issues adding feature on Server 2016 standard has led CBS errors with KB4598243
dirtymac
Well-known member
Good evening folks! I have run into some trouble installing the Windows Server Backup feature on a Server 2016 Standard install (bare metal and not vm). I don't actually need this feature, rather I just wanted to test it for another server. Anyway, the server complained about needing an alternate path. I tried using the install media I used and that did not work. I also tried an identical install (same version, same hardware) and that did not work. I normally use WSUS but I currently have it disabled on this server as part of the troubleshooting process.
I ran "sfc /scannow" and "Dism /Online /Cleanup-Image /RestoreHealth". I found KB4598243 mentioned a number of times in the CBS log. I then ran SFCFix and no errors were found. I used FRST64 to do a search for KB4598243 and found number mentions of it in that log. I also ran the ComponentScanner.
I am attaching the logs in hopes that someone has a suggestion. Thanks!
Follow these instructions to remove an update.
  • Open the Start menu of Windows and type the command CMD
  • When command prompt opens, copy and paste the following command into it, then press enter.
wusa /uninstall /KB:4598243
  • Let me know if it says it was successful or you get the message: The update KB4598243 is not installed on this computer.
Good morning and thank you for the assistance! I meant to say in my original post that I did try to remove it and the update could not be found. I ran the uninstall again and I am including a screenshot of the error removing it.
I wanted to make sure that you could not remove this update, it seems your SearchReg in post#1 is complete and the COMPONENTS hive was loaded. So here's the next fix.
Download the
  • Press the Fix button.
Alright I was able to run that and it looks like everything was successful. I couldn't find any errors in the log.
Please try to install the Windows Backup Feature, if it fails attach a new copy of the CBS logs.
Unfortunately, I still cannot install the feature. I still get an error with code 0x800f081f and it complaining about the source files. The source image I am using is the one that this server was installed with so I'm not sure why it wouldn't find it.
I also tried installing it from PowerShell both with and without a source and both attempts failed. I will attach a screenshot of that as well.
Have you already rebooted the server, if not please do so and try again to install the backup feature. If it fails again attach a new copy of the CBS logs after running DISM.
Run the following DISM command and post the result. If it fails attach a new copy of the CBS log.
I did reboot the server yesterday before I attempted to install the feature again. The FRST fix did not request it, but I did it for good measure. I will the feature again and run DISM.
Let me know the result and attach the latest CBS logs when it fails.
I used Server Manager to attempt the feature add. I provided the same source as before. The error stated the source files could not be found.
After the failure I ran the DISM command.
I am attaching screenshots and the requested log files.
  • CBS.zip
    CBS.zip
  • dism.zip
    dism.zip
Download the
Right-click on the file FRST64.exe and choose Run as administrator.
  • Copy and paste the following (code) into the Search box and click the Search Files button.
wsbcmdlet.resources.dll
  • When the scan is complete, a message will display that 'Search.txt' is saved in the same folder FRST was started from. Notepad will open this file also.
  • Post the logfile Search.txt as attachment in your next reply.
Afterwards reboot the server and attempt to install the backup feature. If it fails attach a new copy of the CBS logs.
I ran the fix and rebooted the server. I rebooted the server and tried the install from Server Manager and it failed again. The error message is the same so I am including the CBS logs.
Download the
Microsoft-Windows-Foundation-Package~31bf3856ad364e35~amd64~~10.0.14393.0.*
Here are the results. Also, I just want to thank you again for the assistance with this.
Could you please perform the first step in post #16 again, attach only SFCFix.txt as result and don't try anything else.
