Security and Quality Rollup for .NET Framework (KB4471987) Fails
I did this:
Unfortunately same thing happened.
I rebooted and got the same error.
I ran the "NetFxRepairTool.exe" got the same error.
I then ran "NDP472-KB4054530-x86-x64-AllOS-ENU.exe" and chose repair, no change same error.
  • Use the Windows key + R to open a run command
  • Type regedit.exe and press OK
  • Navigate to: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer
  • Check if following registry keys have correct values:
    MsiExecCA32 should end with \Windows\syswow64\msiexec.exe
    MsiExecCA64 should end with \Windows\system32\msiexec.exe
  • If those are correct, then highlight one and go to Edit > Permissions and verify that SYSTEM and Administrators have Full Control and not just Read permissions
    Repeat for the other key
  • If you had to make changes to the registry, restart the computer or server and try the installation again
I could not check permissions on:
My choices were: modify, modify binary data, delete and rename
I could only check permissions on "
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer" itself:
This seemed to meet your instructions.
Did I misunderstand your directions?
I removed them all, then reinstalled "4NDP472-KB4054531-Web.exe" after that it is still the same. The update fails the same way.
Thanks
Please run the following again:
Using the .NET Collect Utility
  1. Download collect.exe and save to your desktop.
  2. Go ahead and run the tool
  3. The utility creates a compressed cabinet of all the needed logs to %TEMP%\vslogs.cab.
  4. Please zip/attach to this post or if too large, send using a service such as SendSpace.
Please include your CBS.log as well.
FRST Registry Search
3. Select the Programs group.
4. Click the Turn Windows features on or off link. This will bring up the Windows Features dialog. Wait until this dialog populates with information. If this does not happen for some reason, please continue with the steps anyway.
Note: This loads your components hive which is what we want. Please keep this dialog open while you perform the remaining steps.
5. Please download Farbar Recovery Scan Tool and save it to your Desktop.
7. Copy and paste
.NET Framework into the Search box and click the Search Registry button.
8. When the scan is complete a notepad window will open with the results. Please attach this to your next reply. It is saved on your desktop named SearchReg.txt.
Step#1 - FRST Fix
I apologize for the delay. I think I followed correctly:
When I "Run *FRST64* by *Right-Clicking *on the file and choosing *Run as administrator*"
Pressed OK on failed to update:
Not sure if the program was hung up, I let it run for awhile and finally closed it with task manager.
I then rebooted and ran the update and got the same failure as earlier.
View attachment CBS.log
Thanks
