- Feb 12, 2015
- 1,904
Crystal, this is bad.
Just to check the disk (this doesn't need restart, so there will be no problem), please do the following:
- Download CrystalDiskInfo from here and save it to your Desktop.
- Run the installer to install the program.
- When finished, open the installed program by double clicking on it.
- If everything is working properly, you should see the status “Good“ displayed. Other statuses you might see include “Bad” (which usually indicates a drive that’s dead or near death), “Caution” (which indicates a drive that you should most likely be thinking about backing up and replacing), and “Unknown” (which just means that information could not be obtained).
- Take a screenshot of what you see.
