[SOLVED] Problems with Sfc.exe
No important updates are available. 44 optional updates:
I believe I checked on the NVIDIA update and it was a false positive so I ignored it.....
Please open Command Prompt as Admin and enter the following:
ICACLS c:\Windows\System32\SearchIndexer.exe /grant administrators:F
If the command succeeds, please try SFC Scan again.
C:\Windows\System32>ICACLS c:\Windows\System32\SearchIndexer.exe /grant administrators:F
c:\Windows\System32\SearchIndexer.exe: Access is denied.
Successfully processed 0 files; Failed processing 1 files
FRST Fix
Fix result of Farbar Recovery Scan Tool (x64) Version: 16.05.2018 01
Ran by dbridges (18-05-2018 23:08:45) Run:2
Running from C:\Users\dbridges\Desktop
Loaded Profiles: dbridges (Available Profiles: dbridges & AdminX & Administrator)
Boot Mode: Normal
fixlist content:
SetDefaultPermissions: C:\Windows\System32\searchindexer.exe
SetDefaultPermissions: C:\Windows\System32\searchindexer.exe => Error: No automatic fix found for this entry.
==== End of Fixlog 23:08:45 ====
FRST Fix
Step#1 - ChkDsk Scan
1. Click your Start Orb in the lower left of your computer and type cmd in the search box.
2. Once the cmd program is found, right-click on it with your mouse and select Run as administrator as shown below.
3. Answer Yes when asked to allow.
4. You should now have a black window open that you can type in to.
5. Please type chkdsk /f and then press enter.
6. Chkdsk will start to run. Please allow it to finish.
7. Download ListChkdskResult.exe by SleepyDude and save it on your desktop. If it's already downloaded to your desktop, just skip this step.
8. Right-click this file and select Run as administrator (Allow if prompted)and a text file will open (and also be saved on the desktop as ListChkdskResult.txt).
Please copy the contents of this file and paste into your next post.
Says the voume is in use and offers to do the chkdsk upon reboot. This is with all apps & Explorer windows closed. Should I just let it do that and then forward the log ?
------< Log generate on 5/19/2018 2:04:10 PM >------
Category: 0
Computer Name: dbridges-HP
Event Code: 1001
Record Number: 23928
Time Written: 05-19-2018 @ 19:02:58
Event Type: Information
User:
Message:
Checking file system on C:
Volume label is OS.
CHKDSK is verifying files (stage 1 of 3)...
342272 file records processed.
File verification completed.
847 large file records processed.
0 bad file records processed.
0 EA records processed.
127 reparse records processed.
CHKDSK is verifying indexes (stage 2 of 3)...
423838 index entries processed.
Index verification completed.
0 unindexed files scanned.
0 unindexed files recovered.
CHKDSK is verifying security descriptors (stage 3 of 3)...
342272 file SDs/SIDs processed.
Cleaning up 1317 unused index entries from index $SII of file 0x9.
Cleaning up 1317 unused index entries from index $SDH of file 0x9.
Cleaning up 1317 unused security descriptors.
40784 data files processed.
41249056 USN bytes processed.
Windows has checked the file system and found no problems.
959781887 KB total disk space.
242548764 KB in 299404 files.
178796 KB in 40785 indexes.
0 KB in bad sectors.
481871 KB in use by the system.
716572456 KB available on disk.
239945471 total allocation units on disk.
179143114 allocation units available on disk.
Internal Info:
00 39 05 00 e9 30 05 00 48 71 09 00 00 00 00 00 .9...0..Hq......
97 04 00 00 7f 00 00 00 00 00 00 00 00 00 00 00 ................
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
Category: 0
Event Code: 1001
Record Number: 9327
Time Written: 12-07-2017 @ 21:01:12
User:
Message:
Volume label is OS.
that you continue.
The attribute of type 0x80 and instance tag 0x4 in file 0x195c8
has allocated length of 0xc0000 instead of 0xd0000.
Deleting corrupt attribute record (128, "")
from file record segment 103880.
Cleaning up instance tags for file 0x1fba0.
189696 file records processed.
898 large file records processed.
44 reparse records processed.
255926 index entries processed.
189696 file SDs/SIDs processed.
Cleaning up 493 unused index entries from index $SII of file 0x9.
Cleaning up 493 unused index entries from index $SDH of file 0x9.
Cleaning up 493 unused security descriptors.
Inserting data attribute into file 103880.
33117 data files processed.
37440328 USN bytes processed.
Correcting errors in the master file table's (MFT) BITMAP attribute.
Correcting errors in the Volume Bitmap.
112932292 KB in 141862 files.
88000 KB in 33117 indexes.
323363 KB in use by the system.
846438232 KB available on disk.
211609558 allocation units available on disk.
Internal Info:
00 e5 02 00 90 ab 02 00 1a f5 04 00 00 00 00 00 ................
43 01 00 00 2c 00 00 00 00 00 00 00 00 00 00 00 C...,...........
