[SOLVED] sfc /scannow problem!
Atributes (SMART)
No errors or pink attributes, results posted on first page/last post of thread! :thumbsup2:
Okay, is the following directory: amd64_netfx-aspnet_webadmin_wizard_b03f5f7f11d50a3a_10.0.17763.1_none_db4564d010e1856f present in the C:\Windows\WinSxS directory?
Step#1 - ChkDsk Scan
  1. Click your Start Orb in the lower left of your computer and type cmd in the search box.
  2. Once the cmd program is found, right-click on it with your mouse and select Run as administrator as shown below.
  3. Answer Yes when asked to allow.
  4. You should now have a black window open that you can type in to.
  5. Please type chkdsk /f and then press enter.
  6. Chkdsk will start to run. Please allow it to finish.
  7. Download ListChkdskResult.exe by SleepyDude and save it on your desktop. If it's already downloaded to your desktop, just skip this step.
  8. Right-click this file and select Run as administrator (Allow if prompted) and a text file will open (and also be saved on the desktop as ListChkdskResult.txt).
Please copy the contents of this file and paste into your next post.
After running chkdsk /f & allowing it to finish on a restart, then running ListChkdskResult.exe as admin, I recieved this error:
43664
Here is the chkdsk /f result:
Log Name: Application
Source: Microsoft-Windows-Wininit
Date: 10/02/2019 23:25:51
Event ID: 1001
Task Category: None
Level: Information
Keywords: Classic
User: N/A
Computer: Jims-Laptop
Description:
Checking file system on C:
Volume label is Windows.
Stage 1: Examining basic file system structure ...
515584 file records processed.
File verification completed.
4877 large file records processed.
0 bad file records processed.
Stage 2: Examining file name linkage ...
1797 reparse records processed.
626614 index entries processed.
Index verification completed.
0 unindexed files scanned.
0 unindexed files recovered to lost and found.
Stage 3: Examining security descriptors ...
Cleaning up 6377 unused index entries from index $SII of file 0x9.
Cleaning up 6377 unused index entries from index $SDH of file 0x9.
Cleaning up 6377 unused security descriptors.
CHKDSK is compacting the security descriptor stream
55516 data files processed.
34245152 USN bytes processed.
Correcting errors in the Volume Bitmap.
No further action is required.
960632831 KB total disk space.
101447728 KB in 280186 files.
171756 KB in 55519 indexes.
0 KB in bad sectors.
646863 KB in use by the system.
858366484 KB available on disk.
240158207 total allocation units on disk.
214591621 allocation units available on disk.
Internal Info:
00 de 07 00 58 1f 05 00 69 46 09 00 00 00 00 00 ....X...iF......
c4 05 00 00 41 01 00 00 00 00 00 00 00 00 00 00 ....A...........
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Microsoft-Windows-Wininit" Guid="{206f6dea-d3c5-4d10-bc72-989f03c8b84b}" EventSourceName="Wininit" />
<EventID Qualifiers="16384">1001</EventID>
<Version>0</Version>
<Level>4</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2019-02-10T23:25:51.873619400Z" />
<EventRecordID>26588</EventRecordID>
<Correlation />
<Execution ProcessID="0" ThreadID="0" />
<Channel>Application</Channel>
<Computer>Jims-Laptop</Computer>
<Security />
</System>
<EventData>
<Data>
Internal Info:
</Data>
</EventData>
</Event>
Good. Please run SFC Scan again and attach CBS.log to see if this has made any changes.
Unfortunately sfc /scannow still stops at 59% with the same "Windows Resource Protection could not perform the requested operation" error!
CBS log file is attatched.
Step#1 - FRST Fix
  1. Run FRST64 by Right-Clicking on the file and choosing Run as administrator.
  2. Press the Fix button just once and wait. If for some reason the tool needs a restart, please make sure you let the system restart normally. After that let the tool complete its run.
  3. When finished FRST64 will generate a log on the Desktop (Fixlog.txt). Please post the contents of it in your reply.
Step#1 - FRST Fix
In either case, it won't save a (Fixlog.txt) to my desktop!?
1:
43855
2:
43856
3:
43857
4:
43858
