[SOLVED] Problems with Sfc.exe
FRST Fix
Fix result of Farbar Recovery Scan Tool (x64) Version: 16.05.2018 01
Ran by dbridges (31-05-2018 15:38:15) Run:6
Running from C:\Users\dbridges\Desktop
Loaded Profiles: dbridges (Available Profiles: dbridges & AdminX & Administrator)
Boot Mode: Normal
fixlist content:
CreateRestorePoint:
R2 hfFilter; C:\windows\System32\drivers\hfFilter.sys [41744 2017-10-18] ()
hfFilter => Unable to stop service.
"HKLM\System\CurrentControlSet\Services\hfFilter" => removed successfully
hfFilter => service removed successfully
Could not move "C:\windows\System32\drivers\hfFilter.sys" => Scheduled to move on reboot.
Result of scheduled files to move (Boot Mode: Normal) (Date&Time: 31-05-2018 15:43:03)
C:\windows\System32\drivers\hfFilter.sys => moved successfully
==== End of Fixlog 15:43:03 ====
Yea !
Scan is clear:
log attached.
Forgive what might be an obvious question, but would it be accurate to say that although the sfc scan now reports no integrity violations that based on the cbs log there are still problems with the system ?
