HDaudbus pops
You could be able to block device driver installation for "Intel(R) 300 Series Chipset Family SATA AHCI Controller" (iastorac.sys), Hardware ID--> "PCI\VEN_8086&DEV_A353&SUBSYS_380817AA&REV_10" with the following command (launched in an elevated command prompt):
reg add "hklm\Software\Policies\Microsoft\Windows\DeviceInstall\Restrictions\DenyDeviceIDs" /v "PCI\VEN_8086&DEV_A353&SUBSYS_380817AA&REV_10" /t reg_sz /f
If that shouldn't work, the following operations should block ALL devices drivers installations for your PC.
Valid for Windows 10 Version 10.0.19042.685 (Version 20H2 Build 19042.685), i.e. most recent version.
  • Go to Control Panel\Hardware and Sound\Devices and Printers
  • Right-click your PC
  • Click Device installation settings
  • It will appear a window saying:
    "Do you want to automatically download manufacturers' apps and custom icons that are available for your device?"
    Radio/option buttons:
    - "Yes (recommended)"
    - "No (your device might not work as expected)"
    Buttons:
    "Save changes"
    "Cancel"
  • Select no and click Save changes.
when I changed the driver from Intel to standard SATA, It was ok for a while but the cracks sound came back again.
here is the result, I tried both 1 and 0 value for this. (If this is the same value as before which we changed in the earlier post)
Re-launch the command and reboot:
reg add "hklm\SYSTEM\CurrentControlSet\Enum\PCI\VEN_8086&DEV_A353&SUBSYS_380817AA&REV_10\3&11583659&0&B8\Device Parameters\Interrupt Management\MessageSignaledInterruptProperties" /v MSISupported /t reg_dword /d 0 /f
Download the attached file, unzip its folder on the desktop, launch the following command, zip devices.html you'll find on your desktop, and send it here:
"%userprofile%\Desktop\devmanview x64 1.72 portable\devmanview.exe" /shtml "%userprofile%\desktop\devices.html"
