[SOLVED] Twenty thousand errors in CBS
Install Update with DISM
  1. Download the update MSU here: https://download.microsoft.com/down...178-4B400B24D7C8/Windows6.1-KB3146706-x64.msu
    cd C:\temp
    expand Windows6.1-KB3146706-x64.msu -f:* C:\temp
    DISM.exe /Online /Add-Package /PackagePath:C:\temp\Windows6.1-KB3146706-x64.cab
  9. Paste (Ctrl+V) it into your next post.
  10. Zip and attach C:\Windows\Logs\CBS\CBS.log
  1. Download the update MSU here: http://download.windowsupdate.com/c..._b61f7c48461c725b8b6fc642d482fc496747c160.msu
    cd C:\temp
    expand windows6.1-kb3210131-x64_b61f7c48461c725b8b6fc642d482fc496747c160.msu -f:* C:\temp
    DISM.exe /Online /Add-Package /PackagePath:C:\temp\windows6.1-kb3210131-x64.cab
Hi Peter. Here is the new CheckSUR log. It seems there are eight more updates to be installed. Is it a good idea that you show me the download links for all the packages and I install them one by one? Of course I'll review the CheckSUR.log each time to see whether the number of the missing items is reduced steadily as expected and report to you if anything is abnormal.
I don't have the links at the moment. Still searching.
  1. Go to Download Security Update for Microsoft .NET Framework 3.5.1 on Windows 7 Service Pack 1 and Windows Server 2008 R2 Service Pack 1 from Official Microsoft Download Center and download the file Windows6.1-KB3142024-x64.msu.
    cd C:\temp
    expand Windows6.1-KB3142024-x64.msu -f:* C:\temp
    DISM.exe /Online /Add-Package /PackagePath:C:\temp\Windows6.1-KB3142024-x64.cab
Thanks Peter. No problem. We'll continue to do the fixes one by one. The new CheckSUR.log is attached.
FRST Registry Search
  3. Select the Programs group.
  6. Copy and paste 6.1.7601.18839 into the Search box and click the Search Registry button.
Remove Update Manually
    wusa /uninstall /KB:3022345
It returned the message "The update KB3022345 is not installed on this computer"
  6. Copy and paste KB3022345 into the Search box and click the Search Registry button.
  3. Press the Fix button.
Lets restore some of the removed registry values first.
Hi Peter, the CheckSUR(32).log has the least number of errors so I restored the system to the state right before the fix #93. After the restoration, SURT returned a CheckSUR.log which is exactly the same as the CheckSUR(32).log (with only 45 errors). I prepared a system image before the restoration so we can easily reverse the restoration if necessary.
Hi Peter, I should report to you a good news. Today I tried to install the newest Security Monthly Quality Rollup (KB4493472). Out of my expectation, the installation went through successfully without a single problem. While one cannot exclude the possibility that Microsoft did something unique with this rollup (you know better about it), the fixes in the past two weeks under your guidance certainly played an important role for the success. After installing the update, I ran SURT again, which returned exactly the same CheckSUR.log as before with 45 errors concerning missing deployment keys. Are these errors of a practical significance? Please let me know how to proceed from this point. Thank you very much.
