update and shutting down problem
Restart the machine.
When Windows shows the desktop try to shutdown Windows. Does that work normally ?
If not, restart the machine again.
When Windows shows the desktop open the Task-manager and post screenshot(s) of all items on the tab "Processes".
1.It doesn't work normally.
2.I restarted the machine again and here is screenshot of all items on the tab "Processes".
In the screenshot click "Show processes from all users".
Post a new screenshot or screenshots when not all visible in one.
Here is two screenshots of all processes.
Select the entry mdm.exe *32 then click the button "End Process".
Next, try to shutdown the machine again and report the result.
I did as you told me, but nothing happened, again stuck on shutting down.
When I restarted the computer, and hit ctrl+alt+del mdm.exe*32 appeared again on the tab Processes.
That is not a problem.
Post a screenshot of the tab "Applications".
First screenshot is the tab "Applications".
I'm sending you screenshots of the tab "Services" in case you need it.
  3. Press the Fix button.
Reboot the machine and check the shutdown issue.
