[SOLVED] Having issues with my pc
This is the log that it opens after the restart, to be specific a window appears and was the one that it opens when you do right-click "Open with" choose a program, I pick the Notepad and it just show that install and amazing amount of things on the register key and system files.
It is normal?
Avira log:
2021-11-12 02:19:57.097 Log opened. (Time zone: UTC-05:00)
2021-11-12 02:19:57.097 Setup version: Inno Setup version 6.0.5 (u)
2021-11-12 02:19:57.097 Original Setup EXE: C:\Users\Carlos Luna\AppData\Local\Temp\.CR.1686\40c6d1d5-6393-4feb-8ac4-452a73a9c6bb\avira_system_speedup.exe
2021-11-12 02:19:57.097 Setup command line: /SL5="$1A021C,28870622,916480,C:\Users\Carlos Luna\AppData\Local\Temp\.CR.1686\40c6d1d5-6393-4feb-8ac4-452a73a9c6bb\avira_system_speedup.exe" /install /OTC= /EMAIL= /LOG=C:\Users\Carlos Luna\AppData\Local\Temp\avira_system_speedup_setup_20211112021714.log /VERYSILENT /SUPPRESSMSGBOXES /LANGUAGE=en-us /NOSTART /NORESTART /bundle=sptl1 /download=phpws /Spotlight
2021-11-12 02:19:57.097 Windows version: 6.1.7601 SP1 (NT platform: Yes)
2021-11-12 02:19:57.097 64-bit Windows: Yes
2021-11-12 02:19:57.097 Processor architecture: x64
2021-11-12 02:19:57.097 User privileges: Administrative
2021-11-12 02:19:57.097 Administrative install mode: Yes
2021-11-12 02:19:57.097 Install mode root key: HKEY_LOCAL_MACHINE
2021-11-12 02:19:57.097 64-bit install mode: No
2021-11-12 02:19:57.107 Created temporary directory: C:\Users\CARLOS~1\AppData\Local\Temp\is-7E6O5.tmp
2021-11-12 02:19:57.107 -- DLL function import --
2021-11-12 02:19:57.107 Function name: GetLocalTime
2021-11-12 02:19:57.107 DLL name: {sys}\Kernel32.dll
2021-11-12 02:19:57.107 Dest DLL name: C:\Windows\system32\Kernel32.dll
2021-11-12 02:19:57.107 Importing the DLL function.
2021-11-12 02:19:57.107 Successfully imported the DLL function. Delay loaded? No
2021-11-12 02:19:57.107 Function name: SystemTimeToFileTime
2021-11-12 02:19:57.107 Function name: OutputDebugStringW
2021-11-12 02:19:57.107 DLL name: {sys}\kernel32.dll
2021-11-12 02:19:57.107 Dest DLL name: C:\Windows\system32\kernel32.dll
2021-11-12 02:19:57.107 Function name: PeekMessageA
2021-11-12 02:19:57.107 DLL name: {sys}\user32.dll
2021-11-12 02:19:57.107 Dest DLL name: C:\Windows\system32\user32.dll
2021-11-12 02:19:57.107 Function name: TranslateMessage
2021-11-12 02:19:57.107 Function name: DispatchMessageA
2021-11-12 02:19:57.107 Function name: CreateProcessW
2021-11-12 02:19:57.107 Function name: GetExitCodeProcess
2021-11-12 02:19:57.107 Function name: WaitForSingleObject
2021-11-12 02:19:57.107 Function name: CloseHandle
2021-11-12 02:19:57.107 Function name: ExitProcess
2021-11-12 02:19:57.107 Function name: WTSGetActiveConsoleSessionId
2021-11-12 02:19:57.107 Function name: ProcessIdToSessionId
2021-11-12 02:19:57.107 Function name: FindWindowExW
2021-11-12 02:19:57.107 DLL name: {sys}\User32.dll
2021-11-12 02:19:57.107 Dest DLL name: C:\Windows\system32\User32.dll
2021-11-12 02:19:57.107 Function name: SendMessageTimeoutW
2021-11-12 02:19:57.107 Function name: GetLastError
2021-11-12 02:19:57.107 Function name: CreateToolhelp32Snapshot
2021-11-12 02:19:57.107 Function name: Process32FirstW
2021-11-12 02:19:57.107 Function name: Process32NextW
2021-11-12 02:19:57.107 Function name: OpenProcess
2021-11-12 02:19:57.107 Function name: TerminateProcess
2021-11-12 02:19:57.107 Function name: GetModuleFileNameExW
2021-11-12 02:19:57.107 DLL name: {sys}\psapi.dll
2021-11-12 02:19:57.107 Dest DLL name: C:\Windows\system32\psapi.dll
2021-11-12 02:19:57.107 Function name: QueryFullProcessImageNameW
2021-11-12 02:19:57.107 Successfully imported the DLL function. Delay loaded? Yes
2021-11-12 02:19:57.107 Function name: FindWindowByClass
2021-11-12 02:19:57.107 DLL name: files:Avira.Optimizer.Common.Native.Library.dll
2021-11-12 02:19:57.107 Extracting temporary file: C:\Users\CARLOS~1\AppData\Local\Temp\is-7E6O5.tmp\Avira.Optimizer.Common.Native.Library.dll
2021-11-12 02:19:57.217 Dest DLL name: C:\Users\CARLOS~1\AppData\Local\Temp\is-7E6O5.tmp\Avira.Optimizer.Common.Native.Library.dll
2021-11-12 02:19:57.217 Importing the DLL function.
2021-11-12 02:19:57.497 Successfully imported the DLL function. Delay loaded? No
2021-11-12 02:19:57.497 -- DLL function import --
2021-11-12 02:19:57.497 Function name: FindWindowByClass
2021-11-12 02:19:57.497 DLL name: uninstall:{app}\Avira.Optimizer.Common.Native.Library.dll
2021-11-12 02:19:57.497 Skipping.
2021-11-12 02:19:57.497 Function name: FindWindowByClassAndTitle
2021-11-12 02:19:57.497 DLL name: files:Avira.Optimizer.Common.Native.Library.dll
2021-11-12 02:19:57.497 Dest DLL name: C:\Users\CARLOS~1\AppData\Local\Temp\is-7E6O5.tmp\Avira.Optimizer.Common.Native.Library.dll
2021-11-12 02:19:57.497 Importing the DLL function.
2021-11-12 02:19:57.497 Function name: SHFileOperationW
2021-11-12 02:19:57.497 DLL name: {sys}\shell32.dll
2021-11-12 02:19:57.497 Dest DLL name: C:\Windows\system32\shell32.dll
2021-11-12 02:19:57.497 Function name: SHGetSpecialFolderPathW
2021-11-12 02:19:57.497 Function name: MoveFileExW
2021-11-12 02:19:57.497 DLL name: {sys}\Kernel32.dll
2021-11-12 02:19:57.497 Dest DLL name: C:\Windows\system32\Kernel32.dll
2021-11-12 02:19:57.497 Function name: SendEvent
2021-11-12 02:19:57.497 Function name: CommonV1SetApplication
2021-11-12 02:19:57.497 Function name: CreateScheduledTask
2021-11-12 02:19:57.497 Function name: InstallLauncher
2021-11-12 02:19:57.497 Function name: RemoveScheduledTask
2021-11-12 02:19:57.497 Function name: GetUnixTimeUTC
2021-11-12 02:19:57.497 DLL name: files:Avira.OptimizerHostClientLibrary.dll
2021-11-12 02:19:57.497 Extracting temporary file: C:\Users\CARLOS~1\AppData\Local\Temp\is-7E6O5.tmp\Avira.OptimizerHostClientLibrary.dll
2021-11-12 02:19:57.527 Dest DLL name: C:\Users\CARLOS~1\AppData\Local\Temp\is-7E6O5.tmp\Avira.OptimizerHostClientLibrary.dll
2021-11-12 02:19:57.527 Importing the DLL function.
2021-11-12 02:19:57.527 Successfully imported the DLL function. Delay loaded? Yes
2021-11-12 02:19:57.527 -- DLL function import --
2021-11-12 02:19:57.527 Function name: IsOptimizerHostReady
2021-11-12 02:19:57.527 DLL name: files:Avira.OptimizerHostClientLibrary.dll
2021-11-12 02:19:57.527 Function name: AddTask
2021-11-12 02:19:57.527 Function name: AddTaskEx
2021-11-12 02:19:57.527 Function name: RemoveTask
2021-11-12 02:19:57.527 DLL name: uninstall:{app}\Avira.OptimizerHostClientLibrary.dll
2021-11-12 02:19:57.527 Skipping.
2021-11-12 02:19:57.527 Function name: StartProcess
2021-11-12 02:19:58.467 Starting the installation process.
2021-11-12 02:19:58.497 Creating directory: C:\Program Files (x86)\Avira\System Speedup
2021-11-12 02:19:58.497 Creating directory: C:\ProgramData\Avira\SystemSpeedup
2021-11-12 02:19:58.497 Creating directory: C:\ProgramData\Avira\SystemSpeedup\Logs
2021-11-12 02:19:58.507 Setting permissions on directory: C:\ProgramData\Avira\SystemSpeedup\Logs
2021-11-12 02:19:58.507 Directory for uninstall files: C:\Program Files (x86)\Avira\System Speedup
2021-11-12 02:19:58.507 Creating new uninstall log: C:\Program Files (x86)\Avira\System Speedup\unins000.dat
2021-11-12 02:19:58.507 -- File entry --
2021-11-12 02:19:58.507 Dest filename: C:\Program Files (x86)\Avira\System Speedup\unins000.exe
2021-11-12 02:19:58.507 Time stamp of our file: 2021-11-12 02:19:57.017
2021-11-12 02:19:58.507 Installing the file.
2021-11-12 02:19:58.507 Successfully installed the file.
2021-11-12 02:19:58.507 Dest filename: C:\Program Files (x86)\Avira\System Speedup\Avira.SystemSpeedup.Service.exe
2021-11-12 02:19:58.507 Time stamp of our file: 2021-10-14 09:36:12.000
2021-11-12 02:19:58.517 Successfully installed the file.
2021-11-12 02:19:58.517 -- File entry --
2021-11-12 02:19:58.517 Dest filename: C:\Program Files (x86)\Avira\System Speedup\Avira.SystemSpeedup.Service.exe.config
2021-11-12 02:19:58.517 Time stamp of our file: 2021-10-14 09:28:54.000
2021-11-12 02:19:58.517 Installing the file.
2021-11-12 02:19:58.537 Successfully installed the file.
2021-11-12 02:19:58.537 -- File entry --
2021-11-12 02:19:58.537 Dest filename: C:\Program Files (x86)\Avira\System Speedup\Avira.SystemSpeedup.Maintenance.exe
2021-11-12 02:19:58.537 Time stamp of our file: 2021-10-14 09:36:02.000
2021-11-12 02:19:58.537 Installing the file.
2021-11-12 02:19:58.547 Successfully installed the file.
2021-11-12 02:19:58.547 -- File entry --
2021-11-12 02:19:58.547 Dest filename: C:\Program Files (x86)\Avira\System Speedup\Avira.SystemSpeedup.Maintenance.exe.config
2021-11-12 02:19:58.547 Time stamp of our file: 2021-10-14 09:28:54.000
2021-11-12 02:19:58.547 Installing the file.
2021-11-12 02:19:58.597 Successfully installed the file.
2021-11-12 02:19:58.597 -- File entry --
2021-11-12 02:19:58.597 Dest filename: C:\Program Files (x86)\Avira\System Speedup\Avira.SystemSpeedup.Core.Common.Starter.exe
2021-11-12 02:19:58.597 Time stamp of our file: 2021-10-14 09:35:54.000
2021-11-12 02:19:58.597 Installing the file.
2021-11-12 02:19:58.597 Dest filename: C:\Program Files (x86)\Avira\System Speedup\Avira.SystemSpeedup.Core.Common.Starter.exe.config
2021-11-12 02:19:58.597 Time stamp of our file: 2021-10-14 09:28:52.000
2021-11-12 02:19:58.617 Successfully installed the file.
2021-11-12 02:19:58.617 -- File entry --
2021-11-12 02:19:58.617 Dest filename: C:\Program Files (x86)\Avira\System Speedup\Avira.SystemSpeedup.UI.Application.exe
2021-11-12 02:19:58.617 Time stamp of our file: 2021-10-14 09:36:16.000
2021-11-12 02:19:58.617 Installing the file.
2021-11-12 02:19:58.617 Dest filename: C:\Program Files (x86)\Avira\System Speedup\Avira.SystemSpeedup.UI.Application.exe.config
2021-11-12 02:19:58.617 Time stamp of our file: 2021-10-14 09:28:54.000
2021-11-12 02:19:58.617 Dest filename: C:\Program Files (x86)\Avira\System Speedup\Avira.SystemSpeedup.Core.DeviceOptimization.exe
2021-11-12 02:19:58.617 Time stamp of our file: 2021-10-14 09:35:58.000
2021-11-12 02:19:58.627 Successfully installed the file.
2021-11-12 02:19:58.627 -- File entry --
2021-11-12 02:19:58.627 Dest filename: C:\Program Files (x86)\Avira\System Speedup\Avira.SystemSpeedup.Core.DeviceOptimization.exe.config
2021-11-12 02:19:58.627 Time stamp of our file: 2021-10-14 09:28:50.000
2021-11-12 02:19:58.627 Installing the file.
2021-11-12 02:19:58.657 Successfully installed the file.
2021-11-12 02:19:58.657 -- File entry --
2021-11-12 02:19:58.657 Dest filename: C:\Program Files (x86)\Avira\System Speedup\Avira.Optimizer.Common.ErrorReporter.exe
2021-11-12 02:19:58.657 Time stamp of our file: 2021-10-14 09:32:58.000
2021-11-12 02:19:58.657 Installing the file.
2021-11-12 02:19:58.657 Dest filename: C:\Program Files (x86)\Avira\System Speedup\Avira.Optimizer.Common.ErrorReporter.exe.config
2021-11-12 02:19:58.657 Time stamp of our file: 2021-10-14 09:28:50.000
2021-11-12 02:19:58.667 Successfully installed the file.
2021-11-12 02:19:58.667 -- File entry --
2021-11-12 02:19:58.667 Dest filename: C:\Program Files (x86)\Avira\System Speedup\Avira.Optimizer.Common.Updater.exe
2021-11-12 02:19:58.667 Time stamp of our file: 2021-10-14 09:33:02.000
2021-11-12 02:19:58.667 Installing the file.
2021-11-12 02:19:58.667 Dest filename: C:\Program Files (x86)\Avira\System Speedup\AARKRFA.dll
2021-11-12 02:19:58.667 Time stamp of our file: 2021-10-14 09:37:20.000
2021-11-12 02:19:58.697 Successfully installed the file.
2021-11-12 02:19:58.697 -- File entry --
2021-11-12 02:19:58.697 Dest filename: C:\Program Files (x86)\Avira\System Speedup\Avira.Acp.Common.dll
2021-11-12 02:19:58.697 Time stamp of our file: 2021-03-26 10:44:26.000
2021-11-12 02:19:58.697 Installing the file.
2021-11-12 02:19:58.707 Successfully installed the file.
2021-11-12 02:19:58.707 -- File entry --
2021-11-12 02:19:58.707 Dest filename: C:\Program Files (x86)\Avira\System Speedup\Avira.Acp.dll
2021-11-12 02:19:58.707 Time stamp of our file: 2021-10-14 09:37:14.000
2021-11-12 02:19:58.707 Installing the file.
2021-11-12 02:19:58.717 Successfully installed the file.
2021-11-12 02:19:58.717 -- File entry --
2021-11-12 02:19:58.717 Dest filename: C:\Program Files (x86)\Avira\System Speedup\Avira.Acp.Resources.dll
2021-11-12 02:19:58.717 Time stamp of our file: 2021-03-26 10:44:26.000
2021-11-12 02:19:58.717 Installing the file.
2021-11-12 02:19:58.717 Dest filename: C:\Program Files (x86)\Avira\System Speedup\Avira.Optimizer.Common.Native.dll
2021-11-12 02:19:58.717 Time stamp of our file: 2021-10-14 09:32:46.000
2021-11-12 02:19:58.727 Successfully installed the file.
2021-11-12 02:19:58.727 -- File entry --
2021-11-12 02:19:58.727 Dest filename: C:\Program Files (x86)\Avira\System Speedup\Avira.Optimizer.Common.Native.Library.dll
2021-11-12 02:19:58.727 Time stamp of our file: 2021-10-14 09:32:50.000
2021-11-12 02:19:58.727 Installing the file.
2021-11-12 02:19:58.867 Successfully installed the file.
2021-11-12 02:19:58.867 -- File entry --
2021-11-12 02:19:58.867 Dest filename: C:\Program Files (x86)\Avira\System Speedup\Avira.Optimizer.Common.Tools.dll
2021-11-12 02:19:58.867 Time stamp of our file: 2021-10-14 09:32:54.000
2021-11-12 02:19:58.867 Installing the file.
2021-11-12 02:19:58.877 Successfully installed the file.
2021-11-12 02:19:58.877 -- File entry --
2021-11-12 02:19:58.877 Dest filename: C:\Program Files (x86)\Avira\System Speedup\Avira.SystemSpeedup.Core.Client.Services.dll
2021-11-12 02:19:58.877 Time stamp of our file: 2021-10-14 09:33:06.000
2021-11-12 02:19:58.877 Installing the file.
2021-11-12 02:19:58.877 Dest filename: C:\Program Files (x86)\Avira\System Speedup\Avira.SystemSpeedup.Core.Common.Library.dll
2021-11-12 02:19:58.877 Time stamp of our file: 2021-10-14 09:33:10.000
2021-11-12 02:19:59.067 Successfully installed the file.
2021-11-12 02:19:59.067 -- File entry --
2021-11-12 02:19:59.067 Dest filename: C:\Program Files (x86)\Avira\System Speedup\Avira.SystemSpeedup.Core.Common.UserShell.dll
2021-11-12 02:19:59.068 Time stamp of our file: 2021-10-14 09:33:12.000
2021-11-12 02:19:59.068 Installing the file.
2021-11-12 02:19:59.073 Successfully installed the file.
2021-11-12 02:19:59.073 -- File entry --
2021-11-12 02:19:59.073 Dest filename: C:\Program Files (x86)\Avira\System Speedup\Avira.SystemSpeedup.Core.Defrag.dll
2021-11-12 02:19:59.073 Time stamp of our file: 2021-10-14 09:33:16.000
2021-11-12 02:19:59.073 Installing the file.
2021-11-12 02:19:59.110 Successfully installed the file.
2021-11-12 02:19:59.110 -- File entry --
2021-11-12 02:19:59.110 Dest filename: C:\Program Files (x86)\Avira\System Speedup\Avira.SystemSpeedup.Core.Host.Database.dll
2021-11-12 02:19:59.110 Time stamp of our file: 2021-10-14 09:33:20.000
2021-11-12 02:19:59.110 Installing the file.
2021-11-12 02:19:59.113 Successfully installed the file.
2021-11-12 02:19:59.113 -- File entry --
2021-11-12 02:19:59.113 Dest filename: C:\Program Files (x86)\Avira\System Speedup\Avira.SystemSpeedup.Core.Host.Interfaces.dll
2021-11-12 02:19:59.113 Time stamp of our file: 2021-10-14 09:33:24.000
2021-11-12 02:19:59.113 Installing the file.
2021-11-12 02:19:59.121 Successfully installed the file.
2021-11-12 02:19:59.121 -- File entry --
2021-11-12 02:19:59.121 Dest filename: C:\Program Files (x86)\Avira\System Speedup\Avira.SystemSpeedup.Core.Host.Services.dll
2021-11-12 02:19:59.121 Time stamp of our file: 2021-10-14 09:33:28.000
2021-11-12 02:19:59.121 Installing the file.
2021-11-12 02:19:59.256 Successfully installed the file.
2021-11-12 02:19:59.256 -- File entry --
2021-11-12 02:19:59.256 Dest filename: C:\Program Files (x86)\Avira\System Speedup\Avira.SystemSpeedup.Core.Services.Interface.dll
2021-11-12 02:19:59.256 Time stamp of our file: 2021-10-14 09:33:32.000
2021-11-12 02:19:59.256 Installing the file.
2021-11-12 02:19:59.261 Successfully installed the file.
2021-11-12 02:19:59.261 -- File entry --
2021-11-12 02:19:59.261 Dest filename: C:\Program Files (x86)\Avira\System Speedup\Avira.SystemSpeedup.Infrastructure.Common.dll
2021-11-12 02:19:59.261 Time stamp of our file: 2021-10-14 09:33:36.000
2021-11-12 02:19:59.261 Installing the file.
2021-11-12 02:19:59.262 Successfully installed the file.
2021-11-12 02:19:59.262 -- File entry --
2021-11-12 02:19:59.262 Dest filename: C:\Program Files (x86)\Avira\System Speedup\Avira.SystemSpeedup.Infrastructure.Communication.Pipes.dll
2021-11-12 02:19:59.262 Time stamp of our file: 2021-10-14 09:33:38.000
2021-11-12 02:19:59.262 Installing the file.
2021-11-12 02:19:59.280 Successfully installed the file.
2021-11-12 02:19:59.280 -- File entry --
2021-11-12 02:19:59.280 Dest filename: C:\Program Files (x86)\Avira\System Speedup\Avira.SystemSpeedup.Infrastructure.Database.dll
2021-11-12 02:19:59.281 Time stamp of our file: 2021-10-14 09:33:42.000
2021-11-12 02:19:59.281 Installing the file.
2021-11-12 02:19:59.282 Successfully installed the file.
2021-11-12 02:19:59.282 -- File entry --
2021-11-12 02:19:59.282 Dest filename: C:\Program Files (x86)\Avira\System Speedup\Avira.SystemSpeedup.Infrastructure.Exception.dll
2021-11-12 02:19:59.283 Time stamp of our file: 2021-10-14 09:33:46.000
2021-11-12 02:19:59.283 Installing the file.
2021-11-12 02:19:59.286 Successfully installed the file.
2021-11-12 02:19:59.286 -- File entry --
2021-11-12 02:19:59.286 Dest filename: C:\Program Files (x86)\Avira\System Speedup\Avira.SystemSpeedup.Infrastructure.Presentation.ViewModel.dll
2021-11-12 02:19:59.286 Time stamp of our file: 2021-10-14 09:33:50.000
2021-11-12 02:19:59.286 Installing the file.
2021-11-12 02:19:59.287 Successfully installed the file.
2021-11-12 02:19:59.287 -- File entry --
2021-11-12 02:19:59.287 Dest filename: C:\Program Files (x86)\Avira\System Speedup\Avira.SystemSpeedup.Infrastructure.Wpf.dll
2021-11-12 02:19:59.287 Time stamp of our file: 2021-10-14 09:33:54.000
2021-11-12 02:19:59.287 Installing the file.
2021-11-12 02:19:59.316 Successfully installed the file.
2021-11-12 02:19:59.316 -- File entry --
2021-11-12 02:19:59.316 Dest filename: C:\Program Files (x86)\Avira\System Speedup\Avira.SystemSpeedup.UI.Common.dll
2021-11-12 02:19:59.316 Time stamp of our file: 2021-10-14 09:33:56.000
2021-11-12 02:19:59.316 Installing the file.
2021-11-12 02:19:59.320 Successfully installed the file.
2021-11-12 02:19:59.320 -- File entry --
2021-11-12 02:19:59.320 Dest filename: C:\Program Files (x86)\Avira\System Speedup\Avira.SystemSpeedup.UI.Resources.dll
2021-11-12 02:19:59.320 Time stamp of our file: 2021-10-14 09:34:00.000
2021-11-12 02:19:59.320 Installing the file.
2021-11-12 02:19:59.371 Successfully installed the file.
2021-11-12 02:19:59.371 -- File entry --
2021-11-12 02:19:59.371 Dest filename: C:\Program Files (x86)\Avira\System Speedup\Avira.SystemSpeedup.UI.ShellExtension.dll
2021-11-12 02:19:59.371 Time stamp of our file: 2021-10-14 09:34:04.000
2021-11-12 02:19:59.371 Installing the file.
2021-11-12 02:19:59.375 Successfully installed the file.
2021-11-12 02:19:59.375 -- File entry --
2021-11-12 02:19:59.375 Dest filename: C:\Program Files (x86)\Avira\System Speedup\Avira.SystemSpeedup.UI.Styles.Standard.dll
2021-11-12 02:19:59.375 Time stamp of our file: 2021-10-14 09:34:10.000
2021-11-12 02:19:59.375 Installing the file.
2021-11-12 02:19:59.485 Successfully installed the file.
2021-11-12 02:19:59.486 -- File entry --
2021-11-12 02:19:59.486 Dest filename: C:\Program Files (x86)\Avira\System Speedup\Avira.SystemSpeedup.UI.ViewModels.dll
2021-11-12 02:19:59.486 Time stamp of our file: 2021-10-14 09:34:12.000
2021-11-12 02:19:59.486 Installing the file.
2021-11-12 02:19:59.505 Successfully installed the file.
2021-11-12 02:19:59.505 -- File entry --
2021-11-12 02:19:59.506 Dest filename: C:\Program Files (x86)\Avira\System Speedup\Avira.SystemSpeedup.UI.Views.dll
2021-11-12 02:19:59.506 Time stamp of our file: 2021-10-14 09:34:16.000
2021-11-12 02:19:59.506 Installing the file.
2021-11-12 02:19:59.537 Successfully installed the file.
2021-11-12 02:19:59.537 -- File entry --
2021-11-12 02:19:59.537 Dest filename: C:\Program Files (x86)\Avira\System Speedup\CommonServiceLocator.dll
2021-11-12 02:19:59.538 Time stamp of our file: 2021-10-14 09:37:24.000
2021-11-12 02:19:59.538 Installing the file.
2021-11-12 02:19:59.539 Successfully installed the file.
2021-11-12 02:19:59.539 -- File entry --
2021-11-12 02:19:59.539 Dest filename: C:\Program Files (x86)\Avira\System Speedup\Dia2Lib.dll
2021-11-12 02:19:59.539 Time stamp of our file: 2018-02-21 22:52:20.000
2021-11-12 02:19:59.539 Installing the file.
2021-11-12 02:19:59.546 Successfully installed the file.
2021-11-12 02:19:59.546 -- File entry --
2021-11-12 02:19:59.546 Dest filename: C:\Program Files (x86)\Avira\System Speedup\Microsoft.Diagnostics.FastSerialization.dll
2021-11-12 02:19:59.546 Time stamp of our file: 2019-08-09 18:42:04.000
2021-11-12 02:19:59.546 Installing the file.
2021-11-12 02:19:59.548 Successfully installed the file.
2021-11-12 02:19:59.548 -- File entry --
2021-11-12 02:19:59.549 Dest filename: C:\Program Files (x86)\Avira\System Speedup\Microsoft.Diagnostics.Tracing.TraceEvent.dll
2021-11-12 02:19:59.549 Time stamp of our file: 2019-08-09 18:42:56.000
2021-11-12 02:19:59.549 Installing the file.
2021-11-12 02:19:59.612 Successfully installed the file.
2021-11-12 02:19:59.612 -- File entry --
2021-11-12 02:19:59.612 Dest filename: C:\Program Files (x86)\Avira\System Speedup\Microsoft.Expression.Drawing.dll
2021-11-12 02:19:59.612 Time stamp of our file: 2021-10-14 09:36:38.000
2021-11-12 02:19:59.612 Installing the file.
2021-11-12 02:19:59.617 Successfully installed the file.
2021-11-12 02:19:59.617 -- File entry --
2021-11-12 02:19:59.617 Dest filename: C:\Program Files (x86)\Avira\System Speedup\Microsoft.Expression.Interactions.dll
2021-11-12 02:19:59.617 Time stamp of our file: 2021-10-14 09:36:42.000
2021-11-12 02:19:59.617 Installing the file.
2021-11-12 02:19:59.626 Successfully installed the file.
2021-11-12 02:19:59.626 -- File entry --
2021-11-12 02:19:59.626 Dest filename: C:\Program Files (x86)\Avira\System Speedup\Microsoft.Practices.Prism.dll
2021-11-12 02:19:59.626 Time stamp of our file: 2012-02-14 12:16:26.000
2021-11-12 02:19:59.626 Installing the file.
2021-11-12 02:19:59.631 Successfully installed the file.
2021-11-12 02:19:59.631 -- File entry --
2021-11-12 02:19:59.631 Dest filename: C:\Program Files (x86)\Avira\System Speedup\Microsoft.Practices.Prism.Interactivity.dll
2021-11-12 02:19:59.631 Time stamp of our file: 2012-02-14 12:16:26.000
2021-11-12 02:19:59.631 Installing the file.
2021-11-12 02:19:59.633 Successfully installed the file.
2021-11-12 02:19:59.633 -- File entry --
2021-11-12 02:19:59.633 Dest filename: C:\Program Files (x86)\Avira\System Speedup\Microsoft.Practices.Prism.UnityExtensions.dll
2021-11-12 02:19:59.633 Time stamp of our file: 2012-02-14 12:16:28.000
2021-11-12 02:19:59.633 Installing the file.
2021-11-12 02:19:59.634 Successfully installed the file.
2021-11-12 02:19:59.634 -- File entry --
2021-11-12 02:19:59.634 Dest filename: C:\Program Files (x86)\Avira\System Speedup\Microsoft.Practices.Unity.Configuration.dll
2021-11-12 02:19:59.634 Time stamp of our file: 2012-08-02 13:50:32.000
2021-11-12 02:19:59.634 Installing the file.
2021-11-12 02:19:59.638 Successfully installed the file.
2021-11-12 02:19:59.638 -- File entry --
2021-11-12 02:19:59.638 Dest filename: C:\Program Files (x86)\Avira\System Speedup\Microsoft.Practices.Unity.dll
2021-11-12 02:19:59.638 Time stamp of our file: 2012-08-02 13:50:32.000
2021-11-12 02:19:59.638 Installing the file.
2021-11-12 02:19:59.643 Successfully installed the file.
2021-11-12 02:19:59.643 -- File entry --
2021-11-12 02:19:59.643 Dest filename: C:\Program Files (x86)\Avira\System Speedup\Microsoft.Win32.TaskScheduler.dll
2021-11-12 02:19:59.643 Time stamp of our file: 2021-10-14 09:36:36.000
2021-11-12 02:19:59.643 Installing the file.
2021-11-12 02:19:59.654 Successfully installed the file.
2021-11-12 02:19:59.654 -- File entry --
2021-11-12 02:19:59.654 Dest filename: C:\Program Files (x86)\Avira\System Speedup\Microsoft.Windows.Shell.dll
2021-11-12 02:19:59.654 Time stamp of our file: 2021-10-14 09:37:10.000
2021-11-12 02:19:59.654 Installing the file.
2021-11-12 02:19:59.660 Successfully installed the file.
2021-11-12 02:19:59.660 -- File entry --
2021-11-12 02:19:59.660 Dest filename: C:\Program Files (x86)\Avira\System Speedup\Newtonsoft.Json.dll
2021-11-12 02:19:59.660 Time stamp of our file: 2021-10-14 09:36:46.000
2021-11-12 02:19:59.660 Installing the file.
2021-11-12 02:19:59.683 Successfully installed the file.
2021-11-12 02:19:59.684 -- File entry --
2021-11-12 02:19:59.684 Dest filename: C:\Program Files (x86)\Avira\System Speedup\OSExtensions.dll
2021-11-12 02:19:59.684 Time stamp of our file: 2019-01-03 09:24:20.000
2021-11-12 02:19:59.684 Installing the file.
2021-11-12 02:19:59.686 Successfully installed the file.
2021-11-12 02:19:59.686 -- File entry --
2021-11-12 02:19:59.686 Dest filename: C:\Program Files (x86)\Avira\System Speedup\ServiceStack.Text.dll
2021-11-12 02:19:59.686 Time stamp of our file: 2021-10-14 09:37:02.000
2021-11-12 02:19:59.686 Installing the file.
2021-11-12 02:19:59.693 Successfully installed the file.
2021-11-12 02:19:59.693 -- File entry --
2021-11-12 02:19:59.693 Dest filename: C:\Program Files (x86)\Avira\System Speedup\SharpRaven.dll
2021-11-12 02:19:59.693 Time stamp of our file: 2021-10-14 09:36:48.000
2021-11-12 02:19:59.693 Installing the file.
2021-11-12 02:19:59.697 Successfully installed the file.
2021-11-12 02:19:59.697 -- File entry --
2021-11-12 02:19:59.697 Dest filename: C:\Program Files (x86)\Avira\System Speedup\SharpShell.dll
2021-11-12 02:19:59.697 Time stamp of our file: 2021-10-14 09:37:06.000
2021-11-12 02:19:59.697 Installing the file.
2021-11-12 02:19:59.734 Successfully installed the file.
2021-11-12 02:19:59.734 -- File entry --
2021-11-12 02:19:59.734 Dest filename: C:\Program Files (x86)\Avira\System Speedup\System.Data.SQLite.dll
2021-11-12 02:19:59.734 Time stamp of our file: 2021-10-14 09:36:52.000
2021-11-12 02:19:59.734 Installing the file.
2021-11-12 02:19:59.746 Successfully installed the file.
2021-11-12 02:19:59.746 -- File entry --
2021-11-12 02:19:59.746 Dest filename: C:\Program Files (x86)\Avira\System Speedup\System.ObjectModel.dll
2021-11-12 02:19:59.746 Time stamp of our file: 2019-06-17 14:14:40.000
2021-11-12 02:19:59.746 Installing the file.
2021-11-12 02:19:59.748 Successfully installed the file.
2021-11-12 02:19:59.748 -- File entry --
2021-11-12 02:19:59.748 Dest filename: C:\Program Files (x86)\Avira\System Speedup\System.Runtime.dll
2021-11-12 02:19:59.748 Time stamp of our file: 2019-06-17 14:14:36.000
2021-11-12 02:19:59.748 Installing the file.
2021-11-12 02:19:59.749 Successfully installed the file.
2021-11-12 02:19:59.749 -- File entry --
2021-11-12 02:19:59.749 Dest filename: C:\Program Files (x86)\Avira\System Speedup\System.Runtime.InteropServices.WindowsRuntime.dll
2021-11-12 02:19:59.750 Time stamp of our file: 2019-06-17 14:14:42.000
2021-11-12 02:19:59.750 Installing the file.
2021-11-12 02:19:59.760 Successfully installed the file.
2021-11-12 02:19:59.760 -- File entry --
2021-11-12 02:19:59.760 Dest filename: C:\Program Files (x86)\Avira\System Speedup\System.Runtime.WindowsRuntime.dll
2021-11-12 02:19:59.760 Time stamp of our file: 2019-06-17 14:14:40.000
2021-11-12 02:19:59.760 Installing the file.
2021-11-12 02:19:59.766 Successfully installed the file.
2021-11-12 02:19:59.766 -- File entry --
2021-11-12 02:19:59.766 Dest filename: C:\Program Files (x86)\Avira\System Speedup\System.ValueTuple.dll
2021-11-12 02:19:59.766 Time stamp of our file: 2018-05-15 13:29:52.000
2021-11-12 02:19:59.766 Installing the file.
2021-11-12 02:19:59.769 Successfully installed the file.
2021-11-12 02:19:59.769 -- File entry --
2021-11-12 02:19:59.769 Dest filename: C:\Program Files (x86)\Avira\System Speedup\System.Windows.Interactivity.dll
2021-11-12 02:19:59.769 Time stamp of our file: 2021-10-14 09:36:56.000
2021-11-12 02:19:59.769 Installing the file.
2021-11-12 02:19:59.771 Successfully installed the file.
2021-11-12 02:19:59.771 -- File entry --
2021-11-12 02:19:59.771 Dest filename: C:\Program Files (x86)\Avira\System Speedup\ToggleSwitch.dll
2021-11-12 02:19:59.772 Time stamp of our file: 2021-10-14 09:36:58.000
2021-11-12 02:19:59.772 Installing the file.
2021-11-12 02:19:59.778 Successfully installed the file.
2021-11-12 02:19:59.778 -- File entry --
2021-11-12 02:19:59.778 Dest filename: C:\Program Files (x86)\Avira\System Speedup\TraceReloggerLib.dll
2021-11-12 02:19:59.778 Time stamp of our file: 2018-02-21 22:52:20.000
2021-11-12 02:19:59.778 Installing the file.
2021-11-12 02:19:59.779 Successfully installed the file.
2021-11-12 02:19:59.780 -- File entry --
2021-11-12 02:19:59.780 Dest filename: C:\Program Files (x86)\Avira\System Speedup\x64\SQLite.Interop.dll
2021-11-12 02:19:59.780 Time stamp of our file: 2021-10-14 09:36:28.000
2021-11-12 02:19:59.780 Installing the file.
2021-11-12 02:19:59.780 Creating directory: C:\Program Files (x86)\Avira\System Speedup\x64
2021-11-12 02:19:59.839 Successfully installed the file.
2021-11-12 02:19:59.839 -- File entry --
2021-11-12 02:19:59.839 Dest filename: C:\Program Files (x86)\Avira\System Speedup\x86\KernelTraceControl.dll
2021-11-12 02:19:59.839 Time stamp of our file: 2018-02-21 22:52:20.000
2021-11-12 02:19:59.839 Installing the file.
2021-11-12 02:19:59.839 Creating directory: C:\Program Files (x86)\Avira\System Speedup\x86
2021-11-12 02:19:59.852 Successfully installed the file.
2021-11-12 02:19:59.852 -- File entry --
2021-11-12 02:19:59.852 Dest filename: C:\Program Files (x86)\Avira\System Speedup\x86\KernelTraceControl.Win61.dll
2021-11-12 02:19:59.852 Time stamp of our file: 2018-02-21 22:52:20.000
2021-11-12 02:19:59.852 Installing the file.
2021-11-12 02:19:59.859 Successfully installed the file.
2021-11-12 02:19:59.859 -- File entry --
2021-11-12 02:19:59.859 Dest filename: C:\Program Files (x86)\Avira\System Speedup\x86\msdia140.dll
2021-11-12 02:19:59.859 Time stamp of our file: 2018-02-21 22:52:20.000
2021-11-12 02:19:59.859 Installing the file.
2021-11-12 02:19:59.893 Successfully installed the file.
2021-11-12 02:19:59.893 -- File entry --
2021-11-12 02:19:59.893 Dest filename: C:\Program Files (x86)\Avira\System Speedup\x86\SQLite.Interop.dll
2021-11-12 02:19:59.893 Time stamp of our file: 2021-10-14 09:36:24.000
2021-11-12 02:19:59.893 Installing the file.
2021-11-12 02:19:59.941 Successfully installed the file.
2021-11-12 02:19:59.941 -- File entry --
2021-11-12 02:19:59.941 Dest filename: C:\Program Files (x86)\Avira\System Speedup\amd64\KernelTraceControl.dll
2021-11-12 02:19:59.941 Time stamp of our file: 2018-02-21 22:52:20.000
2021-11-12 02:19:59.941 Installing the file.
2021-11-12 02:19:59.941 Creating directory: C:\Program Files (x86)\Avira\System Speedup\amd64
2021-11-12 02:19:59.950 Successfully installed the file.
2021-11-12 02:19:59.950 -- File entry --
2021-11-12 02:19:59.950 Dest filename: C:\Program Files (x86)\Avira\System Speedup\amd64\msdia140.dll
2021-11-12 02:19:59.950 Time stamp of our file: 2018-02-21 22:52:20.000
2021-11-12 02:19:59.950 Installing the file.
2021-11-12 02:19:59.991 Successfully installed the file.
2021-11-12 02:19:59.992 -- File entry --
2021-11-12 02:19:59.992 Dest filename: C:\Program Files (x86)\Avira\System Speedup\sdf\AnalyzeDisk.sdf
2021-11-12 02:19:59.992 Time stamp of our file: 2021-10-14 09:29:06.000
2021-11-12 02:19:59.992 Installing the file.
2021-11-12 02:19:59.992 Creating directory: C:\Program Files (x86)\Avira\System Speedup\sdf
2021-11-12 02:20:00.014 Successfully installed the file.
2021-11-12 02:20:00.014 -- File entry --
2021-11-12 02:20:00.014 Dest filename: C:\Program Files (x86)\Avira\System Speedup\sdf\battery.sdf
2021-11-12 02:20:00.014 Time stamp of our file: 2021-10-14 09:29:06.000
2021-11-12 02:20:00.014 Installing the file.
2021-11-12 02:20:00.015 Successfully installed the file.
2021-11-12 02:20:00.015 -- File entry --
2021-11-12 02:20:00.015 Dest filename: C:\Program Files (x86)\Avira\System Speedup\sdf\BoostProfiles.sdf
2021-11-12 02:20:00.015 Time stamp of our file: 2021-10-14 09:29:06.000
2021-11-12 02:20:00.015 Installing the file.
2021-11-12 02:20:00.016 Successfully installed the file.
2021-11-12 02:20:00.016 -- File entry --
2021-11-12 02:20:00.016 Dest filename: C:\Program Files (x86)\Avira\System Speedup\sdf\BootDisk.sdf
2021-11-12 02:20:00.016 Time stamp of our file: 2021-10-14 09:29:06.000
2021-11-12 02:20:00.016 Installing the file.
2021-11-12 02:20:00.036 Successfully installed the file.
2021-11-12 02:20:00.036 -- File entry --
2021-11-12 02:20:00.036 Dest filename: C:\Program Files (x86)\Avira\System Speedup\sdf\BootOptimizer.sdf
2021-11-12 02:20:00.036 Time stamp of our file: 2021-10-14 09:29:06.000
2021-11-12 02:20:00.036 Installing the file.
2021-11-12 02:20:00.059 Successfully installed the file.
2021-11-12 02:20:00.059 -- File entry --
2021-11-12 02:20:00.059 Dest filename: C:\Program Files (x86)\Avira\System Speedup\sdf\DataDisk.sdf
2021-11-12 02:20:00.059 Time stamp of our file: 2021-10-14 09:29:06.000
2021-11-12 02:20:00.059 Installing the file.
2021-11-12 02:20:00.060 Successfully installed the file.
2021-11-12 02:20:00.060 -- File entry --
2021-11-12 02:20:00.060 Dest filename: C:\Program Files (x86)\Avira\System Speedup\sdf\DefragDisk.sdf
2021-11-12 02:20:00.060 Time stamp of our file: 2021-10-14 09:29:06.000
2021-11-12 02:20:00.060 Installing the file.
2021-11-12 02:20:00.060 Dest filename: C:\Program Files (x86)\Avira\System Speedup\sdf\exclusions.sdf
2021-11-12 02:20:00.061 Successfully installed the file.
2021-11-12 02:20:00.061 -- File entry --
2021-11-12 02:20:00.061 Dest filename: C:\Program Files (x86)\Avira\System Speedup\sdf\FlashDisk.sdf
2021-11-12 02:20:00.061 Time stamp of our file: 2021-10-14 09:29:06.000
2021-11-12 02:20:00.061 Installing the file.
2021-11-12 02:20:00.062 Successfully installed the file.
2021-11-12 02:20:00.062 -- File entry --
2021-11-12 02:20:00.062 Dest filename: C:\Program Files (x86)\Avira\System Speedup\sdf\mapping.sdf
2021-11-12 02:20:00.062 Time stamp of our file: 2021-10-14 09:29:06.000
2021-11-12 02:20:00.062 Installing the file.
2021-11-12 02:20:00.063 Successfully installed the file.
2021-11-12 02:20:00.063 -- File entry --
2021-11-12 02:20:00.063 Dest filename: C:\Program Files (x86)\Avira\System Speedup\sdf\OneClickFixMapping.sdf
2021-11-12 02:20:00.063 Time stamp of our file: 2021-10-14 09:29:06.000
2021-11-12 02:20:00.063 Installing the file.
2021-11-12 02:20:00.063 Dest filename: C:\Program Files (x86)\Avira\System Speedup\sdf\PrivacyCleaner.sdf
2021-11-12 02:20:00.072 Successfully installed the file.
2021-11-12 02:20:00.072 -- File entry --
2021-11-12 02:20:00.072 Dest filename: C:\Program Files (x86)\Avira\System Speedup\sdf\PrivacyCleanerDefinitionApps.sdf
2021-11-12 02:20:00.072 Time stamp of our file: 2021-10-14 09:29:06.000
2021-11-12 02:20:00.072 Installing the file.
2021-11-12 02:20:00.073 Successfully installed the file.
2021-11-12 02:20:00.073 -- File entry --
2021-11-12 02:20:00.073 Dest filename: C:\Program Files (x86)\Avira\System Speedup\sdf\PrivacyCookies.sdf
2021-11-12 02:20:00.073 Time stamp of our file: 2021-10-14 09:29:06.000
2021-11-12 02:20:00.073 Installing the file.
2021-11-12 02:20:00.201 Successfully installed the file.
2021-11-12 02:20:00.201 -- File entry --
2021-11-12 02:20:00.201 Dest filename: C:\Program Files (x86)\Avira\System Speedup\sdf\PrivacyMappings.sdf
2021-11-12 02:20:00.201 Time stamp of our file: 2021-10-14 09:29:06.000
2021-11-12 02:20:00.201 Installing the file.
2021-11-12 02:20:00.202 Successfully installed the file.
2021-11-12 02:20:00.202 -- File entry --
2021-11-12 02:20:00.202 Dest filename: C:\Program Files (x86)\Avira\System Speedup\sdf\quickScanLocations.sdf
2021-11-12 02:20:00.202 Time stamp of our file: 2021-10-14 09:29:06.000
2021-11-12 02:20:00.202 Installing the file.
2021-11-12 02:20:00.206 Successfully installed the file.
2021-11-12 02:20:00.206 -- File entry --
2021-11-12 02:20:00.206 Dest filename: C:\Program Files (x86)\Avira\System Speedup\sdf\registry.sdf
2021-11-12 02:20:00.206 Time stamp of our file: 2021-10-14 09:29:06.000
2021-11-12 02:20:00.206 Installing the file.
2021-11-12 02:20:00.210 Successfully installed the file.
2021-11-12 02:20:00.210 -- File entry --
2021-11-12 02:20:00.210 Dest filename: C:\Program Files (x86)\Avira\System Speedup\sdf\reg_cleaner.sdf
2021-11-12 02:20:00.210 Time stamp of our file: 2021-10-14 09:29:06.000
2021-11-12 02:20:00.210 Installing the file.
2021-11-12 02:20:00.212 Successfully installed the file.
2021-11-12 02:20:00.212 -- File entry --
2021-11-12 02:20:00.212 Dest filename: C:\Program Files (x86)\Avira\System Speedup\sdf\scanner.sdf
2021-11-12 02:20:00.212 Time stamp of our file: 2021-10-14 09:29:06.000
2021-11-12 02:20:00.212 Installing the file.
2021-11-12 02:20:00.220 Successfully installed the file.
2021-11-12 02:20:00.220 -- File entry --
2021-11-12 02:20:00.220 Dest filename: C:\Program Files (x86)\Avira\System Speedup\sdf\Settings.sdf
2021-11-12 02:20:00.220 Time stamp of our file: 2021-10-14 09:29:06.000
2021-11-12 02:20:00.220 Installing the file.
2021-11-12 02:20:00.222 Successfully installed the file.
2021-11-12 02:20:00.222 -- File entry --
2021-11-12 02:20:00.222 Dest filename: C:\Program Files (x86)\Avira\System Speedup\sdf\SystemDisk.sdf
2021-11-12 02:20:00.222 Time stamp of our file: 2021-10-14 09:29:06.000
2021-11-12 02:20:00.222 Installing the file.
2021-11-12 02:20:00.223 Successfully installed the file.
2021-11-12 02:20:00.223 -- File entry --
2021-11-12 02:20:00.223 Dest filename: C:\Program Files (x86)\Avira\System Speedup\sdf\Winapp2.sdf
2021-11-12 02:20:00.223 Time stamp of our file: 2021-10-14 09:29:06.000
2021-11-12 02:20:00.223 Installing the file.
2021-11-12 02:20:00.248 Successfully installed the file.
2021-11-12 02:20:00.249 -- File entry --
2021-11-12 02:20:00.249 Dest filename: C:\Program Files (x86)\Avira\System Speedup\sdf\winapp2.ini
2021-11-12 02:20:00.249 Time stamp of our file: 2021-10-14 09:28:50.000
2021-11-12 02:20:00.249 Installing the file.
2021-11-12 02:20:00.260 Successfully installed the file.
2021-11-12 02:20:00.260 -- File entry --
2021-11-12 02:20:00.261 Dest filename: C:\Program Files (x86)\Avira\System Speedup\msvcp120.dll
2021-11-12 02:20:00.261 Time stamp of our file: 2021-10-14 09:28:50.000
2021-11-12 02:20:00.261 Installing the file.
2021-11-12 02:20:00.272 Successfully installed the file.
2021-11-12 02:20:00.272 -- File entry --
2021-11-12 02:20:00.272 Dest filename: C:\Program Files (x86)\Avira\System Speedup\msvcr120.dll
2021-11-12 02:20:00.273 Time stamp of our file: 2021-10-14 09:28:50.000
2021-11-12 02:20:00.273 Installing the file.
2021-11-12 02:20:00.305 Successfully installed the file.
2021-11-12 02:20:00.305 -- File entry --
2021-11-12 02:20:00.305 Dest filename: C:\Windows\Fonts\KievitOffcPro.ttf
2021-11-12 02:20:00.305 Time stamp of our file: 2021-10-14 09:28:48.000
2021-11-12 02:20:00.305 Installing the file.
2021-11-12 02:20:00.312 Successfully installed the file.
2021-11-12 02:20:00.312 Registering file as a font ("Kievit Offc Pro (TrueType)")
2021-11-12 02:20:00.428 -- File entry --
2021-11-12 02:20:00.428 Dest filename: C:\Program Files (x86)\Avira\System Speedup\Avira.SystemSpeedup.Tools.exe
2021-11-12 02:20:00.428 Time stamp of our file: 2021-10-14 09:37:18.000
2021-11-12 02:20:00.428 Installing the file.
2021-11-12 02:20:00.688 Successfully installed the file.
2021-11-12 02:20:00.688 -- File entry --
2021-11-12 02:20:00.688 Dest filename: C:\Program Files (x86)\Avira\System Speedup\de-DE\Avira.SystemSpeedup.UI.Resources.resources.dll
2021-11-12 02:20:00.688 Time stamp of our file: 2021-10-14 09:34:20.000
2021-11-12 02:20:00.688 Installing the file.
2021-11-12 02:20:00.688 Creating directory: C:\Program Files (x86)\Avira\System Speedup\de-DE
2021-11-12 02:20:00.698 Successfully installed the file.
2021-11-12 02:20:00.698 -- File entry --
2021-11-12 02:20:00.698 Dest filename: C:\Program Files (x86)\Avira\System Speedup\de-DE\Avira.SystemSpeedup.UI.ShellExtension.resources.dll
2021-11-12 02:20:00.698 Time stamp of our file: 2021-10-14 09:34:24.000
2021-11-12 02:20:00.698 Installing the file.
2021-11-12 02:20:00.698 Dest filename: C:\Program Files (x86)\Avira\System Speedup\en-US\Avira.SystemSpeedup.UI.Resources.resources.dll
2021-11-12 02:20:00.698 Time stamp of our file: 2021-10-14 09:34:28.000
2021-11-12 02:20:00.698 Creating directory: C:\Program Files (x86)\Avira\System Speedup\en-US
2021-11-12 02:20:00.708 Successfully installed the file.
2021-11-12 02:20:00.708 -- File entry --
2021-11-12 02:20:00.708 Dest filename: C:\Program Files (x86)\Avira\System Speedup\en-US\Avira.SystemSpeedup.UI.ShellExtension.resources.dll
2021-11-12 02:20:00.708 Time stamp of our file: 2021-10-14 09:34:34.000
2021-11-12 02:20:00.708 Installing the file.
2021-11-12 02:20:00.708 Dest filename: C:\Program Files (x86)\Avira\System Speedup\es-ES\Avira.SystemSpeedup.UI.Resources.resources.dll
2021-11-12 02:20:00.708 Time stamp of our file: 2021-10-14 09:34:38.000
2021-11-12 02:20:00.708 Creating directory: C:\Program Files (x86)\Avira\System Speedup\es-ES
2021-11-12 02:20:00.728 Successfully installed the file.
2021-11-12 02:20:00.728 -- File entry --
2021-11-12 02:20:00.728 Dest filename: C:\Program Files (x86)\Avira\System Speedup\es-ES\Avira.SystemSpeedup.UI.ShellExtension.resources.dll
2021-11-12 02:20:00.728 Time stamp of our file: 2021-10-14 09:34:40.000
2021-11-12 02:20:00.728 Installing the file.
2021-11-12 02:20:00.728 Dest filename: C:\Program Files (x86)\Avira\System Speedup\fr-FR\Avira.SystemSpeedup.UI.Resources.resources.dll
2021-11-12 02:20:00.728 Time stamp of our file: 2021-10-14 09:34:44.000
2021-11-12 02:20:00.728 Creating directory: C:\Program Files (x86)\Avira\System Speedup\fr-FR
2021-11-12 02:20:00.738 Successfully installed the file.
2021-11-12 02:20:00.738 -- File entry --
2021-11-12 02:20:00.738 Dest filename: C:\Program Files (x86)\Avira\System Speedup\fr-FR\Avira.SystemSpeedup.UI.ShellExtension.resources.dll
2021-11-12 02:20:00.738 Time stamp of our file: 2021-10-14 09:34:48.000
2021-11-12 02:20:00.738 Installing the file.
2021-11-12 02:20:00.738 Dest filename: C:\Program Files (x86)\Avira\System Speedup\it-IT\Avira.SystemSpeedup.UI.Resources.resources.dll
2021-11-12 02:20:00.738 Time stamp of our file: 2021-10-14 09:34:54.000
2021-11-12 02:20:00.738 Creating directory: C:\Program Files (x86)\Avira\System Speedup\it-IT
2021-11-12 02:20:00.748 Successfully installed the file.
2021-11-12 02:20:00.748 -- File entry --
2021-11-12 02:20:00.748 Dest filename: C:\Program Files (x86)\Avira\System Speedup\it-IT\Avira.SystemSpeedup.UI.ShellExtension.resources.dll
2021-11-12 02:20:00.748 Time stamp of our file: 2021-10-14 09:35:00.000
2021-11-12 02:20:00.748 Installing the file.
2021-11-12 02:20:00.748 Dest filename: C:\Program Files (x86)\Avira\System Speedup\nl-NL\Avira.SystemSpeedup.UI.Resources.resources.dll
2021-11-12 02:20:00.748 Time stamp of our file: 2021-10-14 09:35:10.000
2021-11-12 02:20:00.748 Creating directory: C:\Program Files (x86)\Avira\System Speedup\nl-NL
2021-11-12 02:20:00.748 Dest filename: C:\Program Files (x86)\Avira\System Speedup\nl-NL\Avira.SystemSpeedup.UI.ShellExtension.resources.dll
2021-11-12 02:20:00.748 Time stamp of our file: 2021-10-14 09:35:14.000
2021-11-12 02:20:00.758 Successfully installed the file.
2021-11-12 02:20:00.758 -- File entry --
2021-11-12 02:20:00.758 Dest filename: C:\Program Files (x86)\Avira\System Speedup\pt-BR\Avira.SystemSpeedup.UI.Resources.resources.dll
2021-11-12 02:20:00.758 Time stamp of our file: 2021-10-14 09:35:20.000
2021-11-12 02:20:00.758 Installing the file.
2021-11-12 02:20:00.758 Creating directory: C:\Program Files (x86)\Avira\System Speedup\pt-BR
2021-11-12 02:20:00.768 Successfully installed the file.
2021-11-12 02:20:00.768 -- File entry --
2021-11-12 02:20:00.768 Dest filename: C:\Program Files (x86)\Avira\System Speedup\pt-BR\Avira.SystemSpeedup.UI.ShellExtension.resources.dll
2021-11-12 02:20:00.768 Time stamp of our file: 2021-10-14 09:35:24.000
2021-11-12 02:20:00.768 Installing the file.
2021-11-12 02:20:00.768 Dest filename: C:\Program Files (x86)\Avira\System Speedup\ru-RU\Avira.SystemSpeedup.UI.Resources.resources.dll
2021-11-12 02:20:00.768 Time stamp of our file: 2021-10-14 09:35:28.000
2021-11-12 02:20:00.768 Creating directory: C:\Program Files (x86)\Avira\System Speedup\ru-RU
2021-11-12 02:20:00.778 Successfully installed the file.
2021-11-12 02:20:00.778 -- File entry --
2021-11-12 02:20:00.778 Dest filename: C:\Program Files (x86)\Avira\System Speedup\ru-RU\Avira.SystemSpeedup.UI.ShellExtension.resources.dll
2021-11-12 02:20:00.778 Time stamp of our file: 2021-10-14 09:35:30.000
2021-11-12 02:20:00.778 Installing the file.
2021-11-12 02:20:00.788 Successfully installed the file.
2021-11-12 02:20:00.788 -- File entry --
2021-11-12 02:20:00.788 Dest filename: C:\Program Files (x86)\Avira\System Speedup\zh-CN\Avira.SystemSpeedup.UI.Resources.resources.dll
2021-11-12 02:20:00.788 Time stamp of our file: 2021-10-14 09:35:40.000
2021-11-12 02:20:00.788 Installing the file.
2021-11-12 02:20:00.788 Creating directory: C:\Program Files (x86)\Avira\System Speedup\zh-CN
2021-11-12 02:20:00.788 Dest filename: C:\Program Files (x86)\Avira\System Speedup\zh-CN\Avira.SystemSpeedup.UI.ShellExtension.resources.dll
2021-11-12 02:20:00.788 Time stamp of our file: 2021-10-14 09:35:44.000
2021-11-12 02:20:00.798 Successfully installed the file.
2021-11-12 02:20:00.798 -- File entry --
2021-11-12 02:20:00.798 Dest filename: C:\Program Files (x86)\Avira\System Speedup\zh-TW\Avira.SystemSpeedup.UI.Resources.resources.dll
2021-11-12 02:20:00.798 Time stamp of our file: 2021-10-14 09:35:48.000
2021-11-12 02:20:00.798 Installing the file.
2021-11-12 02:20:00.798 Creating directory: C:\Program Files (x86)\Avira\System Speedup\zh-TW
2021-11-12 02:20:00.798 Dest filename: C:\Program Files (x86)\Avira\System Speedup\zh-TW\Avira.SystemSpeedup.UI.ShellExtension.resources.dll
2021-11-12 02:20:00.798 Time stamp of our file: 2021-10-14 09:35:50.000
2021-11-12 02:20:00.798 Dest filename: C:\Program Files (x86)\Avira\System Speedup\ja-JP\Avira.SystemSpeedup.UI.Resources.resources.dll
2021-11-12 02:20:00.798 Time stamp of our file: 2021-10-14 09:35:04.000
2021-11-12 02:20:00.798 Creating directory: C:\Program Files (x86)\Avira\System Speedup\ja-JP
2021-11-12 02:20:00.808 Successfully installed the file.
2021-11-12 02:20:00.808 -- File entry --
2021-11-12 02:20:00.808 Dest filename: C:\Program Files (x86)\Avira\System Speedup\ja-JP\Avira.SystemSpeedup.UI.ShellExtension.resources.dll
2021-11-12 02:20:00.808 Time stamp of our file: 2021-10-14 09:35:06.000
2021-11-12 02:20:00.808 Installing the file.
2021-11-12 02:20:00.808 Dest filename: C:\Program Files (x86)\Avira\System Speedup\tr-TR\Avira.SystemSpeedup.UI.Resources.resources.dll
2021-11-12 02:20:00.808 Time stamp of our file: 2021-10-14 09:35:34.000
2021-11-12 02:20:00.808 Creating directory: C:\Program Files (x86)\Avira\System Speedup\tr-TR
2021-11-12 02:20:00.818 Successfully installed the file.
2021-11-12 02:20:00.818 -- File entry --
2021-11-12 02:20:00.818 Dest filename: C:\Program Files (x86)\Avira\System Speedup\tr-TR\Avira.SystemSpeedup.UI.ShellExtension.resources.dll
2021-11-12 02:20:00.818 Time stamp of our file: 2021-10-14 09:35:36.000
2021-11-12 02:20:00.818 Installing the file.
2021-11-12 02:20:00.828 Successfully installed the file.
2021-11-12 02:20:00.828 -- File entry --
2021-11-12 02:20:00.828 Dest filename: C:\Program Files (x86)\Avira\System Speedup\pl-PL\Avira.SystemSpeedup.UI.Resources.resources.dll
2021-11-12 02:20:00.828 Time stamp of our file: 2021-10-14 09:35:18.000
2021-11-12 02:20:00.828 Installing the file.
2021-11-12 02:20:00.828 Creating directory: C:\Program Files (x86)\Avira\System Speedup\pl-PL
2021-11-12 02:20:00.838 Successfully installed the file.
2021-11-12 02:20:00.838 -- File entry --
2021-11-12 02:20:00.838 Dest filename: C:\Program Files (x86)\Avira\System Speedup\id-ID\Avira.SystemSpeedup.UI.Resources.resources.dll
2021-11-12 02:20:00.838 Time stamp of our file: 2021-10-14 09:34:52.000
2021-11-12 02:20:00.838 Installing the file.
2021-11-12 02:20:00.838 Creating directory: C:\Program Files (x86)\Avira\System Speedup\id-ID
2021-11-12 02:20:00.858 Successfully installed the file.
2021-11-12 02:20:00.858 -- File entry --
2021-11-12 02:20:00.858 Dest filename: C:\Program Files (x86)\Avira\System Speedup\Help\iph_en-US.json
2021-11-12 02:20:00.858 Time stamp of our file: 2021-10-14 09:28:48.000
2021-11-12 02:20:00.858 Installing the file.
2021-11-12 02:20:00.858 Creating directory: C:\Program Files (x86)\Avira\System Speedup\Help
2021-11-12 02:20:00.858 Dest filename: C:\Program Files (x86)\Avira\System Speedup\Help\iph_position.json
2021-11-12 02:20:00.858 Dest filename: C:\Program Files (x86)\Avira\System Speedup\Third-Party Attributions.txt
2021-11-12 02:20:00.858 Dest filename: C:\Program Files (x86)\Avira\System Speedup\AviraConnectSetup.exe
2021-11-12 02:20:00.858 Time stamp of our file: 2021-10-14 09:37:32.000
2021-11-12 02:20:00.888 Successfully installed the file.
2021-11-12 02:20:00.888 -- File entry --
2021-11-12 02:20:00.888 Dest filename: C:\Users\CARLOS~1\AppData\Local\Temp\is-7E6O5.tmp\Avira_Optimizer_Host.exe
2021-11-12 02:20:00.888 Time stamp of our file: 2021-10-14 09:29:02.000
2021-11-12 02:20:00.888 Installing the file.
2021-11-12 02:20:00.928 Successfully installed the file.
2021-11-12 02:20:00.928 -- File entry --
2021-11-12 02:20:00.928 Dest filename: C:\Program Files (x86)\Avira\System Speedup\Avira.OptimizerHostClientLibrary.dll
2021-11-12 02:20:00.928 Time stamp of our file: 2021-10-14 09:29:04.000
2021-11-12 02:20:00.928 Installing the file.
2021-11-12 02:20:00.968 Successfully installed the file.
2021-11-12 02:20:00.968 -- File entry --
2021-11-12 02:20:00.968 Dest filename: C:\Program Files (x86)\Avira\System Speedup\Avira.SystemSpeedup.UI.Popup.exe
2021-11-12 02:20:00.968 Time stamp of our file: 2021-10-14 09:36:20.000
2021-11-12 02:20:00.968 Installing the file.
2021-11-12 02:20:00.978 Successfully installed the file.
2021-11-12 02:20:00.978 -- File entry --
2021-11-12 02:20:00.978 Dest filename: C:\Program Files (x86)\Avira\System Speedup\Avira.SystemSpeedup.UI.Popup.exe.config
2021-11-12 02:20:00.978 Time stamp of our file: 2021-10-14 09:28:54.000
2021-11-12 02:20:00.978 Installing the file.
2021-11-12 02:20:00.998 Successfully installed the file.
2021-11-12 02:20:00.998 -- File entry --
2021-11-12 02:20:00.998 Dest filename: C:\Program Files (x86)\Avira\System Speedup\Avira.SystemSpeedup.RealTimeOptimizer.exe
2021-11-12 02:20:00.998 Time stamp of our file: 2021-10-14 09:36:08.000
2021-11-12 02:20:00.998 Installing the file.
2021-11-12 02:20:01.008 Successfully installed the file.
2021-11-12 02:20:01.008 -- File entry --
2021-11-12 02:20:01.008 Dest filename: C:\Program Files (x86)\Avira\System Speedup\Avira.SystemSpeedup.RealTime.Client.exe
2021-11-12 02:20:01.008 Time stamp of our file: 2021-10-14 09:36:06.000
2021-11-12 02:20:01.008 Installing the file.
2021-11-12 02:20:01.008 Dest filename: C:\Users\CARLOS~1\AppData\Local\Temp\is-7E6O5.tmp\avira_game_booster.exe
2021-11-12 02:20:01.008 Time stamp of our file: 2021-10-14 09:29:04.000
2021-11-12 02:20:01.138 Successfully installed the file.
2021-11-12 02:20:01.208 -- Registry entry --
2021-11-12 02:20:01.208 Key: HKEY_LOCAL_MACHINE\Software\Avira\Speedup\General
2021-11-12 02:20:01.208 Value name: Path
2021-11-12 02:20:01.208 Creating or opening the key.
2021-11-12 02:20:01.208 Creating or setting the value.
2021-11-12 02:20:01.208 Successfully created or set the value.
2021-11-12 02:21:04.068 Saving uninstall information.
2021-11-12 02:21:04.068 Writing uninstaller messages: C:\Program Files (x86)\Avira\System Speedup\unins000.msg
2021-11-12 02:21:04.068 Creating new uninstall key: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Uninstall\Avira System Speedup_is1
2021-11-12 02:21:04.068 Writing uninstall key values.
2021-11-12 02:21:04.068 Detected previous non administrative install? No
2021-11-12 02:21:04.068 Detected previous administrative 64-bit install? No
2021-11-12 02:21:04.238 Installation process succeeded.
2021-11-12 02:21:04.238 Need to restart Windows? No
2021-11-12 02:21:04.248 Deinitializing Setup.
2021-11-12 02:21:04.548 Log closed.
Hi, Carlosh.
The above log appeared after the installation? Are you getting a log every time you restart or it was just when you installed it? If yes, then I guess it's not something to worry about.
Yeah was after I install it and did a restart, the window now appears each time on startup, if is nothing to worry I think I can ignore, but l just find it a bit weird.
And well, once again thank you for all the help and hope to not come back any time soon, also I hope this helps others to look out for more professional help in this kind of issues.
Greetings and have a great day/night there, thanks!
Carlosh,
Although we removed FRST, I would like to see some logs to check what causes this issue. Which is weird indeed.
Download Farbar Recovery Scan Tool and save it to your desktop. --> IMPORTANT
Note: You need to run the version compatible with your system. If you are not sure which version applies to your system download both of them and try to run them. Only one of them will run on your system, that will be the right version.
If your antivirus software detects the tool as malicious, it’s safe to allow FRST to run. It is a false-positive detection.
If English is not your primary language, right click on FRST.exe/FRST64.exe and rename to FRSTEnglish.exe/FRST64English.exe
  • Double-click the FRST icon to run the tool. When the tool opens click Yes to disclaimer.
  • Press Scan button and wait for a while.
  • The scanner will produced two logs on your Desktop: FRST.txt and Addition.txt.
  • Please attach the content of these two logs in your next reply.
Something else, only if that is possible: could you please be a bit more active here, not just once every 24h? I know there is the time difference, plus the work and real life, but it would help to solve the problem faster. It already took rather long.
Just to let you know: here now it is 18:43.
Sorry for that, I'm active around this time because of the time zone, for me it was 11:43 am when you send the reply and usually use the PC a bit late in my time.
Still gonna try to send a bit more early the updates if I could of course, right now is 7:55.
FRST log:
Scan result of Farbar Recovery Scan Tool (FRST) (x64) Version: 09-11-2021
Ran by Carlos Luna (administrator) on 1989AH (ASUS All Series) (13-11-2021 19:40:36)
Running from C:\Users\Carlos Luna\Desktop
Loaded Profiles: Carlos Luna
Platform: Microsoft Windows 7 Ultimate Service Pack 1 (X64) Language: English (United States)
Default browser: Opera
Boot Mode: Normal
(Adobe Systems Incorporated -> Adobe Systems Incorporated) C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\UWA\AAM Updates Notifier.exe
(Adobe Systems, Incorporated -> Adobe Systems Incorporated) C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\armsvc.exe
(Arvato Digital Services Canada Inc -> arvato digital services llc) C:\Program Files (x86)\Common Files\Protexis\License Service\PsiService_2.exe
(Borislav Surbat -> MyCity) C:\Program Files (x86)\MCShield\MCShieldRTM.exe
(Intel Corporation - Intel® Management Engine Firmware -> Intel Corporation) C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL\jhi_service.exe
(Intel Corporation - Software and Firmware Products -> Intel Corporation) C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\LMS\LMS.exe
(Intel Corporation - Software and Firmware Products -> Intel Corporation) C:\Program Files (x86)\Intel\Intel(R) USB 3.0 eXtensible Host Controller Driver\Application\iusb3mon.exe
(Intel(R) Corporation) [File not signed] C:\Program Files\Intel\iCLS Client\HeciServer.exe
(Logitech -> Logitech Inc.) C:\Program Files\Logitech Gaming Software\LCore.exe
(Microsoft Windows Hardware Compatibility Publisher -> ) C:\Program Files (x86)\ASUS\AXSP\1.01.01\atkexComSvc.exe
(NVIDIA Corporation -> NVIDIA Corporation) C:\Program Files\NVIDIA Corporation\Display.NvContainer\NVDisplay.Container.exe <2>
(Opera Software AS -> Opera Software) C:\Users\Carlos Luna\AppData\Local\Programs\Opera GX\80.0.4170.91\opera_crashreporter.exe
(Opera Software AS -> Opera Software) C:\Users\Carlos Luna\AppData\Local\Programs\Opera GX\opera.exe <12>
(Realtek Semiconductor Corp. -> Realtek Semiconductor) C:\Program Files\Realtek\Audio\HDA\RtkNGUI64.exe
==================== Registry (Whitelisted) ===================
HKLM\...\Run: [RTHDVCPL] => C:\Program Files\Realtek\Audio\HDA\RtkNGUI64.exe [9068040 2016-11-09] (Realtek Semiconductor Corp. -> Realtek Semiconductor)
HKLM\...\Run: [Launch LCore] => C:\Program Files\Logitech Gaming Software\LCore.exe [8294680 2014-02-27] (Logitech -> Logitech Inc.)
HKLM\...\Run: [AdobeAAMUpdater-1.0] => C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\UWA\UpdaterStartupUtility.exe [446392 2012-04-04] (Adobe Systems Incorporated -> Adobe Systems Incorporated)
HKLM-x32\...\Run: [USB3MON] => C:\Program Files (x86)\Intel\Intel(R) USB 3.0 eXtensible Host Controller Driver\Application\iusb3mon.exe [292848 2013-04-26] (Intel Corporation - Software and Firmware Products -> Intel Corporation)
HKLM-x32\...\Run: [SwitchBoard] => C:\Program Files (x86)\Common Files\Adobe\SwitchBoard\SwitchBoard.exe [517096 2010-02-19] (Test Signing Certificate -> Adobe Systems Incorporated) [File not signed]
HKLM-x32\...\Run: [BCSSync] => C:\Program Files (x86)\Microsoft Office\Office14\BCSSync.exe [91520 2010-03-13] (Microsoft Corporation -> Microsoft Corporation)
HKLM-x32\...\Run: [AdobeCS6ServiceManager] => C:\Program Files (x86)\Common Files\Adobe\CS6ServiceManager\CS6ServiceManager.exe [1073312 2012-03-09] (Adobe Systems Incorporated -> Adobe Systems Incorporated)
HKU\S-1-5-21-2305226654-651215044-733858041-1000\...\Run: [Opera GX Browser Assistant] => C:\Users\Carlos Luna\AppData\Local\Programs\Opera GX\assistant\browser_assistant.exe [3291288 2021-02-01] (Opera Software AS -> Opera Software)
HKU\S-1-5-21-2305226654-651215044-733858041-1000\...\Run: [MCShield Monitor] => C:\Program Files (x86)\MCShield\mcshieldrtm.exe [650816 2014-04-11] (Borislav Surbat -> MyCity)
HKU\S-1-5-18\...\RunOnce: [SPReview] => C:\Windows\System32\SPReview\SPReview.exe [301568 2014-03-12] (Microsoft Windows -> Microsoft Corporation)
HKLM\Software\Microsoft\Active Setup\Installed Components: [{2D46B6DC-2207-486B-B523-A557E6D54B47}] -> C:\Windows\system32\cmd.exe /D /C start C:\Windows\system32\ie4uinit.exe -ClearIconCache
HKLM\Software\Wow6432Node\Microsoft\Active Setup\Installed Components: [{2D46B6DC-2207-486B-B523-A557E6D54B47}] -> C:\Windows\system32\cmd.exe /D /C start C:\Windows\system32\ie4uinit.exe -ClearIconCache
==================== Scheduled Tasks (Whitelisted) ============
Task: {1ADD0762-CC79-45E7-B15D-17E123E1BE18} - System32\Tasks\Microsoft_Hardware_Launch_ipoint_exe => C:\Program Files\Microsoft Mouse and Keyboard Center\ipoint.exe [2206488 2016-08-15] (Microsoft Corporation -> Microsoft Corporation)
Task: {293D7E12-004D-4520-8CE0-C06D21EFB4D1} - System32\Tasks\Opera GX scheduled Autoupdate 1634241479 => C:\Users\Carlos Luna\AppData\Local\Programs\Opera GX\launcher.exe [46162128 2021-11-04] (Opera Software AS -> Opera Software)
Task: {427624A0-6125-446F-84D9-BC6C71027E47} - System32\Tasks\Microsoft_Hardware_Launch_mousekeyboardcenter_exe => C:\Program Files\Microsoft Mouse and Keyboard Center\mousekeyboardcenter.exe [2225952 2016-08-15] (Microsoft Corporation -> Microsoft)
Task: {45A4D6E9-3EB8-4039-87C0-8EDD5A1CDC23} - System32\Tasks\Opera GX scheduled assistant Autoupdate 1634663272 => C:\Users\Carlos Luna\AppData\Local\Programs\Opera GX\launcher.exe [46162128 2021-11-04] (Opera Software AS -> Opera Software) -> --scheduledautoupdate --component-name=assistant --component-path="C:\Users\Carlos Luna\AppData\Local\Programs\Opera GX\assistant" $(Arg0)
Task: {4D109734-C672-4DAB-8E1C-0848709181B8} - System32\Tasks\Games\UpdateCheck_S-1-5-21-2305226654-651215044-733858041-1000 => {CA22F5B1-E06F-4A2B-94FC-21E87FE53781} C:\Windows\System32\gameux.dll [2746368 2012-12-07] (Microsoft Windows -> Microsoft Corporation)
Task: {5918D14A-68E3-4CFE-B21E-E1748D153440} - System32\Tasks\AdobeAAMUpdater-1.0-CarlosLuna-PC-Carlos Luna => C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\UWA\UpdaterStartupUtility.exe [446392 2012-04-04] (Adobe Systems Incorporated -> Adobe Systems Incorporated)
Task: {62A6C492-DB90-48A0-8729-0E9EE4C6AA60} - System32\Tasks\Adobe Acrobat Update Task => C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\AdobeARM.exe [998104 2015-07-07] (Adobe Systems, Incorporated -> Adobe Systems Incorporated)
Task: {6D10DDD6-E35A-4909-8989-1D5F095840CE} - System32\Tasks\CCleanerSkipUAC => C:\Program Files\CCleaner\CCleaner.exe [4624152 2014-06-24] (Piriform Ltd -> Piriform Ltd)
Task: {6FC4D6E7-AEFA-40A9-9BB7-93CA381DA6F7} - System32\Tasks\BlueStacksHelper_nxt => C:\Program Files\BlueStacks_nxt\BlueStacksHelper.exe [275136 2021-09-21] (Bluestack Systems, Inc -> BlueStack Systems, Inc.)
Task: {A3B005D3-E9D2-481C-8F83-C314EFE5F8A2} - System32\Tasks\Microsoft_MKC_Logon_Task_itype.exe => C:\Program Files\Microsoft Mouse and Keyboard Center\itype.exe [1665312 2016-08-15] (Microsoft Corporation -> Microsoft Corporation)
Task: {D0087371-BA7B-40D8-B082-1AA679E01EE7} - System32\Tasks\Microsoft_MKC_Logon_Task_ipoint.exe => C:\Program Files\Microsoft Mouse and Keyboard Center\ipoint.exe [2206488 2016-08-15] (Microsoft Corporation -> Microsoft Corporation)
Task: {D0C532E0-D1C5-4939-9A5D-20C1E65CEBAA} - System32\Tasks\Microsoft_Hardware_Launch_itype_exe => C:\Program Files\Microsoft Mouse and Keyboard Center\itype.exe [1665312 2016-08-15] (Microsoft Corporation -> Microsoft Corporation)
Task: {D685ED40-7570-4DD0-8D05-E36B8F49EF67} - System32\Tasks\BlueStacksHelper => C:\ProgramData\BlueStacks\Client\Helper\BlueStacksHelper.exe [754472 2021-04-05] (BlueStack Systems, Inc. -> BlueStack Systems, Inc.)
HKLM\SOFTWARE\Policies\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\3: <==== ATTENTION (Restriction - Zones)
Tcpip\Parameters: [DhcpNameServer] 200.48.225.130 200.48.225.146
Tcpip\..\Interfaces\{4F611090-1E2A-4C0B-B218-CB68014871BD}: [DhcpNameServer] 192.168.42.129
Tcpip\..\Interfaces\{577DA66F-E0C5-4726-8D88-1A73332085A9}: [DhcpNameServer] 200.48.225.146 200.48.225.130
Tcpip\..\Interfaces\{8D58557D-1DB6-4DD8-B77E-9A6F9972990A}: [DhcpNameServer] 192.168.42.129
Tcpip\..\Interfaces\{A27F8B15-26C0-4909-9700-9719E16C3A24}: [DhcpNameServer] 200.48.225.130 200.48.225.146
Tcpip\..\Interfaces\{B67BBEAF-70C7-4ED9-ADCE-DAC65DF532A9}: [DhcpNameServer] 200.48.225.130 200.48.225.146
Chrome:
CHR HKLM-x32\...\Chrome\Extension: [caljgklbbfbcjjanaijlacgncafpegll]
CHR HKLM-x32\...\Chrome\Extension: [ccbpbkebodcjkknkfkpmfeciinhidaeh]
CHR HKLM-x32\...\Chrome\Extension: [flliilndjeohchalpbbcdekjklbdgfkk]
Opera:
OPR Profile: C:\Users\Carlos Luna\AppData\Roaming\Opera Software\Opera Stable [2021-11-04]
OPR DefaultSuggestURL: Opera Stable -> hxxps://www.google.com/complete/search?client=opera&q={searchTerms}&ie={inputEncoding}&oe={outputEncoding}
OPR Extension: (Rich Hints Agent) - C:\Users\Carlos Luna\AppData\Roaming\Opera Software\Opera Stable\Extensions\enegjkbbakeegngfapepobipndnebkdk [2021-09-29]
OPR Extension: (Amazon Assistant Promotion) - C:\Users\Carlos Luna\AppData\Roaming\Opera Software\Opera Stable\Extensions\kbmoiomgmchbpihhdpabemajcbjpcijk [2021-09-28]
StartMenuInternet: (HKU\S-1-5-21-2305226654-651215044-733858041-1000) Opera GXStable - "C:\Users\Carlos Luna\AppData\Local\Programs\Opera GX\Launcher.exe"
==================== Services (Whitelisted) ===================
R2 AdobeARMservice; C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\armsvc.exe [82128 2015-07-07] (Adobe Systems, Incorporated -> Adobe Systems Incorporated)
R2 asComSvc; C:\Program Files (x86)\ASUS\AXSP\1.01.01\atkexComSvc.exe [927232 2012-10-29] (Microsoft Windows Hardware Compatibility Publisher -> )
S3 EasyAntiCheat; C:\Program Files (x86)\EasyAntiCheat\EasyAntiCheat.exe [781440 2019-03-11] (EasyAntiCheat Oy -> EasyAntiCheat Ltd)
S3 EpicOnlineServices; C:\Program Files (x86)\Epic Games\Epic Online Services\service\EpicOnlineServicesHost.exe [16029472 2021-10-23] (Epic Games Inc. -> Epic Games, Inc.)
S3 IDriverT; C:\Program Files (x86)\Common Files\InstallShield\Driver\11\Intel 32\IDriverT.exe [69632 2005-04-04] (Macrovision Corporation) [File not signed]
R2 Intel(R) Capability Licensing Service Interface; C:\Program Files\Intel\iCLS Client\HeciServer.exe [747520 2013-08-27] (Intel(R) Corporation) [File not signed]
S3 MBAMService; C:\Program Files\Malwarebytes\Anti-Malware\MBAMService.exe [7848632 2021-11-05] (Malwarebytes Inc -> Malwarebytes)
S3 npggsvc; C:\Windows\SysWOW64\GameMon.des [9473408 2021-01-18] (INCA Internet Co.,Ltd. -> INCA Internet Co., Ltd.)
R2 PSI_SVC_2; c:\Program Files (x86)\Common Files\Protexis\License Service\PsiService_2.exe [277360 2014-04-30] (Arvato Digital Services Canada Inc -> arvato digital services llc)
S3 SwitchBoard; C:\Program Files (x86)\Common Files\Adobe\SwitchBoard\SwitchBoard.exe [517096 2010-02-19] (Test Signing Certificate -> Adobe Systems Incorporated) [File not signed]
R2 WinDefend; C:\Program Files\Windows Defender\mpsvc.dll [1011712 2013-05-27] (Microsoft Windows -> Microsoft Corporation)
===================== Drivers (Whitelisted) ===================
R1 AsIO; C:\Windows\SysWow64\drivers\AsIO.sys [15232 2012-08-21] (ASUSTeK Computer Inc. -> )
R2 BlueStacksDrv_nxt; C:\Program Files\BlueStacks_nxt\BstkDrv_nxt.sys [320728 2021-09-20] (Bluestack Systems, Inc -> Bluestack System Inc.)
S3 dtlitescsibus; C:\Windows\System32\DRIVERS\dtlitescsibus.sys [30264 2016-09-22] (Disc Soft Ltd -> Disc Soft Ltd)
S3 dtliteusbbus; C:\Windows\System32\DRIVERS\dtliteusbbus.sys [47672 2016-09-22] (Disc Soft Ltd -> Disc Soft Ltd)
R3 LGSHidFilt; C:\Windows\System32\DRIVERS\LGSHidFilt.Sys [64280 2013-05-30] (Logitech -> Logitech Inc.)
R3 LGSUsbFilt; C:\Windows\System32\DRIVERS\LGSUsbFilt.Sys [41752 2013-05-30] (Logitech -> Logitech Inc.)
S3 MBAMSwissArmy; C:\Windows\System32\Drivers\mbamswissarmy.sys [248992 2021-11-05] (Malwarebytes Inc -> Malwarebytes)
R3 rtl819xpn64; C:\Windows\System32\DRIVERS\rtl819xp.sys [622624 2010-02-01] (Realtek Semiconductor Corp -> Realtek Semiconductor Corporation)
S3 RTTEAMPT; C:\Windows\System32\DRIVERS\RtTeam620.sys [58512 2012-07-03] (Realtek Semiconductor Corp -> Realtek Corporation)
S3 RvNetMP60; C:\Windows\System32\DRIVERS\RvNetMP60.sys [69048 2018-12-25] (Famatech Corp. -> Famatech Corp.)
S3 tap0901; C:\Windows\System32\DRIVERS\tap0901.sys [27136 2017-08-30] (OpenVPN Technologies, Inc. -> The OpenVPN Project)
R3 wovad_micarray; C:\Windows\System32\drivers\womic.sys [35696 2017-11-25] (Beijing Wolicheng Technology Co., Ltd. -> Windows (R) Win 7 DDK provider)
==================== Three months (created) (Whitelisted) =========
2021-11-13 19:40 - 2021-11-13 19:43 - 000013875 _____ C:\Users\Carlos Luna\Desktop\FRST.txt
2021-11-13 19:40 - 2021-11-13 19:42 - 000000000 ____D C:\FRST
2021-11-13 19:37 - 2021-11-13 19:37 - 002312192 _____ (Farbar) C:\Users\Carlos Luna\Desktop\FRST64.exe
2021-11-12 22:55 - 2021-11-12 22:55 - 000000000 ____D C:\Windows\system32\Tasks\Avira
2021-11-12 02:26 - 2021-11-12 02:26 - 000000000 ____D C:\Users\Public\Security Sessions
2021-11-12 02:24 - 2021-11-12 02:24 - 000000000 ____H C:\Windows\system32\Drivers\Msft_Kernel_avusbflt_01011.Wdf
2021-11-12 02:20 - 2021-11-12 02:20 - 000000000 ____D C:\Windows\SysWOW64\statReporter
2021-11-12 02:19 - 2021-11-12 22:55 - 000000000 ____D C:\ProgramData\Avira
2021-11-12 02:19 - 2021-11-12 02:21 - 000071218 _____ C:\Users\Carlos
2021-11-12 02:14 - 2021-11-12 02:15 - 000002463 _____ C:\Users\Carlos Luna\Documents\kprm-20211112021418.txt
2021-11-12 02:14 - 2021-11-12 02:14 - 000000000 ____D C:\KPRM
2021-11-09 21:11 - 2021-11-09 21:11 - 000000000 ____D C:\SFCFix
2021-11-05 20:05 - 2021-11-05 20:05 - 000248992 _____ (Malwarebytes) C:\Windows\system32\Drivers\mbamswissarmy.sys
2021-11-05 20:05 - 2021-11-05 20:05 - 000001960 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Malwarebytes.lnk
2021-11-05 20:05 - 2021-11-05 20:05 - 000001948 _____ C:\Users\Public\Desktop\Malwarebytes.lnk
2021-11-05 20:05 - 2021-11-05 20:05 - 000000000 ____D C:\Users\Carlos Luna\AppData\Local\mbam
2021-11-05 20:04 - 2021-11-05 20:04 - 000160176 _____ (Malwarebytes) C:\Windows\system32\Drivers\mbae64.sys
2021-11-05 20:04 - 2021-11-05 20:04 - 000000000 ____D C:\ProgramData\Malwarebytes
2021-11-05 20:04 - 2021-11-05 20:04 - 000000000 ____D C:\Program Files\Malwarebytes
2021-11-03 10:11 - 2021-11-05 20:06 - 000000000 ____D C:\Users\Carlos Luna\AppData\Local\CrashDumps
2021-11-03 01:03 - 2021-11-03 01:03 - 000000031 _____ C:\Users\Carlos Luna\Documents\recover network settings.txt
2021-11-02 19:01 - 2021-11-02 19:01 - 000005478 _____ C:\NetworkSettings.txt
2021-11-02 18:59 - 2021-11-02 19:00 - 000005478 _____ C:\Windows\system32\NetworkSettings.txt
2021-10-28 17:52 - 2021-11-13 19:32 - 000000000 ____D C:\ProgramData\MCShield
2021-10-28 17:52 - 2021-10-28 17:52 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\MCShield
2021-10-28 17:52 - 2021-10-28 17:52 - 000000000 ____D C:\Program Files (x86)\MCShield
2021-10-28 17:44 - 2021-10-28 17:45 - 002856736 _____ (MyCity) C:\Users\Carlos Luna\Desktop\MCShield-Setup.exe
2021-10-24 19:45 - 2021-11-09 21:11 - 000000000 ____D C:\Users\Carlos Luna\AppData\Local\niemiro
2021-10-24 01:04 - 2021-10-24 01:05 - 000000000 ____D C:\Users\Carlos Luna\Downloads\Windupdate
2021-10-24 00:28 - 2021-10-28 22:08 - 000000000 ____D C:\Users\Carlos Luna\AppData\Local\ElevatedDiagnostics
2021-10-23 23:01 - 2021-10-23 23:02 - 000000000 ____D C:\Program Files\TEST
2021-10-23 21:43 - 2021-10-23 21:43 - 000000000 ____D C:\Users\Carlos Luna\AppData\Local\EOSUserHelper
2021-10-23 21:42 - 2021-10-23 21:42 - 000000000 ____D C:\Users\Carlos Luna\AppData\Local\Epic Games
2021-10-23 21:30 - 2021-10-23 21:30 - 000000000 ____D C:\Users\Default\AppData\Local\Epic Games
2021-10-21 20:11 - 2021-10-21 20:19 - 000000000 ____D C:\Users\Carlos Luna\Downloads\backups
2021-10-21 18:01 - 2021-10-21 18:01 - 000000000 ____D C:\Users\Carlos Luna\AppData\Local\CEF
2021-10-19 12:08 - 2021-10-19 12:08 - 000004352 _____ C:\Windows\system32\Tasks\Opera GX scheduled assistant Autoupdate 1634663272
2021-10-14 14:58 - 2021-11-04 15:49 - 000004100 _____ C:\Windows\system32\Tasks\Opera GX scheduled Autoupdate 1634241479
2021-10-14 14:58 - 2021-10-14 14:58 - 000001437 _____ C:\Users\Carlos Luna\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Opera GX Browser.lnk
2021-10-12 02:37 - 2021-10-12 02:37 - 000001085 _____ C:\Users\Carlos Luna\Desktop\Windows Media Player.lnk
2021-10-11 02:36 - 2021-10-11 02:36 - 000001345 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Media Center.lnk
2021-10-11 02:35 - 2021-10-11 02:35 - 000000000 ____D C:\Users\Default\AppData\Roaming\Media Center Programs
2021-10-08 16:24 - 2021-10-08 16:24 - 000000000 ____D C:\.android
2021-10-08 04:10 - 2021-10-08 04:10 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Project64 2.3
2021-10-08 04:10 - 2021-10-08 04:10 - 000000000 ____D C:\Program Files (x86)\Project64 3.0
2021-09-27 15:15 - 2021-09-27 20:37 - 000000000 ____D C:\Users\Carlos Luna\AppData\Local\GUI
2021-09-26 13:30 - 2021-11-13 11:15 - 000000000 ____D C:\ProgramData\BlueStacks_nxt
2021-09-26 13:30 - 2021-09-27 18:10 - 000000000 ____D C:\Program Files\BlueStacks_nxt
2021-09-26 13:26 - 2021-09-26 13:26 - 001168608 _____ (BlueStack Systems Inc.) C:\Users\Carlos Luna\Downloads\BlueStacksMicroInstaller_5.3.70.1004_native.exe
2021-08-30 00:49 - 2021-10-10 23:03 - 000000995 _____ C:\Users\Carlos Luna\Desktop\Genshin Impact.lnk
==================== Three months (modified) ==================
2021-11-13 19:38 - 2009-07-13 23:45 - 000023936 ____H C:\Windows\system32\7B296FB0-376B-497e-B012-9C450E1B7327-5P-1.C7483456-A289-439d-8115-601632D005A0
2021-11-13 19:38 - 2009-07-13 23:45 - 000023936 ____H C:\Windows\system32\7B296FB0-376B-497e-B012-9C450E1B7327-5P-0.C7483456-A289-439d-8115-601632D005A0
2021-11-13 19:32 - 2020-07-17 23:22 - 000000000 ____D C:\ProgramData\NVIDIA
2021-11-13 19:32 - 2014-07-04 16:56 - 000000000 ____D C:\Users\Carlos Luna\AppData\Local\Adobe
2021-11-13 19:32 - 2009-07-14 00:08 - 000000006 ____H C:\Windows\Tasks\SA.DAT
2021-11-12 22:32 - 2015-04-19 18:58 - 000007630 _____ C:\Users\Carlos Luna\AppData\Local\Resmon.ResmonCfg
2021-11-12 22:11 - 2020-10-21 01:14 - 000000000 ____D C:\Program Files\Genshin Impact
2021-11-12 21:10 - 2017-05-05 20:31 - 000000000 ____D C:\Users\Carlos Luna\AppData\Roaming\discord
2021-11-12 20:14 - 2017-05-05 20:30 - 000000000 ____D C:\Users\Carlos Luna\AppData\Local\Discord
2021-11-12 02:42 - 2009-07-13 23:45 - 005165648 _____ C:\Windows\system32\FNTCACHE.DAT
2021-11-12 02:25 - 2009-01-01 00:26 - 000154728 _____ C:\Users\Carlos Luna\AppData\Local\GDIPFONTCACHEV1.DAT
2021-11-11 20:40 - 2014-06-22 19:37 - 000000000 ____D C:\Program Files (x86)\Steam
2021-11-10 11:22 - 2009-07-14 00:08 - 000032638 _____ C:\Windows\Tasks\SCHEDLGU.TXT
2021-11-05 19:40 - 2018-08-09 13:33 - 000000000 ____D C:\Users\Carlos Luna\Documents\Carlos
2021-11-04 15:05 - 2020-01-20 18:10 - 000000000 ____D C:\Windows\system32\Tasks\MEGA
2021-11-04 15:05 - 2009-07-13 22:20 - 000000000 ___HD C:\Windows\system32\GroupPolicy
2021-11-04 15:05 - 2009-07-13 22:20 - 000000000 ____D C:\Windows\SysWOW64\GroupPolicy
2021-11-03 20:03 - 2009-07-13 22:20 - 000000000 ____D C:\Windows\inf
2021-11-03 19:59 - 2016-04-14 00:33 - 000000000 ____D C:\Windows\pss
2021-11-02 18:47 - 2014-03-12 19:31 - 000000000 ____D C:\Windows\system32\Macromed
2021-11-02 18:47 - 2014-03-12 19:26 - 000000000 ____D C:\Windows\SysWOW64\Macromed
2021-11-01 20:53 - 2016-06-08 15:05 - 000000000 ____D C:\Users\Carlos Luna\AppData\Roaming\.minecraft
2021-10-30 17:55 - 2014-08-07 03:52 - 000000132 _____ C:\Users\Carlos Luna\AppData\Roaming\Prefs. de formato PNG de Adobe CS6
2021-10-28 18:29 - 2020-03-22 18:03 - 000689126 _____ C:\Windows\system32\perfh007.dat
2021-10-28 18:29 - 2020-03-22 18:03 - 000149098 _____ C:\Windows\system32\perfc007.dat
2021-10-28 18:29 - 2014-03-12 20:39 - 000745504 _____ C:\Windows\system32\perfh00A.dat
2021-10-28 18:29 - 2014-03-12 20:39 - 000158582 _____ C:\Windows\system32\perfc00A.dat
2021-10-28 18:29 - 2009-07-14 00:13 - 002514704 _____ C:\Windows\system32\PerfStringBackup.INI
2021-10-28 18:28 - 2018-08-09 13:46 - 000000000 ____D C:\Users\Carlos Luna\Documents\Hermanos
2021-10-25 19:58 - 2014-04-11 01:54 - 000000000 ____D C:\Users\Carlos Luna\Documents\My Games
2021-10-24 00:28 - 2009-07-13 22:20 - 000000000 ____D C:\Windows\system32\NDF
2021-10-23 02:22 - 2021-08-02 01:56 - 000000000 ____D C:\Users\Carlos Luna\AppData\Roaming\vlc
2021-10-21 02:15 - 2014-03-12 19:32 - 000000000 ____D C:\Users\Carlos Luna\AppData\Roaming\Adobe
2021-10-21 02:04 - 2021-03-11 21:40 - 000000000 ____D C:\Users\Carlos Luna\AppData\Local\Opera Software
2021-10-21 01:46 - 2015-10-24 19:03 - 000000000 ____D C:\Users\Carlos Luna\Downloads\Series
2021-10-20 23:09 - 2014-04-19 03:42 - 000000000 ____D C:\Program Files (x86)\Adobe
2021-10-20 16:10 - 2009-01-01 01:05 - 000000000 ___RD C:\Program Files (x86)\ASUS
2021-10-19 02:07 - 2016-06-08 15:04 - 000000000 ____D C:\Program Files (x86)\Minecraft
2021-10-19 02:06 - 2014-04-19 03:17 - 000000000 ____D C:\ProgramData\Adobe
2021-10-18 22:24 - 2019-02-06 20:46 - 000000000 ____D C:\Windows\system32\DAX2
2021-10-18 22:23 - 2021-05-01 02:22 - 000000000 ____D C:\Windows\SysWOW64\RTCOM
2021-10-18 22:05 - 2015-10-24 19:03 - 000000000 ____D C:\Users\Carlos Luna\Downloads\Archives
2021-10-18 22:02 - 2014-03-12 20:50 - 000000000 ____D C:\Windows\system32\Tasks\Games
2021-10-18 14:41 - 2009-07-13 22:20 - 000000000 ____D C:\Windows\rescache
2021-10-14 14:56 - 2016-01-14 23:46 - 000000000 ____D C:\Users\Carlos Luna\AppData\Roaming\Opera Software
==================== Files in the root of some directories ========
2014-10-07 03:30 - 2016-03-28 23:20 - 000000132 _____ () C:\Users\Carlos Luna\AppData\Roaming\Prefs. de formato OpenEXR de Adobe CS6
2014-08-07 03:52 - 2021-10-30 17:55 - 000000132 _____ () C:\Users\Carlos Luna\AppData\Roaming\Prefs. de formato PNG de Adobe CS6
2016-02-15 18:17 - 2017-09-18 11:15 - 002447075 _____ () C:\Users\Carlos Luna\AppData\Roaming\PS13_panel.log
2020-06-26 00:10 - 2020-06-26 00:10 - 000000045 _____ () C:\Users\Carlos Luna\AppData\Roaming\WB.CFG
2016-08-03 21:50 - 2017-09-17 09:56 - 000001456 _____ () C:\Users\Carlos Luna\AppData\Local\Adobe Guardar para Web 13.0 Prefs
2021-01-10 12:03 - 2021-01-10 12:04 - 000000774 _____ () C:\Users\Carlos Luna\AppData\Local\install_info.txt
2015-08-07 11:17 - 2015-08-07 11:17 - 013545694 _____ () C:\Users\Carlos Luna\AppData\Local\package.nw.new
2018-08-31 01:09 - 2018-12-29 02:20 - 000000600 _____ () C:\Users\Carlos Luna\AppData\Local\PUTTY.RND
2015-04-19 18:58 - 2021-11-12 22:32 - 000007630 _____ () C:\Users\Carlos Luna\AppData\Local\Resmon.ResmonCfg
2019-10-18 02:55 - 2020-07-25 01:51 - 000000077 _____ () C:\Users\Carlos Luna\AppData\Local\update_progress.txt
2019-12-06 23:13 - 2019-12-06 23:13 - 000017408 _____ () C:\Users\Carlos Luna\AppData\Local\WebpageIcons.db
==================== SigCheck ============================
LastRegBack: 2021-11-08 10:31
==================== End of FRST.txt ========================
Addition log:
Additional scan result of Farbar Recovery Scan Tool (x64) Version: 09-11-2021
Ran by Carlos Luna (13-11-2021 19:44:08)
Microsoft Windows 7 Ultimate Service Pack 1 (X64) (2009-01-01 05:23:52)
Boot Mode: Normal
Administrator (S-1-5-21-2305226654-651215044-733858041-500 - Administrator - Disabled)
Carlos Luna (S-1-5-21-2305226654-651215044-733858041-1000 - Administrator - Enabled) => C:\Users\Carlos Luna
Guest (S-1-5-21-2305226654-651215044-733858041-501 - Limited - Enabled)
HomeGroupUser$ (S-1-5-21-2305226654-651215044-733858041-1005 - Limited - Enabled)
AS: Windows Defender (Enabled - Up to date) {D68DDC3A-831F-4fae-9E44-DA132C1ACF46}
7-Zip 19.00 (x64 edition) (HKLM\...\{23170F69-40C1-2702-1900-000001000000}) (Version: 19.00.00.0 - Igor Pavlov)
Action! (HKLM-x32\...\Mirillis Action!) (Version: 3.9.6 - Mirillis)
Autodesk Maya 2015 SP2 (HKLM\...\Autodesk Maya 2015 SP2) (Version: 15.2.1633.0 - Autodesk)
Autodesk Maya 2016 SP1 (HKLM\...\Autodesk Maya 2016 SP1) (Version: 16.6.2775.0 - Autodesk) Hidden
Autodesk Maya 2016 SP2 (HKLM\...\Autodesk Maya 2016 SP2) (Version: 16.6.2775.0 - Autodesk) Hidden
Autodesk Maya 2016 SP3 (HKLM\...\Autodesk Maya 2016 SP3) (Version: 16.6.2775.0 - Autodesk) Hidden
Autodesk Maya 2016 SP3P02 (HKLM\...\Autodesk Maya 2016 SP3P02) (Version: 16.6.2775.0 - Autodesk) Hidden
Autodesk Maya 2016 SP4 (HKLM\...\Autodesk Maya 2016 SP4) (Version: 16.6.2775.0 - Autodesk) Hidden
Autodesk Maya 2016 SP4P04 (HKLM\...\Autodesk Maya 2016 SP4P04) (Version: 16.6.2775.0 - Autodesk) Hidden
Autodesk Maya 2016 SP4P05 (HKLM\...\Autodesk Maya 2016 SP4P05) (Version: 16.6.2775.0 - Autodesk) Hidden
Autodesk Maya 2016 SP5 (HKLM\...\Autodesk Maya 2016 SP5) (Version: 16.6.2775.0 - Autodesk) Hidden
Autodesk Maya 2016 SP5P06 (HKLM\...\Autodesk Maya 2016 SP5P06) (Version: 16.6.2775.0 - Autodesk) Hidden
Autodesk Maya 2016 SP5P07 (HKLM\...\Autodesk Maya 2016 SP5P07) (Version: 16.6.2775.0 - Autodesk) Hidden
Autodesk Maya 2016 SP5P08 (HKLM\...\Autodesk Maya 2016 SP5P08) (Version: 16.6.2775.0 - Autodesk) Hidden
Autodesk Maya 2016 SP6 (HKLM\...\Autodesk Maya 2016 SP6) (Version: 16.6.2775.0 - Autodesk)
BlueStacks 5 (HKLM\...\BlueStacks_nxt) (Version: 5.3.70.1004 - BlueStack Systems, Inc.)
CCleaner (HKLM\...\CCleaner) (Version: 4.15 - Piriform)
Corel Update Manager (HKLM\...\{9E1EE683-0C7B-46E7-83EC-1F5A1D8F2296}) (Version: 2.9.389 - Corel corporation) Hidden
CorelDRAW Graphics Suite 2017 - IPM (x64) (HKLM\...\{904B10A6-0D9C-4645-9C61-504FA92B9220}) (Version: 19.1 - Corel Corporation) Hidden
CorelDRAW Graphics Suite 2017 - IPM Content (x64) (HKLM\...\{54F024CB-16AF-4CC0-9BC2-D2507E7C6C01}) (Version: 19.0 - Corel Corporation) Hidden
CorelDRAW Graphics Suite 2017 - Writing Tools (x64) (HKLM\...\{E38357D4-1B80-400F-A6D7-B4D5DD83D979}) (Version: 19.1 - Corel Corporation) Hidden
CrystalDiskInfo 7.6.1 (HKLM-x32\...\CrystalDiskInfo_is1) (Version: 7.6.1 - Crystal Dew World)
Discord (HKU\S-1-5-21-2305226654-651215044-733858041-1000\...\Discord) (Version: 0.0.309 - Discord Inc.)
Epic Games Launcher (HKLM-x32\...\{8CAF0391-512D-485C-B141-39D89E7EDCA8}) (Version: 1.2.17.0 - Epic Games, Inc.)
Epic Games Launcher Prerequisites (x64) (HKLM\...\{F9C5C994-F6B9-4D75-B3E7-AD01B84073E9}) (Version: 1.0.0.0 - Epic Games, Inc.) Hidden
Epic Online Services (HKLM-x32\...\{32C68D93-D32F-4B01-8250-61642BFC22F8}) (Version: 2.0.28.0 - Epic Games, Inc.)
Genshin Impact (HKLM\...\Genshin Impact) (Version: 2.12.1.0 - miHoYo Co.,Ltd)
Intel(R) C++ Redistributables for Windows* on Intel(R) 64 (HKLM-x32\...\{D2437C5C-2D8C-40D2-8059-689AD7239FA3}) (Version: 11.1.048 - Intel Corporation)
Intel(R) Management Engine Components (HKLM-x32\...\{65153EA5-8B6E-43B6-857B-C6E4FC25798A}) (Version: 9.5.15.1730 - Intel Corporation)
Intel(R) USB 3.0 eXtensible Host Controller Driver (HKLM-x32\...\{240C3DDD-C5E9-4029-9DF7-95650D040CF2}) (Version: 2.5.0.19 - Intel Corporation)
Intel® Hardware Accelerated Execution Manager (HKLM\...\{557D160E-2085-4D38-BDA3-1D5D3F74A3A4}) (Version: 6.0.4 - Intel Corporation)
Launcher Prerequisites (x64) (HKLM-x32\...\{43a03b9c-4770-409c-a999-587b60700b63}) (Version: 1.0.0.0 - Epic Games, Inc.) Hidden
Launcher Prerequisites (x64) (HKLM-x32\...\{c6c5a357-c7ca-4a5f-9789-3bb1af579253}) (Version: 1.0.0.0 - Epic Games, Inc.) Hidden
Malwarebytes version 4.4.10.144 (HKLM\...\{35065F43-4BB2-439A-BFF7-0F1014F2E0CD}_is1) (Version: 4.4.10.144 - Malwarebytes)
MCShield ::Anti-Malware Tool:: (HKLM-x32\...\MCShield) (Version: 3.0.5.28 - MyCity)
Microsoft .NET Framework 4.8 (Deutsch) (HKLM\...\{92FB6C44-E685-45AD-9B20-CADF4CABA132} - 1031) (Version: 4.8.03761 - Microsoft Corporation)
Microsoft .NET Framework 4.8 (español) (HKLM\...\{92FB6C44-E685-45AD-9B20-CADF4CABA132} - 3082) (Version: 4.8.03761 - Microsoft Corporation)
Microsoft .NET Framework 4.8 (HKLM\...\{92FB6C44-E685-45AD-9B20-CADF4CABA132} - 1033) (Version: 4.8.03761 - Microsoft Corporation)
Microsoft Mouse and Keyboard Center (HKLM\...\Microsoft Mouse and Keyboard Center) (Version: 2.8.106.0 - Microsoft Corporation)
Microsoft Office 2010 Service Pack 1 (SP1) (HKLM-x32\...\{90140000-0011-0000-0000-0000000FF1CE}_Office14.PROPLUS_{047B0968-E622-4FAA-9B4B-121FA109EDDE}) (Version: - Microsoft)
Microsoft Office Professional Plus 2010 (HKLM-x32\...\Office14.PROPLUS) (Version: 14.0.6029.1000 - Microsoft Corporation)
Microsoft Research Mesh Virtual WIFI (HKLM-x32\...\{034A32D5-699E-4AED-A2EB-2CCB6E7F37F1}) (Version: 1.0.000 - Microsoft Research)
Microsoft Visual C++ 2005 Redistributable (HKLM-x32\...\{710f4c1c-cc18-4c49-8cbf-51240c89a1a2}) (Version: 8.0.61001 - Microsoft Corporation)
Microsoft Visual C++ 2005 Redistributable (HKLM-x32\...\{7299052b-02a4-4627-81f2-1818da5d550d}) (Version: 8.0.56336 - Microsoft Corporation)
Microsoft Visual C++ 2005 Redistributable (HKLM-x32\...\{837b34e3-7c30-493c-8f6a-2b0f04e2912c}) (Version: 8.0.59193 - Microsoft Corporation)
Microsoft Visual C++ 2005 Redistributable (x64) (HKLM\...\{6ce5bae9-d3ca-4b99-891a-1dc6c118a5fc}) (Version: 8.0.59192 - Microsoft Corporation)
Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.17 (HKLM\...\{8220EEFE-38CD-377E-8595-13398D740ACE}) (Version: 9.0.30729 - Microsoft Corporation)
Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.4148 (HKLM\...\{4B6C7001-C7D6-3710-913E-5BC23FCE91E6}) (Version: 9.0.30729.4148 - Microsoft Corporation)
Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.6161 (HKLM\...\{5FCE6D76-F5DC-37AB-B2B8-22AB8CEDB1D4}) (Version: 9.0.30729.6161 - Microsoft Corporation)
Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.4148 (HKLM-x32\...\{1F1C2DFC-2D24-3E06-BCB8-725134ADF989}) (Version: 9.0.30729.4148 - Microsoft Corporation)
Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.6161 (HKLM-x32\...\{9BE518E6-ECC6-35A9-88E4-87755C07200F}) (Version: 9.0.30729.6161 - Microsoft Corporation)
Microsoft Visual C++ 2012 Redistributable (x64) - 11.0.61030 (HKLM-x32\...\{ca67548a-5ebe-413a-b50c-4b9ceb6d66c6}) (Version: 11.0.61030.0 - Microsoft Corporation)
Microsoft Visual C++ 2013 Redistributable (x64) - 12.0.30501 (HKLM-x32\...\{050d4fc8-5d48-4b8f-8972-47c82c46020f}) (Version: 12.0.30501.0 - Microsoft Corporation)
Microsoft Visual C++ 2013 Redistributable (x64) - 12.0.30501 (HKLM-x32\...\{1b103cea-f037-4504-81de-956057b442c3}) (Version: 12.0.30501.0 - Microsoft Corporation)
Microsoft Visual C++ 2013 Redistributable (x86) - 12.0.30501 (HKLM-x32\...\{f65db027-aff3-4070-886a-0d87064aabb1}) (Version: 12.0.30501.0 - Microsoft Corporation)
Microsoft Visual C++ 2015-2019 Redistributable (x64) - 14.28.29334 (HKLM-x32\...\{a9cfe9c7-e54f-46cd-9c5c-542ff8e3e8c4}) (Version: 14.28.29334.0 - Microsoft Corporation)
Microsoft Visual C++ 2015-2019 Redistributable (x86) - 14.28.29334 (HKLM-x32\...\{b2d0f752-adc5-496e-8f70-8669de01f746}) (Version: 14.28.29334.0 - Microsoft Corporation)
Microsoft Visual Studio Tools for Applications 2012 (HKLM-x32\...\{89ca2a32-2b52-4595-8dfd-6fe4757958d0}) (Version: 11.0.51108 - Microsoft Corporation)
Microsoft Visual Studio Tools for Applications 2015 (HKLM-x32\...\{dd8b09df-3ef8-49f1-bd1a-65278435860b}) (Version: 14.0.23217 - Microsoft Corporation)
Minecraft Launcher (HKLM-x32\...\{810F1419-7760-402E-8772-B4054FAA2B72}) (Version: 1.0.0.0 - Mojang)
MSI Afterburner 4.6.2 (HKLM-x32\...\Afterburner) (Version: 4.6.2 - MSI Co., LTD)
NVIDIA Graphics Driver 451.67 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.Driver) (Version: 451.67 - NVIDIA Corporation)
NVIDIA HD Audio Driver 1.3.38.34 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_HDAudio.Driver) (Version: 1.3.38.34 - NVIDIA Corporation)
NVIDIA PhysX System Software 9.19.0218 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.PhysX) (Version: 9.19.0218 - NVIDIA Corporation)
Opera GX Stable 80.0.4170.91 (HKU\S-1-5-21-2305226654-651215044-733858041-1000\...\Opera GX 80.0.4170.91) (Version: 80.0.4170.91 - Opera Software)
Pacote de Idiomas do Microsoft Visual Studio Tools for Applications 2012 x64 Hosting Support - PTB (HKLM\...\{E237254B-36A1-3D27-815E-B37C13BE0796}) (Version: 11.0.51108 - Microsoft Corporation) Hidden
Pacote de Idiomas do Microsoft Visual Studio Tools for Applications 2012 x86 Hosting Support - PTB (HKLM-x32\...\{03077B58-6ACF-32CA-B42A-EAA458C295A1}) (Version: 11.0.51108 - Microsoft Corporation) Hidden
Project64 version 3.0.1.5664 (HKLM-x32\...\{BEB5FB69-4080-466F-96C4-F15DF271718B}_is1) (Version: 3.0.1.5664 - )
Realtek Ethernet Controller Driver (HKLM-x32\...\{8833FFB6-5B0C-4764-81AA-06DFEED9A476}) (Version: 7.67.1226.2012 - Realtek)
Realtek Ethernet Diagnostic Utility (HKLM-x32\...\{DADC7AB0-E554-4705-9F6A-83EA82ED708E}) (Version: 2.0.2.7 - Realtek)
Realtek High Definition Audio Driver (HKLM-x32\...\{F132AF7F-7BCA-4EDE-8A7C-958108FE7DBC}) (Version: 6.0.1.7982 - Realtek Semiconductor Corp.)
UE4 Prerequisites (x86) (HKLM-x32\...\{6EAAE1C0-6000-45FA-B46D-D206144925BF}) (Version: 1.0.11.0 - Epic Games, Inc.) Hidden
UE4 Prerequisites (x86) (HKLM-x32\...\{f1203e43-4ddb-4280-974e-73f14d793dbd}) (Version: 1.0.13.0 - Epic Games, Inc.) Hidden
WO Mic Client (HKLM-x32\...\WOMic) (Version: - )
Языковой пакет для поддержки размещения набора средств Microsoft Visual Studio Tools для работы с приложениями 2012 (x64) - RUS (HKLM\...\{25FB53C5-BE4C-3B6C-A0C9-D49A39227E1E}) (Version: 11.0.51108 - Microsoft Corporation) Hidden
Языковой пакет для поддержки размещения набора средств Microsoft Visual Studio Tools для работы с приложениями 2012 (x86) - RUS (HKLM-x32\...\{68DC347D-C1C0-3DE2-A53E-CCC71DA53E57}) (Version: 11.0.51108 - Microsoft Corporation) Hidden
==================== Custom CLSID (Whitelisted): ==============
CustomCLSID: HKU\S-1-5-21-2305226654-651215044-733858041-1000_Classes\CLSID\{00020420-0000-0000-C000-000000000046}\InprocServer32 -> C:\Windows\system32\oleaut32.dll (Microsoft Windows -> Microsoft Corporation)
CustomCLSID: HKU\S-1-5-21-2305226654-651215044-733858041-1000_Classes\CLSID\{00020421-0000-0000-C000-000000000046}\InprocServer32 -> C:\Windows\system32\oleaut32.dll (Microsoft Windows -> Microsoft Corporation)
CustomCLSID: HKU\S-1-5-21-2305226654-651215044-733858041-1000_Classes\CLSID\{00020422-0000-0000-C000-000000000046}\InprocServer32 -> C:\Windows\system32\oleaut32.dll (Microsoft Windows -> Microsoft Corporation)
CustomCLSID: HKU\S-1-5-21-2305226654-651215044-733858041-1000_Classes\CLSID\{00020423-0000-0000-C000-000000000046}\InprocServer32 -> C:\Windows\system32\oleaut32.dll (Microsoft Windows -> Microsoft Corporation)
CustomCLSID: HKU\S-1-5-21-2305226654-651215044-733858041-1000_Classes\CLSID\{00020424-0000-0000-C000-000000000046}\InprocServer32 -> C:\Windows\system32\oleaut32.dll (Microsoft Windows -> Microsoft Corporation)
CustomCLSID: HKU\S-1-5-21-2305226654-651215044-733858041-1000_Classes\CLSID\{00020425-0000-0000-C000-000000000046}\InprocServer32 -> C:\Windows\system32\oleaut32.dll (Microsoft Windows -> Microsoft Corporation)
ShellExecuteHooks: Groove GFS Stub Execution Hook - {B5A7F190-DDA6-4420-B3BA-52453494E6CD} - C:\Program Files\Microsoft Office\Office14\GROOVEEX.DLL [6718864 2011-02-12] (Microsoft Corporation -> Microsoft Corporation)
ShellExecuteHooks-x32: Groove GFS Stub Execution Hook - {B5A7F190-DDA6-4420-B3BA-52453494E6CD} - C:\Program Files (x86)\Microsoft Office\Office14\GROOVEEX.DLL [4220304 2011-02-12] (Microsoft Corporation -> Microsoft Corporation)
ContextMenuHandlers1: [7-Zip] -> {23170F69-40C1-278A-1000-000100020000} => C:\Program Files\7-Zip\7-zip.dll [2019-02-21] (Igor Pavlov) [File not signed]
ContextMenuHandlers1-x32: [WinRAR] -> {B41DB860-8EE4-11D2-9906-E49FADC173CA} => C:\Program Files (x86)\WinRAR\rarext.dll [2004-12-26] () [File not signed]
ContextMenuHandlers3: [MBAMShlExt] -> {57CE581A-0CB6-4266-9CA0-19364C90A0B3} => C:\Program Files\Malwarebytes\Anti-Malware\mbshlext.dll [2021-11-05] (Malwarebytes Corporation -> Malwarebytes)
ContextMenuHandlers4: [7-Zip] -> {23170F69-40C1-278A-1000-000100020000} => C:\Program Files\7-Zip\7-zip.dll [2019-02-21] (Igor Pavlov) [File not signed]
ContextMenuHandlers4-x32: [WinRAR] -> {B41DB860-8EE4-11D2-9906-E49FADC173CA} => C:\Program Files (x86)\WinRAR\rarext.dll [2004-12-26] () [File not signed]
ContextMenuHandlers5: [NvCplDesktopContext] -> {3D1975AF-48C6-4f8e-A182-BE0E08FA86A9} => C:\Windows\system32\nvshext.dll [2020-07-05] (NVIDIA Corporation -> NVIDIA Corporation)
ContextMenuHandlers6: [7-Zip] -> {23170F69-40C1-278A-1000-000100020000} => C:\Program Files\7-Zip\7-zip.dll [2019-02-21] (Igor Pavlov) [File not signed]
ContextMenuHandlers6: [MBAMShlExt] -> {57CE581A-0CB6-4266-9CA0-19364C90A0B3} => C:\Program Files\Malwarebytes\Anti-Malware\mbshlext.dll [2021-11-05] (Malwarebytes Corporation -> Malwarebytes)
ContextMenuHandlers6-x32: [WinRAR] -> {B41DB860-8EE4-11D2-9906-E49FADC173CA} => C:\Program Files (x86)\WinRAR\rarext.dll [2004-12-26] () [File not signed]
==================== Codecs (Whitelisted) ====================
HKLM\...\Drivers32: [VIDC.FICV] => C:\Windows\system32\ficvdec_x64.dll [652288 2013-05-28] () [File not signed]
HKLM\...\Drivers32: [VIDC.FICV] => C:\Windows\SysWOW64\ficvdec_x86.dll [641024 2013-05-28] () [File not signed]
==================== Shortcuts & WMI ========================
==================== Loaded Modules (Whitelisted) =============
2009-01-01 01:06 - 2021-11-13 19:32 - 000034448 _____ (ASUSTeK Computer Inc. -> ) [File not signed] C:\Program Files (x86)\ASUS\AXSP\1.01.01\PEbiosinterface32.dll
2019-02-21 21:00 - 2019-02-21 21:00 - 000078336 _____ (Igor Pavlov) [File not signed] C:\Program Files\7-Zip\7-zip.dll
2021-05-01 02:09 - 2013-04-26 10:24 - 000073728 _____ (Intel Corporation) [File not signed] C:\Program Files (x86)\Intel\Intel(R) USB 3.0 eXtensible Host Controller Driver\Application\iusb3mon.dll
2014-02-27 17:43 - 2014-02-27 17:43 - 000173568 _____ (Nokia Corporation and/or its subsidiary(-ies)) [File not signed] C:\Program Files\Logitech Gaming Software\imageformats\qjpeg4.dll
2014-02-27 17:43 - 2014-02-27 17:43 - 001807360 _____ (Nokia Corporation and/or its subsidiary(-ies)) [File not signed] C:\Program Files\Logitech Gaming Software\QtCLucene4.dll
2014-02-27 17:43 - 2014-02-27 17:43 - 003276288 _____ (Nokia Corporation and/or its subsidiary(-ies)) [File not signed] C:\Program Files\Logitech Gaming Software\QtCore4.dll
2014-02-27 17:43 - 2014-02-27 17:43 - 012168192 _____ (Nokia Corporation and/or its subsidiary(-ies)) [File not signed] C:\Program Files\Logitech Gaming Software\QtGui4.dll
2014-02-27 17:43 - 2014-02-27 17:43 - 000750080 _____ (Nokia Corporation and/or its subsidiary(-ies)) [File not signed] C:\Program Files\Logitech Gaming Software\QtHelp4.dll
2014-02-27 17:43 - 2014-02-27 17:43 - 001085952 _____ (Nokia Corporation and/or its subsidiary(-ies)) [File not signed] C:\Program Files\Logitech Gaming Software\QtNetwork4.dll
2014-02-27 17:43 - 2014-02-27 17:43 - 000841728 _____ (Nokia Corporation and/or its subsidiary(-ies)) [File not signed] C:\Program Files\Logitech Gaming Software\QtOpenGL4.dll
2014-02-27 17:43 - 2014-02-27 17:43 - 001990144 _____ (Nokia Corporation and/or its subsidiary(-ies)) [File not signed] C:\Program Files\Logitech Gaming Software\QtScript4.dll
2014-02-27 17:43 - 2014-02-27 17:43 - 000897024 _____ (Nokia Corporation and/or its subsidiary(-ies)) [File not signed] C:\Program Files\Logitech Gaming Software\QtSql4.dll
2014-02-27 17:43 - 2014-02-27 17:43 - 000539136 _____ (Nokia Corporation and/or its subsidiary(-ies)) [File not signed] C:\Program Files\Logitech Gaming Software\QtXml4.dll
==================== Alternate Data Streams (Whitelisted) ========
==================== Safe Mode (Whitelisted) ==================
(If an entry is included in the fixlist, it will be removed from the registry. The "AlternateShell" will be restored.)
HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\MBAMService => ""="Service"
HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\MBAMService => ""="Service"
==================== Association (Whitelisted) =================
==================== Internet Explorer (Version 11) (Whitelisted) ==========
HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = www.google.com
HKU\S-1-5-21-2305226654-651215044-733858041-1000\Software\Microsoft\Internet Explorer\Main,Start Page Redirect Cache = hxxp://latam.msn.com/?ocid=iehp
SearchScopes: HKLM -> DefaultScope {0633EE93-D776-472f-A0FF-E1416B8B2E3A} URL = hxxps://www.bing.com/search?q={searchTerms}&FORM=IE8SRC
SearchScopes: HKLM -> {0633EE93-D776-472f-A0FF-E1416B8B2E3A} URL = hxxps://www.bing.com/search?q={searchTerms}&FORM=IE8SRC
SearchScopes: HKLM-x32 -> DefaultScope {632F07F3-19A1-4d16-A23F-E6CE9486BAB5} URL =
SearchScopes: HKLM-x32 -> {0633EE93-D776-472f-A0FF-E1416B8B2E3A} URL = hxxps://www.bing.com/search?q={searchTerms}&FORM=IE8SRC
BHO: Groove GFS Browser Helper -> {72853161-30C5-4D22-B7F9-0BBC1D38A37E} -> C:\Program Files\Microsoft Office\Office14\GROOVEEX.DLL [2011-02-12] (Microsoft Corporation -> Microsoft Corporation)
BHO: Office Document Cache Handler -> {B4F3A835-0E21-4959-BA22-42B3008E02FF} -> C:\Program Files\Microsoft Office\Office14\URLREDIR.DLL [2010-12-21] (Microsoft Corporation -> Microsoft Corporation)
BHO-x32: Office Document Cache Handler -> {B4F3A835-0E21-4959-BA22-42B3008E02FF} -> C:\Program Files (x86)\Microsoft Office\Office14\URLREDIR.DLL [2010-12-21] (Microsoft Corporation -> Microsoft Corporation)
==================== Hosts content: =========================
2021-10-18 22:12 - 2021-10-18 22:12 - 000000833 ____R C:\Windows\system32\drivers\etc\hosts
==================== Other Areas ===========================
HKU\S-1-5-21-2305226654-651215044-733858041-1000\Control Panel\Desktop\\Wallpaper -> C:\Users\Carlos Luna\AppData\Roaming\Microsoft\Windows\Themes\TranscodedWallpaper.jpg
DNS Servers: 200.48.225.130 - 200.48.225.146
Windows Firewall is enabled.
MSCONFIG\Services: GfExperienceService => 2
MSCONFIG\Services: NvNetworkService => 2
MSCONFIG\Services: NvStreamNetworkSvc => 3
MSCONFIG\Services: NvStreamSvc => 2
MSCONFIG\Services: nvsvc => 2
MSCONFIG\Services: Stereo Service => 2
==================== FirewallRules (Whitelisted) ================
FirewallRules: [TCP Query User{5CB41C60-5184-4DE4-97E7-47A8CE3C61C2}C:\program files (x86)\womic\womicclient.exe] => (Allow) C:\program files (x86)\womic\womicclient.exe () [File not signed]
FirewallRules: [UDP Query User{C4B58CE0-9B62-4529-B69B-189EF82CB167}C:\program files (x86)\womic\womicclient.exe] => (Allow) C:\program files (x86)\womic\womicclient.exe () [File not signed]
FirewallRules: [TCP Query User{53066240-262C-4D89-AD40-374FC9C37118}C:\users\carlos luna\appdata\local\programs\opera gx\opera.exe] => (Allow) C:\users\carlos luna\appdata\local\programs\opera gx\opera.exe (Opera Software AS -> Opera Software)
FirewallRules: [UDP Query User{4FE1146C-6B94-4A3F-B3B9-03B3D4234638}C:\users\carlos luna\appdata\local\programs\opera gx\opera.exe] => (Allow) C:\users\carlos luna\appdata\local\programs\opera gx\opera.exe (Opera Software AS -> Opera Software)
FirewallRules: [TCP Query User{DFCFD19C-91C2-40C7-946E-3EE01B712C2E}C:\program files (x86)\steam\steam.exe] => (Allow) C:\program files (x86)\steam\steam.exe (Valve -> Valve Corporation)
FirewallRules: [UDP Query User{6A80C201-3B27-4588-98EE-E01BBA7533C3}C:\program files (x86)\steam\steam.exe] => (Allow) C:\program files (x86)\steam\steam.exe (Valve -> Valve Corporation)
FirewallRules: [{36077DE1-8476-401E-8EA6-52CBF9065A7D}] => (Allow) C:\Program Files (x86)\Steam\bin\cef\cef.win7x64\steamwebhelper.exe (Valve -> Valve Corporation)
FirewallRules: [{D025ADD2-4276-4691-B046-73FA0D984488}] => (Allow) C:\Program Files (x86)\Steam\bin\cef\cef.win7x64\steamwebhelper.exe (Valve -> Valve Corporation)
FirewallRules: [TCP Query User{586D1D22-7153-4987-97D8-B77472B9AF71}C:\program files\epic games\amongus\among us.exe] => (Allow) C:\program files\epic games\amongus\among us.exe () [File not signed]
FirewallRules: [UDP Query User{CC6FE1C3-7381-4122-8B0F-95493109FF5E}C:\program files\epic games\amongus\among us.exe] => (Allow) C:\program files\epic games\amongus\among us.exe () [File not signed]
FirewallRules: [TCP Query User{5CBDF2E0-CB20-4AE0-9BA2-CE78F6BDF0AE}C:\program files\genshin impact\genshin impact game\genshinimpact.exe] => (Allow) C:\program files\genshin impact\genshin impact game\genshinimpact.exe (miHoYo Co.,Ltd. -> )
FirewallRules: [UDP Query User{985CB71C-5064-4898-8B6F-1A4B83F251E0}C:\program files\genshin impact\genshin impact game\genshinimpact.exe] => (Allow) C:\program files\genshin impact\genshin impact game\genshinimpact.exe (miHoYo Co.,Ltd. -> )
FirewallRules: [{9BCB1DAC-4A40-44C1-BA83-D5E1CF1DD096}] => (Allow) C:\Program Files (x86)\Steam\SteamApps\common\RISK Global Domination\RISK.exe () [File not signed]
FirewallRules: [{2D9C3240-87F7-414B-A498-1A6238A99B0D}] => (Allow) C:\Program Files (x86)\Steam\SteamApps\common\RISK Global Domination\RISK.exe () [File not signed]
FirewallRules: [TCP Query User{01F7E6D7-6831-4E02-AC98-14FC7C0AC9C8}C:\program files (x86)\steam\steamapps\common\left 4 dead 2\left4dead2.exe] => (Allow) C:\program files (x86)\steam\steamapps\common\left 4 dead 2\left4dead2.exe () [File not signed]
FirewallRules: [UDP Query User{53A32A65-3F71-4320-9C6C-D832023AA22C}C:\program files (x86)\steam\steamapps\common\left 4 dead 2\left4dead2.exe] => (Allow) C:\program files (x86)\steam\steamapps\common\left 4 dead 2\left4dead2.exe () [File not signed]
FirewallRules: [{0E255199-C3C4-4F02-88FD-FC94100871C9}] => (Allow) C:\Program Files (x86)\Steam\SteamApps\common\Action Taimanin\ActionTaimanin.exe () [File not signed]
FirewallRules: [{FD9C28AB-F010-407B-B017-0D6B689E01CC}] => (Allow) C:\Program Files (x86)\Steam\SteamApps\common\Action Taimanin\ActionTaimanin.exe () [File not signed]
FirewallRules: [TCP Query User{33001C23-34A2-484A-B476-E23DFAD5ABE6}C:\program files (x86)\minecraft launcher\runtime\java-runtime-alpha\windows-x64\java-runtime-alpha\bin\javaw.exe] => (Allow) C:\program files (x86)\minecraft launcher\runtime\java-runtime-alpha\windows-x64\java-runtime-alpha\bin\javaw.exe
FirewallRules: [UDP Query User{F4584F73-C6BE-4460-AAA4-1C76B08DEB29}C:\program files (x86)\minecraft launcher\runtime\java-runtime-alpha\windows-x64\java-runtime-alpha\bin\javaw.exe] => (Allow) C:\program files (x86)\minecraft launcher\runtime\java-runtime-alpha\windows-x64\java-runtime-alpha\bin\javaw.exe
FirewallRules: [{6765061F-677B-4DBE-A273-09BAC861F1ED}] => (Allow) C:\Users\Carlos Luna\AppData\Local\Programs\Opera GX\80.0.4170.86\opera.exe (Opera Software AS -> Opera Software)
FirewallRules: [{324AD36E-790D-4E4C-853C-D1E1DB37E1EE}] => (Allow) C:\Users\Carlos Luna\AppData\Local\Programs\Opera GX\80.0.4170.91\opera.exe (Opera Software AS -> Opera Software)
FirewallRules: [{FE3F8B73-F1E9-4F0F-B1FA-2FD294031165}] => (Block) C:\Program Files (x86)\Avira\SoftwareUpdater\avirasoftwareupdatertoastnotificationsbridge.exe => No File
FirewallRules: [{66218D12-066D-40C8-BA00-832D47785667}] => (Allow) C:\Program Files (x86)\Avira\SoftwareUpdater\avirasoftwareupdatertoastnotificationsbridge.exe => No File
FirewallRules: [{5158495A-C4E2-49E5-BA83-0EFFF01D72AC}] => (Allow) C:\Program Files (x86)\Avira\SoftwareUpdater\avirasoftwareupdatertoastnotificationsbridge.exe => No File
12-11-2021 02:15:09 KpRm
==================== Faulty Device Manager Devices ============
Name: SM Bus Controller
Description: SM Bus Controller
Class Guid:
Manufacturer:
Service:
Problem: : The drivers for this device are not installed. (Code 28)
Resolution: To install the drivers for this device, click "Update Driver", which starts the Hardware Update wizard.
==================== Event log errors: ========================
Application errors:
Error: (11/10/2021 08:06:53 PM) (Source: VSS) (EventID: 8194) (User: )
Description: Volume Shadow Copy Service error: Unexpected error querying for the IVssWriterCallback interface. hr = 0x80070005, Access is denied.
This is often caused by incorrect security settings in either the writer or requestor process.
Operation:
Gathering Writer Data
Context:
Writer Class Id: {e8132975-6f93-4464-a53e-1050253ae220}
Writer Name: System Writer
Writer Instance ID: {16925720-6d91-4565-94a9-34ef61f2c68b}
Error: (11/08/2021 08:09:50 PM) (Source: VSS) (EventID: 8194) (User: )
Operation:
Context:
Writer Instance ID: {537cc320-8f1a-440c-9643-f9ba8b4b6e3f}
Error: (11/07/2021 07:24:44 PM) (Source: VSS) (EventID: 8194) (User: )
Operation:
Context:
Writer Instance ID: {bf3f010b-b1b9-4960-9b49-008848747a35}
Error: (11/05/2021 08:06:29 PM) (Source: Application Error) (EventID: 1000) (User: )
Description: Faulting application name: mbamtray.exe, version: 4.0.0.1162, time stamp: 0x61783b28
Faulting module name: Qt5Core.dll, version: 5.14.1.0, time stamp: 0x603971ce
Exception code: 0xc0000005
Fault offset: 0x0000000000219dc5
Faulting process id: 0xccc
Faulting application start time: 0x01d7d2aa86888b35
Faulting application path: C:\Program Files\Malwarebytes\Anti-Malware\mbamtray.exe
Faulting module path: C:\Program Files\Malwarebytes\Anti-Malware\Qt5Core.dll
Report Id: c5321d78-3e9d-11ec-85a1-d850e63c46b2
Error: (11/05/2021 07:49:08 PM) (Source: VSS) (EventID: 8194) (User: )
Operation:
Context:
Writer Instance ID: {f9c2217e-9e3d-4114-b3dc-2f49d95edd69}
System errors:
Error: (11/13/2021 07:48:33 PM) (Source: DCOM) (EventID: 10010) (User: )
Description: The server {BB6DF56B-CACE-11DC-9992-0019B93A3A84} did not register with DCOM within the required timeout.
Error: (11/10/2021 08:07:06 PM) (Source: Service Control Manager) (EventID: 7034) (User: )
Description: The Intel(R) Management and Security Application Local Management Service service terminated unexpectedly. It has done this 1 time(s).
Error: (11/10/2021 08:07:06 PM) (Source: Service Control Manager) (EventID: 7031) (User: )
Description: The Windows Search service terminated unexpectedly. It has done this 1 time(s). The following corrective action will be taken in 30000 milliseconds: Restart the service.
Description: The Intel(R) Dynamic Application Loader Host Interface Service service terminated unexpectedly. It has done this 1 time(s).
Description: The Windows Media Player Network Sharing Service service terminated unexpectedly. It has done this 1 time(s). The following corrective action will be taken in 30000 milliseconds: Restart the service.
Description: The Intel(R) Capability Licensing Service Interface service terminated unexpectedly. It has done this 1 time(s). The following corrective action will be taken in 0 milliseconds: Restart the service.
Description: The Corel License Validation Service V2, Powered by arvato service terminated unexpectedly. It has done this 1 time(s).
Description: The ASUS Com Service service terminated unexpectedly. It has done this 1 time(s).
BIOS: American Megatrends Inc. 2003 10/15/2014
Motherboard: ASUSTeK COMPUTER INC. H87-PLUS
Processor: Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz
Percentage of memory in use: 45%
Total physical RAM: 8130.46 MB
Available physical RAM: 4423.6 MB
Total Virtual: 16259.06 MB
Available Virtual: 10370.3 MB
Drive c: () (Fixed) (Total:931.41 GB) (Free:461.34 GB) NTFS
Drive h: (CarlosLuna) (Fixed) (Total:465.76 GB) (Free:253.9 GB) NTFS
\\?\Volume{6f327824-d7c3-11dd-893f-806e6f6e6963}\ (System Reserved) (Fixed) (Total:0.1 GB) (Free:0.06 GB) NTFS
==================== MBR & Partition Table ====================
Disk: 0 (MBR Code: Windows 7/8/10) (Size: 931.5 GB) (Disk ID: 319F4949)
Partition 1: (Active) - (Size=100 MB) - (Type=07 NTFS)
Partition 2: (Not Active) - (Size=931.4 GB) - (Type=07 NTFS)
Disk: 1 (Size: 465.8 GB) (Disk ID: 844382C4)
Partition 1: (Active) - (Size=465.8 GB) - (Type=07 NTFS)
==================== End of Addition.txt =======================
Hi, Carlosh.
There is no indication that Avira is installed in the computer right now. Have you uninstalled it?
Yes, was generating some performance issues so I had to uninstalled, sorry if that affect the scan, but still the window keeps appearing on startup.
Carlosh,
Please do the following to run a FRST fix.
NOTICE: This script was written specifically for this user. Running it on another machine may cause damage to your operating system
  • Please select the entire contents of the code box below, from the "Start::" line to "End::", including both lines. Right-click and select "Copy ". No need to paste anything to anywhere.
Start::
CreateRestorePoint:
CloseProcesses:
EmptyTemp:
End::
  • Please right-click on FRST64 on your Desktop, to run it as administrator. When the tool opens, click "yes" to the disclaimer.[/*]
  • Press the Fix button once and wait.
  • FRST will process fixlist.txt
  • When finished, it will produce a log fixlog.txt on your Desktop.
  • Please post the log in your next reply.
Also let me know if the anything from Avira pops up at the startup.
I did the fix, but still that "Open with" window opens, the same avira log as before.
If it helps, when I select browse it send me to C/Program files directory, there is nothing about Avira but it could be linked to something there.
Fixlog:
Fix result of Farbar Recovery Scan Tool (x64) Version: 09-11-2021
Ran by Carlos Luna (14-11-2021 04:46:11) Run:1
Boot Mode: Normal
fixlist content:
CreateRestorePoint:
CloseProcesses:
EmptyTemp:
C:\Windows\system32\Tasks\Avira => moved successfully
C:\Users\Public\Security Sessions => moved successfully
C:\Windows\system32\Drivers\Msft_Kernel_avusbflt_01011.Wdf => moved successfully
C:\Windows\SysWOW64\statReporter => moved successfully
C:\ProgramData\Avira => moved successfully
"HKLM\SYSTEM\CurrentControlSet\services\SharedAccess\Parameters\FirewallPolicy\FirewallRules\\{FE3F8B73-F1E9-4F0F-B1FA-2FD294031165}" => removed successfully
"HKLM\SYSTEM\CurrentControlSet\services\SharedAccess\Parameters\FirewallPolicy\FirewallRules\\{66218D12-066D-40C8-BA00-832D47785667}" => removed successfully
"HKLM\SYSTEM\CurrentControlSet\services\SharedAccess\Parameters\FirewallPolicy\FirewallRules\\{5158495A-C4E2-49E5-BA83-0EFFF01D72AC}" => removed successfully
HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\SearchScopes\\"DefaultScope"="{0633EE93-D776-472f-A0FF-E1416B8B2E3A}" => value restored successfully
=========== EmptyTemp: ==========
BITS transfer queue => 0 B
DOMStore, IE Recovery, AppCache, Feeds Cache, Thumbcache, IconCache => 31429879 B
Java, Flash, Steam htmlcache => 23535812 B
Windows/system/drivers => 15701948 B
Edge => 0 B
Firefox => 0 B
Opera => 0 B
Temp, IE cache, history, cookies, recent:
Default => 0 B
Public => 0 B
ProgramData => 0 B
systemprofile => 128 B
systemprofile32 => 256 B
LocalService => 256 B
NetworkService => 256 B
Carlos Luna => 19816522 B
RecycleBin => 0 B
EmptyTemp: => 86.3 MB temporary data Removed.
The system needed a reboot.
==== End of Fixlog 04:46:54 ====
Can you attach a screenshot before you open that file? When it appears on your Desktop.
That's the window that appears on desktop after and that's the directory it send me when I select browse.
Edit: I found the file was on Users, with my name, I open it with notepad and is the same log.
The first screenshot appears after you right click the file and choose Open with. I would like to see the file on the Desktop before you right click and choose Open with.
I don't right click anything, it just appears by itself when I start the PC, the window just pops out, the file it seems to be located in Users and is with my name.
Carlosh,
Here it is another FRST fix for you:
Start::
CreateRestorePoint:
CloseProcesses:
EmptyTemp:
End::
Does the file wants to open again?
It's gone now, thanks again, what a weird thing to have, I remember having this issue with Avast too, but I think I removed when I start clearing some archives on the PC, still wasn't sure what cause it.
Here is the Fixlog:
Fix result of Farbar Recovery Scan Tool (x64) Version: 14-11-2021
Ran by Carlos Luna (14-11-2021 17:05:16) Run:2
Boot Mode: Normal
fixlist content:
CreateRestorePoint:
CloseProcesses:
EmptyTemp:
HKLM\SOFTWARE\Policies\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\3 => removed successfully
HKLM\SOFTWARE\Wow6432Node\Google\Chrome\Extensions\caljgklbbfbcjjanaijlacgncafpegll => removed successfully
HKLM\SOFTWARE\Wow6432Node\Google\Chrome\Extensions\ccbpbkebodcjkknkfkpmfeciinhidaeh => removed successfully
HKLM\SOFTWARE\Wow6432Node\Google\Chrome\Extensions\flliilndjeohchalpbbcdekjklbdgfkk => removed successfully
C:\Users\Carlos => moved successfully
DOMStore, IE Recovery, AppCache, Feeds Cache, Thumbcache, IconCache => 7090034 B
Java, Flash, Steam htmlcache => 0 B
Windows/system/drivers => 17778 B
Edge => 0 B
Firefox => 0 B
Opera => 0 B
Default => 0 B
Public => 0 B
ProgramData => 0 B
systemprofile => 0 B
systemprofile32 => 0 B
LocalService => 0 B
NetworkService => 0 B
Carlos Luna => 3790515 B
RecycleBin => 0 B
EmptyTemp: => 10.4 MB temporary data Removed.
==== End of Fixlog 17:05:55 ====
Carlosh,
It seems that the space in your account name creates some confusion.
So... you can try Kaspersky free. Another free option is Sophos free. Hopefully, there will not be a problem with those!
I will be waiting for you to install an antivirus. Then, if there is no problem, and no more issues/questions/concerns, I will give you the final instructions for a system restore and the FRST's removal.
Let me know when you are ready. :-)
I try Kaspersky once and the PC was so slow that I have to uninstall it, Sophos is unknown to me, but I seeing many people having issues with it. So really not sure what to do, I will keep searching for one that doesn't affect my performance, I know is important, but if I can't use the PC because of it, I guess I just should be careful on what I do in this PC, also this computer is share around, so also have to warn my family to not get into bad sites or install unwanted programs frequently.
But well so far the computer is working right, I don't more issues now, really thanks for all the help I will keep searching for an antivirus, if I found one that doesn't eat all the memory and let me work/game/hobby, I will let you know.
Hi, Carlosh.
Did you use the free or the payed version of Kaspersky? I don't think that the free version causes such issues.
Whatever is the case, you need to install an antivirus sooner than later. Or... eventually decide to upgrade to 10. :-)
It seems that we are reaching to the end.
Download KpRm by kernel-panik and save it to your desktop.
  • Right-click kprm_(version).exe and select Run as Administrator.
  • Read and accept the disclaimer.
  • When the tool opens, ensure all boxes under Actions are checked.
  • Under Delete Quarantines select Delete Now, then click Run.
  • Once complete, click OK.
  • A log will open in Notepad titled kprm-(date).txt.
  • Please copy and paste its contents in your next reply.
Yeah I try the free version of kaspersky, it was one of the first I try when having the Rootkit issue, I will try again maybe will be different without the Rootkit. And eventually I will upgrade to windows 10, just need to change my graphic card to AMD, Nvidia drivers have so much issues with W10 that I'm almost forced to stay in W7.
And good to know we are reaching to an end, feeling a bit guilty about taking your time and ask for your help this long, still I'm really glad and thankful that you could find and solve so many issues in my computer.
kprm log:
# Run at 17/11/2021 02:33:31 a.m.
# KpRm (Kernel-panik) version 2.9.2
# Website https://kernel-panik.me/tool/kprm/
# Run by Carlos Luna from C:\Users\Carlos Luna\Desktop
# Computer Name: 1989AH
# OS: Windows 7 X64 (7601) Service Pack 1
# Number of passes: 2
- Checked options -
~ Registry Backup
~ Delete Tools
~ Restore System Settings
~ UAC Restore
~ Delete Restore Points
~ Create Restore Point
~ Delete Quarantines
- Create Registry Backup -
~ [OK] Hive C:\Windows\System32\config\SOFTWARE backed up
~ [OK] Hive C:\Users\Carlos Luna\NTUSER.dat backed up
[OK] Registry Backup: C:\KPRM\backup\2021-11-17-02-33-31
- Delete Tools -
## FRST
[OK] C:\Users\Carlos Luna\Desktop\FRST-OlderVersion deleted
[OK] C:\Users\Carlos Luna\Desktop\FRST64.exe deleted
[OK] C:\FRST deleted
- Restore System Settings -
[OK] Reset WinSock
[OK] FLUSHDNS
[OK] Hide Hidden file.
[OK] Show Extensions for known file types
[OK] Hide protected operating system files
- Restore UAC -
[OK] Set EnableLUA with default (1) value
[OK] Set ConsentPromptBehaviorAdmin with default (5) value
[OK] Set ConsentPromptBehaviorUser with default (3) value
[OK] Set EnableInstallerDetection with default (0) value
[OK] Set EnableSecureUIAPaths with default (1) value
[OK] Set EnableUIADesktopToggle with default (0) value
[OK] Set EnableVirtualization with default (1) value
[OK] Set FilterAdministratorToken with default (0) value
[OK] Set PromptOnSecureDesktop with default (1) value
[OK] Set ValidateAdminCodeSignatures with default (0) value
- Clear Restore Points -
~ [OK] RP named Scheduled Checkpoint created at 11/14/2021 18:45:56 deleted
~ [OK] RP named Restore Point Created by FRST created at 11/14/2021 22:05:17 deleted
[OK] All system restore points have been successfully deleted
- Create Restore Point -
[OK] System Restore Point created
- Display System Restore Point -
~ RP named KpRm created at 11/17/2021 07:34:10
-- KPRM finished in 70.66s --
