My PC is acting very strange
Possibly a badly corrupted operating system, possibly because of the pirated programs/keygens/cracks previously installed in the computer.
Crystal, after the clean install DO NOT install anything not legally activated. :eek:
Let us know when you have something new.
Hello,
I didnt get to make a bootable USB for Windows clean installation but i have tried to do it with an original Windows 10 CD. And during the whole process, i wasnt able to delete/format my hard drive and its partitions. I decided to continue the installation and it was going well until it had to restart, it seems like it forgot the whole process and restarted as normal which meant bringing me to the login screen.
Now after all this, we have replaced my hard drive with an older one i used to use (it had Windows 7). Got Windows 10 installed on it now and is working fine.
I believe my OS is corrupted but there's literally no way i can restart/shut down my PC... without it going back to a previous time (or forgetting why it had to restart). Maybe my hard drive got corrupted along regardless of it being in a good condition, maybe like a broken record?
Never have i ever faced anything like this in my whole years of working with computers and seems like nobody else did either 😥
Where did you find this cd?
So you did a clean install of Windows 10, using the old hard disk and the "original Windows 10 cd" mentioned above?
And everything works fine?
From a good friend of mine.
Yes on my old hard drive. But its nearly impossible to do a clean install of Windows 10 on my other hard drive. Or anything that involves restarting my PC.
I guess its time to close this long frustrating thread, i feel bad for letting you guys wait and end up with a non-fixable hard drive 😥 but i greatly appreciate all the time, patience and effort you guys have provided ❤️
Hi, Crystal.
No reason to feel bad, and I wish we could find a solution to your problem here. Yes, it was a long road, but the only frustrating thing is you having a non responsive computer.
I assume that the problem with the computer "forgetting" everything after a restart is solved now. Right? If yes, all is good. If no, then perhaps a technician's opinion would help.
Some final thoughts/tips:
1. Make sure you have the latest Windows version installed in the new/old disk.
To check, type winver in the Search area and press Enter. The latest Windows 10 version is 21H1.
2. Keep the disk you removed. You can buy an external case for it (not expensive at all), connect it via usb cable in any computer and check it. If the disk is good, then something else was/is the problem.
Hello DR M,
Really appreciate the final thoughts & tips! I will make sure to recheck the other hard drive to tackle down the main issue as i still dont want to give up on it. Hopefully itll eventually let me format it.
And once again, im really thankful as i have learned a few things from you DR M ! 🙏🏻😁
Only a few???? 😁
You are very welcome, Crystal, and as I already said, I wish things were different for you.
Since the computer was infected, I have to close this topic with some useful information about your computer's safety from now on. Some of the following, are from Klein's (2005) article, So how did I get infected in the first place. Since then, the article has been reproduced or linked to in dozens of locations. As a result, many malware experts have continued updating it, to include current operating systems and software program information. My source is Security Garden, and I marked for you the following:
1. Keep your Windows updated!
It is important always to keep current with the latest security fixes from Microsoft. This can patch many of the security holes through which attackers can infect your computer.
2. Update 3rd Party Software Programs
Third Party software programs have long been targets for malware creators. It has been stated that "Adobe’s Reader and Flash and all versions of Java are together responsible for a total of 66 percent of the vulnerabilities in Windows systems exploited by malware.'' It's important to keep everything updated.
3. Update the browsers you use
Many malware infections install themselves by exploiting security holes in the Internet browser that you use. So... Keep them updated.
4. Be careful about what you download and what you open!
  • Many "freeware" programs come with an enormous amount of bundled spyware that will slow down your system, spawn pop-up advertisements, or just plain crash your browser or even Windows itself. Watch for pre-checked options such as toolbars that are not essential to the operation of the installed software.
  • Peer-to-peer (P2P) programs like Kazaa, BearShare, Imesh, Warez P2P, and others, allow the creation of a network enabling people to connect with other users and upload or download material in a fast efficient manner. BUT even if the P2P software you are using is "clean", a large percentage of the files served on the P2P network are likely to be infected.
  • Cracked or pirated programs are not only illegal, but also can make your computer a malware target. Have this in mind.
  • Do not open any files without being certain of what they are!
5. Avoid questionable web sites!
Visit web sites that are trustworthy and reputable. Many disreputable sites will attempt to install malware on your system through "drive-by" exploits just by visiting the site in your browser. Lyrics sites, free software sites (especially ones that target young children), cracked software sites, and pornography sites are some of the worst offenders. Also, never give out personal information of any sort online or click "OK" to a pop-up unless it is signed by a reputable company and you know what it is.
6. Registry cleaners/driver boosters/system optimizers
I do not recommend registry cleaners, system optimizers, driver boosters and the like. It is your computer and certainly your choice. However, please consider that modifying registry keys incorrectly can cause Windows instability, or make Windows unbootable. With registry cleaner and system optimization software programs, the potential is ever present to cause more problems than they claim to fix. Do note, however, that Microsoft does not support the use of registry cleaners. See Microsoft support policy for the use of registry cleaning utilities.
7. PC means personal computer!
Don't give access to your computer to friends or family who appear to be clueless about what they are doing.
8. Back-up your work!
Make back-ups of your personal files frequently. You never know when you'll have to reformat and start from scratch. You can always reformat and reinstall programs, but you cannot replace your data if you haven't made backups.
9. Must-Have Software
An anti-virus and an anti-spyware program is a necessity for the security of your computer. Be sure that you keep them updated, and that real time protection is enabled.
If you have any questions or concerns please don't hesitate to ask.
Only a few???? 😁
Whew, okay now its alot! 😁
Thank you so much for marking those important points for me, i will surely keep them in mind. Even though I didn't get my issue solved, its the effort that counts!
Thank you team, especially you DR M! :giggle:
