[SOLVED] need help
Version: 10.0.14393.0
Image Version: 10.0.14393.0
[===== 9.5% ]
Error: 1726
The remote procedure call failed.
I'll need the CBS log :) (C:\Windows\Logs\CBS\CBS.log)
Please be sure to zip the log before attaching it.
2017-01-12 13:01:56, Error                 CSI    00001d5f (F) STATUS_OBJECT_NAME_NOT_FOUND #3798844# from Windows::Rtl::SystemImplementation::CDirectory::OpenExistingDirectory(...)[gle=0xd0000034]
2017-01-12 13:01:56, Error                 CSI    00001d60 (F) STATUS_OBJECT_NAME_NOT_FOUND #3798843# from Windows::Rtl::SystemImplementation::CDirectory_IRtlDirectoryTearoff::OpenExistingDirectory(flags = 0, da = (SYNCHRONIZE), oa = @0x48002fbc00->SIL_OBJECT_ATTRIBUTES {s:40; on:"amd64_microsoft-windows-f..etype-yugothiclight_31bf3856ad364e35_10.0.14393.82_none_326eb39ed6110748"; a:(OBJ_CASE_INSENSITIVE)}, sa = (FILE_SHARE_READ|FILE_SHARE_WRITE|FILE_SHARE_DELETE), oo = (FILE_DIRECTORY_FILE|FILE_SYNCHRONOUS_IO_NONALERT|FILE_OPEN_FOR_BACKUP_INTENT), dir = NULL, disp = Invalid)
[gle=0xd0000034]
It seems that the same file is still missing.
Please be sure you follow the instructions below (download SFCFix.zip, drag and drop onto SFCFix.exe, include SFCFix.txt with your reply etc.)
SFCFix.zip
Start time: 2017-01-12 14:56:21.102
Microsoft Windows 10 Build 14393 - amd64
Using .zip script file at C:\Users\majnoon\Desktop\odb\SFCFix (1).zip [1]
Finish time: 2017-01-12 14:56:25.518
Script hash: xdtA/yVkRmp3AL9gqGr4WFrJ2amyA38buMkZsa2+mhk=
Start time: 2017-01-12 15:24:18.095
Using .zip script file at C:\Users\majnoon\Desktop\odb\SFCFix.zip [0]
Successfully took permissions for file or folder C:\WINDOWS\WinSxS
Successfully created directory tree \\?\C:\WINDOWS\WinSxS\amd64_microsoft-windows-f..etype-yugothiclight_31bf3856ad364e35_10.0.14393.82_none_326eb39ed6110748.
Successfully copied file C:\Users\majnoon\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-f..etype-yugothiclight_31bf3856ad364e35_10.0.14393.82_none_326eb39ed6110748\YuGothL.ttc to C:\WINDOWS\WinSxS\amd64_microsoft-windows-f..etype-yugothiclight_31bf3856ad364e35_10.0.14393.82_none_326eb39ed6110748\YuGothL.ttc.
Successfully restored ownership for C:\WINDOWS\WinSxS
Successfully restored permissions on C:\WINDOWS\WinSxS
Finish time: 2017-01-12 15:24:43.296
Script hash: RTmkPBESFcjXRVSj4DB10fxmGlEtnJnUpIQoEbcj0vI=
Much better!
Now let's run DISM to verify that the replacement was successful. Once it finishes, zip and attach CBS.log with your reply.
DISM /RestoreHealth Scan
  1. Right-click on the Start
  3. This will create a file, cbs.txt on your Desktop. Please zip and attach this to your next post.
If the zip file is larger than 8MB, please use a file sharing service such as OneDrive, DropBox, SendSpace, etc. and include the link with your reply.
got this
[===== 9.4% ]
Error: 1726
LOOKS like it may be a japanese font
removing ms office now
(no use it)
2017-01-12 15:56:39, Error                 CSI    00000007 (F) Failed on regenerating file [l:11]'YuGothM.ttc'[gle=0x80004005]
2017-01-12 15:56:39, Error                 CSI    00000008@2017/1/12:21:56:39.444 (F) onecore\base\wcp\componentstore\corruptionrepair.cpp(1824): Error STATUS_INTERNAL_ERROR originated in function ComponentStore::CRawStoreLayout::ReplaceFileW expression: Disposition == DecompressFile_Disposition::Decompressed
[gle=0x80004005]
Looks like DISM is expecting the decompressed file.
Let's set the file mark to indicate it is compressed, then try it again.
View attachment SFCFix.zip
There's another font to replace as well.
Download SFCFix.zip from Sendspace.com - send big files the easy way
