Running DISM- CBS MUM Missing Total count 1691
  3. Press the Fix button.
Restart the computer.
If it fails, attach the zipped cbs.log to your next reply.
Fix ran fine. I restarted computer. Opened windows update first time and it still shows the failure from before. I closed windows update and opened it again and it checks for updates and now shows 1 important update (Windows Malicious software removal tool x64 - v5.83 KB890830) and 8 optional updates.
Install KB890830 only.
Which optional updates are listed ?
You may install the 2 optional printer updates if you like. Skip the rest of the optional updates.
