Need help with memory dumps. 3 crashs, no errors or bsods.
I'll do that. Right now I'm mobile and laying in bed. I'll run all the tests when I have some free time.
Btw do you know of a dos based mem tester. I looked up memtest86 and that was a Windows client.
I believe memtest is a blue background with white text similar to most BIOS...
Regardless it is the way to go
Sorry, I thought you were referring to DOS as MS-DOS vs Lin/unix Shells...
Not Disk OS :banghead:
Thank you yes dos based is what I was thinking of. Anyways I'll have my arms up in tests. So fellas how about a order to run the tests in?
I would think the bsod would be the first one but an order to run them in would be nice.
Hi -
1. jcgriff2 BSOD app; steps 1-4 only - attach zip to next post
https://www.sysnative.com/forums/sh...D)-Posting-Instructions-Windows-8-7-amp-Vista
2. HDD diags -
3. Memtest86+
Regards. . .
jcgriff2
@ Anthony N - my apologies... my name is listed as the one who locked the thread at 04:38 EST - the time of my last post.
It was accidental, I assure you.
John
Your zip contained 3 files - 1 named "jcgriff2.txt" - there is no such output file from the app. I'm not sure where that file came from.
PERFMON Health report came out & is asking about your HDD:
[TABLE="class: block"]
[TR]
[TD="class: h4"][/TD]
[TD="class: info"]
The VolumeDirty flag is set on the
disk
[/TD]
[/TR]
[TR]
[TD="class: h4, width: 12%"]Cause:
[/TD]
[TD="class: info b2"]A logical disk has the dirty bit
set.
[/TD]
[/TR]
[TR]
[TD="class: h4, width: 12%"]Details:
[/TD]
[TD="class: info"]This disk has been marked as dirty, it may be
experiencing errors or might have not been shut down correctly
[/TD]
[/TR]
[TR]
[TD="class: h4, width: 12%"]Resolution:
[/TD]
[TD="class: info b2"]1. Run chkdsk on the drive and document any
errors identified.
[/TD]
[/TR]
[TR]
[TD="class: h4, width: 12%"][/TD]
[TD="class: info"]2. If chkdsk determines that there are errors on
the drive run chkdsk /f to repair the errors.
[/TD]
[/TR]
[/TABLE]
Please re-run steps 1 & 2 so we can get the files that will likely help us to help you.
https://www.sysnative.com/forums/bs...g-instructions-windows-8-7-vista.html#post303
Regards. . .
jcgriff2
Hi -
Your 3 GB RAM configuration = 1x1 + 1x2
Are the sticks matched?
Event Viewer recorded 2,046 entries identical to this one that started during Windows installation 2 days ago on 10 December -
Event[4180]:
  Log Name: System
  Source: Disk
  Date: 2012-12-10T03:06:53.040
  Event ID: 11
  Level: Error
  Description:
[COLOR=#ff0000]The driver detected a controller error on \Device\Harddisk0\DR0[/COLOR].
Last HDD controller error entry - yesterday afternoon -
 Date: [B]2012-12-11[/B]T[COLOR=#ff0000]14:32[/COLOR]:23.623
Disk0 is your Hitachi HDS721010CLA HDD -
chkdsk results -
There seems to be something not right with that drive. I'll ask someone more familiar than I am with controller errors to reply.
This is like the entry after re-start from the freeze - occurred ~2 hours after Windows instal began -
Event[847]:
  Log Name: System
  Source: EventLog
  Date: 2012-12-10T14:50:09.000
  Event ID: 6008
  Level: Error
  Description:
[COLOR=#ff0000]The previous system shutdown at 4:50:14 AM on ?12/?10/?2012 was unexpected.
[/COLOR]
Thank you for the files.
Regards. . .
jcgriff2
I'm not sure yet what the repairs are.
I'm not familiar enough with controller hardware. IDK if it's a cable, driver, ...??
chkdsk came out with -0- bad sectors -- OK
SeaTools for DOS passed
HD Tune - OK
It does seem like your HDD itself is OK.
EDIT: Do you know what the controller error is?
Write your reply...
