Sysnative Windows Update
Inactive
- Oct 9, 2014
- 741
Can you describe what you do step by step?
If I do an in-place upgrade, which option ( Upgrade this PC now or Create installation media for another PC ) would be best for my circumstancesIs it an option for you to do an In-Place upgrade? It would fix your issue and all of your data would be left exactly as it is right now.
Well now, so after much hesitation I finally went ahead with an in-place upgrade! I used the Media Creation Tool to create an ISO, & used that method for perhaps less updates!? Whoever said the process is relatively quick & easy (that's all I've been reading in various guides!) is LYING! , It took nearly 3hrs to complete, & froze at 42% then 84%, after & including re-starts! I panicked a lot BUT, cut a long story short, check this out:==>>It makes no difference.
You can select either. If you select upgrade this PC now, the tool will automatically download and try to upgrade the machine, which should work. However, in case it fails, you might be better with having the iso to upgrade from in order to save time in case of (eventual) troubleshooting.
