[SOLVED] Twenty thousand errors in CBS
Step 1: Install Update with DISM
  1. Download the update MSU here: https://download.microsoft.com/down...467-8006D0677905/Windows6.1-KB3083710-x64.msu
    cd C:\temp
    expand Windows6.1-KB3083710-x64.msu -f:* C:\temp
    DISM.exe /Online /Add-Package /PackagePath:C:\temp\Windows6.1-KB3083710-x64.cab
  9. Paste (Ctrl+V) it into your next post.
  10. Zip and attach C:\Windows\Logs\CBS\CBS.log
  1. Download the update MSU here: https://download.microsoft.com/down...6F1-B25B137E3C87/Windows6.1-KB3102810-x64.msu
    cd C:\temp
    expand Windows6.1-KB3102810-x64.msu -f:* C:\temp
    DISM.exe /Online /Add-Package /PackagePath:C:\temp\Windows6.1-KB3102810-x64.cab
  1. Download the update MSU here: https://download.microsoft.com/down...-6388FF7968AD/Windows6.1-KB3065987-v2-x64.msu
    cd C:\temp
    expand Windows6.1-KB3065987-v2-x64.msu -f:* C:\temp
    DISM.exe /Online /Add-Package /PackagePath:C:\temp\Windows6.1-KB3065987-v2-x64.cab
Looking good so far.
    cd C:\temp
This fix has been done in the last round. Should something else be downloaded and added in this new round?
Yes, there are more updates that need to be fixed. Please run the SURT tool in step 2 also so I can see if the fix worked or not.
  1. Download the update MSU here: https://download.microsoft.com/down...199-5B335EE092F6/Windows6.1-KB3112343-x64.msu
    cd C:\temp
    expand Windows6.1-KB3112343-x64.msu -f:* C:\temp
    DISM.exe /Online /Add-Package /PackagePath:C:\temp\Windows6.1-KB3112343-x64.cab
  1. Download the update MSU here: https://download.microsoft.com/down...14F-D8B6B9996683/Windows6.1-KB2990214-x64.msu
    cd C:\temp
    expand Windows6.1-KB2990214-x64.msu -f:* C:\temp
    DISM.exe /Online /Add-Package /PackagePath:C:\temp\Windows6.1-KB2990214-x64.cab
  1. Download the update MSU here: https://download.microsoft.com/down...F46-696D4437254B/Windows6.1-KB3083324-x64.msu
    cd C:\temp
    expand Windows6.1-KB3083324-x64.msu -f:* C:\temp
    DISM.exe /Online /Add-Package /PackagePath:C:\temp\Windows6.1-KB3083324-x64.cab
  1. Download the update MSU here: https://download.microsoft.com/down...7DF-B6A7D187F0B7/Windows6.1-KB3135445-x64.msu
    cd C:\temp
    expand Windows6.1-KB3135445-x64.msu -f:* C:\temp
    DISM.exe /Online /Add-Package /PackagePath:C:\temp\Windows6.1-KB3135445-x64.cab
  1. Download the update MSU here: https://download.microsoft.com/down...EA0-BEB0B90C2099/Windows6.1-KB3075851-x64.msu
    cd C:\temp
    expand Windows6.1-KB3075851-x64.msu -f:* C:\temp
    DISM.exe /Online /Add-Package /PackagePath:C:\temp\Windows6.1-KB3075851-x64.cab
  1. Go to Download Cumulative Security Update for Internet Explorer 11 for Windows 7 for x64-based Systems (KB3134814) from Official Microsoft Download Center and download both .MSU files.
  2. Copy both MSU files to a convenient location (such as C:\temp).
    cd C:\temp
    expand IE11-Windows6.1-KB3134814-x64.msu -f:* C:\temp
    DISM.exe /Online /Add-Package /PackagePath:C:\temp\IE11-Windows6.1-KB3134814-x64.cab
  8. Copy and paste the following commands also in the command prompt, press enter after each
    cd C:\temp
    expand IE11-Windows6.1-KB3141092-x64.msu -f:* C:\temp
    DISM.exe /Online /Add-Package /PackagePath:C:\temp\IE11-Windows6.1-KB3141092-x64.cab
  9. You should receive the message:
  10. Make sure to allow the computer to restart if prompted.
