[SOLVED] SFC and DISM cannot fix files -Ran SFCfix - Need Help.
Thanks.
Step#1 - FRST Fix
WOW!
C:\WINDOWS\system32>DISM.exe /Online /Cleanup-Image /RestoreHealth
Version: 6.3.9600.19408
Image Version: 6.3.9600.19397
The restore operation completed successfully. The component store corruption was
repaired.
DISM log enclosed.
Verification 100% complete.
CBS log attached.
Is it really fixed?
KT
77 important update completed - No issues.
rebooted, ran sfc /scannow again no issues.
Unreal!
Is there anything else I need to do?
Thank you so much for your help.
KT
