kubajed Well-known member Joined Dec 31, 2021 Posts 48 Apr 9, 2023 #81 Failed Attachments CBS.rar CBS.rar 427 KB · Views: 1
P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 14,925 Apr 9, 2023 #82 Attach the files C:\$Windows.~BT\Sources\Panther\setupact.log and C:\$Windows.~BT\Sources\Panther\setuperr.log to your next reply.
kubajed Well-known member Joined Dec 31, 2021 Posts 48 Apr 10, 2023 #83 Please find attached. Attachments Setupact.rar Setupact.rar 572.7 KB · Views: 1
P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 14,925 Apr 10, 2023 #84 Install Update with DISM Download the update MSU here: http://download.windowsupdate.com/d...2798f0d248e08c292076980d2b954e6e1f2c8f99.msu Copy the MSU file to a convenient location (such as C:\temp). Click on the Start button and in the search box, type Command Prompt When you see Command Prompt on the list, right-click on it and select Run as administrator When command prompt opens, copy and paste the following commands into it, press enter after each cd C:\temp replace C:\temp with your path if different expand windows6.1-kb4592510-x64_2798f0d248e08c292076980d2b954e6e1f2c8f99.msu -f:* C:\temp DISM.exe /Online /Add-Package /PackagePath:C:\temp\windows6.1-kb4592510-x64.cab You should receive the message: The operation completed successfully. Make sure to allow the computer to restart if prompted. If you receive any other message: Post a screenshot of the Commandprompt window. Zip and attach the file C:\Windows\Logs\CBS\CBS.log
P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 14,925 Apr 10, 2023 #86 Restart the machine. Disabled the real-time protection of your antivirus (ESET Security). Try the upgrade again and report the result.
kubajed Well-known member Joined Dec 31, 2021 Posts 48 Apr 11, 2023 #87 Failed Attachments Logs.rar Logs.rar 1.8 MB · Views: 1
P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 14,925 Apr 11, 2023 #88 Install Update with DISM Download the update MSU here: http://download.windowsupdate.com/d..._3d7183f85e23d0173ac8cc5d12d66521e61d238f.msu Copy the MSU file to a convenient location (such as C:\temp). Click on the Start button and in the search box, type Command Prompt When you see Command Prompt on the list, right-click on it and select Run as administrator When command prompt opens, copy and paste the following commands into it, press enter after each cd C:\temp replace C:\temp with your path if different expand windows6.1-kb2952664-v23-x64_3d7183f85e23d0173ac8cc5d12d66521e61d238f.msu -f:* C:\temp DISM.exe /Online /Add-Package /PackagePath:C:\temp\windows6.1-kb2952664-v23-x64.cab You should receive the message: The operation completed successfully. Make sure to allow the computer to restart if prompted. If you receive any other message: Post a screenshot of the Commandprompt window. Zip and attach the file C:\Windows\Logs\CBS\CBS.log
P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 14,925 Apr 11, 2023 #90 Restart the machine. Disabled the real-time protection of your antivirus (ESET Security). Try the upgrade again and report the result.
kubajed Well-known member Joined Dec 31, 2021 Posts 48 Apr 11, 2023 #91 Failed Attachments Logs.rar Logs.rar 1.8 MB · Views: 1
P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 14,925 Apr 12, 2023 #92 Which actions do you take to upgrade ?
kubajed Well-known member Joined Dec 31, 2021 Posts 48 Apr 13, 2023 #93 I run system normally, insert a pendrive with Windows 10 installation, and run the setup.exe.
P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 14,925 Apr 13, 2023 #94 Open the page Download Windows 10 Follow the instructions at Using the tool to upgrade this PC to Windows 10 (click to show more or less information) Report the result.
kubajed Well-known member Joined Dec 31, 2021 Posts 48 Apr 14, 2023 #95 Finally, success! Thank you very much for your help, I really appreciate this!
P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 14,925 Apr 14, 2023 #96 Great and your welcome. Take care.
