- Mar 16, 2015
- 8,061
Alright, follow the instructions below please.
Replacing the COMPONENTS Hive
Follow the instructions below to replace the COMPONENTS Hive.
- Download the attached COMPONENTS.zip file, and save it on your Desktop;
- Right-click on it, and select Extract all.... Once done, the folder with the COMPONENTS file will open. This will be your new COMPONENTS Hive.
- Navigate to the C:\Windows\System32\config folder;
- In it, find the COMPONENTS file and rename it to COMPONENTS_bak;
Note: If you receive a message saying that the file is in use, restart your computer and try again. - Once done, copy the new COMPONENTS file I sent you in the C;\Windows\System32\config folder;
