Not Received Help?
Status
Not open for further replies.
Thank you Richard and don't worry-I understand you very well, because i graduated university some years ago and know how important is this exam for you. :-) Good luck tomorrow!
See you,
Sabina
See you,
Sabina
Thank you so much for your understanding. I have now replied.
Richard
[h=2]Windows 7 Compaq presario.. 59 windows updates fail error msg 80070246[/h]
Know you are busy, but the post said to post if no help in 48 hours. Thank you!
Yep. Like AndrewC I'm chasing again and feel bad because you obviously already have stuff piled on your plate. When you get a chance please respond to the second log I posted in this thread. :grin1:
regards
HalfaClue
Hi Guys,
Sorry to chase again but if you get chance to take a look at the issue below it would be great :-)
As above I've seen your away / run off your feet but when you do get chance taking a look at this one would also be much appreciated :cool3:
Can't install IE10 (9c59) via windows updates or manual install
Regards
Andrew
regards
HalfaClue
Hello to you both.
I am so, so sorry for the terrible delay here. I am currently at work and the websites I need to access are sadly blocked, but I will make both of your threads an absolute priority tonight. I will take them on as soon as I come through the door and before anything else. I have taken a look at both of your logs, however, and both look as though they should be fixable (can't guarantee until I try, but neither is immediately impossible).
Richard
I've got a few weeks off until my next exam meaning I should have plenty of time over the weekend to help out :) I'm just about to go out now, but I'll be available tomorrow.
[h=2]Windows 7 Compaq presario.. 59 windows updates fail error msg 80070246[/h]Please remember me! Thanks!
Hi guys. I replied to the latest help provided but haven't had a response for a week. Just in case you have overlooked my thread I'm posting this reminder. No rush, just whenever you have time ... (I'm reminded of a T-shirt I have with the words - "Let me drop everything and work on your problem" he he)
Thanks
Rob
hello :confused2:
I would like to revive you on my topic posted on 2013-11-30 in the Windows 8 Forum | Windows RT https://www.sysnative.com/forums/wi...s-suspicions-corruptions-or-other-things.html: Can not be in the right place?
I thank you in advance ..:beerchug2:
yet my notebook does not have any problem .. given the number of troubleshooting you have to do, but I would like to congratulate the team for your work and your application
cordially
Pierre :wave:
Sorry for the delay - I'll reply very soon!
wondering if Tom has had any luck locating required files per this thread
https://www.sysnative.com/forums/windows-update/7744-windows-windows-vista-sp1-update-fails.html
Best Regards
Dave
Hi Dave,
Sorry for the delay. I recently updated to Windows 8 and completely lost track of the threads I needed to reply to. I'll get those files to you as soon as possible!
Hello,
Can someone helps me out with this?
[h=1]Windows 7 Pro 64-bit Update error 800F0900[/h]https://www.sysnative.com/forums/windows-7-%7C-windows-vista/7759-windows-7-pro-64-bit-update-error-800f0900.html
It has been a while back since my last post.
Thank you very much!
BrxGrp
Umm, your thread is solved isn't it? If you're still having issues, can you post in your thread with the details? If you don't tell us something is wrong, we don't know there's something to fix - we may be able to fix Windows Update problems, but we're not mind readers :p
You said:
Yes! It works now. Finally, windows completed all of its updates.
You guys are the best. THANK YOU !!!
-BrxGrp
Status
