[SOLVED] KB4534310 fails with error 0x80073701
Open an elevated commandprompt.
When command prompt opens, copy and paste the following command into it, then press enter.
REG LOAD HKLM\COMPONENTS C:\Windows\System32\config\COMPONENTS
This will load the components hive which is what we want.
Leave the commandprompt window open.
Right-click on the file FRST64.exe and choose Run as administrator.
Copy and paste KB4054518 into the Search box and click the Search Registry button.
When the scan is complete, a message will display that 'SearchReg.txt' is saved in the same folder FRST was started from. Notepad will open this file also. Close Notepad and attach the file 'SearchReg.txt' to your next reply.
You may close the commandprompt window now.
  3. Press the Fix button.
Try to install KB4534310 only and report the result.
If it fails attach the zipped cbs.log to your next reply.
KB4534310 installed successfully - thank you very much, really appreciate your help. However, upgrade to Windows 10 failed again, but at different, later stage, showing no error code, just came back to Windows 7 saying it was unsuccessful.
Attach the zipped cbs.log to your next reply.
Provide the Components Hive
4. The file will likely be too large to upload here so please upload to GoFile or WeTransfer and just provide the link here.
  • Then please upload the zip file (COMPONENTS.zip) to your favourite file sharing website (it will be too big to upload here). Examples of services to upload to are GoFile or One Drive or WeTransfer and then just provide the link in your reply.
Export registry as hive
  • Click on the Start button and in the search box, type regedit
  • Name this file ComponentBasedServicing (with no file extension) and save it to your Desktop.
  • Right-click on the saved file and choose Send To -> Compressed (zipped) Folder.
  • If the file is too large to upload here, please upload to WeTransfer and just provide the downloadlink here.
I runned the FRST64.exe, however in the log there is an error accessing the registry, as the entry:
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages\Microsoft-Windows-InternetExplorer-Optional-Package~31bf3856ad364e35~amd64~~10.2.9200.16521]
does not exist :
Restart the machine.
Try the upgrade to Windows 10 and report the result.
