[SOLVED] SFC will not run / Missing Features / Corrupt SURT count: 288
Thanks.
Retrieve Components Hive
When able, do the following:
Install Update with DISM
  1. Download this update and save to your desktop. The file name will be Windows6.1-KB4056894-x64.cab.zip.
  2. Right-click on this file and select Extract All... Click the Extract button. You can close the folder window that opens
  4. When you see Command Prompt on the list, right-click on it and select Run as administrator. Go ahead and allow if you receive the UAC prompt.
  5. Copy and paste the following command into the command prompt window and press enter.
    dism /online /add-package /packagepath:%userprofile%\desktop\Windows6.1-KB4056894-x64.cab
    Restart Windows to complete this operation. <---You may not get this line.
    Do you want to restart the computer now (Y/N)? <---You may not get this line.
Go ahead and do so if prompted. Let me know what errors if any come up. If you do get errors, please zip/attach your CBS.log
That update finished. I have had that update or one like it failing for about a year, each time I would restart my computer it would try to install an update and then roll back the update and restart. I developed a habit of leaving my computer on just so I did not have to go through that every single time. finally I got sick of the issue and decided to fix it as I work on windows machines every day. I am very thankful for your service. during the process with the other Gent I also noticed my programs and features menu was empty and corrupt, over the course of this repair with you that has returned to good health. Please accept my Gratitude.
do you recommend doing the optional updates as well ?
Thanks for the kind words. We were happy to help!
No, I would not do optional updates as they can often cause issues. I would recommend you upgrade to Windows 10 as Windows 7 is going to end its support in 4 months.
Thank you for that, Is windows 10 compatible with software written for windows 7 in general ?
