[SOLVED] need to fix OS from an sfcfix log
I really doubt it's this one. Follow the instructions below please.
Uninstall a Windows Update - Command Prompt
Follow the instructions below to uninstall a Windows Update manually via the command prompt.
  • On Windows Vista & 7, click on the Windows Start Menu, then enter cmd in the search box, right-click on the cmd icon and select Run as Administrator
  • Enter the command below (you can copy/paste it, to paste in the command prompt, right-click inside it and select Paste):
    wusa /uninstall /KB:2467174
  • Let me know the outcome of the command: either it uninstall the update or either it says that the update isn't installed on the system;
Wondering, do you still have this computer in your hands, or did you give it back? If the latter, I'll just mark this thread as solved since we cannot go on.
no I don't have it anymore.
Alright, marking this thread as [SOLVED], thank you :)
ok, he brought it back. I'll try the "wusa /uninstall /KB:2467174" and then tell you what happens.
it says update not found.
Any ideas on that method of removing this update's references from the registry? Because you says we can't fix this particular checksur error.
Thanks
Sorry it seems that I missed your replies, since this thread have been moved in a different folder of my "Subscribed" threads (since I marked it as SOLVED). I'll need a fresh CheckSUR log now.
System Update Readiness Tool (SURT) - Scan
Follow the instructions below to run a scan with the System Update Readiness Tool (SURT) and provide a log;
  • Download the right version of SURT for your system;
    • Your version of Windows is:
  • Once downloaded, execute the installer, and go throught the installation (this process can take around 15-20 minutes);
  • On completion, a log will be created in C:\Windows\Logs\CBS\CheckSUR.log;
  • Attach this log in your next reply;
Alternatively, if these instructions are unclear for you, you can follow the tutorial below.
