[SOLVED] Need help for Component Hive
Windows has reboot.
Last install event log is : Package KB4586786 failed to be changed to the Installed state. Status: 0x80070003.
CBS Folder is attached
SFCFix with the same script attached give this result :
Start time: 2020-11-19 22:01:02.028
Microsoft Windows 10 Build 18363 - amd64
Using .txt script file at D:\Eric\Bureau\SFCScript.txt [1]
FileScan::
[0: 3] C:\Windows\WinSxS\amd64_dual_wsynth3dvsc.inf_31bf3856ad364e35_10.0.18362.1_none_8aa34294d0560046\wsynth3dvsc.inf
 Expected: UNKNOWN Found: 0rjtyzosiIz2M4Vy89Epaqn00Ax+gTGAYJ87oIEZ+C0=
 Expected: 10.0.18362.1 Found: Version number not available.
Failed to trace component amd64_dual_wsynth3dvsc.inf_31bf3856ad364e35_10.0.18362.1_none_8aa34294d0560046 with return code -3.
 [C:\Windows\System32\DriverStore\FileRepository\wsynth3dvsc.inf_amd64_1f1fb2ce054f1bce\wsynth3dvsc.inf]
 [C:\Windows\INF\wsynth3dvsc.inf]
Finish time: 2020-11-19 22:01:22.563
Script hash: AFsVpcdZgCYOIs2Ccq/MoRkrgECTPObJRYZwyR5rSZ8=
Thanks, I think it would fail!
Attach setupapi.dev.log please.
You are right, install failed : Package KB4586786 failed to be changed to the Installed state. Status: 0x80070003.
But we progress, Samsung usb update disapeared.
Only this Cumulative update still there ;)
Can you attach the following file C:\WINDOWS\System32\DriverStore\FileRepository\multiprt.inf_amd64_5c187c6876ac2c97\multiprt.inf
Ok, and this one?
C:\Windows\WinSxS\amd64_dual_multiprt.inf_31bf3856ad364e35_10.0.18362.1_none_627905ed79c1430d\multiprt.inf
Thanks for the files.
!!! WARNING !!! The following fix is only relevant for this system and no other, applying this fix on another computer will not work and most likely will cause problems...
  • Download SFCFix.exe (by Niemiro) and save it to the Desktop
  • Download the file SFCFIX.ZIP, attached below, and save this to your Desktop
  • On your Desktop, make sure you have the two files:
    SFCFix.exe and
    SFCFIX.zip
  • Drag the file SFCFIX.zip onto the file SFCFix.exe and release it
  • The SFCFix tool will process the script
  • Upon completion, a log file SFCFix.txt should be created on your Desktop
  • Open the SFCFix.txt log and copy & paste the contents to your post
Here is the result of SFCFix :
Start time: 2020-11-20 16:57:17.384
Using .zip script file at D:\Eric\Bureau\SFCFix.zip [0]
Successfully took permissions for file or folder C:\WINDOWS\System32\DriverStore\FileRepository
Successfully created directory tree \\?\C:\WINDOWS\System32\DriverStore\FileRepository\multiprt.inf_amd64_5c187c6876ac2c97.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\FileRepository\multiprt.inf_amd64_5c187c6876ac2c97\multiprt.inf to C:\WINDOWS\System32\DriverStore\FileRepository\multiprt.inf_amd64_5c187c6876ac2c97\multiprt.inf.
Successfully restored ownership for C:\WINDOWS\System32\DriverStore\FileRepository
Successfully restored permissions on C:\WINDOWS\System32\DriverStore\FileRepository
Finish time: 2020-11-20 16:57:23.232
Script hash: W0SutfCwSjJZ1ksJV8+OwOpfp/0RVGYPbi2POxOvofA=
And after ?
Like you did before run:
pnputil  -a C:\Windows\WinSxS\amd64_dual_multiprt.inf_31bf3856ad364e35_10.0.18362.1_none_627905ed79c1430d\multiprt.inf
After executing the command attach the c:\Windows\inf\setupapi.dev.log
pnputil seems to be ok :
C:\WINDOWS\system32>pnputil  -a C:\Windows\WinSxS\amd64_dual_multiprt.inf_31bf3856ad364e35_10.0.18362.1_none_627905ed79c1430d\multiprt.inf
Utilitaire Plug-and-Play Microsoft
Traitement du fichier inf :            multiprt.inf
Package de pilotes correctement ajouté.
Nom publié :            multiprt.inf
Tentatives totales :              1
Nombre d’importations réussies : 1
Setupapi.dev.log is attached
C:\Windows\System32\DriverStore\FileRepository\multiprt.inf_amd64_5c187c6876ac2c97\multiprt.inf is now existing
Windows has rebooted and update seems to be OK :
- Package KB4586878 was successfully changed to the Installed state.
- Package KB4586786 was successfully changed to the Installed state.
Do you want to check something else or can I install 20H2 (October update)?
