[SOLVED] Problems to update win 7
Hi Peter,
Yes there is no reason to continue with this old system. I will contribute for all the work you have done. I will fix that in the coming days :D
You have been very helpful and i am very grateful for that
Kind Regards
Pär
Hi again Peter,
I have now been donating 300$ i hope that is ok for you, if not let me know.
Kind Regards
Pär
Your welcome and thanks for the donation. (y)
Follow the instructions below to cleanup the tools and logfiles used in this thread.
Rename the file FRST64.exe to uninstall.exe and run it. This will remove all files and folders created by FRST and the tool itself.
Reboot the machine to complete.
You may remove all other tools and log files.
