Running DISM- CBS MUM Missing Total count 1691
Download & Run the tool SetupDiag
  1. Open the website SetupDiag Download Page
  2. Click the Download SetupDiag button.
  3. Create a new folder on your Desktop and nove the file SetupDiag.exe to that folder.
  4. Right-click the "SetupDiag.exe" and click Run as administrator.
  5. When completed, three files are created, "Log.zip," "SetupDiag.exe.config," and "SetupDiagResults.log" in the folder SetupDiag.exe was executed.
  6. Attach only the file "SetupDiagResults.log" to your next reply.
It had a window popup, "This program might not have installed correctly" Options "Reinstall using recommended settings" or "This program installed correctly". It only created 2 files so far [SetupDiag.exe.config] and [SetupDiagResults.log]. I attached the files you wanted and leaving the message on the screen for the time being.
1. Click the Start button and then type cmd in the searchbox. Right-click on cmd that comes up in the search results and select Run as administrator.
2. A User Account Control dialog may come up asking for approval. If it does go ahead and allow.
3. A command prompt window will open. Copy and paste the following into the command-prompt and hit enter.
wmic service get name,displayname,pathname,startmode,exitcode > "%USERPROFILE%\desktop\services.txt"
4. After the command runs there will be a file on your desktop named services.txt.
5. Attach this file to your next reply.
  2. Download the attachment fixlist.txt and save it to your desktop.
  3. Right-click on FRST64.exe and select "Run as administrator".
  4. Press the Fix button.
  5. The tool will now process fixlist.txt.
  6. If for some reason the tool needs a restart, please make sure you let the system restart normally. After that let the tool complete its run.
  7. When finished, a log called Fixlog.txt will appear in the same directory the tool is run from.
  8. Post the logfile Fixlog.txt as attachment in your next reply.
When I first went to Control Panel \ Windows Update it showed the same message as the below red message. I closed the window and went back into Windows update and it then said Checking for updates. Now it shows the green message below.
Try to install KB4481252 only and report the result.
Try to install KB4539601 only and report the result.
Do not run anything but attach the zipped cbs.log to your next reply.
Attach the file C:\Windows\Logs\CBS\CbsPersist_20200909213201.cab to your next reply.
Remove Update Manually
    wusa /uninstall /KB:4530734
FRST Registry Search
  3. Select the Programs group.
  6. Copy and paste KB4530734 into the Search box and click the Search Registry button.
