Not Received Help?
Status
Not open for further replies.
Hello everyone,
I just wanted to apologise for the delay in responding to everyone's threads! It's an incredibly busy time of the year for the small Windows Update team we have here as we're all in full time education and are fast approaching exam territory. I will personally see that I get to everyone's threads eventually, but in return I ask only for your patience whilst we try and work through the backlog - there's only a few of us and lots of you!
I tried my best to clear as many threads as possible whilst I was on my Easter holidays but now I'm back at university my workload has increased significantly and I'm having to cut back on my time here.
Right now I have a few dozen tabs open of threads I need to reply to, so I'll transfer the list to here (in chronological order) and work through that from oldest to newest. If you don't see your thread on the list, please let me know and I'll add it. I need to work through the list and order it, but I will edit this post to add it when it's done.
Hope you all understand :)
Tom
No reply Anas: https://www.sysnative.com/forums/wi...ound-corrupt-files-but-was-unable-to-fix.html
Solved toomanyhobbies: https://www.sysnative.com/forums/wi...tallation-failure-error-80073712-for-sp1.html
Clean Install RaulG: https://www.sysnative.com/forums/windows-update/8706-error-80070002-a.html#post69279
NavySpook78: https://www.sysnative.com/forums/wi...rror-code-0x80073712-windows-7-sp1-64bit.html
sladen: https://www.sysnative.com/forums/windows-update/9560-80070490-error-issue.html
Risen91: https://www.sysnative.com/forums/windows-update/8934-windows-7-error-code-800b0100.html
DavMe: https://www.sysnative.com/forums/windows-update/9611-internet-explorer-10-fails-to-install.html
Pedge: https://www.sysnative.com/forums/windows-update/9580-windows-8-1-update-1-a.html
Selo: https://www.sysnative.com/forums/wi...s-update-error-80070490-error-80073712-a.html
jgaf: https://www.sysnative.com/forums/wi...le-checker-scannow-cannot-repair-files-2.html
yostb: https://www.sysnative.com/forums/windows-update/9450-todays-windows-7-windows-update-failure.html
Richard maurizio: https://www.sysnative.com/forums/windows-update/9628-internet-explorer-dont-install.html
seamatt: https://www.sysnative.com/forums/windows-update/9147-system-file-checker-errors.html
Added by Stephen (Thanks Tom!)
Clean install Icarmona: https://www.sysnative.com/forums/wi...indows-8-1-update-1-failing-continuously.html
kit316: https://www.sysnative.com/forums/windows-update/9497-windows-update-error-80070002-a.html
Pravin: https://www.sysnative.com/forums/wi...n-found-corrupt-files-unable-to-repair-2.html
Fortunately I had quite a few duplicates in the tabs I had open, so I only have 11 threads to reply to (the list can be found in my previous post above). I will be doing two at a time until I get through them all and will remove the thread from the list when finished, as well as adding new ones as they come :)
Tom
N.B. Richard & Stephen, feel free to edit my post if you need to add or remove any to the list!
Tom,
Please remove me from the no reply. Was a busy end of the week and weekend for me and I forgot to check back here. I will make sure to check back more often. Thanks again.
Hey guys, its been a while since someone replied to my post. I posted my latest cbs.log and sfcfix.txt for you to review. Just wanted to make sure you don't forget about me :-). The PC seems to be functioning well, even though it shows many errors.
My post
Thanks for all the help.
Hi, Wasn't sure if it's too soon to be added to the never-ending list (www.sysnative.com/forums/windows-up...77-and-kb2920189-not-installing-800703f1.html). Perhaps the current maximum reply time could be kept updated somewhere? I believe Microsoft should pay everyone who experiences trouble because of their malfunctioning software, then they would quickly change their policies and this list would probably become much shorter. Only when a competitive intelligent operating system (a computer with a brain instead of an airhead) is designed, will they be forced to make amends or lose customers! :startorb:
Status
