[SOLVED] need help
tried no luck
(then again took me 10 min to figure this morning that had chrome muted when went outside with laptop)
looking at that i'm thinking the problem PROBABLY software not hardware
I only see results from the 7th, and all of those tests are in read only mode. This might take quite a while to run the test, so you may want to schedule the disk check then reboot and let it run overnight.
chkdsk /r
  1. Click on the Start
    chkdsk /r
  4. Reboot
  5. Download ListChkdskResult.exe (by SleepyDude) from the link below:
    https://dl.dropboxusercontent.com/u/12354842/My Tools/ListChkdskResult.exe
  6. Double click on it to run it. It will take a few seconds to scan, then it will open a Notepad window with the log. Copy and paste the contents of this into your next post please!
Looks like the filesystem is okay :)
2017-01-11 17:05:48, Info                  CSI    00001db0 [SR] Beginning Verify and Repair transaction
2017-01-11 17:05:52, Error                 CSI    00001db1 (F) STATUS_OBJECT_NAME_NOT_FOUND #3798845# from Windows::Rtl::SystemImplementation::DirectFileSystemProvider::SysCreateFile(flags = (AllowSharingViolation), handle = {provider=NULL, handle=0, name= ("null")}, da = (SYNCHRONIZE|FILE_READ_ATTRIBUTES), oa = @0xf74647b1e0->OBJECT_ATTRIBUTES {s:48; rd:NULL; on:[121]'\??\C:\WINDOWS\WinSxS\amd64_microsoft-windows-f..etype-yugothiclight_31bf3856ad364e35_10.0.14393.82_none_326eb39ed6110748'; a:(OBJ_CASE_INSENSITIVE)}, iosb = @0xf74647b1c0, as = (null), fa = 0, sa = (FILE_SHARE_READ|FILE_SHARE_WRITE|FILE_SHARE_DELETE), cd = FILE_OPEN, co = (FILE_SYNCHRONOUS_IO_NONALERT|0x00004000), eab = NULL, eal = 0, disp = Invalid)
[gle=0xd0000034]
2017-01-11 17:05:52, Error                 CSI    00001db2@2017/1/11:23:05:52.769 (F) onecore\base\wcp\sil\merged\ntu\ntsystem.cpp(2898): Error STATUS_OBJECT_NAME_NOT_FOUND originated in function Windows::Rtl::SystemImplementation::DirectFileSystemProvider::SysCreateFile expression: (null)
[gle=0x80004005]
2017-01-11 17:05:52, Info                  CBS    Added C:\WINDOWS\Logs\CBS\CBS.log to WER report.
2017-01-11 17:05:53, Info                  CBS    Added C:\WINDOWS\Logs\CBS\CbsPersist_20170111041012.log to WER report.
2017-01-11 17:05:53, Info                  CBS    Added C:\WINDOWS\Logs\CBS\CbsPersist_20170111023900.log to WER report.
2017-01-11 17:05:53, Info                  CBS    Added C:\WINDOWS\Logs\CBS\CbsPersist_20170111012731.log to WER report.
2017-01-11 17:05:53, Info                  CBS    Could not get active session for current session file logging [HRESULT = 0x80004003 - E_POINTER]
2017-01-11 17:05:53, Info                  CBS    Not able to add pending.xml to Windows Error Report. [HRESULT = 0x80070002 - ERROR_FILE_NOT_FOUND]
2017-01-11 17:05:53, Info                  CBS    Not able to add pending.xml.bad to Windows Error Report. [HRESULT = 0x80070002 - ERROR_FILE_NOT_FOUND]
2017-01-11 17:06:15, Error                 CSI    00001db3 (F) STATUS_OBJECT_NAME_NOT_FOUND #3798844# from Windows::Rtl::SystemImplementation::CDirectory::OpenExistingDirectory(...)[gle=0xd0000034]
2017-01-11 17:06:15, Error                 CSI    00001db4 (F) STATUS_OBJECT_NAME_NOT_FOUND #3798843# from Windows::Rtl::SystemImplementation::CDirectory_IRtlDirectoryTearoff::OpenExistingDirectory(flags = 0, da = (SYNCHRONIZE), oa = @0xf74647bc00->SIL_OBJECT_ATTRIBUTES {s:40; on:"amd64_microsoft-windows-f..etype-yugothiclight_31bf3856ad364e35_10.0.14393.82_none_326eb39ed6110748"; a:(OBJ_CASE_INSENSITIVE)}, sa = (FILE_SHARE_READ|FILE_SHARE_WRITE|FILE_SHARE_DELETE), oo = (FILE_DIRECTORY_FILE|FILE_SYNCHRONOUS_IO_NONALERT|FILE_OPEN_FOR_BACKUP_INTENT), dir = NULL, disp = Invalid)
[gle=0xd0000034]
2017-01-11 17:08:24, Info                  CBS    Trusted Installer is shutting down because: SHUTDOWN_REASON_AUTOSTOP
Let's replace the missing file.
Download SFCFix.zip from Sendspace.com - send big files the easy way
SFC Scan
  4. This will create a file, cbs.txt on your Desktop. Please zip and attach this to your next post.
Let's try DISM again.
DISM /RestoreHealth Scan
  1. Right-click on the Start
  3. When DISM finishes scanning your component store, zip up and attach your CBS log to your next post:
    C:\Windows\Logs\CBS\CBS.log
If the zip file is larger than 8MB, please use a file sharing service such as OneDrive, DropBox, SendSpace, etc. and include the link with your reply.
