Many updates will not install on a Win 7 system
OK, I've run the program. There were no error messages. As requested here is the text in SFCFix.txt.
Start time: 2016-03-13 19:19:08.973
Using .txt script file at C:\Users\THF\Desktop\SFCFixScript.txt [0]
RegistryScript::
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components.
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments.
Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_microsoft-windows-w..lient-aux.resources_31bf3856ad364e35_7.6.7600.256_en-us_d596e12800d25b42.
Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\microsoft-w..anguagepack_31bf3856ad364e35_7.6.7600.256_7f225668bfd2dbf0.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_microsoft-windows-w..lient-aux.resources_31bf3856ad364e35_7.6.7600.256_en-us_d596e12800d25b42.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\microsoft-w..anguagepack_31bf3856ad364e35_7.6.7600.256_7f225668bfd2dbf0.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments.
Finish time: 2016-03-13 19:20:16.849
Script hash: gmz9D+Hq10EHTrgcywtIcpDTnE7kg+rzguC2nx7ZOSc=
Same error. Let's see if the keys were indeed added (I'm sure they are, but since SFCFix doesn't query the keys added after running, I need to make sure of it). Follow the instructions below please.
Exporting a Custom Registry Key
Follow the instructions below to export the key specified below from the Registry and upload it.
    Run as Administrator
  • Enter the commands below and press on Enter;
    reg export "HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_microsoft-windows-w..lient-aux.resources_31bf3856ad364e35_7.6.7600.256_en-us_d596e12800d25b42" "%userprofile%\Desktop\Export1.txt"
    reg export "HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\microsoft-w..anguagepack_31bf3856ad364e35_7.6.7600.256_7f225668bfd2dbf0" "%userprofile%\Desktop\Export2.txt"
  • Two text files called Export1.txt and Export2.txt will appear on your desktop;
  • Upload the files on Dropbox, Google Drive or OneDrive and post the download URL here, or copy/paste their content directly in your next post;
Alright so the keys indeed exists. Follow the instructions below please.
Retrieving the COMPONENTS Hive
Follow the instructions below to retrieve your COMPONENTS Hive and send me it.
  • Open your Windows Explorer, and navigate to the C:\Windows\System32\Config folder;
  • In this folder, find the COMPONENTS file (there's no extension), and copy it to your Desktop;
    Note: If you receive an error message saying that the COMPONENTS file is in use, restart your computer and try again. If the error message persist, let me know.
  • Right-click on it, and select Send to... and choose Compressed (zipped) folder;
  • Upload the file on Dropbox, Google Drive or OneDrive and post the download URL for it here;
Thank you. Follow the instructions below please.
SFCFix - Fix Time
  • Download the attached SFCFixScript.txt and move the file to your Desktop;
    Note: Make sure that the file is named SFCFixScript.txt, do not rename it.
  • Drag the SFCFixScript.txt file over the SFCFix.exe executable and release it;
SFCFixScript.txt
I've done as requested. The contents of SFCFix.txt are attached below.
Start time: 2016-03-18 19:13:05.310
RegistryScript::
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\VersionedIndex\6.1.7601.17592 (win7sp1_gdr.110408-1631)\ComponentFamilies\amd64_microsoft-windows-w..lient-aux.resources_31bf3856ad364e35_en-us_cf0c2fcf53904b0b\v!7.6.7600.256.
WARNING: Failed to create backup for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\VersionedIndex\6.1.7601.17592 (win7sp1_gdr.110408-1631)\ComponentFamilies\amd64_microsoft-windows-w..lient-aux.resources_31bf3856ad364e35_en-us_cf0c2fcf53904b0b\v!7.6.7600.256.
Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\VersionedIndex\6.1.7601.17592 (win7sp1_gdr.110408-1631)\ComponentFamilies\amd64_microsoft-windows-w..lient-aux.resources_31bf3856ad364e35_en-us_cf0c2fcf53904b0b\v!7.6.7600.256.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\VersionedIndex\6.1.7601.17592 (win7sp1_gdr.110408-1631)\ComponentFamilies\amd64_microsoft-windows-w..lient-aux.resources_31bf3856ad364e35_en-us_cf0c2fcf53904b0b\v!7.6.7600.256.
Finish time: 2016-03-18 19:13:05.763
Script hash: Pg3gggx/WZhoCu230RzWs+cWXITns3xvOv1H4eOX5W8=
Two more keys missing. Follow the instructions below please.
SFCFix - Fix Time
SFCFixScript.txt
OK, as requested I've followed the instructions. The contents of SFCFix.txt are:
Start time: 2016-03-18 22:18:31.512
RegistryScript::
Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\wow64_microsoft-windows-w..lient-aux.resources_31bf3856ad364e35_7.5.7601.17514_en-us_292a8b37a9ef3b8c.
Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\microsoft-w..anguagepack_31bf3856ad364e35_6.1.7601.17514_60259c6fd6373717.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\wow64_microsoft-windows-w..lient-aux.resources_31bf3856ad364e35_7.5.7601.17514_en-us_292a8b37a9ef3b8c.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\microsoft-w..anguagepack_31bf3856ad364e35_6.1.7601.17514_60259c6fd6373717.
Finish time: 2016-03-18 22:18:31.825
Script hash: MmmB9rvxI3ilMJdsrGclluJRGAbBTdCalczXR7AprL8=
Try to install the update again please :)
Alright, follow the instructions below please.
SFCFix - Fix Time
SFCFixScript.txt
Alright, time to try to install the update again please :)
I'll need a new copy of your COMPONENTS Hive.
