BrianDrab Emeritus Joined Oct 20, 2014 Posts 18,134 Location United States Apr 12, 2016 #21 Thanks. OK, what I would like you to do is to go to Add/Remove programs and uninstall Microsoft .NET Framework 3.5 SP1. Let me know when complete.
D Dave S Contributor Joined Mar 21, 2016 Posts 345 Location Weston.Massachusetts Apr 12, 2016 #22 [04/12/16,23:33:28] Microsoft .NET Framework 3.5 (x64) 'package': [2] Error: Installation failed for component Microsoft .NET Framework 3.5 (x64) 'package'. MSI returned error code 1603 [04/12/16,23:33:59] WapUI: [2] DepCheck indicates Microsoft .NET Framework 3.5 (x64) 'package' is not installed. I was unable to uninstall. Above is the error log
D Dave S Contributor Joined Mar 21, 2016 Posts 345 Location Weston.Massachusetts Apr 12, 2016 #23 I tried to repair and that did not work either. It appears that I will have to download the original installation file to install and then repair and maybe uninstall. I await your reply
BrianDrab Emeritus Joined Oct 20, 2014 Posts 18,134 Location United States Apr 13, 2016 #24 Try the .NET Repair tool from the link below. Download Microsoft .NET Framework Repair Tool from Official Microsoft Download Center
D Dave S Contributor Joined Mar 21, 2016 Posts 345 Location Weston.Massachusetts Apr 13, 2016 #25 no luck. In add/remove programs, selecting the repair option says no repair made but also says to download the original source package ( small file) and go from there. I will try that.
D Dave S Contributor Joined Mar 21, 2016 Posts 345 Location Weston.Massachusetts Apr 13, 2016 #26 error, setup stopped error code 1603. next?
BrianDrab Emeritus Joined Oct 20, 2014 Posts 18,134 Location United States Apr 13, 2016 #27 If the .NET Framework Repair tool that I provided a link to didn't work then please do the following. Let me know how it goes. https://blogs.msdn.microsoft.com/astebner/2008/08/28/net-framework-cleanup-tool-users-guide/
D Dave S Contributor Joined Mar 21, 2016 Posts 345 Location Weston.Massachusetts Apr 13, 2016 #28 here is the link to the readme file from the 3.5 attempted install Microsoft services
BrianDrab Emeritus Joined Oct 20, 2014 Posts 18,134 Location United States Apr 13, 2016 #29 I'm confused. Why are you trying to install 3.5 at the moment. Did you run the .NET Framework Cleanup Tool to remove the existing versions?
D Dave S Contributor Joined Mar 21, 2016 Posts 345 Location Weston.Massachusetts Apr 13, 2016 #30 Sorry about that. The repair option from add/remove , after it did not work, said to reinstall 3.5SP1 to make the repair--- so I tried that. I did that before I saw your Cleanup tool post. I am now going to try cleanup tool. Henceforth, I will do nothing before you tell me to. Thanks for all your help.
D Dave S Contributor Joined Mar 21, 2016 Posts 345 Location Weston.Massachusetts Apr 13, 2016 #31 failed. do you want to see the log?
BrianDrab Emeritus Joined Oct 20, 2014 Posts 18,134 Location United States Apr 13, 2016 #32 It failed to uninstall the .NET Framework using the tool? Wow. Never seen it fail. Yes, the log would be great.
D Dave S Contributor Joined Mar 21, 2016 Posts 345 Location Weston.Massachusetts Apr 13, 2016 #33 Microsoft services above is the log
BrianDrab Emeritus Joined Oct 20, 2014 Posts 18,134 Location United States Apr 13, 2016 #34 Thanks for the info Please perform a Clean Boot of your machine and then once in a clean boot please run the removal tool again and let me know the results.
D Dave S Contributor Joined Mar 21, 2016 Posts 345 Location Weston.Massachusetts Apr 13, 2016 #35 you mean run the cleanup tool again, right?
D Dave S Contributor Joined Mar 21, 2016 Posts 345 Location Weston.Massachusetts Apr 13, 2016 #37 success. Next?
BrianDrab Emeritus Joined Oct 20, 2014 Posts 18,134 Location United States Apr 13, 2016 #38 Excellent. Let's start with re-installing 3.5 with SP1 from the link below. Download Microsoft .NET Framework 3.5 Service pack 1 (Full Package) from Official Microsoft Download Center
D Dave S Contributor Joined Mar 21, 2016 Posts 345 Location Weston.Massachusetts Apr 13, 2016 #39 dhttps://onedrive.live.com/redir?resid=6683B21C07BD2957!124&authkey=!AP-T0p1SwwL1cvg&ithint=file%2ctxtownloaded fine; install started. Error in setup
D Dave S Contributor Joined Mar 21, 2016 Posts 345 Location Weston.Massachusetts Apr 13, 2016 #40 by the way, my attempt at reinstall was in clean boot environment
