xperf -d "%userprofile%\Desktop\trace.etl"
.Hello,Hi!
In the elevated command prompt, launchxperf -d "%userprofile%\Desktop\trace.etl"
Wait until the cursor reappears.
Then re-try to generate the trace.
wpr -start generalprofile -start audio -start video
wpr -stop "%userprofile%\desktop\trace.etl" -skipPdbGen
Thanks, it has helped.Re-try with this other method, always from an elevated command prompt:wpr -start generalprofile -start audio -start video
Wait some minutes during the stuttering, then:wpr -stop "%userprofile%\desktop\trace.etl" -skipPdbGen
Zip the trace up and upload the new trace.
dism /online /cleanup-image /checkhealth
dism /online /cleanup-image /restorehealth
SFC /scannow
DISM system Version: 10.0.19041.844 Image version: 10.0.19045.2846 No component store corruption detected. Operation completed successfully.Let's see the results of SFC and dism.
Open a command prompt as administrator, copy/paste this command in it and run it:dism /online /cleanup-image /checkhealth
If the result says that the component store is repairable, run also the following command; otherwise don't run it:dism /online /cleanup-image /restorehealth
Paste here its (or their) result.
Then run also:SFC /scannow
Paste here its result.
No, there are not errors.It is ok, so skipped this dism /online /cleanup-image /restorehealth Should I run it anyway?
dxdiag /whql:off /t "%userprofile%\desktop\logs\dxdiag.txt"
msinfo32 /nfo "%userprofile%\desktop\logs\MsInfo.nfo"
systeminfo > "%userprofile%\desktop\logs\SystemInfo.txt"
(tasklist /v /fo table && tasklist /svc /fo table && tasklist /m /fo table) > "%userprofile%\desktop\logs\tasklist.txt"
wevtutil epl system "%userprofile%\desktop\logs\system.evtx"
wevtutil epl application "%userprofile%\desktop\logs\application.evtx"
move c:\windows\memory.dmp "%userprofile%\desktop\logs"
move c:\windows\minidump\* "%userprofile%\desktop\logs"
after this dxdiag /whqlff /t "%userprofile%\desktop\logs\dxdiag.txt" no issues, but no files appeared on the desktop.No, there are not errors.
Launch the following commands from an elevated command prompt.
At the end, you should find at least 6 files in the logs folder on your desktop.
Zip the logs folder up and upload it here.
If you get errors, post them.
Code:dxdiag /whql:off /t "%userprofile%\desktop\logs\dxdiag.txt" msinfo32 /nfo "%userprofile%\desktop\logs\MsInfo.nfo" systeminfo > "%userprofile%\desktop\logs\SystemInfo.txt" (tasklist /v /fo table && tasklist /svc /fo table && tasklist /m /fo table) > "%userprofile%\desktop\logs\tasklist.txt" wevtutil epl system "%userprofile%\desktop\logs\system.evtx" wevtutil epl application "%userprofile%\desktop\logs\application.evtx" move c:\windows\memory.dmp "%userprofile%\desktop\logs" move c:\windows\minidump\* "%userprofile%\desktop\logs"
The specified file cannot be found.move c:\windows\minidump\* "%userprofile%\desktop\logs"
dxdiag /whql:off /t "c:\users\your-user-name\desktop\logs\dxdiag.txt"
msinfo32 /nfo "c:\users\your-user-name\desktop\logs\MsInfo.nfo"
systeminfo > "c:\users\your-user-name\desktop\logs\SystemInfo.txt"
(tasklist /v /fo table && tasklist /svc /fo table && tasklist /m /fo table) > "c:\users\your-user-name\desktop\logs\tasklist.txt"
wevtutil epl system "c:\users\your-user-name\desktop\logs\system.evtx"
wevtutil epl application "c:\users\your-user-name\desktop\logs\application.evtx"
move c:\windows\memory.dmp "c:\users\your-user-name\desktop\logs"
move c:\windows\minidump\* "c:\users\your-user-name\desktop\logs"
Great!
Re-try the same commands, this time with c:\users\your-user-name in place of %userprofile%.
(Your-user-name is obviously the user name of your profile in windows, you shouldn't use your-user-name for real...)
Code:dxdiag /whql:off /t "c:\users\your-user-name\desktop\logs\dxdiag.txt" msinfo32 /nfo "c:\users\your-user-name\desktop\logs\MsInfo.nfo" systeminfo > "c:\users\your-user-name\desktop\logs\SystemInfo.txt" (tasklist /v /fo table && tasklist /svc /fo table && tasklist /m /fo table) > "c:\users\your-user-name\desktop\logs\tasklist.txt" wevtutil epl system "c:\users\your-user-name\desktop\logs\system.evtx" wevtutil epl application "c:\users\your-user-name\desktop\logs\application.evtx" move c:\windows\memory.dmp "c:\users\your-user-name\desktop\logs" move c:\windows\minidump\* "c:\users\your-user-name\desktop\logs"
md "%userprofile%\desktop\logs"
With md it started working, I so that I saw it prepared some data, gathered, etc. but two last comands finished unsuccessfully, it can't find the file. Could you advise what to change in the commands?Sorry!!! I forgot a command!!!
It needs the logs folder on the desktop, already created!
I added the command, now it should work:Code:md "%userprofile%\desktop\logs" dxdiag /whql:off /t "%userprofile%\desktop\logs\dxdiag.txt" msinfo32 /nfo "%userprofile%\desktop\logs\MsInfo.nfo" systeminfo > "%userprofile%\desktop\logs\SystemInfo.txt" (tasklist /v /fo table && tasklist /svc /fo table && tasklist /m /fo table) > "%userprofile%\desktop\logs\tasklist.txt" wevtutil epl system "%userprofile%\desktop\logs\system.evtx" wevtutil epl application "%userprofile%\desktop\logs\application.evtx" move c:\windows\memory.dmp "%userprofile%\desktop\logs" move c:\windows\minidump\* "%userprofile%\desktop\logs"
Good! But the PC has regular system interruptions and usually works near a 100% of CPU capacity even with a few open tabs in a broswer.Because you don't have dumps or minidumps (results of bsods), hence it's a good thing.
It appeared it created a seperate folder called desktop, that's why I didnt see it on the Desktop.If you have 6 files in the logs folder, zip it up and post it here.
Thank you very much!Most errors come from the intel network adapter (intel dual band wireless-ac 3168).
Try to install the latest drivers: https://downloadmirror.intel.com/777183/WiFi-22.220.0-Driver64-Win10-Win11.exe
(Here, if the link shouldn't work: Windows® 10 and Windows 11* Wi-Fi Drivers for Intel® Wireless Adapters)
Are there other PCs that connects to your connection?
The other error comes from GPU nvidia GeForce 920MX.
Did you disable it?
