issues adding feature on Server 2016 standard has led CBS errors with KB4598243
I downloaded the previous file and it seems to be ok for me. I did remove the .reg extension on it. Either way, I have followed the new instructions and attached the file. This new file does not appear to be text-only.
Please run the following commands in an elevated prompt and post the result of both. If one of them fails attach a new copy of the CBS log.
SFC /Scannow
SFC completed successfully. DISM is looking for a source. I am attaching the output and the CBS logs. Also, the CBS logs rolled over so I am including two.
  • CBS.zip
    CBS.zip
Step 1.
Step 1.
Please try to install the backup feature again, if it fails attach a new copy of the CBS logs.
I tried with and without providing the source image and received the same error.
  • CBS.zip
    CBS.zip
Could you please run the following commands in an elevated command prompt, afterwards attach disk-checks.txt to your next post.
DISM /online /Get-Features /Format:table > "%userprofile%\desktop\dism-checks.txt"
DISM /online /get-packages /format:table >> "%userprofile%\desktop\dism-checks.txt"
DISM /online /get-intl >> "%userprofile%\desktop\dism-checks.txt"
Please try to install the Windows Backup feature again with Process Monitor running.
2. Try to install the Windows Backup feature just like you have in the past.
3. Stop Process Monitor as soon as it fails. You can simply do this by clicking the square (CTRL +E) on the toolbar as shown below.
5. Zip up the LogFile.PML and upload it to WeTransfer - Send Large Files & Share Photos Online - Up to 2GB Free and provide the link.
Please post the latest CBS logs as well, so I can use the time stamps to search for.
Please do the following to look at some folders, and attach a new copy of the COMPONENTS hive.
Download the
  • Press the Fix button.
Upload your COMPONENTS hive.
Thanks, I'll need to do some research on a VM, it seems I was able to reproduce this issue. So I will provide a new fix tommorow after a few tests.
