5 [SR] Verify complete
2021-10-24 01:33:14, Info CSI 000004a6 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:33:14, Info CSI 000004a7 [SR] Beginning Verify and Repair transaction
2021-10-24 01:33:17, Info CSI 000004a9 [SR] Verify complete
2021-10-24 01:33:18, Info CSI 000004aa [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:33:18, Info CSI 000004ab [SR] Beginning Verify and Repair transaction
2021-10-24 01:33:24, Info CSI 000004c5 [SR] Verify complete
2021-10-24 01:33:24, Info CSI 000004c6 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:33:24, Info CSI 000004c7 [SR] Beginning Verify and Repair transaction
2021-10-24 01:33:27, Info CSI 000004c9 [SR] Cannot repair member file [l:28{14}]"iassdo.dll.mui" of Microsoft-Windows-Networking-Internet_Authentication_Service_Iassdo.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"en-US", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2021-10-24 01:33:28, Info CSI 000004cb [SR] Cannot repair member file [l:28{14}]"iassdo.dll.mui" of Microsoft-Windows-Networking-Internet_Authentication_Service_Iassdo.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"en-US", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2021-10-24 01:33:28, Info CSI 000004cc [SR] This component was referenced by [l:266{133}]"Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~en-US~6.1.7601.17514.Windows Foundation Language Pack"
2021-10-24 01:33:28, Info CSI 000004cf [SR] Could not reproject corrupted file [ml:60{30},l:58{29}]"\??\C:\Windows\SysWOW64\en-US"\[l:28{14}]"iassdo.dll.mui"; source file in store is also corrupted
2021-10-24 01:33:28, Info CSI 000004d1 [SR] Verify complete
2021-10-24 01:33:29, Info CSI 000004d2 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:33:29, Info CSI 000004d3 [SR] Beginning Verify and Repair transaction
2021-10-24 01:33:31, Info CSI 000004d5 [SR] Verify complete
2021-10-24 01:33:31, Info CSI 000004d6 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:33:31, Info CSI 000004d7 [SR] Beginning Verify and Repair transaction
2021-10-24 01:33:42, Info CSI 000004d9 [SR] Verify complete
2021-10-24 01:33:42, Info CSI 000004da [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:33:42, Info CSI 000004db [SR] Beginning Verify and Repair transaction
2021-10-24 01:33:45, Info CSI 000004dd [SR] Verify complete
2021-10-24 01:33:45, Info CSI 000004de [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:33:45, Info CSI 000004df [SR] Beginning Verify and Repair transaction
2021-10-24 01:33:48, Info CSI 000004e1 [SR] Verify complete
2021-10-24 01:33:49, Info CSI 000004e2 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:33:49, Info CSI 000004e3 [SR] Beginning Verify and Repair transaction
2021-10-24 01:33:51, Info CSI 000004e5 [SR] Verify complete
2021-10-24 01:33:51, Info CSI 000004e6 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:33:51, Info CSI 000004e7 [SR] Beginning Verify and Repair transaction
2021-10-24 01:33:54, Info CSI 000004eb [SR] Verify complete
2021-10-24 01:33:54, Info CSI 000004ec [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:33:54, Info CSI 000004ed [SR] Beginning Verify and Repair transaction
2021-10-24 01:33:56, Info CSI 000004ef [SR] Verify complete
2021-10-24 01:33:56, Info CSI 000004f0 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:33:56, Info CSI 000004f1 [SR] Beginning Verify and Repair transaction
2021-10-24 01:33:58, Info CSI 000004f3 [SR] Verify complete
2021-10-24 01:33:58, Info CSI 000004f4 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:33:58, Info CSI 000004f5 [SR] Beginning Verify and Repair transaction
2021-10-24 01:34:01, Info CSI 000004f7 [SR] Verify complete
2021-10-24 01:34:01, Info CSI 000004f8 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:34:01, Info CSI 000004f9 [SR] Beginning Verify and Repair transaction
2021-10-24 01:34:05, Info CSI 000004fb [SR] Verify complete
2021-10-24 01:34:05, Info CSI 000004fc [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:34:05, Info CSI 000004fd [SR] Beginning Verify and Repair transaction
2021-10-24 01:34:08, Info CSI 000004ff [SR] Verify complete
2021-10-24 01:34:08, Info CSI 00000500 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:34:08, Info CSI 00000501 [SR] Beginning Verify and Repair transaction
2021-10-24 01:34:11, Info CSI 00000503 [SR] Verify complete
2021-10-24 01:34:11, Info CSI 00000504 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:34:11, Info CSI 00000505 [SR] Beginning Verify and Repair transaction
2021-10-24 01:34:14, Info CSI 00000508 [SR] Verify complete
2021-10-24 01:34:15, Info CSI 00000509 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:34:15, Info CSI 0000050a [SR] Beginning Verify and Repair transaction
2021-10-24 01:34:17, Info CSI 0000050c [SR] Verify complete
2021-10-24 01:34:18, Info CSI 0000050d [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:34:18, Info CSI 0000050e [SR] Beginning Verify and Repair transaction
2021-10-24 01:34:20, Info CSI 00000510 [SR] Verify complete
2021-10-24 01:34:21, Info CSI 00000511 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:34:21, Info CSI 00000512 [SR] Beginning Verify and Repair transaction
2021-10-24 01:34:22, Info CSI 00000514 [SR] Verify complete
2021-10-24 01:34:23, Info CSI 00000515 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:34:23, Info CSI 00000516 [SR] Beginning Verify and Repair transaction
2021-10-24 01:34:26, Info CSI 0000051a [SR] Verify complete
2021-10-24 01:34:26, Info CSI 0000051b [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:34:26, Info CSI 0000051c [SR] Beginning Verify and Repair transaction
2021-10-24 01:34:30, Info CSI 0000051e [SR] Verify complete
2021-10-24 01:34:30, Info CSI 0000051f [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:34:30, Info CSI 00000520 [SR] Beginning Verify and Repair transaction
2021-10-24 01:34:32, Info CSI 00000522 [SR] Verify complete
2021-10-24 01:34:33, Info CSI 00000523 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:34:33, Info CSI 00000524 [SR] Beginning Verify and Repair transaction
2021-10-24 01:34:37, Info CSI 00000526 [SR] Verify complete
2021-10-24 01:34:37, Info CSI 00000527 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:34:37, Info CSI 00000528 [SR] Beginning Verify and Repair transaction
2021-10-24 01:34:40, Info CSI 0000052b [SR] Verify complete
2021-10-24 01:34:41, Info CSI 0000052c [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:34:41, Info CSI 0000052d [SR] Beginning Verify and Repair transaction
2021-10-24 01:34:45, Info CSI 0000052f [SR] Verify complete
2021-10-24 01:34:46, Info CSI 00000530 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:34:46, Info CSI 00000531 [SR] Beginning Verify and Repair transaction
2021-10-24 01:34:50, Info CSI 00000533 [SR] Verify complete
2021-10-24 01:34:51, Info CSI 00000534 [SR] Verifying 100 (0x0000000000000064) components
2021-10-24 01:34:51, Info CSI 00000535 [SR] Beginning Verify and Repair transaction
2021-10-24 01:34:55, Info CSI 00000537 [SR] Verify complete
2021-10-24 01:34:55, Info CSI 00000538 [SR] Verifying 82 (0x0000000000000052) components
2021-10-24 01:34:55, Info CSI 00000539 [SR] Beginning Verify and Repair transaction
2021-10-24 01:34:58, Info CSI 0000053b [SR] Verify complete
2021-10-24 01:34:58, Info CSI 0000053c [SR] Repairing 2 components
2021-10-24 01:34:58, Info CSI 0000053d [SR] Beginning Verify and Repair transaction
2021-10-24 01:34:59, Info CSI 0000053f [SR] Cannot repair member file [l:28{14}]"iassdo.dll.mui" of Microsoft-Windows-Networking-Internet_Authentication_Service_Iassdo.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"en-US", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2021-10-24 01:34:59, Info CSI 00000540 [SR] Repairing corrupted file [ml:520{260},l:90{45}]"\??\C:\Program Files\Internet Explorer\images"\[l:16{8}]"bing.ico" from store
2021-10-24 01:34:59, Info CSI 00000542 [SR] Cannot repair member file [l:28{14}]"iassdo.dll.mui" of Microsoft-Windows-Networking-Internet_Authentication_Service_Iassdo.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"en-US", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2021-10-24 01:34:59, Info CSI 00000543 [SR] This component was referenced by [l:266{133}]"Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~en-US~6.1.7601.17514.Windows Foundation Language Pack"
2021-10-24 01:34:59, Info CSI 00000546 [SR] Could not reproject corrupted file [ml:60{30},l:58{29}]"\??\C:\Windows\SysWOW64\en-US"\[l:28{14}]"iassdo.dll.mui"; source file in store is also corrupted
2021-10-24 01:34:59, Info CSI 00000548 [SR] Repair complete
2021-10-24 01:34:59, Info CSI 00000549 [SR] Committing transaction
2021-10-24 01:34:59, Info CSI 0000054d [SR] Verify and Repair Transaction completed. All files and registry keys listed in this transaction have been successfully repaired
2021-11-07 19:25:25, Info CSI 00000009 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:25:25, Info CSI 0000000a [SR] Beginning Verify and Repair transaction
2021-11-07 19:25:30, Info CSI 0000000c [SR] Verify complete
2021-11-07 19:25:32, Info CSI 0000000d [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:25:32, Info CSI 0000000e [SR] Beginning Verify and Repair transaction
2021-11-07 19:25:37, Info CSI 00000010 [SR] Verify complete
2021-11-07 19:25:41, Info CSI 00000011 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:25:41, Info CSI 00000012 [SR] Beginning Verify and Repair transaction
2021-11-07 19:25:45, Info CSI 00000014 [SR] Verify complete
2021-11-07 19:25:48, Info CSI 00000015 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:25:48, Info CSI 00000016 [SR] Beginning Verify and Repair transaction
2021-11-07 19:25:51, Info CSI 00000018 [SR] Verify complete
2021-11-07 19:25:54, Info CSI 00000019 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:25:54, Info CSI 0000001a [SR] Beginning Verify and Repair transaction
2021-11-07 19:25:59, Info CSI 0000001c [SR] Verify complete
2021-11-07 19:26:00, Info CSI 0000001d [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:26:00, Info CSI 0000001e [SR] Beginning Verify and Repair transaction
2021-11-07 19:26:04, Info CSI 00000020 [SR] Verify complete
2021-11-07 19:26:05, Info CSI 00000021 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:26:05, Info CSI 00000022 [SR] Beginning Verify and Repair transaction
2021-11-07 19:26:08, Info CSI 00000024 [SR] Verify complete
2021-11-07 19:26:09, Info CSI 00000025 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:26:09, Info CSI 00000026 [SR] Beginning Verify and Repair transaction
2021-11-07 19:26:10, Info CSI 00000028 [SR] Verify complete
2021-11-07 19:26:12, Info CSI 00000029 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:26:12, Info CSI 0000002a [SR] Beginning Verify and Repair transaction
2021-11-07 19:26:14, Info CSI 0000002c [SR] Verify complete
2021-11-07 19:26:15, Info CSI 0000002d [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:26:15, Info CSI 0000002e [SR] Beginning Verify and Repair transaction
2021-11-07 19:26:17, Info CSI 00000030 [SR] Verify complete
2021-11-07 19:26:18, Info CSI 00000031 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:26:18, Info CSI 00000032 [SR] Beginning Verify and Repair transaction
2021-11-07 19:26:20, Info CSI 00000034 [SR] Verify complete
2021-11-07 19:26:21, Info CSI 00000035 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:26:21, Info CSI 00000036 [SR] Beginning Verify and Repair transaction
2021-11-07 19:26:23, Info CSI 00000038 [SR] Verify complete
2021-11-07 19:26:24, Info CSI 00000039 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:26:24, Info CSI 0000003a [SR] Beginning Verify and Repair transaction
2021-11-07 19:26:26, Info CSI 0000003c [SR] Verify complete
2021-11-07 19:26:27, Info CSI 0000003d [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:26:27, Info CSI 0000003e [SR] Beginning Verify and Repair transaction
2021-11-07 19:26:29, Info CSI 00000040 [SR] Verify complete
2021-11-07 19:26:30, Info CSI 00000041 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:26:30, Info CSI 00000042 [SR] Beginning Verify and Repair transaction
2021-11-07 19:26:32, Info CSI 00000044 [SR] Verify complete
2021-11-07 19:26:33, Info CSI 00000045 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:26:33, Info CSI 00000046 [SR] Beginning Verify and Repair transaction
2021-11-07 19:26:35, Info CSI 00000048 [SR] Verify complete
2021-11-07 19:26:36, Info CSI 00000049 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:26:36, Info CSI 0000004a [SR] Beginning Verify and Repair transaction
2021-11-07 19:26:38, Info CSI 0000004c [SR] Verify complete
2021-11-07 19:26:39, Info CSI 0000004d [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:26:39, Info CSI 0000004e [SR] Beginning Verify and Repair transaction
2021-11-07 19:26:41, Info CSI 00000050 [SR] Verify complete
2021-11-07 19:26:42, Info CSI 00000051 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:26:42, Info CSI 00000052 [SR] Beginning Verify and Repair transaction
2021-11-07 19:26:43, Info CSI 00000054 [SR] Verify complete
2021-11-07 19:26:45, Info CSI 00000055 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:26:45, Info CSI 00000056 [SR] Beginning Verify and Repair transaction
2021-11-07 19:26:46, Info CSI 00000058 [SR] Verify complete
2021-11-07 19:26:47, Info CSI 00000059 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:26:47, Info CSI 0000005a [SR] Beginning Verify and Repair transaction
2021-11-07 19:26:49, Info CSI 0000005c [SR] Verify complete
2021-11-07 19:26:51, Info CSI 0000005d [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:26:51, Info CSI 0000005e [SR] Beginning Verify and Repair transaction
2021-11-07 19:26:52, Info CSI 00000060 [SR] Verify complete
2021-11-07 19:26:53, Info CSI 00000061 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:26:53, Info CSI 00000062 [SR] Beginning Verify and Repair transaction
2021-11-07 19:26:55, Info CSI 00000064 [SR] Verify complete
2021-11-07 19:26:56, Info CSI 00000065 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:26:56, Info CSI 00000066 [SR] Beginning Verify and Repair transaction
2021-11-07 19:26:58, Info CSI 00000068 [SR] Verify complete
2021-11-07 19:26:59, Info CSI 00000069 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:26:59, Info CSI 0000006a [SR] Beginning Verify and Repair transaction
2021-11-07 19:27:01, Info CSI 0000006c [SR] Verify complete
2021-11-07 19:27:02, Info CSI 0000006d [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:27:02, Info CSI 0000006e [SR] Beginning Verify and Repair transaction
2021-11-07 19:27:04, Info CSI 00000070 [SR] Verify complete
2021-11-07 19:27:04, Info CSI 00000071 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:27:04, Info CSI 00000072 [SR] Beginning Verify and Repair transaction
2021-11-07 19:27:06, Info CSI 00000074 [SR] Verify complete
2021-11-07 19:27:07, Info CSI 00000075 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:27:07, Info CSI 00000076 [SR] Beginning Verify and Repair transaction
2021-11-07 19:27:09, Info CSI 00000078 [SR] Verify complete
2021-11-07 19:27:10, Info CSI 00000079 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:27:10, Info CSI 0000007a [SR] Beginning Verify and Repair transaction
2021-11-07 19:27:12, Info CSI 0000007c [SR] Verify complete
2021-11-07 19:27:13, Info CSI 0000007d [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:27:13, Info CSI 0000007e [SR] Beginning Verify and Repair transaction
2021-11-07 19:27:16, Info CSI 00000080 [SR] Verify complete
2021-11-07 19:27:17, Info CSI 00000081 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:27:17, Info CSI 00000082 [SR] Beginning Verify and Repair transaction
2021-11-07 19:27:18, Info CSI 00000084 [SR] Verify complete
2021-11-07 19:27:19, Info CSI 00000085 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:27:19, Info CSI 00000086 [SR] Beginning Verify and Repair transaction
2021-11-07 19:27:21, Info CSI 00000088 [SR] Verify complete
2021-11-07 19:27:22, Info CSI 00000089 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:27:22, Info CSI 0000008a [SR] Beginning Verify and Repair transaction
2021-11-07 19:27:23, Info CSI 0000008c [SR] Verify complete
2021-11-07 19:27:24, Info CSI 0000008d [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:27:24, Info CSI 0000008e [SR] Beginning Verify and Repair transaction
2021-11-07 19:27:26, Info CSI 00000090 [SR] Verify complete
2021-11-07 19:27:27, Info CSI 00000091 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:27:27, Info CSI 00000092 [SR] Beginning Verify and Repair transaction
2021-11-07 19:27:28, Info CSI 00000094 [SR] Verify complete
2021-11-07 19:27:30, Info CSI 00000095 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:27:30, Info CSI 00000096 [SR] Beginning Verify and Repair transaction
2021-11-07 19:27:31, Info CSI 00000098 [SR] Verify complete
2021-11-07 19:27:31, Info CSI 00000099 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:27:31, Info CSI 0000009a [SR] Beginning Verify and Repair transaction
2021-11-07 19:27:33, Info CSI 0000009c [SR] Verify complete
2021-11-07 19:27:35, Info CSI 0000009d [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:27:35, Info CSI 0000009e [SR] Beginning Verify and Repair transaction
2021-11-07 19:27:36, Info CSI 000000a0 [SR] Verify complete
2021-11-07 19:27:37, Info CSI 000000a1 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:27:37, Info CSI 000000a2 [SR] Beginning Verify and Repair transaction
2021-11-07 19:27:38, Info CSI 000000a4 [SR] Verify complete
2021-11-07 19:27:39, Info CSI 000000a5 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:27:39, Info CSI 000000a6 [SR] Beginning Verify and Repair transaction
2021-11-07 19:27:41, Info CSI 000000a8 [SR] Verify complete
2021-11-07 19:27:42, Info CSI 000000a9 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:27:42, Info CSI 000000aa [SR] Beginning Verify and Repair transaction
2021-11-07 19:27:45, Info CSI 000000ac [SR] Verify complete
2021-11-07 19:27:46, Info CSI 000000ad [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:27:46, Info CSI 000000ae [SR] Beginning Verify and Repair transaction
2021-11-07 19:27:48, Info CSI 000000b0 [SR] Verify complete
2021-11-07 19:27:49, Info CSI 000000b1 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:27:49, Info CSI 000000b2 [SR] Beginning Verify and Repair transaction
2021-11-07 19:27:50, Info CSI 000000b4 [SR] Verify complete
2021-11-07 19:27:51, Info CSI 000000b5 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:27:51, Info CSI 000000b6 [SR] Beginning Verify and Repair transaction
2021-11-07 19:27:53, Info CSI 000000b8 [SR] Verify complete
2021-11-07 19:27:54, Info CSI 000000b9 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:27:54, Info CSI 000000ba [SR] Beginning Verify and Repair transaction
2021-11-07 19:27:57, Info CSI 000000bc [SR] Verify complete
2021-11-07 19:27:58, Info CSI 000000bd [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:27:58, Info CSI 000000be [SR] Beginning Verify and Repair transaction
2021-11-07 19:28:01, Info CSI 000000c0 [SR] Verify complete
2021-11-07 19:28:01, Info CSI 000000c1 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:28:01, Info CSI 000000c2 [SR] Beginning Verify and Repair transaction
2021-11-07 19:28:03, Info CSI 000000c4 [SR] Verify complete
2021-11-07 19:28:04, Info CSI 000000c5 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:28:04, Info CSI 000000c6 [SR] Beginning Verify and Repair transaction
2021-11-07 19:28:05, Info CSI 000000c8 [SR] Verify complete
2021-11-07 19:28:07, Info CSI 000000c9 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:28:07, Info CSI 000000ca [SR] Beginning Verify and Repair transaction
2021-11-07 19:28:08, Info CSI 000000cc [SR] Verify complete
2021-11-07 19:28:09, Info CSI 000000cd [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:28:09, Info CSI 000000ce [SR] Beginning Verify and Repair transaction
2021-11-07 19:28:12, Info CSI 000000d0 [SR] Verify complete
2021-11-07 19:28:13, Info CSI 000000d1 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:28:13, Info CSI 000000d2 [SR] Beginning Verify and Repair transaction
2021-11-07 19:28:14, Info CSI 000000d4 [SR] Verify complete
2021-11-07 19:28:16, Info CSI 000000d5 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:28:16, Info CSI 000000d6 [SR] Beginning Verify and Repair transaction
2021-11-07 19:28:16, Info CSI 000000d8 [SR] Verify complete
2021-11-07 19:28:17, Info CSI 000000d9 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:28:17, Info CSI 000000da [SR] Beginning Verify and Repair transaction
2021-11-07 19:28:20, Info CSI 000000dc [SR] Verify complete
2021-11-07 19:28:20, Info CSI 000000dd [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:28:20, Info CSI 000000de [SR] Beginning Verify and Repair transaction
2021-11-07 19:28:24, Info CSI 000000e0 [SR] Verify complete
2021-11-07 19:28:25, Info CSI 000000e1 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:28:25, Info CSI 000000e2 [SR] Beginning Verify and Repair transaction
2021-11-07 19:28:26, Info CSI 000000e4 [SR] Verify complete
2021-11-07 19:28:27, Info CSI 000000e5 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:28:27, Info CSI 000000e6 [SR] Beginning Verify and Repair transaction
2021-11-07 19:28:29, Info CSI 000000e8 [SR] Verify complete
2021-11-07 19:28:29, Info CSI 000000e9 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:28:29, Info CSI 000000ea [SR] Beginning Verify and Repair transaction
2021-11-07 19:28:31, Info CSI 000000ec [SR] Verify complete
2021-11-07 19:28:32, Info CSI 000000ed [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:28:32, Info CSI 000000ee [SR] Beginning Verify and Repair transaction
2021-11-07 19:28:34, Info CSI 000000f0 [SR] Verify complete
2021-11-07 19:28:35, Info CSI 000000f1 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:28:35, Info CSI 000000f2 [SR] Beginning Verify and Repair transaction
2021-11-07 19:28:36, Info CSI 000000f4 [SR] Verify complete
2021-11-07 19:28:37, Info CSI 000000f5 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:28:37, Info CSI 000000f6 [SR] Beginning Verify and Repair transaction
2021-11-07 19:28:38, Info CSI 000000f8 [SR] Verify complete
2021-11-07 19:28:39, Info CSI 000000f9 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:28:39, Info CSI 000000fa [SR] Beginning Verify and Repair transaction
2021-11-07 19:28:41, Info CSI 000000fc [SR] Verify complete
2021-11-07 19:28:42, Info CSI 000000fd [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:28:42, Info CSI 000000fe [SR] Beginning Verify and Repair transaction
2021-11-07 19:28:45, Info CSI 00000100 [SR] Verify complete
2021-11-07 19:28:46, Info CSI 00000101 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:28:46, Info CSI 00000102 [SR] Beginning Verify and Repair transaction
2021-11-07 19:28:50, Info CSI 00000104 [SR] Verify complete
2021-11-07 19:28:51, Info CSI 00000105 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:28:51, Info CSI 00000106 [SR] Beginning Verify and Repair transaction
2021-11-07 19:28:55, Info CSI 00000108 [SR] Verify complete
2021-11-07 19:28:55, Info CSI 00000109 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:28:55, Info CSI 0000010a [SR] Beginning Verify and Repair transaction
2021-11-07 19:28:58, Info CSI 0000010c [SR] Verify complete
2021-11-07 19:28:58, Info CSI 0000010d [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:28:58, Info CSI 0000010e [SR] Beginning Verify and Repair transaction
2021-11-07 19:29:00, Info CSI 00000110 [SR] Verify complete
2021-11-07 19:29:01, Info CSI 00000111 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:29:01, Info CSI 00000112 [SR] Beginning Verify and Repair transaction
2021-11-07 19:29:04, Info CSI 00000114 [SR] Verify complete
2021-11-07 19:29:04, Info CSI 00000115 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:29:04, Info CSI 00000116 [SR] Beginning Verify and Repair transaction
2021-11-07 19:29:10, Info CSI 00000118 [SR] Verify complete
2021-11-07 19:29:10, Info CSI 00000119 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:29:10, Info CSI 0000011a [SR] Beginning Verify and Repair transaction
2021-11-07 19:29:18, Info CSI 0000011d [SR] Verify complete
2021-11-07 19:29:18, Info CSI 0000011e [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:29:18, Info CSI 0000011f [SR] Beginning Verify and Repair transaction
2021-11-07 19:29:24, Info CSI 00000122 [SR] Verify complete
2021-11-07 19:29:24, Info CSI 00000123 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:29:24, Info CSI 00000124 [SR] Beginning Verify and Repair transaction
2021-11-07 19:29:30, Info CSI 00000127 [SR] Verify complete
2021-11-07 19:29:31, Info CSI 00000128 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:29:31, Info CSI 00000129 [SR] Beginning Verify and Repair transaction
2021-11-07 19:29:35, Info CSI 0000012c [SR] Verify complete
2021-11-07 19:29:36, Info CSI 0000012d [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:29:36, Info CSI 0000012e [SR] Beginning Verify and Repair transaction
2021-11-07 19:29:41, Info CSI 00000133 [SR] Verify complete
2021-11-07 19:29:42, Info CSI 00000134 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:29:42, Info CSI 00000135 [SR] Beginning Verify and Repair transaction
2021-11-07 19:29:46, Info CSI 00000137 [SR] Verify complete
2021-11-07 19:29:47, Info CSI 00000138 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:29:47, Info CSI 00000139 [SR] Beginning Verify and Repair transaction
2021-11-07 19:29:54, Info CSI 0000013b [SR] Verify complete
2021-11-07 19:29:54, Info CSI 0000013c [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:29:54, Info CSI 0000013d [SR] Beginning Verify and Repair transaction
2021-11-07 19:30:00, Info CSI 0000015f [SR] Verify complete
2021-11-07 19:30:00, Info CSI 00000160 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:30:00, Info CSI 00000161 [SR] Beginning Verify and Repair transaction
2021-11-07 19:30:06, Info CSI 00000166 [SR] Verify complete
2021-11-07 19:30:06, Info CSI 00000167 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:30:06, Info CSI 00000168 [SR] Beginning Verify and Repair transaction
2021-11-07 19:30:10, Info CSI 0000016a [SR] Verify complete
2021-11-07 19:30:11, Info CSI 0000016b [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:30:11, Info CSI 0000016c [SR] Beginning Verify and Repair transaction
2021-11-07 19:30:16, Info CSI 0000016e [SR] Verify complete
2021-11-07 19:30:16, Info CSI 0000016f [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:30:16, Info CSI 00000170 [SR] Beginning Verify and Repair transaction
2021-11-07 19:30:20, Info CSI 00000172 [SR] Verify complete
2021-11-07 19:30:20, Info CSI 00000173 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:30:20, Info CSI 00000174 [SR] Beginning Verify and Repair transaction
2021-11-07 19:30:24, Info CSI 00000176 [SR] Verify complete
2021-11-07 19:30:25, Info CSI 00000177 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:30:25, Info CSI 00000178 [SR] Beginning Verify and Repair transaction
2021-11-07 19:30:30, Info CSI 0000017a [SR] Verify complete
2021-11-07 19:30:30, Info CSI 0000017b [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:30:30, Info CSI 0000017c [SR] Beginning Verify and Repair transaction
2021-11-07 19:30:34, Info CSI 0000017e [SR] Verify complete
2021-11-07 19:30:34, Info CSI 0000017f [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:30:34, Info CSI 00000180 [SR] Beginning Verify and Repair transaction
2021-11-07 19:30:38, Info CSI 00000182 [SR] Verify complete
2021-11-07 19:30:38, Info CSI 00000183 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:30:38, Info CSI 00000184 [SR] Beginning Verify and Repair transaction
2021-11-07 19:30:41, Info CSI 00000186 [SR] Verify complete
2021-11-07 19:30:41, Info CSI 00000187 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:30:41, Info CSI 00000188 [SR] Beginning Verify and Repair transaction
2021-11-07 19:30:47, Info CSI 0000018a [SR] Verify complete
2021-11-07 19:30:47, Info CSI 0000018b [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:30:47, Info CSI 0000018c [SR] Beginning Verify and Repair transaction
2021-11-07 19:30:54, Info CSI 000001aa [SR] Verify complete
2021-11-07 19:30:55, Info CSI 000001ab [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:30:55, Info CSI 000001ac [SR] Beginning Verify and Repair transaction
2021-11-07 19:31:00, Info CSI 000001cd [SR] Verify complete
2021-11-07 19:31:00, Info CSI 000001ce [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:31:00, Info CSI 000001cf [SR] Beginning Verify and Repair transaction
2021-11-07 19:31:10, Info CSI 000001d1 [SR] Verify complete
2021-11-07 19:31:11, Info CSI 000001d2 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:31:11, Info CSI 000001d3 [SR] Beginning Verify and Repair transaction
2021-11-07 19:31:18, Info CSI 000001d5 [SR] Verify complete
2021-11-07 19:31:18, Info CSI 000001d6 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:31:18, Info CSI 000001d7 [SR] Beginning Verify and Repair transaction
2021-11-07 19:31:27, Info CSI 000001d9 [SR] Verify complete
2021-11-07 19:31:27, Info CSI 000001da [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:31:27, Info CSI 000001db [SR] Beginning Verify and Repair transaction
2021-11-07 19:31:31, Info CSI 000001df [SR] Verify complete
2021-11-07 19:31:31, Info CSI 000001e0 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:31:31, Info CSI 000001e1 [SR] Beginning Verify and Repair transaction
2021-11-07 19:31:34, Info CSI 000001e3 [SR] Verify complete
2021-11-07 19:31:34, Info CSI 000001e4 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:31:34, Info CSI 000001e5 [SR] Beginning Verify and Repair transaction
2021-11-07 19:31:38, Info CSI 000001e7 [SR] Verify complete
2021-11-07 19:31:38, Info CSI 000001e8 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:31:38, Info CSI 000001e9 [SR] Beginning Verify and Repair transaction
2021-11-07 19:31:40, Info CSI 000001eb [SR] Verify complete
2021-11-07 19:31:40, Info CSI 000001ec [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:31:40, Info CSI 000001ed [SR] Beginning Verify and Repair transaction
2021-11-07 19:31:41, Info CSI 000001ef [SR] Verify complete
2021-11-07 19:31:42, Info CSI 000001f0 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:31:42, Info CSI 000001f1 [SR] Beginning Verify and Repair transaction
2021-11-07 19:31:44, Info CSI 000001f3 [SR] Verify complete
2021-11-07 19:31:45, Info CSI 000001f4 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:31:45, Info CSI 000001f5 [SR] Beginning Verify and Repair transaction
2021-11-07 19:31:48, Info CSI 000001f7 [SR] Verify complete
2021-11-07 19:31:49, Info CSI 000001f8 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:31:49, Info CSI 000001f9 [SR] Beginning Verify and Repair transaction
2021-11-07 19:31:56, Info CSI 0000020c [SR] Verify complete
2021-11-07 19:31:57, Info CSI 0000020d [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:31:57, Info CSI 0000020e [SR] Beginning Verify and Repair transaction
2021-11-07 19:31:58, Info CSI 00000210 [SR] Verify complete
2021-11-07 19:31:59, Info CSI 00000211 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:31:59, Info CSI 00000212 [SR] Beginning Verify and Repair transaction
2021-11-07 19:32:03, Info CSI 00000214 [SR] Verify complete
2021-11-07 19:32:03, Info CSI 00000215 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:32:03, Info CSI 00000216 [SR] Beginning Verify and Repair transaction
2021-11-07 19:32:06, Info CSI 00000218 [SR] Verify complete
2021-11-07 19:32:07, Info CSI 00000219 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:32:07, Info CSI 0000021a [SR] Beginning Verify and Repair transaction
2021-11-07 19:32:12, Info CSI 0000021c [SR] Verify complete
2021-11-07 19:32:12, Info CSI 0000021d [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:32:12, Info CSI 0000021e [SR] Beginning Verify and Repair transaction
2021-11-07 19:32:17, Info CSI 00000221 [SR] Verify complete
2021-11-07 19:32:18, Info CSI 00000222 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:32:18, Info CSI 00000223 [SR] Beginning Verify and Repair transaction
2021-11-07 19:32:32, Info CSI 00000226 [SR] Verify complete
2021-11-07 19:32:32, Info CSI 00000227 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:32:32, Info CSI 00000228 [SR] Beginning Verify and Repair transaction
2021-11-07 19:32:37, Info CSI 0000022a [SR] Verify complete
2021-11-07 19:32:38, Info CSI 0000022b [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:32:38, Info CSI 0000022c [SR] Beginning Verify and Repair transaction
2021-11-07 19:32:42, Info CSI 0000022e [SR] Verify complete
2021-11-07 19:32:42, Info CSI 0000022f [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:32:42, Info CSI 00000230 [SR] Beginning Verify and Repair transaction
2021-11-07 19:32:45, Info CSI 00000232 [SR] Verify complete
2021-11-07 19:32:45, Info CSI 00000233 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:32:45, Info CSI 00000234 [SR] Beginning Verify and Repair transaction
2021-11-07 19:32:48, Info CSI 00000236 [SR] Verify complete
2021-11-07 19:32:48, Info CSI 00000237 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:32:48, Info CSI 00000238 [SR] Beginning Verify and Repair transaction
2021-11-07 19:32:53, Info CSI 0000023a [SR] Verify complete
2021-11-07 19:32:53, Info CSI 0000023b [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:32:53, Info CSI 0000023c [SR] Beginning Verify and Repair transaction
2021-11-07 19:33:00, Info CSI 0000023e [SR] Verify complete
2021-11-07 19:33:00, Info CSI 0000023f [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:33:00, Info CSI 00000240 [SR] Beginning Verify and Repair transaction
2021-11-07 19:33:04, Info CSI 00000242 [SR] Verify complete
2021-11-07 19:33:05, Info CSI 00000243 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:33:05, Info CSI 00000244 [SR] Beginning Verify and Repair transaction
2021-11-07 19:33:09, Info CSI 00000246 [SR] Verify complete
2021-11-07 19:33:09, Info CSI 00000247 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:33:09, Info CSI 00000248 [SR] Beginning Verify and Repair transaction
2021-11-07 19:33:14, Info CSI 0000024a [SR] Verify complete
2021-11-07 19:33:15, Info CSI 0000024b [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:33:15, Info CSI 0000024c [SR] Beginning Verify and Repair transaction
2021-11-07 19:33:24, Info CSI 00000260 [SR] Verify complete
2021-11-07 19:33:25, Info CSI 00000261 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:33:25, Info CSI 00000262 [SR] Beginning Verify and Repair transaction
2021-11-07 19:33:29, Info CSI 00000268 [SR] Verify complete
2021-11-07 19:33:30, Info CSI 00000269 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:33:30, Info CSI 0000026a [SR] Beginning Verify and Repair transaction
2021-11-07 19:33:36, Info CSI 0000026c [SR] Verify complete
2021-11-07 19:33:36, Info CSI 0000026d [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:33:36, Info CSI 0000026e [SR] Beginning Verify and Repair transaction
2021-11-07 19:33:40, Info CSI 00000270 [SR] Verify complete
2021-11-07 19:33:41, Info CSI 00000271 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:33:41, Info CSI 00000272 [SR] Beginning Verify and Repair transaction
2021-11-07 19:33:57, Info CSI 00000274 [SR] Verify complete
2021-11-07 19:33:58, Info CSI 00000275 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:33:58, Info CSI 00000276 [SR] Beginning Verify and Repair transaction
2021-11-07 19:34:03, Info CSI 00000278 [SR] Verify complete
2021-11-07 19:34:04, Info CSI 00000279 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:34:04, Info CSI 0000027a [SR] Beginning Verify and Repair transaction
2021-11-07 19:34:11, Info CSI 0000027d [SR] Verify complete
2021-11-07 19:34:12, Info CSI 0000027e [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:34:12, Info CSI 0000027f [SR] Beginning Verify and Repair transaction
2021-11-07 19:34:18, Info CSI 00000281 [SR] Verify complete
2021-11-07 19:34:19, Info CSI 00000282 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:34:19, Info CSI 00000283 [SR] Beginning Verify and Repair transaction
2021-11-07 19:34:26, Info CSI 00000285 [SR] Verify complete
2021-11-07 19:34:26, Info CSI 00000286 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:34:26, Info CSI 00000287 [SR] Beginning Verify and Repair transaction
2021-11-07 19:34:32, Info CSI 0000028b [SR] Verify complete
2021-11-07 19:34:33, Info CSI 0000028c [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:34:33, Info CSI 0000028d [SR] Beginning Verify and Repair transaction
2021-11-07 19:34:37, Info CSI 0000028f [SR] Verify complete
2021-11-07 19:34:37, Info CSI 00000290 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:34:37, Info CSI 00000291 [SR] Beginning Verify and Repair transaction
2021-11-07 19:34:42, Info CSI 00000293 [SR] Verify complete
2021-11-07 19:34:42, Info CSI 00000294 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:34:42, Info CSI 00000295 [SR] Beginning Verify and Repair transaction
2021-11-07 19:34:47, Info CSI 00000297 [SR] Verify complete
2021-11-07 19:34:48, Info CSI 00000298 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:34:48, Info CSI 00000299 [SR] Beginning Verify and Repair transaction
2021-11-07 19:34:50, Info CSI 0000029b [SR] Verify complete
2021-11-07 19:34:51, Info CSI 0000029c [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:34:51, Info CSI 0000029d [SR] Beginning Verify and Repair transaction
2021-11-07 19:34:55, Info CSI 000002a1 [SR] Verify complete
2021-11-07 19:34:56, Info CSI 000002a2 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:34:56, Info CSI 000002a3 [SR] Beginning Verify and Repair transaction
2021-11-07 19:35:00, Info CSI 000002a5 [SR] Verify complete
2021-11-07 19:35:01, Info CSI 000002a6 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:35:01, Info CSI 000002a7 [SR] Beginning Verify and Repair transaction
2021-11-07 19:35:05, Info CSI 000002a9 [SR] Verify complete
2021-11-07 19:35:06, Info CSI 000002aa [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:35:06, Info CSI 000002ab [SR] Beginning Verify and Repair transaction
2021-11-07 19:35:20, Info CSI 000002ad [SR] Verify complete
2021-11-07 19:35:20, Info CSI 000002ae [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:35:20, Info CSI 000002af [SR] Beginning Verify and Repair transaction
2021-11-07 19:35:25, Info CSI 000002b1 [SR] Verify complete
2021-11-07 19:35:26, Info CSI 000002b2 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:35:26, Info CSI 000002b3 [SR] Beginning Verify and Repair transaction
2021-11-07 19:35:32, Info CSI 000002b6 [SR] Verify complete
2021-11-07 19:35:33, Info CSI 000002b7 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:35:33, Info CSI 000002b8 [SR] Beginning Verify and Repair transaction
2021-11-07 19:35:38, Info CSI 000002ba [SR] Verify complete
2021-11-07 19:35:38, Info CSI 000002bb [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:35:38, Info CSI 000002bc [SR] Beginning Verify and Repair transaction
2021-11-07 19:35:42, Info CSI 000002be [SR] Verify complete
2021-11-07 19:35:43, Info CSI 000002bf [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:35:43, Info CSI 000002c0 [SR] Beginning Verify and Repair transaction
2021-11-07 19:35:47, Info CSI 000002c3 [SR] Verify complete
2021-11-07 19:35:48, Info CSI 000002c4 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:35:48, Info CSI 000002c5 [SR] Beginning Verify and Repair transaction
2021-11-07 19:35:54, Info CSI 000002c7 [SR] Verify complete
2021-11-07 19:35:54, Info CSI 000002c8 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:35:54, Info CSI 000002c9 [SR] Beginning Verify and Repair transaction
2021-11-07 19:36:02, Info CSI 000002cb [SR] Verify complete
2021-11-07 19:36:02, Info CSI 000002cc [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:36:02, Info CSI 000002cd [SR] Beginning Verify and Repair transaction
2021-11-07 19:36:10, Info CSI 000002d0 [SR] Verify complete
2021-11-07 19:36:10, Info CSI 000002d1 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:36:10, Info CSI 000002d2 [SR] Beginning Verify and Repair transaction
2021-11-07 19:36:15, Info CSI 000002d4 [SR] Verify complete
2021-11-07 19:36:16, Info CSI 000002d5 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:36:16, Info CSI 000002d6 [SR] Beginning Verify and Repair transaction
2021-11-07 19:36:20, Info CSI 000002d8 [SR] Verify complete
2021-11-07 19:36:21, Info CSI 000002d9 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:36:21, Info CSI 000002da [SR] Beginning Verify and Repair transaction
2021-11-07 19:36:26, Info CSI 000002dc [SR] Verify complete
2021-11-07 19:36:27, Info CSI 000002dd [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:36:27, Info CSI 000002de [SR] Beginning Verify and Repair transaction
2021-11-07 19:36:32, Info CSI 000002e0 [SR] Verify complete
2021-11-07 19:36:33, Info CSI 000002e1 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:36:33, Info CSI 000002e2 [SR] Beginning Verify and Repair transaction
2021-11-07 19:36:36, Info CSI 000002e5 [SR] Verify complete
2021-11-07 19:36:37, Info CSI 000002e6 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:36:37, Info CSI 000002e7 [SR] Beginning Verify and Repair transaction
2021-11-07 19:36:42, Info CSI 000002e9 [SR] Verify complete
2021-11-07 19:36:43, Info CSI 000002ea [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:36:43, Info CSI 000002eb [SR] Beginning Verify and Repair transaction
2021-11-07 19:36:47, Info CSI 000002ed [SR] Verify complete
2021-11-07 19:36:48, Info CSI 000002ee [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:36:48, Info CSI 000002ef [SR] Beginning Verify and Repair transaction
2021-11-07 19:36:50, Info CSI 000002f2 [SR] Verify complete
2021-11-07 19:36:51, Info CSI 000002f3 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:36:51, Info CSI 000002f4 [SR] Beginning Verify and Repair transaction
2021-11-07 19:36:55, Info CSI 000002f8 [SR] Verify complete
2021-11-07 19:36:56, Info CSI 000002f9 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:36:56, Info CSI 000002fa [SR] Beginning Verify and Repair transaction
2021-11-07 19:37:02, Info CSI 000002fd [SR] Verify complete
2021-11-07 19:37:02, Info CSI 000002fe [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:37:02, Info CSI 000002ff [SR] Beginning Verify and Repair transaction
2021-11-07 19:37:06, Info CSI 00000303 [SR] Verify complete
2021-11-07 19:37:06, Info CSI 00000304 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:37:06, Info CSI 00000305 [SR] Beginning Verify and Repair transaction
2021-11-07 19:37:13, Info CSI 00000309 [SR] Verify complete
2021-11-07 19:37:14, Info CSI 0000030a [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:37:14, Info CSI 0000030b [SR] Beginning Verify and Repair transaction
2021-11-07 19:37:18, Info CSI 0000030e [SR] Verify complete
2021-11-07 19:37:18, Info CSI 0000030f [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:37:18, Info CSI 00000310 [SR] Beginning Verify and Repair transaction
2021-11-07 19:37:24, Info CSI 00000313 [SR] Verify complete
2021-11-07 19:37:25, Info CSI 00000314 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:37:25, Info CSI 00000315 [SR] Beginning Verify and Repair transaction
2021-11-07 19:37:27, Info CSI 00000317 [SR] Verify complete
2021-11-07 19:37:28, Info CSI 00000318 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:37:28, Info CSI 00000319 [SR] Beginning Verify and Repair transaction
2021-11-07 19:37:34, Info CSI 0000031b [SR] Verify complete
2021-11-07 19:37:35, Info CSI 0000031c [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:37:35, Info CSI 0000031d [SR] Beginning Verify and Repair transaction
2021-11-07 19:37:43, Info CSI 00000320 [SR] Verify complete
2021-11-07 19:37:43, Info CSI 00000321 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:37:43, Info CSI 00000322 [SR] Beginning Verify and Repair transaction
2021-11-07 19:37:47, Info CSI 00000324 [SR] Verify complete
2021-11-07 19:37:48, Info CSI 00000325 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:37:48, Info CSI 00000326 [SR] Beginning Verify and Repair transaction
2021-11-07 19:37:52, Info CSI 00000328 [SR] Verify complete
2021-11-07 19:37:52, Info CSI 00000329 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:37:52, Info CSI 0000032a [SR] Beginning Verify and Repair transaction
2021-11-07 19:37:55, Info CSI 0000032c [SR] Verify complete
2021-11-07 19:37:56, Info CSI 0000032d [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:37:56, Info CSI 0000032e [SR] Beginning Verify and Repair transaction
2021-11-07 19:38:02, Info CSI 00000330 [SR] Verify complete
2021-11-07 19:38:03, Info CSI 00000331 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:38:03, Info CSI 00000332 [SR] Beginning Verify and Repair transaction
2021-11-07 19:38:05, Info CSI 00000334 [SR] Verify complete
2021-11-07 19:38:06, Info CSI 00000335 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:38:06, Info CSI 00000336 [SR] Beginning Verify and Repair transaction
2021-11-07 19:38:12, Info CSI 00000338 [SR] Verify complete
2021-11-07 19:38:14, Info CSI 00000339 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:38:14, Info CSI 0000033a [SR] Beginning Verify and Repair transaction
2021-11-07 19:38:21, Info CSI 0000033c [SR] Verify complete
2021-11-07 19:38:21, Info CSI 0000033d [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:38:21, Info CSI 0000033e [SR] Beginning Verify and Repair transaction
2021-11-07 19:38:25, Info CSI 00000340 [SR] Verify complete
2021-11-07 19:38:25, Info CSI 00000341 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:38:25, Info CSI 00000342 [SR] Beginning Verify and Repair transaction
2021-11-07 19:38:28, Info CSI 00000344 [SR] Verify complete
2021-11-07 19:38:28, Info CSI 00000345 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:38:28, Info CSI 00000346 [SR] Beginning Verify and Repair transaction
2021-11-07 19:38:30, Info CSI 00000348 [SR] Verify complete
2021-11-07 19:38:31, Info CSI 00000349 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:38:31, Info CSI 0000034a [SR] Beginning Verify and Repair transaction
2021-11-07 19:38:40, Info CSI 0000034c [SR] Verify complete
2021-11-07 19:38:40, Info CSI 0000034d [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:38:40, Info CSI 0000034e [SR] Beginning Verify and Repair transaction
2021-11-07 19:38:52, Info CSI 00000350 [SR] Verify complete
2021-11-07 19:38:53, Info CSI 00000351 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:38:53, Info CSI 00000352 [SR] Beginning Verify and Repair transaction
2021-11-07 19:39:01, Info CSI 00000354 [SR] Verify complete
2021-11-07 19:39:02, Info CSI 00000355 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:39:02, Info CSI 00000356 [SR] Beginning Verify and Repair transaction
2021-11-07 19:39:12, Info CSI 00000358 [SR] Verify complete
2021-11-07 19:39:13, Info CSI 00000359 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:39:13, Info CSI 0000035a [SR] Beginning Verify and Repair transaction
2021-11-07 19:39:15, Info CSI 0000035c [SR] Verify complete
2021-11-07 19:39:15, Info CSI 0000035d [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:39:15, Info CSI 0000035e [SR] Beginning Verify and Repair transaction
2021-11-07 19:39:17, Info CSI 00000360 [SR] Verify complete
2021-11-07 19:39:17, Info CSI 00000361 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:39:17, Info CSI 00000362 [SR] Beginning Verify and Repair transaction
2021-11-07 19:39:19, Info CSI 00000364 [SR] Verify complete
2021-11-07 19:39:19, Info CSI 00000365 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:39:19, Info CSI 00000366 [SR] Beginning Verify and Repair transaction
2021-11-07 19:39:22, Info CSI 00000368 [SR] Verify complete
2021-11-07 19:39:22, Info CSI 00000369 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:39:22, Info CSI 0000036a [SR] Beginning Verify and Repair transaction
2021-11-07 19:39:24, Info CSI 0000036c [SR] Verify complete
2021-11-07 19:39:24, Info CSI 0000036d [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:39:24, Info CSI 0000036e [SR] Beginning Verify and Repair transaction
2021-11-07 19:39:25, Info CSI 00000370 [SR] Verify complete
2021-11-07 19:39:26, Info CSI 00000371 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:39:26, Info CSI 00000372 [SR] Beginning Verify and Repair transaction
2021-11-07 19:39:27, Info CSI 00000374 [SR] Verify complete
2021-11-07 19:39:27, Info CSI 00000375 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:39:27, Info CSI 00000376 [SR] Beginning Verify and Repair transaction
2021-11-07 19:39:29, Info CSI 00000378 [SR] Verify complete
2021-11-07 19:39:29, Info CSI 00000379 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:39:29, Info CSI 0000037a [SR] Beginning Verify and Repair transaction
2021-11-07 19:39:32, Info CSI 0000037c [SR] Verify complete
2021-11-07 19:39:32, Info CSI 0000037d [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:39:32, Info CSI 0000037e [SR] Beginning Verify and Repair transaction
2021-11-07 19:39:34, Info CSI 00000380 [SR] Verify complete
2021-11-07 19:39:35, Info CSI 00000381 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:39:35, Info CSI 00000382 [SR] Beginning Verify and Repair transaction
2021-11-07 19:39:36, Info CSI 00000384 [SR] Verify complete
2021-11-07 19:39:36, Info CSI 00000385 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:39:36, Info CSI 00000386 [SR] Beginning Verify and Repair transaction
2021-11-07 19:39:39, Info CSI 00000388 [SR] Verify complete
2021-11-07 19:39:39, Info CSI 00000389 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:39:39, Info CSI 0000038a [SR] Beginning Verify and Repair transaction
2021-11-07 19:39:40, Info CSI 0000038c [SR] Verify complete
2021-11-07 19:39:40, Info CSI 0000038d [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:39:40, Info CSI 0000038e [SR] Beginning Verify and Repair transaction
2021-11-07 19:39:41, Info CSI 00000390 [SR] Verify complete
2021-11-07 19:39:41, Info CSI 00000391 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:39:41, Info CSI 00000392 [SR] Beginning Verify and Repair transaction
2021-11-07 19:39:44, Info CSI 000003a0 [SR] Verify complete
2021-11-07 19:39:45, Info CSI 000003a1 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:39:45, Info CSI 000003a2 [SR] Beginning Verify and Repair transaction
2021-11-07 19:39:48, Info CSI 000003a4 [SR] Verify complete
2021-11-07 19:39:48, Info CSI 000003a5 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:39:48, Info CSI 000003a6 [SR] Beginning Verify and Repair transaction
2021-11-07 19:39:50, Info CSI 000003a8 [SR] Verify complete
2021-11-07 19:39:51, Info CSI 000003a9 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:39:51, Info CSI 000003aa [SR] Beginning Verify and Repair transaction
2021-11-07 19:39:53, Info CSI 000003ac [SR] Verify complete
2021-11-07 19:39:54, Info CSI 000003ad [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:39:54, Info CSI 000003ae [SR] Beginning Verify and Repair transaction
2021-11-07 19:39:56, Info CSI 000003b0 [SR] Verify complete
2021-11-07 19:39:57, Info CSI 000003b1 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:39:57, Info CSI 000003b2 [SR] Beginning Verify and Repair transaction
2021-11-07 19:40:00, Info CSI 000003b4 [SR] Verify complete
2021-11-07 19:40:00, Info CSI 000003b5 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:40:00, Info CSI 000003b6 [SR] Beginning Verify and Repair transaction
2021-11-07 19:40:03, Info CSI 000003b8 [SR] Verify complete
2021-11-07 19:40:03, Info CSI 000003b9 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:40:03, Info CSI 000003ba [SR] Beginning Verify and Repair transaction
2021-11-07 19:40:06, Info CSI 000003bc [SR] Verify complete
2021-11-07 19:40:06, Info CSI 000003bd [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:40:06, Info CSI 000003be [SR] Beginning Verify and Repair transaction
2021-11-07 19:40:10, Info CSI 000003c0 [SR] Verify complete
2021-11-07 19:40:10, Info CSI 000003c1 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:40:10, Info CSI 000003c2 [SR] Beginning Verify and Repair transaction
2021-11-07 19:40:14, Info CSI 000003c4 [SR] Verify complete
2021-11-07 19:40:14, Info CSI 000003c5 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:40:14, Info CSI 000003c6 [SR] Beginning Verify and Repair transaction
2021-11-07 19:40:16, Info CSI 000003c8 [SR] Verify complete
2021-11-07 19:40:16, Info CSI 000003c9 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:40:16, Info CSI 000003ca [SR] Beginning Verify and Repair transaction
2021-11-07 19:40:18, Info CSI 000003cc [SR] Verify complete
2021-11-07 19:40:19, Info CSI 000003cd [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:40:19, Info CSI 000003ce [SR] Beginning Verify and Repair transaction
2021-11-07 19:40:26, Info CSI 000003d3 [SR] Verify complete
2021-11-07 19:40:27, Info CSI 000003d4 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:40:27, Info CSI 000003d5 [SR] Beginning Verify and Repair transaction
2021-11-07 19:40:34, Info CSI 000003d7 [SR] Verify complete
2021-11-07 19:40:34, Info CSI 000003d8 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:40:34, Info CSI 000003d9 [SR] Beginning Verify and Repair transaction
2021-11-07 19:40:37, Info CSI 000003de [SR] Verify complete
2021-11-07 19:40:38, Info CSI 000003df [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:40:38, Info CSI 000003e0 [SR] Beginning Verify and Repair transaction
2021-11-07 19:40:41, Info CSI 000003e2 [SR] Verify complete
2021-11-07 19:40:42, Info CSI 000003e3 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:40:42, Info CSI 000003e4 [SR] Beginning Verify and Repair transaction
2021-11-07 19:40:45, Info CSI 000003f1 [SR] Verify complete
2021-11-07 19:40:45, Info CSI 000003f2 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:40:45, Info CSI 000003f3 [SR] Beginning Verify and Repair transaction
2021-11-07 19:40:50, Info CSI 000003f7 [SR] Verify complete
2021-11-07 19:40:50, Info CSI 000003f8 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:40:50, Info CSI 000003f9 [SR] Beginning Verify and Repair transaction
2021-11-07 19:40:53, Info CSI 000003fe [SR] Verify complete
2021-11-07 19:40:54, Info CSI 000003ff [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:40:54, Info CSI 00000400 [SR] Beginning Verify and Repair transaction
2021-11-07 19:40:56, Info CSI 00000402 [SR] Verify complete
2021-11-07 19:40:56, Info CSI 00000403 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:40:56, Info CSI 00000404 [SR] Beginning Verify and Repair transaction
2021-11-07 19:40:58, Info CSI 00000406 [SR] Verify complete
2021-11-07 19:40:59, Info CSI 00000407 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:40:59, Info CSI 00000408 [SR] Beginning Verify and Repair transaction
2021-11-07 19:41:01, Info CSI 0000040c [SR] Verify complete
2021-11-07 19:41:01, Info CSI 0000040d [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:41:01, Info CSI 0000040e [SR] Beginning Verify and Repair transaction
2021-11-07 19:41:03, Info CSI 00000410 [SR] Verify complete
2021-11-07 19:41:03, Info CSI 00000411 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:41:03, Info CSI 00000412 [SR] Beginning Verify and Repair transaction
2021-11-07 19:41:06, Info CSI 00000422 [SR] Verify complete
2021-11-07 19:41:06, Info CSI 00000423 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:41:06, Info CSI 00000424 [SR] Beginning Verify and Repair transaction
2021-11-07 19:41:09, Info CSI 0000043b [SR] Verify complete
2021-11-07 19:41:10, Info CSI 0000043c [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:41:10, Info CSI 0000043d [SR] Beginning Verify and Repair transaction
2021-11-07 19:41:12, Info CSI 0000043f [SR] Verify complete
2021-11-07 19:41:12, Info CSI 00000440 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:41:12, Info CSI 00000441 [SR] Beginning Verify and Repair transaction
2021-11-07 19:41:14, Info CSI 00000443 [SR] Verify complete
2021-11-07 19:41:14, Info CSI 00000444 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:41:14, Info CSI 00000445 [SR] Beginning Verify and Repair transaction
2021-11-07 19:41:16, Info CSI 00000447 [SR] Verify complete
2021-11-07 19:41:16, Info CSI 00000448 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:41:16, Info CSI 00000449 [SR] Beginning Verify and Repair transaction
2021-11-07 19:41:19, Info CSI 0000044b [SR] Verify complete
2021-11-07 19:41:19, Info CSI 0000044c [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:41:19, Info CSI 0000044d [SR] Beginning Verify and Repair transaction
2021-11-07 19:41:21, Info CSI 0000044f [SR] Verify complete
2021-11-07 19:41:21, Info CSI 00000450 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:41:21, Info CSI 00000451 [SR] Beginning Verify and Repair transaction
2021-11-07 19:41:23, Info CSI 00000463 [SR] Verify complete
2021-11-07 19:41:24, Info CSI 00000464 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:41:24, Info CSI 00000465 [SR] Beginning Verify and Repair transaction
2021-11-07 19:41:25, Info CSI 00000467 [SR] Verify complete
2021-11-07 19:41:26, Info CSI 00000468 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:41:26, Info CSI 00000469 [SR] Beginning Verify and Repair transaction
2021-11-07 19:41:30, Info CSI 0000046b [SR] Verify complete
2021-11-07 19:41:30, Info CSI 0000046c [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:41:30, Info CSI 0000046d [SR] Beginning Verify and Repair transaction
2021-11-07 19:41:32, Info CSI 0000046f [SR] Verify complete
2021-11-07 19:41:32, Info CSI 00000470 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:41:32, Info CSI 00000471 [SR] Beginning Verify and Repair transaction
2021-11-07 19:41:36, Info CSI 0000047f [SR] Verify complete
2021-11-07 19:41:36, Info CSI 00000480 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:41:36, Info CSI 00000481 [SR] Beginning Verify and Repair transaction
2021-11-07 19:41:38, Info CSI 00000483 [SR] Verify complete
2021-11-07 19:41:39, Info CSI 00000484 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:41:39, Info CSI 00000485 [SR] Beginning Verify and Repair transaction
2021-11-07 19:41:41, Info CSI 00000487 [SR] Verify complete
2021-11-07 19:41:42, Info CSI 00000488 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:41:42, Info CSI 00000489 [SR] Beginning Verify and Repair transaction
2021-11-07 19:41:46, Info CSI 0000048c [SR] Verify complete
2021-11-07 19:41:46, Info CSI 0000048d [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:41:46, Info CSI 0000048e [SR] Beginning Verify and Repair transaction
2021-11-07 19:41:49, Info CSI 00000490 [SR] Verify complete
2021-11-07 19:41:49, Info CSI 00000491 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:41:49, Info CSI 00000492 [SR] Beginning Verify and Repair transaction
2021-11-07 19:41:50, Info CSI 00000494 [SR] Verify complete
2021-11-07 19:41:50, Info CSI 00000495 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:41:50, Info CSI 00000496 [SR] Beginning Verify and Repair transaction
2021-11-07 19:41:52, Info CSI 00000498 [SR] Verify complete
2021-11-07 19:41:52, Info CSI 00000499 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:41:52, Info CSI 0000049a [SR] Beginning Verify and Repair transaction
2021-11-07 19:41:55, Info CSI 0000049c [SR] Verify complete
2021-11-07 19:41:56, Info CSI 0000049d [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:41:56, Info CSI 0000049e [SR] Beginning Verify and Repair transaction
2021-11-07 19:41:58, Info CSI 000004a0 [SR] Verify complete
2021-11-07 19:41:59, Info CSI 000004a1 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:41:59, Info CSI 000004a2 [SR] Beginning Verify and Repair transaction
2021-11-07 19:42:01, Info CSI 000004a4 [SR] Verify complete
2021-11-07 19:42:01, Info CSI 000004a5 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:42:01, Info CSI 000004a6 [SR] Beginning Verify and Repair transaction
2021-11-07 19:42:04, Info CSI 000004a8 [SR] Verify complete
2021-11-07 19:42:04, Info CSI 000004a9 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:42:04, Info CSI 000004aa [SR] Beginning Verify and Repair transaction
2021-11-07 19:42:08, Info CSI 000004c4 [SR] Verify complete
2021-11-07 19:42:08, Info CSI 000004c5 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:42:08, Info CSI 000004c6 [SR] Beginning Verify and Repair transaction
2021-11-07 19:42:11, Info CSI 000004c8 [SR] Cannot repair member file [l:28{14}]"iassdo.dll.mui" of Microsoft-Windows-Networking-Internet_Authentication_Service_Iassdo.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"en-US", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2021-11-07 19:42:11, Info CSI 000004ca [SR] Cannot repair member file [l:28{14}]"iassdo.dll.mui" of Microsoft-Windows-Networking-Internet_Authentication_Service_Iassdo.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"en-US", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2021-11-07 19:42:11, Info CSI 000004cb [SR] This component was referenced by [l:266{133}]"Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~en-US~6.1.7601.17514.Windows Foundation Language Pack"
2021-11-07 19:42:11, Info CSI 000004ce [SR] Could not reproject corrupted file [ml:60{30},l:58{29}]"\??\C:\Windows\SysWOW64\en-US"\[l:28{14}]"iassdo.dll.mui"; source file in store is also corrupted
2021-11-07 19:42:11, Info CSI 000004d0 [SR] Verify complete
2021-11-07 19:42:11, Info CSI 000004d1 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:42:11, Info CSI 000004d2 [SR] Beginning Verify and Repair transaction
2021-11-07 19:42:13, Info CSI 000004d4 [SR] Verify complete
2021-11-07 19:42:13, Info CSI 000004d5 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:42:13, Info CSI 000004d6 [SR] Beginning Verify and Repair transaction
2021-11-07 19:42:20, Info CSI 000004d8 [SR] Verify complete
2021-11-07 19:42:20, Info CSI 000004d9 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:42:20, Info CSI 000004da [SR] Beginning Verify and Repair transaction
2021-11-07 19:42:22, Info CSI 000004dc [SR] Verify complete
2021-11-07 19:42:22, Info CSI 000004dd [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:42:22, Info CSI 000004de [SR] Beginning Verify and Repair transaction
2021-11-07 19:42:24, Info CSI 000004e0 [SR] Verify complete
2021-11-07 19:42:25, Info CSI 000004e1 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:42:25, Info CSI 000004e2 [SR] Beginning Verify and Repair transaction
2021-11-07 19:42:26, Info CSI 000004e4 [SR] Verify complete
2021-11-07 19:42:26, Info CSI 000004e5 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:42:26, Info CSI 000004e6 [SR] Beginning Verify and Repair transaction
2021-11-07 19:42:28, Info CSI 000004ea [SR] Verify complete
2021-11-07 19:42:28, Info CSI 000004eb [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:42:28, Info CSI 000004ec [SR] Beginning Verify and Repair transaction
2021-11-07 19:42:30, Info CSI 000004ee [SR] Verify complete
2021-11-07 19:42:30, Info CSI 000004ef [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:42:30, Info CSI 000004f0 [SR] Beginning Verify and Repair transaction
2021-11-07 19:42:32, Info CSI 000004f2 [SR] Verify complete
2021-11-07 19:42:32, Info CSI 000004f3 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:42:32, Info CSI 000004f4 [SR] Beginning Verify and Repair transaction
2021-11-07 19:42:33, Info CSI 000004f6 [SR] Verify complete
2021-11-07 19:42:34, Info CSI 000004f7 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:42:34, Info CSI 000004f8 [SR] Beginning Verify and Repair transaction
2021-11-07 19:42:36, Info CSI 000004fa [SR] Verify complete
2021-11-07 19:42:36, Info CSI 000004fb [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:42:36, Info CSI 000004fc [SR] Beginning Verify and Repair transaction
2021-11-07 19:42:38, Info CSI 000004fe [SR] Verify complete
2021-11-07 19:42:39, Info CSI 000004ff [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:42:39, Info CSI 00000500 [SR] Beginning Verify and Repair transaction
2021-11-07 19:42:40, Info CSI 00000502 [SR] Verify complete
2021-11-07 19:42:40, Info CSI 00000503 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:42:40, Info CSI 00000504 [SR] Beginning Verify and Repair transaction
2021-11-07 19:42:43, Info CSI 00000507 [SR] Verify complete
2021-11-07 19:42:43, Info CSI 00000508 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:42:43, Info CSI 00000509 [SR] Beginning Verify and Repair transaction
2021-11-07 19:42:45, Info CSI 0000050b [SR] Verify complete
2021-11-07 19:42:45, Info CSI 0000050c [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:42:45, Info CSI 0000050d [SR] Beginning Verify and Repair transaction
2021-11-07 19:42:47, Info CSI 0000050f [SR] Verify complete
2021-11-07 19:42:47, Info CSI 00000510 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:42:47, Info CSI 00000511 [SR] Beginning Verify and Repair transaction
2021-11-07 19:42:50, Info CSI 00000513 [SR] Verify complete
2021-11-07 19:42:50, Info CSI 00000514 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:42:50, Info CSI 00000515 [SR] Beginning Verify and Repair transaction
2021-11-07 19:42:52, Info CSI 00000519 [SR] Verify complete
2021-11-07 19:42:52, Info CSI 0000051a [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:42:52, Info CSI 0000051b [SR] Beginning Verify and Repair transaction
2021-11-07 19:42:55, Info CSI 0000051d [SR] Verify complete
2021-11-07 19:42:56, Info CSI 0000051e [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:42:56, Info CSI 0000051f [SR] Beginning Verify and Repair transaction
2021-11-07 19:42:58, Info CSI 00000521 [SR] Verify complete
2021-11-07 19:42:58, Info CSI 00000522 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:42:58, Info CSI 00000523 [SR] Beginning Verify and Repair transaction
2021-11-07 19:43:01, Info CSI 00000525 [SR] Verify complete
2021-11-07 19:43:01, Info CSI 00000526 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:43:01, Info CSI 00000527 [SR] Beginning Verify and Repair transaction
2021-11-07 19:43:04, Info CSI 0000052a [SR] Verify complete
2021-11-07 19:43:04, Info CSI 0000052b [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:43:04, Info CSI 0000052c [SR] Beginning Verify and Repair transaction
2021-11-07 19:43:07, Info CSI 0000052e [SR] Verify complete
2021-11-07 19:43:08, Info CSI 0000052f [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:43:08, Info CSI 00000530 [SR] Beginning Verify and Repair transaction
2021-11-07 19:43:11, Info CSI 00000532 [SR] Verify complete
2021-11-07 19:43:11, Info CSI 00000533 [SR] Verifying 100 (0x0000000000000064) components
2021-11-07 19:43:11, Info CSI 00000534 [SR] Beginning Verify and Repair transaction
2021-11-07 19:43:14, Info CSI 00000536 [SR] Verify complete
2021-11-07 19:43:14, Info CSI 00000537 [SR] Verifying 82 (0x0000000000000052) components
2021-11-07 19:43:14, Info CSI 00000538 [SR] Beginning Verify and Repair transaction
2021-11-07 19:43:17, Info CSI 0000053a [SR] Verify complete
2021-11-07 19:43:17, Info CSI 0000053b [SR] Repairing 1 components
2021-11-07 19:43:17, Info CSI 0000053c [SR] Beginning Verify and Repair transaction
2021-11-07 19:43:17, Info CSI 0000053e [SR] Cannot repair member file [l:28{14}]"iassdo.dll.mui" of Microsoft-Windows-Networking-Internet_Authentication_Service_Iassdo.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"en-US", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2021-11-07 19:43:17, Info CSI 00000540 [SR] Cannot repair member file [l:28{14}]"iassdo.dll.mui" of Microsoft-Windows-Networking-Internet_Authentication_Service_Iassdo.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"en-US", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2021-11-07 19:43:17, Info CSI 00000541 [SR] This component was referenced by [l:266{133}]"Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~en-US~6.1.7601.17514.Windows Foundation Language Pack"
2021-11-07 19:43:17, Info CSI 00000544 [SR] Could not reproject corrupted file [ml:60{30},l:58{29}]"\??\C:\Windows\SysWOW64\en-US"\[l:28{14}]"iassdo.dll.mui"; source file in store is also corrupted
2021-11-07 19:43:17, Info CSI 00000546 [SR] Repair complete
2021-11-07 19:43:17, Info CSI 00000547 [SR] Committing transaction
2021-11-07 19:43:17, Info CSI 0000054b [SR] Verify and Repair Transaction completed. All files and registry keys listed in this transaction have been successfully repaired
2021-11-10 20:07:13, Info CSI 00000009 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:07:13, Info CSI 0000000a [SR] Beginning Verify and Repair transaction
2021-11-10 20:07:17, Info CSI 0000000c [SR] Verify complete
2021-11-10 20:07:19, Info CSI 0000000d [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:07:19, Info CSI 0000000e [SR] Beginning Verify and Repair transaction
2021-11-10 20:07:22, Info CSI 00000010 [SR] Verify complete
2021-11-10 20:07:24, Info CSI 00000011 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:07:24, Info CSI 00000012 [SR] Beginning Verify and Repair transaction
2021-11-10 20:07:26, Info CSI 00000014 [SR] Verify complete
2021-11-10 20:07:27, Info CSI 00000015 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:07:27, Info CSI 00000016 [SR] Beginning Verify and Repair transaction
2021-11-10 20:07:30, Info CSI 00000018 [SR] Verify complete
2021-11-10 20:07:31, Info CSI 00000019 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:07:31, Info CSI 0000001a [SR] Beginning Verify and Repair transaction
2021-11-10 20:07:34, Info CSI 0000001c [SR] Verify complete
2021-11-10 20:07:36, Info CSI 0000001d [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:07:36, Info CSI 0000001e [SR] Beginning Verify and Repair transaction
2021-11-10 20:07:40, Info CSI 00000020 [SR] Verify complete
2021-11-10 20:07:42, Info CSI 00000021 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:07:42, Info CSI 00000022 [SR] Beginning Verify and Repair transaction
2021-11-10 20:07:43, Info CSI 00000024 [SR] Verify complete
2021-11-10 20:07:45, Info CSI 00000025 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:07:45, Info CSI 00000026 [SR] Beginning Verify and Repair transaction
2021-11-10 20:07:47, Info CSI 00000028 [SR] Verify complete
2021-11-10 20:07:49, Info CSI 00000029 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:07:49, Info CSI 0000002a [SR] Beginning Verify and Repair transaction
2021-11-10 20:07:50, Info CSI 0000002c [SR] Verify complete
2021-11-10 20:07:52, Info CSI 0000002d [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:07:52, Info CSI 0000002e [SR] Beginning Verify and Repair transaction
2021-11-10 20:07:53, Info CSI 00000030 [SR] Verify complete
2021-11-10 20:07:55, Info CSI 00000031 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:07:55, Info CSI 00000032 [SR] Beginning Verify and Repair transaction
2021-11-10 20:07:56, Info CSI 00000034 [SR] Verify complete
2021-11-10 20:07:58, Info CSI 00000035 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:07:58, Info CSI 00000036 [SR] Beginning Verify and Repair transaction
2021-11-10 20:07:59, Info CSI 00000038 [SR] Verify complete
2021-11-10 20:08:00, Info CSI 00000039 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:08:00, Info CSI 0000003a [SR] Beginning Verify and Repair transaction
2021-11-10 20:08:02, Info CSI 0000003c [SR] Verify complete
2021-11-10 20:08:03, Info CSI 0000003d [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:08:03, Info CSI 0000003e [SR] Beginning Verify and Repair transaction
2021-11-10 20:08:05, Info CSI 00000040 [SR] Verify complete
2021-11-10 20:08:07, Info CSI 00000041 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:08:07, Info CSI 00000042 [SR] Beginning Verify and Repair transaction
2021-11-10 20:08:10, Info CSI 00000044 [SR] Verify complete
2021-11-10 20:08:11, Info CSI 00000045 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:08:11, Info CSI 00000046 [SR] Beginning Verify and Repair transaction
2021-11-10 20:08:13, Info CSI 00000048 [SR] Verify complete
2021-11-10 20:08:14, Info CSI 00000049 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:08:14, Info CSI 0000004a [SR] Beginning Verify and Repair transaction
2021-11-10 20:08:16, Info CSI 0000004c [SR] Verify complete
2021-11-10 20:08:17, Info CSI 0000004d [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:08:17, Info CSI 0000004e [SR] Beginning Verify and Repair transaction
2021-11-10 20:08:19, Info CSI 00000050 [SR] Verify complete
2021-11-10 20:08:21, Info CSI 00000051 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:08:21, Info CSI 00000052 [SR] Beginning Verify and Repair transaction
2021-11-10 20:08:22, Info CSI 00000054 [SR] Verify complete
2021-11-10 20:08:23, Info CSI 00000055 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:08:23, Info CSI 00000056 [SR] Beginning Verify and Repair transaction
2021-11-10 20:08:25, Info CSI 00000058 [SR] Verify complete
2021-11-10 20:08:26, Info CSI 00000059 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:08:26, Info CSI 0000005a [SR] Beginning Verify and Repair transaction
2021-11-10 20:08:27, Info CSI 0000005c [SR] Verify complete
2021-11-10 20:08:29, Info CSI 0000005d [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:08:29, Info CSI 0000005e [SR] Beginning Verify and Repair transaction
2021-11-10 20:08:30, Info CSI 00000060 [SR] Verify complete
2021-11-10 20:08:31, Info CSI 00000061 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:08:31, Info CSI 00000062 [SR] Beginning Verify and Repair transaction
2021-11-10 20:08:32, Info CSI 00000064 [SR] Verify complete
2021-11-10 20:08:34, Info CSI 00000065 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:08:34, Info CSI 00000066 [SR] Beginning Verify and Repair transaction
2021-11-10 20:08:35, Info CSI 00000068 [SR] Verify complete
2021-11-10 20:08:37, Info CSI 00000069 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:08:37, Info CSI 0000006a [SR] Beginning Verify and Repair transaction
2021-11-10 20:08:38, Info CSI 0000006c [SR] Verify complete
2021-11-10 20:08:40, Info CSI 0000006d [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:08:40, Info CSI 0000006e [SR] Beginning Verify and Repair transaction
2021-11-10 20:08:41, Info CSI 00000070 [SR] Verify complete
2021-11-10 20:08:43, Info CSI 00000071 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:08:43, Info CSI 00000072 [SR] Beginning Verify and Repair transaction
2021-11-10 20:08:44, Info CSI 00000074 [SR] Verify complete
2021-11-10 20:08:46, Info CSI 00000075 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:08:46, Info CSI 00000076 [SR] Beginning Verify and Repair transaction
2021-11-10 20:08:47, Info CSI 00000078 [SR] Verify complete
2021-11-10 20:08:49, Info CSI 00000079 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:08:49, Info CSI 0000007a [SR] Beginning Verify and Repair transaction
2021-11-10 20:08:50, Info CSI 0000007c [SR] Verify complete
2021-11-10 20:08:51, Info CSI 0000007d [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:08:51, Info CSI 0000007e [SR] Beginning Verify and Repair transaction
2021-11-10 20:08:53, Info CSI 00000080 [SR] Verify complete
2021-11-10 20:08:54, Info CSI 00000081 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:08:54, Info CSI 00000082 [SR] Beginning Verify and Repair transaction
2021-11-10 20:08:56, Info CSI 00000084 [SR] Verify complete
2021-11-10 20:08:57, Info CSI 00000085 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:08:57, Info CSI 00000086 [SR] Beginning Verify and Repair transaction
2021-11-10 20:08:58, Info CSI 00000088 [SR] Verify complete
2021-11-10 20:08:59, Info CSI 00000089 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:08:59, Info CSI 0000008a [SR] Beginning Verify and Repair transaction
2021-11-10 20:09:01, Info CSI 0000008c [SR] Verify complete
2021-11-10 20:09:02, Info CSI 0000008d [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:09:02, Info CSI 0000008e [SR] Beginning Verify and Repair transaction
2021-11-10 20:09:04, Info CSI 00000090 [SR] Verify complete
2021-11-10 20:09:05, Info CSI 00000091 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:09:05, Info CSI 00000092 [SR] Beginning Verify and Repair transaction
2021-11-10 20:09:06, Info CSI 00000094 [SR] Verify complete
2021-11-10 20:09:07, Info CSI 00000095 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:09:07, Info CSI 00000096 [SR] Beginning Verify and Repair transaction
2021-11-10 20:09:08, Info CSI 00000098 [SR] Verify complete
2021-11-10 20:09:09, Info CSI 00000099 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:09:09, Info CSI 0000009a [SR] Beginning Verify and Repair transaction
2021-11-10 20:09:11, Info CSI 0000009c [SR] Verify complete
2021-11-10 20:09:12, Info CSI 0000009d [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:09:12, Info CSI 0000009e [SR] Beginning Verify and Repair transaction
2021-11-10 20:09:13, Info CSI 000000a0 [SR] Verify complete
2021-11-10 20:09:14, Info CSI 000000a1 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:09:14, Info CSI 000000a2 [SR] Beginning Verify and Repair transaction
2021-11-10 20:09:16, Info CSI 000000a4 [SR] Verify complete
2021-11-10 20:09:16, Info CSI 000000a5 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:09:16, Info CSI 000000a6 [SR] Beginning Verify and Repair transaction
2021-11-10 20:09:19, Info CSI 000000a8 [SR] Verify complete
2021-11-10 20:09:19, Info CSI 000000a9 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:09:19, Info CSI 000000aa [SR] Beginning Verify and Repair transaction
2021-11-10 20:09:23, Info CSI 000000ac [SR] Verify complete
2021-11-10 20:09:24, Info CSI 000000ad [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:09:24, Info CSI 000000ae [SR] Beginning Verify and Repair transaction
2021-11-10 20:09:26, Info CSI 000000b0 [SR] Verify complete
2021-11-10 20:09:27, Info CSI 000000b1 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:09:27, Info CSI 000000b2 [SR] Beginning Verify and Repair transaction
2021-11-10 20:09:28, Info CSI 000000b4 [SR] Verify complete
2021-11-10 20:09:29, Info CSI 000000b5 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:09:29, Info CSI 000000b6 [SR] Beginning Verify and Repair transaction
2021-11-10 20:09:31, Info CSI 000000b8 [SR] Verify complete
2021-11-10 20:09:32, Info CSI 000000b9 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:09:32, Info CSI 000000ba [SR] Beginning Verify and Repair transaction
2021-11-10 20:09:35, Info CSI 000000bc [SR] Verify complete
2021-11-10 20:09:35, Info CSI 000000bd [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:09:35, Info CSI 000000be [SR] Beginning Verify and Repair transaction
2021-11-10 20:09:38, Info CSI 000000c0 [SR] Verify complete
2021-11-10 20:09:39, Info CSI 000000c1 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:09:39, Info CSI 000000c2 [SR] Beginning Verify and Repair transaction
2021-11-10 20:09:40, Info CSI 000000c4 [SR] Verify complete
2021-11-10 20:09:41, Info CSI 000000c5 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:09:41, Info CSI 000000c6 [SR] Beginning Verify and Repair transaction
2021-11-10 20:09:43, Info CSI 000000c8 [SR] Verify complete
2021-11-10 20:09:44, Info CSI 000000c9 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:09:44, Info CSI 000000ca [SR] Beginning Verify and Repair transaction
2021-11-10 20:09:46, Info CSI 000000cc [SR] Verify complete
2021-11-10 20:09:46, Info CSI 000000cd [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:09:46, Info CSI 000000ce [SR] Beginning Verify and Repair transaction
2021-11-10 20:09:49, Info CSI 000000d0 [SR] Verify complete
2021-11-10 20:09:49, Info CSI 000000d1 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:09:49, Info CSI 000000d2 [SR] Beginning Verify and Repair transaction
2021-11-10 20:09:51, Info CSI 000000d4 [SR] Verify complete
2021-11-10 20:09:52, Info CSI 000000d5 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:09:52, Info CSI 000000d6 [SR] Beginning Verify and Repair transaction
2021-11-10 20:09:54, Info CSI 000000d8 [SR] Verify complete
2021-11-10 20:09:55, Info CSI 000000d9 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:09:55, Info CSI 000000da [SR] Beginning Verify and Repair transaction
2021-11-10 20:09:57, Info CSI 000000dc [SR] Verify complete
2021-11-10 20:09:57, Info CSI 000000dd [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:09:57, Info CSI 000000de [SR] Beginning Verify and Repair transaction
2021-11-10 20:10:00, Info CSI 000000e0 [SR] Verify complete
2021-11-10 20:10:01, Info CSI 000000e1 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:10:01, Info CSI 000000e2 [SR] Beginning Verify and Repair transaction
2021-11-10 20:10:03, Info CSI 000000e4 [SR] Verify complete
2021-11-10 20:10:03, Info CSI 000000e5 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:10:03, Info CSI 000000e6 [SR] Beginning Verify and Repair transaction
2021-11-10 20:10:05, Info CSI 000000e8 [SR] Verify complete
2021-11-10 20:10:06, Info CSI 000000e9 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:10:06, Info CSI 000000ea [SR] Beginning Verify and Repair transaction
2021-11-10 20:10:07, Info CSI 000000ec [SR] Verify complete
2021-11-10 20:10:08, Info CSI 000000ed [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:10:08, Info CSI 000000ee [SR] Beginning Verify and Repair transaction
2021-11-10 20:10:10, Info CSI 000000f0 [SR] Verify complete
2021-11-10 20:10:10, Info CSI 000000f1 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:10:10, Info CSI 000000f2 [SR] Beginning Verify and Repair transaction
2021-11-10 20:10:12, Info CSI 000000f4 [SR] Verify complete
2021-11-10 20:10:13, Info CSI 000000f5 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:10:13, Info CSI 000000f6 [SR] Beginning Verify and Repair transaction
2021-11-10 20:10:15, Info CSI 000000f8 [SR] Verify complete
2021-11-10 20:10:16, Info CSI 000000f9 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:10:16, Info CSI 000000fa [SR] Beginning Verify and Repair transaction
2021-11-10 20:10:17, Info CSI 000000fc [SR] Verify complete
2021-11-10 20:10:18, Info CSI 000000fd [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:10:18, Info CSI 000000fe [SR] Beginning Verify and Repair transaction
2021-11-10 20:10:21, Info CSI 00000100 [SR] Verify complete
2021-11-10 20:10:21, Info CSI 00000101 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:10:21, Info CSI 00000102 [SR] Beginning Verify and Repair transaction
2021-11-10 20:10:25, Info CSI 00000104 [SR] Verify complete
2021-11-10 20:10:25, Info CSI 00000105 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:10:25, Info CSI 00000106 [SR] Beginning Verify and Repair transaction
2021-11-10 20:10:29, Info CSI 00000108 [SR] Verify complete
2021-11-10 20:10:29, Info CSI 00000109 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:10:29, Info CSI 0000010a [SR] Beginning Verify and Repair transaction
2021-11-10 20:10:32, Info CSI 0000010c [SR] Verify complete
2021-11-10 20:10:32, Info CSI 0000010d [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:10:32, Info CSI 0000010e [SR] Beginning Verify and Repair transaction
2021-11-10 20:10:35, Info CSI 00000110 [SR] Verify complete
2021-11-10 20:10:36, Info CSI 00000111 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:10:36, Info CSI 00000112 [SR] Beginning Verify and Repair transaction
2021-11-10 20:10:39, Info CSI 00000114 [SR] Verify complete
2021-11-10 20:10:39, Info CSI 00000115 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:10:39, Info CSI 00000116 [SR] Beginning Verify and Repair transaction
2021-11-10 20:10:44, Info CSI 00000118 [SR] Verify complete
2021-11-10 20:10:45, Info CSI 00000119 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:10:45, Info CSI 0000011a [SR] Beginning Verify and Repair transaction
2021-11-10 20:10:52, Info CSI 0000011d [SR] Verify complete
2021-11-10 20:10:52, Info CSI 0000011e [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:10:52, Info CSI 0000011f [SR] Beginning Verify and Repair transaction
2021-11-10 20:10:58, Info CSI 00000122 [SR] Verify complete
2021-11-10 20:10:58, Info CSI 00000123 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:10:58, Info CSI 00000124 [SR] Beginning Verify and Repair transaction
2021-11-10 20:11:04, Info CSI 00000127 [SR] Verify complete
2021-11-10 20:11:05, Info CSI 00000128 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:11:05, Info CSI 00000129 [SR] Beginning Verify and Repair transaction
2021-11-10 20:11:09, Info CSI 0000012c [SR] Verify complete
2021-11-10 20:11:10, Info CSI 0000012d [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:11:10, Info CSI 0000012e [SR] Beginning Verify and Repair transaction
2021-11-10 20:11:14, Info CSI 00000133 [SR] Verify complete
2021-11-10 20:11:15, Info CSI 00000134 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:11:15, Info CSI 00000135 [SR] Beginning Verify and Repair transaction
2021-11-10 20:11:18, Info CSI 00000137 [SR] Verify complete
2021-11-10 20:11:19, Info CSI 00000138 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:11:19, Info CSI 00000139 [SR] Beginning Verify and Repair transaction
2021-11-10 20:11:25, Info CSI 0000013b [SR] Verify complete
2021-11-10 20:11:25, Info CSI 0000013c [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:11:25, Info CSI 0000013d [SR] Beginning Verify and Repair transaction
2021-11-10 20:11:31, Info CSI 0000015f [SR] Verify complete
2021-11-10 20:11:31, Info CSI 00000160 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:11:31, Info CSI 00000161 [SR] Beginning Verify and Repair transaction
2021-11-10 20:11:37, Info CSI 00000166 [SR] Verify complete
2021-11-10 20:11:38, Info CSI 00000167 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:11:38, Info CSI 00000168 [SR] Beginning Verify and Repair transaction
2021-11-10 20:11:43, Info CSI 0000016a [SR] Verify complete
2021-11-10 20:11:43, Info CSI 0000016b [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:11:43, Info CSI 0000016c [SR] Beginning Verify and Repair transaction
2021-11-10 20:11:48, Info CSI 0000016e [SR] Verify complete
2021-11-10 20:11:48, Info CSI 0000016f [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:11:48, Info CSI 00000170 [SR] Beginning Verify and Repair transaction
2021-11-10 20:11:53, Info CSI 00000172 [SR] Verify complete
2021-11-10 20:11:53, Info CSI 00000173 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:11:53, Info CSI 00000174 [SR] Beginning Verify and Repair transaction
2021-11-10 20:11:56, Info CSI 00000176 [SR] Verify complete
2021-11-10 20:11:57, Info CSI 00000177 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:11:57, Info CSI 00000178 [SR] Beginning Verify and Repair transaction
2021-11-10 20:12:02, Info CSI 0000017a [SR] Verify complete
2021-11-10 20:12:02, Info CSI 0000017b [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:12:02, Info CSI 0000017c [SR] Beginning Verify and Repair transaction
2021-11-10 20:12:06, Info CSI 0000017e [SR] Verify complete
2021-11-10 20:12:06, Info CSI 0000017f [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:12:06, Info CSI 00000180 [SR] Beginning Verify and Repair transaction
2021-11-10 20:12:12, Info CSI 00000182 [SR] Verify complete
2021-11-10 20:12:12, Info CSI 00000183 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:12:12, Info CSI 00000184 [SR] Beginning Verify and Repair transaction
2021-11-10 20:12:15, Info CSI 00000186 [SR] Verify complete
2021-11-10 20:12:15, Info CSI 00000187 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:12:15, Info CSI 00000188 [SR] Beginning Verify and Repair transaction
2021-11-10 20:12:21, Info CSI 0000018a [SR] Verify complete
2021-11-10 20:12:21, Info CSI 0000018b [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:12:21, Info CSI 0000018c [SR] Beginning Verify and Repair transaction
2021-11-10 20:12:28, Info CSI 000001aa [SR] Verify complete
2021-11-10 20:12:28, Info CSI 000001ab [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:12:28, Info CSI 000001ac [SR] Beginning Verify and Repair transaction
2021-11-10 20:12:33, Info CSI 000001cd [SR] Verify complete
2021-11-10 20:12:34, Info CSI 000001ce [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:12:34, Info CSI 000001cf [SR] Beginning Verify and Repair transaction
2021-11-10 20:12:44, Info CSI 000001d1 [SR] Verify complete
2021-11-10 20:12:44, Info CSI 000001d2 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:12:44, Info CSI 000001d3 [SR] Beginning Verify and Repair transaction
2021-11-10 20:12:51, Info CSI 000001d5 [SR] Verify complete
2021-11-10 20:12:51, Info CSI 000001d6 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:12:51, Info CSI 000001d7 [SR] Beginning Verify and Repair transaction
2021-11-10 20:13:00, Info CSI 000001d9 [SR] Verify complete
2021-11-10 20:13:01, Info CSI 000001da [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:13:01, Info CSI 000001db [SR] Beginning Verify and Repair transaction
2021-11-10 20:13:04, Info CSI 000001df [SR] Verify complete
2021-11-10 20:13:04, Info CSI 000001e0 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:13:04, Info CSI 000001e1 [SR] Beginning Verify and Repair transaction
2021-11-10 20:13:08, Info CSI 000001e3 [SR] Verify complete
2021-11-10 20:13:08, Info CSI 000001e4 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:13:08, Info CSI 000001e5 [SR] Beginning Verify and Repair transaction
2021-11-10 20:13:11, Info CSI 000001e7 [SR] Verify complete
2021-11-10 20:13:12, Info CSI 000001e8 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:13:12, Info CSI 000001e9 [SR] Beginning Verify and Repair transaction
2021-11-10 20:13:13, Info CSI 000001eb [SR] Verify complete
2021-11-10 20:13:13, Info CSI 000001ec [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:13:13, Info CSI 000001ed [SR] Beginning Verify and Repair transaction
2021-11-10 20:13:15, Info CSI 000001ef [SR] Verify complete
2021-11-10 20:13:15, Info CSI 000001f0 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:13:15, Info CSI 000001f1 [SR] Beginning Verify and Repair transaction
2021-11-10 20:13:18, Info CSI 000001f3 [SR] Verify complete
2021-11-10 20:13:18, Info CSI 000001f4 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:13:18, Info CSI 000001f5 [SR] Beginning Verify and Repair transaction
2021-11-10 20:13:21, Info CSI 000001f7 [SR] Verify complete
2021-11-10 20:13:22, Info CSI 000001f8 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:13:22, Info CSI 000001f9 [SR] Beginning Verify and Repair transaction
2021-11-10 20:13:29, Info CSI 0000020c [SR] Verify complete
2021-11-10 20:13:29, Info CSI 0000020d [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:13:29, Info CSI 0000020e [SR] Beginning Verify and Repair transaction
2021-11-10 20:13:31, Info CSI 00000210 [SR] Verify complete
2021-11-10 20:13:31, Info CSI 00000211 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:13:31, Info CSI 00000212 [SR] Beginning Verify and Repair transaction
2021-11-10 20:13:35, Info CSI 00000214 [SR] Verify complete
2021-11-10 20:13:35, Info CSI 00000215 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:13:35, Info CSI 00000216 [SR] Beginning Verify and Repair transaction
2021-11-10 20:13:39, Info CSI 00000218 [SR] Verify complete
2021-11-10 20:13:39, Info CSI 00000219 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:13:39, Info CSI 0000021a [SR] Beginning Verify and Repair transaction
2021-11-10 20:13:43, Info CSI 0000021c [SR] Verify complete
2021-11-10 20:13:44, Info CSI 0000021d [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:13:44, Info CSI 0000021e [SR] Beginning Verify and Repair transaction
2021-11-10 20:13:48, Info CSI 00000221 [SR] Verify complete
2021-11-10 20:13:49, Info CSI 00000222 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:13:49, Info CSI 00000223 [SR] Beginning Verify and Repair transaction
2021-11-10 20:14:02, Info CSI 00000226 [SR] Verify complete
2021-11-10 20:14:02, Info CSI 00000227 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:14:02, Info CSI 00000228 [SR] Beginning Verify and Repair transaction
2021-11-10 20:14:08, Info CSI 0000022a [SR] Verify complete
2021-11-10 20:14:08, Info CSI 0000022b [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:14:08, Info CSI 0000022c [SR] Beginning Verify and Repair transaction
2021-11-10 20:14:12, Info CSI 0000022e [SR] Verify complete
2021-11-10 20:14:12, Info CSI 0000022f [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:14:12, Info CSI 00000230 [SR] Beginning Verify and Repair transaction
2021-11-10 20:14:15, Info CSI 00000232 [SR] Verify complete
2021-11-10 20:14:15, Info CSI 00000233 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:14:15, Info CSI 00000234 [SR] Beginning Verify and Repair transaction
2021-11-10 20:14:18, Info CSI 00000236 [SR] Verify complete
2021-11-10 20:14:18, Info CSI 00000237 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:14:18, Info CSI 00000238 [SR] Beginning Verify and Repair transaction
2021-11-10 20:14:22, Info CSI 0000023a [SR] Verify complete
2021-11-10 20:14:23, Info CSI 0000023b [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:14:23, Info CSI 0000023c [SR] Beginning Verify and Repair transaction
2021-11-10 20:14:29, Info CSI 0000023e [SR] Verify complete
2021-11-10 20:14:30, Info CSI 0000023f [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:14:30, Info CSI 00000240 [SR] Beginning Verify and Repair transaction
2021-11-10 20:14:34, Info CSI 00000242 [SR] Verify complete
2021-11-10 20:14:35, Info CSI 00000243 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:14:35, Info CSI 00000244 [SR] Beginning Verify and Repair transaction
2021-11-10 20:14:39, Info CSI 00000246 [SR] Verify complete
2021-11-10 20:14:39, Info CSI 00000247 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:14:39, Info CSI 00000248 [SR] Beginning Verify and Repair transaction
2021-11-10 20:14:44, Info CSI 0000024a [SR] Verify complete
2021-11-10 20:14:45, Info CSI 0000024b [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:14:45, Info CSI 0000024c [SR] Beginning Verify and Repair transaction
2021-11-10 20:14:55, Info CSI 00000260 [SR] Verify complete
2021-11-10 20:14:56, Info CSI 00000261 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:14:56, Info CSI 00000262 [SR] Beginning Verify and Repair transaction
2021-11-10 20:15:00, Info CSI 00000268 [SR] Verify complete
2021-11-10 20:15:00, Info CSI 00000269 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:15:00, Info CSI 0000026a [SR] Beginning Verify and Repair transaction
2021-11-10 20:15:06, Info CSI 0000026c [SR] Verify complete
2021-11-10 20:15:07, Info CSI 0000026d [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:15:07, Info CSI 0000026e [SR] Beginning Verify and Repair transaction
2021-11-10 20:15:10, Info CSI 00000270 [SR] Verify complete
2021-11-10 20:15:11, Info CSI 00000271 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:15:11, Info CSI 00000272 [SR] Beginning Verify and Repair transaction
2021-11-10 20:15:29, Info CSI 00000274 [SR] Verify complete
2021-11-10 20:15:29, Info CSI 00000275 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:15:29, Info CSI 00000276 [SR] Beginning Verify and Repair transaction
2021-11-10 20:15:35, Info CSI 00000278 [SR] Verify complete
2021-11-10 20:15:36, Info CSI 00000279 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:15:36, Info CSI 0000027a [SR] Beginning Verify and Repair transaction
2021-11-10 20:15:44, Info CSI 0000027d [SR] Verify complete
2021-11-10 20:15:45, Info CSI 0000027e [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:15:45, Info CSI 0000027f [SR] Beginning Verify and Repair transaction
2021-11-10 20:15:51, Info CSI 00000281 [SR] Verify complete
2021-11-10 20:15:52, Info CSI 00000282 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:15:52, Info CSI 00000283 [SR] Beginning Verify and Repair transaction
2021-11-10 20:15:59, Info CSI 00000285 [SR] Verify complete
2021-11-10 20:15:59, Info CSI 00000286 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:15:59, Info CSI 00000287 [SR] Beginning Verify and Repair transaction
2021-11-10 20:16:06, Info CSI 0000028b [SR] Verify complete
2021-11-10 20:16:06, Info CSI 0000028c [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:16:06, Info CSI 0000028d [SR] Beginning Verify and Repair transaction
2021-11-10 20:16:10, Info CSI 0000028f [SR] Verify complete
2021-11-10 20:16:11, Info CSI 00000290 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:16:11, Info CSI 00000291 [SR] Beginning Verify and Repair transaction
2021-11-10 20:16:15, Info CSI 00000293 [SR] Verify complete
2021-11-10 20:16:16, Info CSI 00000294 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:16:16, Info CSI 00000295 [SR] Beginning Verify and Repair transaction
2021-11-10 20:16:21, Info CSI 00000297 [SR] Verify complete
2021-11-10 20:16:21, Info CSI 00000298 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:16:21, Info CSI 00000299 [SR] Beginning Verify and Repair transaction
2021-11-10 20:16:24, Info CSI 0000029b [SR] Verify complete
2021-11-10 20:16:24, Info CSI 0000029c [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:16:24, Info CSI 0000029d [SR] Beginning Verify and Repair transaction
2021-11-10 20:16:29, Info CSI 000002a1 [SR] Verify complete
2021-11-10 20:16:30, Info CSI 000002a2 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:16:30, Info CSI 000002a3 [SR] Beginning Verify and Repair transaction
2021-11-10 20:16:34, Info CSI 000002a5 [SR] Verify complete
2021-11-10 20:16:34, Info CSI 000002a6 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:16:34, Info CSI 000002a7 [SR] Beginning Verify and Repair transaction
2021-11-10 20:16:39, Info CSI 000002a9 [SR] Verify complete
2021-11-10 20:16:40, Info CSI 000002aa [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:16:40, Info CSI 000002ab [SR] Beginning Verify and Repair transaction
2021-11-10 20:16:54, Info CSI 000002ad [SR] Verify complete
2021-11-10 20:16:54, Info CSI 000002ae [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:16:54, Info CSI 000002af [SR] Beginning Verify and Repair transaction
2021-11-10 20:16:58, Info CSI 000002b1 [SR] Verify complete
2021-11-10 20:16:59, Info CSI 000002b2 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:16:59, Info CSI 000002b3 [SR] Beginning Verify and Repair transaction
2021-11-10 20:17:06, Info CSI 000002b6 [SR] Verify complete
2021-11-10 20:17:07, Info CSI 000002b7 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:17:07, Info CSI 000002b8 [SR] Beginning Verify and Repair transaction
2021-11-10 20:17:12, Info CSI 000002ba [SR] Verify complete
2021-11-10 20:17:12, Info CSI 000002bb [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:17:12, Info CSI 000002bc [SR] Beginning Verify and Repair transaction
2021-11-10 20:17:16, Info CSI 000002be [SR] Verify complete
2021-11-10 20:17:17, Info CSI 000002bf [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:17:17, Info CSI 000002c0 [SR] Beginning Verify and Repair transaction
2021-11-10 20:17:21, Info CSI 000002c3 [SR] Verify complete
2021-11-10 20:17:21, Info CSI 000002c4 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:17:21, Info CSI 000002c5 [SR] Beginning Verify and Repair transaction
2021-11-10 20:17:27, Info CSI 000002c7 [SR] Verify complete
2021-11-10 20:17:27, Info CSI 000002c8 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:17:27, Info CSI 000002c9 [SR] Beginning Verify and Repair transaction
2021-11-10 20:17:35, Info CSI 000002cb [SR] Verify complete
2021-11-10 20:17:35, Info CSI 000002cc [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:17:35, Info CSI 000002cd [SR] Beginning Verify and Repair transaction
2021-11-10 20:17:42, Info CSI 000002d0 [SR] Verify complete
2021-11-10 20:17:42, Info CSI 000002d1 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:17:42, Info CSI 000002d2 [SR] Beginning Verify and Repair transaction
2021-11-10 20:17:48, Info CSI 000002d4 [SR] Verify complete
2021-11-10 20:17:48, Info CSI 000002d5 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:17:48, Info CSI 000002d6 [SR] Beginning Verify and Repair transaction
2021-11-10 20:17:52, Info CSI 000002d8 [SR] Verify complete
2021-11-10 20:17:52, Info CSI 000002d9 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:17:52, Info CSI 000002da [SR] Beginning Verify and Repair transaction
2021-11-10 20:17:58, Info CSI 000002dc [SR] Verify complete
2021-11-10 20:17:59, Info CSI 000002dd [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:17:59, Info CSI 000002de [SR] Beginning Verify and Repair transaction
2021-11-10 20:18:05, Info CSI 000002e0 [SR] Verify complete
2021-11-10 20:18:05, Info CSI 000002e1 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:18:05, Info CSI 000002e2 [SR] Beginning Verify and Repair transaction
2021-11-10 20:18:09, Info CSI 000002e5 [SR] Verify complete
2021-11-10 20:18:10, Info CSI 000002e6 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:18:10, Info CSI 000002e7 [SR] Beginning Verify and Repair transaction
2021-11-10 20:18:15, Info CSI 000002e9 [SR] Verify complete
2021-11-10 20:18:16, Info CSI 000002ea [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:18:16, Info CSI 000002eb [SR] Beginning Verify and Repair transaction
2021-11-10 20:18:21, Info CSI 000002ed [SR] Verify complete
2021-11-10 20:18:22, Info CSI 000002ee [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:18:22, Info CSI 000002ef [SR] Beginning Verify and Repair transaction
2021-11-10 20:18:24, Info CSI 000002f2 [SR] Verify complete
2021-11-10 20:18:25, Info CSI 000002f3 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:18:25, Info CSI 000002f4 [SR] Beginning Verify and Repair transaction
2021-11-10 20:18:30, Info CSI 000002f8 [SR] Verify complete
2021-11-10 20:18:30, Info CSI 000002f9 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:18:30, Info CSI 000002fa [SR] Beginning Verify and Repair transaction
2021-11-10 20:18:36, Info CSI 000002fd [SR] Verify complete
2021-11-10 20:18:36, Info CSI 000002fe [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:18:36, Info CSI 000002ff [SR] Beginning Verify and Repair transaction
2021-11-10 20:18:41, Info CSI 00000303 [SR] Verify complete
2021-11-10 20:18:41, Info CSI 00000304 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:18:41, Info CSI 00000305 [SR] Beginning Verify and Repair transaction
2021-11-10 20:18:47, Info CSI 00000309 [SR] Verify complete
2021-11-10 20:18:48, Info CSI 0000030a [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:18:48, Info CSI 0000030b [SR] Beginning Verify and Repair transaction
2021-11-10 20:18:52, Info CSI 0000030e [SR] Verify complete
2021-11-10 20:18:53, Info CSI 0000030f [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:18:53, Info CSI 00000310 [SR] Beginning Verify and Repair transaction
2021-11-10 20:18:59, Info CSI 00000313 [SR] Verify complete
2021-11-10 20:18:59, Info CSI 00000314 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:18:59, Info CSI 00000315 [SR] Beginning Verify and Repair transaction
2021-11-10 20:19:03, Info CSI 00000317 [SR] Verify complete
2021-11-10 20:19:03, Info CSI 00000318 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:19:03, Info CSI 00000319 [SR] Beginning Verify and Repair transaction
2021-11-10 20:19:10, Info CSI 0000031b [SR] Verify complete
2021-11-10 20:19:11, Info CSI 0000031c [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:19:11, Info CSI 0000031d [SR] Beginning Verify and Repair transaction
2021-11-10 20:19:19, Info CSI 00000320 [SR] Verify complete
2021-11-10 20:19:19, Info CSI 00000321 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:19:19, Info CSI 00000322 [SR] Beginning Verify and Repair transaction
2021-11-10 20:19:23, Info CSI 00000324 [SR] Verify complete
2021-11-10 20:19:23, Info CSI 00000325 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:19:23, Info CSI 00000326 [SR] Beginning Verify and Repair transaction
2021-11-10 20:19:27, Info CSI 00000328 [SR] Verify complete
2021-11-10 20:19:27, Info CSI 00000329 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:19:27, Info CSI 0000032a [SR] Beginning Verify and Repair transaction
2021-11-10 20:19:30, Info CSI 0000032c [SR] Verify complete
2021-11-10 20:19:30, Info CSI 0000032d [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:19:30, Info CSI 0000032e [SR] Beginning Verify and Repair transaction
2021-11-10 20:19:35, Info CSI 00000330 [SR] Verify complete
2021-11-10 20:19:35, Info CSI 00000331 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:19:35, Info CSI 00000332 [SR] Beginning Verify and Repair transaction
2021-11-10 20:19:37, Info CSI 00000334 [SR] Verify complete
2021-11-10 20:19:38, Info CSI 00000335 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:19:38, Info CSI 00000336 [SR] Beginning Verify and Repair transaction
2021-11-10 20:19:44, Info CSI 00000338 [SR] Verify complete
2021-11-10 20:19:45, Info CSI 00000339 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:19:45, Info CSI 0000033a [SR] Beginning Verify and Repair transaction
2021-11-10 20:19:52, Info CSI 0000033c [SR] Verify complete
2021-11-10 20:19:53, Info CSI 0000033d [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:19:53, Info CSI 0000033e [SR] Beginning Verify and Repair transaction
2021-11-10 20:19:57, Info CSI 00000340 [SR] Verify complete
2021-11-10 20:19:57, Info CSI 00000341 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:19:57, Info CSI 00000342 [SR] Beginning Verify and Repair transaction
2021-11-10 20:19:59, Info CSI 00000344 [SR] Verify complete
2021-11-10 20:20:00, Info CSI 00000345 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:20:00, Info CSI 00000346 [SR] Beginning Verify and Repair transaction
2021-11-10 20:20:04, Info CSI 00000348 [SR] Verify complete
2021-11-10 20:20:05, Info CSI 00000349 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:20:05, Info CSI 0000034a [SR] Beginning Verify and Repair transaction
2021-11-10 20:20:10, Info CSI 0000034c [SR] Verify complete
2021-11-10 20:20:11, Info CSI 0000034d [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:20:11, Info CSI 0000034e [SR] Beginning Verify and Repair transaction
2021-11-10 20:20:21, Info CSI 00000350 [SR] Verify complete
2021-11-10 20:20:21, Info CSI 00000351 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:20:21, Info CSI 00000352 [SR] Beginning Verify and Repair transaction
2021-11-10 20:20:26, Info CSI 00000354 [SR] Verify complete
2021-11-10 20:20:26, Info CSI 00000355 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:20:26, Info CSI 00000356 [SR] Beginning Verify and Repair transaction
2021-11-10 20:20:37, Info CSI 00000358 [SR] Verify complete
2021-11-10 20:20:37, Info CSI 00000359 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:20:37, Info CSI 0000035a [SR] Beginning Verify and Repair transaction
2021-11-10 20:20:40, Info CSI 0000035c [SR] Verify complete
2021-11-10 20:20:40, Info CSI 0000035d [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:20:40, Info CSI 0000035e [SR] Beginning Verify and Repair transaction
2021-11-10 20:20:41, Info CSI 00000360 [SR] Verify complete
2021-11-10 20:20:42, Info CSI 00000361 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:20:42, Info CSI 00000362 [SR] Beginning Verify and Repair transaction
2021-11-10 20:20:44, Info CSI 00000364 [SR] Verify complete
2021-11-10 20:20:44, Info CSI 00000365 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:20:44, Info CSI 00000366 [SR] Beginning Verify and Repair transaction
2021-11-10 20:20:47, Info CSI 00000368 [SR] Verify complete
2021-11-10 20:20:47, Info CSI 00000369 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:20:47, Info CSI 0000036a [SR] Beginning Verify and Repair transaction
2021-11-10 20:20:49, Info CSI 0000036c [SR] Verify complete
2021-11-10 20:20:49, Info CSI 0000036d [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:20:49, Info CSI 0000036e [SR] Beginning Verify and Repair transaction
2021-11-10 20:20:50, Info CSI 00000370 [SR] Verify complete
2021-11-10 20:20:50, Info CSI 00000371 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:20:50, Info CSI 00000372 [SR] Beginning Verify and Repair transaction
2021-11-10 20:20:51, Info CSI 00000374 [SR] Verify complete
2021-11-10 20:20:51, Info CSI 00000375 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:20:51, Info CSI 00000376 [SR] Beginning Verify and Repair transaction
2021-11-10 20:20:54, Info CSI 00000378 [SR] Verify complete
2021-11-10 20:20:54, Info CSI 00000379 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:20:54, Info CSI 0000037a [SR] Beginning Verify and Repair transaction
2021-11-10 20:20:56, Info CSI 0000037c [SR] Verify complete
2021-11-10 20:20:57, Info CSI 0000037d [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:20:57, Info CSI 0000037e [SR] Beginning Verify and Repair transaction
2021-11-10 20:20:59, Info CSI 00000380 [SR] Verify complete
2021-11-10 20:20:59, Info CSI 00000381 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:20:59, Info CSI 00000382 [SR] Beginning Verify and Repair transaction
2021-11-10 20:21:01, Info CSI 00000384 [SR] Verify complete
2021-11-10 20:21:01, Info CSI 00000385 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:21:01, Info CSI 00000386 [SR] Beginning Verify and Repair transaction
2021-11-10 20:21:03, Info CSI 00000388 [SR] Verify complete
2021-11-10 20:21:03, Info CSI 00000389 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:21:03, Info CSI 0000038a [SR] Beginning Verify and Repair transaction
2021-11-10 20:21:04, Info CSI 0000038c [SR] Verify complete
2021-11-10 20:21:04, Info CSI 0000038d [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:21:04, Info CSI 0000038e [SR] Beginning Verify and Repair transaction
2021-11-10 20:21:05, Info CSI 00000390 [SR] Verify complete
2021-11-10 20:21:05, Info CSI 00000391 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:21:05, Info CSI 00000392 [SR] Beginning Verify and Repair transaction
2021-11-10 20:21:09, Info CSI 000003a0 [SR] Verify complete
2021-11-10 20:21:09, Info CSI 000003a1 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:21:09, Info CSI 000003a2 [SR] Beginning Verify and Repair transaction
2021-11-10 20:21:12, Info CSI 000003a4 [SR] Verify complete
2021-11-10 20:21:12, Info CSI 000003a5 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:21:12, Info CSI 000003a6 [SR] Beginning Verify and Repair transaction
2021-11-10 20:21:14, Info CSI 000003a8 [SR] Verify complete
2021-11-10 20:21:14, Info CSI 000003a9 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:21:14, Info CSI 000003aa [SR] Beginning Verify and Repair transaction
2021-11-10 20:21:17, Info CSI 000003ac [SR] Verify complete
2021-11-10 20:21:18, Info CSI 000003ad [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:21:18, Info CSI 000003ae [SR] Beginning Verify and Repair transaction
2021-11-10 20:21:20, Info CSI 000003b0 [SR] Verify complete
2021-11-10 20:21:20, Info CSI 000003b1 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:21:20, Info CSI 000003b2 [SR] Beginning Verify and Repair transaction
2021-11-10 20:21:23, Info CSI 000003b4 [SR] Verify complete
2021-11-10 20:21:24, Info CSI 000003b5 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:21:24, Info CSI 000003b6 [SR] Beginning Verify and Repair transaction
2021-11-10 20:21:26, Info CSI 000003b8 [SR] Verify complete
2021-11-10 20:21:27, Info CSI 000003b9 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:21:27, Info CSI 000003ba [SR] Beginning Verify and Repair transaction
2021-11-10 20:21:30, Info CSI 000003bc [SR] Verify complete
2021-11-10 20:21:30, Info CSI 000003bd [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:21:30, Info CSI 000003be [SR] Beginning Verify and Repair transaction
2021-11-10 20:21:33, Info CSI 000003c0 [SR] Verify complete
2021-11-10 20:21:34, Info CSI 000003c1 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:21:34, Info CSI 000003c2 [SR] Beginning Verify and Repair transaction
2021-11-10 20:21:37, Info CSI 000003c4 [SR] Verify complete
2021-11-10 20:21:37, Info CSI 000003c5 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:21:37, Info CSI 000003c6 [SR] Beginning Verify and Repair transaction
2021-11-10 20:21:39, Info CSI 000003c8 [SR] Verify complete
2021-11-10 20:21:39, Info CSI 000003c9 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:21:39, Info CSI 000003ca [SR] Beginning Verify and Repair transaction
2021-11-10 20:21:41, Info CSI 000003cc [SR] Verify complete
2021-11-10 20:21:42, Info CSI 000003cd [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:21:42, Info CSI 000003ce [SR] Beginning Verify and Repair transaction
2021-11-10 20:21:48, Info CSI 000003d3 [SR] Verify complete
2021-11-10 20:21:49, Info CSI 000003d4 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:21:49, Info CSI 000003d5 [SR] Beginning Verify and Repair transaction
2021-11-10 20:21:56, Info CSI 000003d7 [SR] Verify complete
2021-11-10 20:21:56, Info CSI 000003d8 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:21:56, Info CSI 000003d9 [SR] Beginning Verify and Repair transaction
2021-11-10 20:22:00, Info CSI 000003de [SR] Verify complete
2021-11-10 20:22:00, Info CSI 000003df [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:22:00, Info CSI 000003e0 [SR] Beginning Verify and Repair transaction
2021-11-10 20:22:04, Info CSI 000003e2 [SR] Verify complete
2021-11-10 20:22:04, Info CSI 000003e3 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:22:04, Info CSI 000003e4 [SR] Beginning Verify and Repair transaction
2021-11-10 20:22:08, Info CSI 000003f1 [SR] Verify complete
2021-11-10 20:22:08, Info CSI 000003f2 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:22:08, Info CSI 000003f3 [SR] Beginning Verify and Repair transaction
2021-11-10 20:22:13, Info CSI 000003f7 [SR] Verify complete
2021-11-10 20:22:13, Info CSI 000003f8 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:22:13, Info CSI 000003f9 [SR] Beginning Verify and Repair transaction
2021-11-10 20:22:16, Info CSI 000003fe [SR] Verify complete
2021-11-10 20:22:16, Info CSI 000003ff [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:22:16, Info CSI 00000400 [SR] Beginning Verify and Repair transaction
2021-11-10 20:22:19, Info CSI 00000402 [SR] Verify complete
2021-11-10 20:22:19, Info CSI 00000403 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:22:19, Info CSI 00000404 [SR] Beginning Verify and Repair transaction
2021-11-10 20:22:21, Info CSI 00000406 [SR] Verify complete
2021-11-10 20:22:21, Info CSI 00000407 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:22:21, Info CSI 00000408 [SR] Beginning Verify and Repair transaction
2021-11-10 20:22:24, Info CSI 0000040c [SR] Verify complete
2021-11-10 20:22:24, Info CSI 0000040d [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:22:24, Info CSI 0000040e [SR] Beginning Verify and Repair transaction
2021-11-10 20:22:26, Info CSI 00000410 [SR] Verify complete
2021-11-10 20:22:26, Info CSI 00000411 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:22:26, Info CSI 00000412 [SR] Beginning Verify and Repair transaction
2021-11-10 20:22:29, Info CSI 00000422 [SR] Verify complete
2021-11-10 20:22:29, Info CSI 00000423 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:22:29, Info CSI 00000424 [SR] Beginning Verify and Repair transaction
2021-11-10 20:22:32, Info CSI 0000043b [SR] Verify complete
2021-11-10 20:22:33, Info CSI 0000043c [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:22:33, Info CSI 0000043d [SR] Beginning Verify and Repair transaction
2021-11-10 20:22:35, Info CSI 0000043f [SR] Verify complete
2021-11-10 20:22:35, Info CSI 00000440 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:22:35, Info CSI 00000441 [SR] Beginning Verify and Repair transaction
2021-11-10 20:22:37, Info CSI 00000443 [SR] Verify complete
2021-11-10 20:22:37, Info CSI 00000444 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:22:37, Info CSI 00000445 [SR] Beginning Verify and Repair transaction
2021-11-10 20:22:39, Info CSI 00000447 [SR] Verify complete
2021-11-10 20:22:39, Info CSI 00000448 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:22:39, Info CSI 00000449 [SR] Beginning Verify and Repair transaction
2021-11-10 20:22:42, Info CSI 0000044b [SR] Verify complete
2021-11-10 20:22:43, Info CSI 0000044c [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:22:43, Info CSI 0000044d [SR] Beginning Verify and Repair transaction
2021-11-10 20:22:44, Info CSI 0000044f [SR] Verify complete
2021-11-10 20:22:44, Info CSI 00000450 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:22:44, Info CSI 00000451 [SR] Beginning Verify and Repair transaction
2021-11-10 20:22:47, Info CSI 00000463 [SR] Verify complete
2021-11-10 20:22:47, Info CSI 00000464 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:22:47, Info CSI 00000465 [SR] Beginning Verify and Repair transaction
2021-11-10 20:22:49, Info CSI 00000467 [SR] Verify complete
2021-11-10 20:22:49, Info CSI 00000468 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:22:49, Info CSI 00000469 [SR] Beginning Verify and Repair transaction
2021-11-10 20:22:53, Info CSI 0000046b [SR] Verify complete
2021-11-10 20:22:54, Info CSI 0000046c [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:22:54, Info CSI 0000046d [SR] Beginning Verify and Repair transaction
2021-11-10 20:22:55, Info CSI 0000046f [SR] Verify complete
2021-11-10 20:22:55, Info CSI 00000470 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:22:55, Info CSI 00000471 [SR] Beginning Verify and Repair transaction
2021-11-10 20:22:59, Info CSI 0000047f [SR] Verify complete
2021-11-10 20:22:59, Info CSI 00000480 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:22:59, Info CSI 00000481 [SR] Beginning Verify and Repair transaction
2021-11-10 20:23:01, Info CSI 00000483 [SR] Verify complete
2021-11-10 20:23:02, Info CSI 00000484 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:23:02, Info CSI 00000485 [SR] Beginning Verify and Repair transaction
2021-11-10 20:23:04, Info CSI 00000487 [SR] Verify complete
2021-11-10 20:23:04, Info CSI 00000488 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:23:04, Info CSI 00000489 [SR] Beginning Verify and Repair transaction
2021-11-10 20:23:09, Info CSI 0000048c [SR] Verify complete
2021-11-10 20:23:09, Info CSI 0000048d [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:23:09, Info CSI 0000048e [SR] Beginning Verify and Repair transaction
2021-11-10 20:23:12, Info CSI 00000490 [SR] Verify complete
2021-11-10 20:23:12, Info CSI 00000491 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:23:12, Info CSI 00000492 [SR] Beginning Verify and Repair transaction
2021-11-10 20:23:13, Info CSI 00000494 [SR] Verify complete
2021-11-10 20:23:13, Info CSI 00000495 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:23:13, Info CSI 00000496 [SR] Beginning Verify and Repair transaction
2021-11-10 20:23:15, Info CSI 00000498 [SR] Verify complete
2021-11-10 20:23:15, Info CSI 00000499 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:23:15, Info CSI 0000049a [SR] Beginning Verify and Repair transaction
2021-11-10 20:23:18, Info CSI 0000049c [SR] Verify complete
2021-11-10 20:23:18, Info CSI 0000049d [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:23:18, Info CSI 0000049e [SR] Beginning Verify and Repair transaction
2021-11-10 20:23:21, Info CSI 000004a0 [SR] Verify complete
2021-11-10 20:23:21, Info CSI 000004a1 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:23:21, Info CSI 000004a2 [SR] Beginning Verify and Repair transaction
2021-11-10 20:23:23, Info CSI 000004a4 [SR] Verify complete
2021-11-10 20:23:24, Info CSI 000004a5 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:23:24, Info CSI 000004a6 [SR] Beginning Verify and Repair transaction
2021-11-10 20:23:26, Info CSI 000004a8 [SR] Verify complete
2021-11-10 20:23:26, Info CSI 000004a9 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:23:26, Info CSI 000004aa [SR] Beginning Verify and Repair transaction
2021-11-10 20:23:30, Info CSI 000004c4 [SR] Verify complete
2021-11-10 20:23:30, Info CSI 000004c5 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:23:30, Info CSI 000004c6 [SR] Beginning Verify and Repair transaction
2021-11-10 20:23:34, Info CSI 000004c8 [SR] Verify complete
2021-11-10 20:23:34, Info CSI 000004c9 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:23:34, Info CSI 000004ca [SR] Beginning Verify and Repair transaction
2021-11-10 20:23:36, Info CSI 000004cc [SR] Verify complete
2021-11-10 20:23:36, Info CSI 000004cd [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:23:36, Info CSI 000004ce [SR] Beginning Verify and Repair transaction
2021-11-10 20:23:42, Info CSI 000004d0 [SR] Verify complete
2021-11-10 20:23:43, Info CSI 000004d1 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:23:43, Info CSI 000004d2 [SR] Beginning Verify and Repair transaction
2021-11-10 20:23:45, Info CSI 000004d4 [SR] Verify complete
2021-11-10 20:23:45, Info CSI 000004d5 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:23:45, Info CSI 000004d6 [SR] Beginning Verify and Repair transaction
2021-11-10 20:23:47, Info CSI 000004d8 [SR] Verify complete
2021-11-10 20:23:47, Info CSI 000004d9 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:23:47, Info CSI 000004da [SR] Beginning Verify and Repair transaction
2021-11-10 20:23:49, Info CSI 000004dc [SR] Verify complete
2021-11-10 20:23:49, Info CSI 000004dd [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:23:49, Info CSI 000004de [SR] Beginning Verify and Repair transaction
2021-11-10 20:23:51, Info CSI 000004e2 [SR] Verify complete
2021-11-10 20:23:51, Info CSI 000004e3 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:23:51, Info CSI 000004e4 [SR] Beginning Verify and Repair transaction
2021-11-10 20:23:52, Info CSI 000004e6 [SR] Verify complete
2021-11-10 20:23:53, Info CSI 000004e7 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:23:53, Info CSI 000004e8 [SR] Beginning Verify and Repair transaction
2021-11-10 20:23:54, Info CSI 000004ea [SR] Verify complete
2021-11-10 20:23:54, Info CSI 000004eb [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:23:54, Info CSI 000004ec [SR] Beginning Verify and Repair transaction
2021-11-10 20:23:56, Info CSI 000004ee [SR] Verify complete
2021-11-10 20:23:56, Info CSI 000004ef [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:23:56, Info CSI 000004f0 [SR] Beginning Verify and Repair transaction
2021-11-10 20:23:58, Info CSI 000004f2 [SR] Verify complete
2021-11-10 20:23:59, Info CSI 000004f3 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:23:59, Info CSI 000004f4 [SR] Beginning Verify and Repair transaction
2021-11-10 20:24:00, Info CSI 000004f6 [SR] Verify complete
2021-11-10 20:24:01, Info CSI 000004f7 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:24:01, Info CSI 000004f8 [SR] Beginning Verify and Repair transaction
2021-11-10 20:24:02, Info CSI 000004fa [SR] Verify complete
2021-11-10 20:24:02, Info CSI 000004fb [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:24:02, Info CSI 000004fc [SR] Beginning Verify and Repair transaction
2021-11-10 20:24:05, Info CSI 000004ff [SR] Verify complete
2021-11-10 20:24:05, Info CSI 00000500 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:24:05, Info CSI 00000501 [SR] Beginning Verify and Repair transaction
2021-11-10 20:24:07, Info CSI 00000503 [SR] Verify complete
2021-11-10 20:24:07, Info CSI 00000504 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:24:07, Info CSI 00000505 [SR] Beginning Verify and Repair transaction
2021-11-10 20:24:09, Info CSI 00000507 [SR] Verify complete
2021-11-10 20:24:09, Info CSI 00000508 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:24:09, Info CSI 00000509 [SR] Beginning Verify and Repair transaction
2021-11-10 20:24:10, Info CSI 0000050b [SR] Verify complete
2021-11-10 20:24:10, Info CSI 0000050c [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:24:10, Info CSI 0000050d [SR] Beginning Verify and Repair transaction
2021-11-10 20:24:12, Info CSI 00000511 [SR] Verify complete
2021-11-10 20:24:12, Info CSI 00000512 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:24:12, Info CSI 00000513 [SR] Beginning Verify and Repair transaction
2021-11-10 20:24:15, Info CSI 00000515 [SR] Verify complete
2021-11-10 20:24:15, Info CSI 00000516 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:24:15, Info CSI 00000517 [SR] Beginning Verify and Repair transaction
2021-11-10 20:24:17, Info CSI 00000519 [SR] Verify complete
2021-11-10 20:24:17, Info CSI 0000051a [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:24:17, Info CSI 0000051b [SR] Beginning Verify and Repair transaction
2021-11-10 20:24:20, Info CSI 0000051d [SR] Verify complete
2021-11-10 20:24:20, Info CSI 0000051e [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:24:20, Info CSI 0000051f [SR] Beginning Verify and Repair transaction
2021-11-10 20:24:23, Info CSI 00000522 [SR] Verify complete
2021-11-10 20:24:23, Info CSI 00000523 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:24:23, Info CSI 00000524 [SR] Beginning Verify and Repair transaction
2021-11-10 20:24:26, Info CSI 00000526 [SR] Verify complete
2021-11-10 20:24:27, Info CSI 00000527 [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:24:27, Info CSI 00000528 [SR] Beginning Verify and Repair transaction
2021-11-10 20:24:30, Info CSI 0000052a [SR] Verify complete
2021-11-10 20:24:30, Info CSI 0000052b [SR] Verifying 100 (0x0000000000000064) components
2021-11-10 20:24:30, Info CSI 0000052c [SR] Beginning Verify and Repair transaction
2021-11-10 20:24:37, Info CSI 0000052e [SR] Verify complete
2021-11-10 20:24:38, Info CSI 0000052f [SR] Verifying 82 (0x0000000000000052) components
2021-11-10 20:24:38, Info CSI 00000530 [SR] Beginning Verify and Repair transaction
2021-11-10 20:24:40, Info CSI 00000532 [SR] Verify complete
2021-11-10 20:24:40, Info CSI 00000533 [SR] Repairing 0 components
2021-11-10 20:24:40, Info CSI 00000534 [SR] Beginning Verify and Repair transaction
2021-11-10 20:24:40, Info CSI 00000536 [SR] Repair complete
=========== EmptyTemp: ==========
BITS transfer queue => 0 B
DOMStore, IE Recovery, AppCache, Feeds Cache, Thumbcache, IconCache => 12334908 B
Java, Flash, Steam htmlcache => 20230791 B
Windows/system/drivers => 48446 B
Edge => 0 B
Firefox => 0 B
Opera => 0 B
Temp, IE cache, history, cookies, recent:
Default => 0 B
Public => 0 B
ProgramData => 0 B
systemprofile => 0 B
systemprofile32 => 0 B
LocalService => 0 B
NetworkService => 0 B
Carlos Luna => 9513872 B
RecycleBin => 0 B
EmptyTemp: => 40.2 MB temporary data Removed.
The system needed a reboot.
==== End of Fixlog 20:24:51 ====
Carlosh,
From the log:
And from you:
Thanks, so far everything is running smoothly, don't having any issues now with the process or CPU, my main issue was that rootkit that was consuming all the memory, still didn't know I have so many other problems that I could never find for myself. So far everything looks good.
So... this is from me!
As for your other questions:
1. Tools we installed:
We are going to remove them, using a special tool (see at the end of my post). I recommend you to keep both MCShield and Malwarebytes. The former protects the computer every time you insert a USB stick in it, in case of infection. The latter, is an excellent antimalware solution: The free version can be used as an on-demand scanner (no real time protection as the Premium version) which plays well with Windows Defender, and you can use it from time to time to scan your computer. The tool won't remove MCShield and Malwarebytes. If you want to remove them, you have to do that from Control Panel, in the same way you uninstall any program.
2. Antivirus solution: The fact is that you need an antivirus. Free or not, this is a necessity if you also consider that you still have Windows 7, an operating system which stopped getting security updates since January 2020. The outdated operating system with the lack of antivirus software put the computer in a great security risk and make it extremely vulnerable. So, you have to choose an antivirus solution. I chose the specific programs instead of others, intentionally. When I had Windows 7, I tried both, Kaspersky and Avira (be careful, not both at the same time, it is important to use ONE antivirus with real time protection at a time), but eventually I decided to use Eset Internet Security which is a payed product. I was very happy with it, light and effective. And then, Windows 10 came! Windows 10 has a built-in antivirus solution, Microsoft Defender. The difference with Windows 7 Defender is that it is a complete antivirus/antimalware solution which makes its job just fine. You don't need a third party antivirus if you have this. Personally, I use it along with Malwarebytes and I'm pretty happy with them.
And here the question comes:
Have you considered to upgrade to Windows 10? Microsoft still gives this opportunity for free. Think about it and let me know if you want to do the step. In any case, I recommend you to make a backup of all your important files/data. Although the procedure is safe and gets complete without problems, you never know.
Since you don't have any other questions...
The following tool will remove the tools we used as well as reset system restore points:
Download KpRm by kernel-panik and save it to your desktop.
  • Right-click kprm_(version).exe and select Run as Administrator.
  • Read and accept the disclaimer.
  • When the tool opens, ensure all boxes under Actions are checked.
  • Under Delete Quarantines select Delete Now, then click Run.
  • Once complete, click OK.
  • A log will open in Notepad titled kprm-(date).txt.
  • Please copy and paste its contents in your next reply.
That's good to know, really thank you for all the help and time you give me here.
I already remove the tools that were installed during the process, but I keep Malwarebytes and MCShield as you recommend.
Upgrading to Windows 10 I know is for better, but I also know that I will have many issues with Nvidia drivers and well some of my components are a bit old, well I'm pretty sure all problems will be worse, like crashes/bluescreens/freeze/restarting/etc, so if I can upgrade the PC with a more updated build, I will go to Windows 10.
Also gonna post other reply, because I got a weird log when I reset the PC after installing Avira, I really don't know why it install like many components in the system, but just want to check if is just one time thing and of course harmless.
And again thanks for all the help, I was researching for days for all this issues and luckily found this forum.
Here is the log of the Kprm:
# Run at 12/11/2021 02:14:18 a.m.
# KpRm (Kernel-panik) version 2.9.2
# Website https://kernel-panik.me/tool/kprm/
# Run by Carlos Luna from C:\Users\Carlos Luna\Downloads
# Computer Name: 1989AH
# OS: Windows 7 X64 (7601) Service Pack 1
# Number of passes: 1
- Checked options -
~ Registry Backup
~ Delete Tools
~ Restore System Settings
~ UAC Restore
~ Delete Restore Points
~ Create Restore Point
~ Delete Quarantines
- Create Registry Backup -
~ [OK] Hive C:\Windows\System32\config\SOFTWARE backed up
~ [OK] Hive C:\Users\Carlos Luna\NTUSER.dat backed up
[OK] Registry Backup: C:\KPRM\backup\2021-11-12-02-14-18
- Delete Tools -
## AdwCleaner
[OK] C:\Users\Carlos Luna\Desktop\AdwCleaner.exe deleted
[OK] C:\AdwCleaner deleted
## FRST
[OK] C:\Users\Carlos Luna\Desktop\FRST-OlderVersion deleted
[OK] C:\Users\Carlos Luna\Desktop\FRST64.exe deleted
[OK] C:\FRST deleted
- Restore System Settings -
[OK] Reset WinSock
[OK] FLUSHDNS
[OK] Hide Hidden file.
[OK] Show Extensions for known file types
[OK] Hide protected operating system files
- Restore UAC -
[OK] Set EnableLUA with default (1) value
[OK] Set ConsentPromptBehaviorAdmin with default (5) value
[OK] Set ConsentPromptBehaviorUser with default (3) value
[OK] Set EnableInstallerDetection with default (0) value
[OK] Set EnableSecureUIAPaths with default (1) value
[OK] Set EnableUIADesktopToggle with default (0) value
[OK] Set EnableVirtualization with default (1) value
[OK] Set FilterAdministratorToken with default (0) value
[OK] Set PromptOnSecureDesktop with default (1) value
[OK] Set ValidateAdminCodeSignatures with default (0) value
- Clear Restore Points -
~ [OK] RP named Scheduled Checkpoint created at 11/07/2021 21:27:13 deleted
~ [OK] RP named Restore Point Created by FRST created at 11/08/2021 00:24:46 deleted
~ [OK] RP named Restore Point Created by FRST created at 11/09/2021 01:09:52 deleted
~ [OK] RP named Restore Point Created by FRST created at 11/11/2021 01:06:55 deleted
[OK] All system restore points have been successfully deleted
- Create Restore Point -
[OK] System Restore Point created
- Display System Restore Point -
~ RP named KpRm created at 11/12/2021 07:15:09
-- KPRM finished in 80.06s --
