[SOLVED] Need Help Please! SFCFix FAILED TO REPAIR CORRUPTED DATA on windows 7 64bit
Perform a new scan with FRST.
FRST Scan:
  1. Right-click to run FRST64.exe as administrator.
  2. Note: Ensure that the Addition.txt check box is checked at the bottom of the form within the Optional Scan area.
  3. Press the Scan button.
  4. Please wait for the tool to finish. It will produce two logfiles called FRST.txt and Addition.txt in the same directory the tool is run from (which should be the desktop)
  5. Post the logfiles FRST.txt and Addition.txt as attachment in your next reply.
  3. Press the Fix button.
Download
esetonlinescanner.exe.
Double-click on it to start it.
Click Computerscan
In the window "Choose a scantype", click Full Scan.
In the window "Detection of Potentially Unwanted Applications", select Enable ESET to detect and quarantaine potentially unwanted applications.
Click Start scan
The scanner will update itself first and start afterwards. This might take several hours to complete so please be patient.
Note: Do NOT click on 1 of 5 information fields that appear during the scan. It could start the installation of "ESET Internet Security". You can still abort this.
Do not use the computer for other purposes during the scan.
When the scan is completed, click "Save scan log", enter the filename "Eset.txt" and save in on your desktop.
Click several times on Continue to finish and close the "esetonlinescanner".
Attach the file "Eset.txt" on your desktop to your next reply.
I've attached the two log files.
I also read somewhere that since windows 7 reached its end of life,this version of windows has become too old to contact the Microsoft servers.Could that be a valid thing and be the reason for the update error code?
No, Windows Update tried to install SP1 yesterday but failed.
Open the list with available Windows Updates and take a screenshot and paste it into your next reply.
Read this on how to take a screenshot.
Windows update is still giving me the error code so I cant access the list of available updates.As for the sp1 update ,I downloaded that from the Microsoft update catalog and tried to do a manual install.I think it failed because I later noticed that the application's digital signature information stated that the digital signature is not valid.
Collect System Variables
  1. Click the Start button and in the search box, type Command Prompt
    set > "%userprofile%\Desktop\set.txt"
  4. This will create a file, set.txt on your Desktop. Please attach this to your next post.
The Path variable is missing some items.
Open the Explorer.
Right-click Computer at the left side and select Properties.
Click Advanced system settings.
Click the button Environment Variables
In the list System variables, select Path then click Edit
Copy and paste the text below in the inputbox. Make sure to replace the current text in the inputbox.
%SystemRoot%\system32;%SystemRoot%;%SystemRoot%\System32\Wbem;%SYSTEMROOT%\System32\WindowsPowerShell\v1.0\;C:\Program Files\Java\jdk-14.0.2\bin;C:\Program Files\MySQL\MySQL Shell 8.0\bin\
Click OK, click OK, and ones again OK to close all windows.
Restart the machine.
Great.
Step 2: FRST Scan
Good. The proxyserver seems to be gone.
Check Windows Update again and report the result. Does it show a list of available important updates now ?
This will create a file, cbs.txt on your Desktop. Please attach this to your next post.
Note: if the file is too big to upload to your next post please upload via a service such as Filedropper or One Drive or WeTransfer and just provide the download link.
Restart the computer.
If it fails, attach the file cbs.log to your next reply, see message #38
